[Mapbender-commits] r3041 - in branches/2.5/resources/db: . mysql/iso/update mysql/utf8/update postgresql/iso/update postgresql/utf8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Sep 29 10:36:55 EDT 2008
Author: christoph
Date: 2008-09-29 10:36:55 -0400 (Mon, 29 Sep 2008)
New Revision: 3041
Added:
   branches/2.5/resources/db/mysql/iso/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql
   branches/2.5/resources/db/mysql/iso/update/update_2.5rc6_to_2.5_mysql_ISO-8859-1.sql
   branches/2.5/resources/db/mysql/iso/update/update_guis_2.4.5_to_2.5_mysql_ISO-8859-1.sql
   branches/2.5/resources/db/mysql/utf8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql
   branches/2.5/resources/db/mysql/utf8/update/update_2.5rc6_to_2.5_mysql_UTF-8.sql
   branches/2.5/resources/db/mysql/utf8/update/update_guis_2.4.5_to_2.5_mysql_UTF-8.sql
   branches/2.5/resources/db/postgresql/iso/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
   branches/2.5/resources/db/postgresql/iso/update/update_2.5rc6_to_2.5_pgsql_ISO-8859-1.sql
   branches/2.5/resources/db/postgresql/iso/update/update_guis_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
   branches/2.5/resources/db/postgresql/utf8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql
   branches/2.5/resources/db/postgresql/utf8/update/update_2.5rc6_to_2.5_pgsql_UTF-8.sql
   branches/2.5/resources/db/postgresql/utf8/update/update_guis_2.4.5_to_2.5_pgsql_UTF-8.sql
Removed:
   branches/2.5/resources/db/update/
moved update files to correct folder
Added: branches/2.5/resources/db/mysql/iso/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql
--- branches/2.5/resources/db/mysql/iso/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql	                        (rev 0)
+++ branches/2.5/resources/db/mysql/iso/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql	2008-09-29 14:36:55 UTC (rev 3041)
@@ -0,0 +1,522 @@
+-- database changes in version 2.5
+-- notice language plpgsql has to be installed
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin_de_services', 20, '');
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin_en_services', 20, '');
+-- table mb_monitort: new columns for mb_monitor
+ALTER TABLE mb_monitor ADD COLUMN image int(11);
+ALTER TABLE mb_monitor ADD COLUMN map_url varchar(2048);
+-- WFS database handling
+-- enhancement of the datadase structure concerning WFS metadata (same solution like for WMS)
+ALTER table wfs add wfs_getcapabilities_doc text;
+ALTER table wfs add wfs_upload_url varchar(255);
+ALTER table wfs add fees varchar(255);
+ALTER table wfs add accessconstraints text;
+ALTER table wfs add individualname varchar(255);
+ALTER table wfs add positionname varchar(255);
+ALTER table wfs add providername varchar(255);
+ALTER table wfs add city varchar(255);
+ALTER table wfs add deliverypoint varchar(255);
+ALTER table wfs add administrativearea varchar(255);
+ALTER table wfs add postalcode varchar(255);
+ALTER table wfs add voice varchar(255);
+ALTER table wfs add facsimile varchar(255);
+ALTER table wfs add electronicmailaddress varchar(255);
+ALTER table wfs add wfs_mb_getcapabilities_doc text;
+ALTER table wfs add wfs_owner int(11);
+ALTER table wfs add wfs_timestamp int(11);
+ALTER table wfs add country varchar(255);
+ALTER TABLE wfs MODIFY wfs_title varchar(255) NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_title SET DEFAULT '';
+ALTER TABLE wfs MODIFY wfs_version NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_version SET DEFAULT '';
+ALTER TABLE wfs MODIFY wfs_getcapabilities NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_getcapabilities SET DEFAULT '';
+alter table wfs_featuretype add column featuretype_searchable integer default 1;
+alter table wfs_featuretype add column featuretype_abstract character varying(50);
+-- grant root access to default wfs
+UPDATE wfs SET wfs_owner = 1;
+-- new table gui_wfs_conf
+CREATE TABLE gui_wfs_conf (
+    fkey_gui_id character varying(50) DEFAULT '' NOT NULL,
+    fkey_wfs_conf_id integer DEFAULT 0 NOT NULL
+ALTER TABLE gui_wfs_conf
+    ADD CONSTRAINT pk_fkey_wfs_conf_id PRIMARY KEY (fkey_gui_id, fkey_wfs_conf_id);
+    ADD CONSTRAINT gui_wfs_conf_ibfk_1 FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
+    ADD CONSTRAINT gui_wfs_conf_ibfk_2 FOREIGN KEY (fkey_wfs_conf_id) REFERENCES wfs_conf(wfs_conf_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- insert wfs confs into gui digitize
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 1);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 3);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 4);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 2);
+-- new table wfs_featuretype_keyword:
+CREATE TABLE wfs_featuretype_keyword (
+  fkey_featuretype_id integer NOT NULL,
+  fkey_keyword_id integer NOT NULL
+ALTER TABLE wfs_featuretype_keyword
+    ADD CONSTRAINT fkey_keyword_id_fkey_featuretype_id FOREIGN KEY (fkey_keyword_id) REFERENCES keyword(keyword_id) ON UPDATE CASCADE ON DELETE CASCADE;
+    ADD CONSTRAINT fkey_featuretype_id_fkey_keyword_id FOREIGN KEY (fkey_featuretype_id) REFERENCES wfs_featuretype(featuretype_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- new table layer_load_count
+CREATE TABLE layer_load_count (
+ fkey_layer_id int4,
+ load_count int8
+-- table wfs_conf
+ALTER TABLE wfs_conf add COLUMN wfs_conf_description text;
+ALTER TABLE `wfs_conf`
+    ADD CONSTRAINT wfs_conf_ibfk_2 FOREIGN KEY (fkey_featuretype_id) REFERENCES wfs_featuretype(featuretype_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- table wfs_conf_element: change in WFS configuration: access to geometries may now be restricted
+--ALTER TABLE wfs_conf_element ADD COLUMN f_auth_varname VARCHAR(50);
+ALTER TABLE wfs_conf_element ADD COLUMN f_show_detail int4;
+ALTER TABLE wfs_conf_element ADD COLUMN f_operator VARCHAR(50);
+-- table gui_element: new column for translation
+-- ALTER TABLE gui_element ADD COLUMN e_title VARCHAR(255) NULL;
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','WFS',2,1,'edit wfs settings','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,1005,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT WFS','a','','','','AdminFrame','');
+ fkey_layer_id int(11),
+ load_count int(11)
+-- new table translation: new table for translations
+ CREATE TABLE translations
+   trs_id int(11) NOT NULL auto_increment,
+   locale varchar(8),
+   msgid varchar(512),
+   msgstr varchar(512),
+   PRIMARY KEY (trs_id)
+ CREATE INDEX msgid_idx ON translations(msgid);
+-- new function gettext for easy translations
+-- function has to be translated
+-- new entries for table translations
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Pan', 'Ausschnitt verschieben');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Display complete map', 'gesamte Karte anzeigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom in', 'In die Karte hineinzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom out', 'Aus der Karte herauszoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Back', 'Zurück');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Forward', 'Nach vorne');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Coordinates', 'Koordinaten anzeigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom by rectangle', 'Ausschnitt wählen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Redraw', 'Neu laden oder Tastatur: Leertaste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Query', 'Datenabfrage');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Logout', 'Abmelden');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'WMS preferences', 'WMS Einstellungen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS from filtered list', 'WMS von gefilteter Liste hinzufügen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set map center', 'Kartenmittelpunkt setzen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Help', 'Hilfe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Show WMS infos', 'Anzeige von WMS Informationen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Save workspace as web map context document', 'Ansicht als Web Map Context Dokument speichern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Resize Mapsize', 'Bildschirmgröße anpassen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Rubber', 'Skizze löschen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Get Area', 'Fläche berechnen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Close Polygon', 'Polygon schliessen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Move back to your GUI list', 'Zurück zur GUI Liste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Legend', 'Legende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Print', 'Druck');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Imprint', 'Impressum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Maps', 'Karten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Search', 'Suche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Meetingpoint', 'Treffpunkt');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Metadatasearch', 'Metadatensuche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS', 'WMS hinzufügen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS from List', 'WMS aus Liste hinzufügen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Change Projection', 'Projektion ändern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Digitize', 'Digitalisierung');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Overview', 'Übersichtskarte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Drag Mapsize', 'Karte vergrößern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Mapframe', 'Kartenfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Navigation Frame', 'Navigationsfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scale Select', 'Auswahl des Maßstabes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scale Text', 'Maßstab per Texteingabe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scalebar', 'Maßstabsleiste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set Background', 'Hintegrundkarte auswählen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom to Coordinates', 'Zu den Koordinaten zoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Change Password', 'Passwort ändern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Load a web map context document', 'laden eines Web Map Context Dokumentes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de ', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Pan', 'Премести областта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Display complete map', 'Покажи цялата карта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom in', 'Покажи картата в по-едър мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom out', 'Покажи картата в по-дребен мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Back', 'Назад');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Forward', 'Напред');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Coordinates', 'Координати');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom by rectangle', 'Увеличи картата в избраната област');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Redraw', 'Пречертай или от клавиатурата: празен интервал');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Query', 'Зявка към данните');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Logout', 'Изход на потребител');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'WMS preferences', 'WMS настройки');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS from filtered list', 'Добави WMS от избран списък');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Set map center', 'Постави център на карта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Help', 'Помощ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Show WMS infos', 'Покажи WMS информация');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Save workspace as web map context document', 'Запази работния документ като Web Map Context документ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Resize Mapsize', 'Напасни големината на картата');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Rubber', 'Изтрий');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Get Area', 'Изчисли площ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Close Polygon', 'Затвори полигон');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Move back to your GUI list', 'Назад към списъка с интерфейси (GUI)');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Legend', 'Легенда');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Print', 'Печат');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Imprint', 'Авторско каре');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Maps', 'Карти');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Search', 'Търсене');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Meetingpoint', 'Място на среща');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Metadatasearch', 'Търсене по метаданни');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS', 'Добави WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS from List', 'Добави WMS от списък');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Info', 'Информация');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Change Projection', 'Промени проекция');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Copyright', 'Авторско право');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Digitize', 'Дигитализиране');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Overview','Обзорна карта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Drag Mapsize', 'Промени размера на картата');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Mapframe', 'Рамка на картата');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Navigation Frame', 'Навигационна рамка');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scale Select', 'Избор на мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scale Text', 'Въведи мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scalebar', 'Мащабна скала');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Set Background', 'Избери фоново изображение');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom to Coordinates', 'Покажи картата около посочените координати');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Change Password', 'Промени парола');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Load a web map context document', 'Зареди Web Map Context документ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Logo', 'Фирмен знак');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Measure distance', 'Измери разстояние');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Pan', 'Μετακίνηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Display complete map', 'Επίδειξη Πλήρους Χάρτη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom in', 'Zoom In');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom out', 'Zoom Out');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Back', 'Πίσω');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Forward', 'Πρόσθια');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Coordinates', 'Συντεταγμένες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom by rectangle', 'Ζουμ από ορθογώνιο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Redraw', 'Απόσυρση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Query', 'Μέτρηση Εμβαδού');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Logout', 'Αποσύνδεση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'WMS preferences', 'Αλλάξτε τη διάταξη των WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS from filtered list', 'Πρόσθεση WMS από το φιλτραρισμένο κατάλογο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Set map center', 'Το καθορισμένο Κέντρο Χαρτών');
+INSERT INTO translations (locale, msgid, msgstr) VALUES  ('gr', 'Help', 'Βοήθεια');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Save workspace as web map context document', 'Ansicht als Web Map Context Dokument speichern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Rubber', 'Το λάστιχο- Τρίφτης');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Close Polygon', 'Το Κλειστό Πολύγωνο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ( 'gr', 'Move back to your GUI list', 'Παρουσίαση του GUI Καταλόγου');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Print', 'Εκτύπωση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Maps', ' Χάρτες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS', 'Πρόσθεση WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS from List', 'Πρόσθεση WMS από τον κατάλογο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Navigation Frame', 'Navigationsfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Load a web map context document', 'laden eines Web Map Context Dokumentes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Measure distance', 'Μέτρηση Απόστασης');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Meetingpoint', 'Σημείο Συνάντησης');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Info', 'Πληροφορίες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Digitize', 'Ψηφιοποίηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Change Projection', 'Αλλαγή Προβολής');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Set Background', 'Επιλογή Φόντου');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Overview', 'Προεπισκόπιση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Change Password', 'Αλλαγή Συνθηματικού');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scalebar', 'Κανόνας Κλίμακας');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr ', 'Logo', 'Λογότυπο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom to Coordinates', 'Εστίαση σε Συντεταγμένες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scale Text', 'Κείμενο Κλίμακας');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Show WMS infos', 'Προβολή WMS πληροφοριών');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Legend', 'Λεζάντα');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Search', 'Αναζήτηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Resize Mapsize', 'Αλλαγή Μεγέθους Χάρτη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Drag Mapsize', 'Αλλαγή Μεγέθους Χάρτη με Ολίσθηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Mapframe', 'Πλαίσιο Χάρτη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Get Area', 'Προβολή Περιοχής');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Imprint', 'Αποτύπωση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scale Select', 'Επιλογή Κλίμακας');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Metadatasearch', 'Αναζήτηση στα Metadata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Pan', 'Selectie verschuiven');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Display complete map', 'Hele kaart tonen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom in', 'Inzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom out', 'Uitzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Back', 'Terug');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Forward', 'Voorwaarts');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Coordinates', 'Koordinaten tonen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom by rectangle', 'Zoom rechthoek-selectie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Redraw', 'Opfrissen of toetsenbord : spatiebalk');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Query', 'Data opvragen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Logout', 'Afmelden');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'WMS preferences', 'WMS instellingen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS from filtered list', 'WMS van gefilterte lijst toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set map center', 'Kaartmiddelpunt aangeven');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Help', 'Help');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Show WMS infos', 'Tonen van WMS Informatie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Save workspace as web map context document', 'zicht als Web map context dokument bewaren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Resize Mapsize', 'beeldschermgrote aanpassen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Rubber', 'schets verwerpen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Get Area', 'oppervlakte berekenen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Close Polygon', 'Polygoon sluiten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Move back to your GUI list', 'Terug naar GUI lijst');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Legend', 'Legende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Print', 'Drukken');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Imprint', 'Impressum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Maps', 'Kaarten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Search', 'Zoek');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Meetingpoint', 'Trefpunt');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Metadatasearch', 'Zoeken naar Metadata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS', 'WMS toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS from List', 'WMS uit lijst toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Info', 'Informatie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Change Projection', 'Projektie veranderen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Digitize', 'Digitaliseren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Overview', 'overzichtskaart');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Drag Mapsize', 'Kaart vergroten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Mapframe', 'Kaartvenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Navigation Frame', 'Navigeervenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scale Select', 'Schaal selecteren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scale Text', 'Schaal via tekstingave');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scalebar', 'Schaalbalk');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set Background', 'Achtergrond selecteren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom to Coordinates', 'Naar koordinaten zoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Change Password', 'Paswoord wijzigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Load a web map context document', 'Laad een Web Map Context Dokument');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Measure distance', 'Meet afstand');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Pan', 'Sposta dettaglio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Display complete map', 'Mostra tutta la mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom in', 'Ingrandisci');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom out', 'Riduci');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Back', 'Indietro');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Forward', 'Avanti');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Coordinates', 'Mostra coordinate');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom by rectangle', 'Seleziona dettaglio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Redraw', 'Ridisegna oppure, da tastiera: spazio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Query', 'Interroga');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Logout', 'Logout');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'WMS preferences', 'Impostazioni WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS from filtered list', 'Aggiungi un WMS da una lista filtrata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set map center', 'Fissa il centro della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Help', 'Aiuto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Show WMS infos', 'Mostra informazioni sul WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Save workspace as web map context document', 'Salva vista come documento di Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Resize Mapsize', 'Adatta la dimensione della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Rubber', 'Cancella bozza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Get Area', 'Calcola area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Close Polygon', 'Chiudi poligono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Move back to your GUI list', 'Torna alla lista delle GUI');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Legend', 'Legenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Print', 'Stampa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Imprint', 'Colophon');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Maps', 'Mappe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Search', 'Cerca');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Meetingpoint', 'Punti di incontro');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Metadatasearch', 'Ricerca metadati');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS', 'Aggiungi WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS from List', 'Aggiungi WMS da lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Change Projection', 'Cambia proiezione');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Digitize', 'Digitalizza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Overview', 'Mappa di insieme');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Drag Mapsize', 'Cambia dimensione mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Mapframe', 'Quadro della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Navigation Frame', 'Quadro di navigazione');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scale Select', 'Scelta della scala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scale Text', 'Scala dei testi');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scalebar', 'Scala di riferimento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set Background', 'Seleziona mappa di sfondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom to Coordinates', 'Ingrandisci alle coordinate');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Change Password', 'Cambia password');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Load a web map context document', 'Carica un documento Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Measure distance', 'Misura distanza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Pan', 'Desplazamiento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Display complete map', 'Desplazamiento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom in', 'Zoom +');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom out', 'Zoom -');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Back', 'Zoom previo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Forward', 'Zoom siguiente');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Coordinates', 'Mostrar coordenadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom by rectangle', 'Zoom rectángulo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Redraw', 'Refrescar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Query', 'Busqueda de datos');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Logout', 'Terminar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'WMS preferences', 'Ajuste WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS from filtered list', 'Anadir WMS desde lista filtrada');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set map center', 'Centrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Help', 'Ayuda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Show WMS infos', 'Mostrar información sobre WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Save workspace as web map context document', 'Guardar vista como fichero Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Resize Mapsize', 'Modificar el tamano de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Rubber', 'Borrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Get Area', 'Calcular area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Close Polygon', 'Cerrar polígono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Move back to your GUI list', 'Volver a la lista WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Legend', 'Leyenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Print', 'Imprimir');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Imprint', 'Aviso legal');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Maps', 'Mapas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Search', 'Busqueda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Meetingpoint', 'Lugar de reunión');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Metadatasearch', 'Búsqueda de datos meta');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS', 'Añadir WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS from List', 'Añadir WMS desde lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Info', 'Informacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Change Projection', 'Cambiar projecto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Digitize', 'Digitalización');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Overview', 'Mapa de visión general');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Drag Mapsize', 'Ampilar vista de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Mapframe', 'Ventana de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Navigation Frame', 'Ventana de navigacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scale Select', 'Selecionar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scale Text', 'Teclar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scalebar', 'Fraja de escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set Background', 'Poner el fondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom to Coordinates', 'Zoom en coordenadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Change Password', 'Cambiar clave');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Load a web map context document', 'Cargar un documento de Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Measure distance', 'Medir distancias');
+-- new table gui_kml
+CREATE TABLE gui_kml (
+    kml_id int(11) NOT NULL auto_increment,
+    fkey_mb_user_id int(11) NOT NULL,
+    fkey_gui_id varchar(50) NOT NULL,
+    kml_doc text NOT NULL,
+    kml_name varchar(64),
+    kml_description text,
+    kml_timestamp int(11) NOT NULL,
+       PRIMARY KEY (kml_id)
+ALTER TABLE gui_kml
+ADD CONSTRAINT gui_kml_fkey_mb_user_id  FOREIGN KEY (fkey_mb_user_id)
+REFERENCES mb_user(mb_user_id) MATCH SIMPLE ON UPDATE CASCADE ON DELETE CASCADE;
+ADD CONSTRAINT gui_kml_id_fkey_gui_id FOREIGN KEY (fkey_gui_id)
+REFERENCES gui(gui_id) MATCH SIMPLE ON UPDATE CASCADE ON DELETE CASCADE;
+-- new SLD table
+CREATE TABLE sld_user_layer (
+    sld_user_layer_id int(11) NOT NULL auto_increment,
+    fkey_mb_user_id int(11) NOT NULL default '0',
+    fkey_layer_id int(11) NOT NULL default '0',
+    fkey_gui_id varchar(50) NOT NULL default '',
+    sld_xml text,
+    use_sld tinyint(1) default '0',
+    PRIMARY KEY (sld_user_layer_id)
+) TYPE=InnoDB;
+-- constraints for new table sld_user_layer
+ALTER TABLE sld_user_layer ADD CONSTRAINT sld_user_layer_ibfk1 FOREIGN KEY (fkey_mb_user_id) REFERENCES mb_user (mb_user_id) ON DELETE CASCADE ON UPDATE CASCADE;
+ALTER TABLE sld_user_layer ADD CONSTRAINT ADD CONSTRAINT sld_user_layer_ibfk2 FOREIGN KEY (fkey_layer_id) REFERENCES layer (layer_id) ON DELETE CASCADE ON UPDATE CASCADE;
+ALTER TABLE sld_user_layer ADD CONSTRAINT ADD CONSTRAINT sld_user_layer_ibfk3 FOREIGN KEY (fkey_gui_id) REFERENCES gui (gui_id) ON DELETE CASCADE ON UPDATE CASCADE;
+-- add sld related columns
+ALTER TABLE gui_wms ADD COLUMN gui_wms_sldurl varchar(255) NOT NULL default '';
+ALTER TABLE wms ADD COLUMN wms_supportsld boolean NULL;
+ALTER TABLE wms ADD COLUMN wms_userlayer boolean NULL;
+ALTER TABLE wms ADD COLUMN wms_userstyle boolean NULL;
+ALTER TABLE wms ADD COLUMN wms_remotewfs boolean NULL;
+-- opacity handeling
+ALTER TABLE gui_wms ADD COLUMN gui_wms_opacity INT DEFAULT 100;
+UPDATE gui_element SET e_mb_mod = 'mod_addWMSgeneralFunctions.js' WHERE e_id = 'addWMS';
+ALTER TABLE gui_element MODIFY e_js_file character varying(255);
+ALTER TABLE gui_element MODIFY e_mb_mod character varying(255);
+ALTER TABLE wms MODIFY fees text;
+ALTER TABLE wms CHANGE COLUMN wms_mb_getcapabilies_doc wms_mb_getcapabilities_doc text;
\ No newline at end of file
Added: branches/2.5/resources/db/mysql/iso/update/update_2.5rc6_to_2.5_mysql_ISO-8859-1.sql
--- branches/2.5/resources/db/mysql/iso/update/update_2.5rc6_to_2.5_mysql_ISO-8859-1.sql	                        (rev 0)
+++ branches/2.5/resources/db/mysql/iso/update/update_2.5rc6_to_2.5_mysql_ISO-8859-1.sql	2008-09-29 14:36:55 UTC (rev 3041)
@@ -0,0 +1 @@
+DELETE FROM gui_treegde WHERE fkey_gui_id IN ('gui', 'gui1', 'admin1', 'gui2', 'wms_africa');
Added: branches/2.5/resources/db/mysql/iso/update/update_guis_2.4.5_to_2.5_mysql_ISO-8859-1.sql
--- branches/2.5/resources/db/mysql/iso/update/update_guis_2.4.5_to_2.5_mysql_ISO-8859-1.sql	                        (rev 0)
+++ branches/2.5/resources/db/mysql/iso/update/update_guis_2.4.5_to_2.5_mysql_ISO-8859-1.sql	2008-09-29 14:36:55 UTC (rev 3041)
@@ -0,0 +1,932 @@
+-- update of mapbender guis
+-- gui / gui1 / gui2 / gui_digitize
+-- Mapbender (Version: 2.4.2)
+-- 2007-07-30
+Delete from gui_element where fkey_gui_id ='gui';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','FeatureInfoRedirect',2,1,'redirect featureInfoRequests in an iframe for each wms','iframe','../html/mod_blank.html','frameborder="0"',83,-17,1,1,0,'','','iframe','mod_featureInfoRedirect.php','','','','http://www.mapbender.org/index.php/FeatureInfoRedirect');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','WMS_preferences',2,1,'configures the preferences of each loaded wms','img','../img/button_gray/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="WMS preferences"',540,10,24,24,1,'','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','addWMS',2,1,'add a WMS to the running application','img','../img/button_gray/add_off.png','onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS"',515,10,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','ajax',6,1,'ajax module','iframe','../frames/jquery.html','',1,1,1,1,1,'visibility:hidden','','iframe','../javascripts/mb_ajaxWrapper_jQuery.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','back',2,1,'History.back()','img','../img/button_gray/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" title="Back"',360,10,24,24,1,'','','','mod_back.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','body',1,1,'body (obligatory)','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','copyright',2,1,'a Copyright in the map','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','dependentDiv',2,1,'displays infos in a sticky div-tag','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','dragMapSize',2,1,'drag & drop Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','featureInfo1',2,0,'FeatureInfoRequest','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')" title="Query"',425,10,24,24,1,'','','','mod_featureInfoTunnel.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfoTunnel');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','forward',2,1,'History.forward()','img','../img/button_gray/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" title="Forward"',385,10,24,24,1,'','','','mod_forward.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','gazetteerMetadata',2,1,'gazetteer for metadata','iframe','../php/mod_gazetteerMetadata.php?sessionID&target=mapframe1,overview','frameborder = "0"',1,1,1,1,4,'visibility:hidden;','','iframe','','','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','geometry',1,1,'geometry library','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','geometry.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','help',2,1,'button help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" title="help"',620,10,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','highlightPOI',2,1,'highlight 1 to n pois in your gui with a Symbol and a special text','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_highlightPOI.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','imprint',2,1,'Information about the owner of the gui','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_back',3,1,'layout, background for buttons','div','','',360,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_featureInfo',3,1,'layout, background for FeatureInfo','div','','',425,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_help',3,1,'layout, background for Help-button','div','','',620,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_logout',3,1,'layout, background for Logout-button','div','','',660,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_metadata',3,1,'layout, background for Metadata','div','','',580,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_wms',3,1,'layout, background for wms','div','','',490,10,76,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_zoom',3,1,'layout, background for Zoom-button','div','','',220,10,126,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','legend',2,1,'legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','loadData',2,1,'IFRAME, um Daten zu laden','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','logo',2,1,'Logo','img','../img/mapbender_logo.png','',20,20,180,26,5,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','logout',2,1,'Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"',660,10,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','mapbender',2,1,'Mapbender-Logo','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','mapframe1',2,1,'frame for a map','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',230,55,500,450,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','meetingPoint',2,1,'create a meeting point','iframe','../php/mod_meetingPoint.php?sessionID','frameborder = "0" ',0,0,NULL ,NULL ,4,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','metadata',2,1,'shows informations about the wms and the requests of the gui','img','../img/button_gray/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_gray/metadata_over.png"'' onmouseout=''this.src="../img/button_gray/metadata_off.png"'' title="Show service metadata"',580,10,24,24,1,'','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','navFrame',2,1,'navigation mapborder','div','','',0,0,0,0,0,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','overview',2,1,'OverviewFrame','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',30,65,150,130,100,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','pan1',2,1,'pan','img','../img/button_gray/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')" title="Pan"',270,10,24,24,1,'','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','printPDF',2,1,'pdf print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','sandclock',2,1,'displays a sand clock while waiting for requests','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','selArea1',2,1,'zoombox','img','../img/button_gray/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')" title="Zoom by rectangle"',295,10,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','setBBOX',2,0,'set extent for mapframe and overviewframe','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','setBackground',2,1,'switch background-wms','form','','',30,210,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','showCoords_div',2,1,'displays coodinates by onmouseover','img','../img/button_gray/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" title="Coordinates" ',450,10,24,24,1,'','','','mod_coords_div.php','','mapframe1','dependendDiv','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','tabs',2,1,'vertical tabs to handle iframes','div','','',10,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2','iframe','../html/mod_treefolder2.php?sessionID','frameborder = "0" ',10,220,200,300,NULL ,'visibility:visible','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomFull',2,1,'zoom to full extent button','img','../img/button_gray/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"  title="Display complete map"',320,10,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomIn1',2,1,'zoomIn button','img','../img/button_gray/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' title=''Zoom in''',220,10,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomOut1',2,1,'zoomOut button','img','../img/button_gray/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' title="Zoom out"',245,10,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_all', '0', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_group', '0', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_gui', '0', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'gazetteerWFS', 'wfsConfIdString', '1', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_height', '14', 'height of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_width', '14', 'width of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_ccs_file', '../css/meetingPoint.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_format', 'prompt', 'decide which format to choose (email, prompt)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_subject', 'Ein Treffpunkt wurde erzeugt. Folgen Sie dem Link!', 'if you choose format email, define the text for the subject', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_height', '14', 'height of the meetingPoint_icon', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_icon', '../img/redball.gif', 'path to meetingPoint image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_max_characters', '70', 'define the maximum length of the text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_please_click', 'Please click in  the map to define the meeting point position!', 'text to show if no clickposition is set', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_style', 'background-color:white;font-weight: bold;color:red;font-family:Arial;', 'style to display the meetingPoint text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_width', '14', 'width of the meetingPoint_icon', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[5]', '160', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[6]', '280', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[1]', 'legend', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[2]', 'printPDF', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[4]', 'imprint', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[5]', 'meetingPoint', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[6]', 'gazetteerMetadata', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_prefix', '  ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[0]', 'Maps', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[1]', 'Legend', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[2]', 'Print', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[3]', 'WFS Search', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[4]', 'Imprint', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[5]', 'Meeting Point', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[6]', 'Metadata search', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'menu', 'opacity_up,opacity_down,zoom,metainfo,hide,wms_up,wms_down,layer_up,layer_down,remove', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'metadatalink', 'false', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui1';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','WMS_preferences',2,1,'configure the preferences of each loaded wms','img','../img/button_blink_red/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="WMS preferences"',670,60,24,24,1,'','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMS',2,1,'add a WMS to the running application','img','../img/button_blink_red/add_off.png','onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS"',645,60,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMSfromList',2,1,'add a WMS to the running application from a list','img','../img/button_blink_red/addlist_off.png','onclick=''window.open("../javascripts/mod_addWMSfromList.php?sessionID","printWin","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from List"',595,60,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',620,60,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','ajax',6,1,'ajax module','iframe','../frames/jquery.html','',1,1,1,1,1,'visibility:hidden','','iframe','../javascripts/mb_ajaxWrapper_jQuery.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','back',2,1,'History.back()','img','../img/button_blink_red/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" title="Back"',400,60,24,24,1,'','','','mod_back.php','','mapframe1,overview','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','body',1,1,'body (obligatory)','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','center1',2,1,'Center button','img','../img/button_blink_red/center_off.png','onmouseover = "mb_regButton(''init_gui1_center'')" title="Set map center"',310,60,24,24,1,'','','','mod_center1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','changeEPSG',2,1,'change EPSG, Postgres required, overview is targed for full extent','iframe','../php/mod_changeEPSG.php?sessionID','scrolling="no" frameborder=''0'' ',432,25,107,24,1,'','','iframe','','','overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','changePassword_button',2,1,'button: change password of logged user','img','../img/button_blink_red/change_password_off.png','onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0'' onmouseover=''this.src="../img/button_blink_red/change_password_over.png"'' onmouseout=''this.src="../img/button_blink_red/change_password_off.png"'' title="Change password"',750,60,24,24,1,'cursor:hand','','','','','','','http://www.mapbender.org/index.php/ChangePassword');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','closePolygon',3,1,'close Polygon ','div','',' title="Close Polygon"',0,0,0,0,0,'','','div','mod_closePolygon.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','copyright',2,1,'a Copyright in the map','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','dependentDiv',2,1,'displays infos in a sticky div-tag','div','','',-59,1,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','dragMapSize',2,1,'drag & drop Mapsize','div','','',-59,1,0,0,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','featureInfo1',2,1,'FeatureInfoRequest','img','../img/button_blink_red/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')" title="Query"',465,60,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','forward',2,1,'History.forward()','img','../img/button_blink_red/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" title="Forward"',425,60,24,24,1,'','','','mod_forward.php','','mapframe1,overview','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','getArea',3,1,'Calculation of area, Postgis required','div','',' title="Get Area"',0,0,0,0,0,'','','div','mod_getArea.php','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','help',2,1,'button help','img','../img/button_blink_red/help_off.png','onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")'' title="Help"',790,60,24,24,1,'','','','','','','','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','help1',2,1,'button help','img','../img/button_blink_red/help_off.png','onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")'' title="Help"',790,60,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/help');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','highlightPOI',2,1,'highlight 1 to n pois in your gui with a Symbol and a special text','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_highlightPOI.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','layout_1',3,1,'layout, background for buttons','div','','',208,58,670,28,0,'background-color:#FFFFFF;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','legend',2,1,'legend','iframe','../javascripts/mod_legend.php?sessionID&wms_legend = yes','frameborder=''0''',-59,200,180,600,3,'','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','loadData',2,1,'IFRAME to load data','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','loadwmc',2,1,'load workspace from WMC','img','../img/button_blink_red/wmc_load_off.png','onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Load a web map context document"',895,60,24,24,1,'','','','mod_loadwmc.php','','mapframe1','','http://www.mapbender.org/index.php/LoadWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','logout',2,1,'Logout','img','../img/button_blink_red/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blink_red/logout_over.png"'' onmouseout=''this.src="../img/button_blink_red/logout_off.png"'' title="Logout"',830,60,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','mapbender',2,1,'Mapbender-Logo','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',-59,1,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','mapframe1',2,1,'Frame for a map','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',220,105,625,400,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','measure',2,1,'Measure','img','../img/button_blink_red/measure_off.png','onmouseover = "mb_regButton(''init_mod_measure'')" title="Measure distance"',515,60,24,24,1,'','','','mod_measure.php','','mapframe1','','http://www.mapbender.org/index.php/Measure');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','metadata',2,1,'shows informations about the wms and the requests of the gui','img','../img/button_blink_red/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_blink_red/metadata_over.png"'' onmouseout=''this.src="../img/button_blink_red/metadata_off.png"'' title="Show WMS infos"',710,60,24,24,1,'','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','navFrame',2,1,'navigation mapborder','div','','',0,0,0,0,10,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','overview',2,1,'OverviewFrame','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',15,25,150,150,2,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','pan1',2,1,'pan','img','../img/button_blink_red/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')" title="Pan"',260,60,24,24,1,'','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','print1',2,0,'start print GUI','img','../img/button_blink_red/print_off.png','onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID","printWin","width=300, height=400, resizable=yes ")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Print"',555,60,24,24,1,'','','','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','printPDF',2,1,'start print GUI','img','../img/button_blink_red/print_off.png','onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF_b.conf","printWin","width=180, height=200, resizable=yes ")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Print"',555,60,24,24,1,'','','','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','repaint',2,1,'refresh a mapobject','img','../img/button_blink_red/repaint_off.png','onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)'' title="Redraw"',360,60,24,24,1,'','','','mod_repaint.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','rubber',3,1,'deletes temporary (digitized) objects','div','',' title="Rubber"',0,0,0,0,0,'','','div','mod_rubber.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','sandclock',2,1,'displays a sand clock while waiting for requests','div','','',0,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','savewmc',2,1,'save workspace as WMC','img','../img/button_blink_red/wmc_save_off.png','onclick=''mod_savewmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Save workspace as web map context document"',870,60,24,24,1,'','','','mod_savewmc.php','','mapframe1','','http://www.mapbender.org/index.php/SaveWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scaleSelect',2,1,'Scale-Selectbox','select','','onchange=''mod_scaleSelect(this)''',555,25,100,20,1,'','<option value = ''''>Scale</option> <option value=''100''>1 : 100</option> <option value=''250''>1 : 250</option> <option value=''500''>1 : 500</option> <option value=''1000''>1 : 1000</option> <option value=''2500''>1 : 2500</option> <option value=''5000''>1 : 5000</option> <option value=''10000''>1 : 10000</option> <option value=''25000''>1 : 25000</option> <option value=''30000''>1 : 30000</option> <option value=''50000''>1 : 50000</option> <option value=''75000''>1 : 75000</option> <option value=''100000''>1 : 100000</option> <option value=''200000''>1 : 200000</option> <option value=''300000''>1 : 300000</option> <option value=''400000''>1 : 400000</option> <option value=''500000''>1 : 500000</option> <option value=''600000''>1 : 600000</option> <option value=''700000''>1 : 700000</option> <option value=''800000''>1 : 800000</option> <option value=''900000''>1 : 900000</option> <option value=''1000000''>1 : 1000000</option>','select','mod_scaleSel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scaleText',2,1,'Scale-description field','form','','onsubmit=''return mod_scaleText()''',672,25,100,30,0,'','<input type="text">','form','mod_scaleText.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scalebar',2,1,'scalebar','div','','',0,0,0,0,0,'','','div','mod_scalebar.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','selArea1',2,1,'zoombox','img','../img/button_blink_red/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')" title="Zoom by rectangle"',285,60,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBBOX',2,0,'set Extent for mapframe and overviewframe','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBackground',2,0,'switch background-wms','form','','',15,190,0,0,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBackground_all',2,0,'switch all background-wms','form','','',157,190,40,20,1,'','<input type=''checkbox'' onclick=''mod_setBackground_all_init(this)''> <font face="Arial, sans-serif" size="2">all</font>','form','mod_setBackground_all.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setPOI2Scale',2,1,'zoom to a poi (get-parameter)','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_setPOI2Scale.php','','mapframe1','','http://www.mapbender.org/index.php/Mod_setPoi2Scale');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setScaleHint',1,0,'set scaleHint for mapframes','div','','',1,1,1,1,0,'visibility:hidden;','','div','mod_scaleHint.php','','mapframe1,100,10000000','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','showCoords_div',2,1,'displays coordinates by onmouseover','img','../img/button_blink_red/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')"  title="Coordinates"',490,60,24,24,1,'','','','mod_coords_div.php','','mapframe1','','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeConfGDE',2,0,'configurable directory tree','iframe','../php/mod_treefolderClient.php?sessionID','frameborder = "0" ',0,180,250,500,0,'visibility:visible','','iframe','mod_treeConf.js','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeGDE_1',2,0,'directory tree, checkbox for visible, checkbox for querylayer, no immediate refreshing, with nested layers','iframe','../html/mod_sync_treefolder_1.html','frameborder = "0" ',0,180,250,500,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','wfs_gazetteer',2,0,'gazetteer using wfs','iframe','../php/mod_wfs_gazetteer.php?sessionID&color=255,0,255','frameborder = "0" ',-50,490,250,300,0,'visibility:visible','','iframe','','','mapframe1,overview','wfs','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomCoords',2,1,'zoom to coordinate','iframe','../php/mod_zoomCoords_en.php?sessionID','frameborder = "0" ',205,7,220,45,0,'','','iframe','','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomFull',2,1,'zoom to full extent button','img','../img/button_blink_red/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"  title="Display complete map"',335,60,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomIn1',2,1,'zoomIn button','img','../img/button_blink_red/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' title=''Zoom in''',210,60,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomOut1',2,1,'zoomOut button','img','../img/button_blink_red/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' title="Zoom out"',235,60,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_db', '0', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_height', '25', 'height of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_width', '25', 'width of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'css_file_legend', '../css/legend.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'stickylegend', 'true', 'parameter to decide wether the legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'logout', 'logout_location', 'http://www.mapbender.org/', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'setPOI2Scale', 'mod_setPOI2Scale_defScale', '5000', 'default scale', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'menu', '', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui2';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','WMS_preferences',2,1,'configures the preferences of each loaded wms','img','../img/button_blue/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="WMS preferences"',604,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','addWMS',2,1,'add a WMS to the running application','img','../img/button_blue/add_off.png','onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS"',580,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','img','../img/button_blue/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',553,40,28,28,1,'filter:Chroma(color=#C2CBCF);','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','ajax',6,1,'ajax module','iframe','../frames/jquery.html','',1,1,1,1,1,'visibility:hidden','','iframe','../javascripts/mb_ajaxWrapper_jQuery.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','back',2,1,'History.back()','img','../img/button_blue/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" title="Back"',398,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_back.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','body',1,1,'body
+(obligatory)','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'background-image:url(../img/background_yellow.jpg);background-repeat:repeat-x;','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','center1',2,1,'Center button','img','../img/button_blue/center_off.png','onmouseover = "mb_regButton(''init_gui1_center'')" title="Set map center"',308,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_center1.php','','mapframe1','','http://www.mapbender.org/index.php/ReCenter');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','changePassword_button',2,1,'button: change password of logged user','img','../img/button_blue/change_password_off.png','onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0''
+onmouseover=''this.src="../img/button_blue/change_password_over.png"'' onmouseout=''this.src="../img/button_blue/change_password_off.png"'' title="Change password"',668,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','','','http://www.mapbender.org/index.php/ChangePassword');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','closePolygon',3,1,'close Polygon ','div','','title="Close Polygon"',0,0,NULL ,NULL ,NULL ,'','','div','mod_closePolygon.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','copyright',2,1,'a Copyright in the map','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dependentDiv',2,1,'displays infos in a sticky div-tag','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dragMapSize',2,1,'drag & drop Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#799FEB; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dynamicOverview',2,1,'oveview acts in accordance with main mapframe','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','mod_dynamicOverview.php','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','featureInfo1',2,0,'FeatureInfoRequest','img','../img/button_blue/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','img','../img/button_blue/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')" title="Query"',461,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_featureInfoTunnel.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfoTunnel');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','forward',2,1,'History.forward()','img','../img/button_blue/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" title="Forward"',423,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_forward.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','geometry',1,1,'geometry library','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','geometry.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','getArea',3,1,'Calculation of area, Postgis required','div','','title="Get Area"',0,0,NULL ,NULL ,NULL ,'','','div','mod_getArea.php','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','header_yellow',2,0,'header','img','../img/header_yellow.jpg','',-1,-1,833,75,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','help',2,1,'button help','img','../img/button_blue/help_off.png','onmouseover = "mb_regButton(''init_help'')" title="help"',693,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','imprint',2,1,'Information about the owner of the gui','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','layout_linie',3,0,'layout','div','','',1,70,830,1,1,'background-color:#799FEB;font-size:1px;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','layout_linie2',3,0,'layout','div','','',1,35,830,1,1,'background-color:#799FEB;font-size:1px;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','legend',2,1,'legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','loadData',2,1,'IFRAME, um Daten zu laden','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','loadwmc',2,1,'load workspace from WMC','img','../img/button_blue/wmc_load_off.png','onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Load a web map context document"',758,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_loadwmc.php','','mapframe1','','http://www.mapbender.org/index.php/LoadWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','logo',2,1,'Logo','img','../img/mapbender_oo.png','',10,35,129,32,5,'filter:Chroma(color=#C2CBCF);','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','logout',2,1,'Logout','img','../img/button_blue/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blue/logout_over.png"'' onmouseout=''this.src="../img/button_blue/logout_off.png"''',798,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','mapbender',2,1,'Mapbender-Logo','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','mapframe1',2,1,'frame for a map','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',213,90,608,467,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','measure',2,1,'Measure','img','../img/button_blue/measure_off.png','onmouseover = "mb_regButton(''init_mod_measure'')" title="Measure distance"',513,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_measure.php','','mapframe1','','http://www.mapbender.org/index.php/Measure');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','metadata',2,1,'shows informations about the wms and the requests of the gui','img','../img/button_blue/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0''
+onmouseover=''this.src="../img/button_blue/metadata_over.png"'' onmouseout=''this.src="../img/button_blue/metadata_off.png"''
+title="Show SQL"',643,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','navFrame',2,1,'navigation mapborder','div','','',0,0,0,0,0,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>
+<div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>
+<div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>
+<div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div>
+<div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div>
+<div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>
+<div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>
+<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','overview',2,1,'OverviewFrame','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',9,80,185,130,100,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','pan1',2,1,'pan','img','../img/button_blue/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')" title="Pan"',258,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','printPDF',2,1,'pdf print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','repaint',2,1,'refresh a mapobject','img','../img/button_blue/repaint_off.png','onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)'' title="Redraw"',358,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_repaint.php','','mapframe1','','http://www.mapbender.org/index.php/Repaint');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','resizeMapsize',2,1,'resize mapsize to browser window size','img','../img/button_blink_red/resizemapsize_off.png','onclick = "adjustDimension()"
+onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="optimize mapsize to browser window"',838,40,24,24,3,'filter:Chroma(color=#C2CBCF);','','','mod_resize_mapsize.php','','mapframe1','','http://www.mapbender.org/index.php/ResizeMapsize');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','rubber',3,1,'deletes temporary (digitized) objects','div','','title="Rubber"',0,0,NULL ,NULL ,NULL ,'','','div','mod_rubber.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','sandclock',2,1,'displays a sand clock while waiting for requests','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','savewmc',2,1,'save workspace as WMC','img','../img/button_blue/wmc_save_off.png','onclick=''mod_savewmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Save workspace as web map context document"',733,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_savewmc.php','','mapframe1','','http://www.mapbender.org/index.php/SaveWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','selArea1',2,1,'zoombox','img','../img/button_blue/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')" title="Zoom by rectangle"',283,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','setBBOX',2,0,'set extent for mapframe and overviewframe','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','setBackground',2,1,'switch background-wms','form','','',10,218,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','showCoords_div',2,1,'displays coodinates by onmouseover','img','../img/button_blue/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" title="Coordinates" ',488,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_coords_div.php','','mapframe1','dependendDiv','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','tabs',2,1,'vertical tabs to handle iframes','div','','',2,245,191,22,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2','iframe','../html/mod_treefolder2.php?sessionID','frameborder = "0" ',10,220,200,300,NULL ,'visibility:visible','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomFull',2,1,'zoom to full extent button','img','../img/button_blue/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"  title="Display complete map"',333,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomIn1',2,1,'zoomIn button','img','../img/button_blue/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' title=''Zoom in''',203,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomOut1',2,1,'zoomOut button','img','../img/button_blue/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' title="Zoom out"',231,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_class_bg', 'body{background-color: #FEF8D4;}', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_minScale', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_startExtent', '-24.5,32,34.5,71', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_useMaxExtent', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_wmsIndex', '0', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_zoomFactor', '5', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'gazetteerWFS', 'wfsConfIdString', '1', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_height', '-35', 'to adjust the height of the mapframe on the bottom of the window', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_width', '-45', 'to adjust the width of the mapframe on the right side of the window', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'resize_option', 'button', 'auto (autoresize on load), button (resize by button)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'sandclock', 'mod_sandclock_image', '../img/sandclock_oo.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[1]', 'legend', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[2]', 'printPDF', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[4]', 'imprint', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_prefix', '  ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid #FDCC1A;font-size:12;color:#FFFFFF;background-color:#799FEB;cursor:pointer;margin-top:-3px; padding-top:3px;padding-left:4px;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[0]', 'Maps', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[1]', 'Legend', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[2]', 'Print', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[3]', 'WFS Search', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[4]', 'Imprint', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'menu', 'opacity_up,opacity_down,zoom,metainfo,hide,wms_up,wms_down,layer_up,layer_down,remove', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui_digitize';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','FeatureInfoRedirect',2,0,'redirect featureInfoRequests in an iframe for each wms','iframe','../html/mod_blank.html','frameborder="0"',83,-17,1,1,NULL ,'','','iframe','mod_featureInfoRedirect.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','WMS_preferences',2,1,'configures the preferences of each loaded wms','img','../img/button_gray/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="WMS preferences"',540,10,24,24,1,'','','','','','mapframe1,treeGDE','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','addWMS',2,1,'add a WMS to the running application','img','../img/button_gray/add_off.png','onclick=''mod_addWMS()''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS"',515,10,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','ajax',6,1,'ajax module','iframe','../frames/jquery.html','',1,1,1,1,1,'visibility:hidden','','iframe','../javascripts/mb_ajaxWrapper_jQuery.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','back',2,1,'History.back()','img','../img/button_gray/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" title="Back"',360,10,24,24,1,'','','','mod_back.php','','mapframe1,overview0','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','body',1,1,'body (obligatory)','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','closePolygonExt',3,0,'close Polygon ','div','',' title="Close Polygon"',0,0,NULL ,NULL ,NULL ,'','','div','mod_closePolygonExt.js','','mapframe1','setExtRequest','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','copyright',2,1,'a Copyright in the map','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','dependentDiv',2,1,'displays infos in a sticky div-tag','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','digitize',2,1,'Digitize tool.','iframe','../javascripts/mod_digitize_tab.php?sessionID','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','dragMapSize',2,1,'drag & drop Mapsize','div','','',81,-19,0,0,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','featureInfo1',2,0,'FeatureInfoRequest','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')" title="Query"',425,10,24,24,1,'','','','mod_featureInfoTunnel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','forward',2,1,'History.forward()','img','../img/button_gray/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" title="Forward"',385,10,24,24,1,'','','','mod_forward.php','','mapframe1,overview0','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','geometry',1,1,'geometry library','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','geometry.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','help',2,1,'button help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" title="help"',620,10,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','imprint',2,1,'Information about the owner of the gui','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','initWmc',2,0,'initialise client with wmc','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_initWmc.php','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_1',3,0,'Warning notice','div','','',150,250,300,16,100,'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none;','Development Version - Work in Progress!','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_back',3,1,'layout, background for buttons','div','','',360,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_featureInfo',3,1,'layout, background for FeatureInfo','div','','',425,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_help',3,1,'layout, background for Help-button','div','','',620,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_logout',3,1,'layout, background for Logout-button','div','','',660,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_metadata',3,1,'layout, background for Metadata','div','','',580,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_wms',3,1,'layout, background for wms','div','','',490,10,76,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_zoom',3,1,'layout, background for Zoom-button','div','','',220,10,126,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','legend',2,1,'legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','loadData',2,1,'IFRAME, um Daten zu laden','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','loadwmc',2,0,'load workspace from WMC','img','../img/button_wmc/wmc_load.png','onclick=''mod_loadwmc()'' onmouseover=''mod_loadwmc_init(this)''
+title=''Load a web map context document''',760,10,24,24,1,'','','','mod_loadwmc.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','logo',2,1,'Logo','img','../img/mapbender_logo.png','',20,20,180,26,5,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','logout',2,1,'Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''
+onmouseover=''this.src="../img/button_gray/logout_over.png"''
+onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"',660,10,24,24,1,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','mapbender',2,1,'Mapbender-Logo','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr>
+<script language="javascript">
+mb_registerSubFunctions("mod_mapbender()");
+function mod_mapbender(){
+document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90;
+document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1;
+</script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','mapframe1',2,1,'frame for a map','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',230,55,500,450,2,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','metadata',2,1,'shows informations about the wms and the requests of the gui','img','../img/button_gray/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''"
+border=''0''
+onmouseover=''this.src="../img/button_gray/metadata_over.png"''
+onmouseout=''this.src="../img/button_gray/metadata_off.png"'' title="Show service metadata"',580,10,24,24,1,'','','','mod_displayObj.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','navFrame',2,1,'navigation mapborder','div','','',0,0,0,0,0,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>
+<div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>
+<div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>
+<div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div>
+<div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div>
+<div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>
+<div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>
+<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>
+','div','mod_navFrame.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','overview',2,1,'OverviewFrame','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',30,65,150,130,100,'','','iframe','','mod_box1.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','pan1',2,1,'pan','img','../img/button_gray/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')" title="Pan"',270,10,24,24,1,'','','','mod_pan.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','printPDF',2,1,'pdf print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','rubberExt',3,1,'deletes temporary (digitized) objects','div','',' title="Rubber"',0,0,0,0,0,'','','div','mod_rubberExt.js','','mapframe1','setExtRequest','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','sandclock',2,1,'displays a sand clock while waiting for requests','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','savewmc',2,0,'save workspace as WMC','img','../img/button_wmc/wmc_save.png','onclick=''mod_savewmc()'' onmouseover=''mod_savewmc_init(this)''
+title=''Save workspace as web map context document''',730,10,24,24,1,'','','','mod_savewmc.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','scaleSelect',2,0,'Scale-Selectbox','select','','onchange=''mod_scaleSelect(this)''',555,25,100,20,1,'','<option value = ''''>Scale</option>
+<option value=''100''>1 : 100</option>
+<option value=''250''>1 : 250</option>
+<option value=''500''>1 : 500</option>
+<option value=''1000''>1 : 1000</option>
+<option value=''2500''>1 : 2500</option>
+<option value=''5000''>1 : 5000</option>
+<option value=''10000''>1 : 10000</option>
+<option value=''25000''>1 : 25000</option>
+<option value=''30000''>1 : 30000</option>
+<option value=''50000''>1 : 50000</option>
+<option value=''75000''>1 : 75000</option>
+<option value=''100000''>1 : 100000</option>
+<option value=''200000''>1 : 200000</option>
+<option value=''300000''>1 : 300000</option>
+<option value=''400000''>1 : 400000</option>
+<option value=''500000''>1 : 500000</option>
+<option value=''600000''>1 : 600000</option>
+<option value=''700000''>1 : 700000</option>
+<option value=''800000''>1 : 800000</option>
+<option value=''900000''>1 : 900000</option>
+<option value=''1000000''>1 : 1000000</option>','select','mod_scaleSel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','selArea1',2,1,'zoombox','img','../img/button_gray/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')" title="Zoom by rectangle"',295,10,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setBBOX',2,0,'set extent for mapframe and overviewframe','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setBackground',2,1,'switch background-wms','form','','',30,210,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12''
+name=''mod_setBackground_list''
+onchange=''mod_setBackground_change(this)'' ><option
+value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setSpatialRequest',2,1,'Spatial Request','div','','',1,1,1,1,1,'visibility:hidden;','','div','../javascripts/mod_wfs_SpatialRequest.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','showCoords_div',2,1,'displays coodinates by onmouseover','img','../img/button_gray/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" title="Coordinates" ',450,10,24,24,1,'','','','mod_coords_div.php','','mapframe1','dependendDiv','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','showLoggedUser',2,0,'Displays current user','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','tabs',1,1,'vertical tabs to handle iframes','div','','',10,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfs',2,1,'wfs request and result handling','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','wfs.js','../extensions/wz_jsgraphics.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfs_conf',2,1,'get all wfs_conf-params','iframe','../php/mod_wfs.php','frameborder = "0"',1,1,1,1,0,'visibility:hidden','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfsresult',2,1,'display the list of wfs results','iframe','../html/mod_blank.html','frameborder = "0"',10,730,200,150,4,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomFull',2,1,'zoom to full extent button','img','../img/button_gray/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"  title="Display complete map"',320,10,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomIn1',2,1,'zoomIn button','img','../img/button_gray/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' title="Zoom in"',220,10,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomOut1',2,1,'zoomOut button','img','../img/button_gray/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' title="Zoom out"',245,10,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'cssUrl', '../css/digitize.css', 'url to the style sheet of the mapframe', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'digitize_conf_filename', 'digitize_default.conf', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'text css', ' body{
+ font-family: Arial, Helvetica, sans-serif;
+ font-size : 12px;
+ color: #ff00ff;
+ background-color: #ffffff;
+ margin-top: 0px;
+ margin-left: 0px;
+ .button{
+ height: 18px;
+ width: 32px;
+', 'text css', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'wfsCssUrl', '../css/mapbender.css', 'var', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'gazetteerWFS', 'wfsConfIdString', '1,2,3,4', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'useUsemap', '0', '"1" adds a usemap to each geometry; the geometry will be highlighted onMouseOver. Every other value will skip the usemap.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'wfs_conf_filename', 'wfs_default.conf', 'location and name of the WFS configuration file', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'open_tab', '5', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[5]', '250', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[1]', 'legend', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[2]', 'printPDF', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[4]', 'imprint', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[5]', 'digitize', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_prefix', '  ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;padding-left:8px;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[0]', 'Maps', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[1]', 'Legend', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[2]', 'Print', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[3]', 'WFS Search', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[4]', 'Imprint', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[5]', 'Digitize', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'menu', '', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'wfs', 'displayWfsResultList', '1', '', 'var');
+Delete from gui_element where fkey_gui_id ='admin1';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','AdminFrame',2,1,'the frame for administration modules','iframe','','frameborder = "0"',220,20,800,800,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','CreateTreeGDE',2,1,'create a foldertree for a individual geodataexplorer','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,810,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','CREATE TREE_GDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','EditWMSMetadata',2,1,'edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,950,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT WMS-METADATA','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_Gui',2,1,'allocate groups to guis','a','','href = "../php/mod_group_gui.php?sessionID&e_id_css=Group_Gui" target = "AdminFrame" ',10,610,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_User',2,1,'allocate groups to user','a','','href = "../php/mod_group_user.php?sessionID&e_id_css=Group_User" target = "AdminFrame" ',10,550,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','GROUP -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_filteredGui',2,1,'allocate Groups to the guis of this admin','a','','href = "../php/mod_group_filteredGui.php?sessionID&e_id_css=Group_filteredGui" target = "AdminFrame" ',10,710,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Gui_Group',2,1,'allocate guis to groups','a','','href = "../php/mod_gui_group.php?sessionID&e_id_css=Gui_Group" target = "AdminFrame" ',10,250,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Gui_User',2,1,'allocate a gui to user','a','','href = "../php/mod_gui_user.php?sessionID&e_id_css=Gui_User" target = "AdminFrame" ',10,190,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','User_Group',2,1,'allocat user to groups','a','','href = "../php/mod_user_group.php?sessionID&e_id_css=User_Group" target = "AdminFrame" ',10,430,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','body',1,1,'navigation','body','','onload=''mod_adminNavigation_init()''',0,0,0,0,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteGui',2,1,'delete gui','a','','href = "../php/mod_deleteGUI.php?sessionID" target = "AdminFrame" ',10,150,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteWFS',2,1,'delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,890,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteWMS',2,1,'delete wms','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,110,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','delete_filteredGui',2,1,'delete guis of this admin','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,790,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editElements',2,1,'edit gui elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,170,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','EDIT GUI-ELEMENTS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editFilteredGroup',2,1,'edit group of this admin','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',10,530,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editFilteredUser',2,1,'save, edit, delete user where this admin is owner','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',10,350,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editGUI_WMS',2,1,'edit the elements of the gui','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,90,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT GUI-WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editGroup',2,1,'edit group','a','','href = "../php/mod_editGroup.php?sessionID" target = "AdminFrame" ',10,510,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editUser',2,1,'save, edit, delete user','a','','href = "../php/mod_editUser.php?sessionID" target="AdminFrame"',10,330,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','exportGUI',2,1,'export gui, create SQLL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,310,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EXPORT GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl�che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGoup_filteredUser',2,1,'allocate the groups of this admin to user where the admin is owner','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',10,590,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> myUSER ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_Gui',2,1,'allocate groups of this admin to guis','a','','href = "../php/mod_filteredGroup_Gui.php?sessionID&e_id_css=filteredGroup_Gui" target = "AdminFrame" ',10,750,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_User',2,1,'allocate groups of this admin to user','a','','href = "../php/mod_filteredGroup_User.php?sessionID&e_id_css=filteredGroup_User" target = "AdminFrame" ',10,690,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_filteredGui',2,1,'allocate groups of this admin to guis of this admin','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',10,730,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_Group',2,1,'allocate guis to groups','a','','href = "../php/mod_filteredGui_group.php?sessionID&e_id_css=filteredGui_Group" target = "AdminFrame" ',10,270,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> GROUP ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_filteredGroup',2,1,'allocate guis of this admin to groups where this admin is owner','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',10,290,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_filteredUser',2,1,'allocate the user where the admin is owner to his guis ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',10,230,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_user',2,1,'allocate the guis of this admin to a user','a','','href = "../php/mod_filteredGui_User.php?sessionID&e_id_css=filteredGui_user" target = "AdminFrame" ',10,210,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> USER ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_Group',2,1,'allocate user of this admin to groups','a','','href = "../php/mod_filteredUser_Group.php?sessionID&e_id_css=filteredUser_Group" target = "AdminFrame" ',10,670,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_Gui',2,1,'allocate user of this admin to guis','a','','href = "../php/mod_filteredUser_Gui.php?sessionID&e_id_css=filteredUser_Gui" target = "AdminFrame" ',10,770,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_filteredGroup',2,1,'allocate user where this admin is owner to groups where this admin is owner','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',10,490,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_filteredGui',2,1,'allocate admins user to guis of this admin','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',10,410,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','getStyles',2,0,'load styles from wms','a','','href = "../php/mod_getStyles.php?sessionID" target = "AdminFrame" ',10,890,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GET_STYLES','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','group_filteredUser',2,1,'allocate groups to user where this admin is owner','a','','href = "../php/mod_group_filteredUser.php?sessionID&e_id_css=group_filteredUser" target = "AdminFrame" ',10,570,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_filteredGroup',2,1,'allocate guis to groups of this admin','a','','href = "../php/mod_gui_filteredGroup.php?sessionID&e_id_css=gui_filteredGroup" target = "AdminFrame" ',10,650,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_filteredUser',2,1,'allocate guis to user of this admin','a','','href = "../php/mod_gui_filteredUser.php?sessionID&e_id_css=gui_filteredUser" target = "AdminFrame" ',10,630,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_owner',2,1,'set owner','a','','href = "../php/mod_gui_owner.php?sessionID&e_id_css=gui_owner" target = "AdminFrame" ',10,830,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> OWNER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','help',2,1,'button help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" title="help"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWFS',2,1,'load capabilities in a gui','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,850,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/WFS_Konfiguration');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWMS',2,1,'load capabilities in a gui','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,30,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWMSList',2,1,'load wms from a list','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,50,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD myWMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','logout',2,1,'Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"',180,2,24,24,1,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','myGUIlist',2,1,'go back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zur�ck zur GUI Liste"',150,2,24,24,1,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','newGui',2,1,'create a new gui','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,130,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','NEW GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','orphanWMS',2,1,'display orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID&&elementID=orphanWMS" target = "AdminFrame"',10,930,200,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','ORPHAN WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','owsproxy',2,1,'secure services','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,910,200,20,1,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','OWSPROXY','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','rename_copy_Gui',2,1,'rename and copy gui','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,470,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','RENAME COPY GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','showLoggedUser',2,1,'displays the logged admin','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','updateWMSs',2,1,'edit the elements of the gui','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,70,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','UPDATE WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_filteredGroup',2,1,'allocate user to groups where this admin is owner','a','','href = "../php/mod_user_filteredGroup.php?sessionID&e_id_css=user_filteredGroup" target = "AdminFrame" ',10,450,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> myGROUP','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_filteredGui',2,1,'allocate guis of this admin to user','a','','href = "../php/mod_user_filteredGui.php?sessionID&e_id_css=user_filteredGui" target = "AdminFrame" ',10,390,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER-> myGUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_gui',2,1,'allocate guis to user','a','','href = "../php/mod_user_gui.php?sessionID&e_id_css=user_gui" target = "AdminFrame" ',10,370,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> GUI ','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','wfs_conf',2,1,'create and edit a gazetteer module','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,870,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','WFS CONF','a','','','','AdminFrame','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_Gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'User_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'editGUI_WMS', 'file_css', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_Gui', 'file css', '../css/administration_alloc.css', 'file', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_user', 'file css', '../css/administration_alloc.css', 'a file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_Gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'group_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin2_de';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','AdminFrame',2,1,'Bereich f�r Administrationsmodule','iframe','','frameborder = "0"',200,20,800,800,0,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','CreateTreeGDE',2,1,'Ordnerbaum konfigurieren','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',8,280,190,20,5,'','Ordnerbaum konfigurieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','body',1,1,'Navigation','body','','onload=''mod_adminNavigation_init()''',0,0,180,20,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','deleteWMS',2,1,'!Vollst�ndig l�schen!','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',8,100,190,20,5,'','!Vollst�ndig l�schen!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','delete_filteredGui',2,1,'GUI l�schen','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',110,240,80,20,5,'','GUI l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editElements',2,1,'Oberfl�chenelemente editieren','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',8,260,190,20,5,'','GUI-Elemente editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editFilteredGroup',2,1,'Gruppe anlegen und editieren','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',8,400,190,20,10,'','Gruppe anlegen und editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editFilteredUser',2,1,'Benutzer anlegen und editieren','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',8,380,190,20,10,'','Benutzer anlegen und editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editGUI_WMS',2,1,'WMS GUI Einstellungen','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',8,180,190,20,5,'','WMS GUI Einstellungen','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','exportGUI',2,1,'Oberfl�che (GUI) exportieren, SQL erzeugen','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',8,300,190,20,10,'','GUI exportieren (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl�che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGoup_filteredUser',2,1,'Gruppe mit Benutzern best�cken','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',8,440,190,20,10,'','Gruppe mit Benutzern best�cken ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGroup_filteredGui',2,1,'Einzelner Gruppe mehrere Oberflaechen zuordnen','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',8,570,190,25,10,'','Einzelner Gruppe mehrere <br>GUIs zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGui_filteredGroup',2,1,'Einzelner Oberfl�che mehrere Gruppen zuordnen','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',8,605,190,25,10,'','Einzelner GUI mehrere<br> Gruppen zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGui_filteredUser',2,1,'Oberfl�che mehreren Benutzer zuordnen ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',8,535,190,25,10,'','GUI mehreren Benutzern <br> zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredUser_filteredGroup',2,1,'Benutzer in Gruppen eintragen','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,420,190,20,10,'','Benutzer in Gruppen eintragen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredUser_filteredGui',2,1,'Einem Nutzer Zugriff auf mehrere Oberfl�chen erteilen','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',8,500,190,25,10,'','Einem Nutzer Zugriff auf <br> mehrere GUIs erteilen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','gui_owner',2,1,'GUI editieren Benutzer zuordnen','a','','href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame" ',8,640,190,20,10,'','GUI editieren Benutzer zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','help',2,1,'button help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" title="help"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','layout_0',3,1,'Hintergrund WMS Verwaltung Rahmen','div','','',3,35,193,90,1,'','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','layout_1',3,1,'Hintergrund WMS Management','div','','',5,37,193,86,2,'',' WMS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','layout_1a',3,1,'Hintergrund WMS Zuordnung Rahmen','div','','',3,135,193,70,1,'','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','layout_1b',3,1,'Hintergrund WMS Zuordnung','div','','',5,137,193,66,2,'',' WMS Zuordnung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','layout_1c',3,1,'Hintergrund Oberfl�chenverwaltung Rahmen','div','','',3,215,193,130,1,'','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','layout_1d',3,1,'Hintergrund Oberfl�chenverwaltung','div','','',5,217,193,126,2,'',' GUI-Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','layout_2',3,1,'Hintergrund Benutzerverwaltung Rahmen','div','','',3,355,193,110,1,'','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','layout_3',3,1,'Hintergrund Benutzerverwaltung','div','','',5,357,193,106,2,'',' Benutzerverwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','layout_4',3,1,'Hintergrund Benutzerzugriff erteilen Rahmen','div','','',3,475,193,200,1,'','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','layout_5',3,1,'Hintergrund Benutzerzugriff erteilen','div','','',5,477,193,196,2,'',' Benutzerzugriff erteilen','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','loadWMS',2,1,'Capabilities hochladen','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',8,60,190,20,5,'','Capabilities hochladen','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','loadWMSList',2,1,'WMS in GUI einbinden','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',8,160,190,20,5,'','WMS in GUI einbinden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','logout',2,1,'Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','myGUIlist',2,1,'Zur�ck zur eigenen GUI Liste','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zur�ck zur GUI Liste"',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','newGui',2,1,'GUI erzeugen','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',8,240,85,20,5,'','GUI erzeugen','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','rename_copy_Gui',2,1,'GUI umbenennen/ kopieren','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',8,320,190,20,10,'','GUI umbenennen/kopieren','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','showLoggedUser',2,1,'Anzeige des eingeloggten Benutzers','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','updateWMSs',2,1,'Hochgeladene aktualisieren','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',8,80,190,20,5,'','Hochgeladene aktualisieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'body', 'body_css_file', '../css/admin.css', 'css-file to define the style fo the admin-gui', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin2_en';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','AdminFrame',2,1,'the frame for administration modules','iframe','','frameborder = "0"',200,20,800,800,0,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','CreateTreeGDE',2,1,'TreeGDE set up','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',8,280,190,20,5,'','TreeGDE set up','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','body',1,1,'navigation','body','','onload=''mod_adminNavigation_init()''',0,0,0,0,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','deleteWMS',2,1,'!Delete completely!','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',8,100,190,20,5,'','!Delete completely!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','delete_filteredGui',2,1,'Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',120,240,80,20,5,'','Delete GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editElements',2,1,'Edit GUI elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',8,260,190,20,5,'','Edit GUI elements','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editFilteredGroup',2,1,'Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',8,400,190,20,10,'','Create and edit group','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editFilteredUser',2,1,'Create and edit user','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',8,380,190,20,10,'','Create and edit user','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editGUI_WMS',2,1,'WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',8,180,190,20,5,'','WMS GUI settings','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','exportGUI',2,1,'export GUI, create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',8,300,190,20,10,'','Export GUI (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl�che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGoup_filteredUser',2,1,'Add several users to one group','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',8,440,190,20,10,'','Add several users to one group ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGroup_filteredGui',2,1,'Allow one group access to several GUIs','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',8,570,190,25,10,'','Allow one group access to <br> several GUIs','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGui_filteredGroup',2,1,'Allow several groups access to one GUI','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',8,605,190,25,10,'','Allow several groups access <br> to one GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGui_filteredUser',2,1,'Allow several users access to one GUI ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',8,535,190,25,10,'','Allow several users access to <br> one GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredUser_filteredGroup',2,1,'Add one user to serveral groups','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,420,190,20,10,'','Add one user to serveral groups','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredUser_filteredGui',2,1,'Allow one user to access several GUIs','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',8,500,190,25,10,'','Allow one user to access <br> several GUIs','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','gui_owner',2,1,'Edit GUI assign to user','a','','href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame"  ',8,640,190,20,10,'','Edit GUI assign to user','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','help',2,1,'button help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" title="help"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','layout_0',3,1,'WMS Management border','div','','',3,35,193,90,1,'','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','layout_1',3,1,'WMS Management caption','div','','',5,37,193,86,2,'',' WMS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','layout_1a',3,1,'Configure WMS Access border','div','','',3,135,193,70,1,'','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','layout_1b',3,1,'Configure WMS Access','div','','',5,137,193,66,2,'',' Configure WMS Access','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','layout_1c',3,1,'GUI Management border','div','','',3,215,193,130,1,'','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','layout_1d',3,1,'GUI Management caption','div','','',5,217,193,126,2,'',' GUI Management ','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','layout_2',3,1,'User Management border','div','','',3,355,193,110,1,'','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','layout_3',3,1,'User Management caption','div','','',5,357,193,106,2,'',' User Management ','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','layout_4',3,1,'Authorization background','div','','',3,475,193,190,1,'','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','layout_5',3,1,'Authorization caption','div','','',5,477,193,186,2,'',' Authorization','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','loadWMS',2,1,'Load Capabilities','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',8,60,190,20,5,'','Load Capabilities','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','loadWMSList',2,1,'Link WMS into GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',8,160,190,20,5,'','Link WMS into GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','logout',2,1,'Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','myGUIlist',2,1,'go back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zur�ck zur GUI Liste"',150,2,24,24,2,'','','img','mod_home.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','newGui',2,1,'Create new GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',8,240,110,20,5,'','Create new GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','rename_copy_Gui',2,1,'Rename/ copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',8,320,190,20,10,'','Rename / copy GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','showLoggedUser',2,1,'Logged User:','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','updateWMSs',2,1,'Update with Capabilities','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',8,80,190,20,5,'','Update Capabilities','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'body', 'body_css_file', '../css/admin.css', 'css-file to define the style fo the admin-gui', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGoup_filteredUser', 'css_file_filteredGroup_filterdUser', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGroup', 'css_filteredUser_filteredGroup', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin_de_services';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','AdminFrame',2,1,'Bereich f�r Administrationsmodule','iframe','','frameborder = "0"',210,25,800,800,12,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','CreateTreeGDE',2,1,'Ordnerbaum konfigurieren','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,516,200,20,5,'','Ordnerbaum konfigurieren','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','EditWMSMetadata',2,1,'edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,275,200,20,5,'','WMS Metadaten','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_WMS_Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','body',1,1,'Navigation','body','','onload=''mod_adminNavigation_init()''',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','deleteWFS',2,1,'WFS l�schen','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,393,200,20,5,'','WFS l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','deleteWMS',2,1,'!Vollst�ndig l�schen!','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,100,200,20,5,'','WMS l�schen!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','delete_filteredGui',2,1,'GUI l�schen','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,471,200,20,5,'','GUI l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','editElements',2,1,'Oberfl�chenelemente editieren','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,491,200,25,5,'','GUI editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','editGUI_WMS',2,1,'WMS GUI Einstellungen','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,218,200,20,5,'','WMS Einstellungen �ndern','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','exportGUI',2,1,'GUI exportieren, SQL erzeugen','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,536,200,25,10,'x','GUI exportieren (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl�che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','filteredWms_layer_topic',2,1,'allocate topics to layers of wms of this user','a','','href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ',10,295,200,20,5,'','Kategoriezuordnung','a','','','','AdminFrame','http://www.mapbender.org/index.php/Topic_/_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_Configure_WMS_Access',3,1,'Hintergrund WMS Zuordnung','div','','',1,175,210,63,2,'','WMS Zuordnung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_GUI_Management',3,1,'Oberfl�chenverwaltung','div','','',1,428,210,153,2,'','GUI Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_Metadata',3,1,'Metadateneditor Caption','div','','',1,252,210,63,2,'','Metadaten','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_WFS_Management',3,1,'WFS Verwaltung','div','','',1,330,210,82,2,'','WFS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_WMS_Management',3,1,'Dienstverwaltung Beschriftung','div','','',0,37,210,123,2,'','WMS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','help',2,1,'button help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" title="help"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWFS',2,1,'WFS Capabilities in eine GUI laden','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,353,200,20,5,'','WFS laden','a','','','','AdminFrame','http://www.mapbender.org/index.php/LoadWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWMS',2,1,'Capabilities hochladen','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,60,200,20,5,'','WMS laden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWMSList',2,1,'WMS in GUI einbinden','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,198,200,20,5,'','WMS einbinden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','logout',2,1,'Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','myGUIlist',2,1,'Zur�ck zur eigenen GUI Liste','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zur�ck zur GUI Liste"',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','newGui',2,1,'GUI erzeugen','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,451,200,20,5,'','GUI erzeugen','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','orphanWMS',2,1,'display orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID"
+target = "AdminFrame"',10,120,200,20,5,'','WMS ohne Zuordung l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','owsproxy',2,1,'secure services','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,140,200,20,10,'','OWSPROXY','a','','','','AdminFrame','http://www.mapbender.org/index.php/Owsproxy');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','rename_copy_Gui',2,1,'GUI umbenennen/ kopieren','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,561,200,20,10,'','GUI umbenennen/kopieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/RenameGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','showLoggedUser',2,1,'Anzeige des eingeloggten Benutzers','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','updateWMSs',2,1,'Hochgeladene aktualisieren','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,80,200,20,5,'','WMS aktualisieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','wfs_conf',2,1,'WFS konfigurieren','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,373,200,20,5,'','WFS konfigurieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Wfs_conf');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'EditWMSMetadata', 'file_css', '../css/metadata.css', 'css-file to use for the metadata modul', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'body', 'body_file_css', '../css/admin_service.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'filteredWms_layer_topic', 'file css', '../css/administration_alloc_4.css', 'css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'filteredWms_layer_topic', 'language', 'de', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin_en_services';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','AdminFrame',2,1,'administration frame','iframe','','frameborder = "0"',210,25,1000,800,12,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','CreateTreeGDE',2,1,'Configure TreeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,513,200,20,5,'','Configure TreeGDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','EditWMSMetadata',2,1,'edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,275,200,20,5,'','WMS Metadata','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_WMS_Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','body',1,1,'Navigation','body','','onload=''mod_adminNavigation_init()''',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','deleteWFS',2,1,'Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,393,200,20,5,'','Delete WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','deleteWMS',2,1,'!Delete completely!','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,100,200,20,5,'','!Delete completely!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','delete_filteredGui',2,1,'Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,471,200,20,5,'','Delete GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','editElements',2,1,'Edit GUI Elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,491,200,20,5,'','Edit GUI Elements','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','editGUI_WMS',2,1,'WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,218,200,20,5,'','WMS GUI settings','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','exportGUI',2,1,'Export GUI (SQL), create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,533,200,20,10,'x','Export GUI (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl�che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','filteredWms_layer_topic',2,1,'allocate topics to layers of wms of this user','a','','href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ',10,295,200,20,5,'','Allocate topics','a','','','','AdminFrame','http://www.mapbender.org/index.php/Topic_/_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_Configure_WMS_Access',3,1,'WMS Assignment','div','','',1,175,210,63,2,'','WMS Assignment','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_GUI_Management',3,1,'GUI Management','div','','',1,428,210,148,2,'','GUI Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_Metadata',3,1,'Metadata','div','','',1,252,210,63,2,'','Metadata','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_WFS_Management',3,1,'WFS Management','div','','',1,330,210,82,2,'','WFS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_WMS_Management',3,1,'WMS Management','div','','',0,37,210,123,2,'','WMS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','help',2,1,'button help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" title="help"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWFS',2,1,'Load WFS Capabilities into a GUI','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,353,200,20,5,'','Load WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/LoadWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWMS',2,1,'load Capabilities','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,60,200,20,5,'','Load Capabilities','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWMSList',2,1,'assign WMS to a GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,198,200,20,5,'','Assign WMS to a GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','logout',2,1,'Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','myGUIlist',2,1,'back to GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zur�ck zur GUI Liste"',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','newGui',2,1,'New GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,451,200,20,5,'','New GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','orphanWMS',2,1,'Delete orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID"
+target = "AdminFrame"',10,120,200,20,5,'','Delete orphaned WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','owsproxy',2,1,'secure services','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,140,200,20,10,'','OWSPROXY','a','','','','AdminFrame','http://www.mapbender.org/index.php/Owsproxy');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','rename_copy_Gui',2,1,'Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,556,200,20,10,'','Rename / copy GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/RenameGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','showLoggedUser',2,1,'show logged in user','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','updateWMSs',2,1,'Update Capabilities','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,80,200,20,5,'','Update Capabilities','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','wfs_conf',2,1,'Configure WFS','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,373,200,20,5,'','Configure WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Wfs_conf');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'EditWMSMetadata', 'file_css', '../css/metadata.css', 'css-file to use for the metadata modul', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'body', 'body_file_css', '../css/admin_service.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'filteredWms_layer_topic', 'file css', '../css/administration_alloc_4.css', 'css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'filteredWms_layer_topic', 'language', 'de', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui','switchLocale_noreload',8,1,'changes the locale without reloading the client','Set language','div','','frameborder=''0''',696,14,50,30,5,'','<form id=''form_switch_locale'' name=''form_switch_locale'' target=''parent''>
+<select id=''language'' name=''language'' onchange=''validate_locale()''>
+</select>
+</form>
+','div','mod_switchLocale_noreload.php','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'switchLocale_noreload', 'languages', 'de,en,bg,gr,nl,it,es', '' ,'var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_closetag, e_js_file) VALUES('gui1', 'popup', 6, 1, 'popup replacement', 'div', 'div', 'popup.js');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui1' AND e_id = 'wfs_gazetteer';
+DELETE FROM gui_treegde WHERE fkey_gui_id IN ('gui', 'gui1', 'admin1', 'gui2', 'wms_africa');
+-- update own applications
+Update gui_element set e_title =
+mynew.e_title from gui_element as mynew
+where gui_element.e_id = mynew.e_id
+and mynew.fkey_gui_id = 'gui'
+and gui_element.fkey_gui_id != 'gui'
+and gui_element.fkey_gui_id != 'gui1'
+and gui_element.fkey_gui_id != 'gui2'
+and gui_element.fkey_gui_id != 'gui_digitize';
+and mynew.fkey_gui_id = 'gui1'
+and mynew.fkey_gui_id = 'gui2'
+and mynew.fkey_gui_id = 'gui_digitize'
+Delete from gui_element_vars where fkey_e_id ='tabs' and var_name LIKE 'tab_titles[%';
+Update gui_element_vars set var_type='php_var' where fkey_e_id ='tabs' and var_name LIKE 'tab_ids[%' and var_type='var';
+DELETE FROM gui_element WHERE e_id = 'ajax';
+Delete from gui_element where e_id='keyHandler';
+DELETE FROM gui_element WHERE e_id = 'geometry';
+Select * from gui_element where e_mb_mod ='geometry.js' ;
+update gui_element set e_mb_mod = 'geometry.js'
+where e_id = 'digitize';
+where e_id = 'gazetteerWFS';
+where e_id = 'setSpatialRequest';
Added: branches/2.5/resources/db/mysql/utf8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql
--- branches/2.5/resources/db/mysql/utf8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql	                        (rev 0)
+++ branches/2.5/resources/db/mysql/utf8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql	2008-09-29 14:36:55 UTC (rev 3041)
@@ -0,0 +1,522 @@
+-- database changes in version 2.5
+-- notice language plpgsql has to be installed
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin_de_services', 20, '');
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin_en_services', 20, '');
+-- table mb_monitort: new columns for mb_monitor
+ALTER TABLE mb_monitor ADD COLUMN image int(11);
+ALTER TABLE mb_monitor ADD COLUMN map_url varchar(2048);
+-- WFS database handling
+-- enhancement of the datadase structure concerning WFS metadata (same solution like for WMS)
+ALTER table wfs add wfs_getcapabilities_doc text;
+ALTER table wfs add wfs_upload_url varchar(255);
+ALTER table wfs add fees varchar(255);
+ALTER table wfs add accessconstraints text;
+ALTER table wfs add individualname varchar(255);
+ALTER table wfs add positionname varchar(255);
+ALTER table wfs add providername varchar(255);
+ALTER table wfs add city varchar(255);
+ALTER table wfs add deliverypoint varchar(255);
+ALTER table wfs add administrativearea varchar(255);
+ALTER table wfs add postalcode varchar(255);
+ALTER table wfs add voice varchar(255);
+ALTER table wfs add facsimile varchar(255);
+ALTER table wfs add electronicmailaddress varchar(255);
+ALTER table wfs add wfs_mb_getcapabilities_doc text;
+ALTER table wfs add wfs_owner int(11);
+ALTER table wfs add wfs_timestamp int(11);
+ALTER table wfs add country varchar(255);
+ALTER TABLE wfs MODIFY wfs_title varchar(255) NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_title SET DEFAULT '';
+ALTER TABLE wfs MODIFY wfs_version NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_version SET DEFAULT '';
+ALTER TABLE wfs MODIFY wfs_getcapabilities NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_getcapabilities SET DEFAULT '';
+alter table wfs_featuretype add column featuretype_searchable integer default 1;
+alter table wfs_featuretype add column featuretype_abstract character varying(50);
+-- grant root access to default wfs
+UPDATE wfs SET wfs_owner = 1;
+-- new table gui_wfs_conf
+CREATE TABLE gui_wfs_conf (
+    fkey_gui_id character varying(50) DEFAULT '' NOT NULL,
+    fkey_wfs_conf_id integer DEFAULT 0 NOT NULL
+ALTER TABLE gui_wfs_conf
+    ADD CONSTRAINT pk_fkey_wfs_conf_id PRIMARY KEY (fkey_gui_id, fkey_wfs_conf_id);
+    ADD CONSTRAINT gui_wfs_conf_ibfk_1 FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
+    ADD CONSTRAINT gui_wfs_conf_ibfk_2 FOREIGN KEY (fkey_wfs_conf_id) REFERENCES wfs_conf(wfs_conf_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- insert wfs confs into gui digitize
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 1);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 3);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 4);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 2);
+-- new table wfs_featuretype_keyword:
+CREATE TABLE wfs_featuretype_keyword (
+  fkey_featuretype_id integer NOT NULL,
+  fkey_keyword_id integer NOT NULL
+ALTER TABLE wfs_featuretype_keyword
+    ADD CONSTRAINT fkey_keyword_id_fkey_featuretype_id FOREIGN KEY (fkey_keyword_id) REFERENCES keyword(keyword_id) ON UPDATE CASCADE ON DELETE CASCADE;
+    ADD CONSTRAINT fkey_featuretype_id_fkey_keyword_id FOREIGN KEY (fkey_featuretype_id) REFERENCES wfs_featuretype(featuretype_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- new table layer_load_count
+CREATE TABLE layer_load_count (
+ fkey_layer_id int4,
+ load_count int8
+-- table wfs_conf
+ALTER TABLE wfs_conf add COLUMN wfs_conf_description text;
+ALTER TABLE `wfs_conf`
+    ADD CONSTRAINT wfs_conf_ibfk_2 FOREIGN KEY (fkey_featuretype_id) REFERENCES wfs_featuretype(featuretype_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- table wfs_conf_element: change in WFS configuration: access to geometries may now be restricted
+--ALTER TABLE wfs_conf_element ADD COLUMN f_auth_varname VARCHAR(50);
+ALTER TABLE wfs_conf_element ADD COLUMN f_show_detail int4;
+ALTER TABLE wfs_conf_element ADD COLUMN f_operator VARCHAR(50);
+-- table gui_element: new column for translation
+-- ALTER TABLE gui_element ADD COLUMN e_title VARCHAR(255) NULL;
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','WFS',2,1,'edit wfs settings','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,1005,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT WFS','a','','','','AdminFrame','');
+ fkey_layer_id int(11),
+ load_count int(11)
+-- new table translation: new table for translations
+ CREATE TABLE translations
+   trs_id int(11) NOT NULL auto_increment,
+   locale varchar(8),
+   msgid varchar(512),
+   msgstr varchar(512),
+   PRIMARY KEY (trs_id)
+ CREATE INDEX msgid_idx ON translations(msgid);
+-- new function gettext for easy translations
+-- function has to be translated
+-- new entries for table translations
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Pan', 'Ausschnitt verschieben');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Display complete map', 'gesamte Karte anzeigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom in', 'In die Karte hineinzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom out', 'Aus der Karte herauszoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Back', 'Zurück');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Forward', 'Nach vorne');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Coordinates', 'Koordinaten anzeigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom by rectangle', 'Ausschnitt wählen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Redraw', 'Neu laden oder Tastatur: Leertaste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Query', 'Datenabfrage');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Logout', 'Abmelden');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'WMS preferences', 'WMS Einstellungen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS from filtered list', 'WMS von gefilteter Liste hinzufügen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set map center', 'Kartenmittelpunkt setzen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Help', 'Hilfe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Show WMS infos', 'Anzeige von WMS Informationen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Save workspace as web map context document', 'Ansicht als Web Map Context Dokument speichern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Resize Mapsize', 'Bildschirmgröße anpassen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Rubber', 'Skizze löschen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Get Area', 'Fläche berechnen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Close Polygon', 'Polygon schliessen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Move back to your GUI list', 'Zurück zur GUI Liste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Legend', 'Legende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Print', 'Druck');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Imprint', 'Impressum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Maps', 'Karten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Search', 'Suche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Meetingpoint', 'Treffpunkt');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Metadatasearch', 'Metadatensuche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS', 'WMS hinzufügen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS from List', 'WMS aus Liste hinzufügen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Change Projection', 'Projektion ändern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Digitize', 'Digitalisierung');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Overview', 'Übersichtskarte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Drag Mapsize', 'Karte vergrößern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Mapframe', 'Kartenfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Navigation Frame', 'Navigationsfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scale Select', 'Auswahl des Maßstabes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scale Text', 'Maßstab per Texteingabe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scalebar', 'Maßstabsleiste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set Background', 'Hintegrundkarte auswählen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom to Coordinates', 'Zu den Koordinaten zoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Change Password', 'Passwort ändern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Load a web map context document', 'laden eines Web Map Context Dokumentes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de ', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Pan', 'Премести областта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Display complete map', 'Покажи цялата карта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom in', 'Покажи картата в по-едър мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom out', 'Покажи картата в по-дребен мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Back', 'Назад');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Forward', 'Напред');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Coordinates', 'Координати');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom by rectangle', 'Увеличи картата в избраната област');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Redraw', 'Пречертай или от клавиатурата: празен интервал');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Query', 'Зявка към данните');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Logout', 'Изход на потребител');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'WMS preferences', 'WMS настройки');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS from filtered list', 'Добави WMS от избран списък');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Set map center', 'Постави център на карта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Help', 'Помощ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Show WMS infos', 'Покажи WMS информация');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Save workspace as web map context document', 'Запази работния документ като Web Map Context документ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Resize Mapsize', 'Напасни големината на картата');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Rubber', 'Изтрий');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Get Area', 'Изчисли площ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Close Polygon', 'Затвори полигон');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Move back to your GUI list', 'Назад към списъка с интерфейси (GUI)');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Legend', 'Легенда');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Print', 'Печат');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Imprint', 'Авторско каре');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Maps', 'Карти');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Search', 'Търсене');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Meetingpoint', 'Място на среща');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Metadatasearch', 'Търсене по метаданни');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS', 'Добави WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS from List', 'Добави WMS от списък');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Info', 'Информация');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Change Projection', 'Промени проекция');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Copyright', 'Авторско право');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Digitize', 'Дигитализиране');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Overview','Обзорна карта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Drag Mapsize', 'Промени размера на картата');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Mapframe', 'Рамка на картата');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Navigation Frame', 'Навигационна рамка');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scale Select', 'Избор на мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scale Text', 'Въведи мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scalebar', 'Мащабна скала');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Set Background', 'Избери фоново изображение');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom to Coordinates', 'Покажи картата около посочените координати');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Change Password', 'Промени парола');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Load a web map context document', 'Зареди Web Map Context документ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Logo', 'Фирмен знак');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Measure distance', 'Измери разстояние');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Pan', 'Μετακίνηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Display complete map', 'Επίδειξη Πλήρους Χάρτη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom in', 'Zoom In');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom out', 'Zoom Out');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Back', 'Πίσω');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Forward', 'Πρόσθια');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Coordinates', 'Συντεταγμένες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom by rectangle', 'Ζουμ από ορθογώνιο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Redraw', 'Απόσυρση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Query', 'Μέτρηση Εμβαδού');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Logout', 'Αποσύνδεση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'WMS preferences', 'Αλλάξτε τη διάταξη των WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS from filtered list', 'Πρόσθεση WMS από το φιλτραρισμένο κατάλογο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Set map center', 'Το καθορισμένο Κέντρο Χαρτών');
+INSERT INTO translations (locale, msgid, msgstr) VALUES  ('gr', 'Help', 'Βοήθεια');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Save workspace as web map context document', 'Ansicht als Web Map Context Dokument speichern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Rubber', 'Το λάστιχο- Τρίφτης');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Close Polygon', 'Το Κλειστό Πολύγωνο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ( 'gr', 'Move back to your GUI list', 'Παρουσίαση του GUI Καταλόγου');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Print', 'Εκτύπωση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Maps', ' Χάρτες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS', 'Πρόσθεση WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS from List', 'Πρόσθεση WMS από τον κατάλογο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Navigation Frame', 'Navigationsfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Load a web map context document', 'laden eines Web Map Context Dokumentes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Measure distance', 'Μέτρηση Απόστασης');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Meetingpoint', 'Σημείο Συνάντησης');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Info', 'Πληροφορίες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Digitize', 'Ψηφιοποίηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Change Projection', 'Αλλαγή Προβολής');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Set Background', 'Επιλογή Φόντου');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Overview', 'Προεπισκόπιση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Change Password', 'Αλλαγή Συνθηματικού');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scalebar', 'Κανόνας Κλίμακας');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr ', 'Logo', 'Λογότυπο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom to Coordinates', 'Εστίαση σε Συντεταγμένες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scale Text', 'Κείμενο Κλίμακας');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Show WMS infos', 'Προβολή WMS πληροφοριών');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Legend', 'Λεζάντα');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Search', 'Αναζήτηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Resize Mapsize', 'Αλλαγή Μεγέθους Χάρτη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Drag Mapsize', 'Αλλαγή Μεγέθους Χάρτη με Ολίσθηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Mapframe', 'Πλαίσιο Χάρτη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Get Area', 'Προβολή Περιοχής');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Imprint', 'Αποτύπωση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scale Select', 'Επιλογή Κλίμακας');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Metadatasearch', 'Αναζήτηση στα Metadata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Pan', 'Selectie verschuiven');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Display complete map', 'Hele kaart tonen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom in', 'Inzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom out', 'Uitzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Back', 'Terug');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Forward', 'Voorwaarts');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Coordinates', 'Koordinaten tonen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom by rectangle', 'Zoom rechthoek-selectie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Redraw', 'Opfrissen of toetsenbord : spatiebalk');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Query', 'Data opvragen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Logout', 'Afmelden');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'WMS preferences', 'WMS instellingen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS from filtered list', 'WMS van gefilterte lijst toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set map center', 'Kaartmiddelpunt aangeven');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Help', 'Help');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Show WMS infos', 'Tonen van WMS Informatie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Save workspace as web map context document', 'zicht als Web map context dokument bewaren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Resize Mapsize', 'beeldschermgrote aanpassen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Rubber', 'schets verwerpen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Get Area', 'oppervlakte berekenen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Close Polygon', 'Polygoon sluiten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Move back to your GUI list', 'Terug naar GUI lijst');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Legend', 'Legende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Print', 'Drukken');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Imprint', 'Impressum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Maps', 'Kaarten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Search', 'Zoek');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Meetingpoint', 'Trefpunt');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Metadatasearch', 'Zoeken naar Metadata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS', 'WMS toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS from List', 'WMS uit lijst toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Info', 'Informatie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Change Projection', 'Projektie veranderen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Digitize', 'Digitaliseren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Overview', 'overzichtskaart');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Drag Mapsize', 'Kaart vergroten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Mapframe', 'Kaartvenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Navigation Frame', 'Navigeervenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scale Select', 'Schaal selecteren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scale Text', 'Schaal via tekstingave');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scalebar', 'Schaalbalk');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set Background', 'Achtergrond selecteren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom to Coordinates', 'Naar koordinaten zoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Change Password', 'Paswoord wijzigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Load a web map context document', 'Laad een Web Map Context Dokument');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Measure distance', 'Meet afstand');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Pan', 'Sposta dettaglio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Display complete map', 'Mostra tutta la mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom in', 'Ingrandisci');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom out', 'Riduci');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Back', 'Indietro');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Forward', 'Avanti');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Coordinates', 'Mostra coordinate');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom by rectangle', 'Seleziona dettaglio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Redraw', 'Ridisegna oppure, da tastiera: spazio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Query', 'Interroga');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Logout', 'Logout');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'WMS preferences', 'Impostazioni WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS from filtered list', 'Aggiungi un WMS da una lista filtrata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set map center', 'Fissa il centro della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Help', 'Aiuto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Show WMS infos', 'Mostra informazioni sul WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Save workspace as web map context document', 'Salva vista come documento di Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Resize Mapsize', 'Adatta la dimensione della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Rubber', 'Cancella bozza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Get Area', 'Calcola area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Close Polygon', 'Chiudi poligono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Move back to your GUI list', 'Torna alla lista delle GUI');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Legend', 'Legenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Print', 'Stampa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Imprint', 'Colophon');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Maps', 'Mappe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Search', 'Cerca');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Meetingpoint', 'Punti di incontro');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Metadatasearch', 'Ricerca metadati');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS', 'Aggiungi WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS from List', 'Aggiungi WMS da lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Change Projection', 'Cambia proiezione');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Digitize', 'Digitalizza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Overview', 'Mappa di insieme');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Drag Mapsize', 'Cambia dimensione mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Mapframe', 'Quadro della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Navigation Frame', 'Quadro di navigazione');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scale Select', 'Scelta della scala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scale Text', 'Scala dei testi');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scalebar', 'Scala di riferimento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set Background', 'Seleziona mappa di sfondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom to Coordinates', 'Ingrandisci alle coordinate');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Change Password', 'Cambia password');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Load a web map context document', 'Carica un documento Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Measure distance', 'Misura distanza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Pan', 'Desplazamiento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Display complete map', 'Desplazamiento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom in', 'Zoom +');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom out', 'Zoom -');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Back', 'Zoom previo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Forward', 'Zoom siguiente');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Coordinates', 'Mostrar coordenadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom by rectangle', 'Zoom rectángulo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Redraw', 'Refrescar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Query', 'Busqueda de datos');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Logout', 'Terminar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'WMS preferences', 'Ajuste WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS from filtered list', 'Anadir WMS desde lista filtrada');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set map center', 'Centrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Help', 'Ayuda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Show WMS infos', 'Mostrar información sobre WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Save workspace as web map context document', 'Guardar vista como fichero Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Resize Mapsize', 'Modificar el tamano de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Rubber', 'Borrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Get Area', 'Calcular area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Close Polygon', 'Cerrar polígono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Move back to your GUI list', 'Volver a la lista WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Legend', 'Leyenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Print', 'Imprimir');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Imprint', 'Aviso legal');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Maps', 'Mapas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Search', 'Busqueda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Meetingpoint', 'Lugar de reunión');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Metadatasearch', 'Búsqueda de datos meta');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS', 'Añadir WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS from List', 'Añadir WMS desde lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Info', 'Informacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Change Projection', 'Cambiar projecto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Digitize', 'Digitalización');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Overview', 'Mapa de visión general');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Drag Mapsize', 'Ampilar vista de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Mapframe', 'Ventana de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Navigation Frame', 'Ventana de navigacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scale Select', 'Selecionar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scale Text', 'Teclar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scalebar', 'Fraja de escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set Background', 'Poner el fondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom to Coordinates', 'Zoom en coordenadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Change Password', 'Cambiar clave');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Load a web map context document', 'Cargar un documento de Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Measure distance', 'Medir distancias');
+-- new table gui_kml
+CREATE TABLE gui_kml (
+    kml_id int(11) NOT NULL auto_increment,
+    fkey_mb_user_id int(11) NOT NULL,
+    fkey_gui_id varchar(50) NOT NULL,
+    kml_doc text NOT NULL,
+    kml_name varchar(64),
+    kml_description text,
+    kml_timestamp int(11) NOT NULL,
+       PRIMARY KEY (kml_id)
+ALTER TABLE gui_kml
+ADD CONSTRAINT gui_kml_fkey_mb_user_id  FOREIGN KEY (fkey_mb_user_id)
+REFERENCES mb_user(mb_user_id) MATCH SIMPLE ON UPDATE CASCADE ON DELETE CASCADE;
+ADD CONSTRAINT gui_kml_id_fkey_gui_id FOREIGN KEY (fkey_gui_id)
+REFERENCES gui(gui_id) MATCH SIMPLE ON UPDATE CASCADE ON DELETE CASCADE;
+-- new SLD table
+CREATE TABLE sld_user_layer (
+    sld_user_layer_id int(11) NOT NULL auto_increment,
+    fkey_mb_user_id int(11) NOT NULL default '0',
+    fkey_layer_id int(11) NOT NULL default '0',
+    fkey_gui_id varchar(50) NOT NULL default '',
+    sld_xml text,
+    use_sld tinyint(1) default '0',
+    PRIMARY KEY (sld_user_layer_id)
+) TYPE=InnoDB;
+-- constraints for new table sld_user_layer
+ALTER TABLE sld_user_layer ADD CONSTRAINT sld_user_layer_ibfk1 FOREIGN KEY (fkey_mb_user_id) REFERENCES mb_user (mb_user_id) ON DELETE CASCADE ON UPDATE CASCADE;
+ALTER TABLE sld_user_layer ADD CONSTRAINT ADD CONSTRAINT sld_user_layer_ibfk2 FOREIGN KEY (fkey_layer_id) REFERENCES layer (layer_id) ON DELETE CASCADE ON UPDATE CASCADE;
+ALTER TABLE sld_user_layer ADD CONSTRAINT ADD CONSTRAINT sld_user_layer_ibfk3 FOREIGN KEY (fkey_gui_id) REFERENCES gui (gui_id) ON DELETE CASCADE ON UPDATE CASCADE;
+-- add sld related columns
+ALTER TABLE gui_wms ADD COLUMN gui_wms_sldurl varchar(255) NOT NULL default '';
+ALTER TABLE wms ADD COLUMN wms_supportsld boolean NULL;
+ALTER TABLE wms ADD COLUMN wms_userlayer boolean NULL;
+ALTER TABLE wms ADD COLUMN wms_userstyle boolean NULL;
+ALTER TABLE wms ADD COLUMN wms_remotewfs boolean NULL;
+-- opacity handeling
+ALTER TABLE gui_wms ADD COLUMN gui_wms_opacity INT DEFAULT 100;
+UPDATE gui_element SET e_mb_mod = 'mod_addWMSgeneralFunctions.js' WHERE e_id = 'addWMS';
+ALTER TABLE gui_element MODIFY e_js_file character varying(255);
+ALTER TABLE gui_element MODIFY e_mb_mod character varying(255);
+ALTER TABLE wms MODIFY fees text;
+ALTER TABLE wms CHANGE COLUMN wms_mb_getcapabilies_doc wms_mb_getcapabilities_doc text;
\ No newline at end of file
Added: branches/2.5/resources/db/mysql/utf8/update/update_2.5rc6_to_2.5_mysql_UTF-8.sql
--- branches/2.5/resources/db/mysql/utf8/update/update_2.5rc6_to_2.5_mysql_UTF-8.sql	                        (rev 0)
+++ branches/2.5/resources/db/mysql/utf8/update/update_2.5rc6_to_2.5_mysql_UTF-8.sql	2008-09-29 14:36:55 UTC (rev 3041)
@@ -0,0 +1 @@
Added: branches/2.5/resources/db/mysql/utf8/update/update_guis_2.4.5_to_2.5_mysql_UTF-8.sql
--- branches/2.5/resources/db/mysql/utf8/update/update_guis_2.4.5_to_2.5_mysql_UTF-8.sql	                        (rev 0)
+++ branches/2.5/resources/db/mysql/utf8/update/update_guis_2.4.5_to_2.5_mysql_UTF-8.sql	2008-09-29 14:36:55 UTC (rev 3041)
@@ -0,0 +1,901 @@
+-- update of mapbender guis
+-- gui / gui1 / gui2 / gui_digitize
+-- admin1 / admin2_de / admin2_de / admin_de_services / admin_en_services
+-- Mapbender Test for Version: 2.5
+-- 2007-11-29
+-- notice: this guis are not all working properly
+-- the guis contain the e_title informations fpor i18n
+-- these sql are for developers to get the guis working
+Delete from gui_element where fkey_gui_id ='gui';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','FeatureInfoRedirect',2,1,'redirect featureInfoRequests in an iframe for each wms','Info','iframe','../html/mod_blank.html','frameborder="0"',83,-17,1,1,0,'','','iframe','mod_featureInfoRedirect.php','','','','http://www.mapbender.org/index.php/FeatureInfoRedirect');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','WMS_preferences',2,1,'configures the preferences of each loaded wms','WMS preferences','img','../img/button_gray/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',540,10,24,24,1,'','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_gray/add_off.png','onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',515,10,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','back',2,1,'History.back()','Back','img','../img/button_gray/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"',360,10,24,24,1,'','','','mod_back.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','body',1,1,'body (obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','featureInfo1',2,0,'FeatureInfoRequest','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')"',425,10,24,24,1,'','','','mod_featureInfoTunnel.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfoTunnel');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','forward',2,1,'History.forward()','Forward','img','../img/button_gray/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" ',385,10,24,24,1,'','','','mod_forward.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','gazetteerMetadata',2,1,'gazetteer for metadata','Metadatasearch','iframe','../php/mod_gazetteerMetadata.php?sessionID&target=mapframe1,overview','frameborder = "0"',1,1,1,1,4,'visibility:hidden;','','iframe','','','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','Search','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','geometry.js','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" ',620,10,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','highlightPOI',2,1,'highlight 1 to n pois in your gui with a Symbol and a special text','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_highlightPOI.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','imprint',2,1,'Information about the owner of the gui','Imprint','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_back',3,1,'layout, background for buttons','','div','','',360,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_featureInfo',3,1,'layout, background for FeatureInfo','','div','','',425,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_help',3,1,'layout, background for Help-button','','div','','',620,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_logout',3,1,'layout, background for Logout-button','','div','','',660,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_metadata',3,1,'layout, background for Metadata','','div','','',580,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_wms',3,1,'layout, background for wms','','div','','',490,10,76,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_zoom',3,1,'layout, background for Zoom-button','','div','','',220,10,126,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','loadData',2,1,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','logo',2,1,'Logo','Logo','img','../img/mapbender_logo.png','',20,20,180,26,5,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' ',660,10,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','mapframe1',2,1,'frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',230,55,500,450,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','meetingPoint',2,1,'create a meeting point','Meetingpoint','iframe','../php/mod_meetingPoint.php?sessionID','frameborder = "0" ',0,0,NULL ,NULL ,4,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_gray/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_gray/metadata_over.png"'' onmouseout=''this.src="../img/button_gray/metadata_off.png"'' ',580,10,24,24,1,'','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,0,0,0,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',30,65,150,130,100,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','pan1',2,1,'pan','Pan','img','../img/button_gray/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')" ',270,10,24,24,1,'','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','printPDF',2,1,'pdf print','Print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_gray/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')" ',295,10,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','setBBOX',2,0,'set extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','setBackground',2,1,'switch background-wms','Set Background','form','','',30,210,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','showCoords_div',2,1,'displays coodinates by onmouseover','Coordinates','img','../img/button_gray/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ',450,10,24,24,1,'','','','mod_coords_div.php','','mapframe1','dependendDiv','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','tabs',2,1,'vertical tabs to handle iframes','','div','','',10,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2','Maps','iframe','../html/mod_treefolder2.php?sessionID','frameborder = "0" ',10,220,200,300,NULL ,'visibility:visible','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_gray/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)" ',320,10,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_gray/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' ',220,10,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_gray/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''',245,10,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_all', '0', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_group', '0', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_gui', '0', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'gazetteerWFS', 'wfsConfIdString', '1', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_height', '14', 'height of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_width', '14', 'width of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_ccs_file', '../css/meetingPoint.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_format', 'prompt', 'decide which format to choose (email, prompt)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_subject', 'Ein Treffpunkt wurde erzeugt. Folgen Sie dem Link!', 'if you choose format email, define the text for the subject', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_height', '14', 'height of the meetingPoint_icon', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_icon', '../img/redball.gif', 'path to meetingPoint image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_max_characters', '70', 'define the maximum length of the text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_please_click', 'Please click in  the map to define the meeting point position!', 'text to show if no clickposition is set', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_style', 'background-color:white;font-weight: bold;color:red;font-family:Arial;', 'style to display the meetingPoint text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_width', '14', 'width of the meetingPoint_icon', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[5]', '160', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[6]', '280', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[5]', 'meetingPoint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[6]', 'gazetteerMetadata', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_prefix', '  ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'menu', 'opacity_up,opacity_down,zoom,metainfo,hide,wms_up,wms_down,layer_up,layer_down,remove', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'metadatalink', 'false', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui1';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','WMS_preferences',2,1,'configure the preferences of each loaded wms','WMS preferences','img','../img/button_blink_red/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',670,60,24,24,1,'','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_blink_red/add_off.png','onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',645,60,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMSfromList',2,1,'add a WMS to the running application from a list','Adding WMS from List','img','../img/button_blink_red/addlist_off.png','onclick=''window.open("../javascripts/mod_addWMSfromList.php?sessionID","printWin","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',595,60,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',620,60,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','back',2,1,'History.back()','Back','img','../img/button_blink_red/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" ',400,60,24,24,1,'','','','mod_back.php','','mapframe1,overview','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','body',1,1,'body (obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','center1',2,1,'Center button','Set map center','img','../img/button_blink_red/center_off.png','onmouseover = "mb_regButton(''init_gui1_center'')" ',310,60,24,24,1,'','','','mod_center1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','changeEPSG',2,1,'change EPSG, Postgres required, overview is targed for full extent','Change Projection','iframe','../php/mod_changeEPSG.php?sessionID','scrolling="no" frameborder=''0'' ',432,25,107,24,1,'','','iframe','','','overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','changePassword_button',2,1,'button: change password of logged user','Change Password','img','../img/button_blink_red/change_password_off.png','onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0'' onmouseover=''this.src="../img/button_blink_red/change_password_over.png"'' onmouseout=''this.src="../img/button_blink_red/change_password_off.png"'' ',750,60,24,24,1,'cursor:hand','','','','','','','http://www.mapbender.org/index.php/ChangePassword');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','closePolygon',3,1,'close Polygon ','Close Polygon','div','','',0,0,0,0,0,'','','div','mod_closePolygon.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',-59,1,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',-59,1,0,0,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','featureInfo1',2,1,'FeatureInfoRequest','Query','img','../img/button_blink_red/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')" ',465,60,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','forward',2,1,'History.forward()','Forward','img','../img/button_blink_red/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" ',425,60,24,24,1,'','','','mod_forward.php','','mapframe1,overview','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','getArea',3,1,'Calculation of area, Postgis required','Get Area','div','','',0,0,0,0,0,'','','div','mod_getArea.php','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','help',2,1,'button help','Help','img','../img/button_blink_red/help_off.png','onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")''',790,60,24,24,1,'','','','','','','','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','help1',2,1,'button help','Help','img','../img/button_blink_red/help_off.png','onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")''',790,60,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/help');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','highlightPOI',2,1,'highlight 1 to n pois in your gui with a Symbol and a special text','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_highlightPOI.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','layout_1',3,1,'layout, background for buttons','','div','','',208,58,670,28,0,'background-color:#FFFFFF;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&wms_legend = yes','frameborder=''0''',-59,200,180,600,3,'','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','loadData',2,1,'IFRAME to load data','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','loadwmc',2,1,'load workspace from WMC','Load a web map context document','img','../img/button_blink_red/wmc_load_off.png','onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',895,60,24,24,1,'','','','mod_loadwmc.php','','mapframe1','','http://www.mapbender.org/index.php/LoadWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','logout',2,1,'Logout','Logout','img','../img/button_blink_red/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blink_red/logout_over.png"'' onmouseout=''this.src="../img/button_blink_red/logout_off.png"'' ',830,60,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',-59,1,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','mapframe1',2,1,'Frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',220,105,625,400,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','measure',2,1,'Measure','Measure distance','img','../img/button_blink_red/measure_off.png','onmouseover = "mb_regButton(''init_mod_measure'')"',515,60,24,24,1,'','','','mod_measure.php','','mapframe1','','http://www.mapbender.org/index.php/Measure');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_blink_red/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_blink_red/metadata_over.png"'' onmouseout=''this.src="../img/button_blink_red/metadata_off.png"'' ',710,60,24,24,1,'','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,0,0,10,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',15,25,150,150,2,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','pan1',2,1,'pan','Pan','img','../img/button_blink_red/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')"',260,60,24,24,1,'','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','print1',2,0,'start print GUI','Print','img','../img/button_blink_red/print_off.png','onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID","printWin","width=300, height=400, resizable=yes ")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',555,60,24,24,1,'','','','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','printPDF',2,1,'start print GUI','Print','img','../img/button_blink_red/print_off.png','onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF_b.conf","printWin","width=180, height=200, resizable=yes ")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',555,60,24,24,1,'','','','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','repaint',2,1,'refresh a mapobject','Redraw','img','../img/button_blink_red/repaint_off.png','onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)'' ',360,60,24,24,1,'','','','mod_repaint.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','rubber',3,1,'deletes temporary (digitized) objects','Rubber','div','','',0,0,0,0,0,'','','div','mod_rubber.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',0,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','savewmc',2,1,'save workspace as WMC','Save workspace as web map context document','img','../img/button_blink_red/wmc_save_off.png','onclick=''mod_savewmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',870,60,24,24,1,'','','','mod_savewmc.php','','mapframe1','','http://www.mapbender.org/index.php/SaveWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scaleSelect',2,1,'Scale-Selectbox','Scale Select','select','','onchange=''mod_scaleSelect(this)''',555,25,100,20,1,'','<option value = ''''>Scale</option> <option value=''100''>1 : 100</option> <option value=''250''>1 : 250</option> <option value=''500''>1 : 500</option> <option value=''1000''>1 : 1000</option> <option value=''2500''>1 : 2500</option> <option value=''5000''>1 : 5000</option> <option value=''10000''>1 : 10000</option> <option value=''25000''>1 : 25000</option> <option value=''30000''>1 : 30000</option> <option value=''50000''>1 : 50000</option> <option value=''75000''>1 : 75000</option> <option value=''100000''>1 : 100000</option> <option value=''200000''>1 : 200000</option> <option value=''300000''>1 : 300000</option> <option value=''400000''>1 : 400000</option> <option value=''500000''>1 : 500000</option> <option value=''600000''>1 : 600000</option> <option value=''700000''>1 : 700000</option> <option value=''800000''>1 : 800000</option> <option value=''900000''>1 : 900000</option> <option value=''1000000''>1 : 1000000</option>','select','mod_scaleSel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scaleText',2,1,'Scale-description field','Scale Text','form','','onsubmit=''return mod_scaleText()''',672,25,100,30,0,'','<input type="text">','form','mod_scaleText.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scalebar',2,1,'scalebar','Scalebar','div','','',0,0,0,0,0,'','','div','mod_scalebar.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_blink_red/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')"',285,60,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBBOX',2,1,'set Extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBackground',2,0,'switch background-wms','Set Background','form','','',15,190,0,0,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBackground_all',2,0,'switch all background-wms','Set Background','form','','',157,190,40,20,1,'','<input type=''checkbox'' onclick=''mod_setBackground_all_init(this)''> <font face="Arial, sans-serif" size="2">all</font>','form','mod_setBackground_all.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setPOI2Scale',2,1,'zoom to a poi (get-parameter)','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_setPOI2Scale.php','','mapframe1','','http://www.mapbender.org/index.php/Mod_setPoi2Scale');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setScaleHint',1,0,'set scaleHint for mapframes','','div','','',1,1,1,1,0,'visibility:hidden;','','div','mod_scaleHint.php','','mapframe1,100,10000000','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','showCoords_div',2,1,'displays coordinates by onmouseover','Coordinates','img','../img/button_blink_red/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ',490,60,24,24,1,'','','','mod_coords_div.php','','mapframe1','','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeConfGDE',2,0,'configurable directory tree','Maps','iframe','../php/mod_treefolderClient.php?sessionID','frameborder = "0" ',0,180,250,500,0,'visibility:visible','','iframe','mod_treeConf.js','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeGDE_1',2,0,'directory tree, checkbox for visible, checkbox for querylayer, no immediate refreshing, with nested layers','Maps','iframe','../html/mod_sync_treefolder_1.html','frameborder = "0" ',0,180,250,500,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','wfs_gazetteer',2,0,'gazetteer using wfs','Search','iframe','../php/mod_wfs_gazetteer.php?sessionID&color=255,0,255','frameborder = "0" ',-50,490,250,300,0,'visibility:visible','','iframe','','','mapframe1,overview','wfs','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomCoords',2,1,'zoom to coordinate','Zoom to Coordinates','iframe','../php/mod_zoomCoords_en.php?sessionID','frameborder = "0" ',205,7,220,45,0,'','','iframe','','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_blink_red/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)" ',335,60,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_blink_red/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' ',210,60,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_blink_red/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' ',235,60,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_db', '0', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_height', '25', 'height of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_width', '25', 'width of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'css_file_legend', '../css/legend.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'stickylegend', 'true', 'parameter to decide wether the legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'logout', 'logout_location', 'http://www.mapbender.org/', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'setPOI2Scale', 'mod_setPOI2Scale_defScale', '5000', 'default scale', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'menu', '', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui2';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','WMS_preferences',2,1,'configures the preferences of each loaded wms','WMS preferences','img','../img/button_blue/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''',604,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_blue/add_off.png','onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''',580,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blue/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''',553,40,28,28,1,'filter:Chroma(color=#C2CBCF);','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','back',2,1,'History.back()','Back','img','../img/button_blue/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"',398,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_back.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','body',1,1,'body
+(obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'background-image:url(../img/background_yellow.jpg);background-repeat:repeat-x;','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','center1',2,1,'Center button','Set map center','img','../img/button_blue/center_off.png','onmouseover = "mb_regButton(''init_gui1_center'')"',308,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_center1.php','','mapframe1','','http://www.mapbender.org/index.php/ReCenter');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','changePassword_button',2,1,'button: change password of logged user','Change Password','img','../img/button_blue/change_password_off.png','onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0''
+onmouseover=''this.src="../img/button_blue/change_password_over.png"'' onmouseout=''this.src="../img/button_blue/change_password_off.png"''',668,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','','','http://www.mapbender.org/index.php/ChangePassword');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','closePolygon',3,1,'close Polygon ','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_closePolygon.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#799FEB; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dynamicOverview',2,1,'oveview acts in accordance with main mapframe','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','mod_dynamicOverview.php','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','featureInfo1',2,0,'FeatureInfoRequest','Query','img','../img/button_blue/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','Query','img','../img/button_blue/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')"',461,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_featureInfoTunnel.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfoTunnel');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','forward',2,1,'History.forward()','Forward','img','../img/button_blue/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()"',423,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_forward.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','Search','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','geometry.js','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','getArea',3,1,'Calculation of area, Postgis required','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_getArea.php','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','header_yellow',2,0,'header','','img','../img/header_yellow.jpg','',-1,-1,833,75,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','help',2,1,'button help','Help','img','../img/button_blue/help_off.png','onmouseover = "mb_regButton(''init_help'')"',693,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','imprint',2,1,'Information about the owner of the gui','Imprint','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','layout_linie',3,0,'layout','','div','','',1,70,830,1,1,'background-color:#799FEB;font-size:1px;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','layout_linie2',3,0,'layout','','div','','',1,35,830,1,1,'background-color:#799FEB;font-size:1px;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','loadData',2,1,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','loadwmc',2,1,'load workspace from WMC','Load a web map context document','img','../img/button_blue/wmc_load_off.png','onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");''',758,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_loadwmc.php','','mapframe1','','http://www.mapbender.org/index.php/LoadWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','logo',2,1,'Logo','Logo','img','../img/mapbender_oo.png','',10,35,129,32,5,'filter:Chroma(color=#C2CBCF);','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','logout',2,1,'Logout','Logout','img','../img/button_blue/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blue/logout_over.png"'' onmouseout=''this.src="../img/button_blue/logout_off.png"''',798,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','mapframe1',2,1,'frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',213,90,608,467,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','measure',2,1,'Measure','Measure distance','img','../img/button_blue/measure_off.png','onmouseover = "mb_regButton(''init_mod_measure'')"',513,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_measure.php','','mapframe1','','http://www.mapbender.org/index.php/Measure');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_blue/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0''
+onmouseover=''this.src="../img/button_blue/metadata_over.png"'' onmouseout=''this.src="../img/button_blue/metadata_off.png"''',643,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,0,0,0,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>
+<div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>
+<div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>
+<div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div>
+<div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div>
+<div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>
+<div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>
+<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',9,80,185,130,100,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','pan1',2,1,'pan','Pan','img','../img/button_blue/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')"',258,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','printPDF',2,1,'pdf print','Print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','repaint',2,1,'refresh a mapobject','Redraw','img','../img/button_blue/repaint_off.png','onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)''',358,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_repaint.php','','mapframe1','','http://www.mapbender.org/index.php/Repaint');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','resizeMapsize',2,1,'resize mapsize to browser window size','Resize Mapsize','img','../img/button_blink_red/resizemapsize_off.png','onclick = "adjustDimension()"
+onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',838,40,24,24,3,'filter:Chroma(color=#C2CBCF);','','','mod_resize_mapsize.php','','mapframe1','','http://www.mapbender.org/index.php/ResizeMapsize');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','rubber',3,1,'deletes temporary (digitized) objects','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_rubber.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','savewmc',2,1,'save workspace as WMC','Save workspace as web map context document','img','../img/button_blue/wmc_save_off.png','onclick=''mod_savewmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',733,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_savewmc.php','','mapframe1','','http://www.mapbender.org/index.php/SaveWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_blue/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')"',283,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','setBBOX',2,0,'set extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','setBackground',2,1,'switch background-wms','Set Background','form','','',10,218,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','showCoords_div',2,1,'displays coodinates by onmouseover','Coordinates','img','../img/button_blue/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')"',488,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_coords_div.php','','mapframe1','dependendDiv','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','tabs',2,1,'vertical tabs to handle iframes','','div','','',2,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2','Maps','iframe','../html/mod_treefolder2.php?sessionID','frameborder = "0" ',10,220,200,300,NULL ,'visibility:visible','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_blue/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"',333,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_blue/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)''',203,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_blue/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''',231,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_class_bg', 'body{background-color: #FEF8D4;}', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_minScale', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_startExtent', '-24.5,32,34.5,71', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_useMaxExtent', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_wmsIndex', '0', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_zoomFactor', '5', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'gazetteerWFS', 'wfsConfIdString', '1', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_height', '-35', 'to adjust the height of the mapframe on the bottom of the window', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_width', '-45', 'to adjust the width of the mapframe on the right side of the window', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'resize_option', 'button', 'auto (autoresize on load), button (resize by button)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'sandclock', 'mod_sandclock_image', '../img/sandclock_oo.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_prefix', '  ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid #FDCC1A;font-size:12;color:#FFFFFF;background-color:#799FEB;cursor:pointer;margin-top:-3px; padding-top:3px;padding-left:4px;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'menu', 'opacity_up,opacity_down,zoom,metainfo,hide,wms_up,wms_down,layer_up,layer_down,remove', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui_digitize';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','FeatureInfoRedirect',2,0,'redirect featureInfoRequests in an iframe for each wms','Info','iframe','../html/mod_blank.html','frameborder="0"',83,-17,1,1,NULL ,'','','iframe','mod_featureInfoRedirect.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','WMS_preferences',2,1,'configures the preferences of each loaded wms','WMS preferences','img','../img/button_gray/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");''',540,10,24,24,1,'','','','','','mapframe1,treeGDE','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_gray/add_off.png','onclick=''mod_addWMS()''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");''',515,10,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','back',2,1,'History.back()','Back','img','../img/button_gray/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"',360,10,24,24,1,'','','','mod_back.php','','mapframe1,overview0','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','body',1,1,'body (obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','closePolygonExt',3,0,'close Polygon ','Close Polygon','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_closePolygonExt.js','','mapframe1','setExtRequest','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_copyright.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','digitize',2,1,'Digitize tool.','Digitize','iframe','../javascripts/mod_digitize_tab.php?sessionID','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','geometry.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','featureInfo1',2,0,'FeatureInfoRequest','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')"',425,10,24,24,1,'','','','mod_featureInfoTunnel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','forward',2,1,'History.forward()','Forward','img','../img/button_gray/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()"',385,10,24,24,1,'','','','mod_forward.php','','mapframe1,overview0','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','Search','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','geometry.js','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',620,10,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','imprint',2,1,'Information about the owner of the gui','Imprint','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','initWmc',2,0,'initialise client with wmc','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_initWmc.php','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_1',3,0,'Warning notice','','div','','',150,250,300,16,100,'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none;','Development Version - Work in Progress!','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_back',3,1,'layout, background for buttons','','div','','',360,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_featureInfo',3,1,'layout, background for FeatureInfo','','div','','',425,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_help',3,1,'layout, background for Help-button','','div','','',620,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_logout',3,1,'layout, background for Logout-button','','div','','',660,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_metadata',3,1,'layout, background for Metadata','','div','','',580,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_wms',3,1,'layout, background for wms','','div','','',490,10,76,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_zoom',3,1,'layout, background for Zoom-button','','div','','',220,10,126,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','loadData',2,1,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','loadwmc',2,0,'load workspace from WMC','Load a web map context document','img','../img/button_wmc/wmc_load.png','onclick=''mod_loadwmc()'' onmouseover=''mod_loadwmc_init(this)''',760,10,24,24,1,'','','','mod_loadwmc.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','logo',2,1,'Logo','','img','../img/mapbender_logo.png','',20,20,180,26,5,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''
+onmouseover=''this.src="../img/button_gray/logout_over.png"''
+onmouseout=''this.src="../img/button_gray/logout_off.png"''',660,10,24,24,1,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr>
+<script language="javascript">
+mb_registerSubFunctions("mod_mapbender()");
+function mod_mapbender(){
+document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90;
+document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1;
+</script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','mapframe1',2,1,'frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',230,55,500,450,2,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_gray/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''"
+border=''0''
+onmouseover=''this.src="../img/button_gray/metadata_over.png"''
+onmouseout=''this.src="../img/button_gray/metadata_off.png"''',580,10,24,24,1,'','','','mod_displayObj.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,NULL ,NULL ,NULL ,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>
+<div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>
+<div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>
+<div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div>
+<div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div>
+<div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>
+<div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>
+<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>
+','div','mod_navFrame.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',30,65,150,130,100,'','','iframe','','mod_box1.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','pan1',2,1,'pan','Pan','img','../img/button_gray/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')"',270,10,24,24,1,'','','','mod_pan.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','printPDF',2,1,'pdf print','Print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','rubberExt',3,1,'deletes temporary (digitized) objects','Rubber','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_rubberExt.js','','mapframe1','setExtRequest','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','savewmc',2,0,'save workspace as WMC','Save workspace as web map context document','img','../img/button_wmc/wmc_save.png','onclick=''mod_savewmc()'' onmouseover=''mod_savewmc_init(this)''',730,10,24,24,1,'','','','mod_savewmc.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','scaleSelect',2,0,'Scale-Selectbox','Scale Select','select','','onchange=''mod_scaleSelect(this)''',555,25,100,20,1,'','<option value = ''''>Scale</option>
+<option value=''100''>1 : 100</option>
+<option value=''250''>1 : 250</option>
+<option value=''500''>1 : 500</option>
+<option value=''1000''>1 : 1000</option>
+<option value=''2500''>1 : 2500</option>
+<option value=''5000''>1 : 5000</option>
+<option value=''10000''>1 : 10000</option>
+<option value=''25000''>1 : 25000</option>
+<option value=''30000''>1 : 30000</option>
+<option value=''50000''>1 : 50000</option>
+<option value=''75000''>1 : 75000</option>
+<option value=''100000''>1 : 100000</option>
+<option value=''200000''>1 : 200000</option>
+<option value=''300000''>1 : 300000</option>
+<option value=''400000''>1 : 400000</option>
+<option value=''500000''>1 : 500000</option>
+<option value=''600000''>1 : 600000</option>
+<option value=''700000''>1 : 700000</option>
+<option value=''800000''>1 : 800000</option>
+<option value=''900000''>1 : 900000</option>
+<option value=''1000000''>1 : 1000000</option>','select','mod_scaleSel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_gray/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')"',295,10,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setBBOX',2,0,'set extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setBackground',2,1,'switch background-wms','Set Background','form','','',30,210,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12''
+name=''mod_setBackground_list''
+onchange=''mod_setBackground_change(this)'' ><option
+value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setSpatialRequest',2,1,'Spatial Request','','div','','',1,1,1,1,1,'visibility:hidden;','','div','../javascripts/mod_wfs_SpatialRequest.php','geometry.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','showCoords_div',2,1,'displays coodinates by onmouseover','Coordinates','img','../img/button_gray/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ',450,10,24,24,1,'','','','mod_coords_div.php','','mapframe1','dependendDiv','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','showLoggedUser',2,0,'Displays current user','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','tabs',1,1,'vertical tabs to handle iframes','','div','','',10,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfs',2,1,'wfs request and result handling','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','wfs.js','../extensions/wz_jsgraphics.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfs_conf',2,1,'get all wfs_conf-params','','iframe','../php/mod_wfs.php','frameborder = "0"',1,1,1,1,0,'visibility:hidden','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfsresult',2,1,'display the list of wfs results','','iframe','../html/mod_blank.html','frameborder = "0"',10,730,200,150,4,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_gray/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"',320,10,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_gray/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)''',220,10,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_gray/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''',245,10,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'cssUrl', '../css/digitize.css', 'url to the style sheet of the mapframe', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'digitize_conf_filename', 'digitize_default.conf', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'text css', ' body{
+ font-family: Arial, Helvetica, sans-serif;
+ font-size : 12px;
+ color: #ff00ff;
+ background-color: #ffffff;
+ margin-top: 0px;
+ margin-left: 0px;
+ .button{
+ height: 18px;
+ width: 32px;
+', 'text css', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'wfsCssUrl', '../css/mapbender.css', 'var', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'gazetteerWFS', 'wfsConfIdString', '1,2,3,4', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'useUsemap', '0', '"1" adds a usemap to each geometry; the geometry will be highlighted onMouseOver. Every other value will skip the usemap.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'wfs_conf_filename', 'wfs_default.conf', 'location and name of the WFS configuration file', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'open_tab', '5', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[5]', '250', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[5]', 'digitize', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_prefix', '  ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;padding-left:8px;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'menu', '', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'wfs', 'displayWfsResultList', '1', '', 'var');
+Delete from gui_element where fkey_gui_id ='admin1';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','AdminFrame',2,1,'the frame for administration modules','','iframe','','frameborder = "0"',220,20,800,800,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','CreateTreeGDE',2,1,'create a foldertree for a individual geodataexplorer','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,810,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','CREATE TREE_GDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','EditWMSMetadata',2,1,'edit the metadata of wms','edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,950,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT WMS-METADATA','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_Gui',2,1,'allocate groups to guis','','a','','href = "../php/mod_group_gui.php?sessionID&e_id_css=Group_Gui" target = "AdminFrame" ',10,610,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_User',2,1,'allocate groups to user','','a','','href = "../php/mod_group_user.php?sessionID&e_id_css=Group_User" target = "AdminFrame" ',10,550,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','GROUP -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_filteredGui',2,1,'allocate Groups to the guis of this admin','','a','','href = "../php/mod_group_filteredGui.php?sessionID&e_id_css=Group_filteredGui" target = "AdminFrame" ',10,710,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Gui_Group',2,1,'allocate guis to groups','','a','','href = "../php/mod_gui_group.php?sessionID&e_id_css=Gui_Group" target = "AdminFrame" ',10,250,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Gui_User',2,1,'allocate a gui to user','','a','','href = "../php/mod_gui_user.php?sessionID&e_id_css=Gui_User" target = "AdminFrame" ',10,190,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','User_Group',2,1,'allocat user to groups','','a','','href = "../php/mod_user_group.php?sessionID&e_id_css=User_Group" target = "AdminFrame" ',10,430,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','body',1,1,'navigation','','body','','onload=''mod_adminNavigation_init()''',0,0,0,0,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteGui',2,1,'delete gui','','a','','href = "../php/mod_deleteGUI.php?sessionID" target = "AdminFrame" ',10,150,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteWFS',2,1,'delete WFS','Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,890,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteWMS',2,1,'delete wms','Delete WMS completely','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,110,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','delete_filteredGui',2,1,'delete guis of this admin','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,790,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editElements',2,1,'edit gui elements','Edit GUI elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,170,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','EDIT GUI-ELEMENTS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editFilteredGroup',2,1,'edit group of this admin','Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',10,530,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editFilteredUser',2,1,'save, edit, delete user where this admin is owner','Create and edit user','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',10,350,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editGUI_WMS',2,1,'edit the elements of the gui','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,90,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT GUI-WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editGroup',2,1,'edit group','','a','','href = "../php/mod_editGroup.php?sessionID" target = "AdminFrame" ',10,510,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editUser',2,1,'save, edit, delete user','','a','','href = "../php/mod_editUser.php?sessionID" target="AdminFrame"',10,330,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','exportGUI',2,1,'export gui, create SQLL','export GUI, create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,310,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EXPORT GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGoup_filteredUser',2,1,'allocate the groups of this admin to user where the admin is owner','Add several users to one group','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',10,590,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> myUSER ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_Gui',2,1,'allocate groups of this admin to guis','','a','','href = "../php/mod_filteredGroup_Gui.php?sessionID&e_id_css=filteredGroup_Gui" target = "AdminFrame" ',10,750,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_User',2,1,'allocate groups of this admin to user','','a','','href = "../php/mod_filteredGroup_User.php?sessionID&e_id_css=filteredGroup_User" target = "AdminFrame" ',10,690,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_filteredGui',2,1,'allocate groups of this admin to guis of this admin','Allow one group access to several GUIs','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',10,730,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_Group',2,1,'allocate guis to groups','','a','','href = "../php/mod_filteredGui_group.php?sessionID&e_id_css=filteredGui_Group" target = "AdminFrame" ',10,270,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> GROUP ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_filteredGroup',2,1,'allocate guis of this admin to groups where this admin is owner','Allow several groups access to one GUI','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',10,290,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_filteredUser',2,1,'allocate the user where the admin is owner to his guis ','Allow several users access to one GUI ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',10,230,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_user',2,1,'allocate the guis of this admin to a user','','a','','href = "../php/mod_filteredGui_User.php?sessionID&e_id_css=filteredGui_user" target = "AdminFrame" ',10,210,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> USER ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_Group',2,1,'allocate user of this admin to groups','','a','','href = "../php/mod_filteredUser_Group.php?sessionID&e_id_css=filteredUser_Group" target = "AdminFrame" ',10,670,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_Gui',2,1,'allocate user of this admin to guis','','a','','href = "../php/mod_filteredUser_Gui.php?sessionID&e_id_css=filteredUser_Gui" target = "AdminFrame" ',10,770,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_filteredGroup',2,1,'allocate user where this admin is owner to groups where this admin is owner','Add one user to serveral groups','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',10,490,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_filteredGui',2,1,'allocate admins user to guis of this admin','Allow one user to access several GUIs','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',10,410,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','getStyles',2,0,'load styles from wms','','a','','href = "../php/mod_getStyles.php?sessionID" target = "AdminFrame" ',10,890,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GET_STYLES','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','group_filteredUser',2,1,'allocate groups to user where this admin is owner','','a','','href = "../php/mod_group_filteredUser.php?sessionID&e_id_css=group_filteredUser" target = "AdminFrame" ',10,570,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_filteredGroup',2,1,'allocate guis to groups of this admin','','a','','href = "../php/mod_gui_filteredGroup.php?sessionID&e_id_css=gui_filteredGroup" target = "AdminFrame" ',10,650,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_filteredUser',2,1,'allocate guis to user of this admin','','a','','href = "../php/mod_gui_filteredUser.php?sessionID&e_id_css=gui_filteredUser" target = "AdminFrame" ',10,630,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_owner',2,1,'set owner','Edit GUI assign to user','a','','href = "../php/mod_gui_owner.php?sessionID&e_id_css=gui_owner" target = "AdminFrame" ',10,830,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> OWNER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWFS',2,1,'load capabilities in a gui','Load WFS Capabilities into a GUI','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,850,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/WFS_Konfiguration');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWMS',2,1,'load capabilities in a gui','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,30,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWMSList',2,1,'load wms from a list','Link WMS into GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,50,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD myWMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,1,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','myGUIlist',2,1,'go back to your GUI list','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' ',150,2,24,24,1,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','newGui',2,1,'create a new gui','Create new GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,130,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','NEW GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','orphanWMS',2,1,'display orphaned WMS','Delete orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID&&elementID=orphanWMS" target = "AdminFrame"',10,930,200,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','ORPHAN WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','owsproxy',2,1,'secure services','OWSPROXY','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,910,200,20,1,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','OWSPROXY','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','rename_copy_Gui',2,1,'rename and copy gui','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,470,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','RENAME COPY GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','showLoggedUser',2,1,'displays the logged admin','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','updateWMSs',2,1,'edit the elements of the gui','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,70,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','UPDATE WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_filteredGroup',2,1,'allocate user to groups where this admin is owner','','a','','href = "../php/mod_user_filteredGroup.php?sessionID&e_id_css=user_filteredGroup" target = "AdminFrame" ',10,450,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> myGROUP','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_filteredGui',2,1,'allocate guis of this admin to user','','a','','href = "../php/mod_user_filteredGui.php?sessionID&e_id_css=user_filteredGui" target = "AdminFrame" ',10,390,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER-> myGUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_gui',2,1,'allocate guis to user','','a','','href = "../php/mod_user_gui.php?sessionID&e_id_css=user_gui" target = "AdminFrame" ',10,370,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> GUI ','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','wfs_conf',2,1,'create and edit a gazetteer module','Configure WFS','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,870,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','WFS CONF','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','wfs_gui',2,1,'edit wfs settings','Assign WFS conf to gui','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,1000,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','asign WFS conf to gui','a','','','','AdminFrame','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_Gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'User_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'editGUI_WMS', 'file_css', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_Gui', 'file css', '../css/administration_alloc.css', 'file', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_user', 'file css', '../css/administration_alloc.css', 'a file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_Gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'group_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin2_de';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','AdminFrame',2,1,'Bereich f�r Administrationsmodule','','iframe','','frameborder = "0"',200,20,980,800,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','CreateTreeGDE',2,1,'Ordnerbaum konfigurieren','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',8,280,190,20,5,'','Ordnerbaum konfigurieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','body',1,1,'Navigation','','body','','onload=''mod_adminNavigation_init()''',0,0,180,20,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','deleteWMS',2,1,'!Vollst�ndig l�schen!','Delete WMS completely','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',8,100,190,20,5,'','!Vollst�ndig l�schen!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','delete_filteredGui',2,1,'GUI l�schen','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',110,240,80,20,5,'','GUI l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editElements',2,1,'Oberfl�chenelemente editieren','Edit GUI elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',8,260,190,20,5,'','GUI-Elemente editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editFilteredGroup',2,1,'Gruppe anlegen und editieren','Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',8,400,190,20,10,'','Gruppe anlegen und editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editFilteredUser',2,1,'Benutzer anlegen und editieren','Create and edit user','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',8,380,190,20,10,'','Benutzer anlegen und editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editGUI_WMS',2,1,'WMS GUI Einstellungen','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',8,180,190,20,5,'','WMS GUI Einstellungen','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','exportGUI',2,1,'Oberfl�che (GUI) exportieren, SQL erzeugen','export GUI, create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',8,300,190,20,10,'','GUI exportieren (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGoup_filteredUser',2,1,'Gruppe mit Benutzern best�cken','Add several users to one group','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',8,440,190,20,10,'','Gruppe mit Benutzern best�cken ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGroup_filteredGui',2,1,'Einzelner Gruppe mehrere Oberflaechen zuordnen','Allow one group access to several GUIs','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',8,570,190,25,10,'','Einzelner Gruppe mehrere <br>GUIs zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGui_filteredGroup',2,1,'Einzelner Oberfl�che mehrere Gruppen zuordnen','Allow several groups access to one GUI','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',8,605,190,25,10,'','Einzelner GUI mehrere<br> Gruppen zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGui_filteredUser',2,1,'Oberfl�che mehreren Benutzer zuordnen ','Allow several users access to one GUI ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',8,535,190,25,10,'','GUI mehreren Benutzern <br> zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredUser_filteredGroup',2,1,'Benutzer in Gruppen eintragen','Add one user to serveral groups','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,420,190,20,10,'','Benutzer in Gruppen eintragen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredUser_filteredGui',2,1,'Einem Nutzer Zugriff auf mehrere Oberfl�chen erteilen','Allow one user to access several GUIs','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',8,500,190,25,10,'','Einem Nutzer Zugriff auf <br> mehrere GUIs erteilen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','gui_owner',2,1,'GUI editieren Benutzer zuordnen','Edit GUI assign to user','a','','href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame" ',8,640,190,20,10,'','GUI editieren Benutzer zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_Configure_WMS_Access',3,1,'Hintergrund WMS Zuordnung','Configure WMS Access','div','','',5,137,193,66,2,'',' WMS Zuordnung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_GUI_Management',3,1,'Hintergrund Oberfl�chenverwaltung','GUI Management','div','','',5,217,193,126,2,'',' GUI-Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_User_Authorization',3,1,'Hintergrund Benutzerzugriff erteilen','Authorization ','div','','',5,477,193,196,2,'',' Benutzerzugriff erteilen','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_User_Management',3,1,'Hintergrund Benutzerverwaltung','User Management','div','','',5,357,193,106,2,'',' Benutzerverwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_WMS_Management',3,1,'Hintergrund WMS Management','WMS Management','div','','',5,37,193,86,2,'',' WMS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','loadWMS',2,1,'Capabilities hochladen','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',8,60,190,20,5,'','Capabilities hochladen','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','loadWMSList',2,1,'WMS in GUI einbinden','Link WMS into GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',8,160,190,20,5,'','WMS in GUI einbinden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','myGUIlist',2,1,'Zur�ck zur eigenen GUI Liste','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','newGui',2,1,'GUI erzeugen','Create new GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',8,240,85,20,5,'','GUI erzeugen','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','rename_copy_Gui',2,1,'GUI umbenennen/ kopieren','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',8,320,190,20,10,'','GUI umbenennen/kopieren','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','showLoggedUser',2,1,'Anzeige des eingeloggten Benutzers','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','updateWMSs',2,1,'Hochgeladene aktualisieren','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',8,80,190,20,5,'','Hochgeladene aktualisieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'body', 'body_css_file', '../css/admin.css', 'css-file to define the style fo the admin-gui', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin2_en';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','AdminFrame',2,1,'the frame for administration modules','','iframe','','frameborder = "0"',200,20,800,800,0,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','CreateTreeGDE',2,1,'TreeGDE set up','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',8,280,190,20,5,'','Create treeGDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','body',1,1,'navigation','','body','','onload=''mod_adminNavigation_init()''',0,0,0,0,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','deleteWMS',2,1,'!Delete WMS completely!','Delete WMS completely','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',8,100,190,20,5,'','!Delete WMS completely!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','delete_filteredGui',2,1,'Delete GUI','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',120,240,80,20,5,'','Delete GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editElements',2,1,'Edit GUI elements','Edit GUI elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',8,260,190,20,5,'','Edit GUI elements','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editFilteredGroup',2,1,'Create and edit group','Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',8,400,190,20,10,'','Create and edit group','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editFilteredUser',2,1,'Create and edit user','Create and edit user','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',8,380,190,20,10,'','Create and edit user','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editGUI_WMS',2,1,'WMS GUI settings','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',8,180,190,20,5,'','WMS GUI settings','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','exportGUI',2,1,'export GUI, create SQL','export GUI, create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',8,300,190,20,10,'','Export GUI (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGoup_filteredUser',2,1,'Add several users to one group','Add several users to one group','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',8,440,190,20,10,'','Add several users to one group ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGroup_filteredGui',2,1,'Allow one group access to several GUIs','Allow one group access to several GUIs','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',8,570,190,25,10,'','Allow one group access to <br> several GUIs','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGui_filteredGroup',2,1,'Allow several groups access to one GUI','Allow several groups access to one GUI','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',8,605,190,25,10,'','Allow several groups access <br> to one GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGui_filteredUser',2,1,'Allow several users access to one GUI ','Allow several users access to one GUI ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',8,535,190,25,10,'','Allow several users access to <br> one GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredUser_filteredGroup',2,1,'Add one user to serveral groups','Add one user to serveral groups','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,420,190,20,10,'','Add one user to serveral groups','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredUser_filteredGui',2,1,'Allow one user to access several GUIs','Allow one user to access several GUIs','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',8,500,190,25,10,'','Allow one user to access <br> several GUIs','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','gui_owner',2,1,'Edit GUI assign to user','Edit GUI assign to user','a','','href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame"  ',8,640,190,20,10,'','Edit GUI assign to user','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_Configure_WMS_Access',3,1,'Configure WMS Access','Configure WMS Access','div','','',5,137,193,66,2,'',' Configure WMS Access','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_GUI_Management',3,1,'GUI Management caption','GUI Management','div','','',5,217,193,126,2,'',' GUI Management ','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_User_Authorization',3,1,'Authorization caption','Authorization ','div','','',5,477,193,186,2,'',' Authorization','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_User_Management',3,1,'User Management caption','User Management','div','','',5,357,193,106,2,'',' User Management ','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_WMS_Management',3,1,'WMS Management caption','WMS Management','div','','',5,37,193,86,2,'',' WMS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" ',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','loadWMS',2,1,'Load Capabilities','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',8,60,190,20,5,'','Load WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','loadWMSList',2,1,'Link WMS into GUI','Link WMS into GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',8,160,190,20,5,'','Link WMS into GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','myGUIlist',2,1,'go back to your GUI list','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' ',150,2,24,24,2,'','','img','mod_home.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','newGui',2,1,'Create new GUI','Create new GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',8,240,110,20,5,'','Create new GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','rename_copy_Gui',2,1,'Rename/ copy GUI','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',8,320,190,20,10,'','Rename / copy GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','showLoggedUser',2,1,'Logged User:','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','updateWMSs',2,1,'Update with Capabilities','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',8,80,190,20,5,'','Update WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'body', 'body_css_file', '../css/admin.css', 'css-file to define the style fo the admin-gui', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGoup_filteredUser', 'css_file_filteredGroup_filterdUser', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGroup', 'css_filteredUser_filteredGroup', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin_de_services';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','AdminFrame',2,1,'Bereich f�r Administrationsmodule','','iframe','','frameborder = "0"',210,25,800,800,12,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','CreateTreeGDE',2,1,'Ordnerbaum konfigurieren','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,533,200,20,5,'','Ordnerbaum konfigurieren','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','EditWMSMetadata',2,1,'edit the metadata of wms','edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,275,200,20,5,'','WMS Metadaten','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_WMS_Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','body',1,1,'Navigation','','body','','onload=''mod_adminNavigation_init()''',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','deleteWFS',2,1,'WFS l�schen','Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,393,200,20,5,'','WFS l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','deleteWMS',2,1,'!Vollst�ndig l�schen!','!Delete WMS completely!','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,100,200,20,5,'','WMS l�schen!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','delete_filteredGui',2,1,'GUI l�schen','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,491,200,20,5,'','GUI l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','editElements',2,1,'Oberfl�chenelemente editieren','Edit GUI Elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,511,200,25,5,'','GUI editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','editGUI_WMS',2,1,'WMS GUI Einstellungen','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,218,200,20,5,'','WMS Einstellungen �ndern','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','exportGUI',2,1,'GUI exportieren, SQL erzeugen','Export GUI (SQL), create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,554,200,25,10,'x','GUI exportieren (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','filteredWms_layer_topic',2,1,'allocate topics to layers of wms of this user','allocate topics to layers of wms of this user','a','','href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ',10,295,200,20,5,'','Kategoriezuordnung','a','','','','AdminFrame','http://www.mapbender.org/index.php/Topic_/_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_Configure_WMS_Access',3,1,'Hintergrund WMS Zuordnung','WMS Assignment','div','','',1,175,210,63,2,'','WMS Zuordnung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_GUI_Management',3,1,'Oberfl�chenverwaltung','GUI Management','div','','',1,448,210,153,2,'','GUI Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_Metadata',3,1,'Metadateneditor Caption','Metadata','div','','',1,252,210,63,2,'','Metadaten','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_WFS_Management',3,1,'WFS Verwaltung','WFS Management','div','','',1,330,210,103,2,'','WFS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_WMS_Management',3,1,'Dienstverwaltung Beschriftung','WMS Management','div','','',0,37,210,123,2,'','WMS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWFS',2,1,'WFS Capabilities in eine GUI laden','Load WFS Capabilities into a GUI','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,353,200,20,5,'','WFS laden','a','','','','AdminFrame','http://www.mapbender.org/index.php/LoadWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWMS',2,1,'Capabilities hochladen','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,60,200,20,5,'','WMS laden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWMSList',2,1,'WMS in GUI einbinden','Assign WMS to a GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,198,200,20,5,'','WMS einbinden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','myGUIlist',2,1,'Zur�ck zur eigenen GUI Liste','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','newGui',2,1,'GUI erzeugen','New GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,471,200,20,5,'','GUI erzeugen','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','orphanWMS',2,1,'display orphaned WMS','Delete orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID"
+target = "AdminFrame"',10,120,200,20,5,'','WMS ohne Zuordung l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','owsproxy',2,1,'secure services','OWSPROXY','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,140,200,20,10,'','OWSPROXY','a','','','','AdminFrame','http://www.mapbender.org/index.php/Owsproxy');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','rename_copy_Gui',2,1,'GUI umbenennen/ kopieren','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,576,200,20,10,'','GUI umbenennen/kopieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/RenameGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','showLoggedUser',2,1,'Anzeige des eingeloggten Benutzers','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','updateWMSs',2,1,'Hochgeladene aktualisieren','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,80,200,20,5,'','WMS aktualisieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','wfs_conf',2,1,'WFS konfigurieren','Configure WFS','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,373,200,20,5,'','WFS konfigurieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Wfs_conf');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','wfs_gui',2,1,'edit wfs settings','Assign WFS conf to gui','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,413,200,20,10,'','WFS Konfiguration GUI zuweisen','a','','','','AdminFrame','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'EditWMSMetadata', 'file_css', '../css/metadata.css', 'css-file to use for the metadata modul', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'body', 'body_file_css', '../css/admin_service.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'filteredWms_layer_topic', 'file css', '../css/administration_alloc_4.css', 'css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'filteredWms_layer_topic', 'language', 'de', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin_en_services';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','AdminFrame',2,1,'administration frame','','iframe','','frameborder = "0"',210,25,1000,800,12,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','CreateTreeGDE',2,1,'Configure TreeGDE','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,533,200,20,5,'','Configure TreeGDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','EditWMSMetadata',2,1,'edit the metadata of wms','edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,275,200,20,5,'','WMS Metadata','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_WMS_Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','body',1,1,'Navigation','','body','','onload=''mod_adminNavigation_init()''',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','deleteWFS',2,1,'Delete WFS','Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,393,200,20,5,'','Delete WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','deleteWMS',2,1,'!Delete completely!','!Delete WMS completely!','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,100,200,20,5,'','!Delete WMS completely!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','delete_filteredGui',2,1,'Delete GUI','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,491,200,20,5,'','Delete GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','editElements',2,1,'Edit GUI Elements','Edit GUI Elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,511,200,20,5,'','Edit GUI Elements','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','editGUI_WMS',2,1,'WMS GUI settings','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,218,200,20,5,'','WMS GUI settings','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','exportGUI',2,1,'Export GUI (SQL), create SQL','Export GUI (SQL), create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,553,200,20,10,'x','Export GUI (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','filteredWms_layer_topic',2,1,'allocate topics to layers of wms of this user','allocate topics to layers of wms of this user','a','','href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ',10,295,200,20,5,'','Allocate topics','a','','','','AdminFrame','http://www.mapbender.org/index.php/Topic_/_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_Configure_WMS_Access',3,1,'WMS Assignment','WMS Assignment','div','','',1,175,210,63,2,'','WMS Assignment','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_GUI_Management',3,1,'GUI Management','GUI Management','div','','',1,448,210,148,2,'','GUI Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_Metadata',3,1,'Metadata','Metadata','div','','',1,252,210,63,2,'','Metadata','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_WFS_Management',3,1,'WFS Management','WFS Management','div','','',1,330,210,103,2,'','WFS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_WMS_Management',3,1,'WMS Management','WMS Management','div','','',0,37,210,123,2,'','WMS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWFS',2,1,'Load WFS Capabilities into a GUI','Load WFS Capabilities into a GUI','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,353,200,20,5,'','Load WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/LoadWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWMS',2,1,'load Capabilities','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,60,200,20,5,'','Load WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWMSList',2,1,'assign WMS to a GUI','Assign WMS to a GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,198,200,20,5,'','Assign WMS to a GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' ',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','myGUIlist',2,1,'back to GUI list','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','newGui',2,1,'New GUI','New GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,471,200,20,5,'','New GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','orphanWMS',2,1,'Delete orphaned WMS','Delete orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID"
+target = "AdminFrame"',10,120,200,20,5,'','Delete orphaned WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','owsproxy',2,1,'secure services','OWSPROXY','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,140,200,20,10,'','OWSPROXY','a','','','','AdminFrame','http://www.mapbender.org/index.php/Owsproxy');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','rename_copy_Gui',2,1,'Rename / copy GUI','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,576,200,20,10,'','Rename / copy GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/RenameGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','showLoggedUser',2,1,'show logged in user','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','updateWMSs',2,1,'Update Capabilities','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,80,200,20,5,'','Update WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','wfs_conf',2,1,'Configure WFS','Configure WFS','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,373,200,20,5,'','Configure WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Wfs_conf');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','wfs_gui',2,1,'edit wfs settings (Assign WFS conf to GUI)','Assign WFS conf to gui','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,413,200,20,10,'','Assign WFS conf to GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'EditWMSMetadata', 'file_css', '../css/metadata.css', 'css-file to use for the metadata modul', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'body', 'body_file_css', '../css/admin_service.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'filteredWms_layer_topic', 'file css', '../css/administration_alloc_4.css', 'css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'filteredWms_layer_topic', 'language', 'de', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui','switchLocale_noreload',8,1,'changes the locale without reloading the client','Set language','div','','frameborder=''0''',696,14,50,30,5,'','<form id=''form_switch_locale'' name=''form_switch_locale'' target=''parent''>
+<select id=''language'' name=''language'' onchange=''validate_locale()''>
+</select>
+</form>
+','div','mod_switchLocale_noreload.php','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'switchLocale_noreload', 'languages', 'de,en,bg,gr,nl,it,es', '' ,'var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_closetag, e_js_file) VALUES('gui1', 'popup', 6, 1, 'popup replacement', 'div', 'div', 'popup.js');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui1' AND e_id = 'wfs_gazetteer';
+DELETE FROM gui_treegde WHERE fkey_gui_id IN ('gui', 'gui1', 'admin1', 'gui2', 'wms_africa');
+-- update own applications
+Update gui_element set e_title =
+mynew.e_title from gui_element as mynew
+where gui_element.e_id = mynew.e_id
+and mynew.fkey_gui_id = 'gui'
+and gui_element.fkey_gui_id != 'gui'
+and gui_element.fkey_gui_id != 'gui1'
+and gui_element.fkey_gui_id != 'gui2'
+and gui_element.fkey_gui_id != 'gui_digitize';
+and mynew.fkey_gui_id = 'gui1'
+and mynew.fkey_gui_id = 'gui2'
+and mynew.fkey_gui_id = 'gui_digitize'
+Delete from gui_element_vars where fkey_e_id ='tabs' and var_name LIKE 'tab_titles[%';
+Update gui_element_vars set var_type='php_var' where fkey_e_id ='tabs' and var_name LIKE 'tab_ids[%' and var_type='var';
+DELETE FROM gui_element WHERE e_id = 'ajax';
+Delete from gui_element where e_id='keyHandler';
+DELETE FROM gui_element WHERE e_id = 'geometry';
+Select * from gui_element where e_mb_mod ='geometry.js' ;
+update gui_element set e_mb_mod = 'geometry.js'
+where e_id = 'digitize';
+where e_id = 'gazetteerWFS';
+where e_id = 'setSpatialRequest';
Added: branches/2.5/resources/db/postgresql/iso/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
--- branches/2.5/resources/db/postgresql/iso/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql	                        (rev 0)
+++ branches/2.5/resources/db/postgresql/iso/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql	2008-09-29 14:36:55 UTC (rev 3041)
@@ -0,0 +1,540 @@
+-- database changes in version 2.5
+-- notice language plpgsql has to be installed
+-- How to install plpgsql?
+-- createlang plpgsql mapbender
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin_de_services', 20, '');
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin_en_services', 20, '');
+-- table mb_monitor: new columns for mb_monitor
+ALTER TABLE mb_monitor ADD COLUMN image int4;
+ALTER TABLE mb_monitor ADD COLUMN map_url varchar(2048);
+-- WFS database handling
+-- enhancement of the datadase structure concerning WFS metadata (same solution like for WMS)
+ALTER table wfs add wfs_getcapabilities_doc text;
+ALTER table wfs add wfs_upload_url character varying(255);
+ALTER table wfs add fees character varying(255);
+ALTER table wfs add accessconstraints text;
+ALTER table wfs add individualname character varying(255);
+ALTER table wfs add positionname character varying(255);
+ALTER table wfs add providername character varying(255);
+ALTER table wfs add city character varying(255);
+ALTER table wfs add deliverypoint character varying(255);
+ALTER table wfs add administrativearea character varying(255);
+ALTER table wfs add postalcode character varying(255);
+ALTER table wfs add voice character varying(255);
+ALTER table wfs add facsimile character varying(255);
+ALTER table wfs add electronicmailaddress character varying(255);
+ALTER table wfs add wfs_mb_getcapabilities_doc text;
+ALTER table wfs add wfs_owner integer;
+ALTER table wfs add wfs_timestamp integer;
+ALTER table wfs add country character varying(255);
+ALTER TABLE wfs ALTER COLUMN wfs_title SET NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_title SET DEFAULT ''::character varying;
+ALTER TABLE wfs ALTER COLUMN wfs_version SET NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_version SET DEFAULT ''::character varying;
+ALTER TABLE wfs ALTER COLUMN wfs_getcapabilities SET NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_getcapabilities SET DEFAULT ''::character varying;
+alter table wfs_featuretype add column featuretype_searchable integer default 1;
+alter table wfs_featuretype add column featuretype_abstract character varying(50);
+-- grant root access to default wfs
+UPDATE wfs SET wfs_owner = 1;
+-- new table gui_wfs_conf
+CREATE TABLE gui_wfs_conf (
+    fkey_gui_id character varying(50) DEFAULT ''::character varying NOT NULL,
+    fkey_wfs_conf_id integer DEFAULT 0 NOT NULL
+ALTER TABLE ONLY gui_wfs_conf
+    ADD CONSTRAINT pk_fkey_wfs_conf_id PRIMARY KEY (fkey_gui_id, fkey_wfs_conf_id);
+    ADD CONSTRAINT gui_wfs_conf_ibfk_1 FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
+    ADD CONSTRAINT gui_wfs_conf_ibfk_2 FOREIGN KEY (fkey_wfs_conf_id) REFERENCES wfs_conf(wfs_conf_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- insert wfs confs into gui digitize
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 1);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 3);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 4);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 2);
+-- new table wfs_featuretype_keyword:
+CREATE TABLE wfs_featuretype_keyword (
+  fkey_featuretype_id integer NOT NULL,
+  fkey_keyword_id integer NOT NULL
+ALTER TABLE ONLY wfs_featuretype_keyword
+    ADD CONSTRAINT fkey_keyword_id_fkey_featuretype_id FOREIGN KEY (fkey_keyword_id) REFERENCES keyword(keyword_id) ON UPDATE CASCADE ON DELETE CASCADE;
+    ADD CONSTRAINT fkey_featuretype_id_fkey_keyword_id FOREIGN KEY (fkey_featuretype_id) REFERENCES wfs_featuretype(featuretype_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- new table layer_load_count
+CREATE TABLE layer_load_count (
+ fkey_layer_id int4,
+ load_count int8
+-- table wfs_conf
+ALTER TABLE wfs_conf add COLUMN wfs_conf_description text;
+-- table wfs_conf_element: change in WFS configuration: access to geometries may now be restricted
+ALTER TABLE wfs_conf_element ADD COLUMN f_auth_varname VARCHAR(50);
+ALTER TABLE wfs_conf_element ADD COLUMN f_show_detail int4;
+ALTER TABLE wfs_conf_element ADD COLUMN f_operator VARCHAR(50);
+ALTER TABLE ONLY wfs_conf
+    ADD CONSTRAINT wfs_conf_ibfk_2 FOREIGN KEY (fkey_featuretype_id) REFERENCES wfs_featuretype(featuretype_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- table gui_element: new element for table admin1 to edit wfs settings
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','WFS',2,1,'edit wfs settings','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,1005,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT WFS','a','','','','AdminFrame','');
+-- new table translation: new table for translations
+CREATE TABLE translations
+  trs_id serial PRIMARY KEY not null,
+  locale varchar(8),
+  msgid varchar(512),
+  msgstr varchar(512)
+CREATE INDEX msgid_idx ON translations(msgid);
+ CREATE TRUSTED PROCEDURAL LANGUAGE 'plpgsql'
+  HANDLER plpgsql_call_handler;
+-- new function gettext for easy translations
+CREATE OR REPLACE FUNCTION gettext(locale_arg "text", string "text")
+RETURNS "varchar" AS
+$BODY$
+DECLARE
+    msgstr varchar(512);
+    trl RECORD;
+BEGIN
+    -- RAISE NOTICE '>%<', locale_arg;
+    SELECT INTO trl * FROM translations
+    WHERE trim(from locale) = trim(from locale_arg) AND msgid = string;
+    -- we return the original string, if no translation is found.
+    -- this is consistent with gettext's behaviour
+    IF NOT FOUND THEN
+        RETURN string;
+    ELSE
+        RETURN trl.msgstr;
+    END IF;
+END;
+$BODY$
+  LANGUAGE 'plpgsql' VOLATILE;
+-- new entries for table translations
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Pan', 'Ausschnitt verschieben');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Display complete map', 'gesamte Karte anzeigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom in', 'In die Karte hineinzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom out', 'Aus der Karte herauszoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Back', 'Zurück');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Forward', 'Nach vorne');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Coordinates', 'Koordinaten anzeigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom by rectangle', 'Ausschnitt wählen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Redraw', 'Neu laden oder Tastatur: Leertaste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Query', 'Datenabfrage');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Logout', 'Abmelden');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'WMS preferences', 'WMS Einstellungen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS from filtered list', 'WMS von gefilteter Liste hinzufügen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set map center', 'Kartenmittelpunkt setzen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Help', 'Hilfe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Show WMS infos', 'Anzeige von WMS Informationen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Save workspace as web map context document', 'Ansicht als Web Map Context Dokument speichern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Resize Mapsize', 'Bildschirmgröße anpassen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Rubber', 'Skizze löschen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Get Area', 'Fläche berechnen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Close Polygon', 'Polygon schliessen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Move back to your GUI list', 'Zurück zur GUI Liste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Legend', 'Legende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Print', 'Druck');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Imprint', 'Impressum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Maps', 'Karten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Search', 'Suche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Meetingpoint', 'Treffpunkt');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Metadatasearch', 'Metadatensuche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS', 'WMS hinzufügen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS from List', 'WMS aus Liste hinzufügen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Change Projection', 'Projektion ändern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Digitize', 'Digitalisierung');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Overview', 'Übersichtskarte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Drag Mapsize', 'Karte vergrößern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Mapframe', 'Kartenfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Navigation Frame', 'Navigationsfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scale Select', 'Auswahl des Maßstabes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scale Text', 'Maßstab per Texteingabe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scalebar', 'Maßstabsleiste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set Background', 'Hintegrundkarte auswählen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom to Coordinates', 'Zu den Koordinaten zoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Change Password', 'Passwort ändern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Load a web map context document', 'laden eines Web Map Context Dokumentes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de ', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Pan', 'Премести областта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Display complete map', 'Покажи цялата карта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom in', 'Покажи картата в по-едър мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom out', 'Покажи картата в по-дребен мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Back', 'Назад');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Forward', 'Напред');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Coordinates', 'Координати');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom by rectangle', 'Увеличи картата в избраната област');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Redraw', 'Пречертай или от клавиатурата: празен интервал');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Query', 'Зявка към данните');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Logout', 'Изход на потребител');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'WMS preferences', 'WMS настройки');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS from filtered list', 'Добави WMS от избран списък');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Set map center', 'Постави център на карта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Help', 'Помощ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Show WMS infos', 'Покажи WMS информация');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Save workspace as web map context document', 'Запази работния документ като Web Map Context документ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Resize Mapsize', 'Напасни големината на картата');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Rubber', 'Изтрий');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Get Area', 'Изчисли площ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Close Polygon', 'Затвори полигон');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Move back to your GUI list', 'Назад към списъка с интерфейси (GUI)');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Legend', 'Легенда');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Print', 'Печат');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Imprint', 'Авторско каре');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Maps', 'Карти');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Search', 'Търсене');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Meetingpoint', 'Място на среща');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Metadatasearch', 'Търсене по метаданни');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS', 'Добави WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS from List', 'Добави WMS от списък');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Info', 'Информация');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Change Projection', 'Промени проекция');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Copyright', 'Авторско право');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Digitize', 'Дигитализиране');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Overview','Обзорна карта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Drag Mapsize', 'Промени размера на картата');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Mapframe', 'Рамка на картата');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Navigation Frame', 'Навигационна рамка');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scale Select', 'Избор на мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scale Text', 'Въведи мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scalebar', 'Мащабна скала');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Set Background', 'Избери фоново изображение');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom to Coordinates', 'Покажи картата около посочените координати');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Change Password', 'Промени парола');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Load a web map context document', 'Зареди Web Map Context документ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Logo', 'Фирмен знак');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Measure distance', 'Измери разстояние');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Pan', 'Μετακίνηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Display complete map', 'Επίδειξη Πλήρους Χάρτη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom in', 'Zoom In');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom out', 'Zoom Out');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Back', 'Πίσω');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Forward', 'Πρόσθια');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Coordinates', 'Συντεταγμένες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom by rectangle', 'Ζουμ από ορθογώνιο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Redraw', 'Απόσυρση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Query', 'Μέτρηση Εμβαδού');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Logout', 'Αποσύνδεση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'WMS preferences', 'Αλλάξτε τη διάταξη των WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS from filtered list', 'Πρόσθεση WMS από το φιλτραρισμένο κατάλογο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Set map center', 'Το καθορισμένο Κέντρο Χαρτών');
+INSERT INTO translations (locale, msgid, msgstr) VALUES  ('gr', 'Help', 'Βοήθεια');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Save workspace as web map context document', 'Ansicht als Web Map Context Dokument speichern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Rubber', 'Το λάστιχο- Τρίφτης');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Close Polygon', 'Το Κλειστό Πολύγωνο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ( 'gr', 'Move back to your GUI list', 'Παρουσίαση του GUI Καταλόγου');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Print', 'Εκτύπωση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Maps', ' Χάρτες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS', 'Πρόσθεση WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS from List', 'Πρόσθεση WMS από τον κατάλογο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Navigation Frame', 'Navigationsfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Load a web map context document', 'laden eines Web Map Context Dokumentes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Measure distance', 'Μέτρηση Απόστασης');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Meetingpoint', 'Σημείο Συνάντησης');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Info', 'Πληροφορίες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Digitize', 'Ψηφιοποίηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Change Projection', 'Αλλαγή Προβολής');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Set Background', 'Επιλογή Φόντου');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Overview', 'Προεπισκόπιση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Change Password', 'Αλλαγή Συνθηματικού');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scalebar', 'Κανόνας Κλίμακας');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr ', 'Logo', 'Λογότυπο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom to Coordinates', 'Εστίαση σε Συντεταγμένες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scale Text', 'Κείμενο Κλίμακας');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Show WMS infos', 'Προβολή WMS πληροφοριών');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Legend', 'Λεζάντα');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Search', 'Αναζήτηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Resize Mapsize', 'Αλλαγή Μεγέθους Χάρτη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Drag Mapsize', 'Αλλαγή Μεγέθους Χάρτη με Ολίσθηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Mapframe', 'Πλαίσιο Χάρτη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Get Area', 'Προβολή Περιοχής');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Imprint', 'Αποτύπωση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scale Select', 'Επιλογή Κλίμακας');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Metadatasearch', 'Αναζήτηση στα Metadata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Pan', 'Selectie verschuiven');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Display complete map', 'Hele kaart tonen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom in', 'Inzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom out', 'Uitzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Back', 'Terug');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Forward', 'Voorwaarts');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Coordinates', 'Koordinaten tonen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom by rectangle', 'Zoom rechthoek-selectie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Redraw', 'Opfrissen of toetsenbord : spatiebalk');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Query', 'Data opvragen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Logout', 'Afmelden');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'WMS preferences', 'WMS instellingen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS from filtered list', 'WMS van gefilterte lijst toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set map center', 'Kaartmiddelpunt aangeven');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Help', 'Help');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Show WMS infos', 'Tonen van WMS Informatie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Save workspace as web map context document', 'zicht als Web map context dokument bewaren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Resize Mapsize', 'beeldschermgrote aanpassen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Rubber', 'schets verwerpen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Get Area', 'oppervlakte berekenen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Close Polygon', 'Polygoon sluiten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Move back to your GUI list', 'Terug naar GUI lijst');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Legend', 'Legende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Print', 'Drukken');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Imprint', 'Impressum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Maps', 'Kaarten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Search', 'Zoek');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Meetingpoint', 'Trefpunt');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Metadatasearch', 'Zoeken naar Metadata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS', 'WMS toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS from List', 'WMS uit lijst toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Info', 'Informatie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Change Projection', 'Projektie veranderen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Digitize', 'Digitaliseren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Overview', 'overzichtskaart');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Drag Mapsize', 'Kaart vergroten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Mapframe', 'Kaartvenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Navigation Frame', 'Navigeervenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scale Select', 'Schaal selecteren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scale Text', 'Schaal via tekstingave');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scalebar', 'Schaalbalk');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set Background', 'Achtergrond selecteren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom to Coordinates', 'Naar koordinaten zoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Change Password', 'Paswoord wijzigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Load a web map context document', 'Laad een Web Map Context Dokument');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Measure distance', 'Meet afstand');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Pan', 'Sposta dettaglio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Display complete map', 'Mostra tutta la mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom in', 'Ingrandisci');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom out', 'Riduci');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Back', 'Indietro');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Forward', 'Avanti');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Coordinates', 'Mostra coordinate');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom by rectangle', 'Seleziona dettaglio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Redraw', 'Ridisegna oppure, da tastiera: spazio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Query', 'Interroga');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Logout', 'Logout');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'WMS preferences', 'Impostazioni WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS from filtered list', 'Aggiungi un WMS da una lista filtrata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set map center', 'Fissa il centro della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Help', 'Aiuto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Show WMS infos', 'Mostra informazioni sul WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Save workspace as web map context document', 'Salva vista come documento di Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Resize Mapsize', 'Adatta la dimensione della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Rubber', 'Cancella bozza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Get Area', 'Calcola area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Close Polygon', 'Chiudi poligono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Move back to your GUI list', 'Torna alla lista delle GUI');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Legend', 'Legenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Print', 'Stampa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Imprint', 'Colophon');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Maps', 'Mappe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Search', 'Cerca');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Meetingpoint', 'Punti di incontro');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Metadatasearch', 'Ricerca metadati');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS', 'Aggiungi WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS from List', 'Aggiungi WMS da lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Change Projection', 'Cambia proiezione');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Digitize', 'Digitalizza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Overview', 'Mappa di insieme');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Drag Mapsize', 'Cambia dimensione mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Mapframe', 'Quadro della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Navigation Frame', 'Quadro di navigazione');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scale Select', 'Scelta della scala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scale Text', 'Scala dei testi');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scalebar', 'Scala di riferimento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set Background', 'Seleziona mappa di sfondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom to Coordinates', 'Ingrandisci alle coordinate');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Change Password', 'Cambia password');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Load a web map context document', 'Carica un documento Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Measure distance', 'Misura distanza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Pan', 'Desplazamiento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Display complete map', 'Desplazamiento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom in', 'Zoom +');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom out', 'Zoom -');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Back', 'Zoom previo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Forward', 'Zoom siguiente');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Coordinates', 'Mostrar coordenadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom by rectangle', 'Zoom rectángulo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Redraw', 'Refrescar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Query', 'Busqueda de datos');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Logout', 'Terminar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'WMS preferences', 'Ajuste WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS from filtered list', 'Anadir WMS desde lista filtrada');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set map center', 'Centrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Help', 'Ayuda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Show WMS infos', 'Mostrar información sobre WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Save workspace as web map context document', 'Guardar vista como fichero Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Resize Mapsize', 'Modificar el tamano de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Rubber', 'Borrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Get Area', 'Calcular area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Close Polygon', 'Cerrar polígono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Move back to your GUI list', 'Volver a la lista WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Legend', 'Leyenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Print', 'Imprimir');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Imprint', 'Aviso legal');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Maps', 'Mapas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Search', 'Busqueda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Meetingpoint', 'Lugar de reunión');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Metadatasearch', 'Búsqueda de datos meta');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS', 'Añadir WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS from List', 'Añadir WMS desde lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Info', 'Informacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Change Projection', 'Cambiar projecto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Digitize', 'Digitalización');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Overview', 'Mapa de visión general');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Drag Mapsize', 'Ampilar vista de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Mapframe', 'Ventana de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Navigation Frame', 'Ventana de navigacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scale Select', 'Selecionar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scale Text', 'Teclar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scalebar', 'Fraja de escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set Background', 'Poner el fondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom to Coordinates', 'Zoom en coordenadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Change Password', 'Cambiar clave');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Load a web map context document', 'Cargar un documento de Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Measure distance', 'Medir distancias');
+-- new table gui_kml
+CREATE TABLE gui_kml (
+    kml_id serial,
+    fkey_mb_user_id integer NOT NULL,
+    fkey_gui_id character varying(50) NOT NULL,
+    kml_doc text NOT NULL,
+    kml_name character varying(64),
+    kml_description text,
+    kml_timestamp integer NOT NULL
+ALTER TABLE ONLY gui_kml
+    ADD CONSTRAINT mb_gui_kml_pkey PRIMARY KEY (kml_id);
+    ADD CONSTRAINT gui_kml_fkey_mb_user_id FOREIGN KEY (fkey_mb_user_id) REFERENCES mb_user(mb_user_id) ON UPDATE CASCADE ON DELETE CASCADE;
+    ADD CONSTRAINT gui_kml_id_fkey_gui_id  FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- new sld_user_layer table
+CREATE TABLE sld_user_layer (
+    sld_user_layer_id serial NOT NULL,
+    fkey_layer_id integer NOT NULL,
+    fkey_gui_id character varying,
+    sld_xml text,
+    use_sld smallint
+ALTER TABLE sld_user_layer ADD CONSTRAINT pk_sld_user_layer PRIMARY KEY  (sld_user_layer_id);
+-- Name: sld_user_layer_ibfk_1; Type: FK CONSTRAINT; Schema: public; Owner: admin
+ALTER TABLE ONLY sld_user_layer
+    ADD CONSTRAINT sld_user_layer_ibfk_1 FOREIGN KEY (fkey_mb_user_id) REFERENCES mb_user(mb_user_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- Name: sld_user_layer_ibfk_2; Type: FK CONSTRAINT; Schema: public; Owner: admin
+    ADD CONSTRAINT sld_user_layer_ibfk_2 FOREIGN KEY (fkey_layer_id) REFERENCES layer(layer_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- Name: sld_user_layer_ibfk_3; Type: FK CONSTRAINT; Schema: public; Owner: admin
+    ADD CONSTRAINT sld_user_layer_ibfk_3 FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- add sld related columns
+alter table gui_wms add column gui_wms_sldurl character varying(255) DEFAULT ''::character varying NOT NULL;
+alter table wms add column wms_supportsld boolean;
+alter table wms add column wms_userlayer boolean;
+alter table wms add column wms_userstyle boolean;
+alter table wms add column wms_remotewfs boolean;
+-- opacity handeling
+ALTER TABLE gui_wms ADD COLUMN gui_wms_opacity INT DEFAULT 100;
+UPDATE gui_element SET e_mb_mod = 'mod_addWMSgeneralFunctions.js' WHERE e_id = 'addWMS';
+ALTER TABLE gui_element MODIFY e_js_file character varying(255);
+ALTER TABLE gui_element MODIFY e_mb_mod character varying(255);
+ALTER TABLE wms MODIFY fees text;
+ALTER TABLE wms CHANGE COLUMN wms_mb_getcapabilies_doc wms_mb_getcapabilities_doc text;
\ No newline at end of file
Added: branches/2.5/resources/db/postgresql/iso/update/update_2.5rc6_to_2.5_pgsql_ISO-8859-1.sql
--- branches/2.5/resources/db/postgresql/iso/update/update_2.5rc6_to_2.5_pgsql_ISO-8859-1.sql	                        (rev 0)
+++ branches/2.5/resources/db/postgresql/iso/update/update_2.5rc6_to_2.5_pgsql_ISO-8859-1.sql	2008-09-29 14:36:55 UTC (rev 3041)
@@ -0,0 +1 @@
Added: branches/2.5/resources/db/postgresql/iso/update/update_guis_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
--- branches/2.5/resources/db/postgresql/iso/update/update_guis_2.4.5_to_2.5_pgsql_ISO-8859-1.sql	                        (rev 0)
+++ branches/2.5/resources/db/postgresql/iso/update/update_guis_2.4.5_to_2.5_pgsql_ISO-8859-1.sql	2008-09-29 14:36:55 UTC (rev 3041)
@@ -0,0 +1,932 @@
+-- update of mapbender guis
+-- gui / gui1 / gui2 / gui_digitize
+-- Mapbender (Version: 2.4.2)
+-- 2007-07-30
+Delete from gui_element where fkey_gui_id ='gui';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','FeatureInfoRedirect',2,1,'redirect featureInfoRequests in an iframe for each wms','iframe','../html/mod_blank.html','frameborder="0"',83,-17,1,1,0,'','','iframe','mod_featureInfoRedirect.php','','','','http://www.mapbender.org/index.php/FeatureInfoRedirect');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','WMS_preferences',2,1,'configures the preferences of each loaded wms','img','../img/button_gray/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="WMS preferences"',540,10,24,24,1,'','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','addWMS',2,1,'add a WMS to the running application','img','../img/button_gray/add_off.png','onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS"',515,10,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','ajax',6,1,'ajax module','iframe','../frames/jquery.html','',1,1,1,1,1,'visibility:hidden','','iframe','../javascripts/mb_ajaxWrapper_jQuery.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','back',2,1,'History.back()','img','../img/button_gray/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" title="Back"',360,10,24,24,1,'','','','mod_back.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','body',1,1,'body (obligatory)','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','copyright',2,1,'a Copyright in the map','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','dependentDiv',2,1,'displays infos in a sticky div-tag','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','dragMapSize',2,1,'drag & drop Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','featureInfo1',2,0,'FeatureInfoRequest','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')" title="Query"',425,10,24,24,1,'','','','mod_featureInfoTunnel.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfoTunnel');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','forward',2,1,'History.forward()','img','../img/button_gray/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" title="Forward"',385,10,24,24,1,'','','','mod_forward.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','gazetteerMetadata',2,1,'gazetteer for metadata','iframe','../php/mod_gazetteerMetadata.php?sessionID&target=mapframe1,overview','frameborder = "0"',1,1,1,1,4,'visibility:hidden;','','iframe','','','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','geometry',1,1,'geometry library','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','geometry.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','help',2,1,'button help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" title="help"',620,10,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','highlightPOI',2,1,'highlight 1 to n pois in your gui with a Symbol and a special text','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_highlightPOI.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','imprint',2,1,'Information about the owner of the gui','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_back',3,1,'layout, background for buttons','div','','',360,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_featureInfo',3,1,'layout, background for FeatureInfo','div','','',425,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_help',3,1,'layout, background for Help-button','div','','',620,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_logout',3,1,'layout, background for Logout-button','div','','',660,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_metadata',3,1,'layout, background for Metadata','div','','',580,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_wms',3,1,'layout, background for wms','div','','',490,10,76,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_zoom',3,1,'layout, background for Zoom-button','div','','',220,10,126,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','legend',2,1,'legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','loadData',2,1,'IFRAME, um Daten zu laden','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','logo',2,1,'Logo','img','../img/mapbender_logo.png','',20,20,180,26,5,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','logout',2,1,'Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"',660,10,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','mapbender',2,1,'Mapbender-Logo','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','mapframe1',2,1,'frame for a map','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',230,55,500,450,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','meetingPoint',2,1,'create a meeting point','iframe','../php/mod_meetingPoint.php?sessionID','frameborder = "0" ',0,0,NULL ,NULL ,4,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','metadata',2,1,'shows informations about the wms and the requests of the gui','img','../img/button_gray/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_gray/metadata_over.png"'' onmouseout=''this.src="../img/button_gray/metadata_off.png"'' title="Show service metadata"',580,10,24,24,1,'','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','navFrame',2,1,'navigation mapborder','div','','',0,0,0,0,0,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','overview',2,1,'OverviewFrame','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',30,65,150,130,100,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','pan1',2,1,'pan','img','../img/button_gray/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')" title="Pan"',270,10,24,24,1,'','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','printPDF',2,1,'pdf print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','sandclock',2,1,'displays a sand clock while waiting for requests','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','selArea1',2,1,'zoombox','img','../img/button_gray/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')" title="Zoom by rectangle"',295,10,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','setBBOX',2,0,'set extent for mapframe and overviewframe','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','setBackground',2,1,'switch background-wms','form','','',30,210,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','showCoords_div',2,1,'displays coodinates by onmouseover','img','../img/button_gray/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" title="Coordinates" ',450,10,24,24,1,'','','','mod_coords_div.php','','mapframe1','dependendDiv','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','tabs',2,1,'vertical tabs to handle iframes','div','','',10,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2','iframe','../html/mod_treefolder2.php?sessionID','frameborder = "0" ',10,220,200,300,NULL ,'visibility:visible','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomFull',2,1,'zoom to full extent button','img','../img/button_gray/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"  title="Display complete map"',320,10,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomIn1',2,1,'zoomIn button','img','../img/button_gray/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' title=''Zoom in''',220,10,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomOut1',2,1,'zoomOut button','img','../img/button_gray/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' title="Zoom out"',245,10,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_all', '0', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_group', '0', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_gui', '0', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'gazetteerWFS', 'wfsConfIdString', '1', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_height', '14', 'height of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_width', '14', 'width of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_ccs_file', '../css/meetingPoint.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_format', 'prompt', 'decide which format to choose (email, prompt)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_subject', 'Ein Treffpunkt wurde erzeugt. Folgen Sie dem Link!', 'if you choose format email, define the text for the subject', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_height', '14', 'height of the meetingPoint_icon', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_icon', '../img/redball.gif', 'path to meetingPoint image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_max_characters', '70', 'define the maximum length of the text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_please_click', 'Please click in  the map to define the meeting point position!', 'text to show if no clickposition is set', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_style', 'background-color:white;font-weight: bold;color:red;font-family:Arial;', 'style to display the meetingPoint text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_width', '14', 'width of the meetingPoint_icon', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[5]', '160', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[6]', '280', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[1]', 'legend', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[2]', 'printPDF', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[4]', 'imprint', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[5]', 'meetingPoint', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[6]', 'gazetteerMetadata', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_prefix', '  ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[0]', 'Maps', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[1]', 'Legend', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[2]', 'Print', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[3]', 'WFS Search', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[4]', 'Imprint', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[5]', 'Meeting Point', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_titles[6]', 'Metadata search', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'menu', 'opacity_up,opacity_down,zoom,metainfo,hide,wms_up,wms_down,layer_up,layer_down,remove', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'metadatalink', 'false', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui1';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','WMS_preferences',2,1,'configure the preferences of each loaded wms','img','../img/button_blink_red/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="WMS preferences"',670,60,24,24,1,'','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMS',2,1,'add a WMS to the running application','img','../img/button_blink_red/add_off.png','onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS"',645,60,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMSfromList',2,1,'add a WMS to the running application from a list','img','../img/button_blink_red/addlist_off.png','onclick=''window.open("../javascripts/mod_addWMSfromList.php?sessionID","printWin","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from List"',595,60,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',620,60,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','ajax',6,1,'ajax module','iframe','../frames/jquery.html','',1,1,1,1,1,'visibility:hidden','','iframe','../javascripts/mb_ajaxWrapper_jQuery.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','back',2,1,'History.back()','img','../img/button_blink_red/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" title="Back"',400,60,24,24,1,'','','','mod_back.php','','mapframe1,overview','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','body',1,1,'body (obligatory)','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','center1',2,1,'Center button','img','../img/button_blink_red/center_off.png','onmouseover = "mb_regButton(''init_gui1_center'')" title="Set map center"',310,60,24,24,1,'','','','mod_center1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','changeEPSG',2,1,'change EPSG, Postgres required, overview is targed for full extent','iframe','../php/mod_changeEPSG.php?sessionID','scrolling="no" frameborder=''0'' ',432,25,107,24,1,'','','iframe','','','overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','changePassword_button',2,1,'button: change password of logged user','img','../img/button_blink_red/change_password_off.png','onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0'' onmouseover=''this.src="../img/button_blink_red/change_password_over.png"'' onmouseout=''this.src="../img/button_blink_red/change_password_off.png"'' title="Change password"',750,60,24,24,1,'cursor:hand','','','','','','','http://www.mapbender.org/index.php/ChangePassword');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','closePolygon',3,1,'close Polygon ','div','',' title="Close Polygon"',0,0,0,0,0,'','','div','mod_closePolygon.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','copyright',2,1,'a Copyright in the map','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','dependentDiv',2,1,'displays infos in a sticky div-tag','div','','',-59,1,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','dragMapSize',2,1,'drag & drop Mapsize','div','','',-59,1,0,0,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','featureInfo1',2,1,'FeatureInfoRequest','img','../img/button_blink_red/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')" title="Query"',465,60,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','forward',2,1,'History.forward()','img','../img/button_blink_red/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" title="Forward"',425,60,24,24,1,'','','','mod_forward.php','','mapframe1,overview','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','getArea',3,1,'Calculation of area, Postgis required','div','',' title="Get Area"',0,0,0,0,0,'','','div','mod_getArea.php','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','help',2,1,'button help','img','../img/button_blink_red/help_off.png','onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")'' title="Help"',790,60,24,24,1,'','','','','','','','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','help1',2,1,'button help','img','../img/button_blink_red/help_off.png','onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")'' title="Help"',790,60,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/help');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','highlightPOI',2,1,'highlight 1 to n pois in your gui with a Symbol and a special text','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_highlightPOI.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','layout_1',3,1,'layout, background for buttons','div','','',208,58,670,28,0,'background-color:#FFFFFF;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','legend',2,1,'legend','iframe','../javascripts/mod_legend.php?sessionID&wms_legend = yes','frameborder=''0''',-59,200,180,600,3,'','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','loadData',2,1,'IFRAME to load data','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','loadwmc',2,1,'load workspace from WMC','img','../img/button_blink_red/wmc_load_off.png','onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Load a web map context document"',895,60,24,24,1,'','','','mod_loadwmc.php','','mapframe1','','http://www.mapbender.org/index.php/LoadWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','logout',2,1,'Logout','img','../img/button_blink_red/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blink_red/logout_over.png"'' onmouseout=''this.src="../img/button_blink_red/logout_off.png"'' title="Logout"',830,60,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','mapbender',2,1,'Mapbender-Logo','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',-59,1,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','mapframe1',2,1,'Frame for a map','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',220,105,625,400,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','measure',2,1,'Measure','img','../img/button_blink_red/measure_off.png','onmouseover = "mb_regButton(''init_mod_measure'')" title="Measure distance"',515,60,24,24,1,'','','','mod_measure.php','','mapframe1','','http://www.mapbender.org/index.php/Measure');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','metadata',2,1,'shows informations about the wms and the requests of the gui','img','../img/button_blink_red/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_blink_red/metadata_over.png"'' onmouseout=''this.src="../img/button_blink_red/metadata_off.png"'' title="Show WMS infos"',710,60,24,24,1,'','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','navFrame',2,1,'navigation mapborder','div','','',0,0,0,0,10,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','overview',2,1,'OverviewFrame','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',15,25,150,150,2,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','pan1',2,1,'pan','img','../img/button_blink_red/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')" title="Pan"',260,60,24,24,1,'','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','print1',2,0,'start print GUI','img','../img/button_blink_red/print_off.png','onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID","printWin","width=300, height=400, resizable=yes ")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Print"',555,60,24,24,1,'','','','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','printPDF',2,1,'start print GUI','img','../img/button_blink_red/print_off.png','onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF_b.conf","printWin","width=180, height=200, resizable=yes ")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Print"',555,60,24,24,1,'','','','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','repaint',2,1,'refresh a mapobject','img','../img/button_blink_red/repaint_off.png','onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)'' title="Redraw"',360,60,24,24,1,'','','','mod_repaint.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','rubber',3,1,'deletes temporary (digitized) objects','div','',' title="Rubber"',0,0,0,0,0,'','','div','mod_rubber.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','sandclock',2,1,'displays a sand clock while waiting for requests','div','','',0,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','savewmc',2,1,'save workspace as WMC','img','../img/button_blink_red/wmc_save_off.png','onclick=''mod_savewmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Save workspace as web map context document"',870,60,24,24,1,'','','','mod_savewmc.php','','mapframe1','','http://www.mapbender.org/index.php/SaveWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scaleSelect',2,1,'Scale-Selectbox','select','','onchange=''mod_scaleSelect(this)''',555,25,100,20,1,'','<option value = ''''>Scale</option> <option value=''100''>1 : 100</option> <option value=''250''>1 : 250</option> <option value=''500''>1 : 500</option> <option value=''1000''>1 : 1000</option> <option value=''2500''>1 : 2500</option> <option value=''5000''>1 : 5000</option> <option value=''10000''>1 : 10000</option> <option value=''25000''>1 : 25000</option> <option value=''30000''>1 : 30000</option> <option value=''50000''>1 : 50000</option> <option value=''75000''>1 : 75000</option> <option value=''100000''>1 : 100000</option> <option value=''200000''>1 : 200000</option> <option value=''300000''>1 : 300000</option> <option value=''400000''>1 : 400000</option> <option value=''500000''>1 : 500000</option> <option value=''600000''>1 : 600000</option> <option value=''700000''>1 : 700000</option> <option value=''800000''>1 : 800000</option> <option value=''900000''>1 : 900000</option> <option value=''1000000''>1 : 1000000</option>','select','mod_scaleSel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scaleText',2,1,'Scale-description field','form','','onsubmit=''return mod_scaleText()''',672,25,100,30,0,'','<input type="text">','form','mod_scaleText.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scalebar',2,1,'scalebar','div','','',0,0,0,0,0,'','','div','mod_scalebar.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','selArea1',2,1,'zoombox','img','../img/button_blink_red/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')" title="Zoom by rectangle"',285,60,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBBOX',2,0,'set Extent for mapframe and overviewframe','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBackground',2,0,'switch background-wms','form','','',15,190,0,0,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBackground_all',2,0,'switch all background-wms','form','','',157,190,40,20,1,'','<input type=''checkbox'' onclick=''mod_setBackground_all_init(this)''> <font face="Arial, sans-serif" size="2">all</font>','form','mod_setBackground_all.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setPOI2Scale',2,1,'zoom to a poi (get-parameter)','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_setPOI2Scale.php','','mapframe1','','http://www.mapbender.org/index.php/Mod_setPoi2Scale');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setScaleHint',1,0,'set scaleHint for mapframes','div','','',1,1,1,1,0,'visibility:hidden;','','div','mod_scaleHint.php','','mapframe1,100,10000000','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','showCoords_div',2,1,'displays coordinates by onmouseover','img','../img/button_blink_red/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')"  title="Coordinates"',490,60,24,24,1,'','','','mod_coords_div.php','','mapframe1','','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeConfGDE',2,0,'configurable directory tree','iframe','../php/mod_treefolderClient.php?sessionID','frameborder = "0" ',0,180,250,500,0,'visibility:visible','','iframe','mod_treeConf.js','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeGDE_1',2,0,'directory tree, checkbox for visible, checkbox for querylayer, no immediate refreshing, with nested layers','iframe','../html/mod_sync_treefolder_1.html','frameborder = "0" ',0,180,250,500,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','wfs_gazetteer',2,0,'gazetteer using wfs','iframe','../php/mod_wfs_gazetteer.php?sessionID&color=255,0,255','frameborder = "0" ',-50,490,250,300,0,'visibility:visible','','iframe','','','mapframe1,overview','wfs','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomCoords',2,1,'zoom to coordinate','iframe','../php/mod_zoomCoords_en.php?sessionID','frameborder = "0" ',205,7,220,45,0,'','','iframe','','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomFull',2,1,'zoom to full extent button','img','../img/button_blink_red/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"  title="Display complete map"',335,60,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomIn1',2,1,'zoomIn button','img','../img/button_blink_red/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' title=''Zoom in''',210,60,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomOut1',2,1,'zoomOut button','img','../img/button_blink_red/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' title="Zoom out"',235,60,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_db', '0', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_height', '25', 'height of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_width', '25', 'width of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'css_file_legend', '../css/legend.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'stickylegend', 'true', 'parameter to decide wether the legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'logout', 'logout_location', 'http://www.mapbender.org/', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'setPOI2Scale', 'mod_setPOI2Scale_defScale', '5000', 'default scale', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'menu', '', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui2';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','WMS_preferences',2,1,'configures the preferences of each loaded wms','img','../img/button_blue/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="WMS preferences"',604,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','addWMS',2,1,'add a WMS to the running application','img','../img/button_blue/add_off.png','onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS"',580,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','img','../img/button_blue/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',553,40,28,28,1,'filter:Chroma(color=#C2CBCF);','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','ajax',6,1,'ajax module','iframe','../frames/jquery.html','',1,1,1,1,1,'visibility:hidden','','iframe','../javascripts/mb_ajaxWrapper_jQuery.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','back',2,1,'History.back()','img','../img/button_blue/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" title="Back"',398,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_back.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','body',1,1,'body
+(obligatory)','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'background-image:url(../img/background_yellow.jpg);background-repeat:repeat-x;','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','center1',2,1,'Center button','img','../img/button_blue/center_off.png','onmouseover = "mb_regButton(''init_gui1_center'')" title="Set map center"',308,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_center1.php','','mapframe1','','http://www.mapbender.org/index.php/ReCenter');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','changePassword_button',2,1,'button: change password of logged user','img','../img/button_blue/change_password_off.png','onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0''
+onmouseover=''this.src="../img/button_blue/change_password_over.png"'' onmouseout=''this.src="../img/button_blue/change_password_off.png"'' title="Change password"',668,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','','','http://www.mapbender.org/index.php/ChangePassword');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','closePolygon',3,1,'close Polygon ','div','','title="Close Polygon"',0,0,NULL ,NULL ,NULL ,'','','div','mod_closePolygon.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','copyright',2,1,'a Copyright in the map','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dependentDiv',2,1,'displays infos in a sticky div-tag','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dragMapSize',2,1,'drag & drop Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#799FEB; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dynamicOverview',2,1,'oveview acts in accordance with main mapframe','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','mod_dynamicOverview.php','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','featureInfo1',2,0,'FeatureInfoRequest','img','../img/button_blue/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','img','../img/button_blue/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')" title="Query"',461,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_featureInfoTunnel.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfoTunnel');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','forward',2,1,'History.forward()','img','../img/button_blue/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" title="Forward"',423,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_forward.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','geometry',1,1,'geometry library','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','geometry.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','getArea',3,1,'Calculation of area, Postgis required','div','','title="Get Area"',0,0,NULL ,NULL ,NULL ,'','','div','mod_getArea.php','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','header_yellow',2,0,'header','img','../img/header_yellow.jpg','',-1,-1,833,75,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','help',2,1,'button help','img','../img/button_blue/help_off.png','onmouseover = "mb_regButton(''init_help'')" title="help"',693,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','imprint',2,1,'Information about the owner of the gui','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','layout_linie',3,0,'layout','div','','',1,70,830,1,1,'background-color:#799FEB;font-size:1px;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','layout_linie2',3,0,'layout','div','','',1,35,830,1,1,'background-color:#799FEB;font-size:1px;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','legend',2,1,'legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','loadData',2,1,'IFRAME, um Daten zu laden','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','loadwmc',2,1,'load workspace from WMC','img','../img/button_blue/wmc_load_off.png','onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Load a web map context document"',758,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_loadwmc.php','','mapframe1','','http://www.mapbender.org/index.php/LoadWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','logo',2,1,'Logo','img','../img/mapbender_oo.png','',10,35,129,32,5,'filter:Chroma(color=#C2CBCF);','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','logout',2,1,'Logout','img','../img/button_blue/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blue/logout_over.png"'' onmouseout=''this.src="../img/button_blue/logout_off.png"''',798,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','mapbender',2,1,'Mapbender-Logo','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','mapframe1',2,1,'frame for a map','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',213,90,608,467,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','measure',2,1,'Measure','img','../img/button_blue/measure_off.png','onmouseover = "mb_regButton(''init_mod_measure'')" title="Measure distance"',513,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_measure.php','','mapframe1','','http://www.mapbender.org/index.php/Measure');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','metadata',2,1,'shows informations about the wms and the requests of the gui','img','../img/button_blue/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0''
+onmouseover=''this.src="../img/button_blue/metadata_over.png"'' onmouseout=''this.src="../img/button_blue/metadata_off.png"''
+title="Show SQL"',643,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','navFrame',2,1,'navigation mapborder','div','','',0,0,0,0,0,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>
+<div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>
+<div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>
+<div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div>
+<div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div>
+<div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>
+<div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>
+<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','overview',2,1,'OverviewFrame','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',9,80,185,130,100,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','pan1',2,1,'pan','img','../img/button_blue/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')" title="Pan"',258,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','printPDF',2,1,'pdf print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','repaint',2,1,'refresh a mapobject','img','../img/button_blue/repaint_off.png','onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)'' title="Redraw"',358,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_repaint.php','','mapframe1','','http://www.mapbender.org/index.php/Repaint');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','resizeMapsize',2,1,'resize mapsize to browser window size','img','../img/button_blink_red/resizemapsize_off.png','onclick = "adjustDimension()"
+onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="optimize mapsize to browser window"',838,40,24,24,3,'filter:Chroma(color=#C2CBCF);','','','mod_resize_mapsize.php','','mapframe1','','http://www.mapbender.org/index.php/ResizeMapsize');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','rubber',3,1,'deletes temporary (digitized) objects','div','','title="Rubber"',0,0,NULL ,NULL ,NULL ,'','','div','mod_rubber.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','sandclock',2,1,'displays a sand clock while waiting for requests','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','savewmc',2,1,'save workspace as WMC','img','../img/button_blue/wmc_save_off.png','onclick=''mod_savewmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Save workspace as web map context document"',733,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_savewmc.php','','mapframe1','','http://www.mapbender.org/index.php/SaveWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','selArea1',2,1,'zoombox','img','../img/button_blue/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')" title="Zoom by rectangle"',283,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','setBBOX',2,0,'set extent for mapframe and overviewframe','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','setBackground',2,1,'switch background-wms','form','','',10,218,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','showCoords_div',2,1,'displays coodinates by onmouseover','img','../img/button_blue/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" title="Coordinates" ',488,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_coords_div.php','','mapframe1','dependendDiv','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','tabs',2,1,'vertical tabs to handle iframes','div','','',2,245,191,22,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2','iframe','../html/mod_treefolder2.php?sessionID','frameborder = "0" ',10,220,200,300,NULL ,'visibility:visible','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomFull',2,1,'zoom to full extent button','img','../img/button_blue/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"  title="Display complete map"',333,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomIn1',2,1,'zoomIn button','img','../img/button_blue/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' title=''Zoom in''',203,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomOut1',2,1,'zoomOut button','img','../img/button_blue/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' title="Zoom out"',231,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_class_bg', 'body{background-color: #FEF8D4;}', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_minScale', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_startExtent', '-24.5,32,34.5,71', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_useMaxExtent', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_wmsIndex', '0', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_zoomFactor', '5', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'gazetteerWFS', 'wfsConfIdString', '1', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_height', '-35', 'to adjust the height of the mapframe on the bottom of the window', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_width', '-45', 'to adjust the width of the mapframe on the right side of the window', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'resize_option', 'button', 'auto (autoresize on load), button (resize by button)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'sandclock', 'mod_sandclock_image', '../img/sandclock_oo.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[1]', 'legend', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[2]', 'printPDF', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[4]', 'imprint', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_prefix', '  ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid #FDCC1A;font-size:12;color:#FFFFFF;background-color:#799FEB;cursor:pointer;margin-top:-3px; padding-top:3px;padding-left:4px;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[0]', 'Maps', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[1]', 'Legend', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[2]', 'Print', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[3]', 'WFS Search', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_titles[4]', 'Imprint', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'menu', 'opacity_up,opacity_down,zoom,metainfo,hide,wms_up,wms_down,layer_up,layer_down,remove', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui_digitize';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','FeatureInfoRedirect',2,0,'redirect featureInfoRequests in an iframe for each wms','iframe','../html/mod_blank.html','frameborder="0"',83,-17,1,1,NULL ,'','','iframe','mod_featureInfoRedirect.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','WMS_preferences',2,1,'configures the preferences of each loaded wms','img','../img/button_gray/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="WMS preferences"',540,10,24,24,1,'','','','','','mapframe1,treeGDE','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','addWMS',2,1,'add a WMS to the running application','img','../img/button_gray/add_off.png','onclick=''mod_addWMS()''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS"',515,10,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','ajax',6,1,'ajax module','iframe','../frames/jquery.html','',1,1,1,1,1,'visibility:hidden','','iframe','../javascripts/mb_ajaxWrapper_jQuery.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','back',2,1,'History.back()','img','../img/button_gray/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" title="Back"',360,10,24,24,1,'','','','mod_back.php','','mapframe1,overview0','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','body',1,1,'body (obligatory)','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','closePolygonExt',3,0,'close Polygon ','div','',' title="Close Polygon"',0,0,NULL ,NULL ,NULL ,'','','div','mod_closePolygonExt.js','','mapframe1','setExtRequest','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','copyright',2,1,'a Copyright in the map','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','dependentDiv',2,1,'displays infos in a sticky div-tag','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','digitize',2,1,'Digitize tool.','iframe','../javascripts/mod_digitize_tab.php?sessionID','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','dragMapSize',2,1,'drag & drop Mapsize','div','','',81,-19,0,0,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','featureInfo1',2,0,'FeatureInfoRequest','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')" title="Query"',425,10,24,24,1,'','','','mod_featureInfoTunnel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','forward',2,1,'History.forward()','img','../img/button_gray/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" title="Forward"',385,10,24,24,1,'','','','mod_forward.php','','mapframe1,overview0','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','geometry',1,1,'geometry library','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','geometry.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','help',2,1,'button help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" title="help"',620,10,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','imprint',2,1,'Information about the owner of the gui','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','initWmc',2,0,'initialise client with wmc','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_initWmc.php','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_1',3,0,'Warning notice','div','','',150,250,300,16,100,'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none;','Development Version - Work in Progress!','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_back',3,1,'layout, background for buttons','div','','',360,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_featureInfo',3,1,'layout, background for FeatureInfo','div','','',425,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_help',3,1,'layout, background for Help-button','div','','',620,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_logout',3,1,'layout, background for Logout-button','div','','',660,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_metadata',3,1,'layout, background for Metadata','div','','',580,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_wms',3,1,'layout, background for wms','div','','',490,10,76,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_zoom',3,1,'layout, background for Zoom-button','div','','',220,10,126,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','legend',2,1,'legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','loadData',2,1,'IFRAME, um Daten zu laden','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','loadwmc',2,0,'load workspace from WMC','img','../img/button_wmc/wmc_load.png','onclick=''mod_loadwmc()'' onmouseover=''mod_loadwmc_init(this)''
+title=''Load a web map context document''',760,10,24,24,1,'','','','mod_loadwmc.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','logo',2,1,'Logo','img','../img/mapbender_logo.png','',20,20,180,26,5,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','logout',2,1,'Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''
+onmouseover=''this.src="../img/button_gray/logout_over.png"''
+onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"',660,10,24,24,1,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','mapbender',2,1,'Mapbender-Logo','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr>
+<script language="javascript">
+mb_registerSubFunctions("mod_mapbender()");
+function mod_mapbender(){
+document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90;
+document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1;
+</script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','mapframe1',2,1,'frame for a map','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',230,55,500,450,2,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','metadata',2,1,'shows informations about the wms and the requests of the gui','img','../img/button_gray/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''"
+border=''0''
+onmouseover=''this.src="../img/button_gray/metadata_over.png"''
+onmouseout=''this.src="../img/button_gray/metadata_off.png"'' title="Show service metadata"',580,10,24,24,1,'','','','mod_displayObj.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','navFrame',2,1,'navigation mapborder','div','','',0,0,0,0,0,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>
+<div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>
+<div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>
+<div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div>
+<div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div>
+<div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>
+<div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>
+<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>
+','div','mod_navFrame.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','overview',2,1,'OverviewFrame','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',30,65,150,130,100,'','','iframe','','mod_box1.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','pan1',2,1,'pan','img','../img/button_gray/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')" title="Pan"',270,10,24,24,1,'','','','mod_pan.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','printPDF',2,1,'pdf print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','rubberExt',3,1,'deletes temporary (digitized) objects','div','',' title="Rubber"',0,0,0,0,0,'','','div','mod_rubberExt.js','','mapframe1','setExtRequest','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','sandclock',2,1,'displays a sand clock while waiting for requests','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','savewmc',2,0,'save workspace as WMC','img','../img/button_wmc/wmc_save.png','onclick=''mod_savewmc()'' onmouseover=''mod_savewmc_init(this)''
+title=''Save workspace as web map context document''',730,10,24,24,1,'','','','mod_savewmc.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','scaleSelect',2,0,'Scale-Selectbox','select','','onchange=''mod_scaleSelect(this)''',555,25,100,20,1,'','<option value = ''''>Scale</option>
+<option value=''100''>1 : 100</option>
+<option value=''250''>1 : 250</option>
+<option value=''500''>1 : 500</option>
+<option value=''1000''>1 : 1000</option>
+<option value=''2500''>1 : 2500</option>
+<option value=''5000''>1 : 5000</option>
+<option value=''10000''>1 : 10000</option>
+<option value=''25000''>1 : 25000</option>
+<option value=''30000''>1 : 30000</option>
+<option value=''50000''>1 : 50000</option>
+<option value=''75000''>1 : 75000</option>
+<option value=''100000''>1 : 100000</option>
+<option value=''200000''>1 : 200000</option>
+<option value=''300000''>1 : 300000</option>
+<option value=''400000''>1 : 400000</option>
+<option value=''500000''>1 : 500000</option>
+<option value=''600000''>1 : 600000</option>
+<option value=''700000''>1 : 700000</option>
+<option value=''800000''>1 : 800000</option>
+<option value=''900000''>1 : 900000</option>
+<option value=''1000000''>1 : 1000000</option>','select','mod_scaleSel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','selArea1',2,1,'zoombox','img','../img/button_gray/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')" title="Zoom by rectangle"',295,10,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setBBOX',2,0,'set extent for mapframe and overviewframe','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setBackground',2,1,'switch background-wms','form','','',30,210,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12''
+name=''mod_setBackground_list''
+onchange=''mod_setBackground_change(this)'' ><option
+value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setSpatialRequest',2,1,'Spatial Request','div','','',1,1,1,1,1,'visibility:hidden;','','div','../javascripts/mod_wfs_SpatialRequest.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','showCoords_div',2,1,'displays coodinates by onmouseover','img','../img/button_gray/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" title="Coordinates" ',450,10,24,24,1,'','','','mod_coords_div.php','','mapframe1','dependendDiv','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','showLoggedUser',2,0,'Displays current user','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','tabs',1,1,'vertical tabs to handle iframes','div','','',10,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfs',2,1,'wfs request and result handling','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','wfs.js','../extensions/wz_jsgraphics.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfs_conf',2,1,'get all wfs_conf-params','iframe','../php/mod_wfs.php','frameborder = "0"',1,1,1,1,0,'visibility:hidden','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfsresult',2,1,'display the list of wfs results','iframe','../html/mod_blank.html','frameborder = "0"',10,730,200,150,4,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomFull',2,1,'zoom to full extent button','img','../img/button_gray/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"  title="Display complete map"',320,10,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomIn1',2,1,'zoomIn button','img','../img/button_gray/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' title="Zoom in"',220,10,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomOut1',2,1,'zoomOut button','img','../img/button_gray/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' title="Zoom out"',245,10,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'cssUrl', '../css/digitize.css', 'url to the style sheet of the mapframe', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'digitize_conf_filename', 'digitize_default.conf', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'text css', ' body{
+ font-family: Arial, Helvetica, sans-serif;
+ font-size : 12px;
+ color: #ff00ff;
+ background-color: #ffffff;
+ margin-top: 0px;
+ margin-left: 0px;
+ .button{
+ height: 18px;
+ width: 32px;
+', 'text css', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'wfsCssUrl', '../css/mapbender.css', 'var', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'gazetteerWFS', 'wfsConfIdString', '1,2,3,4', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'useUsemap', '0', '"1" adds a usemap to each geometry; the geometry will be highlighted onMouseOver. Every other value will skip the usemap.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'wfs_conf_filename', 'wfs_default.conf', 'location and name of the WFS configuration file', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'open_tab', '5', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[5]', '250', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[1]', 'legend', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[2]', 'printPDF', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[4]', 'imprint', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[5]', 'digitize', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_prefix', '  ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;padding-left:8px;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[0]', 'Maps', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[1]', 'Legend', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[2]', 'Print', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[3]', 'WFS Search', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[4]', 'Imprint', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_titles[5]', 'Digitize', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'menu', '', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'wfs', 'displayWfsResultList', '1', '', 'var');
+Delete from gui_element where fkey_gui_id ='admin1';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','AdminFrame',2,1,'the frame for administration modules','iframe','','frameborder = "0"',220,20,800,800,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','CreateTreeGDE',2,1,'create a foldertree for a individual geodataexplorer','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,810,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','CREATE TREE_GDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','EditWMSMetadata',2,1,'edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,950,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT WMS-METADATA','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_Gui',2,1,'allocate groups to guis','a','','href = "../php/mod_group_gui.php?sessionID&e_id_css=Group_Gui" target = "AdminFrame" ',10,610,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_User',2,1,'allocate groups to user','a','','href = "../php/mod_group_user.php?sessionID&e_id_css=Group_User" target = "AdminFrame" ',10,550,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','GROUP -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_filteredGui',2,1,'allocate Groups to the guis of this admin','a','','href = "../php/mod_group_filteredGui.php?sessionID&e_id_css=Group_filteredGui" target = "AdminFrame" ',10,710,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Gui_Group',2,1,'allocate guis to groups','a','','href = "../php/mod_gui_group.php?sessionID&e_id_css=Gui_Group" target = "AdminFrame" ',10,250,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Gui_User',2,1,'allocate a gui to user','a','','href = "../php/mod_gui_user.php?sessionID&e_id_css=Gui_User" target = "AdminFrame" ',10,190,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','User_Group',2,1,'allocat user to groups','a','','href = "../php/mod_user_group.php?sessionID&e_id_css=User_Group" target = "AdminFrame" ',10,430,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','body',1,1,'navigation','body','','onload=''mod_adminNavigation_init()''',0,0,0,0,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteGui',2,1,'delete gui','a','','href = "../php/mod_deleteGUI.php?sessionID" target = "AdminFrame" ',10,150,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteWFS',2,1,'delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,890,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteWMS',2,1,'delete wms','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,110,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','delete_filteredGui',2,1,'delete guis of this admin','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,790,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editElements',2,1,'edit gui elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,170,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','EDIT GUI-ELEMENTS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editFilteredGroup',2,1,'edit group of this admin','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',10,530,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editFilteredUser',2,1,'save, edit, delete user where this admin is owner','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',10,350,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editGUI_WMS',2,1,'edit the elements of the gui','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,90,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT GUI-WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editGroup',2,1,'edit group','a','','href = "../php/mod_editGroup.php?sessionID" target = "AdminFrame" ',10,510,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editUser',2,1,'save, edit, delete user','a','','href = "../php/mod_editUser.php?sessionID" target="AdminFrame"',10,330,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','exportGUI',2,1,'export gui, create SQLL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,310,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EXPORT GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl�che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGoup_filteredUser',2,1,'allocate the groups of this admin to user where the admin is owner','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',10,590,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> myUSER ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_Gui',2,1,'allocate groups of this admin to guis','a','','href = "../php/mod_filteredGroup_Gui.php?sessionID&e_id_css=filteredGroup_Gui" target = "AdminFrame" ',10,750,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_User',2,1,'allocate groups of this admin to user','a','','href = "../php/mod_filteredGroup_User.php?sessionID&e_id_css=filteredGroup_User" target = "AdminFrame" ',10,690,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_filteredGui',2,1,'allocate groups of this admin to guis of this admin','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',10,730,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_Group',2,1,'allocate guis to groups','a','','href = "../php/mod_filteredGui_group.php?sessionID&e_id_css=filteredGui_Group" target = "AdminFrame" ',10,270,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> GROUP ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_filteredGroup',2,1,'allocate guis of this admin to groups where this admin is owner','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',10,290,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_filteredUser',2,1,'allocate the user where the admin is owner to his guis ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',10,230,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_user',2,1,'allocate the guis of this admin to a user','a','','href = "../php/mod_filteredGui_User.php?sessionID&e_id_css=filteredGui_user" target = "AdminFrame" ',10,210,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> USER ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_Group',2,1,'allocate user of this admin to groups','a','','href = "../php/mod_filteredUser_Group.php?sessionID&e_id_css=filteredUser_Group" target = "AdminFrame" ',10,670,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_Gui',2,1,'allocate user of this admin to guis','a','','href = "../php/mod_filteredUser_Gui.php?sessionID&e_id_css=filteredUser_Gui" target = "AdminFrame" ',10,770,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_filteredGroup',2,1,'allocate user where this admin is owner to groups where this admin is owner','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',10,490,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_filteredGui',2,1,'allocate admins user to guis of this admin','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',10,410,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','getStyles',2,0,'load styles from wms','a','','href = "../php/mod_getStyles.php?sessionID" target = "AdminFrame" ',10,890,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GET_STYLES','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','group_filteredUser',2,1,'allocate groups to user where this admin is owner','a','','href = "../php/mod_group_filteredUser.php?sessionID&e_id_css=group_filteredUser" target = "AdminFrame" ',10,570,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_filteredGroup',2,1,'allocate guis to groups of this admin','a','','href = "../php/mod_gui_filteredGroup.php?sessionID&e_id_css=gui_filteredGroup" target = "AdminFrame" ',10,650,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_filteredUser',2,1,'allocate guis to user of this admin','a','','href = "../php/mod_gui_filteredUser.php?sessionID&e_id_css=gui_filteredUser" target = "AdminFrame" ',10,630,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_owner',2,1,'set owner','a','','href = "../php/mod_gui_owner.php?sessionID&e_id_css=gui_owner" target = "AdminFrame" ',10,830,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> OWNER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','help',2,1,'button help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" title="help"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWFS',2,1,'load capabilities in a gui','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,850,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/WFS_Konfiguration');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWMS',2,1,'load capabilities in a gui','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,30,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWMSList',2,1,'load wms from a list','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,50,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD myWMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','logout',2,1,'Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"',180,2,24,24,1,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','myGUIlist',2,1,'go back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zur�ck zur GUI Liste"',150,2,24,24,1,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','newGui',2,1,'create a new gui','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,130,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','NEW GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','orphanWMS',2,1,'display orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID&&elementID=orphanWMS" target = "AdminFrame"',10,930,200,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','ORPHAN WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','owsproxy',2,1,'secure services','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,910,200,20,1,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','OWSPROXY','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','rename_copy_Gui',2,1,'rename and copy gui','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,470,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','RENAME COPY GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','showLoggedUser',2,1,'displays the logged admin','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','updateWMSs',2,1,'edit the elements of the gui','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,70,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','UPDATE WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_filteredGroup',2,1,'allocate user to groups where this admin is owner','a','','href = "../php/mod_user_filteredGroup.php?sessionID&e_id_css=user_filteredGroup" target = "AdminFrame" ',10,450,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> myGROUP','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_filteredGui',2,1,'allocate guis of this admin to user','a','','href = "../php/mod_user_filteredGui.php?sessionID&e_id_css=user_filteredGui" target = "AdminFrame" ',10,390,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER-> myGUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_gui',2,1,'allocate guis to user','a','','href = "../php/mod_user_gui.php?sessionID&e_id_css=user_gui" target = "AdminFrame" ',10,370,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> GUI ','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','wfs_conf',2,1,'create and edit a gazetteer module','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,870,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','WFS CONF','a','','','','AdminFrame','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_Gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'User_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'editGUI_WMS', 'file_css', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_Gui', 'file css', '../css/administration_alloc.css', 'file', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_user', 'file css', '../css/administration_alloc.css', 'a file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_Gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'group_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin2_de';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','AdminFrame',2,1,'Bereich f�r Administrationsmodule','iframe','','frameborder = "0"',200,20,800,800,0,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','CreateTreeGDE',2,1,'Ordnerbaum konfigurieren','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',8,280,190,20,5,'','Ordnerbaum konfigurieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','body',1,1,'Navigation','body','','onload=''mod_adminNavigation_init()''',0,0,180,20,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','deleteWMS',2,1,'!Vollst�ndig l�schen!','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',8,100,190,20,5,'','!Vollst�ndig l�schen!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','delete_filteredGui',2,1,'GUI l�schen','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',110,240,80,20,5,'','GUI l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editElements',2,1,'Oberfl�chenelemente editieren','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',8,260,190,20,5,'','GUI-Elemente editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editFilteredGroup',2,1,'Gruppe anlegen und editieren','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',8,400,190,20,10,'','Gruppe anlegen und editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editFilteredUser',2,1,'Benutzer anlegen und editieren','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',8,380,190,20,10,'','Benutzer anlegen und editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editGUI_WMS',2,1,'WMS GUI Einstellungen','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',8,180,190,20,5,'','WMS GUI Einstellungen','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','exportGUI',2,1,'Oberfl�che (GUI) exportieren, SQL erzeugen','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',8,300,190,20,10,'','GUI exportieren (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl�che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGoup_filteredUser',2,1,'Gruppe mit Benutzern best�cken','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',8,440,190,20,10,'','Gruppe mit Benutzern best�cken ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGroup_filteredGui',2,1,'Einzelner Gruppe mehrere Oberflaechen zuordnen','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',8,570,190,25,10,'','Einzelner Gruppe mehrere <br>GUIs zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGui_filteredGroup',2,1,'Einzelner Oberfl�che mehrere Gruppen zuordnen','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',8,605,190,25,10,'','Einzelner GUI mehrere<br> Gruppen zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGui_filteredUser',2,1,'Oberfl�che mehreren Benutzer zuordnen ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',8,535,190,25,10,'','GUI mehreren Benutzern <br> zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredUser_filteredGroup',2,1,'Benutzer in Gruppen eintragen','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,420,190,20,10,'','Benutzer in Gruppen eintragen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredUser_filteredGui',2,1,'Einem Nutzer Zugriff auf mehrere Oberfl�chen erteilen','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',8,500,190,25,10,'','Einem Nutzer Zugriff auf <br> mehrere GUIs erteilen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','gui_owner',2,1,'GUI editieren Benutzer zuordnen','a','','href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame" ',8,640,190,20,10,'','GUI editieren Benutzer zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','help',2,1,'button help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" title="help"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','layout_0',3,1,'Hintergrund WMS Verwaltung Rahmen','div','','',3,35,193,90,1,'','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','layout_1',3,1,'Hintergrund WMS Management','div','','',5,37,193,86,2,'',' WMS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','layout_1a',3,1,'Hintergrund WMS Zuordnung Rahmen','div','','',3,135,193,70,1,'','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','layout_1b',3,1,'Hintergrund WMS Zuordnung','div','','',5,137,193,66,2,'',' WMS Zuordnung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','layout_1c',3,1,'Hintergrund Oberfl�chenverwaltung Rahmen','div','','',3,215,193,130,1,'','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','layout_1d',3,1,'Hintergrund Oberfl�chenverwaltung','div','','',5,217,193,126,2,'',' GUI-Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','layout_2',3,1,'Hintergrund Benutzerverwaltung Rahmen','div','','',3,355,193,110,1,'','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','layout_3',3,1,'Hintergrund Benutzerverwaltung','div','','',5,357,193,106,2,'',' Benutzerverwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','layout_4',3,1,'Hintergrund Benutzerzugriff erteilen Rahmen','div','','',3,475,193,200,1,'','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','layout_5',3,1,'Hintergrund Benutzerzugriff erteilen','div','','',5,477,193,196,2,'',' Benutzerzugriff erteilen','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','loadWMS',2,1,'Capabilities hochladen','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',8,60,190,20,5,'','Capabilities hochladen','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','loadWMSList',2,1,'WMS in GUI einbinden','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',8,160,190,20,5,'','WMS in GUI einbinden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','logout',2,1,'Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','myGUIlist',2,1,'Zur�ck zur eigenen GUI Liste','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zur�ck zur GUI Liste"',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','newGui',2,1,'GUI erzeugen','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',8,240,85,20,5,'','GUI erzeugen','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','rename_copy_Gui',2,1,'GUI umbenennen/ kopieren','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',8,320,190,20,10,'','GUI umbenennen/kopieren','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','showLoggedUser',2,1,'Anzeige des eingeloggten Benutzers','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','updateWMSs',2,1,'Hochgeladene aktualisieren','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',8,80,190,20,5,'','Hochgeladene aktualisieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'body', 'body_css_file', '../css/admin.css', 'css-file to define the style fo the admin-gui', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin2_en';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','AdminFrame',2,1,'the frame for administration modules','iframe','','frameborder = "0"',200,20,800,800,0,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','CreateTreeGDE',2,1,'TreeGDE set up','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',8,280,190,20,5,'','TreeGDE set up','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','body',1,1,'navigation','body','','onload=''mod_adminNavigation_init()''',0,0,0,0,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','deleteWMS',2,1,'!Delete completely!','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',8,100,190,20,5,'','!Delete completely!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','delete_filteredGui',2,1,'Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',120,240,80,20,5,'','Delete GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editElements',2,1,'Edit GUI elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',8,260,190,20,5,'','Edit GUI elements','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editFilteredGroup',2,1,'Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',8,400,190,20,10,'','Create and edit group','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editFilteredUser',2,1,'Create and edit user','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',8,380,190,20,10,'','Create and edit user','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editGUI_WMS',2,1,'WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',8,180,190,20,5,'','WMS GUI settings','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','exportGUI',2,1,'export GUI, create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',8,300,190,20,10,'','Export GUI (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl�che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGoup_filteredUser',2,1,'Add several users to one group','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',8,440,190,20,10,'','Add several users to one group ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGroup_filteredGui',2,1,'Allow one group access to several GUIs','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',8,570,190,25,10,'','Allow one group access to <br> several GUIs','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGui_filteredGroup',2,1,'Allow several groups access to one GUI','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',8,605,190,25,10,'','Allow several groups access <br> to one GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGui_filteredUser',2,1,'Allow several users access to one GUI ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',8,535,190,25,10,'','Allow several users access to <br> one GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredUser_filteredGroup',2,1,'Add one user to serveral groups','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,420,190,20,10,'','Add one user to serveral groups','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredUser_filteredGui',2,1,'Allow one user to access several GUIs','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',8,500,190,25,10,'','Allow one user to access <br> several GUIs','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','gui_owner',2,1,'Edit GUI assign to user','a','','href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame"  ',8,640,190,20,10,'','Edit GUI assign to user','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','help',2,1,'button help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" title="help"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','layout_0',3,1,'WMS Management border','div','','',3,35,193,90,1,'','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','layout_1',3,1,'WMS Management caption','div','','',5,37,193,86,2,'',' WMS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','layout_1a',3,1,'Configure WMS Access border','div','','',3,135,193,70,1,'','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','layout_1b',3,1,'Configure WMS Access','div','','',5,137,193,66,2,'',' Configure WMS Access','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','layout_1c',3,1,'GUI Management border','div','','',3,215,193,130,1,'','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','layout_1d',3,1,'GUI Management caption','div','','',5,217,193,126,2,'',' GUI Management ','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','layout_2',3,1,'User Management border','div','','',3,355,193,110,1,'','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','layout_3',3,1,'User Management caption','div','','',5,357,193,106,2,'',' User Management ','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','layout_4',3,1,'Authorization background','div','','',3,475,193,190,1,'','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','layout_5',3,1,'Authorization caption','div','','',5,477,193,186,2,'',' Authorization','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','loadWMS',2,1,'Load Capabilities','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',8,60,190,20,5,'','Load Capabilities','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','loadWMSList',2,1,'Link WMS into GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',8,160,190,20,5,'','Link WMS into GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','logout',2,1,'Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','myGUIlist',2,1,'go back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zur�ck zur GUI Liste"',150,2,24,24,2,'','','img','mod_home.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','newGui',2,1,'Create new GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',8,240,110,20,5,'','Create new GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','rename_copy_Gui',2,1,'Rename/ copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',8,320,190,20,10,'','Rename / copy GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','showLoggedUser',2,1,'Logged User:','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','updateWMSs',2,1,'Update with Capabilities','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',8,80,190,20,5,'','Update Capabilities','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'body', 'body_css_file', '../css/admin.css', 'css-file to define the style fo the admin-gui', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGoup_filteredUser', 'css_file_filteredGroup_filterdUser', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGroup', 'css_filteredUser_filteredGroup', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin_de_services';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','AdminFrame',2,1,'Bereich f�r Administrationsmodule','iframe','','frameborder = "0"',210,25,800,800,12,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','CreateTreeGDE',2,1,'Ordnerbaum konfigurieren','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,516,200,20,5,'','Ordnerbaum konfigurieren','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','EditWMSMetadata',2,1,'edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,275,200,20,5,'','WMS Metadaten','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_WMS_Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','body',1,1,'Navigation','body','','onload=''mod_adminNavigation_init()''',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','deleteWFS',2,1,'WFS l�schen','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,393,200,20,5,'','WFS l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','deleteWMS',2,1,'!Vollst�ndig l�schen!','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,100,200,20,5,'','WMS l�schen!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','delete_filteredGui',2,1,'GUI l�schen','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,471,200,20,5,'','GUI l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','editElements',2,1,'Oberfl�chenelemente editieren','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,491,200,25,5,'','GUI editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','editGUI_WMS',2,1,'WMS GUI Einstellungen','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,218,200,20,5,'','WMS Einstellungen �ndern','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','exportGUI',2,1,'GUI exportieren, SQL erzeugen','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,536,200,25,10,'x','GUI exportieren (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl�che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','filteredWms_layer_topic',2,1,'allocate topics to layers of wms of this user','a','','href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ',10,295,200,20,5,'','Kategoriezuordnung','a','','','','AdminFrame','http://www.mapbender.org/index.php/Topic_/_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_Configure_WMS_Access',3,1,'Hintergrund WMS Zuordnung','div','','',1,175,210,63,2,'','WMS Zuordnung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_GUI_Management',3,1,'Oberfl�chenverwaltung','div','','',1,428,210,153,2,'','GUI Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_Metadata',3,1,'Metadateneditor Caption','div','','',1,252,210,63,2,'','Metadaten','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_WFS_Management',3,1,'WFS Verwaltung','div','','',1,330,210,82,2,'','WFS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_WMS_Management',3,1,'Dienstverwaltung Beschriftung','div','','',0,37,210,123,2,'','WMS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','help',2,1,'button help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" title="help"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWFS',2,1,'WFS Capabilities in eine GUI laden','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,353,200,20,5,'','WFS laden','a','','','','AdminFrame','http://www.mapbender.org/index.php/LoadWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWMS',2,1,'Capabilities hochladen','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,60,200,20,5,'','WMS laden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWMSList',2,1,'WMS in GUI einbinden','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,198,200,20,5,'','WMS einbinden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','logout',2,1,'Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','myGUIlist',2,1,'Zur�ck zur eigenen GUI Liste','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zur�ck zur GUI Liste"',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','newGui',2,1,'GUI erzeugen','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,451,200,20,5,'','GUI erzeugen','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','orphanWMS',2,1,'display orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID"
+target = "AdminFrame"',10,120,200,20,5,'','WMS ohne Zuordung l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','owsproxy',2,1,'secure services','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,140,200,20,10,'','OWSPROXY','a','','','','AdminFrame','http://www.mapbender.org/index.php/Owsproxy');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','rename_copy_Gui',2,1,'GUI umbenennen/ kopieren','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,561,200,20,10,'','GUI umbenennen/kopieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/RenameGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','showLoggedUser',2,1,'Anzeige des eingeloggten Benutzers','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','updateWMSs',2,1,'Hochgeladene aktualisieren','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,80,200,20,5,'','WMS aktualisieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','wfs_conf',2,1,'WFS konfigurieren','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,373,200,20,5,'','WFS konfigurieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Wfs_conf');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'EditWMSMetadata', 'file_css', '../css/metadata.css', 'css-file to use for the metadata modul', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'body', 'body_file_css', '../css/admin_service.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'filteredWms_layer_topic', 'file css', '../css/administration_alloc_4.css', 'css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'filteredWms_layer_topic', 'language', 'de', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin_en_services';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','AdminFrame',2,1,'administration frame','iframe','','frameborder = "0"',210,25,1000,800,12,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','CreateTreeGDE',2,1,'Configure TreeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,513,200,20,5,'','Configure TreeGDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','EditWMSMetadata',2,1,'edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,275,200,20,5,'','WMS Metadata','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_WMS_Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','body',1,1,'Navigation','body','','onload=''mod_adminNavigation_init()''',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','deleteWFS',2,1,'Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,393,200,20,5,'','Delete WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','deleteWMS',2,1,'!Delete completely!','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,100,200,20,5,'','!Delete completely!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','delete_filteredGui',2,1,'Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,471,200,20,5,'','Delete GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','editElements',2,1,'Edit GUI Elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,491,200,20,5,'','Edit GUI Elements','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','editGUI_WMS',2,1,'WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,218,200,20,5,'','WMS GUI settings','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','exportGUI',2,1,'Export GUI (SQL), create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,533,200,20,10,'x','Export GUI (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl�che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','filteredWms_layer_topic',2,1,'allocate topics to layers of wms of this user','a','','href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ',10,295,200,20,5,'','Allocate topics','a','','','','AdminFrame','http://www.mapbender.org/index.php/Topic_/_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_Configure_WMS_Access',3,1,'WMS Assignment','div','','',1,175,210,63,2,'','WMS Assignment','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_GUI_Management',3,1,'GUI Management','div','','',1,428,210,148,2,'','GUI Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_Metadata',3,1,'Metadata','div','','',1,252,210,63,2,'','Metadata','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_WFS_Management',3,1,'WFS Management','div','','',1,330,210,82,2,'','WFS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_WMS_Management',3,1,'WMS Management','div','','',0,37,210,123,2,'','WMS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','help',2,1,'button help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" title="help"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWFS',2,1,'Load WFS Capabilities into a GUI','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,353,200,20,5,'','Load WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/LoadWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWMS',2,1,'load Capabilities','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,60,200,20,5,'','Load Capabilities','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWMSList',2,1,'assign WMS to a GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,198,200,20,5,'','Assign WMS to a GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','logout',2,1,'Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' title="Logout"',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','myGUIlist',2,1,'back to GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' title="move back to your GUI list / zur�ck zur GUI Liste"',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','newGui',2,1,'New GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,451,200,20,5,'','New GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','orphanWMS',2,1,'Delete orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID"
+target = "AdminFrame"',10,120,200,20,5,'','Delete orphaned WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','owsproxy',2,1,'secure services','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,140,200,20,10,'','OWSPROXY','a','','','','AdminFrame','http://www.mapbender.org/index.php/Owsproxy');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','rename_copy_Gui',2,1,'Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,556,200,20,10,'','Rename / copy GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/RenameGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','showLoggedUser',2,1,'show logged in user','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','updateWMSs',2,1,'Update Capabilities','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,80,200,20,5,'','Update Capabilities','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','wfs_conf',2,1,'Configure WFS','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,373,200,20,5,'','Configure WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Wfs_conf');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'EditWMSMetadata', 'file_css', '../css/metadata.css', 'css-file to use for the metadata modul', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'body', 'body_file_css', '../css/admin_service.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'filteredWms_layer_topic', 'file css', '../css/administration_alloc_4.css', 'css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'filteredWms_layer_topic', 'language', 'de', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui','switchLocale_noreload',8,1,'changes the locale without reloading the client','Set language','div','','frameborder=''0''',696,14,50,30,5,'','<form id=''form_switch_locale'' name=''form_switch_locale'' target=''parent''>
+<select id=''language'' name=''language'' onchange=''validate_locale()''>
+</select>
+</form>
+','div','mod_switchLocale_noreload.php','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'switchLocale_noreload', 'languages', 'de,en,bg,gr,nl,it,es', '' ,'var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_closetag, e_js_file) VALUES('gui1', 'popup', 6, 1, 'popup replacement', 'div', 'div', 'popup.js');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui1' AND e_id = 'wfs_gazetteer';
+DELETE FROM gui_treegde WHERE fkey_gui_id IN ('gui', 'gui1', 'admin1', 'gui2', 'wms_africa');
+-- update own applications
+Update gui_element set e_title =
+mynew.e_title from gui_element as mynew
+where gui_element.e_id = mynew.e_id
+and mynew.fkey_gui_id = 'gui'
+and gui_element.fkey_gui_id != 'gui'
+and gui_element.fkey_gui_id != 'gui1'
+and gui_element.fkey_gui_id != 'gui2'
+and gui_element.fkey_gui_id != 'gui_digitize';
+and mynew.fkey_gui_id = 'gui1'
+and mynew.fkey_gui_id = 'gui2'
+and mynew.fkey_gui_id = 'gui_digitize'
+Delete from gui_element_vars where fkey_e_id ='tabs' and var_name LIKE 'tab_titles[%';
+Update gui_element_vars set var_type='php_var' where fkey_e_id ='tabs' and var_name LIKE 'tab_ids[%' and var_type='var';
+DELETE FROM gui_element WHERE e_id = 'ajax';
+Delete from gui_element where e_id='keyHandler';
+DELETE FROM gui_element WHERE e_id = 'geometry';
+Select * from gui_element where e_mb_mod ='geometry.js' ;
+update gui_element set e_mb_mod = 'geometry.js'
+where e_id = 'digitize';
+where e_id = 'gazetteerWFS';
+where e_id = 'setSpatialRequest';
Added: branches/2.5/resources/db/postgresql/utf8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql
--- branches/2.5/resources/db/postgresql/utf8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql	                        (rev 0)
+++ branches/2.5/resources/db/postgresql/utf8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql	2008-09-29 14:36:55 UTC (rev 3041)
@@ -0,0 +1,540 @@
+-- database changes in version 2.5
+-- notice language plpgsql has to be installed
+-- How to install plpgsql?
+-- createlang plpgsql mapbender
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin_de_services', 20, '');
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin_en_services', 20, '');
+-- table mb_monitor: new columns for mb_monitor
+ALTER TABLE mb_monitor ADD COLUMN image int4;
+ALTER TABLE mb_monitor ADD COLUMN map_url varchar(2048);
+-- WFS database handling
+-- enhancement of the datadase structure concerning WFS metadata (same solution like for WMS)
+ALTER table wfs add wfs_getcapabilities_doc text;
+ALTER table wfs add wfs_upload_url character varying(255);
+ALTER table wfs add fees character varying(255);
+ALTER table wfs add accessconstraints text;
+ALTER table wfs add individualname character varying(255);
+ALTER table wfs add positionname character varying(255);
+ALTER table wfs add providername character varying(255);
+ALTER table wfs add city character varying(255);
+ALTER table wfs add deliverypoint character varying(255);
+ALTER table wfs add administrativearea character varying(255);
+ALTER table wfs add postalcode character varying(255);
+ALTER table wfs add voice character varying(255);
+ALTER table wfs add facsimile character varying(255);
+ALTER table wfs add electronicmailaddress character varying(255);
+ALTER table wfs add wfs_mb_getcapabilities_doc text;
+ALTER table wfs add wfs_owner integer;
+ALTER table wfs add wfs_timestamp integer;
+ALTER table wfs add country character varying(255);
+ALTER TABLE wfs ALTER COLUMN wfs_title SET NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_title SET DEFAULT ''::character varying;
+ALTER TABLE wfs ALTER COLUMN wfs_version SET NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_version SET DEFAULT ''::character varying;
+ALTER TABLE wfs ALTER COLUMN wfs_getcapabilities SET NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_getcapabilities SET DEFAULT ''::character varying;
+alter table wfs_featuretype add column featuretype_searchable integer default 1;
+alter table wfs_featuretype add column featuretype_abstract character varying(50);
+-- grant root access to default wfs
+UPDATE wfs SET wfs_owner = 1;
+-- new table gui_wfs_conf
+CREATE TABLE gui_wfs_conf (
+    fkey_gui_id character varying(50) DEFAULT ''::character varying NOT NULL,
+    fkey_wfs_conf_id integer DEFAULT 0 NOT NULL
+ALTER TABLE ONLY gui_wfs_conf
+    ADD CONSTRAINT pk_fkey_wfs_conf_id PRIMARY KEY (fkey_gui_id, fkey_wfs_conf_id);
+    ADD CONSTRAINT gui_wfs_conf_ibfk_1 FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
+    ADD CONSTRAINT gui_wfs_conf_ibfk_2 FOREIGN KEY (fkey_wfs_conf_id) REFERENCES wfs_conf(wfs_conf_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- insert wfs confs into gui digitize
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 1);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 3);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 4);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 2);
+-- new table wfs_featuretype_keyword:
+CREATE TABLE wfs_featuretype_keyword (
+  fkey_featuretype_id integer NOT NULL,
+  fkey_keyword_id integer NOT NULL
+ALTER TABLE ONLY wfs_featuretype_keyword
+    ADD CONSTRAINT fkey_keyword_id_fkey_featuretype_id FOREIGN KEY (fkey_keyword_id) REFERENCES keyword(keyword_id) ON UPDATE CASCADE ON DELETE CASCADE;
+    ADD CONSTRAINT fkey_featuretype_id_fkey_keyword_id FOREIGN KEY (fkey_featuretype_id) REFERENCES wfs_featuretype(featuretype_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- new table layer_load_count
+CREATE TABLE layer_load_count (
+ fkey_layer_id int4,
+ load_count int8
+-- table wfs_conf
+ALTER TABLE wfs_conf add COLUMN wfs_conf_description text;
+-- table wfs_conf_element: change in WFS configuration: access to geometries may now be restricted
+ALTER TABLE wfs_conf_element ADD COLUMN f_auth_varname VARCHAR(50);
+ALTER TABLE wfs_conf_element ADD COLUMN f_show_detail int4;
+ALTER TABLE wfs_conf_element ADD COLUMN f_operator VARCHAR(50);
+ALTER TABLE ONLY wfs_conf
+    ADD CONSTRAINT wfs_conf_ibfk_2 FOREIGN KEY (fkey_featuretype_id) REFERENCES wfs_featuretype(featuretype_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- table gui_element: new element for table admin1 to edit wfs settings
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','WFS',2,1,'edit wfs settings','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,1005,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT WFS','a','','','','AdminFrame','');
+-- new table translation: new table for translations
+CREATE TABLE translations
+  trs_id serial PRIMARY KEY not null,
+  locale varchar(8),
+  msgid varchar(512),
+  msgstr varchar(512)
+CREATE INDEX msgid_idx ON translations(msgid);
+ CREATE TRUSTED PROCEDURAL LANGUAGE 'plpgsql'
+  HANDLER plpgsql_call_handler;
+-- new function gettext for easy translations
+CREATE OR REPLACE FUNCTION gettext(locale_arg "text", string "text")
+RETURNS "varchar" AS
+$BODY$
+DECLARE
+    msgstr varchar(512);
+    trl RECORD;
+BEGIN
+    -- RAISE NOTICE '>%<', locale_arg;
+    SELECT INTO trl * FROM translations
+    WHERE trim(from locale) = trim(from locale_arg) AND msgid = string;
+    -- we return the original string, if no translation is found.
+    -- this is consistent with gettext's behaviour
+    IF NOT FOUND THEN
+        RETURN string;
+    ELSE
+        RETURN trl.msgstr;
+    END IF;
+END;
+$BODY$
+  LANGUAGE 'plpgsql' VOLATILE;
+-- new entries for table translations
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Pan', 'Ausschnitt verschieben');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Display complete map', 'gesamte Karte anzeigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom in', 'In die Karte hineinzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom out', 'Aus der Karte herauszoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Back', 'Zurück');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Forward', 'Nach vorne');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Coordinates', 'Koordinaten anzeigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom by rectangle', 'Ausschnitt wählen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Redraw', 'Neu laden oder Tastatur: Leertaste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Query', 'Datenabfrage');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Logout', 'Abmelden');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'WMS preferences', 'WMS Einstellungen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS from filtered list', 'WMS von gefilteter Liste hinzufügen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set map center', 'Kartenmittelpunkt setzen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Help', 'Hilfe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Show WMS infos', 'Anzeige von WMS Informationen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Save workspace as web map context document', 'Ansicht als Web Map Context Dokument speichern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Resize Mapsize', 'Bildschirmgröße anpassen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Rubber', 'Skizze löschen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Get Area', 'Fläche berechnen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Close Polygon', 'Polygon schliessen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Move back to your GUI list', 'Zurück zur GUI Liste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Legend', 'Legende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Print', 'Druck');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Imprint', 'Impressum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Maps', 'Karten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Search', 'Suche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Meetingpoint', 'Treffpunkt');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Metadatasearch', 'Metadatensuche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS', 'WMS hinzufügen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS from List', 'WMS aus Liste hinzufügen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Change Projection', 'Projektion ändern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Digitize', 'Digitalisierung');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Overview', 'Übersichtskarte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Drag Mapsize', 'Karte vergrößern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Mapframe', 'Kartenfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Navigation Frame', 'Navigationsfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scale Select', 'Auswahl des Maßstabes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scale Text', 'Maßstab per Texteingabe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scalebar', 'Maßstabsleiste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set Background', 'Hintegrundkarte auswählen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom to Coordinates', 'Zu den Koordinaten zoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Change Password', 'Passwort ändern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Load a web map context document', 'laden eines Web Map Context Dokumentes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de ', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Pan', 'Премести областта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Display complete map', 'Покажи цялата карта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom in', 'Покажи картата в по-едър мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom out', 'Покажи картата в по-дребен мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Back', 'Назад');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Forward', 'Напред');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Coordinates', 'Координати');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom by rectangle', 'Увеличи картата в избраната област');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Redraw', 'Пречертай или от клавиатурата: празен интервал');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Query', 'Зявка към данните');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Logout', 'Изход на потребител');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'WMS preferences', 'WMS настройки');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS from filtered list', 'Добави WMS от избран списък');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Set map center', 'Постави център на карта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Help', 'Помощ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Show WMS infos', 'Покажи WMS информация');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Save workspace as web map context document', 'Запази работния документ като Web Map Context документ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Resize Mapsize', 'Напасни големината на картата');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Rubber', 'Изтрий');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Get Area', 'Изчисли площ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Close Polygon', 'Затвори полигон');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Move back to your GUI list', 'Назад към списъка с интерфейси (GUI)');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Legend', 'Легенда');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Print', 'Печат');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Imprint', 'Авторско каре');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Maps', 'Карти');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Search', 'Търсене');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Meetingpoint', 'Място на среща');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Metadatasearch', 'Търсене по метаданни');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS', 'Добави WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS from List', 'Добави WMS от списък');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Info', 'Информация');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Change Projection', 'Промени проекция');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Copyright', 'Авторско право');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Digitize', 'Дигитализиране');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Overview','Обзорна карта');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Drag Mapsize', 'Промени размера на картата');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Mapframe', 'Рамка на картата');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Navigation Frame', 'Навигационна рамка');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scale Select', 'Избор на мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scale Text', 'Въведи мащаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scalebar', 'Мащабна скала');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Set Background', 'Избери фоново изображение');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom to Coordinates', 'Покажи картата около посочените координати');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Change Password', 'Промени парола');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Load a web map context document', 'Зареди Web Map Context документ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Logo', 'Фирмен знак');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Measure distance', 'Измери разстояние');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Pan', 'Μετακίνηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Display complete map', 'Επίδειξη Πλήρους Χάρτη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom in', 'Zoom In');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom out', 'Zoom Out');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Back', 'Πίσω');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Forward', 'Πρόσθια');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Coordinates', 'Συντεταγμένες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom by rectangle', 'Ζουμ από ορθογώνιο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Redraw', 'Απόσυρση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Query', 'Μέτρηση Εμβαδού');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Logout', 'Αποσύνδεση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'WMS preferences', 'Αλλάξτε τη διάταξη των WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS from filtered list', 'Πρόσθεση WMS από το φιλτραρισμένο κατάλογο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Set map center', 'Το καθορισμένο Κέντρο Χαρτών');
+INSERT INTO translations (locale, msgid, msgstr) VALUES  ('gr', 'Help', 'Βοήθεια');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Save workspace as web map context document', 'Ansicht als Web Map Context Dokument speichern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Rubber', 'Το λάστιχο- Τρίφτης');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Close Polygon', 'Το Κλειστό Πολύγωνο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ( 'gr', 'Move back to your GUI list', 'Παρουσίαση του GUI Καταλόγου');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Print', 'Εκτύπωση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Maps', ' Χάρτες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS', 'Πρόσθεση WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS from List', 'Πρόσθεση WMS από τον κατάλογο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Navigation Frame', 'Navigationsfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Load a web map context document', 'laden eines Web Map Context Dokumentes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Measure distance', 'Μέτρηση Απόστασης');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Meetingpoint', 'Σημείο Συνάντησης');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Info', 'Πληροφορίες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Digitize', 'Ψηφιοποίηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Change Projection', 'Αλλαγή Προβολής');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Set Background', 'Επιλογή Φόντου');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Overview', 'Προεπισκόπιση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Change Password', 'Αλλαγή Συνθηματικού');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scalebar', 'Κανόνας Κλίμακας');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr ', 'Logo', 'Λογότυπο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom to Coordinates', 'Εστίαση σε Συντεταγμένες');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scale Text', 'Κείμενο Κλίμακας');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Show WMS infos', 'Προβολή WMS πληροφοριών');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Legend', 'Λεζάντα');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Search', 'Αναζήτηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Resize Mapsize', 'Αλλαγή Μεγέθους Χάρτη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Drag Mapsize', 'Αλλαγή Μεγέθους Χάρτη με Ολίσθηση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Mapframe', 'Πλαίσιο Χάρτη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Get Area', 'Προβολή Περιοχής');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Imprint', 'Αποτύπωση');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scale Select', 'Επιλογή Κλίμακας');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Metadatasearch', 'Αναζήτηση στα Metadata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Pan', 'Selectie verschuiven');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Display complete map', 'Hele kaart tonen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom in', 'Inzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom out', 'Uitzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Back', 'Terug');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Forward', 'Voorwaarts');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Coordinates', 'Koordinaten tonen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom by rectangle', 'Zoom rechthoek-selectie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Redraw', 'Opfrissen of toetsenbord : spatiebalk');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Query', 'Data opvragen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Logout', 'Afmelden');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'WMS preferences', 'WMS instellingen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS from filtered list', 'WMS van gefilterte lijst toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set map center', 'Kaartmiddelpunt aangeven');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Help', 'Help');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Show WMS infos', 'Tonen van WMS Informatie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Save workspace as web map context document', 'zicht als Web map context dokument bewaren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Resize Mapsize', 'beeldschermgrote aanpassen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Rubber', 'schets verwerpen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Get Area', 'oppervlakte berekenen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Close Polygon', 'Polygoon sluiten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Move back to your GUI list', 'Terug naar GUI lijst');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Legend', 'Legende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Print', 'Drukken');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Imprint', 'Impressum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Maps', 'Kaarten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Search', 'Zoek');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Meetingpoint', 'Trefpunt');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Metadatasearch', 'Zoeken naar Metadata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS', 'WMS toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS from List', 'WMS uit lijst toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Info', 'Informatie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Change Projection', 'Projektie veranderen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Digitize', 'Digitaliseren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Overview', 'overzichtskaart');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Drag Mapsize', 'Kaart vergroten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Mapframe', 'Kaartvenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Navigation Frame', 'Navigeervenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scale Select', 'Schaal selecteren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scale Text', 'Schaal via tekstingave');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scalebar', 'Schaalbalk');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set Background', 'Achtergrond selecteren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom to Coordinates', 'Naar koordinaten zoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Change Password', 'Paswoord wijzigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Load a web map context document', 'Laad een Web Map Context Dokument');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Measure distance', 'Meet afstand');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Pan', 'Sposta dettaglio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Display complete map', 'Mostra tutta la mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom in', 'Ingrandisci');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom out', 'Riduci');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Back', 'Indietro');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Forward', 'Avanti');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Coordinates', 'Mostra coordinate');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom by rectangle', 'Seleziona dettaglio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Redraw', 'Ridisegna oppure, da tastiera: spazio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Query', 'Interroga');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Logout', 'Logout');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'WMS preferences', 'Impostazioni WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS from filtered list', 'Aggiungi un WMS da una lista filtrata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set map center', 'Fissa il centro della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Help', 'Aiuto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Show WMS infos', 'Mostra informazioni sul WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Save workspace as web map context document', 'Salva vista come documento di Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Resize Mapsize', 'Adatta la dimensione della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Rubber', 'Cancella bozza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Get Area', 'Calcola area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Close Polygon', 'Chiudi poligono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Move back to your GUI list', 'Torna alla lista delle GUI');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Legend', 'Legenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Print', 'Stampa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Imprint', 'Colophon');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Maps', 'Mappe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Search', 'Cerca');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Meetingpoint', 'Punti di incontro');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Metadatasearch', 'Ricerca metadati');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS', 'Aggiungi WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS from List', 'Aggiungi WMS da lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Change Projection', 'Cambia proiezione');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Digitize', 'Digitalizza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Overview', 'Mappa di insieme');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Drag Mapsize', 'Cambia dimensione mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Mapframe', 'Quadro della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Navigation Frame', 'Quadro di navigazione');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scale Select', 'Scelta della scala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scale Text', 'Scala dei testi');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scalebar', 'Scala di riferimento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set Background', 'Seleziona mappa di sfondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom to Coordinates', 'Ingrandisci alle coordinate');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Change Password', 'Cambia password');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Load a web map context document', 'Carica un documento Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Measure distance', 'Misura distanza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Pan', 'Desplazamiento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Display complete map', 'Desplazamiento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom in', 'Zoom +');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom out', 'Zoom -');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Back', 'Zoom previo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Forward', 'Zoom siguiente');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Coordinates', 'Mostrar coordenadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom by rectangle', 'Zoom rectángulo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Redraw', 'Refrescar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Query', 'Busqueda de datos');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Logout', 'Terminar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'WMS preferences', 'Ajuste WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS from filtered list', 'Anadir WMS desde lista filtrada');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set map center', 'Centrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Help', 'Ayuda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Show WMS infos', 'Mostrar información sobre WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Save workspace as web map context document', 'Guardar vista como fichero Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Resize Mapsize', 'Modificar el tamano de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Rubber', 'Borrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Get Area', 'Calcular area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Close Polygon', 'Cerrar polígono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Move back to your GUI list', 'Volver a la lista WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Legend', 'Leyenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Print', 'Imprimir');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Imprint', 'Aviso legal');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Maps', 'Mapas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Search', 'Busqueda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Meetingpoint', 'Lugar de reunión');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Metadatasearch', 'Búsqueda de datos meta');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS', 'Añadir WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS from List', 'Añadir WMS desde lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Info', 'Informacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Change Projection', 'Cambiar projecto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Digitize', 'Digitalización');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Overview', 'Mapa de visión general');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Drag Mapsize', 'Ampilar vista de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Mapframe', 'Ventana de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Navigation Frame', 'Ventana de navigacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scale Select', 'Selecionar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scale Text', 'Teclar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scalebar', 'Fraja de escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set Background', 'Poner el fondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom to Coordinates', 'Zoom en coordenadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Change Password', 'Cambiar clave');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Load a web map context document', 'Cargar un documento de Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Measure distance', 'Medir distancias');
+-- new table gui_kml
+CREATE TABLE gui_kml (
+    kml_id serial,
+    fkey_mb_user_id integer NOT NULL,
+    fkey_gui_id character varying(50) NOT NULL,
+    kml_doc text NOT NULL,
+    kml_name character varying(64),
+    kml_description text,
+    kml_timestamp integer NOT NULL
+ALTER TABLE ONLY gui_kml
+    ADD CONSTRAINT mb_gui_kml_pkey PRIMARY KEY (kml_id);
+    ADD CONSTRAINT gui_kml_fkey_mb_user_id FOREIGN KEY (fkey_mb_user_id) REFERENCES mb_user(mb_user_id) ON UPDATE CASCADE ON DELETE CASCADE;
+    ADD CONSTRAINT gui_kml_id_fkey_gui_id  FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- new sld_user_layer table
+CREATE TABLE sld_user_layer (
+    sld_user_layer_id serial NOT NULL,
+    fkey_layer_id integer NOT NULL,
+    fkey_gui_id character varying,
+    sld_xml text,
+    use_sld smallint
+ALTER TABLE sld_user_layer ADD CONSTRAINT pk_sld_user_layer PRIMARY KEY  (sld_user_layer_id);
+-- Name: sld_user_layer_ibfk_1; Type: FK CONSTRAINT; Schema: public; Owner: admin
+ALTER TABLE ONLY sld_user_layer
+    ADD CONSTRAINT sld_user_layer_ibfk_1 FOREIGN KEY (fkey_mb_user_id) REFERENCES mb_user(mb_user_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- Name: sld_user_layer_ibfk_2; Type: FK CONSTRAINT; Schema: public; Owner: admin
+    ADD CONSTRAINT sld_user_layer_ibfk_2 FOREIGN KEY (fkey_layer_id) REFERENCES layer(layer_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- Name: sld_user_layer_ibfk_3; Type: FK CONSTRAINT; Schema: public; Owner: admin
+    ADD CONSTRAINT sld_user_layer_ibfk_3 FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- add sld related columns
+alter table gui_wms add column gui_wms_sldurl character varying(255) DEFAULT ''::character varying NOT NULL;
+alter table wms add column wms_supportsld boolean;
+alter table wms add column wms_userlayer boolean;
+alter table wms add column wms_userstyle boolean;
+alter table wms add column wms_remotewfs boolean;
+-- opacity handeling
+ALTER TABLE gui_wms ADD COLUMN gui_wms_opacity INT DEFAULT 100;
+UPDATE gui_element SET e_mb_mod = 'mod_addWMSgeneralFunctions.js' WHERE e_id = 'addWMS';
+ALTER TABLE gui_element MODIFY e_js_file character varying(255);
+ALTER TABLE gui_element MODIFY e_mb_mod character varying(255);
+ALTER TABLE wms MODIFY fees text;
+ALTER TABLE wms CHANGE COLUMN wms_mb_getcapabilies_doc wms_mb_getcapabilities_doc text;
\ No newline at end of file
Added: branches/2.5/resources/db/postgresql/utf8/update/update_2.5rc6_to_2.5_pgsql_UTF-8.sql
--- branches/2.5/resources/db/postgresql/utf8/update/update_2.5rc6_to_2.5_pgsql_UTF-8.sql	                        (rev 0)
+++ branches/2.5/resources/db/postgresql/utf8/update/update_2.5rc6_to_2.5_pgsql_UTF-8.sql	2008-09-29 14:36:55 UTC (rev 3041)
@@ -0,0 +1 @@
Added: branches/2.5/resources/db/postgresql/utf8/update/update_guis_2.4.5_to_2.5_pgsql_UTF-8.sql
--- branches/2.5/resources/db/postgresql/utf8/update/update_guis_2.4.5_to_2.5_pgsql_UTF-8.sql	                        (rev 0)
+++ branches/2.5/resources/db/postgresql/utf8/update/update_guis_2.4.5_to_2.5_pgsql_UTF-8.sql	2008-09-29 14:36:55 UTC (rev 3041)
@@ -0,0 +1,899 @@
+-- update of mapbender guis
+-- gui / gui1 / gui2 / gui_digitize
+-- admin1 / admin2_de / admin2_de / admin_de_services / admin_en_services
+-- Mapbender Test for Version: 2.5
+-- 2007-11-29
+-- notice: this guis are not all working properly
+-- the guis contain the e_title informations fpor i18n
+-- these sql are for developers to get the guis working
+Delete from gui_element where fkey_gui_id ='gui';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','FeatureInfoRedirect',2,1,'redirect featureInfoRequests in an iframe for each wms','Info','iframe','../html/mod_blank.html','frameborder="0"',83,-17,1,1,0,'','','iframe','mod_featureInfoRedirect.php','','','','http://www.mapbender.org/index.php/FeatureInfoRedirect');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','WMS_preferences',2,1,'configures the preferences of each loaded wms','WMS preferences','img','../img/button_gray/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',540,10,24,24,1,'','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_gray/add_off.png','onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',515,10,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','back',2,1,'History.back()','Back','img','../img/button_gray/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"',360,10,24,24,1,'','','','mod_back.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','body',1,1,'body (obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','featureInfo1',2,0,'FeatureInfoRequest','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')"',425,10,24,24,1,'','','','mod_featureInfoTunnel.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfoTunnel');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','forward',2,1,'History.forward()','Forward','img','../img/button_gray/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" ',385,10,24,24,1,'','','','mod_forward.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','gazetteerMetadata',2,1,'gazetteer for metadata','Metadatasearch','iframe','../php/mod_gazetteerMetadata.php?sessionID&target=mapframe1,overview','frameborder = "0"',1,1,1,1,4,'visibility:hidden;','','iframe','','','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','Search','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','geometry.js','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" ',620,10,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','highlightPOI',2,1,'highlight 1 to n pois in your gui with a Symbol and a special text','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_highlightPOI.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','imprint',2,1,'Information about the owner of the gui','Imprint','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_back',3,1,'layout, background for buttons','','div','','',360,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_featureInfo',3,1,'layout, background for FeatureInfo','','div','','',425,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_help',3,1,'layout, background for Help-button','','div','','',620,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_logout',3,1,'layout, background for Logout-button','','div','','',660,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_metadata',3,1,'layout, background for Metadata','','div','','',580,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_wms',3,1,'layout, background for wms','','div','','',490,10,76,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_zoom',3,1,'layout, background for Zoom-button','','div','','',220,10,126,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','loadData',2,1,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','logo',2,1,'Logo','Logo','img','../img/mapbender_logo.png','',20,20,180,26,5,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' ',660,10,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','mapframe1',2,1,'frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',230,55,500,450,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','meetingPoint',2,1,'create a meeting point','Meetingpoint','iframe','../php/mod_meetingPoint.php?sessionID','frameborder = "0" ',0,0,NULL ,NULL ,4,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_gray/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_gray/metadata_over.png"'' onmouseout=''this.src="../img/button_gray/metadata_off.png"'' ',580,10,24,24,1,'','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,0,0,0,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',30,65,150,130,100,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','pan1',2,1,'pan','Pan','img','../img/button_gray/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')" ',270,10,24,24,1,'','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','printPDF',2,1,'pdf print','Print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_gray/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')" ',295,10,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','setBBOX',2,0,'set extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','setBackground',2,1,'switch background-wms','Set Background','form','','',30,210,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','showCoords_div',2,1,'displays coodinates by onmouseover','Coordinates','img','../img/button_gray/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ',450,10,24,24,1,'','','','mod_coords_div.php','','mapframe1','dependendDiv','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','tabs',2,1,'vertical tabs to handle iframes','','div','','',10,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2','Maps','iframe','../html/mod_treefolder2.php?sessionID','frameborder = "0" ',10,220,200,300,NULL ,'visibility:visible','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_gray/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)" ',320,10,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_gray/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' ',220,10,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_gray/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''',245,10,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_all', '0', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_group', '0', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_gui', '0', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'gazetteerWFS', 'wfsConfIdString', '1', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_height', '14', 'height of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_width', '14', 'width of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_ccs_file', '../css/meetingPoint.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_format', 'prompt', 'decide which format to choose (email, prompt)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_subject', 'Ein Treffpunkt wurde erzeugt. Folgen Sie dem Link!', 'if you choose format email, define the text for the subject', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_height', '14', 'height of the meetingPoint_icon', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_icon', '../img/redball.gif', 'path to meetingPoint image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_max_characters', '70', 'define the maximum length of the text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_please_click', 'Please click in  the map to define the meeting point position!', 'text to show if no clickposition is set', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_style', 'background-color:white;font-weight: bold;color:red;font-family:Arial;', 'style to display the meetingPoint text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_width', '14', 'width of the meetingPoint_icon', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[5]', '160', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[6]', '280', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[5]', 'meetingPoint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[6]', 'gazetteerMetadata', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_prefix', '  ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'menu', 'opacity_up,opacity_down,zoom,metainfo,hide,wms_up,wms_down,layer_up,layer_down,remove', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'metadatalink', 'false', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui1';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','WMS_preferences',2,1,'configure the preferences of each loaded wms','WMS preferences','img','../img/button_blink_red/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',670,60,24,24,1,'','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_blink_red/add_off.png','onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',645,60,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMSfromList',2,1,'add a WMS to the running application from a list','Adding WMS from List','img','../img/button_blink_red/addlist_off.png','onclick=''window.open("../javascripts/mod_addWMSfromList.php?sessionID","printWin","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',595,60,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',620,60,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','back',2,1,'History.back()','Back','img','../img/button_blink_red/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" ',400,60,24,24,1,'','','','mod_back.php','','mapframe1,overview','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','body',1,1,'body (obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','center1',2,1,'Center button','Set map center','img','../img/button_blink_red/center_off.png','onmouseover = "mb_regButton(''init_gui1_center'')" ',310,60,24,24,1,'','','','mod_center1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','changeEPSG',2,1,'change EPSG, Postgres required, overview is targed for full extent','Change Projection','iframe','../php/mod_changeEPSG.php?sessionID','scrolling="no" frameborder=''0'' ',432,25,107,24,1,'','','iframe','','','overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','changePassword_button',2,1,'button: change password of logged user','Change Password','img','../img/button_blink_red/change_password_off.png','onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0'' onmouseover=''this.src="../img/button_blink_red/change_password_over.png"'' onmouseout=''this.src="../img/button_blink_red/change_password_off.png"'' ',750,60,24,24,1,'cursor:hand','','','','','','','http://www.mapbender.org/index.php/ChangePassword');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','closePolygon',3,1,'close Polygon ','Close Polygon','div','','',0,0,0,0,0,'','','div','mod_closePolygon.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',-59,1,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',-59,1,0,0,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','featureInfo1',2,1,'FeatureInfoRequest','Query','img','../img/button_blink_red/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')" ',465,60,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','forward',2,1,'History.forward()','Forward','img','../img/button_blink_red/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" ',425,60,24,24,1,'','','','mod_forward.php','','mapframe1,overview','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','getArea',3,1,'Calculation of area, Postgis required','Get Area','div','','',0,0,0,0,0,'','','div','mod_getArea.php','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','help',2,1,'button help','Help','img','../img/button_blink_red/help_off.png','onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")''',790,60,24,24,1,'','','','','','','','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','help1',2,1,'button help','Help','img','../img/button_blink_red/help_off.png','onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")''',790,60,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/help');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','highlightPOI',2,1,'highlight 1 to n pois in your gui with a Symbol and a special text','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_highlightPOI.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','layout_1',3,1,'layout, background for buttons','','div','','',208,58,670,28,0,'background-color:#FFFFFF;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&wms_legend = yes','frameborder=''0''',-59,200,180,600,3,'','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','loadData',2,1,'IFRAME to load data','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','loadwmc',2,1,'load workspace from WMC','Load a web map context document','img','../img/button_blink_red/wmc_load_off.png','onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',895,60,24,24,1,'','','','mod_loadwmc.php','','mapframe1','','http://www.mapbender.org/index.php/LoadWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','logout',2,1,'Logout','Logout','img','../img/button_blink_red/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blink_red/logout_over.png"'' onmouseout=''this.src="../img/button_blink_red/logout_off.png"'' ',830,60,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',-59,1,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','mapframe1',2,1,'Frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',220,105,625,400,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','measure',2,1,'Measure','Measure distance','img','../img/button_blink_red/measure_off.png','onmouseover = "mb_regButton(''init_mod_measure'')"',515,60,24,24,1,'','','','mod_measure.php','','mapframe1','','http://www.mapbender.org/index.php/Measure');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_blink_red/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_blink_red/metadata_over.png"'' onmouseout=''this.src="../img/button_blink_red/metadata_off.png"'' ',710,60,24,24,1,'','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,0,0,10,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',15,25,150,150,2,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','pan1',2,1,'pan','Pan','img','../img/button_blink_red/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')"',260,60,24,24,1,'','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','print1',2,0,'start print GUI','Print','img','../img/button_blink_red/print_off.png','onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID","printWin","width=300, height=400, resizable=yes ")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',555,60,24,24,1,'','','','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','printPDF',2,1,'start print GUI','Print','img','../img/button_blink_red/print_off.png','onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF_b.conf","printWin","width=180, height=200, resizable=yes ")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',555,60,24,24,1,'','','','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','repaint',2,1,'refresh a mapobject','Redraw','img','../img/button_blink_red/repaint_off.png','onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)'' ',360,60,24,24,1,'','','','mod_repaint.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','rubber',3,1,'deletes temporary (digitized) objects','Rubber','div','','',0,0,0,0,0,'','','div','mod_rubber.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',0,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','savewmc',2,1,'save workspace as WMC','Save workspace as web map context document','img','../img/button_blink_red/wmc_save_off.png','onclick=''mod_savewmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',870,60,24,24,1,'','','','mod_savewmc.php','','mapframe1','','http://www.mapbender.org/index.php/SaveWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scaleSelect',2,1,'Scale-Selectbox','Scale Select','select','','onchange=''mod_scaleSelect(this)''',555,25,100,20,1,'','<option value = ''''>Scale</option> <option value=''100''>1 : 100</option> <option value=''250''>1 : 250</option> <option value=''500''>1 : 500</option> <option value=''1000''>1 : 1000</option> <option value=''2500''>1 : 2500</option> <option value=''5000''>1 : 5000</option> <option value=''10000''>1 : 10000</option> <option value=''25000''>1 : 25000</option> <option value=''30000''>1 : 30000</option> <option value=''50000''>1 : 50000</option> <option value=''75000''>1 : 75000</option> <option value=''100000''>1 : 100000</option> <option value=''200000''>1 : 200000</option> <option value=''300000''>1 : 300000</option> <option value=''400000''>1 : 400000</option> <option value=''500000''>1 : 500000</option> <option value=''600000''>1 : 600000</option> <option value=''700000''>1 : 700000</option> <option value=''800000''>1 : 800000</option> <option value=''900000''>1 : 900000</option> <option value=''1000000''>1 : 1000000</option>','select','mod_scaleSel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scaleText',2,1,'Scale-description field','Scale Text','form','','onsubmit=''return mod_scaleText()''',672,25,100,30,0,'','<input type="text">','form','mod_scaleText.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scalebar',2,1,'scalebar','Scalebar','div','','',0,0,0,0,0,'','','div','mod_scalebar.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_blink_red/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')"',285,60,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBBOX',2,1,'set Extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBackground',2,0,'switch background-wms','Set Background','form','','',15,190,0,0,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBackground_all',2,0,'switch all background-wms','Set Background','form','','',157,190,40,20,1,'','<input type=''checkbox'' onclick=''mod_setBackground_all_init(this)''> <font face="Arial, sans-serif" size="2">all</font>','form','mod_setBackground_all.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setPOI2Scale',2,1,'zoom to a poi (get-parameter)','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_setPOI2Scale.php','','mapframe1','','http://www.mapbender.org/index.php/Mod_setPoi2Scale');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setScaleHint',1,0,'set scaleHint for mapframes','','div','','',1,1,1,1,0,'visibility:hidden;','','div','mod_scaleHint.php','','mapframe1,100,10000000','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','showCoords_div',2,1,'displays coordinates by onmouseover','Coordinates','img','../img/button_blink_red/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ',490,60,24,24,1,'','','','mod_coords_div.php','','mapframe1','','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeConfGDE',2,0,'configurable directory tree','Maps','iframe','../php/mod_treefolderClient.php?sessionID','frameborder = "0" ',0,180,250,500,0,'visibility:visible','','iframe','mod_treeConf.js','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeGDE_1',2,0,'directory tree, checkbox for visible, checkbox for querylayer, no immediate refreshing, with nested layers','Maps','iframe','../html/mod_sync_treefolder_1.html','frameborder = "0" ',0,180,250,500,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','wfs_gazetteer',2,0,'gazetteer using wfs','Search','iframe','../php/mod_wfs_gazetteer.php?sessionID&color=255,0,255','frameborder = "0" ',-50,490,250,300,0,'visibility:visible','','iframe','','','mapframe1,overview','wfs','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomCoords',2,1,'zoom to coordinate','Zoom to Coordinates','iframe','../php/mod_zoomCoords_en.php?sessionID','frameborder = "0" ',205,7,220,45,0,'','','iframe','','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_blink_red/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)" ',335,60,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_blink_red/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' ',210,60,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_blink_red/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' ',235,60,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_db', '0', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_height', '25', 'height of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_width', '25', 'width of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'css_file_legend', '../css/legend.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'stickylegend', 'true', 'parameter to decide wether the legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'logout', 'logout_location', 'http://www.mapbender.org/', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'setPOI2Scale', 'mod_setPOI2Scale_defScale', '5000', 'default scale', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'menu', '', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui2';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','WMS_preferences',2,1,'configures the preferences of each loaded wms','WMS preferences','img','../img/button_blue/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''',604,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_blue/add_off.png','onclick=''mod_addWMS()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''',580,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blue/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''',553,40,28,28,1,'filter:Chroma(color=#C2CBCF);','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','back',2,1,'History.back()','Back','img','../img/button_blue/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"',398,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_back.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','body',1,1,'body
+(obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'background-image:url(../img/background_yellow.jpg);background-repeat:repeat-x;','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','center1',2,1,'Center button','Set map center','img','../img/button_blue/center_off.png','onmouseover = "mb_regButton(''init_gui1_center'')"',308,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_center1.php','','mapframe1','','http://www.mapbender.org/index.php/ReCenter');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','changePassword_button',2,1,'button: change password of logged user','Change Password','img','../img/button_blue/change_password_off.png','onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0''
+onmouseover=''this.src="../img/button_blue/change_password_over.png"'' onmouseout=''this.src="../img/button_blue/change_password_off.png"''',668,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','','','http://www.mapbender.org/index.php/ChangePassword');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','closePolygon',3,1,'close Polygon ','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_closePolygon.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#799FEB; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dynamicOverview',2,1,'oveview acts in accordance with main mapframe','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','mod_dynamicOverview.php','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','featureInfo1',2,0,'FeatureInfoRequest','Query','img','../img/button_blue/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','Query','img','../img/button_blue/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')"',461,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_featureInfoTunnel.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfoTunnel');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','forward',2,1,'History.forward()','Forward','img','../img/button_blue/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()"',423,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_forward.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','Search','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','geometry.js','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','getArea',3,1,'Calculation of area, Postgis required','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_getArea.php','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','header_yellow',2,0,'header','','img','../img/header_yellow.jpg','',-1,-1,833,75,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','help',2,1,'button help','Help','img','../img/button_blue/help_off.png','onmouseover = "mb_regButton(''init_help'')"',693,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','imprint',2,1,'Information about the owner of the gui','Imprint','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','layout_linie',3,0,'layout','','div','','',1,70,830,1,1,'background-color:#799FEB;font-size:1px;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','layout_linie2',3,0,'layout','','div','','',1,35,830,1,1,'background-color:#799FEB;font-size:1px;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','loadData',2,1,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','loadwmc',2,1,'load workspace from WMC','Load a web map context document','img','../img/button_blue/wmc_load_off.png','onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");''',758,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_loadwmc.php','','mapframe1','','http://www.mapbender.org/index.php/LoadWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','logo',2,1,'Logo','Logo','img','../img/mapbender_oo.png','',10,35,129,32,5,'filter:Chroma(color=#C2CBCF);','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','logout',2,1,'Logout','Logout','img','../img/button_blue/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blue/logout_over.png"'' onmouseout=''this.src="../img/button_blue/logout_off.png"''',798,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','mapframe1',2,1,'frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',213,90,608,467,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','measure',2,1,'Measure','Measure distance','img','../img/button_blue/measure_off.png','onmouseover = "mb_regButton(''init_mod_measure'')"',513,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_measure.php','','mapframe1','','http://www.mapbender.org/index.php/Measure');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_blue/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0''
+onmouseover=''this.src="../img/button_blue/metadata_over.png"'' onmouseout=''this.src="../img/button_blue/metadata_off.png"''',643,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,0,0,0,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>
+<div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>
+<div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>
+<div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div>
+<div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div>
+<div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>
+<div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>
+<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',9,80,185,130,100,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','pan1',2,1,'pan','Pan','img','../img/button_blue/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')"',258,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','printPDF',2,1,'pdf print','Print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','repaint',2,1,'refresh a mapobject','Redraw','img','../img/button_blue/repaint_off.png','onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)''',358,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_repaint.php','','mapframe1','','http://www.mapbender.org/index.php/Repaint');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','resizeMapsize',2,1,'resize mapsize to browser window size','Resize Mapsize','img','../img/button_blink_red/resizemapsize_off.png','onclick = "adjustDimension()"
+onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',838,40,24,24,3,'filter:Chroma(color=#C2CBCF);','','','mod_resize_mapsize.php','','mapframe1','','http://www.mapbender.org/index.php/ResizeMapsize');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','rubber',3,1,'deletes temporary (digitized) objects','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_rubber.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','savewmc',2,1,'save workspace as WMC','Save workspace as web map context document','img','../img/button_blue/wmc_save_off.png','onclick=''mod_savewmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',733,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_savewmc.php','','mapframe1','','http://www.mapbender.org/index.php/SaveWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_blue/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')"',283,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','setBBOX',2,0,'set extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','setBackground',2,1,'switch background-wms','Set Background','form','','',10,218,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','showCoords_div',2,1,'displays coodinates by onmouseover','Coordinates','img','../img/button_blue/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')"',488,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_coords_div.php','','mapframe1','dependendDiv','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','tabs',2,1,'vertical tabs to handle iframes','','div','','',2,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2','Maps','iframe','../html/mod_treefolder2.php?sessionID','frameborder = "0" ',10,220,200,300,NULL ,'visibility:visible','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_blue/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"',333,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_blue/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)''',203,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_blue/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''',231,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_class_bg', 'body{background-color: #FEF8D4;}', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_minScale', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_startExtent', '-24.5,32,34.5,71', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_useMaxExtent', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_wmsIndex', '0', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_zoomFactor', '5', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'gazetteerWFS', 'wfsConfIdString', '1', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_height', '-35', 'to adjust the height of the mapframe on the bottom of the window', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_width', '-45', 'to adjust the width of the mapframe on the right side of the window', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'resize_option', 'button', 'auto (autoresize on load), button (resize by button)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'sandclock', 'mod_sandclock_image', '../img/sandclock_oo.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_prefix', '  ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid #FDCC1A;font-size:12;color:#FFFFFF;background-color:#799FEB;cursor:pointer;margin-top:-3px; padding-top:3px;padding-left:4px;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'menu', 'opacity_up,opacity_down,zoom,metainfo,hide,wms_up,wms_down,layer_up,layer_down,remove', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui_digitize';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','FeatureInfoRedirect',2,0,'redirect featureInfoRequests in an iframe for each wms','Info','iframe','../html/mod_blank.html','frameborder="0"',83,-17,1,1,NULL ,'','','iframe','mod_featureInfoRedirect.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','WMS_preferences',2,1,'configures the preferences of each loaded wms','WMS preferences','img','../img/button_gray/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");''',540,10,24,24,1,'','','','','','mapframe1,treeGDE','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_gray/add_off.png','onclick=''mod_addWMS()''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");''',515,10,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','back',2,1,'History.back()','Back','img','../img/button_gray/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"',360,10,24,24,1,'','','','mod_back.php','','mapframe1,overview0','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','body',1,1,'body (obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','closePolygonExt',3,0,'close Polygon ','Close Polygon','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_closePolygonExt.js','','mapframe1','setExtRequest','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_copyright.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','digitize',2,1,'Digitize tool.','Digitize','iframe','../javascripts/mod_digitize_tab.php?sessionID','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','geometry.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','featureInfo1',2,0,'FeatureInfoRequest','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')"',425,10,24,24,1,'','','','mod_featureInfoTunnel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','forward',2,1,'History.forward()','Forward','img','../img/button_gray/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()"',385,10,24,24,1,'','','','mod_forward.php','','mapframe1,overview0','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','Search','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','geometry.js','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',620,10,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','imprint',2,1,'Information about the owner of the gui','Imprint','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','initWmc',2,0,'initialise client with wmc','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_initWmc.php','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_1',3,0,'Warning notice','','div','','',150,250,300,16,100,'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none;','Development Version - Work in Progress!','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_back',3,1,'layout, background for buttons','','div','','',360,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_featureInfo',3,1,'layout, background for FeatureInfo','','div','','',425,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_help',3,1,'layout, background for Help-button','','div','','',620,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_logout',3,1,'layout, background for Logout-button','','div','','',660,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_metadata',3,1,'layout, background for Metadata','','div','','',580,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_wms',3,1,'layout, background for wms','','div','','',490,10,76,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_zoom',3,1,'layout, background for Zoom-button','','div','','',220,10,126,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','loadData',2,1,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','loadwmc',2,0,'load workspace from WMC','Load a web map context document','img','../img/button_wmc/wmc_load.png','onclick=''mod_loadwmc()'' onmouseover=''mod_loadwmc_init(this)''',760,10,24,24,1,'','','','mod_loadwmc.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','logo',2,1,'Logo','','img','../img/mapbender_logo.png','',20,20,180,26,5,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''
+onmouseover=''this.src="../img/button_gray/logout_over.png"''
+onmouseout=''this.src="../img/button_gray/logout_off.png"''',660,10,24,24,1,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr>
+<script language="javascript">
+mb_registerSubFunctions("mod_mapbender()");
+function mod_mapbender(){
+document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90;
+document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1;
+</script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','mapframe1',2,1,'frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',230,55,500,450,2,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_gray/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''"
+border=''0''
+onmouseover=''this.src="../img/button_gray/metadata_over.png"''
+onmouseout=''this.src="../img/button_gray/metadata_off.png"''',580,10,24,24,1,'','','','mod_displayObj.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,NULL ,NULL ,NULL ,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>
+<div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>
+<div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>
+<div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div>
+<div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div>
+<div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>
+<div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>
+<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>
+','div','mod_navFrame.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',30,65,150,130,100,'','','iframe','','mod_box1.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','pan1',2,1,'pan','Pan','img','../img/button_gray/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')"',270,10,24,24,1,'','','','mod_pan.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','printPDF',2,1,'pdf print','Print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','rubberExt',3,1,'deletes temporary (digitized) objects','Rubber','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_rubberExt.js','','mapframe1','setExtRequest','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','savewmc',2,0,'save workspace as WMC','Save workspace as web map context document','img','../img/button_wmc/wmc_save.png','onclick=''mod_savewmc()'' onmouseover=''mod_savewmc_init(this)''',730,10,24,24,1,'','','','mod_savewmc.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','scaleSelect',2,0,'Scale-Selectbox','Scale Select','select','','onchange=''mod_scaleSelect(this)''',555,25,100,20,1,'','<option value = ''''>Scale</option>
+<option value=''100''>1 : 100</option>
+<option value=''250''>1 : 250</option>
+<option value=''500''>1 : 500</option>
+<option value=''1000''>1 : 1000</option>
+<option value=''2500''>1 : 2500</option>
+<option value=''5000''>1 : 5000</option>
+<option value=''10000''>1 : 10000</option>
+<option value=''25000''>1 : 25000</option>
+<option value=''30000''>1 : 30000</option>
+<option value=''50000''>1 : 50000</option>
+<option value=''75000''>1 : 75000</option>
+<option value=''100000''>1 : 100000</option>
+<option value=''200000''>1 : 200000</option>
+<option value=''300000''>1 : 300000</option>
+<option value=''400000''>1 : 400000</option>
+<option value=''500000''>1 : 500000</option>
+<option value=''600000''>1 : 600000</option>
+<option value=''700000''>1 : 700000</option>
+<option value=''800000''>1 : 800000</option>
+<option value=''900000''>1 : 900000</option>
+<option value=''1000000''>1 : 1000000</option>','select','mod_scaleSel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_gray/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')"',295,10,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setBBOX',2,0,'set extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setBackground',2,1,'switch background-wms','Set Background','form','','',30,210,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12''
+name=''mod_setBackground_list''
+onchange=''mod_setBackground_change(this)'' ><option
+value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setSpatialRequest',2,1,'Spatial Request','','div','','',1,1,1,1,1,'visibility:hidden;','','div','../javascripts/mod_wfs_SpatialRequest.php','geometry.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','showCoords_div',2,1,'displays coodinates by onmouseover','Coordinates','img','../img/button_gray/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ',450,10,24,24,1,'','','','mod_coords_div.php','','mapframe1','dependendDiv','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','showLoggedUser',2,0,'Displays current user','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','tabs',1,1,'vertical tabs to handle iframes','','div','','',10,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfs',2,1,'wfs request and result handling','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','wfs.js','../extensions/wz_jsgraphics.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfs_conf',2,1,'get all wfs_conf-params','','iframe','../php/mod_wfs.php','frameborder = "0"',1,1,1,1,0,'visibility:hidden','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfsresult',2,1,'display the list of wfs results','','iframe','../html/mod_blank.html','frameborder = "0"',10,730,200,150,4,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_gray/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"',320,10,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_gray/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)''',220,10,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_gray/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''',245,10,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty  result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'cssUrl', '../css/digitize.css', 'url to the style sheet of the mapframe', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'digitize_conf_filename', 'digitize_default.conf', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'text css', ' body{
+ font-family: Arial, Helvetica, sans-serif;
+ font-size : 12px;
+ color: #ff00ff;
+ background-color: #ffffff;
+ margin-top: 0px;
+ margin-left: 0px;
+ .button{
+ height: 18px;
+ width: 32px;
+', 'text css', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'wfsCssUrl', '../css/mapbender.css', 'var', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'gazetteerWFS', 'wfsConfIdString', '1,2,3,4', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'useUsemap', '0', '"1" adds a usemap to each geometry; the geometry will be highlighted onMouseOver. Every other value will skip the usemap.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'wfs_conf_filename', 'wfs_default.conf', 'location and name of the WFS configuration file', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'open_tab', '5', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[5]', '250', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[5]', 'digitize', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_prefix', '  ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;padding-left:8px;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'menu', '', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'wfs', 'displayWfsResultList', '1', '', 'var');
+Delete from gui_element where fkey_gui_id ='admin1';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','AdminFrame',2,1,'the frame for administration modules','','iframe','','frameborder = "0"',220,20,800,800,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','CreateTreeGDE',2,1,'create a foldertree for a individual geodataexplorer','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,810,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','CREATE TREE_GDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','EditWMSMetadata',2,1,'edit the metadata of wms','edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,950,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT WMS-METADATA','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_Gui',2,1,'allocate groups to guis','','a','','href = "../php/mod_group_gui.php?sessionID&e_id_css=Group_Gui" target = "AdminFrame" ',10,610,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_User',2,1,'allocate groups to user','','a','','href = "../php/mod_group_user.php?sessionID&e_id_css=Group_User" target = "AdminFrame" ',10,550,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','GROUP -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_filteredGui',2,1,'allocate Groups to the guis of this admin','','a','','href = "../php/mod_group_filteredGui.php?sessionID&e_id_css=Group_filteredGui" target = "AdminFrame" ',10,710,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Gui_Group',2,1,'allocate guis to groups','','a','','href = "../php/mod_gui_group.php?sessionID&e_id_css=Gui_Group" target = "AdminFrame" ',10,250,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Gui_User',2,1,'allocate a gui to user','','a','','href = "../php/mod_gui_user.php?sessionID&e_id_css=Gui_User" target = "AdminFrame" ',10,190,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','User_Group',2,1,'allocat user to groups','','a','','href = "../php/mod_user_group.php?sessionID&e_id_css=User_Group" target = "AdminFrame" ',10,430,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','body',1,1,'navigation','','body','','onload=''mod_adminNavigation_init()''',0,0,0,0,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteGui',2,1,'delete gui','','a','','href = "../php/mod_deleteGUI.php?sessionID" target = "AdminFrame" ',10,150,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteWFS',2,1,'delete WFS','Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,890,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteWMS',2,1,'delete wms','Delete WMS completely','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,110,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','delete_filteredGui',2,1,'delete guis of this admin','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,790,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editElements',2,1,'edit gui elements','Edit GUI elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,170,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','EDIT GUI-ELEMENTS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editFilteredGroup',2,1,'edit group of this admin','Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',10,530,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editFilteredUser',2,1,'save, edit, delete user where this admin is owner','Create and edit user','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',10,350,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editGUI_WMS',2,1,'edit the elements of the gui','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,90,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT GUI-WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editGroup',2,1,'edit group','','a','','href = "../php/mod_editGroup.php?sessionID" target = "AdminFrame" ',10,510,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editUser',2,1,'save, edit, delete user','','a','','href = "../php/mod_editUser.php?sessionID" target="AdminFrame"',10,330,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','exportGUI',2,1,'export gui, create SQLL','export GUI, create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,310,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EXPORT GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGoup_filteredUser',2,1,'allocate the groups of this admin to user where the admin is owner','Add several users to one group','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',10,590,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> myUSER ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_Gui',2,1,'allocate groups of this admin to guis','','a','','href = "../php/mod_filteredGroup_Gui.php?sessionID&e_id_css=filteredGroup_Gui" target = "AdminFrame" ',10,750,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_User',2,1,'allocate groups of this admin to user','','a','','href = "../php/mod_filteredGroup_User.php?sessionID&e_id_css=filteredGroup_User" target = "AdminFrame" ',10,690,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_filteredGui',2,1,'allocate groups of this admin to guis of this admin','Allow one group access to several GUIs','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',10,730,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_Group',2,1,'allocate guis to groups','','a','','href = "../php/mod_filteredGui_group.php?sessionID&e_id_css=filteredGui_Group" target = "AdminFrame" ',10,270,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> GROUP ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_filteredGroup',2,1,'allocate guis of this admin to groups where this admin is owner','Allow several groups access to one GUI','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',10,290,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_filteredUser',2,1,'allocate the user where the admin is owner to his guis ','Allow several users access to one GUI ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',10,230,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_user',2,1,'allocate the guis of this admin to a user','','a','','href = "../php/mod_filteredGui_User.php?sessionID&e_id_css=filteredGui_user" target = "AdminFrame" ',10,210,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> USER ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_Group',2,1,'allocate user of this admin to groups','','a','','href = "../php/mod_filteredUser_Group.php?sessionID&e_id_css=filteredUser_Group" target = "AdminFrame" ',10,670,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_Gui',2,1,'allocate user of this admin to guis','','a','','href = "../php/mod_filteredUser_Gui.php?sessionID&e_id_css=filteredUser_Gui" target = "AdminFrame" ',10,770,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_filteredGroup',2,1,'allocate user where this admin is owner to groups where this admin is owner','Add one user to serveral groups','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',10,490,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_filteredGui',2,1,'allocate admins user to guis of this admin','Allow one user to access several GUIs','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',10,410,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','getStyles',2,0,'load styles from wms','','a','','href = "../php/mod_getStyles.php?sessionID" target = "AdminFrame" ',10,890,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GET_STYLES','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','group_filteredUser',2,1,'allocate groups to user where this admin is owner','','a','','href = "../php/mod_group_filteredUser.php?sessionID&e_id_css=group_filteredUser" target = "AdminFrame" ',10,570,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_filteredGroup',2,1,'allocate guis to groups of this admin','','a','','href = "../php/mod_gui_filteredGroup.php?sessionID&e_id_css=gui_filteredGroup" target = "AdminFrame" ',10,650,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_filteredUser',2,1,'allocate guis to user of this admin','','a','','href = "../php/mod_gui_filteredUser.php?sessionID&e_id_css=gui_filteredUser" target = "AdminFrame" ',10,630,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_owner',2,1,'set owner','Edit GUI assign to user','a','','href = "../php/mod_gui_owner.php?sessionID&e_id_css=gui_owner" target = "AdminFrame" ',10,830,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> OWNER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWFS',2,1,'load capabilities in a gui','Load WFS Capabilities into a GUI','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,850,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/WFS_Konfiguration');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWMS',2,1,'load capabilities in a gui','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,30,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWMSList',2,1,'load wms from a list','Link WMS into GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,50,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD myWMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,1,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','myGUIlist',2,1,'go back to your GUI list','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' ',150,2,24,24,1,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','newGui',2,1,'create a new gui','Create new GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,130,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','NEW GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','orphanWMS',2,1,'display orphaned WMS','Delete orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID&&elementID=orphanWMS" target = "AdminFrame"',10,930,200,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','ORPHAN WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','owsproxy',2,1,'secure services','OWSPROXY','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,910,200,20,1,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','OWSPROXY','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','rename_copy_Gui',2,1,'rename and copy gui','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,470,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','RENAME COPY GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','showLoggedUser',2,1,'displays the logged admin','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','updateWMSs',2,1,'edit the elements of the gui','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,70,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','UPDATE WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_filteredGroup',2,1,'allocate user to groups where this admin is owner','','a','','href = "../php/mod_user_filteredGroup.php?sessionID&e_id_css=user_filteredGroup" target = "AdminFrame" ',10,450,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> myGROUP','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_filteredGui',2,1,'allocate guis of this admin to user','','a','','href = "../php/mod_user_filteredGui.php?sessionID&e_id_css=user_filteredGui" target = "AdminFrame" ',10,390,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER-> myGUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_gui',2,1,'allocate guis to user','','a','','href = "../php/mod_user_gui.php?sessionID&e_id_css=user_gui" target = "AdminFrame" ',10,370,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> GUI ','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','wfs_conf',2,1,'create and edit a gazetteer module','Configure WFS','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,870,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','WFS CONF','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','wfs_gui',2,1,'edit wfs settings','Assign WFS conf to gui','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,1000,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','asign WFS conf to gui','a','','','','AdminFrame','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_Gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'User_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'editGUI_WMS', 'file_css', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_Gui', 'file css', '../css/administration_alloc.css', 'file', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_user', 'file css', '../css/administration_alloc.css', 'a file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_Gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'group_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin2_de';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','AdminFrame',2,1,'Bereich f�r Administrationsmodule','','iframe','','frameborder = "0"',200,20,980,800,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','CreateTreeGDE',2,1,'Ordnerbaum konfigurieren','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',8,280,190,20,5,'','Ordnerbaum konfigurieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','body',1,1,'Navigation','','body','','onload=''mod_adminNavigation_init()''',0,0,180,20,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','deleteWMS',2,1,'!Vollst�ndig l�schen!','Delete WMS completely','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',8,100,190,20,5,'','!Vollst�ndig l�schen!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','delete_filteredGui',2,1,'GUI l�schen','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',110,240,80,20,5,'','GUI l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editElements',2,1,'Oberfl�chenelemente editieren','Edit GUI elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',8,260,190,20,5,'','GUI-Elemente editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editFilteredGroup',2,1,'Gruppe anlegen und editieren','Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',8,400,190,20,10,'','Gruppe anlegen und editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editFilteredUser',2,1,'Benutzer anlegen und editieren','Create and edit user','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',8,380,190,20,10,'','Benutzer anlegen und editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editGUI_WMS',2,1,'WMS GUI Einstellungen','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',8,180,190,20,5,'','WMS GUI Einstellungen','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','exportGUI',2,1,'Oberfl�che (GUI) exportieren, SQL erzeugen','export GUI, create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',8,300,190,20,10,'','GUI exportieren (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGoup_filteredUser',2,1,'Gruppe mit Benutzern best�cken','Add several users to one group','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',8,440,190,20,10,'','Gruppe mit Benutzern best�cken ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGroup_filteredGui',2,1,'Einzelner Gruppe mehrere Oberflaechen zuordnen','Allow one group access to several GUIs','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',8,570,190,25,10,'','Einzelner Gruppe mehrere <br>GUIs zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGui_filteredGroup',2,1,'Einzelner Oberfl�che mehrere Gruppen zuordnen','Allow several groups access to one GUI','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',8,605,190,25,10,'','Einzelner GUI mehrere<br> Gruppen zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGui_filteredUser',2,1,'Oberfl�che mehreren Benutzer zuordnen ','Allow several users access to one GUI ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',8,535,190,25,10,'','GUI mehreren Benutzern <br> zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredUser_filteredGroup',2,1,'Benutzer in Gruppen eintragen','Add one user to serveral groups','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,420,190,20,10,'','Benutzer in Gruppen eintragen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredUser_filteredGui',2,1,'Einem Nutzer Zugriff auf mehrere Oberfl�chen erteilen','Allow one user to access several GUIs','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',8,500,190,25,10,'','Einem Nutzer Zugriff auf <br> mehrere GUIs erteilen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','gui_owner',2,1,'GUI editieren Benutzer zuordnen','Edit GUI assign to user','a','','href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame" ',8,640,190,20,10,'','GUI editieren Benutzer zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_Configure_WMS_Access',3,1,'Hintergrund WMS Zuordnung','Configure WMS Access','div','','',5,137,193,66,2,'',' WMS Zuordnung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_GUI_Management',3,1,'Hintergrund Oberfl�chenverwaltung','GUI Management','div','','',5,217,193,126,2,'',' GUI-Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_User_Authorization',3,1,'Hintergrund Benutzerzugriff erteilen','Authorization ','div','','',5,477,193,196,2,'',' Benutzerzugriff erteilen','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_User_Management',3,1,'Hintergrund Benutzerverwaltung','User Management','div','','',5,357,193,106,2,'',' Benutzerverwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_WMS_Management',3,1,'Hintergrund WMS Management','WMS Management','div','','',5,37,193,86,2,'',' WMS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','loadWMS',2,1,'Capabilities hochladen','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',8,60,190,20,5,'','Capabilities hochladen','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','loadWMSList',2,1,'WMS in GUI einbinden','Link WMS into GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',8,160,190,20,5,'','WMS in GUI einbinden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','myGUIlist',2,1,'Zur�ck zur eigenen GUI Liste','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','newGui',2,1,'GUI erzeugen','Create new GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',8,240,85,20,5,'','GUI erzeugen','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','rename_copy_Gui',2,1,'GUI umbenennen/ kopieren','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',8,320,190,20,10,'','GUI umbenennen/kopieren','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','showLoggedUser',2,1,'Anzeige des eingeloggten Benutzers','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','updateWMSs',2,1,'Hochgeladene aktualisieren','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',8,80,190,20,5,'','Hochgeladene aktualisieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'body', 'body_css_file', '../css/admin.css', 'css-file to define the style fo the admin-gui', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin2_en';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','AdminFrame',2,1,'the frame for administration modules','','iframe','','frameborder = "0"',200,20,800,800,0,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','CreateTreeGDE',2,1,'TreeGDE set up','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',8,280,190,20,5,'','Create treeGDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','body',1,1,'navigation','','body','','onload=''mod_adminNavigation_init()''',0,0,0,0,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','deleteWMS',2,1,'!Delete WMS completely!','Delete WMS completely','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',8,100,190,20,5,'','!Delete WMS completely!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','delete_filteredGui',2,1,'Delete GUI','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',120,240,80,20,5,'','Delete GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editElements',2,1,'Edit GUI elements','Edit GUI elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',8,260,190,20,5,'','Edit GUI elements','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editFilteredGroup',2,1,'Create and edit group','Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',8,400,190,20,10,'','Create and edit group','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editFilteredUser',2,1,'Create and edit user','Create and edit user','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',8,380,190,20,10,'','Create and edit user','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editGUI_WMS',2,1,'WMS GUI settings','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',8,180,190,20,5,'','WMS GUI settings','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','exportGUI',2,1,'export GUI, create SQL','export GUI, create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',8,300,190,20,10,'','Export GUI (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGoup_filteredUser',2,1,'Add several users to one group','Add several users to one group','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',8,440,190,20,10,'','Add several users to one group ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGroup_filteredGui',2,1,'Allow one group access to several GUIs','Allow one group access to several GUIs','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',8,570,190,25,10,'','Allow one group access to <br> several GUIs','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGui_filteredGroup',2,1,'Allow several groups access to one GUI','Allow several groups access to one GUI','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',8,605,190,25,10,'','Allow several groups access <br> to one GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGui_filteredUser',2,1,'Allow several users access to one GUI ','Allow several users access to one GUI ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',8,535,190,25,10,'','Allow several users access to <br> one GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredUser_filteredGroup',2,1,'Add one user to serveral groups','Add one user to serveral groups','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,420,190,20,10,'','Add one user to serveral groups','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredUser_filteredGui',2,1,'Allow one user to access several GUIs','Allow one user to access several GUIs','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',8,500,190,25,10,'','Allow one user to access <br> several GUIs','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','gui_owner',2,1,'Edit GUI assign to user','Edit GUI assign to user','a','','href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame"  ',8,640,190,20,10,'','Edit GUI assign to user','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_Configure_WMS_Access',3,1,'Configure WMS Access','Configure WMS Access','div','','',5,137,193,66,2,'',' Configure WMS Access','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_GUI_Management',3,1,'GUI Management caption','GUI Management','div','','',5,217,193,126,2,'',' GUI Management ','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_User_Authorization',3,1,'Authorization caption','Authorization ','div','','',5,477,193,186,2,'',' Authorization','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_User_Management',3,1,'User Management caption','User Management','div','','',5,357,193,106,2,'',' User Management ','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_WMS_Management',3,1,'WMS Management caption','WMS Management','div','','',5,37,193,86,2,'',' WMS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" ',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','loadWMS',2,1,'Load Capabilities','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',8,60,190,20,5,'','Load WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','loadWMSList',2,1,'Link WMS into GUI','Link WMS into GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',8,160,190,20,5,'','Link WMS into GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','myGUIlist',2,1,'go back to your GUI list','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' ',150,2,24,24,2,'','','img','mod_home.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','newGui',2,1,'Create new GUI','Create new GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',8,240,110,20,5,'','Create new GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','rename_copy_Gui',2,1,'Rename/ copy GUI','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',8,320,190,20,10,'','Rename / copy GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','showLoggedUser',2,1,'Logged User:','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','updateWMSs',2,1,'Update with Capabilities','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',8,80,190,20,5,'','Update WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'body', 'body_css_file', '../css/admin.css', 'css-file to define the style fo the admin-gui', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGoup_filteredUser', 'css_file_filteredGroup_filterdUser', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGroup', 'css_filteredUser_filteredGroup', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin_de_services';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','AdminFrame',2,1,'Bereich f�r Administrationsmodule','','iframe','','frameborder = "0"',210,25,800,800,12,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','CreateTreeGDE',2,1,'Ordnerbaum konfigurieren','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,533,200,20,5,'','Ordnerbaum konfigurieren','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','EditWMSMetadata',2,1,'edit the metadata of wms','edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,275,200,20,5,'','WMS Metadaten','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_WMS_Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','body',1,1,'Navigation','','body','','onload=''mod_adminNavigation_init()''',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','deleteWFS',2,1,'WFS l�schen','Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,393,200,20,5,'','WFS l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','deleteWMS',2,1,'!Vollst�ndig l�schen!','!Delete WMS completely!','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,100,200,20,5,'','WMS l�schen!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','delete_filteredGui',2,1,'GUI l�schen','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,491,200,20,5,'','GUI l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','editElements',2,1,'Oberfl�chenelemente editieren','Edit GUI Elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,511,200,25,5,'','GUI editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','editGUI_WMS',2,1,'WMS GUI Einstellungen','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,218,200,20,5,'','WMS Einstellungen �ndern','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','exportGUI',2,1,'GUI exportieren, SQL erzeugen','Export GUI (SQL), create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,554,200,25,10,'x','GUI exportieren (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','filteredWms_layer_topic',2,1,'allocate topics to layers of wms of this user','allocate topics to layers of wms of this user','a','','href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ',10,295,200,20,5,'','Kategoriezuordnung','a','','','','AdminFrame','http://www.mapbender.org/index.php/Topic_/_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_Configure_WMS_Access',3,1,'Hintergrund WMS Zuordnung','WMS Assignment','div','','',1,175,210,63,2,'','WMS Zuordnung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_GUI_Management',3,1,'Oberfl�chenverwaltung','GUI Management','div','','',1,448,210,153,2,'','GUI Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_Metadata',3,1,'Metadateneditor Caption','Metadata','div','','',1,252,210,63,2,'','Metadaten','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_WFS_Management',3,1,'WFS Verwaltung','WFS Management','div','','',1,330,210,103,2,'','WFS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_WMS_Management',3,1,'Dienstverwaltung Beschriftung','WMS Management','div','','',0,37,210,123,2,'','WMS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWFS',2,1,'WFS Capabilities in eine GUI laden','Load WFS Capabilities into a GUI','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,353,200,20,5,'','WFS laden','a','','','','AdminFrame','http://www.mapbender.org/index.php/LoadWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWMS',2,1,'Capabilities hochladen','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,60,200,20,5,'','WMS laden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWMSList',2,1,'WMS in GUI einbinden','Assign WMS to a GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,198,200,20,5,'','WMS einbinden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','myGUIlist',2,1,'Zur�ck zur eigenen GUI Liste','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','newGui',2,1,'GUI erzeugen','New GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,471,200,20,5,'','GUI erzeugen','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','orphanWMS',2,1,'display orphaned WMS','Delete orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID"
+target = "AdminFrame"',10,120,200,20,5,'','WMS ohne Zuordung l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','owsproxy',2,1,'secure services','OWSPROXY','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,140,200,20,10,'','OWSPROXY','a','','','','AdminFrame','http://www.mapbender.org/index.php/Owsproxy');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','rename_copy_Gui',2,1,'GUI umbenennen/ kopieren','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,576,200,20,10,'','GUI umbenennen/kopieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/RenameGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','showLoggedUser',2,1,'Anzeige des eingeloggten Benutzers','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','updateWMSs',2,1,'Hochgeladene aktualisieren','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,80,200,20,5,'','WMS aktualisieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','wfs_conf',2,1,'WFS konfigurieren','Configure WFS','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,373,200,20,5,'','WFS konfigurieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Wfs_conf');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','wfs_gui',2,1,'edit wfs settings','Assign WFS conf to gui','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,413,200,20,10,'','WFS Konfiguration GUI zuweisen','a','','','','AdminFrame','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'EditWMSMetadata', 'file_css', '../css/metadata.css', 'css-file to use for the metadata modul', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'body', 'body_file_css', '../css/admin_service.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'filteredWms_layer_topic', 'file css', '../css/administration_alloc_4.css', 'css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'filteredWms_layer_topic', 'language', 'de', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin_en_services';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','AdminFrame',2,1,'administration frame','','iframe','','frameborder = "0"',210,25,1000,800,12,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','CreateTreeGDE',2,1,'Configure TreeGDE','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,533,200,20,5,'','Configure TreeGDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','EditWMSMetadata',2,1,'edit the metadata of wms','edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,275,200,20,5,'','WMS Metadata','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_WMS_Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','body',1,1,'Navigation','','body','','onload=''mod_adminNavigation_init()''',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','deleteWFS',2,1,'Delete WFS','Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,393,200,20,5,'','Delete WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','deleteWMS',2,1,'!Delete completely!','!Delete WMS completely!','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,100,200,20,5,'','!Delete WMS completely!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','delete_filteredGui',2,1,'Delete GUI','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,491,200,20,5,'','Delete GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','editElements',2,1,'Edit GUI Elements','Edit GUI Elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,511,200,20,5,'','Edit GUI Elements','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','editGUI_WMS',2,1,'WMS GUI settings','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,218,200,20,5,'','WMS GUI settings','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','exportGUI',2,1,'Export GUI (SQL), create SQL','Export GUI (SQL), create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,553,200,20,10,'x','Export GUI (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','filteredWms_layer_topic',2,1,'allocate topics to layers of wms of this user','allocate topics to layers of wms of this user','a','','href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ',10,295,200,20,5,'','Allocate topics','a','','','','AdminFrame','http://www.mapbender.org/index.php/Topic_/_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_Configure_WMS_Access',3,1,'WMS Assignment','WMS Assignment','div','','',1,175,210,63,2,'','WMS Assignment','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_GUI_Management',3,1,'GUI Management','GUI Management','div','','',1,448,210,148,2,'','GUI Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_Metadata',3,1,'Metadata','Metadata','div','','',1,252,210,63,2,'','Metadata','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_WFS_Management',3,1,'WFS Management','WFS Management','div','','',1,330,210,103,2,'','WFS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_WMS_Management',3,1,'WMS Management','WMS Management','div','','',0,37,210,123,2,'','WMS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWFS',2,1,'Load WFS Capabilities into a GUI','Load WFS Capabilities into a GUI','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,353,200,20,5,'','Load WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/LoadWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWMS',2,1,'load Capabilities','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,60,200,20,5,'','Load WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWMSList',2,1,'assign WMS to a GUI','Assign WMS to a GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,198,200,20,5,'','Assign WMS to a GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' ',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','myGUIlist',2,1,'back to GUI list','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','newGui',2,1,'New GUI','New GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,471,200,20,5,'','New GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','orphanWMS',2,1,'Delete orphaned WMS','Delete orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID"
+target = "AdminFrame"',10,120,200,20,5,'','Delete orphaned WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','owsproxy',2,1,'secure services','OWSPROXY','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,140,200,20,10,'','OWSPROXY','a','','','','AdminFrame','http://www.mapbender.org/index.php/Owsproxy');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','rename_copy_Gui',2,1,'Rename / copy GUI','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,576,200,20,10,'','Rename / copy GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/RenameGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','showLoggedUser',2,1,'show logged in user','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','updateWMSs',2,1,'Update Capabilities','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,80,200,20,5,'','Update WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','wfs_conf',2,1,'Configure WFS','Configure WFS','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,373,200,20,5,'','Configure WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Wfs_conf');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','wfs_gui',2,1,'edit wfs settings (Assign WFS conf to GUI)','Assign WFS conf to gui','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,413,200,20,10,'','Assign WFS conf to GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'EditWMSMetadata', 'file_css', '../css/metadata.css', 'css-file to use for the metadata modul', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'body', 'body_file_css', '../css/admin_service.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'filteredWms_layer_topic', 'file css', '../css/administration_alloc_4.css', 'css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'filteredWms_layer_topic', 'language', 'de', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui','switchLocale_noreload',8,1,'changes the locale without reloading the client','Set language','div','','frameborder=''0''',696,14,50,30,5,'','<form id=''form_switch_locale'' name=''form_switch_locale'' target=''parent''>
+<select id=''language'' name=''language'' onchange=''validate_locale()''>
+</select>
+</form>
+','div','mod_switchLocale_noreload.php','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'switchLocale_noreload', 'languages', 'de,en,bg,gr,nl,it,es', '' ,'var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_closetag, e_js_file) VALUES('gui1', 'popup', 6, 1, 'popup replacement', 'div', 'div', 'popup.js');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui1' AND e_id = 'wfs_gazetteer';
+DELETE FROM gui_treegde WHERE fkey_gui_id IN ('gui', 'gui1', 'admin1', 'gui2', 'wms_africa');
+-- update own applications
+Update gui_element set e_title =
+mynew.e_title from gui_element as mynew
+where gui_element.e_id = mynew.e_id
+and mynew.fkey_gui_id = 'gui'
+and gui_element.fkey_gui_id != 'gui'
+and gui_element.fkey_gui_id != 'gui1'
+and gui_element.fkey_gui_id != 'gui2'
+and gui_element.fkey_gui_id != 'gui_digitize';
+and mynew.fkey_gui_id = 'gui1'
+and mynew.fkey_gui_id = 'gui2'
+and mynew.fkey_gui_id = 'gui_digitize'
+Delete from gui_element_vars where fkey_e_id ='tabs' and var_name LIKE 'tab_titles[%';
+Update gui_element_vars set var_type='php_var' where fkey_e_id ='tabs' and var_name LIKE 'tab_ids[%' and var_type='var';
+DELETE FROM gui_element WHERE e_id = 'ajax';
+Delete from gui_element where e_id='keyHandler';
+DELETE FROM gui_element WHERE e_id = 'geometry';
+Select * from gui_element where e_mb_mod ='geometry.js' ;
+update gui_element set e_mb_mod = 'geometry.js'
+where e_id = 'digitize';
+where e_id = 'gazetteerWFS';
+where e_id = 'setSpatialRequest';
More information about the Mapbender_commits mailing list
