[Mapbender-commits] r3016 - branches/2.5/http/classes
svn_mapbender at osgeo.org
Fri Sep 26 03:52:44 EDT 2008
Author: verenadiewald
Date: 2008-09-26 03:52:43 -0400 (Fri, 26 Sep 2008)
New Revision: 3016
branches/2.5/http/classes/class_wfs_conf.php
http://trac.osgeo.org/mapbender/ticket/301 -> Sort wfs conf selectbox in order of wfsConfIdString
Modified: branches/2.5/http/classes/class_wfs_conf.php
--- branches/2.5/http/classes/class_wfs_conf.php 2008-09-26 07:40:36 UTC (rev 3015)
+++ branches/2.5/http/classes/class_wfs_conf.php 2008-09-26 07:52:43 UTC (rev 3016)
@@ -93,27 +93,19 @@
* @param $idArray Array an array of integer values representing WFS conf IDs.
private static function getWfsConfFromDbByArray ($idArray) {
- $sql = "SELECT * FROM wfs_conf ";
- $sql .= "JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
- $sql .= "WHERE wfs_conf.wfs_conf_id IN (";
- $v = array();
- $t = array();
- for ($i = 0; $i < count($idArray); $i++) {
- if ($i > 0) {$sql .= ", ";}
- $sql .= "$" . ($i+1);
- array_push($v, $idArray[$i]);
- array_push($t, 'i');
- $sql .= ")";
- $res = db_prep_query($sql, $v, $t);
$rowArray = array();
- while ($row = db_fetch_array($res)) {
- array_push($rowArray, $row);
- return $rowArray;
+ foreach ($idArray as $id) {
+ $sql = "SELECT * FROM wfs_conf ";
+ $sql .= "JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
+ $sql .= "WHERE wfs_conf.wfs_conf_id = $1 LIMIT 1";
+ $v = array($id);
+ $t = array("i");
+ $res = db_prep_query($sql, $v, $t);
+ $row = db_fetch_array($res);
+ array_push($rowArray, $row);
+ return $rowArray;
More information about the Mapbender_commits
