[Mapbender-commits] r5063 - trunk/mapbender/lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Dec 3 04:12:55 EST 2009
Author: kmq
Date: 2009-12-03 04:12:54 -0500 (Thu, 03 Dec 2009)
New Revision: 5063
   trunk/mapbender/lib/resultGeometryListController.js
Clean up a little an add documantation
Modified: trunk/mapbender/lib/resultGeometryListController.js
--- trunk/mapbender/lib/resultGeometryListController.js	2009-12-03 08:54:19 UTC (rev 5062)
+++ trunk/mapbender/lib/resultGeometryListController.js	2009-12-03 09:12:54 UTC (rev 5063)
@@ -15,7 +15,12 @@
 	var columns = [];
-	// adding
+	 * Method: addFeature
+	 * Description: adds a Feature to the Model
+	 * Parameters:
+	 * feature - a geoJSON featuree
 	this.addFeature = function(feature) {
 		if (this.wfsConfId === null){
 			// or throw an exception?
@@ -24,12 +29,22 @@
 		var result = this.model.addFeature(feature);
-	// featureCollection is geoJSON
-	this.addFeatureCollection = function(featureCollection){
-		var result = this.model.addFeatureCollection(featureCollection);
+	 * Method: addFeatureCollection
+	 * Description: adds a FeatureCollection to the Model
+	 * Parameters:
+	 * geoJSON - a geoJSON featureCollection
+	this.addFeatureCollection = function(geoJSON){
+		var result = this.model.addFeatureCollection(geoJSON);
-	//called if a FeatureCollection was successfully added to the model
+	 * Method: addFeatureCollection_callback
+	 * Description: The callback received from the Model upon successfully adding a Feature
+	 * Parameters:
+	 * featureEntryCollection - an array of (index,featureCollection) tuples
 	var addFeatureCollection_callback = function(featureEntryCollection){
 	// featureEntryCollection is an array of {index: <index>, feature: <feature>}
 	// where <index> is the index in the model, and feature a featuireCollection
More information about the Mapbender_commits mailing list
