[Mapbender-commits] r3028 - branches/2.5
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Sep 29 05:52:47 EDT 2008
Author: astrid_emde
Date: 2008-09-29 05:52:47 -0400 (Mon, 29 Sep 2008)
New Revision: 3028
   branches/2.5/Changes.txt
changelog till 2.5 added
Modified: branches/2.5/Changes.txt
--- branches/2.5/Changes.txt	2008-09-29 09:41:26 UTC (rev 3027)
+++ branches/2.5/Changes.txt	2008-09-29 09:52:47 UTC (rev 3028)
@@ -6,7 +6,175 @@
 http://trac.osgeo.org/mapbender/report/6
+Changelog 2.5
+#264  	ISO dump contains UTF characters  	closed  	09/29/08
+#298 	remove content in gui_treegde 	closed 	09/29/08
+#288 	gazetteerWFS wfs_conf rights are not handled properly 	closed 	09/29/08
+#282 	DB - Create schema: wrong column name wms_mb_get_capabilities_doc in table wms 	closed 	09/29/08
+#301 	WFS Gazetteer: Sort wfs conf selectbox in order of wfsConfIdString 	closed 	09/26/08
+#31 	move mb_wfs_tolerance to conf file 	closed 	09/25/08
+#300 	PrintPDF: Error if overview image is false 	closed 	09/25/08
+#87 	enable owsproxy to handle wms layer legends 	closed 	09/25/08
+#269 	printPDF: owsproxy and wms - test wether all is working 	closed 	09/25/08
+#299 	MeetingPoint: Insert of Umlaute or Zeilenumbruch is not possible 	closed 	09/24/08
+#297 	featureInfo1 does not work anymore 	closed 	09/18/08
+#286 	SetSpatialRequest 	closed 	09/17/08
+#294 	mod_changePassword.php 	closed 	09/15/08
+#293 	New modul: ShowGuiName 	closed 	09/10/08
+#222 	WFS digitizing failed when using GeoServer 1.6.2 due to missing links in xsi:schemaLocation 	closed 	09/01/08
+#284 	wfsGazetteer - no search result if a geometry field is empty 	closed 	08/29/08
+#285 	PrintPDF: Error in Print using dynamicOverview 	closed 	08/28/08
+#283 	FeatureInfo: Popup divs should not be shown if featureInfo is empty 	closed 	08/28/08
+#280 	prepared statement error occurred at WFS Configuration 	closed 	08/25/08
+#281 	WFS conf: after saving the new configuration the featureType table disappears 	closed 	08/25/08
+#258 	MySQL test for version 2.5 	closed 	08/15/08
+#276 	PrintPDF: Last Measure-Item gets lost if its not a closed Polygon 	closed 	08/15/08
+#277 	WFS update does not cascade changes to wfs_conf 	closed 	08/15/08
+#273 	update GUI SQL doesn't delete element vars? 	closed 	08/15/08
+#268 	Bug in module Meeting Point MB 2.5 rc5: missing target 	closed 	08/15/08
+#179 	treeConfGDE - admin 	closed 	08/15/08
+#261 	WFS and MySQL doesn't work 	closed 	08/12/08
+#265 	print pdf with locale set to de_DE: encoding problems 	closed 	08/12/08
+#183 	printPDF, no link for downloading, no maps 	closed 	08/11/08
+#263 	Error when highlighting digitized objects 	closed 	08/11/08
+#259 	mod_tabs does'nt display characters from element_var 'tab_prefix' 	closed 	08/11/08
+#260 	Setting language with initial request parameter mb_lang fails 	closed 	08/11/08
+#266 	login.php - white screen after 3 times failed login 	closed 	08/06/08
+#121 	Login fails with https protocol 	closed 	08/05/08
+#262 	setlocale with param LC_ALL converts corrupts numerics 	closed 	08/04/08
+#230 	Mapbender /db/update/update_postgresql_db.sql 	closed 	07/28/08
+#154 	i18n and MySQL: a db function has to be written 	closed 	07/25/08
+#205 	selecting print-format changes mapscale 	closed 	07/23/08
+#151 	edit WFS Configuration: set the dialog in alphabetical order 	closed 	07/21/08
+#237 	FeatureInfo: popup title does not appear and the popup-window can´t be moved (IE7) 	closed 	07/21/08
+#256 	setSpatialRequest: 4326 is static epsg code 	closed 	07/21/08
+#226 	Digitize: spatial request show data from layers without selected FeatureInfo 	closed 	07/21/08
+#223 	logging in mb25 	closed 	07/21/08
+#255 	wfs conf: field f_show_detail missing in module wfs configuration 	closed 	07/21/08
+#234 	Adding new WMS does not work 	closed 	07/21/08
+#213 	wms gui settings: changes are not accepted 	closed 	07/21/08
+#238 	Cannot change password in mod_editUser 	closed 	07/21/08
+#210 	"Umlauts" broken, when loading a WMS 	closed 	07/16/08
+#250 	Gui element Module AddWMS needs mod_addWMSgeneralFunctions.js as Module param 	closed 	07/11/08
+#214 	module tabs does not show tabs 	closed 	07/11/08
+#180 	WFS Configuration 	closed 	07/11/08
+#254 	Gettext broken 	closed 	07/08/08
+#198 	jquery in main frame instead of separate ajax module 	closed 	07/08/08
+#233 	test if gettext .po compilation is necessary on new installation 	closed 	07/08/08
+#249 	Measure: No measure lines drawn after upsizing mapframe width and height 	closed 	07/01/08
+#248 	AddWMSfromList + AddWMSfromFilteredList don't use OWSPROXY when loading WMS 	closed 	06/30/08
+#241 	Query WMS does not work if no layers are selected as "info_default" 	closed 	06/17/08
+#240 	"the_geom" hard wired in class_gml2.php 	closed 	06/10/08
+#239 	JSON encoding faulty (using PEAR library) 	closed 	06/09/08
+#235 	popup.js - error: every popup gets ID 150 	closed 	06/05/08
+#212 	capabilities-upload does not work 	closed 	06/04/08
+#204 	added same wms twice into a gui 	closed 	05/19/08
+#221 	setSpatialRequest did not form correct getFeature-Request, in some cases & was missing 	closed 	05/16/08
+#218 	PEAR JSON not functional, native JSON works 	closed 	05/07/08
+#217 	Application w/ digitizing module won't load in IE 	closed 	05/07/08
+#157 	transfer dbchanges wiki site to update SQL in SVN 	closed 	05/01/08
+#130 	monitoring checks if a reachable WMS returns images or error msgs 	closed 	05/01/08
+#216 	WMS Metadata metadataurl included, minscale, maxscale presentation changed 	closed 	05/01/08
+#215 	gazetteerMetadata does not work as script mod_gazetteerMetadata_search.php moved to /php 	closed 	05/01/08
+#201 	load WMC fails / WMC does not contain layer data 	closed 	04/18/08
+#161 	Remove GUI element "geometry" from all GUIs 	closed 	04/15/08
+#192 	geoportal.con must be removed 	closed 	04/15/08
+#185 	WMC 	closed 	04/15/08
+#206 	Resize mapframe1 before loading WMS maps 	closed 	04/08/08
+#197 	LOAD myWMS doesn't copy gui_layer_wfs_featuretype and gui_layer_style 	closed 	04/07/08
+#181 	personally uploaded WMS services do not appear in list "Add to GUI" 	closed 	03/19/08
+#194 	a fisheye style menubar 	closed 	03/14/08
+#141 	move mb_feature_count from map.js to conf file 	closed 	03/06/08
+#170 	move LOG_LEVEL_LIST to system.php 	closed 	03/06/08
+#155 	hard wired version number (php file) 	closed 	03/06/08
+#184 	Module measure (gui1) 	closed 	03/06/08
+#1 	    Initialize GUI with WMC error 	closed 	03/06/08
+#188 	New Button to export the Mapimage to png, jpeg or geotiff 	closed 	03/06/08
+#122 	SLD creation from scratch 	closed 	03/06/08
+#182 	Delete GUI 	closed 	03/06/08
+#91 	wfs_conf: delete WZ-Graphics-checkbox 	closed 	03/06/08
+#44 	SLD Integration 	closed 	03/06/08
+#173 	Digitize GUI broken on wheregroup/mapbender_dev 	closed 	02/18/08
+#126 	overview incorrect after load WMC 	closed 	02/02/08
+#128 	store ScaleHints in WMC 	closed 	02/02/08
+#10 	MySql Error (near: version=''1.'' encoding=) 	closed 	02/02/08
+#8 	    prepared statements w/ MB 2.4, PGIS 8.1.x and php5.2.x 	closed 	02/02/08
+#71 	mod_help for modules in tabs 	closed 	01/28/08
+#86 	Mapbender - logging the MapRequests from the guis in the table mb_log 	closed 	01/28/08
+#163 	WFS transaction: describefeaturetype-request is missing in xsi:schemaLocation 	closed 	01/24/08
+#169 	IE: WFS conf select box in WFS gazetteer defect 	closed 	01/24/08
+#132 	treegde2: wms opacity is lowered to 0 (fully transparent) 	closed 	01/21/08
+#55 	reloadTree() opens and closes the wms folder 	closed 	01/21/08
+#89 	Add admin_services_* to default interfaces for self created portal users 	closed 	01/18/08
+#164 	New module 'reload' 	closed 	01/17/08
+#152 	remove Ajax module from all GUIs 	closed 	01/17/08
+#158 	include and require with dirname when using relative paths 	closed 	01/15/08
+#96 	Add WFS Update 	closed 	01/14/08
+#97 	Support for Sublayers (grouped layers) 	closed 	01/14/08
+#160 	Encoding error for ISO docsuments in UTF8 database 	closed 	01/14/08
+#159 	By WFS-T Insert (Digitizing) GeoServer version >= 1.5.4 needs only used namespaces 	closed 	01/14/08
+#113 	Integrate jquery in Mainframe / json as a jquery plugin 	closed 	01/11/08
+#134 	the same javascript may be loaded twice in map.php 	closed 	12/21/07
+#142 	Mapbender setup to check error logging 	closed 	11/23/07
+#135 	internationalisation: tabs module 	closed 	11/08/07
+#103 	faulty regular expression 	closed 	10/05/07
+#98 	Popup windows as div-layer 	closed 	09/26/07
+#39 	reverse order of wms in treegde2 	closed 	09/26/07
+#100 	error in table name of insert statements for translations 	closed 	09/19/07
+Changelog 2.4.5
+#191  	missing column layer_md_topic_category in dump for 2.4.5  	closed  	04/15/08
+#202 	problem w/ z-Index in map layers 	closed 	03/19/08
+#200 	featureInfo is checked after load WMC 	closed 	03/19/08
+#195 	Remote Command Execution in Mapbender 	closed 	03/13/08
+#196 	SQL-Injections in Mapbender 	closed 	03/13/08
+#193 	remove element filteredWms_layer_topic from admin guis 	closed 	03/08/08
+#190 	bug in wz_jsGraphics 	closed 	03/06/08
+#189 	logging set to "off" by default 	closed 	03/06/08
+#168 	new database-field 'e_title' not in 'update_postgresql_db.sql' 	closed 	03/06/08
+#129 	mixed up wfs_conf_ids 	closed 	02/18/08
+#165 	mb_execloadwmcSubFunctions not found 	closed 	02/18/08
+#162 	WMS upload fails 	closed 	02/18/08
+#176 	WFS-T write failed 	closed 	02/18/08
+#177 	Update WMS has to display only the WMS that the user owns 	closed 	02/14/08
+#119 	wfs selection in IE 6.0, IE 7 not working using multiple wfs id's 	closed 	02/02/08
+Changelog 2.4.4
+#137  	measure dont work with more then 20 wms  	closed  	04/17/08
+#148 	Save WMC doesn't work 	closed 	12/21/07
+#150 	Zoom to feature: Buffer is NaN 	closed 	12/21/07
+#145 	Spatial request: coords is not defined 	closed 	12/21/07
+#149 	incorrect wfs_describefeaturetype 	closed 	12/21/07
+#147 	dependentDiv element_vars to define the position 	closed 	12/18/07
+#116 	Buffer from WFS conf not used in WFS gazetteer 	closed 	11/30/07
+#123 	Parsing WMS Capabilities Doc with duplicate SRS entries fails 	closed 	11/30/07
+#124 	group rights after copying a gui 	closed 	11/30/07
+#115 	Saving digitized geometries: Integer field always mandatory? 	closed 	11/30/07
+#139 	geom2wfst.php: error message with "new line" command corrupts JS 	closed 	11/30/07
+#77 	mod_digitize : namespace xmlns:xmlns makes no sense in wfs:transaction 	closed 	11/30/07
+#92 	wfs digitize namespace Problems 	closed 	11/30/07
+#140 	in log file, it is not clear whether the entry is an error, a warning, or a notice 	closed 	11/30/07
+Changelog 2.4.3
+#133  	weird behaviour when using left and right key  	closed  	10/31/07
+#108 	Invalid constant declaration in saveWKT 	closed 	10/02/07
+#102 	new jQuery version available 	closed 	09/21/07
+#53 	WMS - wms_format..data_format column not long enough 	closed 	09/21/07
+#80 	Headers in wfs_conf are not displayed 	closed 	09/21/07
+#95 	load a WMC from a file 	closed 	09/20/07
+#66 	layer transparency in IE 	closed 	09/20/07
+#79 	gui_digitize will not load properly 	closed 	09/20/07
+#94 	opaque map images shown incorrectly in IE, worked in older versions 	closed 	09/20/07
+#78 	createImagefromText in wfs/wms conf failed 	closed 	09/20/07
+#99 	Zoombox is hidden behind wms map images 	closed 	09/20/07
 Changelog 2.4.2
   english
More information about the Mapbender_commits mailing list
