[Mapbender-commits] r5109 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Dec 10 08:05:16 EST 2009
Author: verenadiewald
Date: 2009-12-10 08:05:15 -0500 (Thu, 10 Dec 2009)
New Revision: 5109
   trunk/mapbender/http/plugins/mb_resultList_PrintPreview.js
   trunk/mapbender/http/plugins/mb_resultList_SaveAsFile.js
Modified: trunk/mapbender/http/plugins/mb_resultList_PrintPreview.js
--- trunk/mapbender/http/plugins/mb_resultList_PrintPreview.js	2009-12-10 09:37:37 UTC (rev 5108)
+++ trunk/mapbender/http/plugins/mb_resultList_PrintPreview.js	2009-12-10 13:05:15 UTC (rev 5109)
@@ -5,26 +5,59 @@
 	var c = 0;
 	var table = "";
 	var rows = "";
-	for (var c = 0; c < geoObj.features.length; c++){
-		var feature = geoObj.features[c]
-		var cells = "<td>"+ feature.properties.firstname + "</td>";
-		rows += "<tr>"+cells+"</tr>";
+	var showDetailColumnsArray = [];
+	for (var i = 0 ; i < data.WFSConf.element.length ; i++) {
+		if(data.WFSConf.element[i].f_show_detail == 1) {
+			showDetailColumnsArray.push({
+				name : data.WFSConf.element[i].element_name,
+				label : data.WFSConf.element[i].f_label,
+				position : data.WFSConf.element[i].f_detail_pos
+	var sortFunction = function (a, b) {
+		if(typeof a.position != "number") {
+			return 1;
+		if(typeof b.position != "number") {
+			return -1;
+		return a.position < b.position;
+	showDetailColumnsArray.sort(sortFunction);
+	var pageHtml = "";
+	for (var j = 0; j < geoObj.features.length; j++){
+		var feature = geoObj.features[j];
+		var rows = "";
+		for (elementName in feature.properties) {
+			for (var k = 0 ; k < showDetailColumnsArray.length ; k++) {
+				if(showDetailColumnsArray[k].name == elementName) {
+					var cells = "<td>"+ showDetailColumnsArray[k].label + "</td>";
+					cells += "<td>"+ feature.properties[elementName] + "</td>";
+					rows += "<tr>"+cells+"</tr>";
+		pageHtml += "<table><tbody>"+rows+"</tbody></table><br>";
-	var selected = data.selectedRows;
+/*	var selected = data.selectedRows;
 	rows = "";
     for(c in selected){
 		var feature = selected[c];
 		var name = feature.e.getElementValueByName("firstname")
 		rows += "<tr><td>"+ name +"</td></tr>";
-	table = "<table><tbody>"+rows+"</tbody></table>";
-	doc = "<html><head></head><body>"+ table +"</body></html>";
+	doc = "<html><head>" + options.pageCss + "</head><body>"+ pageHtml +"</body></html>";
 	var popup = open("","Print FeatureCollection");
 	popup.document.write(doc);
 	popup.document.close();
-Mapbender.modules[options.target].addGlobalButton({"title":"Print Preview", "callback": WFSPrintPreview});
+Mapbender.modules[options.target].addGlobalButton({"title":"Alle Detailinfos drucken", "callback": WFSPrintPreview});
Modified: trunk/mapbender/http/plugins/mb_resultList_SaveAsFile.js
--- trunk/mapbender/http/plugins/mb_resultList_SaveAsFile.js	2009-12-10 09:37:37 UTC (rev 5108)
+++ trunk/mapbender/http/plugins/mb_resultList_SaveAsFile.js	2009-12-10 13:05:15 UTC (rev 5109)
@@ -6,12 +6,16 @@
 			data: data.geoJSON
 		callback : function(result, success, message){
-			if(success){
+			if(success) {
 				$('#resultdownloader').remove();
-				var hiddenIframe = $(document.body).append('<iframe id="resultdownloader"></iframe>');
-				$('#resultdownloader').css('display','none');
-				$('#resultdownloader').attr('src',result.url);
-			}else{
+				var hiddenIframe = $(document.body).append('<iframe name="resultdownloader" id="resultdownloader"></iframe>');
+				$('#resultdownloader').css(
+					'display','none'
+				).attr('src',result.url);
+				window.frames["resultdownloader"].location.href =
+					"../php/mod_download.php?download=" + result.url;
+			else {
 				alert("could not create file on server: "+message);
@@ -23,5 +27,4 @@
-Mapbender.modules[options.target].addGlobalButton({"title":"Save as File", "callback": WFSSaveAsFile});
+Mapbender.modules[options.target].addGlobalButton({"title":"Suchergebnis speichern", "callback": WFSSaveAsFile});
\ No newline at end of file
More information about the Mapbender_commits mailing list
