[Mapbender-commits] r2905 - in trunk/mapbender: conf http/img/button_digitize http/javascripts http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Sep 3 08:40:39 EDT 2008
Author: christoph
Date: 2008-09-03 08:40:37 -0400 (Wed, 03 Sep 2008)
New Revision: 2905
Added:
   trunk/mapbender/http/img/button_digitize/mergePolygons_off.png
   trunk/mapbender/http/img/button_digitize/mergePolygons_on.png
   trunk/mapbender/http/img/button_digitize/mergePolygons_over.png
   trunk/mapbender/http/img/button_digitize/splitPolygon_off.png
   trunk/mapbender/http/img/button_digitize/splitPolygon_on.png
   trunk/mapbender/http/img/button_digitize/splitPolygon_over.png
   trunk/mapbender/http/php/mod_digitize_mergePolygon.php
   trunk/mapbender/http/php/mod_digitize_splitPolygon.php
   trunk/mapbender/conf/digitize_default.conf
   trunk/mapbender/http/javascripts/geometry.js
   trunk/mapbender/http/javascripts/mod_digitize_tab.php
   trunk/mapbender/http/php/mod_digitize_messages.php
http://trac.osgeo.org/mapbender/ticket/287
Modified: trunk/mapbender/conf/digitize_default.conf
--- trunk/mapbender/conf/digitize_default.conf	2008-09-01 15:41:46 UTC (rev 2904)
+++ trunk/mapbender/conf/digitize_default.conf	2008-09-03 12:40:37 UTC (rev 2905)
@@ -10,6 +10,8 @@
 addButtonDig("setBasePoint", 1, "new_node_off.png", "", "", 100, 0);
 addButtonDig("delBasePoint", 1, "delete_node_off.png", "", "", 125, 0);
 addButtonDig("clear", 1, "del_off.png", "", "", 150, 0);
+addButtonDig("digitizeSplit", 1, "splitPolygon_off.png", "", "", 175, 0);
+addButtonDig("digitizeMerge", 1, "mergePolygons_off.png", "", "", 200, 0);
 //definition of directory of digitize buttons
 buttonDig_imgdir = "../img/button_digitize/";
Added: trunk/mapbender/http/img/button_digitize/mergePolygons_off.png
(Binary files differ)
Property changes on: trunk/mapbender/http/img/button_digitize/mergePolygons_off.png
___________________________________________________________________
   + application/octet-stream
Added: trunk/mapbender/http/img/button_digitize/mergePolygons_on.png
Property changes on: trunk/mapbender/http/img/button_digitize/mergePolygons_on.png
Added: trunk/mapbender/http/img/button_digitize/mergePolygons_over.png
Property changes on: trunk/mapbender/http/img/button_digitize/mergePolygons_over.png
Added: trunk/mapbender/http/img/button_digitize/splitPolygon_off.png
Property changes on: trunk/mapbender/http/img/button_digitize/splitPolygon_off.png
Added: trunk/mapbender/http/img/button_digitize/splitPolygon_on.png
Property changes on: trunk/mapbender/http/img/button_digitize/splitPolygon_on.png
Added: trunk/mapbender/http/img/button_digitize/splitPolygon_over.png
Property changes on: trunk/mapbender/http/img/button_digitize/splitPolygon_over.png
Modified: trunk/mapbender/http/javascripts/geometry.js
--- trunk/mapbender/http/javascripts/geometry.js	2008-09-01 15:41:46 UTC (rev 2904)
+++ trunk/mapbender/http/javascripts/geometry.js	2008-09-03 12:40:37 UTC (rev 2905)
@@ -241,7 +241,46 @@
 	return [min, max];
+GeometryArray.prototype.importGeometryFromText = function (text) {
+	var tmpArray = text.split("(");
+	var geometryType = tmpArray[0];
+	switch (geometryType) {
+		case "POLYGON":
+			var text = text.replace(/\)/, "");
+			text = text.replace(/\(\(/, "(");
+			var coordinatesArray = tmpArray[1].split(",");
+			this.addMember(geomType.polygon);
+			this.get(-1).addGeometry();
+			for (var m = 0; m < -1 + coordinatesArray.length; m++) {
+				var currentPoint = coordinatesArray[m].split(" ");
+				this.getGeometry(-1, -1).addPointByCoordinates(parseFloat(currentPoint[0]), parseFloat(currentPoint[1]));
+			this.close();
+			break;
+		case "MULTIPOLYGON":
+			text = text.replace(/\(\(\(/, "(");
+			this.close();
+			break;
 GeometryArray.prototype.importGeoJSON = function (geoJSON) {
 	var isFeatureCollection = false;
 	var featureCollectionEpsg = 4326;
@@ -635,6 +674,53 @@
 	return false;
+MultiGeometry.prototype.toText = function () {
+	var text = "";
+	var numOfGeom = this.count();
+	if (numOfGeom >= 1) {
+		if (this.geomType == geomType.polygon) {
+			text += "POLYGON (";
+			for (var i = 0; i < this.count(); i++) {
+				if (i > 0) {
+					text += ", ";
+				text += "(";
+				var currentPolygon = this.get(i);
+				for (var j = 0; j < currentPolygon.count(); j++) {
+					if (j > 0) {
+						text += ", ";
+					var currentPoint = currentPolygon.get(j);
+					text += currentPoint.x + " " + currentPoint.y
+				text += ")";
+			text += ")";
+		else if (this.geomType == geomType.line) {
+			text += "LINESTRING (";
+			var currentLine = this.get(0);
+			for (var j = 0; j < currentLine.count(); j++) {
+				if (j > 0) {
+					text += ", ";
+				var currentPoint = currentLine.get(j);
+			text += ")";
+	return text;
 MultiGeometry.prototype.toString = function () {
 	var str = this.toStringWithoutProperties();
Modified: trunk/mapbender/http/javascripts/mod_digitize_tab.php
--- trunk/mapbender/http/javascripts/mod_digitize_tab.php	2008-09-01 15:41:46 UTC (rev 2904)
+++ trunk/mapbender/http/javascripts/mod_digitize_tab.php	2008-09-03 12:40:37 UTC (rev 2905)
@@ -84,7 +84,8 @@
 var button_insert = "setBasePoint";
 var button_delete = "delBasePoint";
 var button_clear = "clear";
-var button_combine = "combine";
+var button_split = "digitizeSplit";
+var button_merge = "digitizeMerge";
 var digitizeDivTag;
@@ -583,7 +584,10 @@
 		mod_digitizeEvent = obj.id;
 		executeDigitizePreFunctions();
-	else if (obj.id == button_point || obj.id == button_line || obj.id == button_polygon || obj.id == button_clear || obj.id == button_combine){
+	else if (obj.id == button_point || obj.id == button_line ||
+				obj.id == button_polygon || obj.id == button_clear ||
+				obj.id == button_split || obj.id == button_merge){
 		var el = parent.frames[mod_digitize_target].document;
 		el.onmousemove = mod_digitize_go;
@@ -695,14 +699,54 @@
 				parent.mb_disableThisButton(button_clear);
-		else if (obj.id == button_combine) {
-//			d.combineToMultiGeometry();
-//			prompt('', d.toJSONString());
-//			parent.mb_ajax_post("../php/jsonTest.php", {json:d.toJSONString()}, function(test, status) {
-//				alert(test);
-			parent.mb_disableThisButton(button_combine);
+		else if (obj.id == button_merge) {
+			var applicable = (d.count() > 1);
+			var polygonTextArray = [];
+			for (var i = 0; i < d.count(); i++) {
+				if (d.get(i).geomType != parent.geomType.polygon) {
+					applicable = false;
+					polygonTextArray = [];
+					break;
+				polygonTextArray.push(d.get(i).toText());
+			if (!applicable) {
+				alert(msgObj.messageErrorMergeNotApplicable);
+				parent.mb_disableThisButton(button_merge);
+				return false;
+			parent.mb_ajax_post("../php/mod_digitize_mergePolygon.php", {polygons: polygonTextArray.join(";")}, function(json, status) {
+				var response = eval('(' + json + ')');
+				var polygon = response.polygon;
+				d.importGeometryFromText(polygon);
+		else if (obj.id == button_split) {
+			var applicable = (d.count() == 2) &&
+							(d.get(0).geomType == parent.geomType.polygon) &&
+							(d.get(1).geomType == parent.geomType.line);
+				alert(msgObj.messageErrorSplitNotApplicable);
+				parent.mb_disableThisButton(button_split);
+				return false;
+			var polygonText = d.get(0).toText();
+			var lineText = d.get(1).toText();
+			parent.mb_ajax_post("../php/mod_digitize_splitPolygon.php", {polygon: polygonText, line: lineText}, function(json, status) {
+				var polygonArray = response.polygons;
+				for (var i in polygonArray) {
+					d.importGeometryFromText(polygonArray[i]);
@@ -719,6 +763,14 @@
 		mod_digitize_timeout();
 		executeDigitizeSubFunctions();
+		mod_digitize_timeout();
+		executeDigitizeSubFunctions();
 	mod_digitizeEvent = false;
 // --- button handling (end) ----------------------------------------------------------------------------------------------
Added: trunk/mapbender/http/php/mod_digitize_mergePolygon.php
--- trunk/mapbender/http/php/mod_digitize_mergePolygon.php	                        (rev 0)
+++ trunk/mapbender/http/php/mod_digitize_mergePolygon.php	2008-09-03 12:40:37 UTC (rev 2905)
@@ -0,0 +1,60 @@
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/DeleteWMS
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__) . "/../../core/globalSettings.php");
+require_once(dirname(__FILE__) . "/../classes/class_json.php");
+$json = new Mapbender_JSON();
+$polygonList = stripslashes($_REQUEST["polygons"]);
+$floatPattern = "-?\d+(\.\d+)?";
+$pointPattern = $floatPattern . " " . $floatPattern;
+$polygonPattern = "POLYGON \(\(" . $pointPattern . "(, " . $pointPattern . ")*\)\)";
+$pattern = "/" . $polygonPattern . "(;" . $polygonPattern . ")+/";
+if (!preg_match($pattern, $polygonList)) {
+	echo "not a polygon.";
+	die();
+$polygonArray = explode(";", $polygonList);
+$sql = "SELECT astext(multi(geomunion(geom))) FROM (";
+for ($i = 0; $i < count($polygonArray); $i++) {
+	if ($i > 0) {
+		$sql .= " UNION ";
+	$sql .= "(SELECT '" . $polygonArray[$i] . "'::geometry AS geom) ";
+$sql .= ") as a";
+$res = db_query($sql);
+$polygonArray = array();
+$row = db_fetch_array($res);
+$data = array("polygon" => $row[0]);
+$output = $json->encode($data);
+header("Content-type:application/x-json; charset=utf-8");
+echo $output;
\ No newline at end of file
Property changes on: trunk/mapbender/http/php/mod_digitize_mergePolygon.php
   + HeadURL Id LastChangedBy LastChangedDate LastChangedRevision
Modified: trunk/mapbender/http/php/mod_digitize_messages.php
--- trunk/mapbender/http/php/mod_digitize_messages.php	2008-09-01 15:41:46 UTC (rev 2904)
+++ trunk/mapbender/http/php/mod_digitize_messages.php	2008-09-03 12:40:37 UTC (rev 2905)
@@ -35,6 +35,8 @@
 $msg_obj["messageErrorFieldIsEmpty"] = _mb("This field may not be empty.");
 $msg_obj["messageErrorFormEvaluation"] = _mb("Failure during form evaluation.");
 $msg_obj["messageErrorWfsWrite"] = _mb("An error occured.");
+$msg_obj["messageErrorMergeNotApplicable"] = _mb("At least two geometries must be available. Only polygons are allowed in the geometry list.");
+$msg_obj["messageErrorSplitNotApplicable"] = _mb("Exactly two geometries must be available. The first geometry shall be a polygon, the second geometry shall be a line.");
 $msg_obj["messageSuccessWfsWrite"] = _mb("Success.");
 $msg_obj["messageConfirmDeleteGeomFromDb"] = _mb("Delete geometry from database?");
 $msg_obj["messageConfirmDeleteAllGeomFromList"] = _mb("Clear list of geometries?");
@@ -59,6 +61,10 @@
 $msg_obj["buttonLabelDeleteBasepointOn"] = _mb("Delete basepoint");
 $msg_obj["buttonLabelClearListOff"] = _mb("clear list of geometries");
 $msg_obj["buttonLabelClearListOn"] = _mb("clear list of geometries");
+$msg_obj["buttonLabelMergeOff"] = _mb("Merge geometries");
+$msg_obj["buttonLabelMergeOn"] = _mb("Merge geometries");
+$msg_obj["buttonLabelSplitOff"] = _mb("Split geometries");
+$msg_obj["buttonLabelSplitOn"] = _mb("Split geometries");
 $msg_obj["buttonDig_wfs_title"] = _mb("save / update / delete");
 $msg_obj["buttonDig_remove_title"] = _mb("remove from workspace");
 $msg_obj["buttonDig_removeDb_title"] = _mb("remove from database");
Added: trunk/mapbender/http/php/mod_digitize_splitPolygon.php
--- trunk/mapbender/http/php/mod_digitize_splitPolygon.php	                        (rev 0)
+++ trunk/mapbender/http/php/mod_digitize_splitPolygon.php	2008-09-03 12:40:37 UTC (rev 2905)
@@ -0,0 +1,69 @@
+<?php
+# $Id$
+$lineText = $_REQUEST["line"];
+$polygonText = $_REQUEST["polygon"];
+$linePattern = "LINESTRING \(" . $pointPattern . ", " . $pointPattern . "\)";
+$pattern = "/" . $polygonPattern . "/";
+if (!preg_match($pattern, $polygonText)) {
+	die();
+$pattern = "/" . $linePattern . "/";
+if (!preg_match($pattern, $lineText)) {
+	echo "not a line.";
+	die();
+$sql = "SELECT astext(geom) FROM dump ((" .
+	"SELECT polygonize(geomunion(boundary('" .
+	$polygonText . "'::geometry),'" .
+	$lineText . "'::geometry))" .
+	"WHERE contains('" .
+	$polygonText . "'::geometry, pointonsurface(geom)" .
+while ($row = db_fetch_array($res)) {
+	array_push($polygonArray, $row[0]);
+$data = array("polygons" => $polygonArray);
+echo $output;
Property changes on: trunk/mapbender/http/php/mod_digitize_splitPolygon.php
More information about the Mapbender_commits mailing list
