[Mapbender-commits] r2902 - in branches/2.5/http: html javascripts
svn_mapbender at osgeo.org
Mon Sep 1 09:56:04 EDT 2008
Author: nimix
Date: 2008-09-01 09:56:03 -0400 (Mon, 01 Sep 2008)
New Revision: 2902
branches/2.5/http/html/mod_treefolder2.php
branches/2.5/http/javascripts/map_obj.js
fix FI selection bug
http://trac.osgeo.org/mapbender/ticket/219
Modified: branches/2.5/http/html/mod_treefolder2.php
--- branches/2.5/http/html/mod_treefolder2.php 2008-09-01 13:23:08 UTC (rev 2901)
+++ branches/2.5/http/html/mod_treefolder2.php 2008-09-01 13:56:03 UTC (rev 2902)
@@ -1,609 +1,611 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/Mod_treefolder2.php
-# Copyright (C) 2007 Melchior Moos
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/Mod_treefolder2.php
+# Copyright (C) 2007 Melchior Moos
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-$gui_id = $_SESSION["mb_user_gui"];
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">
-<HTML>
-<HEAD>
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<TITLE>Treefolder</TITLE>
-<?php
- include '../include/dyn_css.php';
-<script language='JavaScript'>
-function openwindow(Adresse) {
-Fenster1 = window.open(Adresse, "Informationen", "width=500,height=500,left=100,top=100,scrollbars=yes,resizable=no");
-Fenster1.focus();
-</script>
-<script src="../javascripts/jsTree.js" type="text/javascript" language="JavaScript"></script>
-<?php
-echo "<script language='JavaScript'>";
- $sql = "SELECT e_target FROM gui_element WHERE e_id = $1 AND fkey_gui_id = $2";
- $v = array($_REQUEST['e_id_css'],$_SESSION["mb_user_gui"]);
- $t = array('s','s');
- $res = db_prep_query($sql,$v,$t);
- $e_target = db_result($res,0,"e_target");
- echo "mod_treeGDE_map = '".$e_target."';";
-echo "</script>";
-<SCRIPT language="JavaScript" type="text/javascript">
-var jst_container = "document.getElementById('treeContainer')";
-var jst_image_folder = imagedir;
-var jst_display_root = false;
-var defaultTarget = 'examplemain';
-var lock=false;
-var lock_update=false;
-var lock_check=false;
-var selectedMap=-1;
-var selectedWMS=-1;
-var selectedLayer=-1;
-var init=false;
-var errors = 0;
-var state=Array();
-var treeState = "";
-var arrNodes =
- ['root_id', ['Layer','javascript:_foo()']
-function _foo(){}
-// some defaults
-try{if (reverse){}}catch(e){reverse = 'false';}
-try{if (switchwms){}}catch(e){switchwms = 'true';}
-try{if (ficheckbox){}}catch(e){ficheckbox = 'false';}
-try{if (metadatalink){}}catch(e){metadatalink = 'false';}
-try{if (wmsbuttons){}}catch(e){wmsbuttons = 'false';}
-try{if (showstatus){}}catch(e){showstatus = 'false';}
-try{if (alerterror){}}catch(e){alerterror = 'false';}
-try{if (openfolder){}}catch(e){openfolder = 'false';}
-try{if (handlesublayer){}}catch(e){handlesublayer = 'false';}
-try{if (menu){}}catch(e){menu = '';}
-try {
- if (redirectToMetadataUrl) {
- if (redirectToMetadataUrl == "false") {
- redirectToMetadataUrl = false;
- else {
- redirectToMetadataUrl = true;
-catch (e) {
- var redirectToMetadataUrl = true;
-var defaultMetadataUrl = '../php/mod_layerMetadata.php?';
-if (redirectToMetadataUrl) {
- defaultMetadataUrl += 'redirectToMetadataUrl=1';
-else {
- defaultMetadataUrl += 'redirectToMetadataUrl=0';
-//menu elements
-var menu_move_up = ['menu_move_up', ['Move up ','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];move_up(ids[0],ids[1],ids[2]);',,'move_up.png']];
-var menu_move_down = ['menu_move_down', ['Move down ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];move_down(ids[0],ids[1],ids[2]);',,'move_down.png']];
-var menu_delete = ['menu_delete', ['Remove ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];remove_wms(ids[0],ids[1],ids[2]);',,'delete_wms.png']];
-var menu_opacity_up = ['menu_opacity_up', ['Opacity up ','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];opacity_up(ids[0],ids[1],ids[2]);',,'move_up.png']];
-var menu_opacity_down = ['menu_opacity_down', ['Opacity down ','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];opacity_down(ids[0],ids[1],ids[2]);',,'move_down.png']];
-var menu_metalink = ['menu_metalink', ['Information ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[ids[0]].wms[ids[1]].objLayer[ids[2]].layer_uid);',,'info.png']];
-var menu_zoom = ['menu_zoom', ['Zoom ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];zoomToLayer(ids[0],ids[1],ids[2]);',,'zoom.png']];
-var menu_hide = ['menu_hide', ['Hide menu ', 'javascript:hideMenu()',,'hide.png']];
-//var menu_wms_switch = ['menu_zoom', ['Zoom ', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid);',,'info.png']];
-//var menu_layer_switch = ['menu_zoom', ['Zjjj ', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid);',,'info.png']];
-//var menu_info_switch = ['menu_zoom', ['Zmn ', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid);',,'info.png']];
-parent.eventAfterLoadWMS.register(reloadTree);
+$gui_id = $_SESSION["mb_user_gui"];
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">
+<HTML>
+<HEAD>
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<TITLE>Treefolder</TITLE>
+<?php
+ include '../include/dyn_css.php';
+<script language='JavaScript'>
+function openwindow(Adresse) {
+Fenster1 = window.open(Adresse, "Informationen", "width=500,height=500,left=100,top=100,scrollbars=yes,resizable=no");
+Fenster1.focus();
+</script>
+<script src="../javascripts/jsTree.js" type="text/javascript" language="JavaScript"></script>
+<?php
+echo "<script language='JavaScript'>";
+ $sql = "SELECT e_target FROM gui_element WHERE e_id = $1 AND fkey_gui_id = $2";
+ $v = array($_REQUEST['e_id_css'],$_SESSION["mb_user_gui"]);
+ $t = array('s','s');
+ $res = db_prep_query($sql,$v,$t);
+ $e_target = db_result($res,0,"e_target");
+ echo "mod_treeGDE_map = '".$e_target."';";
+echo "</script>";
+<SCRIPT language="JavaScript" type="text/javascript">
+var jst_container = "document.getElementById('treeContainer')";
+var jst_image_folder = imagedir;
+var jst_display_root = false;
+var defaultTarget = 'examplemain';
+var lock=false;
+var lock_update=false;
+var lock_check=false;
+var selectedMap=-1;
+var selectedWMS=-1;
+var selectedLayer=-1;
+var init=false;
+var errors = 0;
+var state=Array();
+var treeState = "";
+var arrNodes =
+ ['root_id', ['Layer','javascript:_foo()']
+function _foo(){}
+// some defaults
+try{if (reverse){}}catch(e){reverse = 'false';}
+try{if (switchwms){}}catch(e){switchwms = 'true';}
+try{if (ficheckbox){}}catch(e){ficheckbox = 'false';}
+try{if (metadatalink){}}catch(e){metadatalink = 'false';}
+try{if (wmsbuttons){}}catch(e){wmsbuttons = 'false';}
+try{if (showstatus){}}catch(e){showstatus = 'false';}
+try{if (alerterror){}}catch(e){alerterror = 'false';}
+try{if (openfolder){}}catch(e){openfolder = 'false';}
+try{if (handlesublayer){}}catch(e){handlesublayer = 'false';}
+try{if (menu){}}catch(e){menu = '';}
+try {
+ if (redirectToMetadataUrl) {
+ if (redirectToMetadataUrl == "false") {
+ redirectToMetadataUrl = false;
+ else {
+ redirectToMetadataUrl = true;
+catch (e) {
+ var redirectToMetadataUrl = true;
+var defaultMetadataUrl = '../php/mod_layerMetadata.php?';
+if (redirectToMetadataUrl) {
+ defaultMetadataUrl += 'redirectToMetadataUrl=1';
+else {
+ defaultMetadataUrl += 'redirectToMetadataUrl=0';
+//menu elements
+var menu_move_up = ['menu_move_up', ['Move up ','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];move_up(ids[0],ids[1],ids[2]);',,'move_up.png']];
+var menu_move_down = ['menu_move_down', ['Move down ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];move_down(ids[0],ids[1],ids[2]);',,'move_down.png']];
+var menu_delete = ['menu_delete', ['Remove ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];remove_wms(ids[0],ids[1],ids[2]);',,'delete_wms.png']];
+var menu_opacity_up = ['menu_opacity_up', ['Opacity up ','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];opacity_up(ids[0],ids[1],ids[2]);',,'move_up.png']];
+var menu_opacity_down = ['menu_opacity_down', ['Opacity down ','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];opacity_down(ids[0],ids[1],ids[2]);',,'move_down.png']];
+var menu_metalink = ['menu_metalink', ['Information ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[ids[0]].wms[ids[1]].objLayer[ids[2]].layer_uid);',,'info.png']];
+var menu_zoom = ['menu_zoom', ['Zoom ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];zoomToLayer(ids[0],ids[1],ids[2]);',,'zoom.png']];
+var menu_hide = ['menu_hide', ['Hide menu ', 'javascript:hideMenu()',,'hide.png']];
+//var menu_wms_switch = ['menu_zoom', ['Zoom ', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid);',,'info.png']];
+//var menu_layer_switch = ['menu_zoom', ['Zjjj ', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid);',,'info.png']];
+//var menu_info_switch = ['menu_zoom', ['Zmn ', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow(defaultMetadataUrl + "&id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid);',,'info.png']];
+parent.eventAfterLoadWMS.register(reloadTree);
parent.eventInit.register(loadTree);
if(showstatus=='true'||alerterror=='true'){
parent.eventAfterMapRequest.register(init_mapcheck);
- init_mapcheck();
+ init_mapcheck();
parent.eventAfterMapRequest.register(updateScale);
-if(wmsbuttons != "true")
- jst_highlight = false;
-function select(i,ii,iii){
- //ignore if selected
- if(selectedMap==i && selectedWMS==ii && selectedLayer==iii)return;
- if(selectedMap==-1 && selectedWMS==-1 && selectedLayer==-1){
- selectedMap=i;
- selectedWMS=ii;
- selectedLayer=iii;
- return;
- //scalehints
- var scale = parseInt(parent.mb_getScale(mod_treeGDE_map));
- if(scale < parseInt(parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_minscale) && parseInt(parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_minscale) != 0){
- if(selectedLayer==0)
- setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].wms_id, '#999999');
- else
- setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].wms_id+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_id, '#999999');
- else if(scale > parseInt(parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_maxscale) && parseInt(parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_maxscale) != 0){
- else
- else{
- setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].wms_id, '');
- else
- setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].wms_id+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_id, '');
- selectedMap=i;
- selectedWMS=ii;
-function updateScale(){
- if(!init)return;
- for(var i=0; i<parent.mb_mapObj.length; i++){
- if(parent.mb_mapObj[i].frameName == mod_treeGDE_map){
- for(var ii=0; ii<parent.mb_mapObj[i].wms.length; ii++){
- for(var iii=1; iii<parent.mb_mapObj[i].wms[ii].objLayer.length; iii++){
- if(scale < parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_minscale) && parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_minscale) != 0){
- if(iii==0)
- setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[ii].wms_id, '#999999');
- else
- setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[ii].wms_id+"|"+parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_id, '#999999');
- else if(scale > parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_maxscale) && parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_maxscale) != 0){
- if(iii==0)
- else
- else{
- if(iii==0)
- setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[ii].wms_id, '');
- else
- setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[ii].wms_id+"|"+parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_id, '');
-function operaLoad(){
- initArray();
- renderTree();
- setTimeout('initWmsCheckboxen();updateScale();',100);
-function loadTree(){
- if(window.opera){
- setTimeout('operaLoad()',200);
- return;
- initArray();
- renderTree();
- initWmsCheckboxen();
- updateScale();
-function reloadTree(){
- if(!init) return;
- selectedMap=-1;
- selectedWMS=-1;
- selectedLayer=-1;
- init=false;
- arrNodes = [['root_id', ['Layer','javascript:_foo()']]];
- initArray();
- if(showstatus=='true'||alerterror=='true')
- init_mapcheck();
- renderTree();
- if(window.opera)
- else{
- updateScale();
-function imgerror(){
- var map=parent.getMapObjIndexByName(mod_treeGDE_map);
- var wms=Number(this.id.substr(4));
- this.onerror=null;
- this.onabort=null;
- if(state[wms]!=-1 && alerterror=='true'){
- state[wms]=-1;
- if(confirm('Failed to Load WMS "'+parent.mb_mapObj[map].wms[wms].objLayer[0].layer_title+'" from Server "'+parent.mb_mapObj[map].wms[wms].wms_getmap.substr(0,parent.mb_mapObj[map].wms[wms].wms_getmap.length-1)+'"\nDo you want to try to load it in a new window?')){
- window.open(this.src,"");
- state[wms]=-1;
- errors++;
- if(showstatus=='true')
- setNodeImage(arrNodes[0][0]+"|"+parent.mb_mapObj[map].wms[wms].wms_id, "error_folder.png");
-function checkComplete(wms, map, img, first){
- var ind=parent.getMapObjIndexByName(mod_treeGDE_map);
- if(parent.mb_mapObj[ind].wms[wms].mapURL == false || parent.frames[mod_treeGDE_map].document.getElementById(map).complete){
- if(state[wms]!=-1){
- for(var i=1;i<parent.mb_mapObj[ind].wms[wms].objLayer.length;i++){
- if(parent.mb_mapObj[ind].wms[wms].objLayer[i].gui_layer_visible==1){
- state[wms]=1;
- setNodeImage(img);
- break;
- else{
- if(first){
- state[wms]=0;
- parent.frames[mod_treeGDE_map].document.getElementById(map).onerror=imgerror;
- parent.frames[mod_treeGDE_map].document.getElementById(map).onabort=imgerror;
- setNodeImage(img, "loading_folder.gif");
- setTimeout('checkComplete('+wms+', "'+map+'", "'+img+'");',100);
-//parent.mb_registerWmsLoadErrorFunctions("window.frames['treeGDE'].imgerror();");
-function init_mapcheck(){
- if(!init)return;
- errors = 0;
- var ind = parent.getMapObjIndexByName(mod_treeGDE_map);
- if(!parent.mb_mapObj[ind]||!init){
- setTimeout("init_mapcheck();",100);
- return;
- for(var wms=0;wms<parent.mb_mapObj[ind].wms.length;wms++){
- var wmsimgid="map_"+wms;
- if(parent.frames[mod_treeGDE_map].document.getElementById(wmsimgid)){
- checkComplete(wms, wmsimgid, arrNodes[0][0]+'|'+parent.mb_mapObj[ind].wms[wms].wms_id, true);
-function handleSelectedLayer(mapObj,wms_id,layername,type,status){
- if(lock_update||lock_check)return;
- var ind = parent.getMapObjIndexByName(mapObj);
- for(var i=0; i<parent.mb_mapObj[ind].wms.length; i++){
- if(parent.mb_mapObj[ind].wms[i].wms_id == wms_id){
- parent.mb_mapObj[ind].wms[i].handleLayer(layername, type, status);
- break;
-function zoomToLayer(j,k,l){
- if(!j&&!k&&!l){
- j=selectedMap;
- k=selectedWMS;
- l=selectedLayer;
- var my=parent.mb_mapObj[j].wms[k].objLayer[l].layer_epsg;
- for (var i=0;i<my.length;i++){
- if(my[i]["epsg"]==parent.mb_mapObj[j].epsg){
- parent.mb_calculateExtent(mod_treeGDE_map,my[i]["minx"],my[i]["miny"],my[i]["maxx"],my[i]["maxy"]);
- var arrayExt = parent.mb_mapObj[j].extent.split(",");
- parent.mb_repaint(mod_treeGDE_map,arrayExt[0],arrayExt[1],arrayExt[2],arrayExt[3]);
- break;
-//---begin------------- opacity --------------------
-var opacityIncrement = 20;
-function opacity_up(j, k, l) {
- handleOpacity(j, k, opacityIncrement);
-function opacity_down(j, k, l) {
- handleOpacity(j, k, -opacityIncrement);
-function handleOpacity(mapObj_id, wms_id, increment) {
- var opacity = parent.mb_mapObj[mapObj_id].wms[wms_id].gui_wms_mapopacity*100 + increment;
- parent.mb_mapObj[mapObj_id].wms[wms_id].setOpacity(opacity);
- reloadTree();
-//---end------------- opacity --------------------
-function move_up(j,k,l){
- if(isNaN(j)&&isNaN(k)&&isNaN(l)){
- j=selectedMap;
- k=selectedWMS;
- l=selectedLayer;
- if(j==-1||k==-1||l==-1){
- alert("You have to select the WMS you want to move up!")
- return;
- var lid=parent.mb_mapObj[j].wms[k].objLayer[l].layer_id;
- if(!parent.mb_mapObj[j].move(parent.mb_mapObj[j].wms[k].wms_id,lid,(reverse=="true")?false:true)){
- alert("Illegal move operation");
- return;
- treeState = getState();
- parent.zoom(parent.mb_mapObj[j].frameName, true, 1.0);
- parent.mb_execloadWmsSubFunctions();
- //find layer and select
- for(k=0;k<parent.mb_mapObj[j].wms.length;k++){
- for(l=0;l<parent.mb_mapObj[j].wms[k].objLayer.length;l++){
- if(parent.mb_mapObj[j].wms[k].objLayer[l].layer_id==lid){
- select(j,k,l);
- if(l!=0)
- selectNode(String(lid));
- else
- selectNode(String(parent.mb_mapObj[j].wms[k].wms_id));
-function move_down(j,k,l){
- j=selectedMap;
- k=selectedWMS;
- l=selectedLayer;
- alert("You have to select the WMS you want to move down!")
- return;
- if(!parent.mb_mapObj[j].move(parent.mb_mapObj[j].wms[k].wms_id,lid,(reverse=="true")?true:false)){
- return;
- select(j,k,l);
- if(l!=0)
- else
-function remove_wms(j,k,l){
- j=selectedMap;
- k=selectedWMS;
- l=selectedLayer;
- alert("You have to select the WMS you want to delete!")
- return;
- if(l!=0){
- alert("It is not possible to delete a single layer, please select a WMS!")
- return;
- var visibleWMS=0;
- for(var i=0;i<parent.mb_mapObj[j].wms.length;i++)
- if(parent.mb_mapObj[j].wms[i].gui_wms_visible=='1'||parent.mb_mapObj[j].wms[i].gui_wms_visible==1)
- visibleWMS++;
- if(visibleWMS<=1){
- alert ("Last WMS can't be removed.\n(Der letzte WMS kann nicht entfernt werden.)");
- return;
- if(confirm('Are you sure you want to remove "'+parent.mb_mapObj[j].wms[k].objLayer[l].layer_title+'"?')){
- parent.mb_mapObjremoveWMS(j,k);
-function updateParent(path){
- if(lock_check)return;
- var reset_lock=!lock_update;
- lock_update=true;
- var state=getChildrenCheckState(path, 0);
- //enableCheckbox(path, (state!=-1)); //3rd state
- checkNode(path, 0, (state==1));
- if(state==0 && showstatus=='true' && path.split(jst_delimiter[0]).length == 2){
- setTimeout('setNodeImage("'+path+'", "error_folder.png");', 100);
- if(reset_lock)
- lock_update=false;
-function handleSelectedWMS(path){
- if(lock_update)return;
- var t = path.split("|");
- var reset_lock=!lock_check;
- var layername = parent.mb_mapObj[ind].wms[parent.getWMSIndexById(mod_treeGDE_map,t[t.length-1])].objLayer[0].layer_name;
- var bChk = IsChecked(path, 0);
- handleSelectedLayer(mod_treeGDE_map,t[t.length-1],layername,"visible",bChk?"1":"0");
- lock_check=true;
- checkChildren(path, 0, bChk);
- if(ficheckbox)checkChildren(path, 1, bChk);
- if(bChk==false && showstatus=='true')
- if(reset_lock)
- lock_check=false;
- parent.mb_restateLayers(mod_treeGDE_map,t[t.length-1]);
- parent.setSingleMapRequest(mod_treeGDE_map,t[t.length-1]);
+if(wmsbuttons != "true")
+ jst_highlight = false;
+function select(i,ii,iii){
+ //ignore if selected
+ if(selectedMap==i && selectedWMS==ii && selectedLayer==iii)return;
+ if(selectedMap==-1 && selectedWMS==-1 && selectedLayer==-1){
+ selectedMap=i;
+ selectedWMS=ii;
+ selectedLayer=iii;
+ return;
+ //scalehints
+ var scale = parseInt(parent.mb_getScale(mod_treeGDE_map));
+ if(scale < parseInt(parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_minscale) && parseInt(parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_minscale) != 0){
+ if(selectedLayer==0)
+ setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].wms_id, '#999999');
+ else
+ setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].wms_id+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_id, '#999999');
+ else if(scale > parseInt(parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_maxscale) && parseInt(parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_maxscale) != 0){
+ else
+ else{
+ setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].wms_id, '');
+ else
+ setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].wms_id+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_id, '');
+ selectedMap=i;
+ selectedWMS=ii;
+function updateScale(){
+ if(!init)return;
+ for(var i=0; i<parent.mb_mapObj.length; i++){
+ if(parent.mb_mapObj[i].frameName == mod_treeGDE_map){
+ for(var ii=0; ii<parent.mb_mapObj[i].wms.length; ii++){
+ for(var iii=1; iii<parent.mb_mapObj[i].wms[ii].objLayer.length; iii++){
+ if(scale < parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_minscale) && parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_minscale) != 0){
+ if(iii==0)
+ setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[ii].wms_id, '#999999');
+ else
+ setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[ii].wms_id+"|"+parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_id, '#999999');
+ else if(scale > parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_maxscale) && parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_maxscale) != 0){
+ if(iii==0)
+ else
+ else{
+ if(iii==0)
+ setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[ii].wms_id, '');
+ else
+ setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[ii].wms_id+"|"+parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_id, '');
+function operaLoad(){
+ initArray();
+ renderTree();
+ setTimeout('initWmsCheckboxen();updateScale();',100);
+function loadTree(){
+ if(window.opera){
+ setTimeout('operaLoad()',200);
+ return;
+ initArray();
+ renderTree();
+ initWmsCheckboxen();
+ updateScale();
+function reloadTree(){
+ if(!init) return;
+ selectedMap=-1;
+ selectedWMS=-1;
+ selectedLayer=-1;
+ init=false;
+ arrNodes = [['root_id', ['Layer','javascript:_foo()']]];
+ initArray();
+ if(showstatus=='true'||alerterror=='true')
+ init_mapcheck();
+ renderTree();
+ if(window.opera)
+ else{
+ updateScale();
+function imgerror(){
+ var map=parent.getMapObjIndexByName(mod_treeGDE_map);
+ var wms=Number(this.id.substr(4));
+ this.onerror=null;
+ this.onabort=null;
+ if(state[wms]!=-1 && alerterror=='true'){
+ state[wms]=-1;
+ if(confirm('Failed to Load WMS "'+parent.mb_mapObj[map].wms[wms].objLayer[0].layer_title+'" from Server "'+parent.mb_mapObj[map].wms[wms].wms_getmap.substr(0,parent.mb_mapObj[map].wms[wms].wms_getmap.length-1)+'"\nDo you want to try to load it in a new window?')){
+ window.open(this.src,"");
+ state[wms]=-1;
+ errors++;
+ if(showstatus=='true')
+ setNodeImage(arrNodes[0][0]+"|"+parent.mb_mapObj[map].wms[wms].wms_id, "error_folder.png");
+function checkComplete(wms, map, img, first){
+ var ind=parent.getMapObjIndexByName(mod_treeGDE_map);
+ if(parent.mb_mapObj[ind].wms[wms].mapURL == false || parent.frames[mod_treeGDE_map].document.getElementById(map).complete){
+ if(state[wms]!=-1){
+ for(var i=1;i<parent.mb_mapObj[ind].wms[wms].objLayer.length;i++){
+ if(parent.mb_mapObj[ind].wms[wms].objLayer[i].gui_layer_visible==1){
+ state[wms]=1;
+ setNodeImage(img);
+ break;
+ else{
+ if(first){
+ state[wms]=0;
+ parent.frames[mod_treeGDE_map].document.getElementById(map).onerror=imgerror;
+ parent.frames[mod_treeGDE_map].document.getElementById(map).onabort=imgerror;
+ setNodeImage(img, "loading_folder.gif");
+ setTimeout('checkComplete('+wms+', "'+map+'", "'+img+'");',100);
+//parent.mb_registerWmsLoadErrorFunctions("window.frames['treeGDE'].imgerror();");
+function init_mapcheck(){
+ if(!init)return;
+ errors = 0;
+ var ind = parent.getMapObjIndexByName(mod_treeGDE_map);
+ if(!parent.mb_mapObj[ind]||!init){
+ setTimeout("init_mapcheck();",100);
+ return;
+ for(var wms=0;wms<parent.mb_mapObj[ind].wms.length;wms++){
+ var wmsimgid="map_"+wms;
+ if(parent.frames[mod_treeGDE_map].document.getElementById(wmsimgid)){
+ checkComplete(wms, wmsimgid, arrNodes[0][0]+'|'+parent.mb_mapObj[ind].wms[wms].wms_id, true);
+function handleSelectedLayer(mapObj,wms_id,layername,type,status){
+ if(lock_update||lock_check)return;
+ var ind = parent.getMapObjIndexByName(mapObj);
+ for(var i=0; i<parent.mb_mapObj[ind].wms.length; i++){
+ if(parent.mb_mapObj[ind].wms[i].wms_id == wms_id){
+ parent.mb_mapObj[ind].wms[i].handleLayer(layername, type, status);
+ break;
+function zoomToLayer(j,k,l){
+ if(!j&&!k&&!l){
+ j=selectedMap;
+ k=selectedWMS;
+ l=selectedLayer;
+ var my=parent.mb_mapObj[j].wms[k].objLayer[l].layer_epsg;
+ for (var i=0;i<my.length;i++){
+ if(my[i]["epsg"]==parent.mb_mapObj[j].epsg){
+ parent.mb_calculateExtent(mod_treeGDE_map,my[i]["minx"],my[i]["miny"],my[i]["maxx"],my[i]["maxy"]);
+ var arrayExt = parent.mb_mapObj[j].extent.split(",");
+ parent.mb_repaint(mod_treeGDE_map,arrayExt[0],arrayExt[1],arrayExt[2],arrayExt[3]);
+ break;
+//---begin------------- opacity --------------------
+var opacityIncrement = 20;
+function opacity_up(j, k, l) {
+ handleOpacity(j, k, opacityIncrement);
+function opacity_down(j, k, l) {
+ handleOpacity(j, k, -opacityIncrement);
+function handleOpacity(mapObj_id, wms_id, increment) {
+ var opacity = parent.mb_mapObj[mapObj_id].wms[wms_id].gui_wms_mapopacity*100 + increment;
+ parent.mb_mapObj[mapObj_id].wms[wms_id].setOpacity(opacity);
+ reloadTree();
+//---end------------- opacity --------------------
+function move_up(j,k,l){
+ if(isNaN(j)&&isNaN(k)&&isNaN(l)){
+ j=selectedMap;
+ k=selectedWMS;
+ l=selectedLayer;
+ if(j==-1||k==-1||l==-1){
+ alert("You have to select the WMS you want to move up!")
+ return;
+ var lid=parent.mb_mapObj[j].wms[k].objLayer[l].layer_id;
+ if(!parent.mb_mapObj[j].move(parent.mb_mapObj[j].wms[k].wms_id,lid,(reverse=="true")?false:true)){
+ alert("Illegal move operation");
+ return;
+ treeState = getState();
+ parent.zoom(parent.mb_mapObj[j].frameName, true, 1.0);
+ parent.mb_execloadWmsSubFunctions();
+ //find layer and select
+ for(k=0;k<parent.mb_mapObj[j].wms.length;k++){
+ for(l=0;l<parent.mb_mapObj[j].wms[k].objLayer.length;l++){
+ if(parent.mb_mapObj[j].wms[k].objLayer[l].layer_id==lid){
+ select(j,k,l);
+ if(l!=0)
+ selectNode(String(lid));
+ else
+ selectNode(String(parent.mb_mapObj[j].wms[k].wms_id));
+function move_down(j,k,l){
+ j=selectedMap;
+ k=selectedWMS;
+ l=selectedLayer;
+ alert("You have to select the WMS you want to move down!")
+ return;
+ if(!parent.mb_mapObj[j].move(parent.mb_mapObj[j].wms[k].wms_id,lid,(reverse=="true")?true:false)){
+ return;
+ select(j,k,l);
+ if(l!=0)
+ else
+function remove_wms(j,k,l){
+ j=selectedMap;
+ k=selectedWMS;
+ l=selectedLayer;
+ alert("You have to select the WMS you want to delete!")
+ return;
+ if(l!=0){
+ alert("It is not possible to delete a single layer, please select a WMS!")
+ return;
+ var visibleWMS=0;
+ for(var i=0;i<parent.mb_mapObj[j].wms.length;i++)
+ if(parent.mb_mapObj[j].wms[i].gui_wms_visible=='1'||parent.mb_mapObj[j].wms[i].gui_wms_visible==1)
+ visibleWMS++;
+ if(visibleWMS<=1){
+ alert ("Last WMS can't be removed.\n(Der letzte WMS kann nicht entfernt werden.)");
+ return;
+ if(confirm('Are you sure you want to remove "'+parent.mb_mapObj[j].wms[k].objLayer[l].layer_title+'"?')){
+ parent.mb_mapObjremoveWMS(j,k);
+function updateParent(path){
+ if(lock_check)return;
+ var reset_lock=!lock_update;
+ lock_update=true;
+ var state=getChildrenCheckState(path, 0);
+ //enableCheckbox(path, (state!=-1)); //3rd state
+ checkNode(path, 0, (state==1));
+ if(state==0 && showstatus=='true' && path.split(jst_delimiter[0]).length == 2){
+ setTimeout('setNodeImage("'+path+'", "error_folder.png");', 100);
+ if(reset_lock)
+ lock_update=false;
+function handleSelectedWMS(path){
+ if(lock_update)return;
+ var t = path.split("|");
+ var reset_lock=!lock_check;
+ var layername = parent.mb_mapObj[ind].wms[parent.getWMSIndexById(mod_treeGDE_map,t[t.length-1])].objLayer[0].layer_name;
+ var bChk = IsChecked(path, 0);
+ handleSelectedLayer(mod_treeGDE_map,t[t.length-1],layername,"visible",bChk?"1":"0");
+ handleSelectedLayer(mod_treeGDE_map,t[t.length-1],layername,"querylayer",bChk?"1":"0");
+ lock_check=true;
+ checkChildren(path, 0, bChk);
+ if(ficheckbox)checkChildren(path, 1, bChk);
+ if(bChk==false && showstatus=='true')
+ if(reset_lock)
+ lock_check=false;
+ parent.mb_restateLayers(mod_treeGDE_map,t[t.length-1]);
+ parent.setSingleMapRequest(mod_treeGDE_map,t[t.length-1]);
function handleSelection(path, box){
- lock_check=true;
+ lock_check=true;
var bChk = IsChecked(path, box);
-// enableCheckbox(path, 0, true);
+// enableCheckbox(path, 0, true);
checkChildren(path, box, bChk);
- if(reset_lock){
- lock_check=false;
- parent.mb_restateLayers(mod_treeGDE_map,t[1]);
+ if(reset_lock){
+ lock_check=false;
+ parent.mb_restateLayers(mod_treeGDE_map,t[1]);
if(box==0)
- parent.setSingleMapRequest(mod_treeGDE_map,t[1]);
-function initArray(){
- var parentObj = "";
- var controls="";
- if(parent.mb_mapObj.length > 0){
- if(parent.mb_mapObj[i].wms[ii].gui_wms_visible == '1' || parent.mb_mapObj[i].wms[ii].gui_wms_visible == 1){
- for(var iii=0; iii<parent.mb_mapObj[i].wms[ii].objLayer.length; iii++){
- var temp = parent.mb_mapObj[i].wms[ii].objLayer[iii];
- if(parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_parent == ""){
- if(!temp.gui_layer_selectable == '1' && !temp.gui_layer_queryable == '1')
- continue;
- var c_menu="[";
- if(reverse=="true"){
- if(menu.indexOf("wms_down")!=-1 && ii!=parent.mb_mapObj[i].wms.length-1)c_menu+="menu_move_up,";
- if(menu.indexOf("wms_up")!=-1 && parentObj!="")c_menu+="menu_move_down,";
- else{
- if(menu.indexOf("wms_up")!=-1 && parentObj!="")c_menu+="menu_move_up,";
- if(menu.indexOf("wms_down")!=-1 && ii!=parent.mb_mapObj[i].wms.length-1)c_menu+="menu_move_down,";
- if(menu.indexOf("remove")!=-1)c_menu+="menu_delete,";
-// if(menu.indexOf("wms_switch")!=-1)c_menu+="menu_wms_switch,";
- if(menu.indexOf("opacity_up")!=-1 && parseFloat(parent.mb_mapObj[i].wms[ii].gui_wms_mapopacity) < 1)c_menu+="menu_opacity_up,";
- if(menu.indexOf("opacity_down")!=-1 && parseFloat(parent.mb_mapObj[i].wms[ii].gui_wms_mapopacity) > 0)c_menu+="menu_opacity_down,";
- if(menu.indexOf("hide")!=-1)c_menu+="menu_hide";
- c_menu+="]";
- controls=null;
- if(switchwms=='true')controls='<INPUT type="checkbox" checked onclick="handleSelectedWMS(\''+arrNodes[0][0]+'|'+parent.mb_mapObj[i].wms[ii].wms_id+'\');" />';
- if(wmsbuttons == 'true'&&metadatalink == 'true')controls+='<a href="'+'javascript:openwindow(\''+ defaultMetadataUrl + '&id='+temp.layer_uid+'\');'+'"><img src="'+imagedir+'/info.png" /></a>';
- addNode(arrNodes[0][0],[parent.mb_mapObj[i].wms[ii].wms_id,[temp.layer_title,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"'+ defaultMetadataUrl + '&id='+temp.layer_uid+'\");'):"javascript:select("+i+","+ii+","+iii+");"),,,temp.layer_title,eval(c_menu),controls,[i,ii,iii]]],false,false,reverse=="true");
- parentObj = arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[ii].wms_id;
- if(parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_parent && (handlesublayer=="true"||parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_parent=="0")){
- var parentLayer = "";
- var j = iii;
- while(parent.mb_mapObj[i].wms[ii].objLayer[j].layer_parent!="0"){
- //find parent
- for(var jj=0; jj < parent.mb_mapObj[i].wms[ii].objLayer.length; jj++){
- if(parent.mb_mapObj[i].wms[ii].objLayer[jj].layer_pos==parseInt(parent.mb_mapObj[i].wms[ii].objLayer[j].layer_parent)){
- j=jj;
- break;
- parentLayer = "|" + parent.mb_mapObj[i].wms[ii].objLayer[j].layer_id + parentLayer;
- if(temp.gui_layer_selectable == '1' || temp.gui_layer_queryable == '1'){
- var c_menu="[";
- if(menu.indexOf("layer_down")!=-1 && iii!=parent.mb_mapObj[i].wms[ii].objLayer.length-1)c_menu+="menu_move_up,";
- if(menu.indexOf("layer_up")!=-1 && iii!=1)c_menu+="menu_move_down,";
- else{
- if(menu.indexOf("layer_up")!=-1 && iii!=1)c_menu+="menu_move_up,";
- if(menu.indexOf("layer_down")!=-1 && iii!=parent.mb_mapObj[i].wms[ii].objLayer.length-1)c_menu+="menu_move_down,";
- if(menu.indexOf("metainfo")!=-1)c_menu+="menu_metalink,";
- if(menu.indexOf("zoom")!=-1 && temp.layer_epsg.length>0)c_menu+="menu_zoom,";
-// if(menu.indexOf("layer_switch")!=-1)c_menu+="menu_layer_switch,";
-// if(menu.indexOf("info_switch")!=-1)c_menu+="menu_info_switch,";
- c_menu+="]";
- controls='<input type="checkbox" '+(temp.layer_name==""?'style="display:none;" ':"")+((temp.gui_layer_visible=='1')?'checked ':'')+(temp.gui_layer_selectable!='1'?'disabled ':'')+"onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','visible',this.checked?1:0);handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"', 0);updateParent('"+parentObj+parentLayer+"');"+((ficheckbox == 'false')?"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0)":"")+"\" />";
- if(ficheckbox == 'true')controls+='<input type="checkbox" '+(temp.gui_layer_querylayer=='1'?'checked ':'')+(temp.gui_layer_queryable!='1'?'disabled ':'')+"onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"', 1)\" />";
- addNode(parentObj + parentLayer, [temp.layer_id,[temp.layer_title,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"'+ defaultMetadataUrl + '&id='+temp.layer_uid+'\");'):"javascript:select("+i+","+ii+","+iii+");"),,((c_menu!='[]'&&temp.layer_name!="")?'menu.png':null),temp.layer_title,eval(c_menu),controls,[i,ii,iii]]],false,false,reverse=="true");
- init=true;
-function initWmsCheckboxen(){
- var hidden=0;
- updateParent(arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[ii].wms_id);
- else if(ii<=parent.parseInt(openfolder)+hidden)
- hidden++;
- closeAll()
- if(treeState!='')
- setState(treeState);
- else if(openfolder!='false')
- setState(arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[parent.parseInt(openfolder)+hidden].wms_id);
- </SCRIPT>
-</HEAD>
-<BODY VLINK="#000000" ALINK="#000000" LINK="#000000" BGCOLOR="#ffffff" TEXT="#000000"
- MARGINHEIGHT="0" MARGINWIDTH="0" LEFTMARGIN="0" TOPMARGIN="0">
-if(wmsbuttons=='true'){
- document.writeln("<div>");
- document.writeln('<a href="javascript:move_up()"><img src="'+imagedir+'/move_up.png" alt="move up" style="position:relative;top:0px;left:0px;"/></a>');
- document.writeln('<a href="javascript:move_down()"><img src="'+imagedir+'/move_down.png" alt="move down" style="position:relative;top:0px;left:-3px"/></a>');
- document.writeln('<a href="javascript:remove_wms()"><img src="'+imagedir+'/delete_wms.png" alt="remove wms" style="position:relative;top:0px;left:-6px"/></a>');
- document.writeln("</div>");
-</SCRIPT>
-<DIV id="treeContainer"></DIV>
-</BODY>
-</HTML>
+ parent.setSingleMapRequest(mod_treeGDE_map,t[1]);
+function initArray(){
+ var parentObj = "";
+ var controls="";
+ if(parent.mb_mapObj.length > 0){
+ if(parent.mb_mapObj[i].wms[ii].gui_wms_visible == '1' || parent.mb_mapObj[i].wms[ii].gui_wms_visible == 1){
+ for(var iii=0; iii<parent.mb_mapObj[i].wms[ii].objLayer.length; iii++){
+ var temp = parent.mb_mapObj[i].wms[ii].objLayer[iii];
+ if(parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_parent == ""){
+ if(!temp.gui_layer_selectable == '1' && !temp.gui_layer_queryable == '1')
+ continue;
+ var c_menu="[";
+ if(reverse=="true"){
+ if(menu.indexOf("wms_down")!=-1 && ii!=parent.mb_mapObj[i].wms.length-1)c_menu+="menu_move_up,";
+ if(menu.indexOf("wms_up")!=-1 && parentObj!="")c_menu+="menu_move_down,";
+ else{
+ if(menu.indexOf("wms_up")!=-1 && parentObj!="")c_menu+="menu_move_up,";
+ if(menu.indexOf("wms_down")!=-1 && ii!=parent.mb_mapObj[i].wms.length-1)c_menu+="menu_move_down,";
+ if(menu.indexOf("remove")!=-1)c_menu+="menu_delete,";
+// if(menu.indexOf("wms_switch")!=-1)c_menu+="menu_wms_switch,";
+ if(menu.indexOf("opacity_up")!=-1 && parseFloat(parent.mb_mapObj[i].wms[ii].gui_wms_mapopacity) < 1)c_menu+="menu_opacity_up,";
+ if(menu.indexOf("opacity_down")!=-1 && parseFloat(parent.mb_mapObj[i].wms[ii].gui_wms_mapopacity) > 0)c_menu+="menu_opacity_down,";
+ if(menu.indexOf("hide")!=-1)c_menu+="menu_hide";
+ c_menu+="]";
+ controls=null;
+ if(switchwms=='true')controls='<INPUT type="checkbox" checked onclick="handleSelectedWMS(\''+arrNodes[0][0]+'|'+parent.mb_mapObj[i].wms[ii].wms_id+'\');" />';
+ if(wmsbuttons == 'true'&&metadatalink == 'true')controls+='<a href="'+'javascript:openwindow(\''+ defaultMetadataUrl + '&id='+temp.layer_uid+'\');'+'"><img src="'+imagedir+'/info.png" /></a>';
+ addNode(arrNodes[0][0],[parent.mb_mapObj[i].wms[ii].wms_id,[temp.layer_title,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"'+ defaultMetadataUrl + '&id='+temp.layer_uid+'\");'):"javascript:select("+i+","+ii+","+iii+");"),,,temp.layer_title,eval(c_menu),controls,[i,ii,iii]]],false,false,reverse=="true");
+ parentObj = arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[ii].wms_id;
+ if(parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_parent && (handlesublayer=="true"||parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_parent=="0")){
+ var parentLayer = "";
+ var j = iii;
+ while(parent.mb_mapObj[i].wms[ii].objLayer[j].layer_parent!="0"){
+ //find parent
+ for(var jj=0; jj < parent.mb_mapObj[i].wms[ii].objLayer.length; jj++){
+ if(parent.mb_mapObj[i].wms[ii].objLayer[jj].layer_pos==parseInt(parent.mb_mapObj[i].wms[ii].objLayer[j].layer_parent)){
+ j=jj;
+ break;
+ parentLayer = "|" + parent.mb_mapObj[i].wms[ii].objLayer[j].layer_id + parentLayer;
+ if(temp.gui_layer_selectable == '1' || temp.gui_layer_queryable == '1'){
+ var c_menu="[";
+ if(menu.indexOf("layer_down")!=-1 && iii!=parent.mb_mapObj[i].wms[ii].objLayer.length-1)c_menu+="menu_move_up,";
+ if(menu.indexOf("layer_up")!=-1 && iii!=1)c_menu+="menu_move_down,";
+ else{
+ if(menu.indexOf("layer_up")!=-1 && iii!=1)c_menu+="menu_move_up,";
+ if(menu.indexOf("layer_down")!=-1 && iii!=parent.mb_mapObj[i].wms[ii].objLayer.length-1)c_menu+="menu_move_down,";
+ if(menu.indexOf("metainfo")!=-1)c_menu+="menu_metalink,";
+ if(menu.indexOf("zoom")!=-1 && temp.layer_epsg.length>0)c_menu+="menu_zoom,";
+// if(menu.indexOf("layer_switch")!=-1)c_menu+="menu_layer_switch,";
+// if(menu.indexOf("info_switch")!=-1)c_menu+="menu_info_switch,";
+ c_menu+="]";
+ controls='<input type="checkbox" '+(temp.layer_name==""?'style="display:none;" ':"")+((temp.gui_layer_visible=='1')?'checked ':'')+(temp.gui_layer_selectable!='1'?'disabled ':'')+"onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','visible',this.checked?1:0);"+((ficheckbox == 'false')?"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);":"")+"handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"', 0);updateParent('"+parentObj+parentLayer+"');\" />";
+ if(ficheckbox == 'true')controls+='<input type="checkbox" '+(temp.gui_layer_querylayer=='1'?'checked ':'')+(temp.gui_layer_queryable!='1'?'disabled ':'')+"onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"', 1, this.checked?1:0)\" />";
+ addNode(parentObj + parentLayer, [temp.layer_id,[temp.layer_title,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"'+ defaultMetadataUrl + '&id='+temp.layer_uid+'\");'):"javascript:select("+i+","+ii+","+iii+");"),,((c_menu!='[]'&&temp.layer_name!="")?'menu.png':null),temp.layer_title,eval(c_menu),controls,[i,ii,iii]]],false,false,reverse=="true");
+ init=true;
+function initWmsCheckboxen(){
+ var hidden=0;
+ updateParent(arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[ii].wms_id);
+ else if(ii<=parent.parseInt(openfolder)+hidden)
+ hidden++;
+ closeAll()
+ if(treeState!='')
+ setState(treeState);
+ else if(openfolder!='false')
+ setState(arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[parent.parseInt(openfolder)+hidden].wms_id);
+ </SCRIPT>
+</HEAD>
+<BODY VLINK="#000000" ALINK="#000000" LINK="#000000" BGCOLOR="#ffffff" TEXT="#000000"
+ MARGINHEIGHT="0" MARGINWIDTH="0" LEFTMARGIN="0" TOPMARGIN="0">
+if(wmsbuttons=='true'){
+ document.writeln("<div>");
+ document.writeln('<a href="javascript:move_up()"><img src="'+imagedir+'/move_up.png" alt="move up" style="position:relative;top:0px;left:0px;"/></a>');
+ document.writeln('<a href="javascript:move_down()"><img src="'+imagedir+'/move_down.png" alt="move down" style="position:relative;top:0px;left:-3px"/></a>');
+ document.writeln('<a href="javascript:remove_wms()"><img src="'+imagedir+'/delete_wms.png" alt="remove wms" style="position:relative;top:0px;left:-6px"/></a>');
+ document.writeln("</div>");
+</SCRIPT>
+<DIV id="treeContainer"></DIV>
+</BODY>
+</HTML>
\ No newline at end of file
Modified: branches/2.5/http/javascripts/map_obj.js
--- branches/2.5/http/javascripts/map_obj.js 2008-09-01 13:23:08 UTC (rev 2901)
+++ branches/2.5/http/javascripts/map_obj.js 2008-09-01 13:56:03 UTC (rev 2902)
@@ -498,7 +498,7 @@
if(type == "visible") {
this.objLayer[j].gui_layer_visible = parseInt(value, 10);
- else if(type=="querylayer") {
+ else if(type=="querylayer" && this.objLayer[j].gui_layer_queryable) {
this.objLayer[j].gui_layer_querylayer = parseInt(value, 10);
@@ -511,7 +511,7 @@
this.objLayer[j].gui_layer_visible = state;
this.objLayer[j].gui_layer_querylayer = state;
More information about the Mapbender_commits
