[Mapbender-commits] r2928 - branches/beck_dev
svn_mapbender at osgeo.org
Mon Sep 15 05:48:53 EDT 2008
Author: beck
Date: 2008-09-15 05:48:53 -0400 (Mon, 15 Sep 2008)
New Revision: 2928
Removed:
branches/beck_dev/README.txt
Deleted: branches/beck_dev/README.txt
--- branches/beck_dev/README.txt 2008-09-15 09:48:20 UTC (rev 2927)
+++ branches/beck_dev/README.txt 2008-09-15 09:48:53 UTC (rev 2928)
@@ -1,9 +0,0 @@
-This is a Subversion repository; use the 'svnadmin' tool to examine
-it. Do not add, delete, or modify files here unless you know how
-to avoid corrupting the repository.
-If the directory "db" contains a Berkeley DB environment,
-you may need to tweak the values in "db/DB_CONFIG" to match the
-requirements of your site.
-Visit http://subversion.tigris.org/ for more information.
More information about the Mapbender_commits
