[Mapbender-commits] r5116 - in trunk/mapbender/documents/api_js: javascript search styles
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Dec 11 05:43:08 EST 2009
Author: christoph
Date: 2009-12-11 05:43:07 -0500 (Fri, 11 Dec 2009)
New Revision: 5116
Added:
   trunk/mapbender/documents/api_js/javascript/main.js
   trunk/mapbender/documents/api_js/javascript/searchdata.js
   trunk/mapbender/documents/api_js/styles/main.css
Removed:
   trunk/mapbender/documents/api_js/search/ClassesSymbols.html
   trunk/mapbender/documents/api_js/search/FilesM.html
   trunk/mapbender/documents/api_js/search/VariablesK.html
   trunk/mapbender/documents/api_js/search/VariablesL.html
   trunk/mapbender/documents/api_js/search/VariablesM.html
   trunk/mapbender/documents/api_js/search/VariablesR.html
Added: trunk/mapbender/documents/api_js/javascript/main.js
--- trunk/mapbender/documents/api_js/javascript/main.js	                        (rev 0)
+++ trunk/mapbender/documents/api_js/javascript/main.js	2009-12-11 10:43:07 UTC (rev 5116)
@@ -0,0 +1,836 @@
+// This file is part of Natural Docs, which is Copyright (C) 2003-2008 Greg Valure
+// Natural Docs is licensed under the GPL
+//  Browser Styles
+// ____________________________________________________________________________
+var agt=navigator.userAgent.toLowerCase();
+var browserType;
+var browserVer;
+if (agt.indexOf("opera") != -1)
+    browserType = "Opera";
+    if (agt.indexOf("opera 7") != -1 || agt.indexOf("opera/7") != -1)
+        {  browserVer = "Opera7";  }
+    else if (agt.indexOf("opera 8") != -1 || agt.indexOf("opera/8") != -1)
+        {  browserVer = "Opera8";  }
+    else if (agt.indexOf("opera 9") != -1 || agt.indexOf("opera/9") != -1)
+        {  browserVer = "Opera9";  }
+else if (agt.indexOf("applewebkit") != -1)
+    browserType = "Safari";
+    if (agt.indexOf("version/3") != -1)
+        {  browserVer = "Safari3";  }
+    else if (agt.indexOf("safari/4") != -1)
+        {  browserVer = "Safari2";  }
+else if (agt.indexOf("khtml") != -1)
+    browserType = "Konqueror";
+else if (agt.indexOf("msie") != -1)
+    browserType = "IE";
+    if (agt.indexOf("msie 6") != -1)
+        {  browserVer = "IE6";  }
+    else if (agt.indexOf("msie 7") != -1)
+        {  browserVer = "IE7";  }
+else if (agt.indexOf("gecko") != -1)
+    browserType = "Firefox";
+    if (agt.indexOf("rv:1.7") != -1)
+        {  browserVer = "Firefox1";  }
+    else if (agt.indexOf("rv:1.8)") != -1 || agt.indexOf("rv:1.8.0") != -1)
+        {  browserVer = "Firefox15";  }
+    else if (agt.indexOf("rv:1.8.1") != -1)
+        {  browserVer = "Firefox2";  }
+//  Support Functions
+function GetXPosition(item)
+    var position = 0;
+    if (item.offsetWidth != null)
+        while (item != document.body && item != null)
+            position += item.offsetLeft;
+            item = item.offsetParent;
+    return position;
+function GetYPosition(item)
+    var position = 0;
+            position += item.offsetTop;
+    return position;
+function MoveToPosition(item, x, y)
+    // Opera 5 chokes on the px extension, so it can use the Microsoft one instead.
+    if (item.style.left != null)
+        item.style.left = x + "px";
+        item.style.top = y + "px";
+    else if (item.style.pixelLeft != null)
+        item.style.pixelLeft = x;
+        item.style.pixelTop = y;
+//  Menu
+function ToggleMenu(id)
+    if (!window.document.getElementById)
+        {  return;  };
+    var display = window.document.getElementById(id).style.display;
+    if (display == "none")
+        {  display = "block";  }
+    else
+        {  display = "none";  }
+    window.document.getElementById(id).style.display = display;
+function HideAllBut(ids, max)
+    if (document.getElementById)
+        ids.sort( function(a,b) { return a - b; } );
+        var number = 1;
+        while (number < max)
+            if (ids.length > 0 && number == ids[0])
+                {  ids.shift();  }
+            else
+                document.getElementById("MGroupContent" + number).style.display = "none";
+            number++;
+//  Tooltips
+var tooltipTimer = 0;
+function ShowTip(event, tooltipID, linkID)
+    if (tooltipTimer)
+        {  clearTimeout(tooltipTimer);  };
+    var docX = event.clientX + window.pageXOffset;
+    var docY = event.clientY + window.pageYOffset;
+    var showCommand = "ReallyShowTip('" + tooltipID + "', '" + linkID + "', " + docX + ", " + docY + ")";
+    tooltipTimer = setTimeout(showCommand, 1000);
+function ReallyShowTip(tooltipID, linkID, docX, docY)
+    tooltipTimer = 0;
+    var tooltip;
+    var link;
+        tooltip = document.getElementById(tooltipID);
+        link = document.getElementById(linkID);
+/*    else if (document.all)
+        tooltip = eval("document.all['" + tooltipID + "']");
+        link = eval("document.all['" + linkID + "']");
+    if (tooltip)
+        var left = GetXPosition(link);
+        var top = GetYPosition(link);
+        top += link.offsetHeight;
+        // The fallback method is to use the mouse X and Y relative to the document.  We use a separate if and test if its a number
+        // in case some browser snuck through the above if statement but didn't support everything.
+        if (!isFinite(top) || top == 0)
+            left = docX;
+            top = docY;
+        // Some spacing to get it out from under the cursor.
+        top += 10;
+        // Make sure the tooltip doesnt get smushed by being too close to the edge, or in some browsers, go off the edge of the
+        // page.  We do it here because Konqueror does get offsetWidth right even if it doesnt get the positioning right.
+        if (tooltip.offsetWidth != null)
+            var width = tooltip.offsetWidth;
+            var docWidth = document.body.clientWidth;
+            if (left + width > docWidth)
+                {  left = docWidth - width - 1;  }
+            // If there's a horizontal scroll bar we could go past zero because it's using the page width, not the window width.
+            if (left < 0)
+                {  left = 0;  };
+        MoveToPosition(tooltip, left, top);
+        tooltip.style.visibility = "visible";
+function HideTip(tooltipID)
+    if (tooltipTimer)
+        clearTimeout(tooltipTimer);
+        tooltipTimer = 0;
+    var tooltip;
+        {  tooltip = document.getElementById(tooltipID); }
+    else if (document.all)
+        {  tooltip = eval("document.all['" + tooltipID + "']");  }
+    if (tooltip)
+        {  tooltip.style.visibility = "hidden";  }
+//  Blockquote fix for IE
+function NDOnLoad()
+    if (browserVer == "IE6")
+        var scrollboxes = document.getElementsByTagName('blockquote');
+        if (scrollboxes.item(0))
+            NDDoResize();
+            window.onresize=NDOnResize;
+var resizeTimer = 0;
+function NDOnResize()
+    if (resizeTimer != 0)
+        {  clearTimeout(resizeTimer);  };
+    resizeTimer = setTimeout(NDDoResize, 250);
+function NDDoResize()
+    var i;
+    var item;
+    i = 0;
+    while (item = scrollboxes.item(i))
+        item.style.width = 100;
+        i++;
+    i = 0;
+        item.style.width = item.parentNode.offsetWidth;
+        i++;
+    clearTimeout(resizeTimer);
+    resizeTimer = 0;
+/* ________________________________________________________________________________________________________
+    Class: SearchPanel
+    ________________________________________________________________________________________________________
+    A class handling everything associated with the search panel.
+    Parameters:
+        name - The name of the global variable that will be storing this instance.  Is needed to be able to set timeouts.
+        mode - The mode the search is going to work in.  Pass <NaturalDocs::Builder::Base->CommandLineOption()>, so the
+                   value will be something like "HTML" or "FramedHTML".
+function SearchPanel(name, mode, resultsPath)
+    if (!name || !mode || !resultsPath)
+        {  alert("Incorrect parameters to SearchPanel.");  };
+    // Group: Variables
+    // ________________________________________________________________________
+        var: name
+        The name of the global variable that will be storing this instance of the class.
+    this.name = name;
+        var: mode
+        The mode the search is going to work in, such as "HTML" or "FramedHTML".
+    this.mode = mode;
+        var: resultsPath
+        The relative path from the current HTML page to the results page directory.
+    this.resultsPath = resultsPath;
+        var: keyTimeout
+        The timeout used between a keystroke and when a search is performed.
+    this.keyTimeout = 0;
+        var: keyTimeoutLength
+        The length of <keyTimeout> in thousandths of a second.
+    this.keyTimeoutLength = 500;
+        var: lastSearchValue
+        The last search string executed, or an empty string if none.
+    this.lastSearchValue = "";
+        var: lastResultsPage
+        The last results page.  The value is only relevant if <lastSearchValue> is set.
+    this.lastResultsPage = "";
+        var: deactivateTimeout
+        The timeout used between when a control is deactivated and when the entire panel is deactivated.  Is necessary
+        because a control may be deactivated in favor of another control in the same panel, in which case it should stay
+        active.
+    this.deactivateTimout = 0;
+        var: deactivateTimeoutLength
+        The length of <deactivateTimeout> in thousandths of a second.
+    this.deactivateTimeoutLength = 200;
+    // Group: DOM Elements
+    // Function: DOMSearchField
+    this.DOMSearchField = function()
+        {  return document.getElementById("MSearchField");  };
+    // Function: DOMSearchType
+    this.DOMSearchType = function()
+        {  return document.getElementById("MSearchType");  };
+    // Function: DOMPopupSearchResults
+    this.DOMPopupSearchResults = function()
+        {  return document.getElementById("MSearchResults");  };
+    // Function: DOMPopupSearchResultsWindow
+    this.DOMPopupSearchResultsWindow = function()
+        {  return document.getElementById("MSearchResultsWindow");  };
+    // Function: DOMSearchPanel
+    this.DOMSearchPanel = function()
+        {  return document.getElementById("MSearchPanel");  };
+    // Group: Event Handlers
+        Function: OnSearchFieldFocus
+        Called when focus is added or removed from the search field.
+    this.OnSearchFieldFocus = function(isActive)
+        this.Activate(isActive);
+        Function: OnSearchFieldChange
+        Called when the content of the search field is changed.
+    this.OnSearchFieldChange = function()
+        if (this.keyTimeout)
+            clearTimeout(this.keyTimeout);
+        var searchValue = this.DOMSearchField().value.replace(/ +/g, "");
+        if (searchValue != this.lastSearchValue)
+            if (searchValue != "")
+                this.keyTimeout = setTimeout(this.name + ".Search()", this.keyTimeoutLength);
+            else
+                if (this.mode == "HTML")
+                    {  this.DOMPopupSearchResultsWindow().style.display = "none";  };
+        Function: OnSearchTypeFocus
+        Called when focus is added or removed from the search type.
+    this.OnSearchTypeFocus = function(isActive)
+        Function: OnSearchTypeChange
+        Called when the search type is changed.
+    this.OnSearchTypeChange = function()
+            this.Search();
+    // Group: Action Functions
+        Function: CloseResultsWindow
+        Closes the results window.
+    this.CloseResultsWindow = function()
+        this.DOMPopupSearchResultsWindow().style.display = "none";
+        this.Activate(false, true);
+        Function: Search
+        Performs a search.
+    this.Search = function()
+        var searchValue = this.DOMSearchField().value.replace(/^ +/, "");
+        var searchTopic = this.DOMSearchType().value;
+        var pageExtension = searchValue.substr(0,1);
+        if (pageExtension.match(/^[a-z]/i))
+            {  pageExtension = pageExtension.toUpperCase();  }
+        else if (pageExtension.match(/^[0-9]/))
+            {  pageExtension = 'Numbers';  }
+        else
+            {  pageExtension = "Symbols";  };
+        var resultsPage;
+        var resultsPageWithSearch;
+        var hasResultsPage;
+        // indexSectionsWithContent is defined in searchdata.js
+        if (indexSectionsWithContent[searchTopic][pageExtension] == true)
+            resultsPage = this.resultsPath + '/' + searchTopic + pageExtension + '.html';
+            resultsPageWithSearch = resultsPage+'?'+escape(searchValue);
+            hasResultsPage = true;
+        else
+            resultsPage = this.resultsPath + '/NoResults.html';
+            resultsPageWithSearch = resultsPage;
+            hasResultsPage = false;
+        var resultsFrame;
+            {  resultsFrame = window.frames.MSearchResults;  }
+        else if (this.mode == "FramedHTML")
+            {  resultsFrame = window.top.frames['Content'];  };
+        if (resultsPage != this.lastResultsPage ||
+            // Bug in IE.  If everything becomes hidden in a run, none of them will be able to be reshown in the next for some
+            // reason.  It counts the right number of results, and you can even read the display as "block" after setting it, but it
+            // just doesn't work in IE 6 or IE 7.  So if we're on the right page but the previous search had no results, reload the
+            // page anyway to get around the bug.
+            (browserType == "IE" && hasResultsPage &&
+            	(!resultsFrame.searchResults || resultsFrame.searchResults.lastMatchCount == 0)) )
+            resultsFrame.location.href = resultsPageWithSearch;
+        // So if the results page is right and there's no IE bug, reperform the search on the existing page.  We have to check if there
+        // are results because NoResults.html doesn't have any JavaScript, and it would be useless to do anything on that page even
+        // if it did.
+        else if (hasResultsPage)
+            // We need to check if this exists in case the frame is present but didn't finish loading.
+            if (resultsFrame.searchResults)
+                {  resultsFrame.searchResults.Search(searchValue);  }
+            // Otherwise just reload instead of waiting.
+            else
+                {  resultsFrame.location.href = resultsPageWithSearch;  };
+        var domPopupSearchResultsWindow = this.DOMPopupSearchResultsWindow();
+        if (this.mode == "HTML" && domPopupSearchResultsWindow.style.display != "block")
+            var domSearchType = this.DOMSearchType();
+            var left = GetXPosition(domSearchType);
+            var top = GetYPosition(domSearchType) + domSearchType.offsetHeight;
+            MoveToPosition(domPopupSearchResultsWindow, left, top);
+            domPopupSearchResultsWindow.style.display = 'block';
+        this.lastSearchValue = searchValue;
+        this.lastResultsPage = resultsPage;
+    // Group: Activation Functions
+    // Functions that handle whether the entire panel is active or not.
+        Function: Activate
+        Activates or deactivates the search panel, resetting things to their default values if necessary.  You can call this on every
+        control's OnBlur() and it will handle not deactivating the entire panel when focus is just switching between them transparently.
+        Parameters:
+            isActive - Whether you're activating or deactivating the panel.
+            ignoreDeactivateDelay - Set if you're positive the action will deactivate the panel and thus want to skip the delay.
+    this.Activate = function(isActive, ignoreDeactivateDelay)
+        // We want to ignore isActive being false while the results window is open.
+        if (isActive || (this.mode == "HTML" && this.DOMPopupSearchResultsWindow().style.display == "block"))
+            if (this.inactivateTimeout)
+                clearTimeout(this.inactivateTimeout);
+                this.inactivateTimeout = 0;
+            this.DOMSearchPanel().className = 'MSearchPanelActive';
+            var searchField = this.DOMSearchField();
+            if (searchField.value == 'Search')
+                 {  searchField.value = "";  }
+        else if (!ignoreDeactivateDelay)
+            this.inactivateTimeout = setTimeout(this.name + ".InactivateAfterTimeout()", this.inactivateTimeoutLength);
+        else
+            this.InactivateAfterTimeout();
+        Function: InactivateAfterTimeout
+        Called by <inactivateTimeout>, which is set by <Activate()>.  Inactivation occurs on a timeout because a control may
+        receive OnBlur() when focus is really transferring to another control in the search panel.  In this case we don't want to
+        actually deactivate the panel because not only would that cause a visible flicker but it could also reset the search value.
+        So by doing it on a timeout instead, there's a short period where the second control's OnFocus() can cancel the deactivation.
+    this.InactivateAfterTimeout = function()
+        this.DOMSearchPanel().className = 'MSearchPanelInactive';
+        this.DOMSearchField().value = "Search";
+   Class: SearchResults
+   _________________________________________________________________________________________________________
+   The class that handles everything on the search results page.
+function SearchResults(name, mode)
+        var: mode
+    this.mode = mode;
+        var: lastMatchCount
+        The number of matches from the last run of <Search()>.
+    this.lastMatchCount = 0;
+        Function: Toggle
+        Toggles the visibility of the passed element ID.
+    this.Toggle = function(id)
+        if (this.mode == "FramedHTML")
+            {  return;  };
+        var parentElement = document.getElementById(id);
+        var element = parentElement.firstChild;
+        while (element && element != parentElement)
+            if (element.nodeName == 'DIV' && element.className == 'ISubIndex')
+                if (element.style.display == 'block')
+                    {  element.style.display = "none";  }
+                else
+                    {  element.style.display = 'block';  }
+            if (element.nodeName == 'DIV' && element.hasChildNodes())
+                {  element = element.firstChild;  }
+            else if (element.nextSibling)
+                {  element = element.nextSibling;  }
+            else
+                do
+                    element = element.parentNode;
+                while (element && element != parentElement && !element.nextSibling);
+                if (element && element != parentElement)
+                    {  element = element.nextSibling;  };
+        Function: Search
+        Searches for the passed string.  If there is no parameter, it takes it from the URL query.
+        Always returns true, since other documents may try to call it and that may or may not be possible.
+    this.Search = function(search)
+        if (!search)
+            search = window.location.search;
+            search = search.substring(1);  // Remove the leading ?
+            search = unescape(search);
+        search = search.replace(/^ +/, "");
+        search = search.replace(/ +$/, "");
+        search = search.toLowerCase();
+        if (search.match(/[^a-z0-9]/)) // Just a little speedup so it doesn't have to go through the below unnecessarily.
+            search = search.replace(/\_/g, "_und");
+            search = search.replace(/\ +/gi, "_spc");
+            search = search.replace(/\~/g, "_til");
+            search = search.replace(/\!/g, "_exc");
+            search = search.replace(/\@/g, "_att");
+            search = search.replace(/\#/g, "_num");
+            search = search.replace(/\$/g, "_dol");
+            search = search.replace(/\%/g, "_pct");
+            search = search.replace(/\^/g, "_car");
+            search = search.replace(/\&/g, "_amp");
+            search = search.replace(/\*/g, "_ast");
+            search = search.replace(/\(/g, "_lpa");
+            search = search.replace(/\)/g, "_rpa");
+            search = search.replace(/\-/g, "_min");
+            search = search.replace(/\+/g, "_plu");
+            search = search.replace(/\=/g, "_equ");
+            search = search.replace(/\{/g, "_lbc");
+            search = search.replace(/\}/g, "_rbc");
+            search = search.replace(/\[/g, "_lbk");
+            search = search.replace(/\]/g, "_rbk");
+            search = search.replace(/\:/g, "_col");
+            search = search.replace(/\;/g, "_sco");
+            search = search.replace(/\"/g, "_quo");
+            search = search.replace(/\'/g, "_apo");
+            search = search.replace(/\</g, "_lan");
+            search = search.replace(/\>/g, "_ran");
+            search = search.replace(/\,/g, "_com");
+            search = search.replace(/\./g, "_per");
+            search = search.replace(/\?/g, "_que");
+            search = search.replace(/\//g, "_sla");
+            search = search.replace(/[^a-z0-9\_]i/gi, "_zzz");
+        var resultRows = document.getElementsByTagName("div");
+        var matches = 0;
+        var i = 0;
+        while (i < resultRows.length)
+            var row = resultRows.item(i);
+            if (row.className == "SRResult")
+                var rowMatchName = row.id.toLowerCase();
+                rowMatchName = rowMatchName.replace(/^sr\d*_/, '');
+                if (search.length <= rowMatchName.length && rowMatchName.substr(0, search.length) == search)
+                    row.style.display = "block";
+                    matches++;
+                else
+                    {  row.style.display = "none";  };
+            i++;
+        document.getElementById("Searching").style.display="none";
+        if (matches == 0)
+            {  document.getElementById("NoMatches").style.display="block";  }
+        else
+            {  document.getElementById("NoMatches").style.display="none";  }
+        this.lastMatchCount = matches;
+        return true;
Added: trunk/mapbender/documents/api_js/javascript/searchdata.js
--- trunk/mapbender/documents/api_js/javascript/searchdata.js	                        (rev 0)
+++ trunk/mapbender/documents/api_js/javascript/searchdata.js	2009-12-11 10:43:07 UTC (rev 5116)
@@ -0,0 +1,302 @@
+var indexSectionsWithContent = {
+   "General": {
+      "Symbols": false,
+      "Numbers": false,
+      "A": true,
+      "B": false,
+      "C": true,
+      "D": true,
+      "E": true,
+      "F": true,
+      "G": false,
+      "H": true,
+      "I": true,
+      "J": false,
+      "K": true,
+      "L": true,
+      "M": true,
+      "N": true,
+      "O": true,
+      "P": false,
+      "Q": false,
+      "R": true,
+      "S": true,
+      "T": true,
+      "U": false,
+      "V": true,
+      "W": false,
+      "X": false,
+      "Y": false,
+      "Z": true
+   "Variables": {
+      "Symbols": true,
+      "Numbers": false,
+      "A": true,
+      "B": true,
+      "C": true,
+      "D": true,
+      "E": false,
+      "F": true,
+      "G": false,
+      "H": false,
+      "I": true,
+      "J": false,
+      "K": false,
+      "L": false,
+      "M": false,
+      "N": true,
+      "O": true,
+      "P": false,
+      "Q": false,
+      "R": false,
+      "S": true,
+      "T": true,
+      "U": false,
+      "V": false,
+      "W": false,
+      "X": false,
+      "Y": false,
+      "Z": false
+   "Functions": {
+      "Symbols": true,
+      "Numbers": false,
+      "A": true,
+      "B": true,
+      "C": true,
+      "D": true,
+      "E": true,
+      "F": true,
+      "G": true,
+      "H": true,
+      "I": true,
+      "J": true,
+      "K": true,
+      "L": true,
+      "M": true,
+      "N": true,
+      "O": true,
+      "P": true,
+      "Q": false,
+      "R": true,
+      "S": true,
+      "T": true,
+      "U": true,
+      "V": true,
+      "W": true,
+      "X": true,
+      "Y": true,
+      "Z": true
+   "Files": {
+      "Symbols": false,
+      "Numbers": false,
+      "A": true,
+      "B": false,
+      "C": true,
+      "D": false,
+      "E": false,
+      "F": true,
+      "G": false,
+      "H": false,
+      "I": false,
+      "J": true,
+      "K": false,
+      "L": false,
+      "M": false,
+      "N": false,
+      "O": true,
+      "P": false,
+      "Q": false,
+      "R": true,
+      "S": true,
+      "T": true,
+      "U": true,
+      "V": false,
+      "W": true,
+      "X": false,
+      "Y": false,
+      "Z": false
+   "Constants": {
+      "Symbols": false,
+      "Numbers": false,
+      "A": false,
+      "B": true,
+      "C": true,
+      "D": true,
+      "E": true,
+      "F": true,
+      "G": false,
+      "H": false,
+      "I": true,
+      "J": false,
+      "K": true,
+      "L": true,
+      "M": true,
+      "N": false,
+      "O": true,
+      "P": false,
+      "Q": false,
+      "R": true,
+      "S": true,
+      "T": true,
+      "U": true,
+      "V": true,
+      "W": false,
+      "X": true,
+      "Y": true,
+      "Z": true
+   "DatabaseIndexes": {
+      "Symbols": false,
+      "Numbers": false,
+      "A": false,
+      "B": false,
+      "C": false,
+      "D": false,
+      "E": false,
+      "F": false,
+      "G": false,
+      "H": false,
+      "I": true,
+      "J": false,
+      "K": false,
+      "L": false,
+      "M": false,
+      "N": false,
+      "O": false,
+      "P": false,
+      "Q": false,
+      "R": false,
+      "S": false,
+      "T": false,
+      "U": false,
+      "V": false,
+      "W": false,
+      "X": false,
+      "Y": false,
+      "Z": false
+   "DatabaseTables": {
+      "Symbols": false,
+      "Numbers": false,
+      "A": false,
+      "B": false,
+      "C": false,
+      "D": false,
+      "E": false,
+      "F": false,
+      "G": false,
+      "H": false,
+      "I": false,
+      "J": false,
+      "K": false,
+      "L": false,
+      "M": true,
+      "N": false,
+      "O": false,
+      "P": false,
+      "Q": false,
+      "R": false,
+      "S": false,
+      "T": false,
+      "U": false,
+      "V": false,
+      "W": false,
+      "X": false,
+      "Y": false,
+      "Z": false
+   "Classes": {
+      "Symbols": false,
+      "Numbers": false,
+      "A": true,
+      "B": false,
+      "C": true,
+      "D": true,
+      "E": true,
+      "F": false,
+      "G": false,
+      "H": false,
+      "I": true,
+      "J": true,
+      "K": false,
+      "L": true,
+      "M": true,
+      "N": true,
+      "O": true,
+      "P": true,
+      "Q": false,
+      "R": true,
+      "S": true,
+      "T": false,
+      "U": true,
+      "V": false,
+      "W": true,
+      "X": false,
+      "Y": false,
+      "Z": true
+   "DatabaseTriggers": {
+      "Symbols": false,
+      "Numbers": false,
+      "A": false,
+      "B": false,
+      "C": false,
+      "D": false,
+      "E": false,
+      "F": false,
+      "G": false,
+      "H": false,
+      "I": false,
+      "J": false,
+      "K": false,
+      "L": false,
+      "M": true,
+      "N": false,
+      "O": false,
+      "P": false,
+      "Q": false,
+      "R": false,
+      "S": false,
+      "T": false,
+      "U": false,
+      "V": false,
+      "W": false,
+      "X": false,
+      "Y": false,
+      "Z": false
+   "Properties": {
+      "Symbols": true,
+      "Numbers": false,
+      "A": true,
+      "B": true,
+      "C": true,
+      "D": true,
+      "E": true,
+      "F": true,
+      "G": true,
+      "H": true,
+      "I": true,
+      "J": true,
+      "K": false,
+      "L": true,
+      "M": true,
+      "N": true,
+      "O": true,
+      "P": true,
+      "Q": true,
+      "R": true,
+      "S": true,
+      "T": true,
+      "U": true,
+      "V": true,
+      "W": true,
+      "X": true,
+      "Y": true,
+      "Z": true
\ No newline at end of file
Deleted: trunk/mapbender/documents/api_js/search/ClassesSymbols.html
--- trunk/mapbender/documents/api_js/search/ClassesSymbols.html	2009-12-11 10:42:34 UTC (rev 5115)
+++ trunk/mapbender/documents/api_js/search/ClassesSymbols.html	2009-12-11 10:43:07 UTC (rev 5116)
@@ -1,20 +0,0 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
-<html><head><link rel="stylesheet" type="text/css" href="../styles/main.css"><script language=JavaScript src="../javascript/main.js"></script></head><body class="PopupSearchResultsPage" onLoad="NDOnLoad()"><script language=JavaScript><!--
-if (browserType) {document.write("<div class=" + browserType + ">");if (browserVer) {document.write("<div class=" + browserVer + ">"); }}// --></script>
-<!--  Generated by Natural Docs, version 1.4 -->
-<!--  http://www.naturaldocs.org  -->
-<!-- saved from url=(0026)http://www.naturaldocs.org -->
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR__lanApplication_spcelement_spcname_ran><div class=IEntry><a href="../files/http/plugins/mb_selectMapsize-js.html#Application_element_name" target=_parent class=ISymbol>&lt;Application element name&gt;</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
-document.getElementById("Loading").style.display="none";
-document.getElementById("NoMatches").style.display="none";
-var searchResults = new SearchResults("searchResults", "HTML");
-searchResults.Search();
---></script></div><script language=JavaScript><!--
-if (browserType) {if (browserVer) {document.write("</div>"); }document.write("</div>");}// --></script></body></html>
Deleted: trunk/mapbender/documents/api_js/search/FilesM.html
--- trunk/mapbender/documents/api_js/search/FilesM.html	2009-12-11 10:42:34 UTC (rev 5115)
+++ trunk/mapbender/documents/api_js/search/FilesM.html	2009-12-11 10:43:07 UTC (rev 5116)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_mod_undaddWMSfromfilteredList_perphp><div class=IEntry><a href="../files/http/javascripts/mod_addWMSfromfilteredList-php.html#mod_addWMSfromfilteredList.php" target=_parent class=ISymbol>mod_addWMSfromfilteredList.php</a></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: trunk/mapbender/documents/api_js/search/VariablesK.html
--- trunk/mapbender/documents/api_js/search/VariablesK.html	2009-12-11 10:42:34 UTC (rev 5115)
+++ trunk/mapbender/documents/api_js/search/VariablesK.html	2009-12-11 10:43:07 UTC (rev 5116)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_keyTimeout><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.keyTimeout" target=_parent class=ISymbol>keyTimeout</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_keyTimeoutLength><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.keyTimeoutLength" target=_parent class=ISymbol>keyTimeoutLength</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: trunk/mapbender/documents/api_js/search/VariablesL.html
--- trunk/mapbender/documents/api_js/search/VariablesL.html	2009-12-11 10:42:34 UTC (rev 5115)
+++ trunk/mapbender/documents/api_js/search/VariablesL.html	2009-12-11 10:43:07 UTC (rev 5116)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_lastMatchCount><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchResults.lastMatchCount" target=_parent class=ISymbol>lastMatchCount</a>, <span class=IParent>SearchResults</span></div></div><div class=SRResult id=SR_lastResultsPage><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.lastResultsPage" target=_parent class=ISymbol>lastResultsPage</a>, <span class=IParent>SearchPanel</span></div></div><div class=SRResult id=SR_lastSearchValue><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.lastSearchValue" target=_parent class=ISymbol>lastSearchValue</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: trunk/mapbender/documents/api_js/search/VariablesM.html
--- trunk/mapbender/documents/api_js/search/VariablesM.html	2009-12-11 10:42:34 UTC (rev 5115)
+++ trunk/mapbender/documents/api_js/search/VariablesM.html	2009-12-11 10:43:07 UTC (rev 5116)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_mode><div class=IEntry><a href="javascript:searchResults.Toggle('SR_mode')" class=ISymbol>mode</a><div class=ISubIndex><a href="../files/docs/javascript/main-js.html#SearchPanel.mode" target=_parent class=IParent>SearchPanel</a><a href="../files/docs/javascript/main-js.html#SearchResults.mode" target=_parent class=IParent>SearchResults</a></div></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Deleted: trunk/mapbender/documents/api_js/search/VariablesR.html
--- trunk/mapbender/documents/api_js/search/VariablesR.html	2009-12-11 10:42:34 UTC (rev 5115)
+++ trunk/mapbender/documents/api_js/search/VariablesR.html	2009-12-11 10:43:07 UTC (rev 5116)
@@ -1,20 +0,0 @@
-<div id=Index><div class=SRStatus id=Loading>Loading...</div><table border=0 cellspacing=0 cellpadding=0><div class=SRResult id=SR_resultsPath><div class=IEntry><a href="../files/docs/javascript/main-js.html#SearchPanel.resultsPath" target=_parent class=ISymbol>resultsPath</a>, <span class=IParent>SearchPanel</span></div></div></table><div class=SRStatus id=Searching>Searching...</div><div class=SRStatus id=NoMatches>No Matches</div><script type="text/javascript"><!--
Added: trunk/mapbender/documents/api_js/styles/main.css
--- trunk/mapbender/documents/api_js/styles/main.css	                        (rev 0)
+++ trunk/mapbender/documents/api_js/styles/main.css	2009-12-11 10:43:07 UTC (rev 5116)
@@ -0,0 +1,767 @@
+   IMPORTANT: If you're editing this file in the output directory of one of
+   your projects, your changes will be overwritten the next time you run
+   Natural Docs.  Instead, copy this file to your project directory, make your
+   changes, and you can use it with -s.  Even better would be to make a CSS
+   file in your project directory with only your changes, which you can then
+   use with -s [original style] [your changes].
+   On the other hand, if you're editing this file in the Natural Docs styles
+   directory, the changes will automatically be applied to all your projects
+   that use this style the next time Natural Docs is run on them.
+   This file is part of Natural Docs, which is Copyright (C) 2003-2008 Greg Valure
+   Natural Docs is licensed under the GPL
+body {
+    font: 10pt Verdana, Arial, sans-serif;
+    color: #000000;
+    margin: 0; padding: 0;
+.ContentPage,
+.IndexPage,
+.FramedMenuPage {
+    background-color: #E8E8E8;
+.FramedContentPage,
+.FramedIndexPage,
+.FramedSearchResultsPage,
+.PopupSearchResultsPage {
+    background-color: #FFFFFF;
+a:link,
+a:visited { color: #900000; text-decoration: none }
+a:hover { color: #900000; text-decoration: underline }
+a:active { color: #FF0000; text-decoration: underline }
+td {
+    vertical-align: top }
+img { border: 0;  }
+    Comment out this line to use web-style paragraphs (blank line between
+    paragraphs, no indent) instead of print-style paragraphs (no blank line,
+    indented.)
+p {
+    text-indent: 5ex; margin: 0 }
+/*  Opera doesn't break with just wbr, but will if you add this.  */
+.Opera wbr:after {
+	content: "\00200B";
+/*  Blockquotes are used as containers for things that may need to scroll.  */
+blockquote {
+    padding: 0;
+    margin: 0;
+    overflow: auto;
+.Firefox1 blockquote {
+    padding-bottom: .5em;
+/*  Turn off scrolling when printing.  */
+ at media print {
+    blockquote {
+        overflow: visible;
+    .IE blockquote {
+        width: auto;
+#Menu {
+    font-size: 9pt;
+    padding: 10px 0 0 0;
+.ContentPage #Menu,
+.IndexPage #Menu {
+    position: absolute;
+    top: 0;
+    left: 0;
+    width: 31ex;
+    overflow: hidden;
+.ContentPage .Firefox #Menu,
+.IndexPage .Firefox #Menu {
+    width: 27ex;
+    .MTitle {
+        font-size: 16pt; font-weight: bold; font-variant: small-caps;
+        text-align: center;
+        padding: 5px 10px 15px 10px;
+        border-bottom: 1px dotted #000000;
+        margin-bottom: 15px }
+    .MSubTitle {
+        font-size: 9pt; font-weight: normal; font-variant: normal;
+        margin-top: 1ex; margin-bottom: 5px }
+    .MEntry a:link,
+    .MEntry a:hover,
+    .MEntry a:visited { color: #606060; margin-right: 0 }
+    .MEntry a:active { color: #A00000; margin-right: 0 }
+    .MGroup {
+        font-variant: small-caps; font-weight: bold;
+        margin: 1em 0 1em 10px;
+    .MGroupContent {
+        font-variant: normal; font-weight: normal }
+    .MGroup a:link,
+    .MGroup a:hover,
+    .MGroup a:visited { color: #545454; margin-right: 10px }
+    .MGroup a:active { color: #A00000; margin-right: 10px }
+    .MFile,
+    .MText,
+    .MLink,
+    .MIndex {
+        padding: 1px 17px 2px 10px;
+        margin: .25em 0 .25em 0;
+    .MText {
+        font-size: 8pt; font-style: italic }
+    .MLink {
+        font-style: italic }
+    #MSelected {
+        color: #000000; background-color: #FFFFFF;
+        /*  Replace padding with border.  */
+        padding: 0 10px 0 10px;
+        border-width: 1px 2px 2px 0; border-style: solid; border-color: #000000;
+        margin-right: 5px;
+    /*  Close off the left side when its in a group.  */
+    .MGroup #MSelected {
+        padding-left: 9px; border-left-width: 1px }
+    /*  A treat for Mozilla users.  Blatantly non-standard.  Will be replaced with CSS 3 attributes when finalized/supported.  */
+    .Firefox #MSelected {
+        -moz-border-radius-topright: 10px;
+        -moz-border-radius-bottomright: 10px }
+    .Firefox .MGroup #MSelected {
+        -moz-border-radius-topleft: 10px;
+        -moz-border-radius-bottomleft: 10px }
+    #MSearchPanel {
+        padding: 0px 6px;
+        margin: .25em 0;
+    #MSearchField {
+        font: italic 9pt Verdana, sans-serif;
+        color: #606060;
+        border: none;
+        padding: 2px 4px;
+        width: 100%;
+    /* Only Opera gets it right. */
+    .Firefox #MSearchField,
+    .IE #MSearchField,
+    .Safari #MSearchField {
+        width: 94%;
+    .Opera9 #MSearchField,
+    .Konqueror #MSearchField {
+        width: 97%;
+    .FramedMenuPage .Firefox #MSearchField,
+    .FramedMenuPage .Safari #MSearchField,
+    .FramedMenuPage .Konqueror #MSearchField {
+        width: 98%;
+    /* Firefox doesn't do this right in frames without #MSearchPanel added on.
+        It's presence doesn't hurt anything other browsers. */
+    #MSearchPanel.MSearchPanelInactive:hover #MSearchField {
+        border: 1px solid #C0C0C0;
+        padding: 1px 3px;
+    .MSearchPanelActive #MSearchField {
+        font-style: normal;
+        padding: 1px 3px;
+    #MSearchType {
+        visibility: hidden;
+        font: 8pt Verdana, sans-serif;
+        width: 98%;
+        padding: 0;
+    .MSearchPanelActive #MSearchType,
+    /*  As mentioned above, Firefox doesn't do this right in frames without #MSearchPanel added on. */
+    #MSearchPanel.MSearchPanelInactive:hover #MSearchType,
+    #MSearchType:focus {
+        visibility: visible;
+        color: #606060;
+    #MSearchType option#MSearchEverything {
+        font-weight: bold;
+    .Opera8 .MSearchPanelInactive:hover,
+    .Opera8 .MSearchPanelActive {
+        margin-left: -1px;
+    iframe#MSearchResults {
+        width: 60ex;
+        height: 15em;
+    #MSearchResultsWindow {
+        display: none;
+        left: 0; top: 0;
+        border: 1px solid #000000;
+    #MSearchResultsWindowClose {
+        font-size: 8pt;
+        display: block;
+        padding: 2px 5px;
+    #MSearchResultsWindowClose:link,
+    #MSearchResultsWindowClose:visited {
+        color: #000000;
+        text-decoration: none;
+    #MSearchResultsWindowClose:active,
+    #MSearchResultsWindowClose:hover {
+        color: #800000;
+        background-color: #F4F4F4;
+#Content {
+    padding-bottom: 15px;
+.ContentPage #Content {
+    border-width: 0 0 1px 1px;
+    border-style: solid;
+    border-color: #000000;
+    font-size: 9pt;  /* To make 31ex match the menu's 31ex. */
+    margin-left: 31ex;
+.ContentPage .Firefox #Content {
+    margin-left: 27ex;
+    .CTopic {
+        font-size: 10pt;
+        margin-bottom: 3em;
+    .CTitle {
+        font-size: 12pt; font-weight: bold;
+        border-width: 0 0 1px 0; border-style: solid; border-color: #A0A0A0;
+        margin: 0 15px .5em 15px }
+    .CGroup .CTitle {
+        font-size: 16pt; font-variant: small-caps;
+        padding-left: 15px; padding-right: 15px;
+        border-width: 0 0 2px 0; border-color: #000000;
+        margin-left: 0; margin-right: 0 }
+    .CClass .CTitle,
+    .CInterface .CTitle,
+    .CDatabase .CTitle,
+    .CDatabaseTable .CTitle,
+    .CSection .CTitle {
+        font-size: 18pt;
+        color: #FFFFFF; background-color: #A0A0A0;
+        padding: 10px 15px 10px 15px;
+        border-width: 2px 0; border-color: #000000;
+    #MainTopic .CTitle {
+        font-size: 20pt;
+        color: #FFFFFF; background-color: #7070C0;
+        border-width: 0 0 3px 0; border-color: #000000;
+    .CBody {
+        margin-left: 15px; margin-right: 15px }
+    .CToolTip {
+        position: absolute; visibility: hidden;
+        left: 0; top: 0;
+        background-color: #FFFFE0;
+        padding: 5px;
+        border-width: 1px 2px 2px 1px; border-style: solid; border-color: #000000;
+        font-size: 8pt;
+    .Opera .CToolTip {
+        max-width: 98%;
+    /*  Scrollbars would be useless.  */
+    .CToolTip blockquote {
+        overflow: hidden;
+    .IE6 .CToolTip blockquote {
+    .CHeading {
+        font-weight: bold; font-size: 10pt;
+        margin: 1.5em 0 .5em 0;
+    .CBody pre {
+        font: 10pt "Courier New", Courier, monospace;
+        margin: 1em 0;
+    .CBody ul {
+        /*  I don't know why CBody's margin doesn't apply, but it's consistent across browsers so whatever.
+             Reapply it here as padding.  */
+        margin: .5em 5ex .5em 5ex;
+    .CDescriptionList {
+        margin: .5em 5ex 0 5ex }
+        .CDLEntry {
+            font: 10pt "Courier New", Courier, monospace; color: #808080;
+            padding-bottom: .25em;
+            white-space: nowrap }
+        .CDLDescription {
+            font-size: 10pt;  /*  For browsers that don't inherit correctly, like Opera 5.  */
+            padding-bottom: .5em; padding-left: 5ex }
+    .CTopic img {
+        display: block;
+        margin: 1em auto;
+    .CImageCaption {
+        font-size: 8pt;
+        color: #808080;
+        position: relative;
+        top: 1em;
+    .CImageLink {
+        color: #808080;
+        font-style: italic;
+    a.CImageLink:link,
+    a.CImageLink:visited,
+    a.CImageLink:hover { color: #808080 }
+.Prototype {
+    padding: 5px 3ex;
+    border-width: 1px; border-style: solid;
+    margin: 0 5ex 1.5em 5ex;
+    .Prototype td {
+        font-size: 10pt;
+    .PDefaultValue,
+    .PDefaultValuePrefix,
+    .PTypePrefix {
+        color: #8F8F8F;
+    .PTypePrefix {
+        text-align: right;
+    .PAfterParameters {
+        vertical-align: bottom;
+    .IE .Prototype table {
+        padding: 0;
+    .CFunction .Prototype {
+        background-color: #F4F4F4; border-color: #D0D0D0 }
+    .CProperty .Prototype {
+        background-color: #F4F4FF; border-color: #C0C0E8 }
+    .CVariable .Prototype {
+        background-color: #FFFFF0; border-color: #E0E0A0 }
+    .CClass .Prototype {
+        border-width: 1px 2px 2px 1px; border-style: solid; border-color: #A0A0A0;
+    .CInterface .Prototype {
+        border-width: 1px 2px 2px 1px; border-style: solid; border-color: #A0A0D0;
+    .CDatabaseIndex .Prototype,
+    .CConstant .Prototype {
+        background-color: #D0D0D0; border-color: #000000 }
+    .CType .Prototype,
+    .CEnumeration .Prototype {
+        background-color: #FAF0F0; border-color: #E0B0B0;
+    .CDatabaseTrigger .Prototype,
+    .CEvent .Prototype,
+    .CDelegate .Prototype {
+        background-color: #F0FCF0; border-color: #B8E4B8 }
+    .CToolTip .Prototype {
+        margin: 0 0 .5em 0;
+        white-space: nowrap;
+.Summary {
+    margin: 1.5em 5ex 0 5ex }
+    .STitle {
+        margin-bottom: .5em }
+    .SBorder {
+        padding: 15px;
+        border: 1px solid #C0C060 }
+    /* In a frame IE 6 will make them too long unless you set the width to 100%.  Without frames it will be correct without a width
+        or slightly too long (but not enough to scroll) with a width.  This arbitrary weirdness simply astounds me.  IE 7 has the same
+        problem with frames, haven't tested it without.  */
+    .FramedContentPage .IE .SBorder {
+        width: 100% }
+    .Firefox .SBorder {
+        -moz-border-radius: 20px }
+    .STable {
+        font-size: 9pt; width: 100% }
+    .SEntry {
+        width: 30% }
+    .SDescription {
+        width: 70% }
+    .SMarked {
+        background-color: #F8F8D8 }
+    .SDescription { padding-left: 2ex }
+    .SIndent1 .SEntry { padding-left: 1.5ex }   .SIndent1 .SDescription { padding-left: 3.5ex }
+    .SIndent2 .SEntry { padding-left: 3.0ex }   .SIndent2 .SDescription { padding-left: 5.0ex }
+    .SIndent3 .SEntry { padding-left: 4.5ex }   .SIndent3 .SDescription { padding-left: 6.5ex }
+    .SIndent4 .SEntry { padding-left: 6.0ex }   .SIndent4 .SDescription { padding-left: 8.0ex }
+    .SIndent5 .SEntry { padding-left: 7.5ex }   .SIndent5 .SDescription { padding-left: 9.5ex }
+    .SDescription a { color: #800000}
+    .SDescription a:active { color: #A00000 }
+    .SGroup td {
+        padding-top: .5em; padding-bottom: .25em }
+    .SGroup .SEntry {
+        font-weight: bold; font-variant: small-caps }
+    .SGroup .SEntry a { color: #800000 }
+    .SGroup .SEntry a:active { color: #F00000 }
+    .SMain td,
+    .SClass td,
+    .SDatabase td,
+    .SDatabaseTable td,
+    .SSection td {
+        font-size: 10pt;
+        padding-bottom: .25em }
+    .SClass td,
+    .SDatabase td,
+    .SSection td {
+        padding-top: 1em }
+    .SMain .SEntry,
+    .SClass .SEntry,
+    .SDatabase .SEntry,
+    .SDatabaseTable .SEntry,
+    .SSection .SEntry {
+    .SMain .SEntry a,
+    .SClass .SEntry a,
+    .SDatabase .SEntry a,
+    .SDatabaseTable .SEntry a,
+    .SSection .SEntry a { color: #000000 }
+    .SMain .SEntry a:active,
+    .SClass .SEntry a:active,
+    .SDatabase .SEntry a:active,
+    .SDatabaseTable .SEntry a:active,
+    .SSection .SEntry a:active { color: #A00000 }
+.ClassHierarchy {
+    margin: 0 15px 1em 15px }
+    .CHEntry {
+        margin-bottom: 3px;
+        padding: 2px 2ex;
+        font-size: 10pt;
+        background-color: #F4F4F4; color: #606060;
+    .Firefox .CHEntry {
+        -moz-border-radius: 4px;
+    .CHCurrent .CHEntry {
+        color: #000000;
+    .CHChildNote .CHEntry {
+        font-size: 8pt;
+    .CHIndent {
+        margin-left: 3ex;
+    .CHEntry a:link,
+    .CHEntry a:visited,
+    .CHEntry a:hover {
+        color: #606060;
+    .CHEntry a:active {
+        color: #800000;
+#Index {
+/*  As opposed to .PopupSearchResultsPage #Index  */
+.IndexPage #Index,
+.FramedIndexPage #Index,
+.FramedSearchResultsPage #Index {
+    padding: 15px;
+.IndexPage #Index {
+    font-size: 9pt;  /* To make 27ex match the menu's 27ex. */
+    .IPageTitle {
+        font-size: 20pt; font-weight: bold;
+        border-width: 0 0 3px 0; border-color: #000000; border-style: solid;
+        margin: -15px -15px 0 -15px }
+    .FramedSearchResultsPage .IPageTitle {
+        margin-bottom: 15px;
+    .INavigationBar {
+        font-size: 10pt;
+        padding: 5px;
+        border-bottom: solid 1px black;
+        margin: 0 -15px 15px -15px;
+    .INavigationBar a {
+        font-weight: bold }
+    .IHeading {
+        padding: 2.5em 0 .5em 0;
+        width: 3.5ex;
+    #IFirstHeading {
+        padding-top: 0;
+    .IEntry {
+        font-size: 10pt;
+        padding-left: 1ex;
+    .PopupSearchResultsPage .IEntry {
+        font-size: 8pt;
+        padding: 1px 5px;
+    .PopupSearchResultsPage .Opera9 .IEntry,
+    .FramedSearchResultsPage .Opera9 .IEntry {
+        text-align: left;
+    .FramedSearchResultsPage .IEntry {
+        padding: 0;
+    .ISubIndex {
+        padding-left: 3ex; padding-bottom: .5em }
+    .PopupSearchResultsPage .ISubIndex {
+        display: none;
+    /*  While it may cause some entries to look like links when they aren't, I found it's much easier to read the
+         index if everything's the same color.  */
+    .ISymbol {
+        font-weight: bold; color: #900000  }
+    .IndexPage .ISymbolPrefix,
+    .FramedIndexPage .ISymbolPrefix {
+        font-size: 10pt;
+        color: #C47C7C;
+        background-color: #F8F8F8;
+        border-right: 3px solid #E0E0E0;
+        border-left: 1px solid #E0E0E0;
+        padding: 0 1px 0 2px;
+    .PopupSearchResultsPage .ISymbolPrefix,
+    .FramedSearchResultsPage .ISymbolPrefix {
+        color: #900000;
+    .PopupSearchResultsPage .ISymbolPrefix {
+        font-size: 8pt;
+    .IndexPage #IFirstSymbolPrefix,
+    .FramedIndexPage #IFirstSymbolPrefix {
+        border-top: 1px solid #E0E0E0;
+    .IndexPage #ILastSymbolPrefix,
+    .FramedIndexPage #ILastSymbolPrefix {
+        border-bottom: 1px solid #E0E0E0;
+    .IndexPage #IOnlySymbolPrefix,
+    .FramedIndexPage #IOnlySymbolPrefix {
+    a.IParent,
+    a.IFile {
+        display: block;
+    .PopupSearchResultsPage .SRStatus {
+        padding: 2px 5px;
+        font-size: 8pt;
+    .FramedSearchResultsPage .SRStatus {
+        font-size: 10pt;
+    .SRResult {
+        display: none;
+#Footer {
+    font-size: 8pt;
+    color: #989898;
+#Footer p {
+    text-indent: 0;
+    margin-bottom: .5em;
+.ContentPage #Footer,
+.IndexPage #Footer {
+    margin: 2px;
+.FramedMenuPage #Footer {
+    margin: 5em 10px 10px 10px;
+    padding-top: 1em;
+    border-top: 1px solid #C8C8C8;
+    #Footer a:link,
+    #Footer a:hover,
+    #Footer a:visited { color: #989898 }
+    #Footer a:active { color: #A00000 }
More information about the Mapbender_commits mailing list
