[Mapbender-commits] r3043 - branches/spsneo_dev/build
svn_mapbender at osgeo.org
Mon Sep 29 10:42:34 EDT 2008
Author: christoph
Date: 2008-09-29 10:42:34 -0400 (Mon, 29 Sep 2008)
New Revision: 3043
branches/spsneo_dev/build/build-checksum.php
added "http/tmp" to $dir_not_to_scan
Modified: branches/spsneo_dev/build/build-checksum.php
--- branches/spsneo_dev/build/build-checksum.php 2008-09-29 14:41:15 UTC (rev 3042)
+++ branches/spsneo_dev/build/build-checksum.php 2008-09-29 14:42:34 UTC (rev 3043)
@@ -22,7 +22,7 @@
#A constant for the path to the mapbender installation folder
-define("ROOTDIR", "../mapbender");
+define("ROOTDIR", "../../2.5/");
#check whether this file is being executed from command line or not
#abort if it is not being executed from command line
@@ -34,7 +34,7 @@
#These are the directories which are not to be scanned and checksum not to be evaluated as these
#directories are prone to change and always include "." and ".." in this list.
$dir_not_to_scan = array();
-array_push($dir_not_to_scan,".", "..", "conf", "license", "log", "resources", "update");
+array_push($dir_not_to_scan,".", "..", "conf", "license", "log", "resources", "update", "http/tmp");
$rootdir_path = ROOTDIR;
More information about the Mapbender_commits
