[Mapbender-commits] r2899 - branches/2.5/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Sep 1 04:06:38 EDT 2008
Author: astrid_emde
Date: 2008-09-01 04:06:38 -0400 (Mon, 01 Sep 2008)
New Revision: 2899
   branches/2.5/http/classes/class_wmc.php
column wmc_id is of type varchar, therefore array("s") has to be used instead of array("i")
Modified: branches/2.5/http/classes/class_wmc.php
--- branches/2.5/http/classes/class_wmc.php	2008-08-29 10:30:48 UTC (rev 2898)
+++ branches/2.5/http/classes/class_wmc.php	2008-09-01 08:06:38 UTC (rev 2899)
@@ -665,7 +665,7 @@
 	$sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1";
 	$v = array($wmc_id);
-	$t = array("i");
+	$t = array("s");
 	$res = db_prep_query($sql, $v, $t);
 	$wmc = db_fetch_row($res);
 	$this->createObjFromWMC_xml($wmc[0]);
More information about the Mapbender_commits mailing list
