[Mapbender-commits] r2946 - in branches/tree_dev/http: . extensions
x_test
svn_mapbender at osgeo.org
Wed Sep 17 05:22:21 EDT 2008
Author: christoph
Date: 2008-09-17 05:22:20 -0400 (Wed, 17 Sep 2008)
New Revision: 2946
Added:
branches/tree_dev/http/extensions/jquery-1.2.6.min.js
branches/tree_dev/http/extensions/jquery-ui-personalized-1.5.2.js
branches/tree_dev/http/extensions/jquery.contextmenu.r2.js
branches/tree_dev/http/x_test/
branches/tree_dev/http/x_test/customTree.js
branches/tree_dev/http/x_test/customTreeModel.js
branches/tree_dev/http/x_test/tree.html
initial commit
Added: branches/tree_dev/http/extensions/jquery-1.2.6.min.js
--- branches/tree_dev/http/extensions/jquery-1.2.6.min.js (rev 0)
+++ branches/tree_dev/http/extensions/jquery-1.2.6.min.js 2008-09-17 09:22:20 UTC (rev 2946)
@@ -0,0 +1,32 @@
+ * jQuery 1.2.6 - New Wave Javascript
+ * Copyright (c) 2008 John Resig (jquery.com)
+ * Dual licensed under the MIT (MIT-LICENSE.txt)
+ * and GPL (GPL-LICENSE.txt) licenses.
+ * $Date: 2008-05-24 14:22:17 -0400 (Sat, 24 May 2008) $
+ * $Rev: 5685 $
+(function(){var _jQuery=window.jQuery,_$=window.$;var jQuery=window.jQuery=window.$=function(selector,context){return new jQuery.fn.init(selector,context);};var quickExpr=/^[^<]*(<(.|\s)+>)[^>]*$|^#(\w+)$/,isSimple=/^.[^:#\[\.]*$/,undefined;jQuery.fn=jQuery.prototype={init:function(selector,context){selector=selector||document;if(selector.nodeType){this[0]=selector;this.length=1;return this;}if(typeof selector=="string"){var match=quickExpr.exec(selector);if(match&&(match[1]||!context)){if(match[1])selector=jQuery.clean([match[1]],context);else{var elem=document.getElementById(match[3]);if(elem){if(elem.id!=match[3])return jQuery().find(selector);return jQuery(elem);}selector=[];}}else
+return jQuery(context).find(selector);}else if(jQuery.isFunction(selector))return jQuery(document)[jQuery.fn.ready?"ready":"load"](selector);return this.setArray(jQuery.makeArray(selector));},jquery:"1.2.6",size:function(){return this.length;},length:0,get:function(num){return num==undefined?jQuery.makeArray(this):this[num];},pushStack:function(elems){var ret=jQuery(elems);ret.prevObject=this;return ret;},setArray:function(elems){this.length=0;Array.prototype.push.apply(this,elems);return this;},each:function(callback,args){return jQuery.each(this,callback,args);},index:function(elem){var ret=-1;return jQuery.inArray(elem&&elem.jquery?elem[0]:elem,this);},attr:function(name,value,type){var options=name;if(name.constructor==String)if(value===undefined)return this[0]&&jQuery[type||"attr"](this[0],name);else{options={};options[name]=value;}return this.each(function(i){for(name in options)jQuery.attr(type?this.style:this,name,jQuery.prop(this,options[name],type,i,name));});},css:function(key,value){if((key=='width'||key=='height')&&parseFloat(value)<0)value=undefined;return this.attr(key,value,"curCSS");},text:function(text){if(typeof text!="object"&&text!=null)return this.empty().append((this[0]&&this[0].ownerDocument||document).createTextNode(text));var ret="";jQuery.each(text||this,function(){jQuery.each(this.childNodes,function(){if(this.nodeType!=8)ret+=this.nodeType!=1?this.nodeValue:jQuery.fn.text([this]);});});return ret;},wrapAll:function(html){if(this[0])jQuery(html,this[0].ownerDocument).clone().insertBefore(this[0]).map(function(){var elem=this;while(elem.firstChild)elem=elem.firstChild;return elem;}).append(this);return this;},wrapInner:function(html){return this.each(function(){jQuery(this).contents().wrapAll(html);});},wrap:function(html){return this.each(function(){jQuery(this).wrapAll(html);});},append:function(){return this.domManip(arguments,true,false,function(elem){if(this.nodeType==1)this.appendChild(elem);});},prepend:function(){return this.domManip(arguments,true,true,function(elem){if(this.nodeType==1)this.insertBefore(elem,this.firstChild);});},before:function(){return this.domManip(arguments,false,false,function(elem){this.parentNode.insertBefore(elem,this);});},after:function(){return this.domManip(arguments,false,true,function(elem){this.parentNode.insertBefore(elem,this.nextSibling);});},end:function(){return this.prevObject||jQuery([]);},find:function(selector){var elems=jQuery.map(this,function(elem){return jQuery.find(selector,elem);});return this.pushStack(/[^+>] [^+>]/.test(selector)||selector.indexOf("..")>-1?jQuery.unique(elems):elems);},clone:function(events){var ret=this.map(function(){if(jQuery.browser.msie&&!jQuery.isXMLDoc(this)){var clone=this.cloneNode(true),container=document.createElement("div");container.appendChild(clone);return jQuery.clean([container.innerHTML])[0];}else
+return this.cloneNode(true);});var clone=ret.find("*").andSelf().each(function(){if(this[expando]!=undefined)this[expando]=null;});if(events===true)this.find("*").andSelf().each(function(i){if(this.nodeType==3)return;var events=jQuery.data(this,"events");for(var type in events)for(var handler in events[type])jQuery.event.add(clone[i],type,events[type][handler],events[type][handler].data);});return ret;},filter:function(selector){return this.pushStack(jQuery.isFunction(selector)&&jQuery.grep(this,function(elem,i){return selector.call(elem,i);})||jQuery.multiFilter(selector,this));},not:function(selector){if(selector.constructor==String)if(isSimple.test(selector))return this.pushStack(jQuery.multiFilter(selector,this,true));else
+selector=jQuery.multiFilter(selector,this);var isArrayLike=selector.length&&selector[selector.length-1]!==undefined&&!selector.nodeType;return this.filter(function(){return isArrayLike?jQuery.inArray(this,selector)<0:this!=selector;});},add:function(selector){return this.pushStack(jQuery.unique(jQuery.merge(this.get(),typeof selector=='string'?jQuery(selector):jQuery.makeArray(selector))));},is:function(selector){return!!selector&&jQuery.multiFilter(selector,this).length>0;},hasClass:function(selector){return this.is("."+selector);},val:function(value){if(value==undefined){if(this.length){var elem=this[0];if(jQuery.nodeName(elem,"select")){var index=elem.selectedIndex,values=[],options=elem.options,one=elem.type=="select-one";if(index<0)return null;for(var i=one?index:0,max=one?index+1:options.length;i<max;i++){var option=options[i];if(option.selected){value=jQuery.browser.msie&&!option.attributes.value.specified?option.text:option.value;if(one)return value;values.push(value);}}return values;}else
+return(this[0].value||"").replace(/\r/g,"");}return undefined;}if(value.constructor==Number)value+='';return this.each(function(){if(this.nodeType!=1)return;if(value.constructor==Array&&/radio|checkbox/.test(this.type))this.checked=(jQuery.inArray(this.value,value)>=0||jQuery.inArray(this.name,value)>=0);else if(jQuery.nodeName(this,"select")){var values=jQuery.makeArray(value);jQuery("option",this).each(function(){this.selected=(jQuery.inArray(this.value,values)>=0||jQuery.inArray(this.text,values)>=0);});if(!values.length)this.selectedIndex=-1;}else
+this.value=value;});},html:function(value){return value==undefined?(this[0]?this[0].innerHTML:null):this.empty().append(value);},replaceWith:function(value){return this.after(value).remove();},eq:function(i){return this.slice(i,i+1);},slice:function(){return this.pushStack(Array.prototype.slice.apply(this,arguments));},map:function(callback){return this.pushStack(jQuery.map(this,function(elem,i){return callback.call(elem,i,elem);}));},andSelf:function(){return this.add(this.prevObject);},data:function(key,value){var parts=key.split(".");parts[1]=parts[1]?"."+parts[1]:"";if(value===undefined){var data=this.triggerHandler("getData"+parts[1]+"!",[parts[0]]);if(data===undefined&&this.length)data=jQuery.data(this[0],key);return data===undefined&&parts[1]?this.data(parts[0]):data;}else
+return this.trigger("setData"+parts[1]+"!",[parts[0],value]).each(function(){jQuery.data(this,key,value);});},removeData:function(key){return this.each(function(){jQuery.removeData(this,key);});},domManip:function(args,table,reverse,callback){var clone=this.length>1,elems;return this.each(function(){if(!elems){elems=jQuery.clean(args,this.ownerDocument);if(reverse)elems.reverse();}var obj=this;if(table&&jQuery.nodeName(this,"table")&&jQuery.nodeName(elems[0],"tr"))obj=this.getElementsByTagName("tbody")[0]||this.appendChild(this.ownerDocument.createElement("tbody"));var scripts=jQuery([]);jQuery.each(elems,function(){var elem=clone?jQuery(this).clone(true)[0]:this;if(jQuery.nodeName(elem,"script"))scripts=scripts.add(elem);else{if(elem.nodeType==1)scripts=scripts.add(jQuery("script",elem).remove());callback.call(obj,elem);}});scripts.each(evalScript);});}};jQuery.fn.init.prototype=jQuery.fn;function evalScript(i,elem){if(elem.src)jQuery.ajax({url:elem.src,async:false,dataType:"script"});else
+jQuery.globalEval(elem.text||elem.textContent||elem.innerHTML||"");if(elem.parentNode)elem.parentNode.removeChild(elem);}function now(){return+new Date;}jQuery.extend=jQuery.fn.extend=function(){var target=arguments[0]||{},i=1,length=arguments.length,deep=false,options;if(target.constructor==Boolean){deep=target;target=arguments[1]||{};i=2;}if(typeof target!="object"&&typeof target!="function")target={};if(length==i){target=this;--i;}for(;i<length;i++)if((options=arguments[i])!=null)for(var name in options){var src=target[name],copy=options[name];if(target===copy)continue;if(deep&©&&typeof copy=="object"&&!copy.nodeType)target[name]=jQuery.extend(deep,src||(copy.length!=null?[]:{}),copy);else if(copy!==undefined)target[name]=copy;}return target;};var expando="jQuery"+now(),uuid=0,windowData={},exclude=/z-?index|font-?weight|opacity|zoom|line-?height/i,defaultView=document.defaultView||{};jQuery.extend({noConflict:function(deep){window.$=_$;if(deep)window.jQuery=_jQuery;return jQuery;},isFunction:function(fn){return!!fn&&typeof fn!="string"&&!fn.nodeName&&fn.constructor!=Array&&/^[\s[]?function/.test(fn+"");},isXMLDoc:function(elem){return elem.documentElement&&!elem.body||elem.tagName&&elem.ownerDocument&&!elem.ownerDocument.body;},globalEval:function(data){data=jQuery.trim(data);if(data){var head=document.getElementsByTagName("head")[0]||document.documentElement,script=document.createElement("script");script.type="text/javascript";if(jQuery.browser.msie)script.text=data;else
+script.appendChild(document.createTextNode(data));head.insertBefore(script,head.firstChild);head.removeChild(script);}},nodeName:function(elem,name){return elem.nodeName&&elem.nodeName.toUpperCase()==name.toUpperCase();},cache:{},data:function(elem,name,data){elem=elem==window?windowData:elem;var id=elem[expando];if(!id)id=elem[expando]=++uuid;if(name&&!jQuery.cache[id])jQuery.cache[id]={};if(data!==undefined)jQuery.cache[id][name]=data;return name?jQuery.cache[id][name]:id;},removeData:function(elem,name){elem=elem==window?windowData:elem;var id=elem[expando];if(name){if(jQuery.cache[id]){delete jQuery.cache[id][name];name="";for(name in jQuery.cache[id])break;if(!name)jQuery.removeData(elem);}}else{try{delete elem[expando];}catch(e){if(elem.removeAttribute)elem.removeAttribute(expando);}delete jQuery.cache[id];}},each:function(object,callback,args){var name,i=0,length=object.length;if(args){if(length==undefined){for(name in object)if(callback.apply(object[name],args)===false)break;}else
+for(;i<length;)if(callback.apply(object[i++],args)===false)break;}else{if(length==undefined){for(name in object)if(callback.call(object[name],name,object[name])===false)break;}else
+for(var value=object[0];i<length&&callback.call(value,i,value)!==false;value=object[++i]){}}return object;},prop:function(elem,value,type,i,name){if(jQuery.isFunction(value))value=value.call(elem,i);return value&&value.constructor==Number&&type=="curCSS"&&!exclude.test(name)?value+"px":value;},className:{add:function(elem,classNames){jQuery.each((classNames||"").split(/\s+/),function(i,className){if(elem.nodeType==1&&!jQuery.className.has(elem.className,className))elem.className+=(elem.className?" ":"")+className;});},remove:function(elem,classNames){if(elem.nodeType==1)elem.className=classNames!=undefined?jQuery.grep(elem.className.split(/\s+/),function(className){return!jQuery.className.has(classNames,className);}).join(" "):"";},has:function(elem,className){return jQuery.inArray(className,(elem.className||elem).toString().split(/\s+/))>-1;}},swap:function(elem,options,callback){var old={};for(var name in options){old[name]=elem.style[name];elem.style[name]=options[name];}callback.call(elem);for(var name in options)elem.style[name]=old[name];},css:function(elem,name,force){if(name=="width"||name=="height"){var val,props={position:"absolute",visibility:"hidden",display:"block"},which=name=="width"?["Left","Right"]:["Top","Bottom"];function getWH(){val=name=="width"?elem.offsetWidth:elem.offsetHeight;var padding=0,border=0;jQuery.each(which,function(){padding+=parseFloat(jQuery.curCSS(elem,"padding"+this,true))||0;border+=parseFloat(jQuery.curCSS(elem,"border"+this+"Width",true))||0;});val-=Math.round(padding+border);}if(jQuery(elem).is(":visible"))getWH();else
+jQuery.swap(elem,props,getWH);return Math.max(0,val);}return jQuery.curCSS(elem,name,force);},curCSS:function(elem,name,force){var ret,style=elem.style;function color(elem){if(!jQuery.browser.safari)return false;var ret=defaultView.getComputedStyle(elem,null);return!ret||ret.getPropertyValue("color")=="";}if(name=="opacity"&&jQuery.browser.msie){ret=jQuery.attr(style,"opacity");return ret==""?"1":ret;}if(jQuery.browser.opera&&name=="display"){var save=style.outline;style.outline="0 solid black";style.outline=save;}if(name.match(/float/i))name=styleFloat;if(!force&&style&&style[name])ret=style[name];else if(defaultView.getComputedStyle){if(name.match(/float/i))name="float";name=name.replace(/([A-Z])/g,"-$1").toLowerCase();var computedStyle=defaultView.getComputedStyle(elem,null);if(computedStyle&&!color(elem))ret=computedStyle.getPropertyValue(name);else{var swap=[],stack=[],a=elem,i=0;for(;a&&color(a);a=a.parentNode)stack.unshift(a);for(;i<stack.length;i++)if(color(stack[i])){swap[i]=stack[i].style.display;stack[i].style.display="block";}ret=name=="display"&&swap[stack.length-1]!=null?"none":(computedStyle&&computedStyle.getPropertyValue(name))||"";for(i=0;i<swap.length;i++)if(swap[i]!=null)stack[i].style.display=swap[i];}if(name=="opacity"&&ret=="")ret="1";}else if(elem.currentStyle){var camelCase=name.replace(/\-(\w)/g,function(all,letter){return letter.toUpperCase();});ret=elem.currentStyle[name]||elem.currentStyle[camelCase];if(!/^\d+(px)?$/i.test(ret)&&/^\d/.test(ret)){var left=style.left,rsLeft=elem.runtimeStyle.left;elem.runtimeStyle.left=elem.currentStyle.left;style.left=ret||0;ret=style.pixelLeft+"px";style.left=left;elem.runtimeStyle.left=rsLeft;}}return ret;},clean:function(elems,context){var ret=[];context=context||document;if(typeof context.createElement=='undefined')context=context.ownerDocument||context[0]&&context[0].ownerDocument||document;jQuery.each(elems,function(i,elem){if(!elem)return;if(elem.constructor==Number)elem+='';if(typeof elem=="string"){elem=elem.replace(/(<(\w+)[^>]*?)\/>/g,function(all,front,tag){return tag.match(/^(abbr|br|col|img|input|link|meta|param|hr|area|embed)$/i)?all:front+"></"+tag+">";});var tags=jQuery.trim(elem).toLowerCase(),div=context.createElement("div");var wrap=!tags.indexOf("<opt")&&[1,"<select multiple='multiple'>","</select>"]||!tags.indexOf("<leg")&&[1,"<fieldset>","</fieldset>"]||tags.match(/^<(thead|tbody|tfoot|colg|cap)/)&&[1,"<table>","</table>"]||!tags.indexOf("<tr")&&[2,"<table><tbody>","</tbody></table>"]||(!tags.indexOf("<td")||!tags.indexOf("<th"))&&[3,"<table><tbody><tr>","</tr></tbody></table>"]||!tags.indexOf("<col")&&[2,"<table><tbody></tbody><colgroup>","</colgroup></table>"]||jQuery.browser.msie&&[1,"div<div>","</div>"]||[0,"",""];div.innerHTML=wrap[1]+elem+wrap[2];while(wrap[0]--)div=div.lastChild;if(jQuery.browser.msie){var tbody=!tags.indexOf("<table")&&tags.indexOf("<tbody")<0?div.firstChild&&div.firstChild.childNodes:wrap[1]=="<table>"&&tags.indexOf("<tbody")<0?div.childNodes:[];for(var j=tbody.length-1;j>=0;--j)if(jQuery.nodeName(tbody[j],"tbody")&&!tbody[j].childNodes.length)tbody[j].parentNode.removeChild(tbody[j]);if(/^\s/.test(elem))div.insertBefore(context.createTextNode(elem.match(/^\s*/)[0]),div.firstChild);}elem=jQuery.makeArray(div.childNodes);}if(elem.length===0&&(!jQuery.nodeName(elem,"form")&&!jQuery.nodeName(elem,"select")))return;if(elem[0]==undefined||jQuery.nodeName(elem,"form")||elem.options)ret.push(elem);else
+ret=jQuery.merge(ret,elem);});return ret;},attr:function(elem,name,value){if(!elem||elem.nodeType==3||elem.nodeType==8)return undefined;var notxml=!jQuery.isXMLDoc(elem),set=value!==undefined,msie=jQuery.browser.msie;name=notxml&&jQuery.props[name]||name;if(elem.tagName){var special=/href|src|style/.test(name);if(name=="selected"&&jQuery.browser.safari)elem.parentNode.selectedIndex;if(name in elem&¬xml&&!special){if(set){if(name=="type"&&jQuery.nodeName(elem,"input")&&elem.parentNode)throw"type property can't be changed";elem[name]=value;}if(jQuery.nodeName(elem,"form")&&elem.getAttributeNode(name))return elem.getAttributeNode(name).nodeValue;return elem[name];}if(msie&¬xml&&name=="style")return jQuery.attr(elem.style,"cssText",value);if(set)elem.setAttribute(name,""+value);var attr=msie&¬xml&&special?elem.getAttribute(name,2):elem.getAttribute(name);return attr===null?undefined:attr;}if(msie&&name=="opacity"){if(set){elem.zoom=1;elem.filter=(elem.filter||"").replace(/alpha\([^)]*\)/,"")+(parseInt(value)+''=="NaN"?"":"alpha(opacity="+value*100+")");}return elem.filter&&elem.filter.indexOf("opacity=")>=0?(parseFloat(elem.filter.match(/opacity=([^)]*)/)[1])/100)+'':"";}name=name.replace(/-([a-z])/ig,function(all,letter){return letter.toUpperCase();});if(set)elem[name]=value;return elem[name];},trim:function(text){return(text||"").replace(/^\s+|\s+$/g,"");},makeArray:function(array){var ret=[];if(array!=null){var i=array.length;if(i==null||array.split||array.setInterval||array.call)ret[0]=array;else
+while(i)ret[--i]=array[i];}return ret;},inArray:function(elem,array){for(var i=0,length=array.length;i<length;i++)if(array[i]===elem)return i;return-1;},merge:function(first,second){var i=0,elem,pos=first.length;if(jQuery.browser.msie){while(elem=second[i++])if(elem.nodeType!=8)first[pos++]=elem;}else
+while(elem=second[i++])first[pos++]=elem;return first;},unique:function(array){var ret=[],done={};try{for(var i=0,length=array.length;i<length;i++){var id=jQuery.data(array[i]);if(!done[id]){done[id]=true;ret.push(array[i]);}}}catch(e){ret=array;}return ret;},grep:function(elems,callback,inv){var ret=[];for(var i=0,length=elems.length;i<length;i++)if(!inv!=!callback(elems[i],i))ret.push(elems[i]);return ret;},map:function(elems,callback){var ret=[];for(var i=0,length=elems.length;i<length;i++){var value=callback(elems[i],i);if(value!=null)ret[ret.length]=value;}return ret.concat.apply([],ret);}});var userAgent=navigator.userAgent.toLowerCase();jQuery.browser={version:(userAgent.match(/.+(?:rv|it|ra|ie)[\/: ]([\d.]+)/)||[])[1],safari:/webkit/.test(userAgent),opera:/opera/.test(userAgent),msie:/msie/.test(userAgent)&&!/opera/.test(userAgent),mozilla:/mozilla/.test(userAgent)&&!/(compatible|webkit)/.test(userAgent)};var styleFloat=jQuery.browser.msie?"styleFloat":"cssFloat";jQuery.extend({boxModel:!jQuery.browser.msie||document.compatMode=="CSS1Compat",props:{"for":"htmlFor","class":"className","float":styleFloat,cssFloat:styleFloat,styleFloat:styleFloat,readonly:"readOnly",maxlength:"maxLength",cellspacing:"cellSpacing"}});jQuery.each({parent:function(elem){return elem.parentNode;},parents:function(elem){return jQuery.dir(elem,"parentNode");},next:function(elem){return jQuery.nth(elem,2,"nextSibling");},prev:function(elem){return jQuery.nth(elem,2,"previousSibling");},nextAll:function(elem){return jQuery.dir(elem,"nextSibling");},prevAll:function(elem){return jQuery.dir(elem,"previousSibling");},siblings:function(elem){return jQuery.sibling(elem.parentNode.firstChild,elem);},children:function(elem){return jQuery.sibling(elem.firstChild);},contents:function(elem){return jQuery.nodeName(elem,"iframe")?elem.contentDocument||elem.contentWindow.document:jQuery.makeArray(elem.childNodes);}},function(name,fn){jQuery.fn[name]=function(selector){var ret=jQuery.map(this,fn);if(selector&&typeof selector=="string")ret=jQuery.multiFilter(selector,ret);return this.pushStack(jQuery.unique(ret));};});jQuery.each({appendTo:"append",prependTo:"prepend",insertBefore:"before",insertAfter:"after",replaceAll:"replaceWith"},function(name,original){jQuery.fn[name]=function(){var args=arguments;return this.each(function(){for(var i=0,length=args.length;i<length;i++)jQuery(args[i])[original](this);});};});jQuery.each({removeAttr:function(name){jQuery.attr(this,name,"");if(this.nodeType==1)this.removeAttribute(name);},addClass:function(classNames){jQuery.className.add(this,classNames);},removeClass:function(classNames){jQuery.className.remove(this,classNames);},toggleClass:function(classNames){jQuery.className[jQuery.className.has(this,classNames)?"remove":"add"](this,classNames);},remove:function(selector){if(!selector||jQuery.filter(selector,[this]).r.length){jQuery("*",this).add(this).each(function(){jQuery.event.remove(this);jQuery.removeData(this);});if(this.parentNode)this.parentNode.removeChild(this);}},empty:function(){jQuery(">*",this).remove();while(this.firstChild)this.removeChild(this.firstChild);}},function(name,fn){jQuery.fn[name]=function(){return this.each(fn,arguments);};});jQuery.each(["Height","Width"],function(i,name){var type=name.toLowerCase();jQuery.fn[type]=function(size){return this[0]==window?jQuery.browser.opera&&document.body["client"+name]||jQuery.browser.safari&&window["inner"+name]||document.compatMode=="CSS1Compat"&&document.documentElement["client"+name]||document.body["client"+name]:this[0]==document?Math.max(Math.max(document.body["scroll"+name],document.documentElement["scroll"+name]),Math.max(document.body["offset"+name],document.documentElement["offset"+name])):size==undefined?(this.length?jQuery.css(this[0],type):null):this.css(type,size.constructor==String?size:size+"px");};});function num(elem,prop){return elem[0]&&parseInt(jQuery.curCSS(elem[0],prop,true),10)||0;}var chars=jQuery.browser.safari&&parseInt(jQuery.browser.version)<417?"(?:[\\w*_-]|\\\\.)":"(?:[\\w\u0128-\uFFFF*_-]|\\\\.)",quickChild=new RegExp("^>\\s*("+chars+"+)"),quickID=new RegExp("^("+chars+"+)(#)("+chars+"+)"),quickClass=new RegExp("^([#.]?)("+chars+"*)");jQuery.extend({expr:{"":function(a,i,m){return m[2]=="*"||jQuery.nodeName(a,m[2]);},"#":function(a,i,m){return a.getAttribute("id")==m[2];},":":{lt:function(a,i,m){return i<m[3]-0;},gt:function(a,i,m){return i>m[3]-0;},nth:function(a,i,m){return m[3]-0==i;},eq:function(a,i,m){return m[3]-0==i;},first:function(a,i){return i==0;},last:function(a,i,m,r){return i==r.length-1;},even:function(a,i){return i%2==0;},odd:function(a,i){return i%2;},"first-child":function(a){return a.parentNode.getElementsByTagName("*")[0]==a;},"last-child":function(a){return jQuery.nth(a.parentNode.lastChild,1,"previousSibling")==a;},"only-child":function(a){return!jQuery.nth(a.parentNode.lastChild,2,"previousSibling");},parent:function(a){return a.firstChild;},empty:function(a){return!a.firstChild;},contains:function(a,i,m){return(a.textContent||a.innerText||jQuery(a).text()||"").indexOf(m[3])>=0;},visible:function(a){return"hidden"!=a.type&&jQuery.css(a,"display")!="none"&&jQuery.css(a,"visibility")!="hidden";},hidden:function(a){return"hidden"==a.type||jQuery.css(a,"display")=="none"||jQuery.css(a,"visibility")=="hidden";},enabled:function(a){return!a.disabled;},disabled:function(a){return a.disabled;},checked:function(a){return a.checked;},selected:function(a){return a.selected||jQuery.attr(a,"selected");},text:function(a){return"text"==a.type;},radio:function(a){return"radio"==a.type;},checkbox:function(a){return"checkbox"==a.type;},file:function(a){return"file"==a.type;},password:function(a){return"password"==a.type;},submit:function(a){return"submit"==a.type;},image:function(a){return"image"==a.type;},reset:function(a){return"reset"==a.type;},button:function(a){return"button"==a.type||jQuery.nodeName(a,"button");},input:function(a){return/input|select|textarea|button/i.test(a.nodeName);},has:function(a,i,m){return jQuery.find(m[3],a).length;},header:function(a){return/h\d/i.test(a.nodeName);},animated:function(a){return jQuery.grep(jQuery.timers,function(fn){return a==fn.elem;}).length;}}},parse:[/^(\[) *@?([\w-]+) *([!*$^~=]*) *('?"?)(.*?)\4 *\]/,/^(:)([\w-]+)\("?'?(.*?(\(.*?\))?[^(]*?)"?'?\)/,new RegExp("^([:.#]*)("+chars+"+)")],multiFilter:function(expr,elems,not){var old,cur=[];while(expr&&expr!=old){old=expr;var f=jQuery.filter(expr,elems,not);expr=f.t.replace(/^\s*,\s*/,"");cur=not?elems=f.r:jQuery.merge(cur,f.r);}return cur;},find:function(t,context){if(typeof t!="string")return[t];if(context&&context.nodeType!=1&&context.nodeType!=9)return[];context=context||document;var ret=[context],done=[],last,nodeName;while(t&&last!=t){var r=[];last=t;t=jQuery.trim(t);var foundToken=false,re=quickChild,m=re.exec(t);if(m){nodeName=m[1].toUpperCase();for(var i=0;ret[i];i++)for(var c=ret[i].firstChild;c;c=c.nextSibling)if(c.nodeType==1&&(nodeName=="*"||c.nodeName.toUpperCase()==nodeName))r.push(c);ret=r;t=t.replace(re,"");if(t.indexOf(" ")==0)continue;foundToken=true;}else{re=/^([>+~])\s*(\w*)/i;if((m=re.exec(t))!=null){r=[];var merge={};nodeName=m[2].toUpperCase();m=m[1];for(var j=0,rl=ret.length;j<rl;j++){var n=m=="~"||m=="+"?ret[j].nextSibling:ret[j].firstChild;for(;n;n=n.nextSibling)if(n.nodeType==1){var id=jQuery.data(n);if(m=="~"&&merge[id])break;if(!nodeName||n.nodeName.toUpperCase()==nodeName){if(m=="~")merge[id]=true;r.push(n);}if(m=="+")break;}}ret=r;t=jQuery.trim(t.replace(re,""));foundToken=true;}}if(t&&!foundToken){if(!t.indexOf(",")){if(context==ret[0])ret.shift();done=jQuery.merge(done,ret);r=ret=[context];t=" "+t.substr(1,t.length);}else{var re2=quickID;var m=re2.exec(t);if(m){m=[0,m[2],m[3],m[1]];}else{re2=quickClass;m=re2.exec(t);}m[2]=m[2].replace(/\\/g,"");var elem=ret[ret.length-1];if(m[1]=="#"&&elem&&elem.getElementById&&!jQuery.isXMLDoc(elem)){var oid=elem.getElementById(m[2]);if((jQuery.browser.msie||jQuery.browser.opera)&&oid&&typeof oid.id=="string"&&oid.id!=m[2])oid=jQuery('[@id="'+m[2]+'"]',elem)[0];ret=r=oid&&(!m[3]||jQuery.nodeName(oid,m[3]))?[oid]:[];}else{for(var i=0;ret[i];i++){var tag=m[1]=="#"&&m[3]?m[3]:m[1]!=""||m[0]==""?"*":m[2];if(tag=="*"&&ret[i].nodeName.toLowerCase()=="object")tag="param";r=jQuery.merge(r,ret[i].getElementsByTagName(tag));}if(m[1]==".")r=jQuery.classFilter(r,m[2]);if(m[1]=="#"){var tmp=[];for(var i=0;r[i];i++)if(r[i].getAttribute("id")==m[2]){tmp=[r[i]];break;}r=tmp;}ret=r;}t=t.replace(re2,"");}}if(t){var val=jQuery.filter(t,r);ret=r=val.r;t=jQuery.trim(val.t);}}if(t)ret=[];if(ret&&context==ret[0])ret.shift();done=jQuery.merge(done,ret);return done;},classFilter:function(r,m,not){m=" "+m+" ";var tmp=[];for(var i=0;r[i];i++){var pass=(" "+r[i].className+" ").indexOf(m)>=0;if(!not&&pass||not&&!pass)tmp.push(r[i]);}return tmp;},filter:function(t,r,not){var last;while(t&&t!=last){last=t;var p=jQuery.parse,m;for(var i=0;p[i];i++){m=p[i].exec(t);if(m){t=t.substring(m[0].length);m[2]=m[2].replace(/\\/g,"");break;}}if(!m)break;if(m[1]==":"&&m[2]=="not")r=isSimple.test(m[3])?jQuery.filter(m[3],r,true).r:jQuery(r).not(m[3]);else if(m[1]==".")r=jQuery.classFilter(r,m[2],not);else if(m[1]=="["){var tmp=[],type=m[3];for(var i=0,rl=r.length;i<rl;i++){var a=r[i],z=a[jQuery.props[m[2]]||m[2]];if(z==null||/href|src|selected/.test(m[2]))z=jQuery.attr(a,m[2])||'';if((type==""&&!!z||type=="="&&z==m[5]||type=="!="&&z!=m[5]||type=="^="&&z&&!z.indexOf(m[5])||type=="$="&&z.substr(z.length-m[5].length)==m[5]||(type=="*="||type=="~=")&&z.indexOf(m[5])>=0)^not)tmp.push(a);}r=tmp;}else if(m[1]==":"&&m[2]=="nth-child"){var merge={},tmp=[],test=/(-?)(\d*)n((?:\+|-)?\d*)/.exec(m[3]=="even"&&"2n"||m[3]=="odd"&&"2n+1"||!/\D/.test(m[3])&&"0n+"+m[3]||m[3]),first=(test[1]+(test[2]||1))-0,last=test[3]-0;for(var i=0,rl=r.length;i<rl;i++){var node=r[i],parentNode=node.parentNode,id=jQuery.data(parentNode);if(!merge[id]){var c=1;for(var n=parentNode.firstChild;n;n=n.nextSibling)if(n.nodeType==1)n.nodeIndex=c++;merge[id]=true;}var add=false;if(first==0){if(node.nodeIndex==last)add=true;}else if((node.nodeIndex-last)%first==0&&(node.nodeIndex-last)/first>=0)add=true;if(add^not)tmp.push(node);}r=tmp;}else{var fn=jQuery.expr[m[1]];if(typeof fn=="object")fn=fn[m[2]];if(typeof fn=="string")fn=eval("false||function(a,i){return "+fn+";}");r=jQuery.grep(r,function(elem,i){return fn(elem,i,m,r);},not);}}return{r:r,t:t};},dir:function(elem,dir){var matched=[],cur=elem[dir];while(cur&&cur!=document){if(cur.nodeType==1)matched.push(cur);cur=cur[dir];}return matched;},nth:function(cur,result,dir,elem){result=result||1;var num=0;for(;cur;cur=cur[dir])if(cur.nodeType==1&&++num==result)break;return cur;},sibling:function(n,elem){var r=[];for(;n;n=n.nextSibling){if(n.nodeType==1&&n!=elem)r.push(n);}return r;}});jQuery.event={add:function(elem,types,handler,data){if(elem.nodeType==3||elem.nodeType==8)return;if(jQuery.browser.msie&&elem.setInterval)elem=window;if(!handler.guid)handler.guid=this.guid++;if(data!=undefined){var fn=handler;handler=this.proxy(fn,function(){return fn.apply(this,arguments);});handler.data=data;}var events=jQuery.data(elem,"events")||jQuery.data(elem,"events",{}),handle=jQuery.data(elem,"handle")||jQuery.data(elem,"handle",function(){if(typeof jQuery!="undefined"&&!jQuery.event.triggered)return jQuery.event.handle.apply(arguments.callee.elem,arguments);});handle.elem=elem;jQuery.each(types.split(/\s+/),function(index,type){var parts=type.split(".");type=parts[0];handler.type=parts[1];var handlers=events[type];if(!handlers){handlers=events[type]={};if(!jQuery.event.special[type]||jQuery.event.special[type].setup.call(elem)===false){if(elem.addEventListener)elem.addEventListener(type,handle,false);else if(elem.attachEvent)elem.attachEvent("on"+type,handle);}}handlers[handler.guid]=handler;jQuery.event.global[type]=true;});elem=null;},guid:1,global:{},remove:function(elem,types,handler){if(elem.nodeType==3||elem.nodeType==8)return;var events=jQuery.data(elem,"events"),ret,index;if(events){if(types==undefined||(typeof types=="string"&&types.charAt(0)=="."))for(var type in events)this.remove(elem,type+(types||""));else{if(types.type){handler=types.handler;types=types.type;}jQuery.each(types.split(/\s+/),function(index,type){var parts=type.split(".");type=parts[0];if(events[type]){if(handler)delete events[type][handler.guid];else
+for(handler in events[type])if(!parts[1]||events[type][handler].type==parts[1])delete events[type][handler];for(ret in events[type])break;if(!ret){if(!jQuery.event.special[type]||jQuery.event.special[type].teardown.call(elem)===false){if(elem.removeEventListener)elem.removeEventListener(type,jQuery.data(elem,"handle"),false);else if(elem.detachEvent)elem.detachEvent("on"+type,jQuery.data(elem,"handle"));}ret=null;delete events[type];}}});}for(ret in events)break;if(!ret){var handle=jQuery.data(elem,"handle");if(handle)handle.elem=null;jQuery.removeData(elem,"events");jQuery.removeData(elem,"handle");}}},trigger:function(type,data,elem,donative,extra){data=jQuery.makeArray(data);if(type.indexOf("!")>=0){type=type.slice(0,-1);var exclusive=true;}if(!elem){if(this.global[type])jQuery("*").add([window,document]).trigger(type,data);}else{if(elem.nodeType==3||elem.nodeType==8)return undefined;var val,ret,fn=jQuery.isFunction(elem[type]||null),event=!data[0]||!data[0].preventDefault;if(event){data.unshift({type:type,target:elem,preventDefault:function(){},stopPropagation:function(){},timeStamp:now()});data[0][expando]=true;}data[0].type=type;if(exclusive)data[0].exclusive=true;var handle=jQuery.data(elem,"handle");if(handle)val=handle.apply(elem,data);if((!fn||(jQuery.nodeName(elem,'a')&&type=="click"))&&elem["on"+type]&&elem["on"+type].apply(elem,data)===false)val=false;if(event)data.shift();if(extra&&jQuery.isFunction(extra)){ret=extra.apply(elem,val==null?data:data.concat(val));if(ret!==undefined)val=ret;}if(fn&&donative!==false&&val!==false&&!(jQuery.nodeName(elem,'a')&&type=="click")){this.triggered=true;try{elem[type]();}catch(e){}}this.triggered=false;}return val;},handle:function(event){var val,ret,namespace,all,handlers;event=arguments[0]=jQuery.event.fix(event||window.event);namespace=event.type.split(".");event.type=namespace[0];namespace=namespace[1];all=!namespace&&!event.exclusive;handlers=(jQuery.data(this,"events")||{})[event.type];for(var j in handlers){var handler=handlers[j];if(all||handler.type==namespace){event.handler=handler;event.data=handler.data;ret=handler.apply(this,arguments);if(val!==false)val=ret;if(ret===false){event.preventDefault();event.stopPropagation();}}}return val;},fix:function(event){if(event[expando]==true)return event;var originalEvent=event;event={originalEvent:originalEvent};var props="altKey attrChange attrName bubbles button cancelable charCode clientX clientY ctrlKey currentTarget data detail eventPhase fromElement handler keyCode metaKey newValue originalTarget pageX pageY prevValue relatedNode relatedTarget screenX screenY shiftKey srcElement target timeStamp toElement type view wheelDelta which".split(" ");for(var i=props.length;i;i--)event[props[i]]=originalEvent[props[i]];event[expando]=true;event.preventDefault=function(){if(originalEvent.preventDefault)originalEvent.preventDefault();originalEvent.returnValue=false;};event.stopPropagation=function(){if(originalEvent.stopPropagation)originalEvent.stopPropagation();originalEvent.cancelBubble=true;};event.timeStamp=event.timeStamp||now();if(!event.target)event.target=event.srcElement||document;if(event.target.nodeType==3)event.target=event.target.parentNode;if(!event.relatedTarget&&event.fromElement)event.relatedTarget=event.fromElement==event.target?event.toElement:event.fromElement;if(event.pageX==null&&event.clientX!=null){var doc=document.documentElement,body=document.body;event.pageX=event.clientX+(doc&&doc.scrollLeft||body&&body.scrollLeft||0)-(doc.clientLeft||0);event.pageY=event.clientY+(doc&&doc.scrollTop||body&&body.scrollTop||0)-(doc.clientTop||0);}if(!event.which&&((event.charCode||event.charCode===0)?event.charCode:event.keyCode))event.which=event.charCode||event.keyCode;if(!event.metaKey&&event.ctrlKey)event.metaKey=event.ctrlKey;if(!event.which&&event.button)event.which=(event.button&1?1:(event.button&2?3:(event.button&4?2:0)));return event;},proxy:function(fn,proxy){proxy.guid=fn.guid=fn.guid||proxy.guid||this.guid++;return proxy;},special:{ready:{setup:function(){bindReady();return;},teardown:function(){return;}},mouseenter:{setup:function(){if(jQuery.browser.msie)return false;jQuery(this).bind("mouseover",jQuery.event.special.mouseenter.handler);return true;},teardown:function(){if(jQuery.browser.msie)return false;jQuery(this).unbind("mouseover",jQuery.event.special.mouseenter.handler);return true;},handler:function(event){if(withinElement(event,this))return true;event.type="mouseenter";return jQuery.event.handle.apply(this,arguments);}},mouseleave:{setup:function(){if(jQuery.browser.msie)return false;jQuery(this).bind("mouseout",jQuery.event.special.mouseleave.handler);return true;},teardown:function(){if(jQuery.browser.msie)return false;jQuery(this).unbind("mouseout",jQuery.event.special.mouseleave.handler);return true;},handler:function(event){if(withinElement(event,this))return true;event.type="mouseleave";return jQuery.event.handle.apply(this,arguments);}}}};jQuery.fn.extend({bind:function(type,data,fn){return type=="unload"?this.one(type,data,fn):this.each(function(){jQuery.event.add(this,type,fn||data,fn&&data);});},one:function(type,data,fn){var one=jQuery.event.proxy(fn||data,function(event){jQuery(this).unbind(event,one);return(fn||data).apply(this,arguments);});return this.each(function(){jQuery.event.add(this,type,one,fn&&data);});},unbind:function(type,fn){return this.each(function(){jQuery.event.remove(this,type,fn);});},trigger:function(type,data,fn){return this.each(function(){jQuery.event.trigger(type,data,this,true,fn);});},triggerHandler:function(type,data,fn){return this[0]&&jQuery.event.trigger(type,data,this[0],false,fn);},toggle:function(fn){var args=arguments,i=1;while(i<args.length)jQuery.event.proxy(fn,args[i++]);return this.click(jQuery.event.proxy(fn,function(event){this.lastToggle=(this.lastToggle||0)%i;event.preventDefault();return args[this.lastToggle++].apply(this,arguments)||false;}));},hover:function(fnOver,fnOut){return this.bind('mouseenter',fnOver).bind('mouseleave',fnOut);},ready:function(fn){bindReady();if(jQuery.isReady)fn.call(document,jQuery);else
+jQuery.readyList.push(function(){return fn.call(this,jQuery);});return this;}});jQuery.extend({isReady:false,readyList:[],ready:function(){if(!jQuery.isReady){jQuery.isReady=true;if(jQuery.readyList){jQuery.each(jQuery.readyList,function(){this.call(document);});jQuery.readyList=null;}jQuery(document).triggerHandler("ready");}}});var readyBound=false;function bindReady(){if(readyBound)return;readyBound=true;if(document.addEventListener&&!jQuery.browser.opera)document.addEventListener("DOMContentLoaded",jQuery.ready,false);if(jQuery.browser.msie&&window==top)(function(){if(jQuery.isReady)return;try{document.documentElement.doScroll("left");}catch(error){setTimeout(arguments.callee,0);return;}jQuery.ready();})();if(jQuery.browser.opera)document.addEventListener("DOMContentLoaded",function(){if(jQuery.isReady)return;for(var i=0;i<document.styleSheets.length;i++)if(document.styleSheets[i].disabled){setTimeout(arguments.callee,0);return;}jQuery.ready();},false);if(jQuery.browser.safari){var numStyles;(function(){if(jQuery.isReady)return;if(document.readyState!="loaded"&&document.readyState!="complete"){setTimeout(arguments.callee,0);return;}if(numStyles===undefined)numStyles=jQuery("style, link[rel=stylesheet]").length;if(document.styleSheets.length!=numStyles){setTimeout(arguments.callee,0);return;}jQuery.ready();})();}jQuery.event.add(window,"load",jQuery.ready);}jQuery.each(("blur,focus,load,resize,scroll,unload,click,dblclick,"+"mousedown,mouseup,mousemove,mouseover,mouseout,change,select,"+"submit,keydown,keypress,keyup,error").split(","),function(i,name){jQuery.fn[name]=function(fn){return fn?this.bind(name,fn):this.trigger(name);};});var withinElement=function(event,elem){var parent=event.relatedTarget;while(parent&&parent!=elem)try{parent=parent.parentNode;}catch(error){parent=elem;}return parent==elem;};jQuery(window).bind("unload",function(){jQuery("*").add(document).unbind();});jQuery.fn.extend({_load:jQuery.fn.load,load:function(url,params,callback){if(typeof url!='string')return this._load(url);var off=url.indexOf(" ");if(off>=0){var selector=url.slice(off,url.length);url=url.slice(0,off);}callback=callback||function(){};var type="GET";if(params)if(jQuery.isFunction(params)){callback=params;params=null;}else{params=jQuery.param(params);type="POST";}var self=this;jQuery.ajax({url:url,type:type,dataType:"html",data:params,complete:function(res,status){if(status=="success"||status=="notmodified")self.html(selector?jQuery("<div/>").append(res.responseText.replace(/<script(.|\s)*?\/script>/g,"")).find(selector):res.responseText);self.each(callback,[res.responseText,status,res]);}});return this;},serialize:function(){return jQuery.param(this.serializeArray());},serializeArray:function(){return this.map(function(){return jQuery.nodeName(this,"form")?jQuery.makeArray(this.elements):this;}).filter(function(){return this.name&&!this.disabled&&(this.checked||/select|textarea/i.test(this.nodeName)||/text|hidden|password/i.test(this.type));}).map(function(i,elem){var val=jQuery(this).val();return val==null?null:val.constructor==Array?jQuery.map(val,function(val,i){return{name:elem.name,value:val};}):{name:elem.name,value:val};}).get();}});jQuery.each("ajaxStart,ajaxStop,ajaxComplete,ajaxError,ajaxSuccess,ajaxSend".split(","),function(i,o){jQuery.fn[o]=function(f){return this.bind(o,f);};});var jsc=now();jQuery.extend({get:function(url,data,callback,type){if(jQuery.isFunction(data)){callback=data;data=null;}return jQuery.ajax({type:"GET",url:url,data:data,success:callback,dataType:type});},getScript:function(url,callback){return jQuery.get(url,null,callback,"script");},getJSON:function(url,data,callback){return jQuery.get(url,data,callback,"json");},post:function(url,data,callback,type){if(jQuery.isFunction(data)){callback=data;data={};}return jQuery.ajax({type:"POST",url:url,data:data,success:callback,dataType:type});},ajaxSetup:function(settings){jQuery.extend(jQuery.ajaxSettings,settings);},ajaxSettings:{url:location.href,global:true,type:"GET",timeout:0,contentType:"application/x-www-form-urlencoded",processData:true,async:true,data:null,username:null,password:null,accepts:{xml:"application/xml, text/xml",html:"text/html",script:"text/javascript, application/javascript",json:"application/json, text/javascript",text:"text/plain",_default:"*/*"}},lastModified:{},ajax:function(s){s=jQuery.extend(true,s,jQuery.extend(true,{},jQuery.ajaxSettings,s));var jsonp,jsre=/=\?(&|$)/g,status,data,type=s.type.toUpperCase();if(s.data&&s.processData&&typeof s.data!="string")s.data=jQuery.param(s.data);if(s.dataType=="jsonp"){if(type=="GET"){if(!s.url.match(jsre))s.url+=(s.url.match(/\?/)?"&":"?")+(s.jsonp||"callback")+"=?";}else if(!s.data||!s.data.match(jsre))s.data=(s.data?s.data+"&":"")+(s.jsonp||"callback")+"=?";s.dataType="json";}if(s.dataType=="json"&&(s.data&&s.data.match(jsre)||s.url.match(jsre))){jsonp="jsonp"+jsc++;if(s.data)s.data=(s.data+"").replace(jsre,"="+jsonp+"$1");s.url=s.url.replace(jsre,"="+jsonp+"$1");s.dataType="script";window[jsonp]=function(tmp){data=tmp;success();complete();window[jsonp]=undefined;try{delete window[jsonp];}catch(e){}if(head)head.removeChild(script);};}if(s.dataType=="script"&&s.cache==null)s.cache=false;if(s.cache===false&&type=="GET"){var ts=now();var ret=s.url.replace(/(\?|&)_=.*?(&|$)/,"$1_="+ts+"$2");s.url=ret+((ret==s.url)?(s.url.match(/\?/)?"&":"?")+"_="+ts:"");}if(s.data&&type=="GET"){s.url+=(s.url.match(/\?/)?"&":"?")+s.data;s.data=null;}if(s.global&&!jQuery.active++)jQuery.event.trigger("ajaxStart");var remote=/^(?:\w+:)?\/\/([^\/?#]+)/;if(s.dataType=="script"&&type=="GET"&&remote.test(s.url)&&remote.exec(s.url)[1]!=location.host){var head=document.getElementsByTagName("head")[0];var script=document.createElement("script");script.src=s.url;if(s.scriptCharset)script.charset=s.scriptCharset;if(!jsonp){var done=false;script.onload=script.onreadystatechange=function(){if(!done&&(!this.readyState||this.readyState=="loaded"||this.readyState=="complete")){done=true;success();complete();head.removeChild(script);}};}head.appendChild(script);return undefined;}var requestDone=false;var xhr=window.ActiveXObject?new ActiveXObject("Microsoft.XMLHTTP"):new XMLHttpRequest();if(s.username)xhr.open(type,s.url,s.async,s.username,s.password);else
+xhr.open(type,s.url,s.async);try{if(s.data)xhr.setRequestHeader("Content-Type",s.contentType);if(s.ifModified)xhr.setRequestHeader("If-Modified-Since",jQuery.lastModified[s.url]||"Thu, 01 Jan 1970 00:00:00 GMT");xhr.setRequestHeader("X-Requested-With","XMLHttpRequest");xhr.setRequestHeader("Accept",s.dataType&&s.accepts[s.dataType]?s.accepts[s.dataType]+", */*":s.accepts._default);}catch(e){}if(s.beforeSend&&s.beforeSend(xhr,s)===false){s.global&&jQuery.active--;xhr.abort();return false;}if(s.global)jQuery.event.trigger("ajaxSend",[xhr,s]);var onreadystatechange=function(isTimeout){if(!requestDone&&xhr&&(xhr.readyState==4||isTimeout=="timeout")){requestDone=true;if(ival){clearInterval(ival);ival=null;}status=isTimeout=="timeout"&&"timeout"||!jQuery.httpSuccess(xhr)&&"error"||s.ifModified&&jQuery.httpNotModified(xhr,s.url)&&"notmodified"||"success";if(status=="success"){try{data=jQuery.httpData(xhr,s.dataType,s.dataFilter);}catch(e){status="parsererror";}}if(status=="success"){var modRes;try{modRes=xhr.getResponseHeader("Last-Modified");}catch(e){}if(s.ifModified&&modRes)jQuery.lastModified[s.url]=modRes;if(!jsonp)success();}else
+jQuery.handleError(s,xhr,status);complete();if(s.async)xhr=null;}};if(s.async){var ival=setInterval(onreadystatechange,13);if(s.timeout>0)setTimeout(function(){if(xhr){xhr.abort();if(!requestDone)onreadystatechange("timeout");}},s.timeout);}try{xhr.send(s.data);}catch(e){jQuery.handleError(s,xhr,null,e);}if(!s.async)onreadystatechange();function success(){if(s.success)s.success(data,status);if(s.global)jQuery.event.trigger("ajaxSuccess",[xhr,s]);}function complete(){if(s.complete)s.complete(xhr,status);if(s.global)jQuery.event.trigger("ajaxComplete",[xhr,s]);if(s.global&&!--jQuery.active)jQuery.event.trigger("ajaxStop");}return xhr;},handleError:function(s,xhr,status,e){if(s.error)s.error(xhr,status,e);if(s.global)jQuery.event.trigger("ajaxError",[xhr,s,e]);},active:0,httpSuccess:function(xhr){try{return!xhr.status&&location.protocol=="file:"||(xhr.status>=200&&xhr.status<300)||xhr.status==304||xhr.status==1223||jQuery.browser.safari&&xhr.status==undefined;}catch(e){}return false;},httpNotModified:function(xhr,url){try{var xhrRes=xhr.getResponseHeader("Last-Modified");return xhr.status==304||xhrRes==jQuery.lastModified[url]||jQuery.browser.safari&&xhr.status==undefined;}catch(e){}return false;},httpData:function(xhr,type,filter){var ct=xhr.getResponseHeader("content-type"),xml=type=="xml"||!type&&ct&&ct.indexOf("xml")>=0,data=xml?xhr.responseXML:xhr.responseText;if(xml&&data.documentElement.tagName=="parsererror")throw"parsererror";if(filter)data=filter(data,type);if(type=="script")jQuery.globalEval(data);if(type=="json")data=eval("("+data+")");return data;},param:function(a){var s=[];if(a.constructor==Array||a.jquery)jQuery.each(a,function(){s.push(encodeURIComponent(this.name)+"="+encodeURIComponent(this.value));});else
+for(var j in a)if(a[j]&&a[j].constructor==Array)jQuery.each(a[j],function(){s.push(encodeURIComponent(j)+"="+encodeURIComponent(this));});else
+s.push(encodeURIComponent(j)+"="+encodeURIComponent(jQuery.isFunction(a[j])?a[j]():a[j]));return s.join("&").replace(/%20/g,"+");}});jQuery.fn.extend({show:function(speed,callback){return speed?this.animate({height:"show",width:"show",opacity:"show"},speed,callback):this.filter(":hidden").each(function(){this.style.display=this.oldblock||"";if(jQuery.css(this,"display")=="none"){var elem=jQuery("<"+this.tagName+" />").appendTo("body");this.style.display=elem.css("display");if(this.style.display=="none")this.style.display="block";elem.remove();}}).end();},hide:function(speed,callback){return speed?this.animate({height:"hide",width:"hide",opacity:"hide"},speed,callback):this.filter(":visible").each(function(){this.oldblock=this.oldblock||jQuery.css(this,"display");this.style.display="none";}).end();},_toggle:jQuery.fn.toggle,toggle:function(fn,fn2){return jQuery.isFunction(fn)&&jQuery.isFunction(fn2)?this._toggle.apply(this,arguments):fn?this.animate({height:"toggle",width:"toggle",opacity:"toggle"},fn,fn2):this.each(function(){jQuery(this)[jQuery(this).is(":hidden")?"show":"hide"]();});},slideDown:function(speed,callback){return this.animate({height:"show"},speed,callback);},slideUp:function(speed,callback){return this.animate({height:"hide"},speed,callback);},slideToggle:function(speed,callback){return this.animate({height:"toggle"},speed,callback);},fadeIn:function(speed,callback){return this.animate({opacity:"show"},speed,callback);},fadeOut:function(speed,callback){return this.animate({opacity:"hide"},speed,callback);},fadeTo:function(speed,to,callback){return this.animate({opacity:to},speed,callback);},animate:function(prop,speed,easing,callback){var optall=jQuery.speed(speed,easing,callback);return this[optall.queue===false?"each":"queue"](function(){if(this.nodeType!=1)return false;var opt=jQuery.extend({},optall),p,hidden=jQuery(this).is(":hidden"),self=this;for(p in prop){if(prop[p]=="hide"&&hidden||prop[p]=="show"&&!hidden)return opt.complete.call(this);if(p=="height"||p=="width"){opt.display=jQuery.css(this,"display");opt.overflow=this.style.overflow;}}if(opt.overflow!=null)this.style.overflow="hidden";opt.curAnim=jQuery.extend({},prop);jQuery.each(prop,function(name,val){var e=new jQuery.fx(self,opt,name);if(/toggle|show|hide/.test(val))e[val=="toggle"?hidden?"show":"hide":val](prop);else{var parts=val.toString().match(/^([+-]=)?([\d+-.]+)(.*)$/),start=e.cur(true)||0;if(parts){var end=parseFloat(parts[2]),unit=parts[3]||"px";if(unit!="px"){self.style[name]=(end||1)+unit;start=((end||1)/e.cur(true))*start;self.style[name]=start+unit;}if(parts[1])end=((parts[1]=="-="?-1:1)*end)+start;e.custom(start,end,unit);}else
+e.custom(start,val,"");}});return true;});},queue:function(type,fn){if(jQuery.isFunction(type)||(type&&type.constructor==Array)){fn=type;type="fx";}if(!type||(typeof type=="string"&&!fn))return queue(this[0],type);return this.each(function(){if(fn.constructor==Array)queue(this,type,fn);else{queue(this,type).push(fn);if(queue(this,type).length==1)fn.call(this);}});},stop:function(clearQueue,gotoEnd){var timers=jQuery.timers;if(clearQueue)this.queue([]);this.each(function(){for(var i=timers.length-1;i>=0;i--)if(timers[i].elem==this){if(gotoEnd)timers[i](true);timers.splice(i,1);}});if(!gotoEnd)this.dequeue();return this;}});var queue=function(elem,type,array){if(elem){type=type||"fx";var q=jQuery.data(elem,type+"queue");if(!q||array)q=jQuery.data(elem,type+"queue",jQuery.makeArray(array));}return q;};jQuery.fn.dequeue=function(type){type=type||"fx";return this.each(function(){var q=queue(this,type);q.shift();if(q.length)q[0].call(this);});};jQuery.extend({speed:function(speed,easing,fn){var opt=speed&&speed.constructor==Object?speed:{complete:fn||!fn&&easing||jQuery.isFunction(speed)&&speed,duration:speed,easing:fn&&easing||easing&&easing.constructor!=Function&&easing};opt.duration=(opt.duration&&opt.duration.constructor==Number?opt.duration:jQuery.fx.speeds[opt.duration])||jQuery.fx.speeds.def;opt.old=opt.complete;opt.complete=function(){if(opt.queue!==false)jQuery(this).dequeue();if(jQuery.isFunction(opt.old))opt.old.call(this);};return opt;},easing:{linear:function(p,n,firstNum,diff){return firstNum+diff*p;},swing:function(p,n,firstNum,diff){return((-Math.cos(p*Math.PI)/2)+0.5)*diff+firstNum;}},timers:[],timerId:null,fx:function(elem,options,prop){this.options=options;this.elem=elem;this.prop=prop;if(!options.orig)options.orig={};}});jQuery.fx.prototype={update:function(){if(this.options.step)this.options.step.call(this.elem,this.now,this);(jQuery.fx.step[this.prop]||jQuery.fx.step._default)(this);if(this.prop=="height"||this.prop=="width")this.elem.style.display="block";},cur:function(force){if(this.elem[this.prop]!=null&&this.elem.style[this.prop]==null)return this.elem[this.prop];var r=parseFloat(jQuery.css(this.elem,this.prop,force));return r&&r>-10000?r:parseFloat(jQuery.curCSS(this.elem,this.prop))||0;},custom:function(from,to,unit){this.startTime=now();this.start=from;this.end=to;this.unit=unit||this.unit||"px";this.now=this.start;this.pos=this.state=0;this.update();var self=this;function t(gotoEnd){return self.step(gotoEnd);}t.elem=this.elem;jQuery.timers.push(t);if(jQuery.timerId==null){jQuery.timerId=setInterval(function(){var timers=jQuery.timers;for(var i=0;i<timers.length;i++)if(!timers[i]())timers.splice(i--,1);if(!timers.length){clearInterval(jQuery.timerId);jQuery.timerId=null;}},13);}},show:function(){this.options.orig[this.prop]=jQuery.attr(this.elem.style,this.prop);this.options.show=true;this.custom(0,this.cur());if(this.prop=="width"||this.prop=="height")this.elem.style[this.prop]="1px";jQuery(this.elem).show();},hide:function(){this.options.orig[this.prop]=jQuery.attr(this.elem.style,this.prop);this.options.hide=true;this.custom(this.cur(),0);},step:function(gotoEnd){var t=now();if(gotoEnd||t>this.options.duration+this.startTime){this.now=this.end;this.pos=this.state=1;this.update();this.options.curAnim[this.prop]=true;var done=true;for(var i in this.options.curAnim)if(this.options.curAnim[i]!==true)done=false;if(done){if(this.options.display!=null){this.elem.style.overflow=this.options.overflow;this.elem.style.display=this.options.display;if(jQuery.css(this.elem,"display")=="none")this.elem.style.display="block";}if(this.options.hide)this.elem.style.display="none";if(this.options.hide||this.options.show)for(var p in this.options.curAnim)jQuery.attr(this.elem.style,p,this.options.orig[p]);}if(done)this.options.complete.call(this.elem);return false;}else{var n=t-this.startTime;this.state=n/this.options.duration;this.pos=jQuery.easing[this.options.easing||(jQuery.easing.swing?"swing":"linear")](this.state,n,0,1,this.options.duration);this.now=this.start+((this.end-this.start)*this.pos);this.update();}return true;}};jQuery.extend(jQuery.fx,{speeds:{slow:600,fast:200,def:400},step:{scrollLeft:function(fx){fx.elem.scrollLeft=fx.now;},scrollTop:function(fx){fx.elem.scrollTop=fx.now;},opacity:function(fx){jQuery.attr(fx.elem.style,"opacity",fx.now);},_default:function(fx){fx.elem.style[fx.prop]=fx.now+fx.unit;}}});jQuery.fn.offset=function(){var left=0,top=0,elem=this[0],results;if(elem)with(jQuery.browser){var parent=elem.parentNode,offsetChild=elem,offsetParent=elem.offsetParent,doc=elem.ownerDocument,safari2=safari&&parseInt(version)<522&&!/adobeair/i.test(userAgent),css=jQuery.curCSS,fixed=css(elem,"position")=="fixed";if(elem.getBoundingClientRect){var box=elem.getBoundingClientRect();add(box.left+Math.max(doc.documentElement.scrollLeft,doc.body.scrollLeft),box.top+Math.max(doc.documentElement.scrollTop,doc.body.scrollTop));add(-doc.documentElement.clientLeft,-doc.documentElement.clientTop);}else{add(elem.offsetLeft,elem.offsetTop);while(offsetParent){add(offsetParent.offsetLeft,offsetParent.offsetTop);if(mozilla&&!/^t(able|d|h)$/i.test(offsetParent.tagName)||safari&&!safari2)border(offsetParent);if(!fixed&&css(offsetParent,"position")=="fixed")fixed=true;offsetChild=/^body$/i.test(offsetParent.tagName)?offsetChild:offsetParent;offsetParent=offsetParent.offsetParent;}while(parent&&parent.tagName&&!/^body|html$/i.test(parent.tagName)){if(!/^inline|table.*$/i.test(css(parent,"display")))add(-parent.scrollLeft,-parent.scrollTop);if(mozilla&&css(parent,"overflow")!="visible")border(parent);parent=parent.parentNode;}if((safari2&&(fixed||css(offsetChild,"position")=="absolute"))||(mozilla&&css(offsetChild,"position")!="absolute"))add(-doc.body.offsetLeft,-doc.body.offsetTop);if(fixed)add(Math.max(doc.documentElement.scrollLeft,doc.body.scrollLeft),Math.max(doc.documentElement.scrollTop,doc.body.scrollTop));}results={top:top,left:left};}function border(elem){add(jQuery.curCSS(elem,"borderLeftWidth",true),jQuery.curCSS(elem,"borderTopWidth",true));}function add(l,t){left+=parseInt(l,10)||0;top+=parseInt(t,10)||0;}return results;};jQuery.fn.extend({position:function(){var left=0,top=0,results;if(this[0]){var offsetParent=this.offsetParent(),offset=this.offset(),parentOffset=/^body|html$/i.test(offsetParent[0].tagName)?{top:0,left:0}:offsetParent.offset();offset.top-=num(this,'marginTop');offset.left-=num(this,'marginLeft');parentOffset.top+=num(offsetParent,'borderTopWidth');parentOffset.left+=num(offsetParent,'borderLeftWidth');results={top:offset.top-parentOffset.top,left:offset.left-parentOffset.left};}return results;},offsetParent:function(){var offsetParent=this[0].offsetParent;while(offsetParent&&(!/^body|html$/i.test(offsetParent.tagName)&&jQuery.css(offsetParent,'position')=='static'))offsetParent=offsetParent.offsetParent;return jQuery(offsetParent);}});jQuery.each(['Left','Top'],function(i,name){var method='scroll'+name;jQuery.fn[method]=function(val){if(!this[0])return;return val!=undefined?this.each(function(){this==window||this==document?window.scrollTo(!i?val:jQuery(window).scrollLeft(),i?val:jQuery(window).scrollTop()):this[method]=val;}):this[0]==window||this[0]==document?self[i?'pageYOffset':'pageXOffset']||jQuery.boxModel&&document.documentElement[method]||document.body[method]:this[0][method];};});jQuery.each(["Height","Width"],function(i,name){var tl=i?"Left":"Top",br=i?"Right":"Bottom";jQuery.fn["inner"+name]=function(){return this[name.toLowerCase()]()+num(this,"padding"+tl)+num(this,"padding"+br);};jQuery.fn["outer"+name]=function(margin){return this["inner"+name]()+num(this,"border"+tl+"Width")+num(this,"border"+br+"Width")+(margin?num(this,"margin"+tl)+num(this,"margin"+br):0);};});})();
\ No newline at end of file
Added: branches/tree_dev/http/extensions/jquery-ui-personalized-1.5.2.js
--- branches/tree_dev/http/extensions/jquery-ui-personalized-1.5.2.js (rev 0)
+++ branches/tree_dev/http/extensions/jquery-ui-personalized-1.5.2.js 2008-09-17 09:22:20 UTC (rev 2946)
@@ -0,0 +1,1134 @@
+ * jQuery UI @VERSION
+ * Copyright (c) 2008 Paul Bakaus (ui.jquery.com)
+ * http://docs.jquery.com/UI
+;(function($) {
+$.ui = {
+ plugin: {
+ add: function(module, option, set) {
+ var proto = $.ui[module].prototype;
+ for(var i in set) {
+ proto.plugins[i] = proto.plugins[i] || [];
+ proto.plugins[i].push([option, set[i]]);
+ call: function(instance, name, args) {
+ var set = instance.plugins[name];
+ if(!set) { return; }
+ for (var i = 0; i < set.length; i++) {
+ if (instance.options[set[i][0]]) {
+ set[i][1].apply(instance.element, args);
+ cssCache: {},
+ css: function(name) {
+ if ($.ui.cssCache[name]) { return $.ui.cssCache[name]; }
+ var tmp = $('<div class="ui-gen">').addClass(name).css({position:'absolute', top:'-5000px', left:'-5000px', display:'block'}).appendTo('body');
+ //if (!$.browser.safari)
+ //tmp.appendTo('body');
+ //Opera and Safari set width and height to 0px instead of auto
+ //Safari returns rgba(0,0,0,0) when bgcolor is not set
+ $.ui.cssCache[name] = !!(
+ (!(/auto|default/).test(tmp.css('cursor')) || (/^[1-9]/).test(tmp.css('height')) || (/^[1-9]/).test(tmp.css('width')) ||
+ !(/none/).test(tmp.css('backgroundImage')) || !(/transparent|rgba\(0, 0, 0, 0\)/).test(tmp.css('backgroundColor')))
+ try { $('body').get(0).removeChild(tmp.get(0)); } catch(e){}
+ return $.ui.cssCache[name];
+ disableSelection: function(el) {
+ $(el).attr('unselectable', 'on').css('MozUserSelect', 'none');
+ enableSelection: function(el) {
+ $(el).attr('unselectable', 'off').css('MozUserSelect', '');
+ hasScroll: function(e, a) {
+ var scroll = /top/.test(a||"top") ? 'scrollTop' : 'scrollLeft', has = false;
+ if (e[scroll] > 0) return true; e[scroll] = 1;
+ has = e[scroll] > 0 ? true : false; e[scroll] = 0;
+ return has;
+/** jQuery core modifications and additions **/
+var _remove = $.fn.remove;
+$.fn.remove = function() {
+ $("*", this).add(this).triggerHandler("remove");
+ return _remove.apply(this, arguments );
+// $.widget is a factory to create jQuery plugins
+// taking some boilerplate code out of the plugin code
+// created by Scott González and Jörn Zaefferer
+function getter(namespace, plugin, method) {
+ var methods = $[namespace][plugin].getter || [];
+ methods = (typeof methods == "string" ? methods.split(/,?\s+/) : methods);
+ return ($.inArray(method, methods) != -1);
+$.widget = function(name, prototype) {
+ var namespace = name.split(".")[0];
+ name = name.split(".")[1];
+ // create plugin method
+ $.fn[name] = function(options) {
+ var isMethodCall = (typeof options == 'string'),
+ args = Array.prototype.slice.call(arguments, 1);
+ if (isMethodCall && getter(namespace, name, options)) {
+ var instance = $.data(this[0], name);
+ return (instance ? instance[options].apply(instance, args)
+ : undefined);
+ return this.each(function() {
+ var instance = $.data(this, name);
+ if (isMethodCall && instance && $.isFunction(instance[options])) {
+ instance[options].apply(instance, args);
+ } else if (!isMethodCall) {
+ $.data(this, name, new $[namespace][name](this, options));
+ // create widget constructor
+ $[namespace][name] = function(element, options) {
+ var self = this;
+ this.widgetName = name;
+ this.widgetBaseClass = namespace + '-' + name;
+ this.options = $.extend({}, $.widget.defaults, $[namespace][name].defaults, options);
+ this.element = $(element)
+ .bind('setData.' + name, function(e, key, value) {
+ return self.setData(key, value);
+ .bind('getData.' + name, function(e, key) {
+ return self.getData(key);
+ .bind('remove', function() {
+ return self.destroy();
+ this.init();
+ // add widget prototype
+ $[namespace][name].prototype = $.extend({}, $.widget.prototype, prototype);
+$.widget.prototype = {
+ init: function() {},
+ destroy: function() {
+ this.element.removeData(this.widgetName);
+ getData: function(key) {
+ return this.options[key];
+ setData: function(key, value) {
+ this.options[key] = value;
+ if (key == 'disabled') {
+ this.element[value ? 'addClass' : 'removeClass'](
+ this.widgetBaseClass + '-disabled');
+ enable: function() {
+ this.setData('disabled', false);
+ disable: function() {
+ this.setData('disabled', true);
+$.widget.defaults = {
+ disabled: false
+/** Mouse Interaction Plugin **/
+$.ui.mouse = {
+ mouseInit: function() {
+ var self = this;
+ this.element.bind('mousedown.'+this.widgetName, function(e) {
+ return self.mouseDown(e);
+ // Prevent text selection in IE
+ if ($.browser.msie) {
+ this._mouseUnselectable = this.element.attr('unselectable');
+ this.element.attr('unselectable', 'on');
+ this.started = false;
+ // TODO: make sure destroying one instance of mouse doesn't mess with
+ // other instances of mouse
+ mouseDestroy: function() {
+ this.element.unbind('.'+this.widgetName);
+ // Restore text selection in IE
+ ($.browser.msie
+ && this.element.attr('unselectable', this._mouseUnselectable));
+ mouseDown: function(e) {
+ // we may have missed mouseup (out of window)
+ (this._mouseStarted && this.mouseUp(e));
+ this._mouseDownEvent = e;
+ var self = this,
+ btnIsLeft = (e.which == 1),
+ elIsCancel = (typeof this.options.cancel == "string" ? $(e.target).parents().add(e.target).filter(this.options.cancel).length : false);
+ if (!btnIsLeft || elIsCancel || !this.mouseCapture(e)) {
+ return true;
+ this._mouseDelayMet = !this.options.delay;
+ if (!this._mouseDelayMet) {
+ this._mouseDelayTimer = setTimeout(function() {
+ self._mouseDelayMet = true;
+ }, this.options.delay);
+ if (this.mouseDistanceMet(e) && this.mouseDelayMet(e)) {
+ this._mouseStarted = (this.mouseStart(e) !== false);
+ if (!this._mouseStarted) {
+ e.preventDefault();
+ return true;
+ // these delegates are required to keep context
+ this._mouseMoveDelegate = function(e) {
+ return self.mouseMove(e);
+ this._mouseUpDelegate = function(e) {
+ return self.mouseUp(e);
+ $(document)
+ .bind('mousemove.'+this.widgetName, this._mouseMoveDelegate)
+ .bind('mouseup.'+this.widgetName, this._mouseUpDelegate);
+ return false;
+ mouseMove: function(e) {
+ // IE mouseup check - mouseup happened when mouse was out of window
+ if ($.browser.msie && !e.button) {
+ return this.mouseUp(e);
+ if (this._mouseStarted) {
+ this.mouseDrag(e);
+ return false;
+ (this.mouseStart(this._mouseDownEvent, e) !== false);
+ (this._mouseStarted ? this.mouseDrag(e) : this.mouseUp(e));
+ return !this._mouseStarted;
+ mouseUp: function(e) {
+ $(document)
+ .unbind('mousemove.'+this.widgetName, this._mouseMoveDelegate)
+ .unbind('mouseup.'+this.widgetName, this._mouseUpDelegate);
+ this._mouseStarted = false;
+ this.mouseStop(e);
+ return false;
+ mouseDistanceMet: function(e) {
+ return (Math.max(
+ Math.abs(this._mouseDownEvent.pageX - e.pageX),
+ Math.abs(this._mouseDownEvent.pageY - e.pageY)
+ ) >= this.options.distance
+ mouseDelayMet: function(e) {
+ return this._mouseDelayMet;
+ // These are placeholder methods, to be overriden by extending plugin
+ mouseStart: function(e) {},
+ mouseDrag: function(e) {},
+ mouseStop: function(e) {},
+ mouseCapture: function(e) { return true; }
+$.ui.mouse.defaults = {
+ cancel: null,
+ distance: 1,
+ delay: 0
+})(jQuery);
+ * jQuery UI Draggable
+ * Dual licensed under the MIT (MIT-LICENSE.txt)
+ * and GPL (GPL-LICENSE.txt) licenses.
+ * http://docs.jquery.com/UI/Draggables
+ * Depends:
+ * ui.core.js
+(function($) {
+$.widget("ui.draggable", $.extend({}, $.ui.mouse, {
+ //Initialize needed constants
+ var o = this.options;
+ //Position the node
+ if (o.helper == 'original' && !(/(relative|absolute|fixed)/).test(this.element.css('position')))
+ this.element.css('position', 'relative');
+ this.element.addClass('ui-draggable');
+ (o.disabled && this.element.addClass('ui-draggable-disabled'));
+ this.mouseInit();
+ if (this.helper || o.disabled || $(e.target).is('.ui-resizable-handle')) return false;
+ var handle = !this.options.handle || !$(this.options.handle, this.element).length ? true : false;
+ $(this.options.handle, this.element).find("*").andSelf().each(function() {
+ if(this == e.target) handle = true;
+ if (!handle) return false;
+ if($.ui.ddmanager) $.ui.ddmanager.current = this;
+ //Create and append the visible helper
+ this.helper = $.isFunction(o.helper) ? $(o.helper.apply(this.element[0], [e])) : (o.helper == 'clone' ? this.element.clone() : this.element);
+ if(!this.helper.parents('body').length) this.helper.appendTo((o.appendTo == 'parent' ? this.element[0].parentNode : o.appendTo));
+ if(this.helper[0] != this.element[0] && !(/(fixed|absolute)/).test(this.helper.css("position"))) this.helper.css("position", "absolute");
+ * - Position generation -
+ * This block generates everything position related - it's the core of draggables.
+ this.margins = { //Cache the margins
+ left: (parseInt(this.element.css("marginLeft"),10) || 0),
+ top: (parseInt(this.element.css("marginTop"),10) || 0)
+ this.cssPosition = this.helper.css("position"); //Store the helper's css position
+ this.offset = this.element.offset(); //The element's absolute position on the page
+ this.offset = { //Substract the margins from the element's absolute offset
+ top: this.offset.top - this.margins.top,
+ left: this.offset.left - this.margins.left
+ this.offset.click = { //Where the click happened, relative to the element
+ left: e.pageX - this.offset.left,
+ top: e.pageY - this.offset.top
+ this.offsetParent = this.helper.offsetParent(); var po = this.offsetParent.offset(); //Get the offsetParent and cache its position
+ if(this.offsetParent[0] == document.body && $.browser.mozilla) po = { top: 0, left: 0 }; //Ugly FF3 fix
+ this.offset.parent = { //Store its position plus border
+ top: po.top + (parseInt(this.offsetParent.css("borderTopWidth"),10) || 0),
+ left: po.left + (parseInt(this.offsetParent.css("borderLeftWidth"),10) || 0)
+ var p = this.element.position(); //This is a relative to absolute position minus the actual position calculation - only used for relative positioned helpers
+ this.offset.relative = this.cssPosition == "relative" ? {
+ top: p.top - (parseInt(this.helper.css("top"),10) || 0) + this.offsetParent[0].scrollTop,
+ left: p.left - (parseInt(this.helper.css("left"),10) || 0) + this.offsetParent[0].scrollLeft
+ } : { top: 0, left: 0 };
+ this.originalPosition = this.generatePosition(e); //Generate the original position
+ this.helperProportions = { width: this.helper.outerWidth(), height: this.helper.outerHeight() };//Cache the helper size
+ if(o.cursorAt) {
+ if(o.cursorAt.left != undefined) this.offset.click.left = o.cursorAt.left + this.margins.left;
+ if(o.cursorAt.right != undefined) this.offset.click.left = this.helperProportions.width - o.cursorAt.right + this.margins.left;
+ if(o.cursorAt.top != undefined) this.offset.click.top = o.cursorAt.top + this.margins.top;
+ if(o.cursorAt.bottom != undefined) this.offset.click.top = this.helperProportions.height - o.cursorAt.bottom + this.margins.top;
+ * - Position constraining -
+ * Here we prepare position constraining like grid and containment.
+ if(o.containment) {
+ if(o.containment == 'parent') o.containment = this.helper[0].parentNode;
+ if(o.containment == 'document' || o.containment == 'window') this.containment = [
+ 0 - this.offset.relative.left - this.offset.parent.left,
+ 0 - this.offset.relative.top - this.offset.parent.top,
+ $(o.containment == 'document' ? document : window).width() - this.offset.relative.left - this.offset.parent.left - this.helperProportions.width - this.margins.left - (parseInt(this.element.css("marginRight"),10) || 0),
+ ($(o.containment == 'document' ? document : window).height() || document.body.parentNode.scrollHeight) - this.offset.relative.top - this.offset.parent.top - this.helperProportions.height - this.margins.top - (parseInt(this.element.css("marginBottom"),10) || 0)
+ if(!(/^(document|window|parent)$/).test(o.containment)) {
+ var ce = $(o.containment)[0];
+ var co = $(o.containment).offset();
+ this.containment = [
+ co.left + (parseInt($(ce).css("borderLeftWidth"),10) || 0) - this.offset.relative.left - this.offset.parent.left,
+ co.top + (parseInt($(ce).css("borderTopWidth"),10) || 0) - this.offset.relative.top - this.offset.parent.top,
+ co.left+Math.max(ce.scrollWidth,ce.offsetWidth) - (parseInt($(ce).css("borderLeftWidth"),10) || 0) - this.offset.relative.left - this.offset.parent.left - this.helperProportions.width - this.margins.left - (parseInt(this.element.css("marginRight"),10) || 0),
+ co.top+Math.max(ce.scrollHeight,ce.offsetHeight) - (parseInt($(ce).css("borderTopWidth"),10) || 0) - this.offset.relative.top - this.offset.parent.top - this.helperProportions.height - this.margins.top - (parseInt(this.element.css("marginBottom"),10) || 0)
+ //Call plugins and callbacks
+ this.propagate("start", e);
+ this.helperProportions = { width: this.helper.outerWidth(), height: this.helper.outerHeight() };//Recache the helper size
+ if ($.ui.ddmanager && !o.dropBehaviour) $.ui.ddmanager.prepareOffsets(this, e);
+ this.helper.addClass("ui-draggable-dragging");
+ this.mouseDrag(e); //Execute the drag once - this causes the helper not to be visible before getting its correct position
+ return true;
+ convertPositionTo: function(d, pos) {
+ if(!pos) pos = this.position;
+ var mod = d == "absolute" ? 1 : -1;
+ return {
+ top: (
+ pos.top // the calculated relative position
+ + this.offset.relative.top * mod // Only for relative positioned nodes: Relative offset from element to offset parent
+ + this.offset.parent.top * mod // The offsetParent's offset without borders (offset + border)
+ - (this.cssPosition == "fixed" || (this.cssPosition == "absolute" && this.offsetParent[0] == document.body) ? 0 : this.offsetParent[0].scrollTop) * mod // The offsetParent's scroll position, not if the element is fixed
+ + (this.cssPosition == "fixed" ? $(document).scrollTop() : 0) * mod
+ + this.margins.top * mod //Add the margin (you don't want the margin counting in intersection methods)
+ left: (
+ pos.left // the calculated relative position
+ + this.offset.relative.left * mod // Only for relative positioned nodes: Relative offset from element to offset parent
+ + this.offset.parent.left * mod // The offsetParent's offset without borders (offset + border)
+ - (this.cssPosition == "fixed" || (this.cssPosition == "absolute" && this.offsetParent[0] == document.body) ? 0 : this.offsetParent[0].scrollLeft) * mod // The offsetParent's scroll position, not if the element is fixed
+ + (this.cssPosition == "fixed" ? $(document).scrollLeft() : 0) * mod
+ + this.margins.left * mod //Add the margin (you don't want the margin counting in intersection methods)
+ generatePosition: function(e) {
+ var position = {
+ top: (
+ e.pageY // The absolute mouse position
+ - this.offset.click.top // Click offset (relative to the element)
+ - this.offset.relative.top // Only for relative positioned nodes: Relative offset from element to offset parent
+ - this.offset.parent.top // The offsetParent's offset without borders (offset + border)
+ + (this.cssPosition == "fixed" || (this.cssPosition == "absolute" && this.offsetParent[0] == document.body) ? 0 : this.offsetParent[0].scrollTop) // The offsetParent's scroll position, not if the element is fixed
+ - (this.cssPosition == "fixed" ? $(document).scrollTop() : 0)
+ left: (
+ e.pageX // The absolute mouse position
+ - this.offset.click.left // Click offset (relative to the element)
+ - this.offset.relative.left // Only for relative positioned nodes: Relative offset from element to offset parent
+ - this.offset.parent.left // The offsetParent's offset without borders (offset + border)
+ + (this.cssPosition == "fixed" || (this.cssPosition == "absolute" && this.offsetParent[0] == document.body) ? 0 : this.offsetParent[0].scrollLeft) // The offsetParent's scroll position, not if the element is fixed
+ - (this.cssPosition == "fixed" ? $(document).scrollLeft() : 0)
+ if(!this.originalPosition) return position; //If we are not dragging yet, we won't check for options
+ * Constrain the position to a mix of grid, containment.
+ if(this.containment) {
+ if(position.left < this.containment[0]) position.left = this.containment[0];
+ if(position.top < this.containment[1]) position.top = this.containment[1];
+ if(position.left > this.containment[2]) position.left = this.containment[2];
+ if(position.top > this.containment[3]) position.top = this.containment[3];
+ if(o.grid) {
+ var top = this.originalPosition.top + Math.round((position.top - this.originalPosition.top) / o.grid[1]) * o.grid[1];
+ position.top = this.containment ? (!(top < this.containment[1] || top > this.containment[3]) ? top : (!(top < this.containment[1]) ? top - o.grid[1] : top + o.grid[1])) : top;
+ var left = this.originalPosition.left + Math.round((position.left - this.originalPosition.left) / o.grid[0]) * o.grid[0];
+ position.left = this.containment ? (!(left < this.containment[0] || left > this.containment[2]) ? left : (!(left < this.containment[0]) ? left - o.grid[0] : left + o.grid[0])) : left;
+ return position;
+ //Compute the helpers position
+ this.position = this.generatePosition(e);
+ this.positionAbs = this.convertPositionTo("absolute");
+ //Call plugins and callbacks and use the resulting position if something is returned
+ this.position = this.propagate("drag", e) || this.position;
+ if(!this.options.axis || this.options.axis != "y") this.helper[0].style.left = this.position.left+'px';
+ if(!this.options.axis || this.options.axis != "x") this.helper[0].style.top = this.position.top+'px';
+ if($.ui.ddmanager) $.ui.ddmanager.drag(this, e);
+ return false;
+ //If we are using droppables, inform the manager about the drop
+ var dropped = false;
+ if ($.ui.ddmanager && !this.options.dropBehaviour)
+ var dropped = $.ui.ddmanager.drop(this, e);
+ if((this.options.revert == "invalid" && !dropped) || (this.options.revert == "valid" && dropped) || this.options.revert === true) {
+ var self = this;
+ $(this.helper).animate(this.originalPosition, parseInt(this.options.revert, 10) || 500, function() {
+ self.propagate("stop", e);
+ self.clear();
+ } else {
+ this.propagate("stop", e);
+ this.clear();
+ return false;
+ clear: function() {
+ this.helper.removeClass("ui-draggable-dragging");
+ if(this.options.helper != 'original' && !this.cancelHelperRemoval) this.helper.remove();
+ //if($.ui.ddmanager) $.ui.ddmanager.current = null;
+ this.helper = null;
+ this.cancelHelperRemoval = false;
+ // From now on bulk stuff - mainly helpers
+ plugins: {},
+ uiHash: function(e) {
+ return {
+ helper: this.helper,
+ position: this.position,
+ absolutePosition: this.positionAbs,
+ options: this.options
+ propagate: function(n,e) {
+ $.ui.plugin.call(this, n, [e, this.uiHash()]);
+ if(n == "drag") this.positionAbs = this.convertPositionTo("absolute"); //The absolute position has to be recalculated after plugins
+ return this.element.triggerHandler(n == "drag" ? n : "drag"+n, [e, this.uiHash()], this.options[n]);
+ if(!this.element.data('draggable')) return;
+ this.element.removeData("draggable").unbind(".draggable").removeClass('ui-draggable');
+ this.mouseDestroy();
+$.extend($.ui.draggable, {
+ defaults: {
+ appendTo: "parent",
+ axis: false,
+ cancel: ":input",
+ delay: 0,
+ distance: 1,
+ helper: "original"
+$.ui.plugin.add("draggable", "cursor", {
+ start: function(e, ui) {
+ var t = $('body');
+ if (t.css("cursor")) ui.options._cursor = t.css("cursor");
+ t.css("cursor", ui.options.cursor);
+ stop: function(e, ui) {
+ if (ui.options._cursor) $('body').css("cursor", ui.options._cursor);
+$.ui.plugin.add("draggable", "zIndex", {
+ var t = $(ui.helper);
+ if(t.css("zIndex")) ui.options._zIndex = t.css("zIndex");
+ t.css('zIndex', ui.options.zIndex);
+ if(ui.options._zIndex) $(ui.helper).css('zIndex', ui.options._zIndex);
+$.ui.plugin.add("draggable", "opacity", {
+ if(t.css("opacity")) ui.options._opacity = t.css("opacity");
+ t.css('opacity', ui.options.opacity);
+ if(ui.options._opacity) $(ui.helper).css('opacity', ui.options._opacity);
+$.ui.plugin.add("draggable", "iframeFix", {
+ $(ui.options.iframeFix === true ? "iframe" : ui.options.iframeFix).each(function() {
+ $('<div class="ui-draggable-iframeFix" style="background: #fff;"></div>')
+ .css({
+ width: this.offsetWidth+"px", height: this.offsetHeight+"px",
+ position: "absolute", opacity: "0.001", zIndex: 1000
+ .css($(this).offset())
+ .appendTo("body");
+ $("div.DragDropIframeFix").each(function() { this.parentNode.removeChild(this); }); //Remove frame helpers
+$.ui.plugin.add("draggable", "scroll", {
+ var o = ui.options;
+ var i = $(this).data("draggable");
+ o.scrollSensitivity = o.scrollSensitivity || 20;
+ o.scrollSpeed = o.scrollSpeed || 20;
+ i.overflowY = function(el) {
+ do { if(/auto|scroll/.test(el.css('overflow')) || (/auto|scroll/).test(el.css('overflow-y'))) return el; el = el.parent(); } while (el[0].parentNode);
+ return $(document);
+ }(this);
+ i.overflowX = function(el) {
+ do { if(/auto|scroll/.test(el.css('overflow')) || (/auto|scroll/).test(el.css('overflow-x'))) return el; el = el.parent(); } while (el[0].parentNode);
+ }(this);
+ if(i.overflowY[0] != document && i.overflowY[0].tagName != 'HTML') i.overflowYOffset = i.overflowY.offset();
+ if(i.overflowX[0] != document && i.overflowX[0].tagName != 'HTML') i.overflowXOffset = i.overflowX.offset();
+ drag: function(e, ui) {
+ if(i.overflowY[0] != document && i.overflowY[0].tagName != 'HTML') {
+ if((i.overflowYOffset.top + i.overflowY[0].offsetHeight) - e.pageY < o.scrollSensitivity)
+ i.overflowY[0].scrollTop = i.overflowY[0].scrollTop + o.scrollSpeed;
+ if(e.pageY - i.overflowYOffset.top < o.scrollSensitivity)
+ i.overflowY[0].scrollTop = i.overflowY[0].scrollTop - o.scrollSpeed;
+ } else {
+ if(e.pageY - $(document).scrollTop() < o.scrollSensitivity)
+ $(document).scrollTop($(document).scrollTop() - o.scrollSpeed);
+ if($(window).height() - (e.pageY - $(document).scrollTop()) < o.scrollSensitivity)
+ $(document).scrollTop($(document).scrollTop() + o.scrollSpeed);
+ if(i.overflowX[0] != document && i.overflowX[0].tagName != 'HTML') {
+ if((i.overflowXOffset.left + i.overflowX[0].offsetWidth) - e.pageX < o.scrollSensitivity)
+ i.overflowX[0].scrollLeft = i.overflowX[0].scrollLeft + o.scrollSpeed;
+ if(e.pageX - i.overflowXOffset.left < o.scrollSensitivity)
+ i.overflowX[0].scrollLeft = i.overflowX[0].scrollLeft - o.scrollSpeed;
+ } else {
+ if(e.pageX - $(document).scrollLeft() < o.scrollSensitivity)
+ $(document).scrollLeft($(document).scrollLeft() - o.scrollSpeed);
+ if($(window).width() - (e.pageX - $(document).scrollLeft()) < o.scrollSensitivity)
+ $(document).scrollLeft($(document).scrollLeft() + o.scrollSpeed);
+$.ui.plugin.add("draggable", "snap", {
+ var inst = $(this).data("draggable");
+ inst.snapElements = [];
+ $(ui.options.snap === true ? '.ui-draggable' : ui.options.snap).each(function() {
+ var $t = $(this); var $o = $t.offset();
+ if(this != inst.element[0]) inst.snapElements.push({
+ item: this,
+ width: $t.outerWidth(), height: $t.outerHeight(),
+ top: $o.top, left: $o.left
+ var d = ui.options.snapTolerance || 20;
+ var x1 = ui.absolutePosition.left, x2 = x1 + inst.helperProportions.width,
+ y1 = ui.absolutePosition.top, y2 = y1 + inst.helperProportions.height;
+ for (var i = inst.snapElements.length - 1; i >= 0; i--){
+ var l = inst.snapElements[i].left, r = l + inst.snapElements[i].width,
+ t = inst.snapElements[i].top, b = t + inst.snapElements[i].height;
+ //Yes, I know, this is insane ;)
+ if(!((l-d < x1 && x1 < r+d && t-d < y1 && y1 < b+d) || (l-d < x1 && x1 < r+d && t-d < y2 && y2 < b+d) || (l-d < x2 && x2 < r+d && t-d < y1 && y1 < b+d) || (l-d < x2 && x2 < r+d && t-d < y2 && y2 < b+d))) continue;
+ if(ui.options.snapMode != 'inner') {
+ var ts = Math.abs(t - y2) <= 20;
+ var bs = Math.abs(b - y1) <= 20;
+ var ls = Math.abs(l - x2) <= 20;
+ var rs = Math.abs(r - x1) <= 20;
+ if(ts) ui.position.top = inst.convertPositionTo("relative", { top: t - inst.helperProportions.height, left: 0 }).top;
+ if(bs) ui.position.top = inst.convertPositionTo("relative", { top: b, left: 0 }).top;
+ if(ls) ui.position.left = inst.convertPositionTo("relative", { top: 0, left: l - inst.helperProportions.width }).left;
+ if(rs) ui.position.left = inst.convertPositionTo("relative", { top: 0, left: r }).left;
+ if(ui.options.snapMode != 'outer') {
+ var ts = Math.abs(t - y1) <= 20;
+ var bs = Math.abs(b - y2) <= 20;
+ var ls = Math.abs(l - x1) <= 20;
+ var rs = Math.abs(r - x2) <= 20;
+ if(ts) ui.position.top = inst.convertPositionTo("relative", { top: t, left: 0 }).top;
+ if(bs) ui.position.top = inst.convertPositionTo("relative", { top: b - inst.helperProportions.height, left: 0 }).top;
+ if(ls) ui.position.left = inst.convertPositionTo("relative", { top: 0, left: l }).left;
+ if(rs) ui.position.left = inst.convertPositionTo("relative", { top: 0, left: r - inst.helperProportions.width }).left;
+$.ui.plugin.add("draggable", "connectToSortable", {
+ start: function(e,ui) {
+ inst.sortables = [];
+ $(ui.options.connectToSortable).each(function() {
+ if($.data(this, 'sortable')) {
+ var sortable = $.data(this, 'sortable');
+ inst.sortables.push({
+ instance: sortable,
+ shouldRevert: sortable.options.revert
+ sortable.refreshItems(); //Do a one-time refresh at start to refresh the containerCache
+ sortable.propagate("activate", e, inst);
+ stop: function(e,ui) {
+ //If we are still over the sortable, we fake the stop event of the sortable, but also remove helper
+ $.each(inst.sortables, function() {
+ if(this.instance.isOver) {
+ this.instance.isOver = 0;
+ inst.cancelHelperRemoval = true; //Don't remove the helper in the draggable instance
+ this.instance.cancelHelperRemoval = false; //Remove it in the sortable instance (so sortable plugins like revert still work)
+ if(this.shouldRevert) this.instance.options.revert = true; //revert here
+ this.instance.mouseStop(e);
+ //Also propagate receive event, since the sortable is actually receiving a element
+ this.instance.element.triggerHandler("sortreceive", [e, $.extend(this.instance.ui(), { sender: inst.element })], this.instance.options["receive"]);
+ this.instance.options.helper = this.instance.options._helper;
+ } else {
+ this.instance.propagate("deactivate", e, inst);
+ drag: function(e,ui) {
+ var inst = $(this).data("draggable"), self = this;
+ var checkPos = function(o) {
+ var l = o.left, r = l + o.width,
+ t = o.top, b = t + o.height;
+ return (l < (this.positionAbs.left + this.offset.click.left) && (this.positionAbs.left + this.offset.click.left) < r
+ && t < (this.positionAbs.top + this.offset.click.top) && (this.positionAbs.top + this.offset.click.top) < b);
+ $.each(inst.sortables, function(i) {
+ if(checkPos.call(inst, this.instance.containerCache)) {
+ //If it intersects, we use a little isOver variable and set it once, so our move-in stuff gets fired only once
+ if(!this.instance.isOver) {
+ this.instance.isOver = 1;
+ //Now we fake the start of dragging for the sortable instance,
+ //by cloning the list group item, appending it to the sortable and using it as inst.currentItem
+ //We can then fire the start event of the sortable with our passed browser event, and our own helper (so it doesn't create a new one)
+ this.instance.currentItem = $(self).clone().appendTo(this.instance.element).data("sortable-item", true);
+ this.instance.options._helper = this.instance.options.helper; //Store helper option to later restore it
+ this.instance.options.helper = function() { return ui.helper[0]; };
+ e.target = this.instance.currentItem[0];
+ this.instance.mouseCapture(e, true);
+ this.instance.mouseStart(e, true, true);
+ //Because the browser event is way off the new appended portlet, we modify a couple of variables to reflect the changes
+ this.instance.offset.click.top = inst.offset.click.top;
+ this.instance.offset.click.left = inst.offset.click.left;
+ this.instance.offset.parent.left -= inst.offset.parent.left - this.instance.offset.parent.left;
+ this.instance.offset.parent.top -= inst.offset.parent.top - this.instance.offset.parent.top;
+ inst.propagate("toSortable", e);
+ //Provided we did all the previous steps, we can fire the drag event of the sortable on every draggable drag, when it intersects with the sortable
+ if(this.instance.currentItem) this.instance.mouseDrag(e);
+ } else {
+ //If it doesn't intersect with the sortable, and it intersected before,
+ //we fake the drag stop of the sortable, but make sure it doesn't remove the helper by using cancelHelperRemoval
+ this.instance.cancelHelperRemoval = true;
+ this.instance.options.revert = false; //No revert here
+ this.instance.mouseStop(e, true);
+ //Now we remove our currentItem, the list group clone again, and the placeholder, and animate the helper back to it's original size
+ this.instance.currentItem.remove();
+ if(this.instance.placeholder) this.instance.placeholder.remove();
+ inst.propagate("fromSortable", e);
+$.ui.plugin.add("draggable", "stack", {
+ var group = $.makeArray($(ui.options.stack.group)).sort(function(a,b) {
+ return (parseInt($(a).css("zIndex"),10) || ui.options.stack.min) - (parseInt($(b).css("zIndex"),10) || ui.options.stack.min);
+ $(group).each(function(i) {
+ this.style.zIndex = ui.options.stack.min + i;
+ this[0].style.zIndex = ui.options.stack.min + group.length;
+})(jQuery);
+ * jQuery UI Droppable
+ * http://docs.jquery.com/UI/Droppables
+ * Depends:
+ * ui.core.js
+ * ui.draggable.js
+(function($) {
+$.widget("ui.droppable", {
+ this.element.addClass("ui-droppable");
+ this.isover = 0; this.isout = 1;
+ //Prepare the passed options
+ var o = this.options, accept = o.accept;
+ o = $.extend(o, {
+ accept: o.accept && o.accept.constructor == Function ? o.accept : function(d) {
+ return $(d).is(accept);
+ //Store the droppable's proportions
+ this.proportions = { width: this.element[0].offsetWidth, height: this.element[0].offsetHeight };
+ // Add the reference and positions to the manager
+ $.ui.ddmanager.droppables.push(this);
+ plugins: {},
+ ui: function(c) {
+ return {
+ draggable: (c.currentItem || c.element),
+ helper: c.helper,
+ position: c.position,
+ absolutePosition: c.positionAbs,
+ options: this.options,
+ element: this.element
+ var drop = $.ui.ddmanager.droppables;
+ for ( var i = 0; i < drop.length; i++ )
+ if ( drop[i] == this )
+ drop.splice(i, 1);
+ this.element
+ .removeClass("ui-droppable ui-droppable-disabled")
+ .removeData("droppable")
+ .unbind(".droppable");
+ over: function(e) {
+ var draggable = $.ui.ddmanager.current;
+ if (!draggable || (draggable.currentItem || draggable.element)[0] == this.element[0]) return; // Bail if draggable and droppable are same element
+ if (this.options.accept.call(this.element,(draggable.currentItem || draggable.element))) {
+ $.ui.plugin.call(this, 'over', [e, this.ui(draggable)]);
+ this.element.triggerHandler("dropover", [e, this.ui(draggable)], this.options.over);
+ out: function(e) {
+ $.ui.plugin.call(this, 'out', [e, this.ui(draggable)]);
+ this.element.triggerHandler("dropout", [e, this.ui(draggable)], this.options.out);
+ drop: function(e,custom) {
+ var draggable = custom || $.ui.ddmanager.current;
+ if (!draggable || (draggable.currentItem || draggable.element)[0] == this.element[0]) return false; // Bail if draggable and droppable are same element
+ var childrenIntersection = false;
+ this.element.find(".ui-droppable").not(".ui-draggable-dragging").each(function() {
+ var inst = $.data(this, 'droppable');
+ if(inst.options.greedy && $.ui.intersect(draggable, $.extend(inst, { offset: inst.element.offset() }), inst.options.tolerance)) {
+ childrenIntersection = true; return false;
+ if(childrenIntersection) return false;
+ if(this.options.accept.call(this.element,(draggable.currentItem || draggable.element))) {
+ $.ui.plugin.call(this, 'drop', [e, this.ui(draggable)]);
+ this.element.triggerHandler("drop", [e, this.ui(draggable)], this.options.drop);
+ return true;
+ return false;
+ activate: function(e) {
+ $.ui.plugin.call(this, 'activate', [e, this.ui(draggable)]);
+ if(draggable) this.element.triggerHandler("dropactivate", [e, this.ui(draggable)], this.options.activate);
+ deactivate: function(e) {
+ $.ui.plugin.call(this, 'deactivate', [e, this.ui(draggable)]);
+ if(draggable) this.element.triggerHandler("dropdeactivate", [e, this.ui(draggable)], this.options.deactivate);
+$.extend($.ui.droppable, {
+ defaults: {
+ disabled: false,
+ tolerance: 'intersect'
+$.ui.intersect = function(draggable, droppable, toleranceMode) {
+ if (!droppable.offset) return false;
+ var x1 = (draggable.positionAbs || draggable.position.absolute).left, x2 = x1 + draggable.helperProportions.width,
+ y1 = (draggable.positionAbs || draggable.position.absolute).top, y2 = y1 + draggable.helperProportions.height;
+ var l = droppable.offset.left, r = l + droppable.proportions.width,
+ t = droppable.offset.top, b = t + droppable.proportions.height;
+ switch (toleranceMode) {
+ case 'fit':
+ return (l < x1 && x2 < r
+ && t < y1 && y2 < b);
+ break;
+ case 'intersect':
+ return (l < x1 + (draggable.helperProportions.width / 2) // Right Half
+ && x2 - (draggable.helperProportions.width / 2) < r // Left Half
+ && t < y1 + (draggable.helperProportions.height / 2) // Bottom Half
+ && y2 - (draggable.helperProportions.height / 2) < b ); // Top Half
+ break;
+ case 'pointer':
+ return (l < ((draggable.positionAbs || draggable.position.absolute).left + (draggable.clickOffset || draggable.offset.click).left) && ((draggable.positionAbs || draggable.position.absolute).left + (draggable.clickOffset || draggable.offset.click).left) < r
+ && t < ((draggable.positionAbs || draggable.position.absolute).top + (draggable.clickOffset || draggable.offset.click).top) && ((draggable.positionAbs || draggable.position.absolute).top + (draggable.clickOffset || draggable.offset.click).top) < b);
+ break;
+ case 'touch':
+ return (
+ (y1 >= t && y1 <= b) || // Top edge touching
+ (y2 >= t && y2 <= b) || // Bottom edge touching
+ (y1 < t && y2 > b) // Surrounded vertically
+ (x1 >= l && x1 <= r) || // Left edge touching
+ (x2 >= l && x2 <= r) || // Right edge touching
+ (x1 < l && x2 > r) // Surrounded horizontally
+ break;
+ default:
+ return false;
+ break;
+ This manager tracks offsets of draggables and droppables
+$.ui.ddmanager = {
+ current: null,
+ droppables: [],
+ prepareOffsets: function(t, e) {
+ var m = $.ui.ddmanager.droppables;
+ var type = e ? e.type : null; // workaround for #2317
+ for (var i = 0; i < m.length; i++) {
+ if(m[i].options.disabled || (t && !m[i].options.accept.call(m[i].element,(t.currentItem || t.element)))) continue;
+ m[i].visible = m[i].element.css("display") != "none"; if(!m[i].visible) continue; //If the element is not visible, continue
+ m[i].offset = m[i].element.offset();
+ m[i].proportions = { width: m[i].element[0].offsetWidth, height: m[i].element[0].offsetHeight };
+ if(type == "dragstart" || type == "sortactivate") m[i].activate.call(m[i], e); //Activate the droppable if used directly from draggables
+ drop: function(draggable, e) {
+ $.each($.ui.ddmanager.droppables, function() {
+ if(!this.options) return;
+ if (!this.options.disabled && this.visible && $.ui.intersect(draggable, this, this.options.tolerance))
+ dropped = this.drop.call(this, e);
+ if (!this.options.disabled && this.visible && this.options.accept.call(this.element,(draggable.currentItem || draggable.element))) {
+ this.isout = 1; this.isover = 0;
+ this.deactivate.call(this, e);
+ return dropped;
+ drag: function(draggable, e) {
+ //If you have a highly dynamic page, you might try this option. It renders positions every time you move the mouse.
+ if(draggable.options.refreshPositions) $.ui.ddmanager.prepareOffsets(draggable, e);
+ //Run through all droppables and check their positions based on specific tolerance options
+ if(this.options.disabled || this.greedyChild || !this.visible) return;
+ var intersects = $.ui.intersect(draggable, this, this.options.tolerance);
+ var c = !intersects && this.isover == 1 ? 'isout' : (intersects && this.isover == 0 ? 'isover' : null);
+ if(!c) return;
+ var parentInstance;
+ if (this.options.greedy) {
+ var parent = this.element.parents('.ui-droppable:eq(0)');
+ if (parent.length) {
+ parentInstance = $.data(parent[0], 'droppable');
+ parentInstance.greedyChild = (c == 'isover' ? 1 : 0);
+ // we just moved into a greedy child
+ if (parentInstance && c == 'isover') {
+ parentInstance['isover'] = 0;
+ parentInstance['isout'] = 1;
+ parentInstance.out.call(parentInstance, e);
+ this[c] = 1; this[c == 'isout' ? 'isover' : 'isout'] = 0;
+ this[c == "isover" ? "over" : "out"].call(this, e);
+ // we just moved out of a greedy child
+ if (parentInstance && c == 'isout') {
+ parentInstance['isout'] = 0;
+ parentInstance['isover'] = 1;
+ parentInstance.over.call(parentInstance, e);
+ * Droppable Extensions
+$.ui.plugin.add("droppable", "activeClass", {
+ activate: function(e, ui) {
+ $(this).addClass(ui.options.activeClass);
+ deactivate: function(e, ui) {
+ $(this).removeClass(ui.options.activeClass);
+ drop: function(e, ui) {
+$.ui.plugin.add("droppable", "hoverClass", {
+ over: function(e, ui) {
+ $(this).addClass(ui.options.hoverClass);
+ out: function(e, ui) {
+ $(this).removeClass(ui.options.hoverClass);
+})(jQuery);
Added: branches/tree_dev/http/extensions/jquery.contextmenu.r2.js
--- branches/tree_dev/http/extensions/jquery.contextmenu.r2.js (rev 0)
+++ branches/tree_dev/http/extensions/jquery.contextmenu.r2.js 2008-09-17 09:22:20 UTC (rev 2946)
@@ -0,0 +1,144 @@
+ * ContextMenu - jQuery plugin for right-click context menus
+ * Author: Chris Domigan
+ * Contributors: Dan G. Switzer, II
+ * Parts of this plugin are inspired by Joern Zaefferer's Tooltip plugin
+ * Dual licensed under the MIT and GPL licenses:
+ * http://www.opensource.org/licenses/mit-license.php
+ * http://www.gnu.org/licenses/gpl.html
+ * Version: r2
+ * Date: 16 July 2007
+ * For documentation visit http://www.trendskitchens.co.nz/jquery/contextmenu/
+(function($) {
+ var menu, shadow, trigger, content, hash, currentTarget;
+ var defaults = {
+ menuStyle: {
+ listStyle: 'none',
+ padding: '1px',
+ margin: '0px',
+ backgroundColor: '#fff',
+ border: '1px solid #999',
+ width: '100px'
+ itemStyle: {
+ margin: '0px',
+ color: '#000',
+ display: 'block',
+ cursor: 'default',
+ padding: '3px',
+ border: '1px solid #fff',
+ backgroundColor: 'transparent'
+ itemHoverStyle: {
+ border: '1px solid #0a246a',
+ backgroundColor: '#b6bdd2'
+ eventPosX: 'pageX',
+ eventPosY: 'pageY',
+ shadow : true,
+ onContextMenu: null,
+ onShowMenu: null
+ $.fn.contextMenu = function(id, options) {
+ if (!menu) { // Create singleton menu
+ menu = $('<div id="jqContextMenu"></div>')
+ .hide()
+ .css({position:'absolute', zIndex:'500'})
+ .appendTo('body')
+ .bind('click', function(e) {
+ e.stopPropagation();
+ if (!shadow) {
+ shadow = $('<div></div>')
+ .css({backgroundColor:'#000',position:'absolute',opacity:0.2,zIndex:499})
+ .appendTo('body')
+ .hide();
+ hash = hash || [];
+ hash.push({
+ id : id,
+ menuStyle: $.extend({}, defaults.menuStyle, options.menuStyle || {}),
+ itemStyle: $.extend({}, defaults.itemStyle, options.itemStyle || {}),
+ itemHoverStyle: $.extend({}, defaults.itemHoverStyle, options.itemHoverStyle || {}),
+ bindings: options.bindings || {},
+ shadow: options.shadow || options.shadow === false ? options.shadow : defaults.shadow,
+ onContextMenu: options.onContextMenu || defaults.onContextMenu,
+ onShowMenu: options.onShowMenu || defaults.onShowMenu,
+ eventPosX: options.eventPosX || defaults.eventPosX,
+ eventPosY: options.eventPosY || defaults.eventPosY
+ var index = hash.length - 1;
+ $(this).bind('contextmenu', function(e) {
+ // Check if onContextMenu() defined
+ var bShowContext = (!!hash[index].onContextMenu) ? hash[index].onContextMenu(e) : true;
+ if (bShowContext) display(index, this, e, options);
+ return false;
+ return this;
+ function display(index, trigger, e, options) {
+ var cur = hash[index];
+ content = $('#'+cur.id).find('ul:first').clone(true);
+ content.css(cur.menuStyle).find('li').css(cur.itemStyle).hover(
+ function() {
+ $(this).css(cur.itemHoverStyle);
+ function(){
+ $(this).css(cur.itemStyle);
+ ).find('img').css({verticalAlign:'middle',paddingRight:'2px'});
+ // Send the content to the menu
+ menu.html(content);
+ // if there's an onShowMenu, run it now -- must run after content has been added
+ // if you try to alter the content variable before the menu.html(), IE6 has issues
+ // updating the content
+ if (!!cur.onShowMenu) menu = cur.onShowMenu(e, menu);
+ $.each(cur.bindings, function(id, func) {
+ $('#'+id, menu).bind('click', function(e) {
+ hide();
+ func(trigger, currentTarget);
+ menu.css({'left':e[cur.eventPosX],'top':e[cur.eventPosY]}).show();
+ if (cur.shadow) shadow.css({width:menu.width(),height:menu.height(),left:e.pageX+2,top:e.pageY+2}).show();
+ $(document).one('click', hide);
+ function hide() {
+ menu.hide();
+ shadow.hide();
+ // Apply defaults
+ $.contextMenu = {
+ defaults : function(userDefaults) {
+ $.each(userDefaults, function(i, val) {
+ if (typeof val == 'object' && defaults[i]) {
+ $.extend(defaults[i], val);
+ else defaults[i] = val;
+})(jQuery);
+$(function() {
+ $('div.contextMenu').hide();
Added: branches/tree_dev/http/x_test/customTree.js
--- branches/tree_dev/http/x_test/customTree.js (rev 0)
+++ branches/tree_dev/http/x_test/customTree.js 2008-09-17 09:22:20 UTC (rev 2946)
@@ -0,0 +1,202 @@
+var customTreeController = function (myTree) {
+// this.myTree = new CustomTree();
+// this.myTree.root.name = "My tree";
+ this.myTree = myTree;
+ this.$root = $("<ul></ul>");
+ var that = this;
+ var setProperties = function () {
+ * A recursive function to draw the nodes of a tree and attach
+ * draggables and droppables
+ * @param {Object} $domNode
+ * @param {Object} treeNode
+ var drawNode = function ($domNode, treeNode) {
+ var numOfChildren = treeNode.childNodeList.count();
+ var $currentItem;
+ var $currentLabel;
+ // this treeNode is a leaf
+ if (numOfChildren === 0) {
+ $currentLabel = $("<span>" + treeNode.name + "</span>");
+ $currentItem = $("<li class='treeLeaf'></li>");
+ $currentItem.append($currentLabel);
+ $currentLabel.contextMenu('leafMenu', {
+ onContextMenu: function(e) {
+ return true;
+ onShowMenu: function(e, menu) {
+ return menu;
+ bindings: {
+ 'deleteService': function () {
+ treeNode.remove();
+ else {
+ // this treeNode is an inner node
+ $currentItem = $("<li class='treeNode'></li>");
+ $currentLabel = $("<div class='treeNodeDrop'><span>" + treeNode.name + "</span></div>");
+ var $currentFolder = $("<ul></ul>");
+ $currentItem.append($currentFolder);
+ // enable folder closing and opening
+ // (not for root node)
+ if (treeNode != that.myTree.root) {
+ $currentLabel.toggle(function () {
+ $(this).siblings().hide("fast");
+ }, function () {
+ $(this).siblings().show("fast");
+ $currentLabel.contextMenu('folderMenu', {
+ onContextMenu: function(e){
+ return true;
+ onShowMenu: function(e, menu){
+ return menu;
+ bindings: {
+ 'addFolder': function(item){
+ var newChild = treeNode.addChild();
+ 'deleteFolder': function(){
+ 'editFolder': function(){
+ // make inner nodes droppable
+ $currentLabel.droppable({
+ "accept": function ($draggable) {
+ var $invalidDroppables = $(".currently-dragging .treeNodeDrop");
+ var $invalidDroppablesMinusThis = $invalidDroppables.not($currentLabel);
+ if ($invalidDroppables.size() > $invalidDroppablesMinusThis.size()) {
+ return false;
+ return true;
+ "tolerance": "pointer",
+ "drop": function (e, ui) {
+ $toDomNode = $(this);
+ $fromDomNode = $(ui.draggable);
+ that.myTree.currentlyDraggedNode.afterMove = function () {
+ $toDomNode.next().append($(ui.draggable));
+ $(".treeLeaf").removeAttr("style");
+ $("*").removeClass("currently-dragging");
+ that.myTree.currentlyDraggedNode.move(treeNode);
+ // visit the child nodes (depth first)
+ for (var i = 0; i < numOfChildren; i++) {
+ drawNode.apply(that, [$currentFolder, treeNode.childNodeList.get(i)]);
+ // make node draggable
+ $currentItem.draggable({
+ "helper": "clone",
+ "start": function(){
+ $(this).addClass("currently-dragging");
+ that.myTree.currentlyDraggedNode = treeNode;
+ // attach node to tree
+ $domNode.append($currentItem);
+ // link model and view
+ treeNode.$domNode = $currentItem;
+ treeNode.afterRemove = function () {
+ $currentItem.remove();
+ $(document.body).append(that.$root);
+ drawNode(that.$root, that.myTree.root);
+// see example at http://guxx.de/2007/05/30/nested-sets/
+var myTree = new CustomTree();
+var root = myTree.root;
+root.name = "(root)";
+var startNode = new CustomTreeNode();
+startNode.name = "Startseite";
+root.append(startNode);
+var newsNode = new CustomTreeNode();
+newsNode.name = "News";
+startNode.append(newsNode);
+var impNode = new CustomTreeNode();
+impNode.name = "Impressum";
+startNode.append(impNode);
+var heutNode = new CustomTreeNode();
+heutNode.name = "Heute";
+newsNode.append(heutNode);
+var archNode = new CustomTreeNode();
+archNode.name = "Archiv";
+newsNode.append(archNode);
+var arch05Node = new CustomTreeNode();
+arch05Node.name = "2005";
+archNode.append(arch05Node);
+var arch06Node = new CustomTreeNode();
+arch06Node.name = "2006";
+archNode.append(arch06Node);
+var arch07Node = new CustomTreeNode();
+arch07Node.name = "2007";
+archNode.append(arch07Node);
+console.log(myTree);
+$(function () {
+ var displayTree = new customTreeController(myTree);
Added: branches/tree_dev/http/x_test/customTreeModel.js
--- branches/tree_dev/http/x_test/customTreeModel.js (rev 0)
+++ branches/tree_dev/http/x_test/customTreeModel.js 2008-09-17 09:22:20 UTC (rev 2946)
@@ -0,0 +1,244 @@
+ * @class A List object is an array of arbitrary objects with additional methods.
+ * @constructor
+var List = function() {
+ * gets the number of elements in this {@link List}
+ * @returns number of elements in this {@link List}
+ * @type Integer
+ this.count = function() {
+ return this.list.length;
+ * deletes the object at index i; -1 refers to the last object in this {@link List}
+ * @param {Integer} i index
+ this.del = function(i){
+ i = this.getIndex(i);
+ if (i !== false) {
+ for(var z = i; z < this.count() - 1; z++){
+ this.list[z] = this.list[z+1];
+ this.list.length -= 1;
+ return true;
+ return false;
+ * empties this {@link List}
+ this.empty = function() {
+ while (this.list !== null && this.count() > 0) {
+ this.list.pop();
+ * @returns the object at index i; -1 refers to the last object in this {@link List}
+ * @type Integer or false
+ this.get = function(i) {
+ if (i !== false) {return this.list[i];}
+ return false;
+ * adds a reference to item to this {@link List}.
+ * @param {Object} item an object
+ this.add = function(item) {
+ var i = this.list.length;
+ this.list[i] = item;
+ * adds a copy of item to this {@link List}.
+ this.addCopy = function(item) {
+ this.add(cloneObject(item));
+ * attaches the {@link List} aList to this {@link List}
+ * @param {List} aList another list
+ this.union = function(aList) {
+ for (var i=0; i < aList.count(); i++) {this.addCopy(aList.get(i));}
+ * checks if the index is valid and returns it if it is; if i == -1, the correct index is retrieved.
+ * @private
+ * @return Integer or false
+ * @type Integer
+ this.getIndex = function(i){
+ var len = this.list.length;
+ if (i<0 && len + i > -1) {
+ return len + i;
+ else if (i > -1 && i < len){
+ return i;
+ var e = new Mb_exception("class List: function getIndex: member index " + i + " is not valid");
+ return false;
+ * @returns a {String} representation of this List
+ * @type String
+ this.toString = function(){
+ var str = "";
+ for (var i =0 ; i < this.count() ; i++){
+ str += this.get(i).toString();
+ return str;
+ this.list = null;
+ * A tree
+ * Using adjacency model
+ * w/ nested sets output
+var CustomTree = function () {
+ this.root = new CustomTreeNode (null);
+ this.currentlyDraggedNode = null;
+ var that = this;
+ * Returns this tree as nested sets
+ this.toString = function () {
+ // initialising recursion
+ var nodeArray = toStringNode.apply(this, [[], this.root, 1]);
+ return $.toJSON(nodeArray);
+ var toStringNode = function (nodeArray, node, nextLeft) {
+ var left = nextLeft;
+ var right;
+ var newLeft = nextLeft + 1;
+ var nodeCount = node.childNodeList.count();
+ // node has children...
+ if (nodeCount > 0) {
+ for (var i = 0; i < nodeCount; i++) {
+ var currentChild = node.childNodeList.get(i);
+ // ... recursion
+ nodeArray = toStringNode.apply(that, [nodeArray, currentChild, newLeft]);
+ newLeft = nodeArray[-1 + nodeArray.length].right + 1;
+ right = newLeft;
+ // node is a leaf...
+ else {
+ right = left + 1;
+ nodeArray.push({
+ "left": left,
+ "right": right,
+ "name": node.name
+ return nodeArray;
+ * A list of nodes
+var CustomTreeChildList = function () {
+ this.list = [];
+CustomTreeChildList.prototype = new List();
+ * A single node
+ * @param {Object} parentNode
+var CustomTreeNode = function (parentNode) {
+ this.name;
+ this.parentNode = parentNode;
+ this.childNodeList = new CustomTreeChildList();
+ this.$domNode = null;
+ this.afterMove = function () {
+ this.afterRemove = function () {
+ this.afterAddChild = function () {
+ this.addChild = function () {
+ this.childNodeList.add(new CustomTreeNode(this));
+ var newChild = this.childNodeList.get(-1);
+ newChild.name = "(new node)";
+ this.afterAddChild();
+ return newChild;
+ this.getNumberOfChildren = function () {
+ var cnt = this.childNodeList.count();
+ var numOfChildren = cnt;
+ if (cnt > 0) {
+ for (var i = 0; i < cnt; i++) {
+ numOfChildren += this.childNodeList.get(i).getNumberOfChildren();
+ return numOfChildren;
+ this.remove = function () {
+ this.childNodeArray = [];
+ this.parentNode.removeChild(this);
+ this.parentNode = null;
+ this.afterRemove();
+ this.removeChild = function (someNode) {
+ for (var i = 0; i < this.childNodeList.count(); i++) {
+ var child = this.childNodeList.get(i);
+ if (child == someNode) {
+ this.childNodeList.del(i);
+ break;
+ this.move = function (toParent) {
+ toParent.append(this);
+ this.afterMove();
+ this.append = function (someNode) {
+ someNode.parentNode = this;
+ this.childNodeList.add(someNode);
Added: branches/tree_dev/http/x_test/tree.html
--- branches/tree_dev/http/x_test/tree.html (rev 0)
+++ branches/tree_dev/http/x_test/tree.html 2008-09-17 09:22:20 UTC (rev 2946)
@@ -0,0 +1,60 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
+ <title>Untitled Document</title>
+<style type="text/css">
+.ui-selecting {
+ color:red;
+.treeNode {
+ color:green;
+.treeLeaf {
+ color:blue;
+.ui-selected {
+ border-width:thin;
+ border-style:solid;
+ border-color:red;
+ background-color:transparent;
+ font-size:9px;
+.ui-draggable {
+.div-border {
+ border-color:black;
+ font-size:9px;
+.contextMenu
+ display:none;
+</style>
+ <script type="text/javascript" src="../extensions/jquery-1.2.6.min.js"></script>
+ <script type="text/javascript" src="../extensions/jquery-ui-personalized-1.5.2.js"></script>
+ <script type="text/javascript" src="../extensions/jquery.contextmenu.r2.js"></script>
+ <script type="text/javascript" src="../extensions/jqjson.js"></script>
+ <script type="text/javascript" src="customTreeModel.js"></script>
+ <script type="text/javascript" src="customTree.js"></script>
+ </head>
+ <body>
+ <div class="contextMenu" id="folderMenu">
+ <ul>
+ <li id="addFolder"><img src="images/folder_add.png" /> Add </li>
+ <li id="deleteFolder"><img src="images/folder_delete.png" /> Delete</li>
+ <li id="editFolder"><img src="images/folder_edit.png" /> Edit</li>
+ </ul>
+ </div>
+ <div class="contextMenu" id="leafMenu">
+ <ul>
+ <li id="deleteService"><img src="images/folder_delete.png" /> Delete</li>
+ </ul>
+ </div>
+ </body>
+</html>
More information about the Mapbender_commits
