[Mapbender-commits] r5119 - in trunk/mapbender/documents/api_js: . Data
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Dec 11 05:49:50 EST 2009
Author: christoph
Date: 2009-12-11 05:49:49 -0500 (Fri, 11 Dec 2009)
New Revision: 5119
   trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
   trunk/mapbender/documents/api_js/Data/ConfigFileInfo.nd
   trunk/mapbender/documents/api_js/Data/IndexInfo.nd
   trunk/mapbender/documents/api_js/Data/PreviousMenuState.nd
   trunk/mapbender/documents/api_js/Data/SymbolTable.nd
   trunk/mapbender/documents/api_js/Menu.txt
   trunk/mapbender/documents/api_js/index.html
Modified: trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
(Binary files differ)
Modified: trunk/mapbender/documents/api_js/Data/ConfigFileInfo.nd
--- trunk/mapbender/documents/api_js/Data/ConfigFileInfo.nd	2009-12-11 10:48:19 UTC (rev 5118)
+++ trunk/mapbender/documents/api_js/Data/ConfigFileInfo.nd	2009-12-11 10:49:49 UTC (rev 5119)
@@ -1 +1 @@
-(   K"!—K"ÞK"!˜K"ÞK"!˜
\ No newline at end of file
+(   K"# K"ÞK"!˜K"ÞK"!˜
Modified: trunk/mapbender/documents/api_js/Data/IndexInfo.nd
--- trunk/mapbender/documents/api_js/Data/IndexInfo.nd	2009-12-11 10:48:19 UTC (rev 5118)
+++ trunk/mapbender/documents/api_js/Data/IndexInfo.nd	2009-12-11 10:49:49 UTC (rev 5119)
@@ -1 +1 @@
-(    General            Variable                  Function   File                   Constant           Database Index                            Database Table                            Class             Database Trigger                            Property
+(    General            Function   Variable                  File                   Constant           Database Index                            Database Table                            Class             Database Trigger                            Property
Modified: trunk/mapbender/documents/api_js/Data/PreviousMenuState.nd
--- trunk/mapbender/documents/api_js/Data/PreviousMenuState.nd	2009-12-11 10:48:19 UTC (rev 5118)
+++ trunk/mapbender/documents/api_js/Data/PreviousMenuState.nd	2009-12-11 10:49:49 UTC (rev 5119)
@@ -1,9 +1,11 @@
-(    	Mapbender  	Mapbender 8/home/cbaudson/workspace/trunk/http/javascripts/core.php  Map :/home/cbaudson/workspace/trunk/http/javascripts/map_obj.js modules  AddWmsFromTree E/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromTree.js
-changeEPSG A/home/cbaudson/workspace/trunk/http/javascripts/mod_changeEPSG.js  coordsLookup C/home/cbaudson/workspace/trunk/http/javascripts/mod_coordsLookup.js  doubleclickZoom F/home/cbaudson/workspace/trunk/http/javascripts/mod_doubleclickZoom.js  Log :/home/cbaudson/workspace/trunk/http/javascripts/mod_log.js  mousewheelZoom E/home/cbaudson/workspace/trunk/http/javascripts/mod_mousewheelZoom.js  Overview ?/home/cbaudson/workspace/trunk/http/javascripts/mod_overview.js  overviewToggle E/home/cbaudson/workspace/trunk/http/javascripts/mod_overviewToggle.js  Reload =/home/cbaudson/workspace/trunk/http/javascripts/mod_reload.js  repaint >/home/cbaudson/workspace/trunk/http/javascripts/mod_repaint.js  repaint ?/home/cbaudson/workspace/trunk/http/javascripts/mod_repaint.php
-ResizeMapsize E/home/cbaudson/workspace/trunk/http/javascripts/mod_resize_mapsize.js  	Sandclock @/home/cbaudson/workspace/trunk/http/javascripts/mod_sandclock.js  savewmc >/home/cbaudson/workspace/trunk/http/javascripts/mod_savewmc.js  scalebar ?/home/cbaudson/workspace/trunk/http/javascripts/mod_scalebar.js  selArea >/home/cbaudson/workspace/trunk/http/javascripts/mod_selArea.js  selArea :/home/cbaudson/workspace/trunk/http/javascripts/mod_pan.js  zoomFull ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomFull.js  ZoomIn1 >/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomIn1.js  ZoomOut1 ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomOut1.js  Lib  Ajax */home/cbaudson/workspace/trunk/lib/ajax.js  Event +/home/cbaudson/workspace/trunk/lib/event.js  	Exception //home/cbaudson/workspace/trunk/lib/exception.js  Extent ,/home/cbaudson/workspace/trunk/lib/extent.js  resultGeometryListController.js B/home/cbaudson/workspace/trunk/lib/resultGeometryListController.js  ResultGeometryListModel =/home/cbaudson/workspace/trunk/lib/resultGeometryListModel.js    5pgsql/.../update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql c/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql  sql_updates_monitoring.sql F/home/cbaudson/workspace/trunk/resources/db/sql_updates_monitoring.sql Http
-Extensions DataTables-1.5 Extras  FixedHeader.js _/home/cbaudson/workspace/trunk/http/extensions/dataTables-1.5/extras/FixedHeader/FixedHeader.js  jquery.dataTables.min.js v/home/cbaudson/workspace/trunk/http/extensions/dataTables-1.5/extras/TableTools/media/support/jquery.dataTables.min.js
+(    Http DataTables-1.5 Extras  FixedHeader.js _/home/cbaudson/workspace/trunk/http/extensions/dataTables-1.5/extras/FixedHeader/FixedHeader.js  jquery.dataTables.min.js v/home/cbaudson/workspace/trunk/http/extensions/dataTables-1.5/extras/TableTools/media/support/jquery.dataTables.min.js
 TableTools.js f/home/cbaudson/workspace/trunk/http/extensions/dataTables-1.5/extras/TableTools/media/js/TableTools.js
-ZeroClipboard t/home/cbaudson/workspace/trunk/http/extensions/dataTables-1.5/extras/TableTools/media/ZeroClipboard/ZeroClipboard.as  Media  jquery.dataTables.js [/home/cbaudson/workspace/trunk/http/extensions/dataTables-1.5/media/js/jquery.dataTables.js  jquery.dataTables.min.js _/home/cbaudson/workspace/trunk/http/extensions/dataTables-1.5/media/js/jquery.dataTables.min.js  js/jquery.js P/home/cbaudson/workspace/trunk/http/extensions/dataTables-1.5/media/js/jquery.js  unit_test.js ]/home/cbaudson/workspace/trunk/http/extensions/dataTables-1.5/media/unit_testing/unit_test.js    jquery-1.3.2.js h/home/cbaudson/workspace/trunk/http/extensions/jquery-ui-1.7.2.custom/development-bundle/jquery-1.3.2.js proj4js OpenLayers-2.8
+ZeroClipboard t/home/cbaudson/workspace/trunk/http/extensions/dataTables-1.5/extras/TableTools/media/ZeroClipboard/ZeroClipboard.as  Media  jquery.dataTables.js [/home/cbaudson/workspace/trunk/http/extensions/dataTables-1.5/media/js/jquery.dataTables.js  jquery.dataTables.min.js _/home/cbaudson/workspace/trunk/http/extensions/dataTables-1.5/media/js/jquery.dataTables.min.js  js/jquery.js P/home/cbaudson/workspace/trunk/http/extensions/dataTables-1.5/media/js/jquery.js  unit_test.js ]/home/cbaudson/workspace/trunk/http/extensions/dataTables-1.5/media/unit_testing/unit_test.js    9jquery-ui-1.7.2.custom/development-bundle/jquery-1.3.2.js h/home/cbaudson/workspace/trunk/http/extensions/jquery-ui-1.7.2.custom/development-bundle/jquery-1.3.2.js 	Mapbender  	Mapbender 8/home/cbaudson/workspace/trunk/http/javascripts/core.php  Map :/home/cbaudson/workspace/trunk/http/javascripts/map_obj.js modules  AddWmsFromTree E/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromTree.js
+changeEPSG A/home/cbaudson/workspace/trunk/http/javascripts/mod_changeEPSG.js  coordsLookup C/home/cbaudson/workspace/trunk/http/javascripts/mod_coordsLookup.js  doubleclickZoom F/home/cbaudson/workspace/trunk/http/javascripts/mod_doubleclickZoom.js  Log :/home/cbaudson/workspace/trunk/http/javascripts/mod_log.js  mousewheelZoom E/home/cbaudson/workspace/trunk/http/javascripts/mod_mousewheelZoom.js  Overview ?/home/cbaudson/workspace/trunk/http/javascripts/mod_overview.js  overviewToggle E/home/cbaudson/workspace/trunk/http/javascripts/mod_overviewToggle.js  Reload =/home/cbaudson/workspace/trunk/http/javascripts/mod_reload.js  repaint >/home/cbaudson/workspace/trunk/http/javascripts/mod_repaint.js  repaint ?/home/cbaudson/workspace/trunk/http/javascripts/mod_repaint.php
+ResizeMapsize E/home/cbaudson/workspace/trunk/http/javascripts/mod_resize_mapsize.js  	Sandclock @/home/cbaudson/workspace/trunk/http/javascripts/mod_sandclock.js  savewmc >/home/cbaudson/workspace/trunk/http/javascripts/mod_savewmc.js  scalebar ?/home/cbaudson/workspace/trunk/http/javascripts/mod_scalebar.js  selArea >/home/cbaudson/workspace/trunk/http/javascripts/mod_selArea.js  selArea :/home/cbaudson/workspace/trunk/http/javascripts/mod_pan.js  zoomFull ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomFull.js  ZoomIn1 >/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomIn1.js  ZoomOut1 ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomOut1.js  cookie 8/home/cbaudson/workspace/trunk/http/plugins/mb_cookie.js  i18n 6/home/cbaudson/workspace/trunk/http/plugins/mb_i18n.js
+jq_datatables </home/cbaudson/workspace/trunk/http/plugins/jq_datatables.js  jq_ui_accordion >/home/cbaudson/workspace/trunk/http/plugins/jq_ui_accordion.js  	mb_zoomIn 8/home/cbaudson/workspace/trunk/http/plugins/mb_zoomIn.js
+mb_zoomOut 9/home/cbaudson/workspace/trunk/http/plugins/mb_zoomOut.js
+selectMapsize ?/home/cbaudson/workspace/trunk/http/plugins/mb_selectMapsize.js  wmsTimeInterval A/home/cbaudson/workspace/trunk/http/plugins/mb_wmsTimeInterval.js  wmsTimeSliderYear C/home/cbaudson/workspace/trunk/http/plugins/mb_wmsTimeSliderYear.js  Lib  Ajax */home/cbaudson/workspace/trunk/lib/ajax.js  Event +/home/cbaudson/workspace/trunk/lib/event.js  	Exception //home/cbaudson/workspace/trunk/lib/exception.js  Extent ,/home/cbaudson/workspace/trunk/lib/extent.js  resultGeometryListController.js B/home/cbaudson/workspace/trunk/lib/resultGeometryListController.js  ResultGeometryListModel =/home/cbaudson/workspace/trunk/lib/resultGeometryListModel.js   OpenLayers-2.8
 OpenLayers O/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers.js
 OpenLayers  Ajax.js T/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Ajax.js 	BaseTypes  Bounds `/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/BaseTypes/Bounds.js  Class.js _/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/BaseTypes/Class.js  Element a/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/BaseTypes/Element.js  LonLat `/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/BaseTypes/LonLat.js  Pixel _/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/BaseTypes/Pixel.js  Size ^/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/BaseTypes/Size.js  Control  	ArgParser a/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/ArgParser.js  Attribution c/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/Attribution.js  Button ^/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/Button.js  DragFeature c/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/DragFeature.js  DragPan _/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/DragPan.js  DrawFeature c/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/DrawFeature.js  EditingToolbar f/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/EditingToolbar.js
 GetFeature b/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/GetFeature.js  KeyboardDefaults h/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/KeyboardDefaults.js
@@ -40,10 +42,7 @@
 Lang["zh-CN"] Z/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Lang/zh-CN.js
 Lang["zh-TW"] Z/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Lang/zh-TW.js  Layer  ArcGIS93Rest b/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/ArcGIS93Rest.js  ArcIMS \/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/ArcIMS.js  Boxes [/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Boxes.js  	EventPane _/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/EventPane.js  FixedZoomLevels e/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/FixedZoomLevels.js  GeoRSS \/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/GeoRSS.js  GML Y/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/GML.js  Google \/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Google.js  Grid Z/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Grid.js  HTTPRequest a/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/HTTPRequest.js  Image [/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Image.js  KaMap [/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/KaMap.js
 KaMapCache `/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/KaMapCache.js  MapGuide ^/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/MapGuide.js  	MapServer _/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/MapServer.js  MapServer.Untiled g/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/MapServer/Untiled.js  Markers ]/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Markers.js  MultiMap ^/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/MultiMap.js
-PointTrack `/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/PointTrack.js  SphericalMercator g/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/SphericalMercator.js  Text Z/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Text.js  	TileCache _/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/TileCache.js  TMS Y/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/TMS.js  Vector \/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Vector.js  Vector.RootContainer j/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Vector/RootContainer.js  VirtualEarth b/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/VirtualEarth.js  WFS Y/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/WFS.js  WMS Y/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/WMS.js  WMS.Untiled a/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/WMS/Untiled.js  	WorldWind _/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/WorldWind.js  XYZ Y/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/XYZ.js  Yahoo [/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Yahoo.js   OpenLayers Base Types Y/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/BaseTypes.js  OpenLayers.Console W/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Console.js  OpenLayers.Control W/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Control.js  OpenLayers.Event V/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Events.js  OpenLayers.Feature W/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Feature.js  OpenLayers.Feature.Vector ^/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Feature/Vector.js  OpenLayers.Feature.WFS [/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Feature/WFS.js  OpenLayers.Filter V/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Filter.js  OpenLayers.Format V/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Format.js  OpenLayers.Geometry X/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Geometry.js  OpenLayers.Handler W/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Handler.js  OpenLayers.Icon T/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Icon.js  OpenLayers.Lang T/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Lang.js  OpenLayers.Layer U/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer.js  OpenLayers.Map S/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Map.js  OpenLayers.Marker V/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Marker.js  OpenLayers.Marker.Box Z/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Marker/Box.js  OpenLayers.Popup U/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Popup.js  OpenLayers.Projection Z/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Projection.js  OpenLayers.Protocol X/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol.js  OpenLayers.Renderer X/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Renderer.js  OpenLayers.Request W/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Request.js  !OpenLayers.Request.XMLHttpRequest f/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Request/XMLHttpRequest.js  OpenLayers.Rule T/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Rule.js  OpenLayers.Strategy X/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Strategy.js  OpenLayers.Style U/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Style.js  OpenLayers.StyleMap X/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/StyleMap.js  OpenLayers.Tile T/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Tile.js  OpenLayers.Tile.Image Z/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Tile/Image.js  OpenLayers.Tile.WFS X/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Tile/WFS.js  OpenLayers.Tween U/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Tween.js Popup  Anchored ^/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Popup/Anchored.js  AnchoredBubble d/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Popup/AnchoredBubble.js  Framed \/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Popup/Framed.js  FramedCloud a/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Popup/FramedCloud.js  Protocol  HTTP ]/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol/HTTP.js  SQL \/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol/SQL.js  	SQL.Gears b/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol/SQL/Gears.js WFS  v1 _/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol/WFS/v1.js  v1_0_0 c/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol/WFS/v1_0_0.js  v1_1_0 c/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol/WFS/v1_1_0.js   WFS.js \/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol/WFS.js  Renderer  ElementsIndexer a/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Renderer/Elements.js  Renderer.Canvas _/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Renderer/Canvas.js  Renderer.SVG \/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Renderer/SVG.js  Renderer.VML \/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Renderer/VML.js  Strategy  BBOX ]/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Strategy/BBOX.js  Cluster `/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Strategy/Cluster.js  Fixed ^/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Strategy/Fixed.js  Paging _/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Strategy/Paging.js  Save ]/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Strategy/Save.js   Util T/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Util.js    Proj4js N/home/cbaudson/workspace/trunk/http/extensions/proj4js/lib/proj4js-combined.js  Proj4js E/home/cbaudson/workspace/trunk/http/extensions/proj4js/lib/proj4js.js   Plugins  cookie 8/home/cbaudson/workspace/trunk/http/plugins/mb_cookie.js  i18n 6/home/cbaudson/workspace/trunk/http/plugins/mb_i18n.js
-jq_datatables </home/cbaudson/workspace/trunk/http/plugins/jq_datatables.js  jq_ui_accordion >/home/cbaudson/workspace/trunk/http/plugins/jq_ui_accordion.js  	mb_zoomIn 8/home/cbaudson/workspace/trunk/http/plugins/mb_zoomIn.js
-mb_zoomOut 9/home/cbaudson/workspace/trunk/http/plugins/mb_zoomOut.js
-selectMapsize ?/home/cbaudson/workspace/trunk/http/plugins/mb_selectMapsize.js  wmsTimeInterval A/home/cbaudson/workspace/trunk/http/plugins/mb_wmsTimeInterval.js  wmsTimeSliderYear C/home/cbaudson/workspace/trunk/http/plugins/mb_wmsTimeSliderYear.js   Index
+PointTrack `/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/PointTrack.js  SphericalMercator g/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/SphericalMercator.js  Text Z/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Text.js  	TileCache _/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/TileCache.js  TMS Y/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/TMS.js  Vector \/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Vector.js  Vector.RootContainer j/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Vector/RootContainer.js  VirtualEarth b/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/VirtualEarth.js  WFS Y/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/WFS.js  WMS Y/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/WMS.js  WMS.Untiled a/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/WMS/Untiled.js  	WorldWind _/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/WorldWind.js  XYZ Y/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/XYZ.js  Yahoo [/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Yahoo.js   OpenLayers Base Types Y/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/BaseTypes.js  OpenLayers.Console W/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Console.js  OpenLayers.Control W/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Control.js  OpenLayers.Event V/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Events.js  OpenLayers.Feature W/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Feature.js  OpenLayers.Feature.Vector ^/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Feature/Vector.js  OpenLayers.Feature.WFS [/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Feature/WFS.js  OpenLayers.Filter V/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Filter.js  OpenLayers.Format V/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Format.js  OpenLayers.Geometry X/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Geometry.js  OpenLayers.Handler W/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Handler.js  OpenLayers.Icon T/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Icon.js  OpenLayers.Lang T/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Lang.js  OpenLayers.Layer U/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer.js  OpenLayers.Map S/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Map.js  OpenLayers.Marker V/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Marker.js  OpenLayers.Marker.Box Z/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Marker/Box.js  OpenLayers.Popup U/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Popup.js  OpenLayers.Projection Z/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Projection.js  OpenLayers.Protocol X/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol.js  OpenLayers.Renderer X/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Renderer.js  OpenLayers.Request W/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Request.js  !OpenLayers.Request.XMLHttpRequest f/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Request/XMLHttpRequest.js  OpenLayers.Rule T/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Rule.js  OpenLayers.Strategy X/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Strategy.js  OpenLayers.Style U/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Style.js  OpenLayers.StyleMap X/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/StyleMap.js  OpenLayers.Tile T/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Tile.js  OpenLayers.Tile.Image Z/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Tile/Image.js  OpenLayers.Tile.WFS X/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Tile/WFS.js  OpenLayers.Tween U/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Tween.js Popup  Anchored ^/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Popup/Anchored.js  AnchoredBubble d/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Popup/AnchoredBubble.js  Framed \/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Popup/Framed.js  FramedCloud a/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Popup/FramedCloud.js  Protocol  HTTP ]/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol/HTTP.js  SQL \/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol/SQL.js  	SQL.Gears b/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol/SQL/Gears.js WFS  v1 _/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol/WFS/v1.js  v1_0_0 c/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol/WFS/v1_0_0.js  v1_1_0 c/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol/WFS/v1_1_0.js   WFS.js \/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol/WFS.js  Renderer  ElementsIndexer a/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Renderer/Elements.js  Renderer.Canvas _/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Renderer/Canvas.js  Renderer.SVG \/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Renderer/SVG.js  Renderer.VML \/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Renderer/VML.js  Strategy  BBOX ]/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Strategy/BBOX.js  Cluster `/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Strategy/Cluster.js  Fixed ^/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Strategy/Fixed.js  Paging _/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Strategy/Paging.js  Save ]/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Strategy/Save.js   Util T/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Util.js    Proj4js N/home/cbaudson/workspace/trunk/http/extensions/proj4js/lib/proj4js-combined.js  Proj4js E/home/cbaudson/workspace/trunk/http/extensions/proj4js/lib/proj4js.js   5pgsql/.../update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql c/home/cbaudson/workspace/trunk/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql  sql_updates_monitoring.sql F/home/cbaudson/workspace/trunk/resources/db/sql_updates_monitoring.sql Index
 Everything general Classes class 	Functions function
 Properties property Database Indexes
 databaseindex Database Tables
Modified: trunk/mapbender/documents/api_js/Data/SymbolTable.nd
--- trunk/mapbender/documents/api_js/Data/SymbolTable.nd	2009-12-11 10:48:19 UTC (rev 5118)
+++ trunk/mapbender/documents/api_js/Data/SymbolTable.nd	2009-12-11 10:49:49 UTC (rev 5119)
@@ -5,10 +5,10 @@
 OpenLayers Strategy Cluster
 clustering  `/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Strategy/Cluster.js property   8{Boolean} The strategy is currently clustering features.
 OpenLayers Control Attribution 	Functions  c/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/Attribution.js group
-OpenLayers Feature WFS 	Functions  [/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Feature/WFS.js group
-OpenLayers Format Filter v1_0_0 	Constants  d/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/Filter/v1_0_0.js group
+OpenLayers Feature WFS 	Functions  [/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Feature/WFS.js group
 OpenLayers Format WFSCapabilities v1
-OpenLayers Format WFSCapabilities v1_1  i/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WFSCapabilities/v1.js function   ,Create an instance of one of the subclasses.
+OpenLayers Format WFSCapabilities v1_1  i/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WFSCapabilities/v1.js function   ,Create an instance of one of the subclasses.
+OpenLayers Format Filter v1_0_0 	Constants  d/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/Filter/v1_0_0.js group
 OpenLayers Renderer
 OpenLayers Renderer  X/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Renderer.js function
 OpenLayers Tile Image
@@ -3480,15 +3480,15 @@
 OpenLayers Format XML
 JavaScript
 OpenLayers Format WMSDescribeLayer  g/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WMSDescribeLayer.js
+OpenLayers Geometry
+JavaScript
+LineString  c/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Geometry/LineString.js
 OpenLayers Protocol
 JavaScript
 OpenLayers Control
-GetFeature  b/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/GetFeature.js
-OpenLayers Geometry
+GetFeature  b/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/GetFeature.js Control Panel
 JavaScript
-LineString  c/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Geometry/LineString.js Control Panel
-JavaScript
 OpenLayers Control Pan  [/home/cbaudson/workspace/trunk/http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/Pan.js
 OpenLayers Filter
 JavaScript
Modified: trunk/mapbender/documents/api_js/Menu.txt
--- trunk/mapbender/documents/api_js/Menu.txt	2009-12-11 10:48:19 UTC (rev 5118)
+++ trunk/mapbender/documents/api_js/Menu.txt	2009-12-11 10:49:49 UTC (rev 5119)
@@ -46,56 +46,392 @@
-Group: Mapbender  {
+Group: Http  {
-   File: Mapbender  (http/javascripts/core.php)
-   File: Map  (http/javascripts/map_obj.js)
+   Group: DataTables-1.5  {
-   Group: modules  {
+      Group: Extras  {
-      File: AddWmsFromTree  (http/javascripts/mod_addWMSfromTree.js)
-      File: changeEPSG  (http/javascripts/mod_changeEPSG.js)
-      File: coordsLookup  (http/javascripts/mod_coordsLookup.js)
-      File: doubleclickZoom  (http/javascripts/mod_doubleclickZoom.js)
-      File: Log  (http/javascripts/mod_log.js)
-      File: mousewheelZoom  (http/javascripts/mod_mousewheelZoom.js)
-      File: Overview  (http/javascripts/mod_overview.js)
-      File: overviewToggle  (http/javascripts/mod_overviewToggle.js)
-      File: Reload  (http/javascripts/mod_reload.js)
-      File: repaint  (http/javascripts/mod_repaint.js)
-      File: repaint  (http/javascripts/mod_repaint.php)
-      File: ResizeMapsize  (http/javascripts/mod_resize_mapsize.js)
-      File: Sandclock  (http/javascripts/mod_sandclock.js)
-      File: savewmc  (http/javascripts/mod_savewmc.js)
-      File: scalebar  (http/javascripts/mod_scalebar.js)
-      File: selArea  (http/javascripts/mod_selArea.js)
-      File: selArea  (http/javascripts/mod_pan.js)
-      File: zoomFull  (http/javascripts/mod_zoomFull.js)
-      File: ZoomIn1  (http/javascripts/mod_zoomIn1.js)
-      File: ZoomOut1  (http/javascripts/mod_zoomOut1.js)
-      File: cookie  (http/plugins/mb_cookie.js)
-      File: i18n  (http/plugins/mb_i18n.js)
-      File: jq_datatables  (http/plugins/jq_datatables.js)
-      File: jq_ui_accordion  (http/plugins/jq_ui_accordion.js)
-      File: mb_zoomIn  (http/plugins/mb_zoomIn.js)
-      File: mb_zoomOut  (http/plugins/mb_zoomOut.js)
-      File: selectMapsize  (http/plugins/mb_selectMapsize.js)
-      File: wmsTimeInterval  (http/plugins/mb_wmsTimeInterval.js)
-      File: wmsTimeSliderYear  (http/plugins/mb_wmsTimeSliderYear.js)
-      }  # Group: modules
+         File: FixedHeader.js  (http/extensions/dataTables-1.5/extras/FixedHeader/FixedHeader.js)
+         File: jquery.dataTables.min.js  (http/extensions/dataTables-1.5/extras/TableTools/media/support/jquery.dataTables.min.js)
+         File: TableTools.js  (http/extensions/dataTables-1.5/extras/TableTools/media/js/TableTools.js)
+         File: ZeroClipboard  (http/extensions/dataTables-1.5/extras/TableTools/media/ZeroClipboard/ZeroClipboard.as)
+         }  # Group: Extras
-   Group: Lib  {
+      Group: Media  {
-      File: Ajax  (lib/ajax.js)
-      File: Event  (lib/event.js)
-      File: Exception  (lib/exception.js)
-      File: Extent  (lib/extent.js)
-      File: resultGeometryListController.js  (lib/resultGeometryListController.js)
-      File: ResultGeometryListModel  (lib/resultGeometryListModel.js)
-      }  # Group: Lib
+         File: jquery.dataTables.js  (http/extensions/dataTables-1.5/media/js/jquery.dataTables.js)
+         File: jquery.dataTables.min.js  (http/extensions/dataTables-1.5/media/js/jquery.dataTables.min.js)
+         File: js/jquery.js  (http/extensions/dataTables-1.5/media/js/jquery.js)
+         File: unit_test.js  (http/extensions/dataTables-1.5/media/unit_testing/unit_test.js)
+         }  # Group: Media
-   }  # Group: Mapbender
+      }  # Group: DataTables-1.5
+   File: jquery-ui-1.7.2.custom/development-bundle/jquery-1.3.2.js  (http/extensions/jquery-ui-1.7.2.custom/development-bundle/jquery-1.3.2.js)
+   Group: Mapbender  {
+      File: Mapbender  (http/javascripts/core.php)
+      File: Map  (http/javascripts/map_obj.js)
+      Group: modules  {
+         File: AddWmsFromTree  (http/javascripts/mod_addWMSfromTree.js)
+         File: changeEPSG  (http/javascripts/mod_changeEPSG.js)
+         File: coordsLookup  (http/javascripts/mod_coordsLookup.js)
+         File: doubleclickZoom  (http/javascripts/mod_doubleclickZoom.js)
+         File: Log  (http/javascripts/mod_log.js)
+         File: mousewheelZoom  (http/javascripts/mod_mousewheelZoom.js)
+         File: Overview  (http/javascripts/mod_overview.js)
+         File: overviewToggle  (http/javascripts/mod_overviewToggle.js)
+         File: Reload  (http/javascripts/mod_reload.js)
+         File: repaint  (http/javascripts/mod_repaint.js)
+         File: repaint  (http/javascripts/mod_repaint.php)
+         File: ResizeMapsize  (http/javascripts/mod_resize_mapsize.js)
+         File: Sandclock  (http/javascripts/mod_sandclock.js)
+         File: savewmc  (http/javascripts/mod_savewmc.js)
+         File: scalebar  (http/javascripts/mod_scalebar.js)
+         File: selArea  (http/javascripts/mod_selArea.js)
+         File: selArea  (http/javascripts/mod_pan.js)
+         File: zoomFull  (http/javascripts/mod_zoomFull.js)
+         File: ZoomIn1  (http/javascripts/mod_zoomIn1.js)
+         File: ZoomOut1  (http/javascripts/mod_zoomOut1.js)
+         File: cookie  (http/plugins/mb_cookie.js)
+         File: i18n  (http/plugins/mb_i18n.js)
+         File: jq_datatables  (http/plugins/jq_datatables.js)
+         File: jq_ui_accordion  (http/plugins/jq_ui_accordion.js)
+         File: mb_zoomIn  (http/plugins/mb_zoomIn.js)
+         File: mb_zoomOut  (http/plugins/mb_zoomOut.js)
+         File: selectMapsize  (http/plugins/mb_selectMapsize.js)
+         File: wmsTimeInterval  (http/plugins/mb_wmsTimeInterval.js)
+         File: wmsTimeSliderYear  (http/plugins/mb_wmsTimeSliderYear.js)
+         }  # Group: modules
+      Group: Lib  {
+         File: Ajax  (lib/ajax.js)
+         File: Event  (lib/event.js)
+         File: Exception  (lib/exception.js)
+         File: Extent  (lib/extent.js)
+         File: resultGeometryListController.js  (lib/resultGeometryListController.js)
+         File: ResultGeometryListModel  (lib/resultGeometryListModel.js)
+         }  # Group: Lib
+      }  # Group: Mapbender
+   Group: OpenLayers-2.8  {
+      File: OpenLayers  (http/extensions/OpenLayers-2.8/lib/OpenLayers.js)
+      Group: OpenLayers  {
+         File: Ajax.js  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Ajax.js)
+         Group: BaseTypes  {
+            File: Bounds  (http/extensions/OpenLayers-2.8/lib/OpenLayers/BaseTypes/Bounds.js)
+            File: Class.js  (http/extensions/OpenLayers-2.8/lib/OpenLayers/BaseTypes/Class.js)
+            File: Element  (http/extensions/OpenLayers-2.8/lib/OpenLayers/BaseTypes/Element.js)
+            File: LonLat  (http/extensions/OpenLayers-2.8/lib/OpenLayers/BaseTypes/LonLat.js)
+            File: Pixel  (http/extensions/OpenLayers-2.8/lib/OpenLayers/BaseTypes/Pixel.js)
+            File: Size  (http/extensions/OpenLayers-2.8/lib/OpenLayers/BaseTypes/Size.js)
+            }  # Group: BaseTypes
+         Group: Control  {
+            File: ArgParser  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/ArgParser.js)
+            File: Attribution  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/Attribution.js)
+            File: Button  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/Button.js)
+            File: DragFeature  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/DragFeature.js)
+            File: DragPan  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/DragPan.js)
+            File: DrawFeature  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/DrawFeature.js)
+            File: EditingToolbar  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/EditingToolbar.js)
+            File: GetFeature  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/GetFeature.js)
+            File: KeyboardDefaults  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/KeyboardDefaults.js)
+            File: LayerSwitcher  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/LayerSwitcher.js)
+            File: Measure  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/Measure.js)
+            File: ModifyFeature  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/ModifyFeature.js)
+            File: MouseDefaults  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/MouseDefaults.js)
+            File: MousePosition  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/MousePosition.js)
+            File: MouseToolbar  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/MouseToolbar.js)
+            File: Navigation  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/Navigation.js)
+            File: NavigationHistory  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/NavigationHistory.js)
+            File: NavToolbar  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/NavToolbar.js)
+            File: OverviewMap  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/OverviewMap.js)
+            File: Pan  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/Pan.js)
+            File: Panel  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/Panel.js)
+            File: PanPanel  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/PanPanel.js)
+            File: PanZoom  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/PanZoom.js)
+            File: PanZoomBar  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/PanZoomBar.js)
+            File: Permalink  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/Permalink.js)
+            File: Scale  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/Scale.js)
+            File: ScaleLine  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/ScaleLine.js)
+            File: SelectFeature  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/SelectFeature.js)
+            File: Snapping  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/Snapping.js)
+            File: Split  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/Split.js)
+            File: WMSGetFeatureInfo  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/WMSGetFeatureInfo.js)
+            File: ZoomBox  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/ZoomBox.js)
+            File: ZoomIn  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/ZoomIn.js)
+            File: ZoomOut  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/ZoomOut.js)
+            File: ZoomPanel  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/ZoomPanel.js)
+            File: ZoomToMaxExtent  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control/ZoomToMaxExtent.js)
+            }  # Group: Control
+         Group: Filter  {
+            File: Comparison  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Filter/Comparison.js)
+            File: FeatureId  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Filter/FeatureId.js)
+            File: Logical  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Filter/Logical.js)
+            File: Spatial  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Filter/Spatial.js)
+            }  # Group: Filter
+         Group: Format  {
+            File: ArcXML  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/ArcXML.js)
+            File: ArcXML.Features  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/ArcXML/Features.js)
+            File: Filter  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/Filter.js)
+            Group: Filter  {
+               File: v1  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/Filter/v1.js)
+               File: v1_0_0  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/Filter/v1_0_0.js)
+               File: v1_1_0  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/Filter/v1_1_0.js)
+               }  # Group: Filter
+            File: GeoJSON  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/GeoJSON.js)
+            File: GeoRSS  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/GeoRSS.js)
+            File: GML  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/GML.js)
+            Group: GML  {
+               File: Base  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/GML/Base.js)
+               File: v2  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/GML/v2.js)
+               File: v3  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/GML/v3.js)
+               }  # Group: GML
+            File: GPX  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/GPX.js)
+            File: JSON  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/JSON.js)
+            File: KML  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/KML.js)
+            File: OSM  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/OSM.js)
+            File: SLD  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/SLD.js)
+            File: SLD.v1  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/SLD/v1.js)
+            File: SLD.v1_0_0  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/SLD/v1_0_0.js)
+            File: Text  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/Text.js)
+            File: WFS  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WFS.js)
+            File: WFSCapabilities  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WFSCapabilities.js)
+            Group: WFSCapabilities  {
+               File: WFSCapabilities.v1  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WFSCapabilities/v1.js)
+               File: WFSCapabilities/v1_0_0  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WFSCapabilities/v1_0_0.js)
+               File: WFSCapabilities/v1_1_0  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WFSCapabilities/v1_1_0.js)
+               }  # Group: WFSCapabilities
+            File: WFSDescribeFeatureType.js  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WFSDescribeFeatureType.js)
+            Group: WFST  {
+               File: v1  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WFST/v1.js)
+               File: v1_0_0  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WFST/v1_0_0.js)
+               File: v1_1_0  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WFST/v1_1_0.js)
+               }  # Group: WFST
+            File: WFST.js  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WFST.js)
+            File: WKT  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WKT.js)
+            File: WMC  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WMC.js)
+            Group: WMC  {
+               File: v1  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WMC/v1.js)
+               File: v1_0_0  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WMC/v1_0_0.js)
+               File: v1_1_0  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WMC/v1_1_0.js)
+               }  # Group: WMC
+            File: WMSCapabilities  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WMSCapabilities.js)
+            Group: WMSCapabilities  {
+               File: WMSCapabilities.v1_1  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WMSCapabilities/v1_1.js)
+               File: WMSCapabilities/v1_1_0  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WMSCapabilities/v1_1_0.js)
+               File: WMSCapabilities/v1_1_1  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WMSCapabilities/v1_1_1.js)
+               }  # Group: WMSCapabilities
+            File: WMSDescribeLayer  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WMSDescribeLayer.js)
+            File: WMSDescribeLayer.v1_1  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WMSDescribeLayer/v1_1.js)
+            File: WMSGetFeatureInfo  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/WMSGetFeatureInfo.js)
+            File: XML  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format/XML.js)
+            }  # Group: Format
+         Group: Geometry  {
+            File: Collection  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Geometry/Collection.js)
+            File: Curve  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Geometry/Curve.js)
+            File: LinearRing  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Geometry/LinearRing.js)
+            File: LineString  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Geometry/LineString.js)
+            File: MultiLineString  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Geometry/MultiLineString.js)
+            File: MultiPoint  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Geometry/MultiPoint.js)
+            File: MultiPolygon  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Geometry/MultiPolygon.js)
+            File: Point  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Geometry/Point.js)
+            File: Polygon  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Geometry/Polygon.js)
+            File: Rectangle  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Geometry/Rectangle.js)
+            }  # Group: Geometry
+         Group: Handler  {
+            File: Handler.Box  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Handler/Box.js)
+            File: Handler.Click  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Handler/Click.js)
+            File: Handler.Drag  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Handler/Drag.js)
+            File: Handler.Feature  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Handler/Feature.js)
+            File: Handler.Hover  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Handler/Hover.js)
+            File: handler.Keyboard  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Handler/Keyboard.js)
+            File: Handler.MouseWheel  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Handler/MouseWheel.js)
+            File: Handler.Path  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Handler/Path.js)
+            File: Handler.Point  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Handler/Point.js)
+            File: Handler.Polygon  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Handler/Polygon.js)
+            File: Handler.RegularPolygon  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Handler/RegularPolygon.js)
+            }  # Group: Handler
+         Group: Lang  {
+            File: Lang["ca"]  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Lang/ca.js)
+            File: Lang["cs-CZ"]  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Lang/cs-CZ.js)
+            File: Lang["da-DK"]  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Lang/da-DK.js)
+            File: Lang["de"]  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Lang/de.js)
+            File: Lang["en"]  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Lang/en.js)
+            File: Lang["en-CA"]  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Lang/en-CA.js)
+            File: Lang["es"]  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Lang/es.js)
+            File: Lang["fr"]  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Lang/fr.js)
+            File: Lang["it"]  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Lang/it.js)
+            File: Lang["nb"]  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Lang/nb.js)
+            File: Lang["nl"]  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Lang/nl.js)
+            File: Lang["pt-BR"]  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Lang/pt-BR.js)
+            File: Lang["sv-SE"]  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Lang/sv-SE.js)
+            File: Lang["zh-CN"]  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Lang/zh-CN.js)
+            File: Lang["zh-TW"]  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Lang/zh-TW.js)
+            }  # Group: Lang
+         Group: Layer  {
+            File: ArcGIS93Rest  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/ArcGIS93Rest.js)
+            File: ArcIMS  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/ArcIMS.js)
+            File: Boxes  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Boxes.js)
+            File: EventPane  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/EventPane.js)
+            File: FixedZoomLevels  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/FixedZoomLevels.js)
+            File: GeoRSS  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/GeoRSS.js)
+            File: GML  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/GML.js)
+            File: Google  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Google.js)
+            File: Grid  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Grid.js)
+            File: HTTPRequest  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/HTTPRequest.js)
+            File: Image  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Image.js)
+            File: KaMap  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/KaMap.js)
+            File: KaMapCache  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/KaMapCache.js)
+            File: MapGuide  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/MapGuide.js)
+            File: MapServer  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/MapServer.js)
+            File: MapServer.Untiled  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/MapServer/Untiled.js)
+            File: Markers  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Markers.js)
+            File: MultiMap  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/MultiMap.js)
+            File: PointTrack  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/PointTrack.js)
+            File: SphericalMercator  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/SphericalMercator.js)
+            File: Text  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Text.js)
+            File: TileCache  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/TileCache.js)
+            File: TMS  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/TMS.js)
+            File: Vector  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Vector.js)
+            File: Vector.RootContainer  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Vector/RootContainer.js)
+            File: VirtualEarth  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/VirtualEarth.js)
+            File: WFS  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/WFS.js)
+            File: WMS  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/WMS.js)
+            File: WMS.Untiled  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/WMS/Untiled.js)
+            File: WorldWind  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/WorldWind.js)
+            File: XYZ  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/XYZ.js)
+            File: Yahoo  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer/Yahoo.js)
+            }  # Group: Layer
+         File: OpenLayers Base Types  (http/extensions/OpenLayers-2.8/lib/OpenLayers/BaseTypes.js)
+         File: OpenLayers.Console  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Console.js)
+         File: OpenLayers.Control  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Control.js)
+         File: OpenLayers.Event  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Events.js)
+         File: OpenLayers.Feature  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Feature.js)
+         File: OpenLayers.Feature.Vector  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Feature/Vector.js)
+         File: OpenLayers.Feature.WFS  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Feature/WFS.js)
+         File: OpenLayers.Filter  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Filter.js)
+         File: OpenLayers.Format  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Format.js)
+         File: OpenLayers.Geometry  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Geometry.js)
+         File: OpenLayers.Handler  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Handler.js)
+         File: OpenLayers.Icon  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Icon.js)
+         File: OpenLayers.Lang  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Lang.js)
+         File: OpenLayers.Layer  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Layer.js)
+         File: OpenLayers.Map  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Map.js)
+         File: OpenLayers.Marker  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Marker.js)
+         File: OpenLayers.Marker.Box  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Marker/Box.js)
+         File: OpenLayers.Popup  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Popup.js)
+         File: OpenLayers.Projection  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Projection.js)
+         File: OpenLayers.Protocol  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol.js)
+         File: OpenLayers.Renderer  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Renderer.js)
+         File: OpenLayers.Request  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Request.js)
+         File: OpenLayers.Request.XMLHttpRequest  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Request/XMLHttpRequest.js)
+         File: OpenLayers.Rule  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Rule.js)
+         File: OpenLayers.Strategy  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Strategy.js)
+         File: OpenLayers.Style  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Style.js)
+         File: OpenLayers.StyleMap  (http/extensions/OpenLayers-2.8/lib/OpenLayers/StyleMap.js)
+         File: OpenLayers.Tile  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Tile.js)
+         File: OpenLayers.Tile.Image  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Tile/Image.js)
+         File: OpenLayers.Tile.WFS  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Tile/WFS.js)
+         File: OpenLayers.Tween  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Tween.js)
+         Group: Popup  {
+            File: Anchored  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Popup/Anchored.js)
+            File: AnchoredBubble  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Popup/AnchoredBubble.js)
+            File: Framed  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Popup/Framed.js)
+            File: FramedCloud  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Popup/FramedCloud.js)
+            }  # Group: Popup
+         Group: Protocol  {
+            File: HTTP  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol/HTTP.js)
+            File: SQL  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol/SQL.js)
+            File: SQL.Gears  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol/SQL/Gears.js)
+            Group: WFS  {
+               File: v1  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol/WFS/v1.js)
+               File: v1_0_0  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol/WFS/v1_0_0.js)
+               File: v1_1_0  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol/WFS/v1_1_0.js)
+               }  # Group: WFS
+            File: WFS.js  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Protocol/WFS.js)
+            }  # Group: Protocol
+         Group: Renderer  {
+            File: ElementsIndexer  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Renderer/Elements.js)
+            File: Renderer.Canvas  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Renderer/Canvas.js)
+            File: Renderer.SVG  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Renderer/SVG.js)
+            File: Renderer.VML  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Renderer/VML.js)
+            }  # Group: Renderer
+         Group: Strategy  {
+            File: BBOX  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Strategy/BBOX.js)
+            File: Cluster  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Strategy/Cluster.js)
+            File: Fixed  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Strategy/Fixed.js)
+            File: Paging  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Strategy/Paging.js)
+            File: Save  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Strategy/Save.js)
+            }  # Group: Strategy
+         File: Util  (http/extensions/OpenLayers-2.8/lib/OpenLayers/Util.js)
+         }  # Group: OpenLayers
+      }  # Group: OpenLayers-2.8
+   File: Proj4js  (http/extensions/proj4js/lib/proj4js-combined.js)
+   File: Proj4js  (http/extensions/proj4js/lib/proj4js.js)
+   }  # Group: Http
+File: pgsql/.../update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql  (resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql)
+File: sql_updates_monitoring.sql  (resources/db/sql_updates_monitoring.sql)
 Group: Index  {
    Index: Everything
Modified: trunk/mapbender/documents/api_js/index.html
--- trunk/mapbender/documents/api_js/index.html	2009-12-11 10:48:19 UTC (rev 5118)
+++ trunk/mapbender/documents/api_js/index.html	2009-12-11 10:49:49 UTC (rev 5119)
@@ -1 +1 @@
-<html><head><meta http-equiv="Refresh" CONTENT="0; URL=files/http/javascripts/core-php.html"></head></html>
+<html><head><meta http-equiv="Refresh" CONTENT="0; URL=files/http/extensions/dataTables-1-5/extras/FixedHeader/FixedHeader-js.html"></head></html>
More information about the Mapbender_commits mailing list
