[Mapbender-commits] r2986 - in trunk/documents/presentations: . FOSS4G2006 Linuxtag2008 templates
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Sep 19 03:41:06 EDT 2008
Author: astrid_emde
Date: 2008-09-19 03:41:06 -0400 (Fri, 19 Sep 2008)
New Revision: 2986
Added:
   trunk/documents/presentations/FOSS4G2006/
   trunk/documents/presentations/FOSS4G2006/fiona_on_FOSS4G2006.pdf
   trunk/documents/presentations/FOSS4G2006/mapbender_on_FOSS4G2006.pdf
   trunk/documents/presentations/Linuxtag2008/
   trunk/documents/presentations/Linuxtag2008/mapbender_on_linuxtag2008_de.odp
   trunk/documents/presentations/Linuxtag2008/mapbender_on_linuxtag2008_de.pdf
   trunk/documents/presentations/templates/
   trunk/documents/presentations/templates/mapbender_de.odp
   trunk/documents/presentations/templates/mapbender_en.odp
new folder for presentations
Added: trunk/documents/presentations/FOSS4G2006/fiona_on_FOSS4G2006.pdf
(Binary files differ)
Property changes on: trunk/documents/presentations/FOSS4G2006/fiona_on_FOSS4G2006.pdf
___________________________________________________________________
   + application/octet-stream
Added: trunk/documents/presentations/FOSS4G2006/mapbender_on_FOSS4G2006.pdf
Property changes on: trunk/documents/presentations/FOSS4G2006/mapbender_on_FOSS4G2006.pdf
Added: trunk/documents/presentations/Linuxtag2008/mapbender_on_linuxtag2008_de.odp
Property changes on: trunk/documents/presentations/Linuxtag2008/mapbender_on_linuxtag2008_de.odp
Added: trunk/documents/presentations/Linuxtag2008/mapbender_on_linuxtag2008_de.pdf
Property changes on: trunk/documents/presentations/Linuxtag2008/mapbender_on_linuxtag2008_de.pdf
Added: trunk/documents/presentations/templates/mapbender_de.odp
Property changes on: trunk/documents/presentations/templates/mapbender_de.odp
Added: trunk/documents/presentations/templates/mapbender_en.odp
Property changes on: trunk/documents/presentations/templates/mapbender_en.odp
More information about the Mapbender_commits mailing list
