[Mapbender-commits] r2934 - in branches: . beck_dev/http/css beck_dev/http/print
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Sep 15 06:52:12 EDT 2008
Author: beck
Date: 2008-09-15 06:52:12 -0400 (Mon, 15 Sep 2008)
New Revision: 2934
Added:
   branches/beck_dev/
   branches/beck_dev/http/css/print.css
Removed:
   branches/beck_dev/http/print/mod_printPDF.php
Copied: branches/beck_dev (from rev 2743, branches/2.5)
Deleted: branches/beck_dev/http/css/print.css
--- branches/2.5/http/css/print.css	2008-08-06 07:43:23 UTC (rev 2743)
+++ branches/beck_dev/http/css/print.css	2008-09-15 10:52:12 UTC (rev 2934)
@@ -1,43 +0,0 @@
-	font: 12px normal Verdana,Arial,Helvetica,sans-serif;
-body {
-	margin: 0;
-	padding: 10px;
-	color: #000;
-	background-color: #FFF;
-form fieldset {
-	margin: 0;
-	padding: 0;
-	border: 0;
-form p {
-	line-height: 1.25em;
-	white-space: nowrap;
-form p label {
-	display: block;
-	float: left;
-	width: 7em;
-	padding-right: 1em;
-form p label em {
-	display: block;
-	color: #666;
-form p input#mylegendcheckbox {
-	margin: 0;
-	padding: 0;
-form p input#print {
-	margin-left: 8em;
\ No newline at end of file
Copied: branches/beck_dev/http/css/print.css (from rev 2744, branches/2.5/http/css/print.css)
--- branches/beck_dev/http/css/print.css	                        (rev 0)
@@ -0,0 +1,45 @@
+	font: 12px normal Verdana,Arial,Helvetica,sans-serif;
+body {
+	margin: 0;
+	padding: 10px;
+	color: #000;
+	background-color: #FFF;
+form fieldset {
+	margin: 0;
+	padding: 0;
+	border: 0;
+form p {
+	line-height: 1.25em;
+	white-space: nowrap;
+form p label {
+	display: block;
+	float: left;
+	width: 7em;
+	padding-right: 1em;
+form p label em {
+	display: block;
+	color: #666;
+form p input#mylegendcheckbox {
+	margin: 0;
+	padding: 0;
+form p input#print {
+	margin-left: 8em;
Modified: branches/beck_dev/http/print/mod_printPDF.php
--- branches/2.5/http/print/mod_printPDF.php	2008-08-06 07:43:23 UTC (rev 2743)
+++ branches/beck_dev/http/print/mod_printPDF.php	2008-09-15 10:52:12 UTC (rev 2934)
@@ -34,7 +34,7 @@
 	//FIXME:
 	//setlocale(LC_ALL, "de_DE.utf8");
-	require_once(dirname(__FILE__)."/../print/".$_REQUEST["conf"]);
+	require_once(dirname(__FILE__)."/../print_ingrid/".$_REQUEST["conf"]);
 	printf("
 	<script type=\"text/javascript\">
@@ -287,35 +287,41 @@
 </head>
 <body>
-<form name="form1" method="post" action="../print/mod_printPDF_pdf.php?<?php echo SID; ?>" target="_blank">
-<p id="container_size">
-	<label for="size"><?php echo $label_format ?></label>
-	<select id="size" name="size" onchange="validate();">
-		<option value="false">-</option>
-		<?php
-		for($i = 4; $i >= 0; $i--) {
-			if(${"a".$i}) {
-				printf("<option value=\"A%s\">%s</option>",$i,${"label_format_a".$i});
+<form name="form1" method="POST" action="../print/mod_printPDF_pdf.php?<?php echo SID; ?>" target="_blank">
+<fieldset id="container_size">
+	<p>
+		<label for="size"><?php echo $label_format ?></label>
+		<select id="size" name="size" onchange="validate();">
+			<option value="false">-</option>
+			<?php
+			for($i = 4; $i >= 0; $i--) {
+				if(${"a".$i}) {
+					printf("<option value=\"A%s\">%s</option>",$i,${"label_format_a".$i});
-	</select>
-</p>
+		</select>
+	</p>
+</fieldset>
-<p id="container_orientation">
-	<label for="format"><?php echo $label_orientation; ?></label>
-	<select id="format" name="format" onchange="validate();">
-		<option value="portrait"><?php echo $label_portrait; ?></option>
-		<option value="landscape"><?php echo $label_landscape; ?></option>
-	</select>
-</p>
+<fieldset id="container_orientation">
+	<p>
+		<label for="format"><?php echo $label_orientation; ?></label>
+		<select id="format" name="format" onchange="validate();">
+			<option value="portrait"><?php echo $label_portrait; ?></option>
+			<option value="landscape"><?php echo $label_landscape; ?></option>
+		</select>
+	</p>
+</fieldset>
 <?php if($highquality === TRUE): ?>
-	<p id="container_quality">
-		<label for="quality"><?php echo $label_quality; ?></label>
-		<input type="radio" id="quality" name="quality" value="1" checked="checked" /> <?php echo $label_72dpi; ?>
-		<input type="radio" id="quality" name="quality" value="2" /> <?php echo $label_288dpi; ?>
-	</p>
+	<fieldset id="container_quality">
+		<p>
+			<label for="quality"><?php echo $label_quality; ?></label>
+			<input type="radio" id="quality" name="quality" value="1" checked="checked" /> <?php echo $label_72dpi; ?>
+			<input type="radio" id="quality" name="quality" value="2" /> <?php echo $label_288dpi; ?>
+		</p>
+	</fieldset>
 <?php endif; ?>
 <?php
@@ -326,20 +332,24 @@
 		$label_hint         = ($max_comment_length > -1) ? sprintf(" <em>(max. %s)</em>",$max_comment_length) : NULL;
 		$javascript         = ($max_comment_length > -1) ? sprintf(" onblur=\"checkCommentLength(this,%s)\"",$max_comment_length) : NULL;
-		$html  = sprintf("<p id=\"container_comment%s\">",$i);
+		$html  = sprintf("<fieldset id=\"container_comment%s\">",$i);
+		$html .= "<p>";
 		$html .= sprintf("<label for=\"c%s\">%s%s</label> ",$i,${"label_comment".$i},$label_hint);
 		$html .= sprintf("<textarea id=\"c%s\" name=\"c%s\" cols=\"20\" rows=\"2\"%s></textarea> ",$i,$i,$javascript);
 		$html .= "</p>";
+		$html .= "</fieldset>";
 		echo $html;
 <?php if($legend === TRUE): ?>
-	<p id="container_legend">
-		<label for="mylegendcheckbox"><?php echo $label_legend; ?></label>
-		<input type="checkbox" id="mylegendcheckbox" name="mylegendcheckbox" value="false" />
-	</p>
+	<fieldset id="container_legend">
+		<p>
+			<label for="mylegendcheckbox"><?php echo $label_legend; ?></label>
+			<input type="checkbox" id="mylegendcheckbox" name="mylegendcheckbox" value="false" />
+		</p>
+	</fieldset>
 <?php else: ?>
 	<input type="hidden" name="mylegendcheckbox" value="false" />
 <?php endif; ?>
@@ -359,9 +369,11 @@
 <input type="hidden" name="measured_x_values" />
 <input type="hidden" name="measured_y_values" />
-<p>
-	<input type="button" id="print" name="print" value="<?php echo $label_button; ?>" onclick="printMap();" />
-</p>
+<fieldset>
+	<p>
+		<input type="button" id="print" name="print" value="<?php echo $label_button; ?>" onclick="printMap();" />
+	</p>
+</fieldset>
 </form>
 </body>
More information about the Mapbender_commits mailing list
