[Mapbender-commits] r2953 - branches/tree_dev/http/x_test
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Sep 17 08:33:33 EDT 2008
Author: christoph
Date: 2008-09-17 08:33:33 -0400 (Wed, 17 Sep 2008)
New Revision: 2953
Added:
   branches/tree_dev/http/x_test/customTreeController.js
Removed:
   branches/tree_dev/http/x_test/customTree.js
   branches/tree_dev/http/x_test/customTreeModel.js
   branches/tree_dev/http/x_test/tree.html
added context menu
added 2nd tree
Deleted: branches/tree_dev/http/x_test/customTree.js
--- branches/tree_dev/http/x_test/customTree.js	2008-09-17 10:31:27 UTC (rev 2952)
+++ branches/tree_dev/http/x_test/customTree.js	2008-09-17 12:33:33 UTC (rev 2953)
@@ -1,231 +0,0 @@
-var customTreeController = function (myTree) {
-//	this.myTree = new CustomTree();
-//	this.myTree.root.name = "My tree";
-	this.myTree = myTree;
-	this.$root = $("<ul></ul>");
-	var that = this;
-	var currentlyDraggedNode;
-	var addContextMenuToLeaf = function ($domNode, treeNode) {
-		$domNode.contextMenu('leafMenu', {
-			onContextMenu: function(e) {
-				return true;
-			onShowMenu: function(e, menu) {
-				return menu;
-			bindings: {
-				'deleteService': function () {
-					treeNode.remove();
-	var addContextMenuToFolder = function ($domNode, treeNode) {
-		$domNode.contextMenu('folderMenu', {
-			onContextMenu: function(e){
-				return true;
-			onShowMenu: function(e, menu){
-				return menu;
-			bindings: {
-				'addFolder': function(item){
-					var newChild = treeNode.addChild();
-				'deleteFolder': function(){
-				'editFolder': function(){
-	var addContextMenuToRoot = function ($domNode, treeNode) {
-		$domNode.contextMenu('rootMenu', {
-				return true;
-				return menu;
-			bindings: {
-	var addOpenCloseBehaviour = function ($domNode) {
-		$domNode.toggle(function () {
-			$(this).siblings().hide("fast");
-		}, function () {
-			$(this).siblings().show("fast");
-	var makeNodeDroppable = function ($domNode, treeNode) {
-		$domNode.droppable({
-			"accept": function ($draggable) {
-				var $invalidDroppables = $(".currently-dragging .treeNodeDrop");
-				var $invalidDroppablesMinusThis = $invalidDroppables.not($domNode);
-				if ($invalidDroppables.size() > $invalidDroppablesMinusThis.size()) {
-					return false;
-				return true;
-			"tolerance": "pointer",
-			"drop": function (e, ui) {
-				$toDomNode = $(this);
-				$fromDomNode = $(ui.draggable);
-				currentlyDraggedNode.afterMove = function () {
-					$toDomNode.next().append($(ui.draggable));
-					$(".treeLeaf").removeAttr("style");
-					$("*").removeClass("currently-dragging");
-				currentlyDraggedNode.move(treeNode);
-	 *  A recursive function to draw the nodes of a tree and attach
-	 *  draggables and droppables
-	 * @param {Object} $domNode
-	 * @param {Object} treeNode
-	var drawNode = function ($domNode, treeNode) {
-		var numOfChildren = treeNode.childNodeList.count();
-		var $currentItem;
-		var $currentLabel;
-		// this treeNode is a leaf
-		if (numOfChildren === 0) {
-			$currentLabel = $("<span>" + treeNode.name + "</span>");
-			$currentItem = $("<li class='treeLeaf'></li>");
-			$currentItem.append($currentLabel);
-			addContextMenuToLeaf($currentLabel, treeNode);
-		else {
-			// this treeNode is an inner node
-			$currentItem = $("<li class='treeNode'></li>");
-			$currentLabel = $("<div class='treeNodeDrop'><span>" + treeNode.name + "</span></div>");
-			var $currentFolder = $("<ul></ul>");
-			$currentItem.append($currentFolder);
-			// enable folder closing and opening
-			// (not for root node)
-			if (treeNode != that.myTree.root) {
-				addOpenCloseBehaviour($currentLabel);
-			// enable context menu
-				addContextMenuToFolder($currentLabel, treeNode);
-			else {
-				addContextMenuToRoot($currentLabel, treeNode);
-			// make inner nodes droppable
-			makeNodeDroppable($currentLabel, treeNode);
-			// visit the child nodes (depth first)
-			for (var i = 0; i < numOfChildren; i++) {
-				drawNode.apply(that, [$currentFolder, treeNode.childNodeList.get(i)]);
-		// make node draggable
-			$currentItem.draggable({
-				"helper": "clone",
-				"start": function(){
-					$(this).addClass("currently-dragging");
-					currentlyDraggedNode = treeNode;
-		// attach node to tree
-		$domNode.append($currentItem);
-		// link model and view
-		treeNode.$domNode = $currentItem;
-		treeNode.afterRemove = function () {
-			$currentItem.remove();
-	$(document.body).append(that.$root);
-	drawNode(that.$root, that.myTree.root);
-// see example at http://guxx.de/2007/05/30/nested-sets/
-var myTree = new CustomTree();
-var root = myTree.root;
-root.name = "(root)";
-var startNode = new CustomTreeNode();
-startNode.name = "Startseite";
-root.append(startNode);
-var newsNode = new CustomTreeNode();
-newsNode.name = "News";
-startNode.append(newsNode);
-var impNode = new CustomTreeNode();
-impNode.name = "Impressum";
-startNode.append(impNode);
-var heutNode = new CustomTreeNode();
-heutNode.name = "Heute";
-newsNode.append(heutNode);
-var archNode = new CustomTreeNode();
-archNode.name = "Archiv";
-newsNode.append(archNode);
-var arch05Node = new CustomTreeNode();
-arch05Node.name = "2005";
-archNode.append(arch05Node);
-var arch06Node = new CustomTreeNode();
-arch06Node.name = "2006";
-archNode.append(arch06Node);
-var arch07Node = new CustomTreeNode();
-arch07Node.name = "2007";
-archNode.append(arch07Node);
-console.log(myTree);
-$(function () {
-	var displayTree = new customTreeController(myTree);
Added: branches/tree_dev/http/x_test/customTreeController.js
--- branches/tree_dev/http/x_test/customTreeController.js	                        (rev 0)
+++ branches/tree_dev/http/x_test/customTreeController.js	2008-09-17 12:33:33 UTC (rev 2953)
@@ -0,0 +1,239 @@
+var customTreeController = function (myTree) {
+//	this.myTree = new CustomTree();
+//	this.myTree.root.name = "My tree";
+	this.myTree = myTree;
+	this.$root = $("<ul></ul>");
+	var that = this;
+	var currentlyDraggedNode;
+	// --------------- BEHAVIOUR (begin) ------------------
+	var addLeafBehaviour = function ($domNode, treeNode) {
+		// enable context menu
+		$label = $domNode.children().eq(0);
+		addContextMenuToLeaf($domNode, treeNode);
+		// make leaves draggable
+		makeNodeDraggable($domNode, treeNode);
+	var addFolderBehaviour = function ($domNode, treeNode) {
+		if (treeNode != that.myTree.root) {
+			// enable folder closing and opening
+			addOpenCloseBehaviour($label);
+			addContextMenuToFolder($domNode, treeNode);
+			// make inner nodes draggable
+		else {
+			addContextMenuToRoot($domNode, treeNode);
+		// make all folders droppable
+		makeNodeDroppable($label, treeNode);
+	var deleteNode = function (treeNode) {
+		treeNode.remove();
+	var editNode = function ($domNode, treeNode) {
+		var newName = prompt('Name');
+		if (newName) {
+			treeNode.setName(newName);
+	var addNode = function ($domNode, treeNode) {
+		var newChild = treeNode.addChild();
+		$newNode = createFolder(newChild);
+		var $folder = $domNode.children().eq(1);
+		$folder.append($newNode);
+	// CONTEXT MENU
+	var addContextMenuToLeaf = function ($domNode, treeNode) {
+		$domNode.contextMenu('leafMenu', {
+			onContextMenu: function(e) {
+				return true;
+			onShowMenu: function(e, menu) {
+				return menu;
+			bindings: {
+				'deleteService': function () {
+					deleteNode(treeNode);
+	var addContextMenuToFolder = function ($domNode, treeNode) {
+		$domNode.contextMenu('folderMenu', {
+			onContextMenu: function(e){
+				return true;
+			onShowMenu: function(e, menu){
+				return menu;
+			bindings: {
+				'addFolder': function(item){
+					addNode($domNode, treeNode);
+				'deleteFolder': function(){
+				'editFolder': function(){
+					editNode($domNode, treeNode);
+	var addContextMenuToRoot = function ($domNode, treeNode) {
+		$domNode.contextMenu('rootMenu', {
+				return true;
+				return menu;
+			bindings: {
+	// OPEN AND CLOSE BEHAVIOUR
+	var addOpenCloseBehaviour = function ($domNode) {
+		$domNode.toggle(function () {
+			$(this).siblings().hide("fast");
+		}, function () {
+			$(this).siblings().show("fast");
+	// DRAGGABLE AND DROPPABLE
+	var makeNodeDraggable = function ($domNode, treeNode) {
+		$domNode.draggable({
+			"helper": "clone",
+			"start": function(){
+				$(this).addClass("currently-dragging");
+				currentlyDraggedNode = treeNode;
+	var makeNodeDroppable = function ($domNode, treeNode) {
+		$domNode.droppable({
+			"accept": function ($draggable) {
+				var $invalidDroppables = $(".currently-dragging .treeNodeDrop");
+				var $invalidDroppablesMinusThis = $invalidDroppables.not($domNode);
+				if ($invalidDroppables.size() > $invalidDroppablesMinusThis.size()) {
+					return false;
+				return true;
+			"tolerance": "pointer",
+			"drop": function (e, ui) {
+				$toDomNode = $(this);
+				$fromDomNode = $(ui.draggable);
+				currentlyDraggedNode.afterMove = function () {
+					$toDomNode.next().append($(ui.draggable));
+					$(".treeLeaf").removeAttr("style");
+					$("*").removeClass("currently-dragging");
+				currentlyDraggedNode.move(treeNode);
+	// --------------- BEHAVIOUR (end) ------------------
+	var createLeaf = function (treeNode) {
+		var $currentItem = $("<li class='treeLeaf'></li>");
+		var $currentLabel = $("<span>" + treeNode.name + "</span>");
+		$currentItem.append($currentLabel);
+		addLeafBehaviour($currentItem, treeNode);
+		treeNode.$domNode = $currentItem;
+		treeNode.afterRemove = function () {
+			$currentItem.remove();
+		return $currentItem;
+	var createFolder = function (treeNode) {
+		var $currentItem = $("<li class='treeNode'></li>");
+		var $currentLabel = $("<div class='treeNodeDrop'><span>" + treeNode.name + "</span></div>");
+		var $currentFolder = $("<ul></ul>");
+		$currentItem.append($currentFolder);
+		addFolderBehaviour($currentItem, treeNode);
+		treeNode.afterSetName = function () {
+			$currentLabel.children().eq(0).html(treeNode.name);
+	 *  A recursive function to draw the nodes of a tree and attach
+	 *  draggables and droppables
+	 * @param {Object} $domNode
+	 * @param {Object} treeNode
+	var drawNode = function ($domNode, treeNode) {
+		var numOfChildren = treeNode.childNodeList.count();
+		var $newNode;
+		if (numOfChildren === 0) {
+			$newNode = createLeaf(treeNode);
+		else {
+			$newNode = createFolder(treeNode);
+			// visit the child nodes (depth first)
+			var $folder = $newNode.children().eq(1);
+			for (var i = 0; i < numOfChildren; i++) {
+				drawNode.apply(that, [$folder, treeNode.childNodeList.get(i)]);
+		// attach node to tree
+		$domNode.append($newNode);
+	$(document.body).append(that.$root);
+	drawNode(that.$root, that.myTree.root);
Modified: branches/tree_dev/http/x_test/customTreeModel.js
--- branches/tree_dev/http/x_test/customTreeModel.js	2008-09-17 10:31:27 UTC (rev 2952)
+++ branches/tree_dev/http/x_test/customTreeModel.js	2008-09-17 12:33:33 UTC (rev 2953)
@@ -239,9 +239,16 @@
 	this.afterAddChild = function () {
+	this.afterSetName = function () {
+	this.setName = function (newName) {
+		this.name = newName;
+		this.afterSetName();
 	this.addChild = function () {
 		this.childNodeList.add(new CustomTreeNode(this));
 		var newChild = this.childNodeList.get(-1);
Modified: branches/tree_dev/http/x_test/tree.html
--- branches/tree_dev/http/x_test/tree.html	2008-09-17 10:31:27 UTC (rev 2952)
+++ branches/tree_dev/http/x_test/tree.html	2008-09-17 12:33:33 UTC (rev 2953)
@@ -41,7 +41,74 @@
 		<script type="text/javascript" src="../extensions/jquery.contextmenu.r2.js"></script>
 		<script type="text/javascript" src="../extensions/jqjson.js"></script>
 		<script type="text/javascript" src="customTreeModel.js"></script>
-		<script type="text/javascript" src="customTree.js"></script>
+		<script type="text/javascript" src="customTreeController.js"></script>
+		<script type="text/javascript">
+			// see example at http://guxx.de/2007/05/30/nested-sets/
+			var myTree = new CustomTree();
+			var root = myTree.root;
+			root.name = "(root)";
+			var startNode = new CustomTreeNode();
+			startNode.name = "Startseite";
+			root.append(startNode);
+			var newsNode = new CustomTreeNode();
+			newsNode.name = "News";
+			startNode.append(newsNode);
+			var impNode = new CustomTreeNode();
+			impNode.name = "Impressum";
+			startNode.append(impNode);
+			var heutNode = new CustomTreeNode();
+			heutNode.name = "Heute";
+			newsNode.append(heutNode);
+			var archNode = new CustomTreeNode();
+			archNode.name = "Archiv";
+			newsNode.append(archNode);
+			var arch05Node = new CustomTreeNode();
+			arch05Node.name = "2005";
+			archNode.append(arch05Node);
+			var arch06Node = new CustomTreeNode();
+			arch06Node.name = "2006";
+			archNode.append(arch06Node);
+			var arch07Node = new CustomTreeNode();
+			arch07Node.name = "2007";
+			archNode.append(arch07Node);
+			console.log(myTree);
+			var wmsTree = new CustomTree();
+			var wmsRoot = wmsTree.root;
+			wmsRoot.name = "(root)";
+			var wms1Node = new CustomTreeNode();
+			wms1Node.name = "Germany";
+			wmsRoot.append(wms1Node);
+			var wms2Node = new CustomTreeNode();
+			wms2Node.name = "Demis";
+			wmsRoot.append(wms2Node);
+			var wms3Node = new CustomTreeNode();
+			wms3Node.name = "Mapbender User";
+			wmsRoot.append(wms3Node);
+			$(function () {
+				var displayTree = new customTreeController(myTree);
+				var displayWmsTree = new customTreeController(wmsTree);
+		</script>
 	</head>
 	<body>
 		<div class="contextMenu" id="folderMenu">
More information about the Mapbender_commits mailing list
