[Mapbender-commits] r2974 - branches/nimix_dev/http/html
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Sep 18 08:37:07 EDT 2008
Author: nimix
Date: 2008-09-18 08:37:07 -0400 (Thu, 18 Sep 2008)
New Revision: 2974
   branches/nimix_dev/http/html/mod_treefolder2.php
fix wms selection
Modified: branches/nimix_dev/http/html/mod_treefolder2.php
--- branches/nimix_dev/http/html/mod_treefolder2.php	2008-09-18 12:16:34 UTC (rev 2973)
+++ branches/nimix_dev/http/html/mod_treefolder2.php	2008-09-18 12:37:07 UTC (rev 2974)
@@ -545,15 +545,15 @@
 function handleSelectedWMS(path){
 	if(lock_update)return;
-	console.log(path);
 	var t = path.split("|");
 	var wms_id = t[t.length-1].substr(4);
 	var reset_lock=!lock_check;
 	var ind = parent.getMapObjIndexByName(mod_treeGDE_map);
-	var layername = parent.mb_mapObj[ind].wms[parent.getWMSIndexById(mod_treeGDE_map,wms_id)].objLayer[0].layer_name;
+	var wms = parent.getWMSIndexById(mod_treeGDE_map,wms_id);
+	var layername = parent.mb_mapObj[ind].wms[wms].objLayer[0].layer_name;
 	var bChk = IsChecked(path, 0);
-	handleSelectedLayer(mod_treeGDE_map,wms_id,layername,"visible",bChk?"1":"0");
-	handleSelectedLayer(mod_treeGDE_map,wms_id,layername,"querylayer",bChk?"1":"0");
+	parent.mb_mapObj[ind].wms[wms].handleLayer(layername,"visible",bChk?"1":"0");
+	parent.mb_mapObj[ind].wms[wms].handleLayer(layername,"querylayer",bChk?"1":"0");
 	lock_check=true;
 	checkChildren(path, 0, bChk);
 	if(ficheckbox)checkChildren(path, 1, bChk);
@@ -569,7 +569,6 @@
 function handleSelection(path, box){
 	lock_check=true;
 	var bChk = IsChecked(path, box);
@@ -601,6 +600,13 @@
 							if(parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_parent == ""){
 								if(!temp.gui_layer_selectable == '1' && !temp.gui_layer_queryable == '1')
 									continue;
+								parentNode = arrNodes[0][0];
+								if(eval("categories.wms_"+parent.mb_mapObj[i].wms[ii].wms_id) !== undefined)
+									parentNode = eval("categories.wms_"+parent.mb_mapObj[i].wms[ii].wms_id);
+								else
+									eval("categories['wms_"+parent.mb_mapObj[i].wms[ii].wms_id+"'] = parentNode");
 								var c_menu="[";
 								if(reverse=="true"){
 									if(menu.indexOf("wms_down")!=-1 && ii!=parent.mb_mapObj[i].wms.length-1)c_menu+="menu_move_up,";
@@ -617,13 +623,8 @@
 								if(menu.indexOf("hide")!=-1)c_menu+="menu_hide";
 								c_menu+="]";
 								controls=null;
-								if(switchwms=='true')controls='<INPUT type="checkbox" title="' + msgObj.tooltipHandleWms + '" checked onclick="handleSelectedWMS(\''+arrNodes[0][0]+'|'+parent.mb_mapObj[i].wms[ii].wms_id+'\');" />';
+								if(switchwms=='true')controls='<INPUT type="checkbox" title="' + msgObj.tooltipHandleWms + '" checked onclick="handleSelectedWMS(\''+parentNode+'|wms_'+parent.mb_mapObj[i].wms[ii].wms_id+'\');" />';
 								if(wmsbuttons == 'true'&&metadatalink == 'true')controls+='<a href="'+'javascript:openwindow(\''+ defaultMetadataUrl + '&id='+temp.layer_uid+'\');'+'"><img src="'+imagedir+'/info.png" /></a>';
-								parentNode = arrNodes[0][0];
-								if(eval("categories.wms_"+parent.mb_mapObj[i].wms[ii].wms_id) !== undefined)
-									parentNode = eval("categories.wms_"+parent.mb_mapObj[i].wms[ii].wms_id);
-								else
-									eval("categories['wms_"+parent.mb_mapObj[i].wms[ii].wms_id+"'] = parentNode");
 								addNode(parentNode,["wms_"+parent.mb_mapObj[i].wms[ii].wms_id,[temp.layer_title,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"'+ defaultMetadataUrl + '&id='+temp.layer_uid+'\");'):"javascript:select("+i+","+ii+","+iii+");"),,,temp.layer_title,eval(c_menu),controls,[i,ii,iii]]],false,false,reverse=="true");
 								parentObj = parentNode+"|wms_"+parent.mb_mapObj[i].wms[ii].wms_id;
More information about the Mapbender_commits mailing list
