[Mapbender-commits] r3025 - branches/2.5
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Sep 29 05:22:14 EDT 2008
Author: astrid_emde
Date: 2008-09-29 05:22:14 -0400 (Mon, 29 Sep 2008)
New Revision: 3025
   branches/2.5/Changes.txt
link to trac added
Modified: branches/2.5/Changes.txt
--- branches/2.5/Changes.txt	2008-09-29 09:18:18 UTC (rev 3024)
+++ branches/2.5/Changes.txt	2008-09-29 09:22:14 UTC (rev 3025)
@@ -1,419 +1,422 @@
-The following Link gives a review on the changes in Mapbender you can get in the WIKI
-http://www.mapbender.org/index.php/Version_History
-Changelog 2.4.2
-  english
-    bug fixes: see http://trac.osgeo.org/mapbender/report/9
-    new features
-    * set WMS opacity in treeGDE2
-    * Bulgarian translation of the introduction to Mapbender
-    * improved module Add WMS from filtered list: loading a configured WMS from a GUI is now possible
-    * updated Meetingpoint / Treffpunkt: new image, some bugfixes
-    * improved exception handling / log levels (see mapbender.conf#Mapbender_error_logging)
-    * poi (not included in a GUI yet)
-    * JavaScript compression; Mapbender will load faster
-    * dynamic overview - integration in the rc1 an testing gui2
-    * treeGDE2 replaces treeGDE
-    * different configurations of treeGDE2
-    * first draft of an API documentation for JavaScript classes
-    * print temporary objects (lines and polygons) which where drawn with the measure element
-  deutsch
-    behobene Fehler: siehe http://trac.osgeo.org/mapbender/report/9
-    neue Features
-    * Einstellen der Deckkraft (Opacity) einzelner WMSe in der TreeGDE2
-    * Bulgarische Übersetzung der Mapbender-Einführung
-    * Verbesserung des Moduls Add WMS from filtered list: es ist nun möglich, konfigurierte WMSe aus GUIs zu laden
-    * Update des Moduls Meetingpoint / Treffpunkt: neue Bilddatei, diverse Fehler behoben
-    * Verbessertes Logging, auch von JavaScript Fehlern (siehe mapbender.conf#Mapbender_error_logging)
-    * poi (noch in keiner GUI enthalten)
-    * JavaScript Kompression; Mapbender lädt schneller
-    * Dynamisches Overview
-    * TreeGDE2 ersetzt die alte Baumstruktur
-    * verschiedene Konfigurationen der TreeGDE2 in den Standard-GUIs
-    * vorläufige API Dokumentation für JavaScript Klassen
-    * Druck von temporären Objekten (Linien und Polygone), die mit dem "measure" Element erstellt wurden
-Changelog 2.4.1
-english
-new features
-bug fixes
-    * 1658777 Export GUI SQL unsorted
-    * 1634035 Wfs geometry name not sorted by position
-    * 1647206 sort order of modules in gui element list
-    * 1635839 JS error: document.form1.newGuiName has no properties
-    * 1589764 wms loading problems when abstract contain linebreak
-    * 1653348 mod_filteredGroup_filteredGui.php
-    * 1653160 Metadata: Undefined variable: wms_id
-    * 3 Online resource incorrect in monitoring module
-    * 11 wrong sort order in edit_gui_wms
-database changes
-see latest database changes.
-deutsch
-Changelog Mapbender 2.4.1 rc1
-english
-    * changes in database architecture: For update have a look in the wiki at dbchanges or Database_Changes_2.4.1. The update sqls you find in the download package in the folder mapbender/resources/db/update/
-    * WFS_gazetteer possibility to handle several wfs_confs and choose from a select-box - thanx to User:Verena Diewald
-    * new treeGDE - thanx to User:Melchior Moos
-    * new element setPOI2Scale mod_setPoi2Scale to open a GUI at a special coordinate and scale - have a look Mod_setPoi2Scale
-    * extended ResizeMapsize functionality - Modul can act automatically or by button click. 3 element vars are added.
-    * new administration functionality OrphanWMS to find information about orphaned WMS and to fix them.
-    * new functionality meetingPoint to generate meeting points and export them as text or via email. The url can be displayed by highlightPOI
-    * pdf-Print now with Din-A2 support
-    * new element highlightPOI (mod_highlightPOI.php) to open a gui and set poi points with text
-    * metadata handling
-    * new admin guis
-    * wfs bug fix for digitize modul
-    * featureinfo tunnel closes empty result windows automatically
-deutsch
-    * Änderungen in der Datenbankarchitektur: Angaben im Wiki unter dbchanges oder Database_Changes_2.4.1. Die update-sqls befinden sich im Download-Paket im Verzeicnis mapbender/resources/db/update/
-    * WFS_gazetteer Auswahlmöglichkeit zwischen mehreren WFS-Konfigurationenüber eine Auswahlliste - thanx to User:Verena Diewald
-    * treeGDE - neue Baumstruktur - thanx to User:Melchior Moos
-    * Neues Modul add_vendorspecific.
-    * Neues Element setPOI2Scale um eine GUI an einen Punkt in einem bestimmten Maßstab zu öffnen Mod_setPoi2Scale.
-    * Erweiterung des Moduls resizeMapsize. Kartenfenster kann sich automatisch an die Browsergröße anpasssen oder über einen Button. 3 Element vars wurden hinzugefügt.
-    * Neues Administrationselement OrphanWMS, dass informationen über verwaiste WMS liefert und diese löschen kann.
-    * Neues Element meetingPoint um Treffpunkte zu generieren und diese als Text oder via E-Mail zu exportieren. Die URL kann durch highlightPOI angezeigt werden.
-    * pdf-Print nun auch mit Din-A2 Unterstützung (Dank an Frank Härtel und Horst Becker).
-    * Neues Element highlightPOI (mod_highlightPOI.php) ermöglicht es beim Öffnen einer GUI ein oder mehrere Punkte mit Beschriftung zu setzen.
-    * Metadaten handling.
-    * Featureinfotunnel schließt leere Fenster ohne Ergebnis gleich wieder.
-english
-    * bugs in loadWMC are fixed
-    * new module resizeMapsize to resize the Mapsize depending on the size of the browser window
-    * new module monitorCapabilities: periodically checks all WMS and gathers data in the new table mb_monitor (see Database_Changes_2.4)
-    * new module initWMC: starts the client with a wmc.
-    * wms_extent - WMS representing the EXTENTs of the WMS loaded in Mapbender
-deutsch
-    * Bugs im Modul loadWMC wurden behoben.
-    * Neues Modul resizeMapsize das Modul paßt die Kartengröße in Abhängigkeit von der Größe des Browserfensters dynamisch an.
-    * Neues Modul monitorCapabilities: periodisch werden alle WMSe kontrolliert und alle Daten in der neuen Tabelle mn_monitor erfaßt (siehe auch Database_Changes_2.4).
-    * Neues Modul initWMC: startet den Client mit einem WMS.
-    * wms_extent - WMS, der die Ausdehnungen (Extent) der in Mapbender geladenen WMSe anzeigt.
-Changelog 2.4 rc2
-english
-    * mapbender changed to Subversion (svn), big effort is done in code cleaning
-    * owsproxy is implemented
-    * treeGDE improved, now there is the possibility to handle the layers of a wms with one click (all layer on / all layer off). new element var switchwms
-    * bugs in legend solved
-    * changes in database architecture: new table wfs_featuretype_namespace, new column wms_owsproxy in table wms, new column wms_upload_url in table wms. For update have a look at dbchanges or Database Changes 2.4
-    * perpared statements for PHP > 5.1.x, PostgreSQL > 7.4
-    * new gui_digitize in the installation package. Read more about Digitizing
-    * new gui2 in the installation package with new buttons (button_blue), new tree-style (tree_blue) and more color.
-    * default md5-encryption for the passwords in MySQL and PostgreSQL. Mapbender is doing the md5-encryption.
-    * extended mapbender_setup.php with more information (Thanks to Marko Samson)
-    * new element deleteWFS in GUI admin1
-    * printPDF: highquality print and matching for the overview image
-    * new help: every element in the gui refers to a page in the Mapbender wiki. The link is saved in the table gui_element column e_url and can be changed individual.
-deutsch
-    * Mapbender wechselt zum Subversion (svn) mit dem damit verbundenen Code cleaning
-    * owsproxy
-    * treeGDE wurde verbessert, es gibt nun die Möglichkeit alle Layer eines WMS durch einen Klick an- bzw. auszustellen.
-    * Bugs in der Legende behoben
-    * Veränderungen in der Datenbankarchitektur: neue Tabelle wfs_featuretype_namespace, neue Spalte wms_owsproxy in Tabelle wms, neue Spalte wms_upload_url in Tabelle wms. Um eine bestehende Datenbank zu aktualisieren, gibt es unter dbchanges weitere Informationen. Database Changes 2.4
-    * Es besteht die Möglichkeit Perpared Statements ab PHP > 5.1.x, PostgreSQL > 7.4 einzusetzen
-    * Neue gui_digitize im Installationsumfang. Mehr unter Digitizing
-    * Neue gui2 im Installationsumfang mit neuen Buttons (button_blue), neuem Style für die Baumstruktur (tree_blue) und mehr Farbe
-    * Standardmäßige md5-Verschlüsselung des Passworts in MySQL und PostgreSQL. Mapbender verschlüsselt nun das Passwort, nicht die Datenbank.
-    * mapbender_setup.php liefert nun mehr Informationen und weist auf Fehler hin (Danke an Marko Samson)
-    * Neues Element deleteWFS in der GUI admin1
-    * printPDF: für den Overview ist nun auch der hochqualitative Druck und das Matching möglich
-    * Hilfebutton: jedes Element der GUI ist direkt mit der Hilfeseite im Mapbender Wiki verlinkt (Eintrag in der Tabelle gui_element Spalte e_url). Dieser Link kann an die jeweilige Umgebung angepaßt werden.
-Changelog 2.2.3
-english
-    * print: now with overview window with position rectangle and scalebar
-    * gui_de and gui1_de are no longer part of the standard installation of mapbender, as it is too much work to handle 4 guis. If you want a german gui, you have to change the tool tip texts. In the next versions we want to handle the language differences with element vars.
-    * WMC handling: includes DisplayWMC, loadWMC, saveWMC and listWMC.
-    * element logout: now with element_var logout_location to define the webside to show after logout
-    * the overview window of the pdf-print is now displayed in highquality, if you use highquality = true in your print-configuration
-    * there has been some rework done at the AddWMS functions. Now the mod_addWMSgeneralFunctions.js offers the functions mod_addWMS_load and mod_addWMS_refresh to the elements addWMSfromfilteredList and addWMSfromList IMPORTANT: JS has to be added as modul in the element-definition
-    * element tabs (mod_tab.php) now with element_var open_tab to decide which tab should be opened at the beginning
-    * print : there where errors in the generation of the legend especially with grouped layers
-    * legend : new element_var checkbox_on_off to decide wether you want to show or hide the on/off checkbox - there where errors in the generation of the legend especially with grouped layers
-    * legend: new element var : stickylegend to decide wether the legend should stick at the mapframe1
-    * connection to GEOS function for mysql users: mapbender.conf / mod_changeEPSG.php / mod_evalArea.php - database parameters where added to the mapbender.conf to enable Mapbender user with mysql-Administration to transform and change the projection
-    * encoding of Mapbender: now UTF-8 or ISO-8859-1 can be choosed as the encoding for the database (have a look in the mapbender.conf CHARSET)
-    * fixed: WFS configuration caused errors with postgresql database
-    * copyright now works with element var for the copyright text: define the JavaScript Variable mod_copyright_text with a text you want as value
-    * fixed: there was an error in class_log, now the printed maprequests should be logged
-    * database changes
-deutsch
-    * print: nun mit Übersichtsfenster mit Positionsrechteck und Maßstabsleiste (beide Funktionalitäten können in der Konfigurationsdatei des Drucks an- oder ausgestellt werden)
-    * Die Oberflächen gui1_de und gui_de werden nicht mehr weitergeführt, da es zu viel Aufwand darstellt 4 Oberflächen weiterzuführen. Wenn eine deutsche Oberfläche gebraucht wird können die ToolTipTexte auf deutsch angelegt werden. Die Mehrsprachigkeit der einzelnen Elemente soll zukünftig über die Element vars gelöst werden.
-    * WMC-Nutzung: beinhaltet anzeigen (DisplayWMC), laden (loadWMC), speichern (saveWMC) eines WMCs und auflisten aller WMCs (listWMC).
-    * Element logout: verfügt nun über den element_var logout_location, um zu definieren welche Webseite nach dem Logout angezeigt werden soll.
-    * Das Übersichtsfenster des PDF-Drucks wird nun auch hochqualitativ angezeigt bei hochqualitativem Druck.
-    * Die AddWMS Funktionalität wurde überarbeitet. Eine neue Datei mod_addWMSgeneralFunctions.js stellt nun die Funktionen mod_addWMS_load und mod_addWMS_refresh zur Verfügung. Wichtig für die Elemente addWMSfromfilteredList and addWMSfromList das JavaScript mod_addWMSgeneralFunctions.js muß in der Elementdefinition unter Modul angegeben werden.
-    * Element tabs (mod_tab.php) wurde um die element_var open_tab erweitert, um beim Start des Clients einen tab voreingestellt zu öffnen.
-    * print: Fehler in der Legende bei gruppierten Ebenen beseitigt.
-    * legend: Neue element_var: checkbox_on_off zur Steuerung der on/off checkbox.
-    * legend: Neue element_var: stickylegend zur Steuerung des Anzeigefesters der Legende (Positionierung / sticky-Frame).
-    * Bereitstellung der GEOS Funktionen für Mapbender mit mysql-Administrationsdatenbank: mapbender.conf / mod_changeEPSG.php / mod_evalArea.php - Zusätzliche Datenbankparameter für eine PostgresDB neben der mysql-Administrationsdatenbank, zur Transformation von Projektionssystemen und Berechnung von Flächen.
-    * Encoding (Zeichensatz) in Mapbender: es besteht nun die Auswahl zwischen UTF-8 oder ISO-8859-1 als Zeichensatz (die Angabe erfolgt in der mapbender.conf CHARSET)
-    * wfs configuration: WFS Konfiguration erzeugte Fehler mit der PostgreSQL-Datenbank.
-    * copyright: Neue element_var mod_copyright_text, Angabe zum Copyright-Text über die Administrationsoberfläche.
-    * fixed: Fehler in class_log behoben.
-    * Datenbankänderungen
-Changelog 2.2.2
-english
-    * Unfortunately there was a bug left in the PostgreSQL database-module. In the edit gui-menu no templates from other guis were shown so that it was impossible to modify guis.
-To fix this, minor changes in the PostgreSQL database-structure were necessary. If you are updating, please do not use an already existing V. 2.2.1-database and create the database with the SQL-dumps attached to this version instead.
-deutsch
-    * Leider war noch ein Fehler im PostgreSQL Datenbank-Modul übersehen worden. Da im Menü Oberflächenelemente editieren die bestehenden GUIs und deren Elemente nicht angezeigt wurden, um sie als Templates zu verwenden, ließen sich die GUIs nicht nach den eigenen Bedürfnissen anpassen.
-Um diesen Fehler zu beheben wurden kleinere Änderungen in der PostgreSQL Datenbank-Struktur vorgenommen. Bitte verwenden Sie daher keine bereits existierende V. 2.2.1-Datenbank falls Sie updaten, sondern benutzen Sie bitte die SQL-Dumps, die dieser Version beigefügt sind.
-Changelog 2.2.1
-english
-We have been a bit quick with the release 2.2 and didn't put the focus on documentation and debugging. But with the help of the users of Mapbender we fixed the bugs and now there is the next Mapbender version for download.
-    * There where some bugs when you run Mapbender with PostgreSQL. Hope they are fixed. Have a look at the Installation to find out about how to configure Mapbender (configuration files have been consolidated into ./conf/mapbender.conf)
-    * the name of two columns had to be changed:
-          o mb_log.session changes to mb_log.mb_session (session is a reserved name in postgresql)
-          o gui_element.e_closeTag changed to gui_element.e_closetag (all table- and columnnames are handled in lower case)
-    * Sequences in PostgreSQL: if you use postgresql you have to set sequences for the serial columns so that the next value for the serial is fixed. user mapbender/resources/db/pgsql_serial_set_sequences.sql to set the sequences
-    * changeEPSG and calculating areas at the moment is only possible for user with PostgreSQL/PostGIS database
-deutsch
-Vielleicht waren wir etwas voreilig mit dem Mapbender Release 2.2 und haben den Fokus nicht auf die Dokumentation und das Debuggig gesetzt. Aber mit Hilfe der User sind viele Fehler aufgezeigt worden und konnten gelöst werden. Hier nun der neue Mapbender 2.2.1. Derzeit gibt es noch keine Dokumentation und auch kein Skript für den automatisierten Update einer bestehenden Mapbender Installation. Die vormals eingesetzen Skripte mapbender_setup.php und validate_db.php können derzeit nicht mehr verwendet werden und wurden aus dem Paket entfernt. Die Skripte müssen erst wieder auf den neuen Release angepaßt werden, damit sie wieder zum Einsatz kommen können.
-    * es lagen einige Bugs bei der Verwendung von PostgreSQL als Administrationsdatenbank vor. Diese sind hoffentlich alle beseitigt. In der Installationsanleitung unter
-mapbender.conf findet sich alles wichtige zur Installation (Alles ist nun einfacher. Es muß nur noch die Datei mapbender.conf angepaßt werden)
-    * der Name zweier Spalten hat sich geändert:
-          o mb_log.session geändert in mb_log.mb_session (session reserviertes Wort in PostgreSQL)
-          o gui_element.e_closeTag geändert in gui_element.e_closetag (alle Tabellen- und Spaltennamen in Kleinbuchstaben)
-    * Sequences in PostgreSQL: bei der Verwendung von PostgreSQL müssen die Sequenzen der Autowerte nach dem Laden der Daten explizit gesetzt werden. Dazu steht die Datei mapbender/resources/db/pgsql_serial_set_sequences.sql zur Verfügung
-    * changeEPSG und Flächenberechnung steht derzeit nur Benutzern mit einer PostgreSQL-Datenbank zur Verfügung
-Changelog 2.2.0
-[edit]
-english
-Here you find a list with the changes in Mapbender 2.2.0:
-    * The configuration files have been consolidated into one single mapbender.conf
-    * Now Mapbender 2.2.0 is able to work with MySQL- or PostgreSQL-database. Configure the settings in the mapbender.conf.
-    * You can edit the single elements of a GUI with the Mapbender-Administration (table element_vars/ css-files/ var).
-    * WFS
-    * Proxy
-    * PrintPDF. This module enables you to configure the PrintPDF containing an overview, legend, northarrow and your logo.
-    * Click on a Layer refers to the WMS METADATAURL - new column layer_metadataurl.
-    * The legend is displayed by the LEGENDURL.
-    * New Wiki: To edit the new wiki you have to ask for an account at mailto:info at mapbender.org.
-    * ToggleModule to define a function to be active when the gui is opened
-Here you already find a list with the changes in Mapbender 2.2:
-    * Mapbender for MySQL or PostgreSQL
-    * click on a Layer refers to the WMS METADATAURLD - new column layer_metadataurl
-    * the legend is displayed by the LEGENDURL
-deutsch
-Hier die Änderungen, die mit der Version 2.2 erfolgt sind:
-    * Nun ist es möglich Mapbender mit einer MySQL- oder PostgreSQL-Datenbank zu installieren. Konfigurieren Sie die Einstellungen in der Datei mapbender.conf.
-    * Sie können die einzelnen Elemente einer GUI mit der Mapbender-Administration editieren (Tabelle element_vars/ css-files/ var).
-    * WFS
-    * Proxy
-    * PrintPDF. Dieses Modul erlaubt es dem Benutzer den PrintPDF zu konfigurieren und beinhaltet Overview, Legende, Nordpfeil und ein Logo.
-    * Neue Buttons (button_oo) sind in der GUI 'gui' verfügbar.
-    * Ein Klick auf einen Layer referenziert die WMS METADATAURL - neue Spalte layer_metadataurl.
-    * Die Legende wird durch die LEGENDURL dargestellt.
-    * Neues Wiki: Um im neuen Wiki editieren zu können, müssen Sie einen Account beantragen bei CCGIS.
-    * ToggleModule - definiert ein Element, das beim Start der GUI aktiviert sein soll
-Hier aber schonmal die Änderungen, die uns mit der Version 2.2 erwarten:
-    * Mapbender für MySQL oder PostgreSQL
-    * Anpassung der einzelnen Elemente einer GUI über die Mapbender-Administration (element_vars)
-    * Metadataurl
-    * Legendurl
-Changelog 2.1.0
-english
-    * communication by email mail.conf
-    * new button myGUIlist in the administration-guis to go back to the list of myGUIs
-    * New table mb_log
-    * New column in table wms wms_getCapabilities_doc
-    * ChangeEpsg_dynamic
-    * Edit gui shows the images of a gui as little pictures (better orientation)
-    * sql to update the mapbender standard guis Update Mapbender
-    * mapbender/http/tools/validate_db.php - php to update the database and add new columns and tables if necessary
-    * New column layer_dataurl in table layer
-    * New columns legendurl and legendurlformat in table layer_style
-    * New table wms_srs
-    * Security update in Edit GUI Elements
-deutsch
-    * Kommunikation über email mail.conf
-    * Neuer Button myGUIlist für die Administrations-GUIs, um in die Liste von meinenGUIs zurück zu kommen.
-    * Neue Tabelle mb_log
-    * Neue Spalte in der Tabelle wms wms_getCapabilities_doc
-    * Die Rubrik 'Oberflächenelemente editieren' zeigt nun kleine Bilder der Oberfläche zur besseren Orientierung.
-    * SQL zur Aktualisierung Ihrer GUIs: siehe Update Mapbender
-    * mapbender/http/tools/validate_db.php - PHP, um die Datenbank zu aktualisieren und wenn nötig neue Spalten und Tabellen hinzuzufügen.
-    * Neue Spalte layer_dataurl in der Tabelle layer hinzugefügt.
-    * Neue Spalten 'legendurl' und 'legendurlformat' in der Tabelle layer_style hinzugefügt.
-    * Neue Tabelle wms_srs
-Changelog 2.1.0 rc1
-english
-    * Print with Mapbender Version 2.1.0 pdf-print is used as standard. You have the possibility to choose A4 or A3 and landscape or portrait. The printframe can be styled to your own design by editing a configuration file.
-    * GUIOwner a new parameter <owner> has been added to the user management. This allows a distinction between reading/using a GUI and being allowed to change it ( edit GUI elements). This feature is necessary as a preliminary step to open Mapbender as a portal with anonymous access which is needed to implement Wikimaps functionality. Additionally this enables setting up a hierarchical administration.
-    * Overview The overview map should be addressed with the module Overview, (<Overview0>, <Overview1>, <Overview2>, ... are deprecated). The module can be parameterized with the field "wms". It contains the index of the WMS which should be displayed in the overview map. (starting at 0).
-    * showCoords_div On button click the coordinate of the mouseposition will be displayed below the target (e.g. mapframe1)
-    * Detailed metadatainformation for a GUI. Also information about the last requests as a link.
-    * Additional default GUIs are added to the Mapbender database.
-    * After installing Mapbender a set of worldwide WMS are already contained in several GUIs.
-    * Copy a GUI copyGUI / rename a GUI RenameGUI.
-    * AddWMS Add a new web map service dynamically by entering the URL to an OGC WMS Capabilities document. Current extent, layers and settings are not affected.
-    * Add WMS from list Dynamically add WMS from a list of all OGC WMS contained in the Mapbender database to the current GUI.
-    * Add WMS from filtered list Dynamically add WMS from a list (filtered by group or gui) to a GUI.
-    * setBackground Define several WMS to be displayed in the background.
-    * setBackground_all You can define one or more WMS to be displayed in the background.
-    * DeleteGUI Delete a selected GUI.
-    * DeleteWMS Delete a selected WMS.
-    * Edit GUI Elements - added: GUI description editable.
-    * Edit GUI WMS - added: show WMS ID.
-    * showCoords_div - shows the coordinate below the target (i.e. mapframe1).
-    * setScaleHint - set scale hints for mapframes.
-    * tabs_vertical - handle iframes with vertical tabs.
-    * WMS_preferences - edit service settings of the loaded WMS, change order, remove wms, change settings.
-deutsch
-    * Print Ab der Mapbender Version 2.1.0 erfolgt der Standardausdruck von Mapbender als PDF. Hierbei stehen A4 und A3 Druck zur Auswahl sowie Hoch- und Querformat. Der Kartenspiegel kann dabei über eine Konfigurationsdatei an das eigene Design angepaßt werden. Hierbei stehen A4 und A3 Druck zur Auswahl sowie Hoch- und Querformat.
-    * GUIOwner Der neue Parameter <owner> (Besitzer) wurde der Benutzerverwaltung hinzugefügt. Dies erlaubt eine Unterscheidung zwischen lesen/benutzen einer GUI und der Berechtigung die GUI zu ändern ( edit GUI elements). Dieses Feature ist notwendig als Vorbereitung Mapbender als Portal mit anonymem Zugang einzusetzen, was wiederum notwendig ist, um Wikimap-Funktionalität zu implementieren. Zusätzlich ermöglicht diese Einstellung den Aufbau einer hierarchischen Verwaltung.
-    * Overview Die Übersichtskarte sollte mit dem Modul Overview adressiert werden (<Overview0>, <Overview1>, <Overview2>, ... wurden eingestellt). Das Modul kann mit dem Feld "wms" parametriert werden. Es beinhaltet den Index des WMS, der nicht in der Übersichtskarte angezeigt werden sollte (beginnend bei 0).
-    * showCoords_div Bei Aktivierung dieses Buttons werden die Koordinaten der Mausposition unter dem Ziel (target = z.B. mapframe1) angezeigt.
-    * Detaillierte Metadatainformationen für eine GUI. Ebenso Information über die letzte Anfrage als Link.
-    * Zusätzliche Standard-GUIs wurden der Mapbender Datenbank hinzugefügt.
-    * Nach der Installation von Mapbender ist bereits ein Set von weltweiten WMSen in verschiedenen GUIs enthalten.
-    * Kopieren einer GUI copyGUI / Umbenennen einer GUI RenameGUI.
-    * AddWMS Dynamisches Hinzufügen eines neuen Web Map Services durch die Eingabe der URL in ein OGC WMS Capabilities Dokument. Der aktuelle Ausschnitt, Layer und Einstellungen sind davon nicht betroffen.
-    * Add WMS from list Dynamisches Hinzufügen eines WMS von einer Liste von allen OGC WMS, die in der Mapbender Datenbank enthalten sind für die aktuelle GUI.
-    * Add WMS from filtered list Dynamisches Hinzufügen eines WMS von einer Liste (gefiltert für eine Gruppe oder GUI) für eine GUI .
-    * setBackground Definiert einige WMS, die im Hintergrund angezeigt werden.
-    * setBackground_all Definieren Sie hier einen oder mehrere WMS, die im Hintergrund angezeigt werden.
-    * DeleteGUI Löschen einer ausgewählten GUI.
-    * DeleteWMS Löschen eines ausgewählten WMS.
-    * Oberflächenelemente editieren (Edit GUI Elements) - Hinzugefügt: GUI Beschreibung editierbar.
-    * WMS GUI Einstellungen (Edit GUI WMS/ WMS GUI settings) - Hinzugefügt: Anzeige der WMS ID.
-    * showCoords_div - Anzeige der Koordinaten unter dem Ziel (target, z.B. mapframe1).
-    * setScaleHint - Setzen eines Maßstabes für Kartenframes.
-    * tabs_vertical - Handhaben von Iframes mit vertikal Karteireitern.
-    * WMS_preferences - Bearbeiten der Einstellungen eines Dienstes eines geladenen WMS, Änderung der Reihenfolge, Entfernen eines WMS, Änderung der Einstellungen.
\ No newline at end of file
+The following Link gives a review on the changes in Mapbender you can get in the WIKI
+http://www.mapbender.org/index.php/Version_History
+Also have a look in the trac for detailed informations:
+http://trac.osgeo.org/mapbender/report/6
+Changelog 2.4.2
+  english
+    bug fixes: see http://trac.osgeo.org/mapbender/report/9
+    new features
+    * set WMS opacity in treeGDE2
+    * Bulgarian translation of the introduction to Mapbender
+    * improved module Add WMS from filtered list: loading a configured WMS from a GUI is now possible
+    * updated Meetingpoint / Treffpunkt: new image, some bugfixes
+    * improved exception handling / log levels (see mapbender.conf#Mapbender_error_logging)
+    * poi (not included in a GUI yet)
+    * JavaScript compression; Mapbender will load faster
+    * dynamic overview - integration in the rc1 an testing gui2
+    * treeGDE2 replaces treeGDE
+    * different configurations of treeGDE2
+    * first draft of an API documentation for JavaScript classes
+    * print temporary objects (lines and polygons) which where drawn with the measure element
+  deutsch
+    behobene Fehler: siehe http://trac.osgeo.org/mapbender/report/9
+    neue Features
+    * Einstellen der Deckkraft (Opacity) einzelner WMSe in der TreeGDE2
+    * Bulgarische Übersetzung der Mapbender-Einführung
+    * Verbesserung des Moduls Add WMS from filtered list: es ist nun möglich, konfigurierte WMSe aus GUIs zu laden
+    * Update des Moduls Meetingpoint / Treffpunkt: neue Bilddatei, diverse Fehler behoben
+    * Verbessertes Logging, auch von JavaScript Fehlern (siehe mapbender.conf#Mapbender_error_logging)
+    * poi (noch in keiner GUI enthalten)
+    * JavaScript Kompression; Mapbender lädt schneller
+    * Dynamisches Overview
+    * TreeGDE2 ersetzt die alte Baumstruktur
+    * verschiedene Konfigurationen der TreeGDE2 in den Standard-GUIs
+    * vorläufige API Dokumentation für JavaScript Klassen
+    * Druck von temporären Objekten (Linien und Polygone), die mit dem "measure" Element erstellt wurden
+Changelog 2.4.1
+english
+new features
+bug fixes
+    * 1658777 Export GUI SQL unsorted
+    * 1634035 Wfs geometry name not sorted by position
+    * 1647206 sort order of modules in gui element list
+    * 1635839 JS error: document.form1.newGuiName has no properties
+    * 1589764 wms loading problems when abstract contain linebreak
+    * 1653348 mod_filteredGroup_filteredGui.php
+    * 1653160 Metadata: Undefined variable: wms_id
+    * 3 Online resource incorrect in monitoring module
+    * 11 wrong sort order in edit_gui_wms
+database changes
+see latest database changes.
+deutsch
+Changelog Mapbender 2.4.1 rc1
+english
+    * changes in database architecture: For update have a look in the wiki at dbchanges or Database_Changes_2.4.1. The update sqls you find in the download package in the folder mapbender/resources/db/update/
+    * WFS_gazetteer possibility to handle several wfs_confs and choose from a select-box - thanx to User:Verena Diewald
+    * new treeGDE - thanx to User:Melchior Moos
+    * new element setPOI2Scale mod_setPoi2Scale to open a GUI at a special coordinate and scale - have a look Mod_setPoi2Scale
+    * extended ResizeMapsize functionality - Modul can act automatically or by button click. 3 element vars are added.
+    * new administration functionality OrphanWMS to find information about orphaned WMS and to fix them.
+    * new functionality meetingPoint to generate meeting points and export them as text or via email. The url can be displayed by highlightPOI
+    * pdf-Print now with Din-A2 support
+    * new element highlightPOI (mod_highlightPOI.php) to open a gui and set poi points with text
+    * metadata handling
+    * new admin guis
+    * wfs bug fix for digitize modul
+    * featureinfo tunnel closes empty result windows automatically
+deutsch
+    * Änderungen in der Datenbankarchitektur: Angaben im Wiki unter dbchanges oder Database_Changes_2.4.1. Die update-sqls befinden sich im Download-Paket im Verzeicnis mapbender/resources/db/update/
+    * WFS_gazetteer Auswahlmöglichkeit zwischen mehreren WFS-Konfigurationenüber eine Auswahlliste - thanx to User:Verena Diewald
+    * treeGDE - neue Baumstruktur - thanx to User:Melchior Moos
+    * Neues Modul add_vendorspecific.
+    * Neues Element setPOI2Scale um eine GUI an einen Punkt in einem bestimmten Maßstab zu öffnen Mod_setPoi2Scale.
+    * Erweiterung des Moduls resizeMapsize. Kartenfenster kann sich automatisch an die Browsergröße anpasssen oder über einen Button. 3 Element vars wurden hinzugefügt.
+    * Neues Administrationselement OrphanWMS, dass informationen über verwaiste WMS liefert und diese löschen kann.
+    * Neues Element meetingPoint um Treffpunkte zu generieren und diese als Text oder via E-Mail zu exportieren. Die URL kann durch highlightPOI angezeigt werden.
+    * pdf-Print nun auch mit Din-A2 Unterstützung (Dank an Frank Härtel und Horst Becker).
+    * Neues Element highlightPOI (mod_highlightPOI.php) ermöglicht es beim Öffnen einer GUI ein oder mehrere Punkte mit Beschriftung zu setzen.
+    * Metadaten handling.
+    * Featureinfotunnel schließt leere Fenster ohne Ergebnis gleich wieder.
+english
+    * bugs in loadWMC are fixed
+    * new module resizeMapsize to resize the Mapsize depending on the size of the browser window
+    * new module monitorCapabilities: periodically checks all WMS and gathers data in the new table mb_monitor (see Database_Changes_2.4)
+    * new module initWMC: starts the client with a wmc.
+    * wms_extent - WMS representing the EXTENTs of the WMS loaded in Mapbender
+deutsch
+    * Bugs im Modul loadWMC wurden behoben.
+    * Neues Modul resizeMapsize das Modul paßt die Kartengröße in Abhängigkeit von der Größe des Browserfensters dynamisch an.
+    * Neues Modul monitorCapabilities: periodisch werden alle WMSe kontrolliert und alle Daten in der neuen Tabelle mn_monitor erfaßt (siehe auch Database_Changes_2.4).
+    * Neues Modul initWMC: startet den Client mit einem WMS.
+    * wms_extent - WMS, der die Ausdehnungen (Extent) der in Mapbender geladenen WMSe anzeigt.
+Changelog 2.4 rc2
+english
+    * mapbender changed to Subversion (svn), big effort is done in code cleaning
+    * owsproxy is implemented
+    * treeGDE improved, now there is the possibility to handle the layers of a wms with one click (all layer on / all layer off). new element var switchwms
+    * bugs in legend solved
+    * changes in database architecture: new table wfs_featuretype_namespace, new column wms_owsproxy in table wms, new column wms_upload_url in table wms. For update have a look at dbchanges or Database Changes 2.4
+    * perpared statements for PHP > 5.1.x, PostgreSQL > 7.4
+    * new gui_digitize in the installation package. Read more about Digitizing
+    * new gui2 in the installation package with new buttons (button_blue), new tree-style (tree_blue) and more color.
+    * default md5-encryption for the passwords in MySQL and PostgreSQL. Mapbender is doing the md5-encryption.
+    * extended mapbender_setup.php with more information (Thanks to Marko Samson)
+    * new element deleteWFS in GUI admin1
+    * printPDF: highquality print and matching for the overview image
+    * new help: every element in the gui refers to a page in the Mapbender wiki. The link is saved in the table gui_element column e_url and can be changed individual.
+deutsch
+    * Mapbender wechselt zum Subversion (svn) mit dem damit verbundenen Code cleaning
+    * owsproxy
+    * treeGDE wurde verbessert, es gibt nun die Möglichkeit alle Layer eines WMS durch einen Klick an- bzw. auszustellen.
+    * Bugs in der Legende behoben
+    * Veränderungen in der Datenbankarchitektur: neue Tabelle wfs_featuretype_namespace, neue Spalte wms_owsproxy in Tabelle wms, neue Spalte wms_upload_url in Tabelle wms. Um eine bestehende Datenbank zu aktualisieren, gibt es unter dbchanges weitere Informationen. Database Changes 2.4
+    * Es besteht die Möglichkeit Perpared Statements ab PHP > 5.1.x, PostgreSQL > 7.4 einzusetzen
+    * Neue gui_digitize im Installationsumfang. Mehr unter Digitizing
+    * Neue gui2 im Installationsumfang mit neuen Buttons (button_blue), neuem Style für die Baumstruktur (tree_blue) und mehr Farbe
+    * Standardmäßige md5-Verschlüsselung des Passworts in MySQL und PostgreSQL. Mapbender verschlüsselt nun das Passwort, nicht die Datenbank.
+    * mapbender_setup.php liefert nun mehr Informationen und weist auf Fehler hin (Danke an Marko Samson)
+    * Neues Element deleteWFS in der GUI admin1
+    * printPDF: für den Overview ist nun auch der hochqualitative Druck und das Matching möglich
+    * Hilfebutton: jedes Element der GUI ist direkt mit der Hilfeseite im Mapbender Wiki verlinkt (Eintrag in der Tabelle gui_element Spalte e_url). Dieser Link kann an die jeweilige Umgebung angepaßt werden.
+Changelog 2.2.3
+english
+    * print: now with overview window with position rectangle and scalebar
+    * gui_de and gui1_de are no longer part of the standard installation of mapbender, as it is too much work to handle 4 guis. If you want a german gui, you have to change the tool tip texts. In the next versions we want to handle the language differences with element vars.
+    * WMC handling: includes DisplayWMC, loadWMC, saveWMC and listWMC.
+    * element logout: now with element_var logout_location to define the webside to show after logout
+    * the overview window of the pdf-print is now displayed in highquality, if you use highquality = true in your print-configuration
+    * there has been some rework done at the AddWMS functions. Now the mod_addWMSgeneralFunctions.js offers the functions mod_addWMS_load and mod_addWMS_refresh to the elements addWMSfromfilteredList and addWMSfromList IMPORTANT: JS has to be added as modul in the element-definition
+    * element tabs (mod_tab.php) now with element_var open_tab to decide which tab should be opened at the beginning
+    * print : there where errors in the generation of the legend especially with grouped layers
+    * legend : new element_var checkbox_on_off to decide wether you want to show or hide the on/off checkbox - there where errors in the generation of the legend especially with grouped layers
+    * legend: new element var : stickylegend to decide wether the legend should stick at the mapframe1
+    * connection to GEOS function for mysql users: mapbender.conf / mod_changeEPSG.php / mod_evalArea.php - database parameters where added to the mapbender.conf to enable Mapbender user with mysql-Administration to transform and change the projection
+    * encoding of Mapbender: now UTF-8 or ISO-8859-1 can be choosed as the encoding for the database (have a look in the mapbender.conf CHARSET)
+    * fixed: WFS configuration caused errors with postgresql database
+    * copyright now works with element var for the copyright text: define the JavaScript Variable mod_copyright_text with a text you want as value
+    * fixed: there was an error in class_log, now the printed maprequests should be logged
+    * database changes
+deutsch
+    * print: nun mit Übersichtsfenster mit Positionsrechteck und Maßstabsleiste (beide Funktionalitäten können in der Konfigurationsdatei des Drucks an- oder ausgestellt werden)
+    * Die Oberflächen gui1_de und gui_de werden nicht mehr weitergeführt, da es zu viel Aufwand darstellt 4 Oberflächen weiterzuführen. Wenn eine deutsche Oberfläche gebraucht wird können die ToolTipTexte auf deutsch angelegt werden. Die Mehrsprachigkeit der einzelnen Elemente soll zukünftig über die Element vars gelöst werden.
+    * WMC-Nutzung: beinhaltet anzeigen (DisplayWMC), laden (loadWMC), speichern (saveWMC) eines WMCs und auflisten aller WMCs (listWMC).
+    * Element logout: verfügt nun über den element_var logout_location, um zu definieren welche Webseite nach dem Logout angezeigt werden soll.
+    * Das Ãœbersichtsfenster des PDF-Drucks wird nun auch hochqualitativ angezeigt bei hochqualitativem Druck.
+    * Die AddWMS Funktionalität wurde überarbeitet. Eine neue Datei mod_addWMSgeneralFunctions.js stellt nun die Funktionen mod_addWMS_load und mod_addWMS_refresh zur Verfügung. Wichtig für die Elemente addWMSfromfilteredList and addWMSfromList das JavaScript mod_addWMSgeneralFunctions.js muß in der Elementdefinition unter Modul angegeben werden.
+    * Element tabs (mod_tab.php) wurde um die element_var open_tab erweitert, um beim Start des Clients einen tab voreingestellt zu öffnen.
+    * print: Fehler in der Legende bei gruppierten Ebenen beseitigt.
+    * legend: Neue element_var: checkbox_on_off zur Steuerung der on/off checkbox.
+    * legend: Neue element_var: stickylegend zur Steuerung des Anzeigefesters der Legende (Positionierung / sticky-Frame).
+    * Bereitstellung der GEOS Funktionen für Mapbender mit mysql-Administrationsdatenbank: mapbender.conf / mod_changeEPSG.php / mod_evalArea.php - Zusätzliche Datenbankparameter für eine PostgresDB neben der mysql-Administrationsdatenbank, zur Transformation von Projektionssystemen und Berechnung von Flächen.
+    * Encoding (Zeichensatz) in Mapbender: es besteht nun die Auswahl zwischen UTF-8 oder ISO-8859-1 als Zeichensatz (die Angabe erfolgt in der mapbender.conf CHARSET)
+    * wfs configuration: WFS Konfiguration erzeugte Fehler mit der PostgreSQL-Datenbank.
+    * copyright: Neue element_var mod_copyright_text, Angabe zum Copyright-Text über die Administrationsoberfläche.
+    * fixed: Fehler in class_log behoben.
+    * Datenbankänderungen
+Changelog 2.2.2
+english
+    * Unfortunately there was a bug left in the PostgreSQL database-module. In the edit gui-menu no templates from other guis were shown so that it was impossible to modify guis.
+To fix this, minor changes in the PostgreSQL database-structure were necessary. If you are updating, please do not use an already existing V. 2.2.1-database and create the database with the SQL-dumps attached to this version instead.
+deutsch
+    * Leider war noch ein Fehler im PostgreSQL Datenbank-Modul übersehen worden. Da im Menü Oberflächenelemente editieren die bestehenden GUIs und deren Elemente nicht angezeigt wurden, um sie als Templates zu verwenden, ließen sich die GUIs nicht nach den eigenen Bedürfnissen anpassen.
+Um diesen Fehler zu beheben wurden kleinere Änderungen in der PostgreSQL Datenbank-Struktur vorgenommen. Bitte verwenden Sie daher keine bereits existierende V. 2.2.1-Datenbank falls Sie updaten, sondern benutzen Sie bitte die SQL-Dumps, die dieser Version beigefügt sind.
+Changelog 2.2.1
+english
+We have been a bit quick with the release 2.2 and didn't put the focus on documentation and debugging. But with the help of the users of Mapbender we fixed the bugs and now there is the next Mapbender version for download.
+    * There where some bugs when you run Mapbender with PostgreSQL. Hope they are fixed. Have a look at the Installation to find out about how to configure Mapbender (configuration files have been consolidated into ./conf/mapbender.conf)
+    * the name of two columns had to be changed:
+          o mb_log.session changes to mb_log.mb_session (session is a reserved name in postgresql)
+          o gui_element.e_closeTag changed to gui_element.e_closetag (all table- and columnnames are handled in lower case)
+    * Sequences in PostgreSQL: if you use postgresql you have to set sequences for the serial columns so that the next value for the serial is fixed. user mapbender/resources/db/pgsql_serial_set_sequences.sql to set the sequences
+    * changeEPSG and calculating areas at the moment is only possible for user with PostgreSQL/PostGIS database
+deutsch
+Vielleicht waren wir etwas voreilig mit dem Mapbender Release 2.2 und haben den Fokus nicht auf die Dokumentation und das Debuggig gesetzt. Aber mit Hilfe der User sind viele Fehler aufgezeigt worden und konnten gelöst werden. Hier nun der neue Mapbender 2.2.1. Derzeit gibt es noch keine Dokumentation und auch kein Skript für den automatisierten Update einer bestehenden Mapbender Installation. Die vormals eingesetzen Skripte mapbender_setup.php und validate_db.php können derzeit nicht mehr verwendet werden und wurden aus dem Paket entfernt. Die Skripte müssen erst wieder auf den neuen Release angepaßt werden, damit sie wieder zum Einsatz kommen können.
+    * es lagen einige Bugs bei der Verwendung von PostgreSQL als Administrationsdatenbank vor. Diese sind hoffentlich alle beseitigt. In der Installationsanleitung unter
+mapbender.conf findet sich alles wichtige zur Installation (Alles ist nun einfacher. Es muß nur noch die Datei mapbender.conf angepaßt werden)
+    * der Name zweier Spalten hat sich geändert:
+          o mb_log.session geändert in mb_log.mb_session (session reserviertes Wort in PostgreSQL)
+          o gui_element.e_closeTag geändert in gui_element.e_closetag (alle Tabellen- und Spaltennamen in Kleinbuchstaben)
+    * Sequences in PostgreSQL: bei der Verwendung von PostgreSQL müssen die Sequenzen der Autowerte nach dem Laden der Daten explizit gesetzt werden. Dazu steht die Datei mapbender/resources/db/pgsql_serial_set_sequences.sql zur Verfügung
+    * changeEPSG und Flächenberechnung steht derzeit nur Benutzern mit einer PostgreSQL-Datenbank zur Verfügung
+Changelog 2.2.0
+[edit]
+english
+Here you find a list with the changes in Mapbender 2.2.0:
+    * The configuration files have been consolidated into one single mapbender.conf
+    * Now Mapbender 2.2.0 is able to work with MySQL- or PostgreSQL-database. Configure the settings in the mapbender.conf.
+    * You can edit the single elements of a GUI with the Mapbender-Administration (table element_vars/ css-files/ var).
+    * WFS
+    * Proxy
+    * PrintPDF. This module enables you to configure the PrintPDF containing an overview, legend, northarrow and your logo.
+    * Click on a Layer refers to the WMS METADATAURL - new column layer_metadataurl.
+    * The legend is displayed by the LEGENDURL.
+    * New Wiki: To edit the new wiki you have to ask for an account at mailto:info at mapbender.org.
+    * ToggleModule to define a function to be active when the gui is opened
+Here you already find a list with the changes in Mapbender 2.2:
+    * Mapbender for MySQL or PostgreSQL
+    * click on a Layer refers to the WMS METADATAURLD - new column layer_metadataurl
+    * the legend is displayed by the LEGENDURL
+deutsch
+Hier die Änderungen, die mit der Version 2.2 erfolgt sind:
+    * Nun ist es möglich Mapbender mit einer MySQL- oder PostgreSQL-Datenbank zu installieren. Konfigurieren Sie die Einstellungen in der Datei mapbender.conf.
+    * Sie können die einzelnen Elemente einer GUI mit der Mapbender-Administration editieren (Tabelle element_vars/ css-files/ var).
+    * WFS
+    * Proxy
+    * PrintPDF. Dieses Modul erlaubt es dem Benutzer den PrintPDF zu konfigurieren und beinhaltet Overview, Legende, Nordpfeil und ein Logo.
+    * Neue Buttons (button_oo) sind in der GUI 'gui' verfügbar.
+    * Ein Klick auf einen Layer referenziert die WMS METADATAURL - neue Spalte layer_metadataurl.
+    * Die Legende wird durch die LEGENDURL dargestellt.
+    * Neues Wiki: Um im neuen Wiki editieren zu können, müssen Sie einen Account beantragen bei CCGIS.
+    * ToggleModule - definiert ein Element, das beim Start der GUI aktiviert sein soll
+Hier aber schonmal die Änderungen, die uns mit der Version 2.2 erwarten:
+    * Mapbender für MySQL oder PostgreSQL
+    * Anpassung der einzelnen Elemente einer GUI über die Mapbender-Administration (element_vars)
+    * Metadataurl
+    * Legendurl
+Changelog 2.1.0
+english
+    * communication by email mail.conf
+    * new button myGUIlist in the administration-guis to go back to the list of myGUIs
+    * New table mb_log
+    * New column in table wms wms_getCapabilities_doc
+    * ChangeEpsg_dynamic
+    * Edit gui shows the images of a gui as little pictures (better orientation)
+    * sql to update the mapbender standard guis Update Mapbender
+    * mapbender/http/tools/validate_db.php - php to update the database and add new columns and tables if necessary
+    * New column layer_dataurl in table layer
+    * New columns legendurl and legendurlformat in table layer_style
+    * New table wms_srs
+    * Security update in Edit GUI Elements
+deutsch
+    * Kommunikation über email mail.conf
+    * Neuer Button myGUIlist für die Administrations-GUIs, um in die Liste von meinenGUIs zurück zu kommen.
+    * Neue Tabelle mb_log
+    * Neue Spalte in der Tabelle wms wms_getCapabilities_doc
+    * Die Rubrik 'Oberflächenelemente editieren' zeigt nun kleine Bilder der Oberfläche zur besseren Orientierung.
+    * SQL zur Aktualisierung Ihrer GUIs: siehe Update Mapbender
+    * mapbender/http/tools/validate_db.php - PHP, um die Datenbank zu aktualisieren und wenn nötig neue Spalten und Tabellen hinzuzufügen.
+    * Neue Spalte layer_dataurl in der Tabelle layer hinzugefügt.
+    * Neue Spalten 'legendurl' und 'legendurlformat' in der Tabelle layer_style hinzugefügt.
+    * Neue Tabelle wms_srs
+Changelog 2.1.0 rc1
+english
+    * Print with Mapbender Version 2.1.0 pdf-print is used as standard. You have the possibility to choose A4 or A3 and landscape or portrait. The printframe can be styled to your own design by editing a configuration file.
+    * GUIOwner a new parameter <owner> has been added to the user management. This allows a distinction between reading/using a GUI and being allowed to change it ( edit GUI elements). This feature is necessary as a preliminary step to open Mapbender as a portal with anonymous access which is needed to implement Wikimaps functionality. Additionally this enables setting up a hierarchical administration.
+    * Overview The overview map should be addressed with the module Overview, (<Overview0>, <Overview1>, <Overview2>, ... are deprecated). The module can be parameterized with the field "wms". It contains the index of the WMS which should be displayed in the overview map. (starting at 0).
+    * showCoords_div On button click the coordinate of the mouseposition will be displayed below the target (e.g. mapframe1)
+    * Detailed metadatainformation for a GUI. Also information about the last requests as a link.
+    * Additional default GUIs are added to the Mapbender database.
+    * After installing Mapbender a set of worldwide WMS are already contained in several GUIs.
+    * Copy a GUI copyGUI / rename a GUI RenameGUI.
+    * AddWMS Add a new web map service dynamically by entering the URL to an OGC WMS Capabilities document. Current extent, layers and settings are not affected.
+    * Add WMS from list Dynamically add WMS from a list of all OGC WMS contained in the Mapbender database to the current GUI.
+    * Add WMS from filtered list Dynamically add WMS from a list (filtered by group or gui) to a GUI.
+    * setBackground Define several WMS to be displayed in the background.
+    * setBackground_all You can define one or more WMS to be displayed in the background.
+    * DeleteGUI Delete a selected GUI.
+    * DeleteWMS Delete a selected WMS.
+    * Edit GUI Elements - added: GUI description editable.
+    * Edit GUI WMS - added: show WMS ID.
+    * showCoords_div - shows the coordinate below the target (i.e. mapframe1).
+    * setScaleHint - set scale hints for mapframes.
+    * tabs_vertical - handle iframes with vertical tabs.
+    * WMS_preferences - edit service settings of the loaded WMS, change order, remove wms, change settings.
+deutsch
+    * Print Ab der Mapbender Version 2.1.0 erfolgt der Standardausdruck von Mapbender als PDF. Hierbei stehen A4 und A3 Druck zur Auswahl sowie Hoch- und Querformat. Der Kartenspiegel kann dabei über eine Konfigurationsdatei an das eigene Design angepaßt werden. Hierbei stehen A4 und A3 Druck zur Auswahl sowie Hoch- und Querformat.
+    * GUIOwner Der neue Parameter <owner> (Besitzer) wurde der Benutzerverwaltung hinzugefügt. Dies erlaubt eine Unterscheidung zwischen lesen/benutzen einer GUI und der Berechtigung die GUI zu ändern ( edit GUI elements). Dieses Feature ist notwendig als Vorbereitung Mapbender als Portal mit anonymem Zugang einzusetzen, was wiederum notwendig ist, um Wikimap-Funktionalität zu implementieren. Zusätzlich ermöglicht diese Einstellung den Aufbau einer hierarchischen Verwaltung.
+    * Overview Die Ãœbersichtskarte sollte mit dem Modul Overview adressiert werden (<Overview0>, <Overview1>, <Overview2>, ... wurden eingestellt). Das Modul kann mit dem Feld "wms" parametriert werden. Es beinhaltet den Index des WMS, der nicht in der Ãœbersichtskarte angezeigt werden sollte (beginnend bei 0).
+    * showCoords_div Bei Aktivierung dieses Buttons werden die Koordinaten der Mausposition unter dem Ziel (target = z.B. mapframe1) angezeigt.
+    * Detaillierte Metadatainformationen für eine GUI. Ebenso Information über die letzte Anfrage als Link.
+    * Zusätzliche Standard-GUIs wurden der Mapbender Datenbank hinzugefügt.
+    * Nach der Installation von Mapbender ist bereits ein Set von weltweiten WMSen in verschiedenen GUIs enthalten.
+    * Kopieren einer GUI copyGUI / Umbenennen einer GUI RenameGUI.
+    * AddWMS Dynamisches Hinzufügen eines neuen Web Map Services durch die Eingabe der URL in ein OGC WMS Capabilities Dokument. Der aktuelle Ausschnitt, Layer und Einstellungen sind davon nicht betroffen.
+    * Add WMS from list Dynamisches Hinzufügen eines WMS von einer Liste von allen OGC WMS, die in der Mapbender Datenbank enthalten sind für die aktuelle GUI.
+    * Add WMS from filtered list Dynamisches Hinzufügen eines WMS von einer Liste (gefiltert für eine Gruppe oder GUI) für eine GUI .
+    * setBackground Definiert einige WMS, die im Hintergrund angezeigt werden.
+    * setBackground_all Definieren Sie hier einen oder mehrere WMS, die im Hintergrund angezeigt werden.
+    * DeleteGUI Löschen einer ausgewählten GUI.
+    * DeleteWMS Löschen eines ausgewählten WMS.
+    * Oberflächenelemente editieren (Edit GUI Elements) - Hinzugefügt: GUI Beschreibung editierbar.
+    * WMS GUI Einstellungen (Edit GUI WMS/ WMS GUI settings) - Hinzugefügt: Anzeige der WMS ID.
+    * showCoords_div - Anzeige der Koordinaten unter dem Ziel (target, z.B. mapframe1).
+    * setScaleHint - Setzen eines Maßstabes für Kartenframes.
+    * tabs_vertical - Handhaben von Iframes mit vertikal Karteireitern.
+    * WMS_preferences - Bearbeiten der Einstellungen eines Dienstes eines geladenen WMS, Änderung der Reihenfolge, Entfernen eines WMS, Änderung der Einstellungen.
More information about the Mapbender_commits mailing list
