[Mapbender-commits] r3045 - in branches/2.5/resources/db/mysql: iso/update utf8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Sep 30 04:08:19 EDT 2008
Author: christoph
Date: 2008-09-30 04:08:19 -0400 (Tue, 30 Sep 2008)
New Revision: 3045
   branches/2.5/resources/db/mysql/iso/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql
   branches/2.5/resources/db/mysql/utf8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql
* removed obsolete sql "f_auth_varname"
Modified: branches/2.5/resources/db/mysql/iso/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql
--- branches/2.5/resources/db/mysql/iso/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql	2008-09-30 08:05:29 UTC (rev 3044)
+++ branches/2.5/resources/db/mysql/iso/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql	2008-09-30 08:08:19 UTC (rev 3045)
@@ -113,7 +113,6 @@
 -- table wfs_conf_element: change in WFS configuration: access to geometries may now be restricted
---ALTER TABLE wfs_conf_element ADD COLUMN f_auth_varname VARCHAR(50);
 ALTER TABLE wfs_conf_element ADD COLUMN f_show_detail int4;
 ALTER TABLE wfs_conf_element ADD COLUMN f_operator VARCHAR(50);
Modified: branches/2.5/resources/db/mysql/utf8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql
--- branches/2.5/resources/db/mysql/utf8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql	2008-09-30 08:05:29 UTC (rev 3044)
+++ branches/2.5/resources/db/mysql/utf8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql	2008-09-30 08:08:19 UTC (rev 3045)
@@ -113,7 +113,6 @@
More information about the Mapbender_commits mailing list
