[Mapbender-commits] r5128 - in trunk/mapbender/documents/api_js: . Data files index
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Dec 11 06:38:01 EST 2009
Author: christoph
Date: 2009-12-11 06:38:00 -0500 (Fri, 11 Dec 2009)
New Revision: 5128
   trunk/mapbender/documents/api_js/Data/ConfigFileInfo.nd
   trunk/mapbender/documents/api_js/Data/PreviousMenuState.nd
   trunk/mapbender/documents/api_js/Menu.txt
   trunk/mapbender/documents/api_js/files/core-php.html
   trunk/mapbender/documents/api_js/files/map_obj-js.html
   trunk/mapbender/documents/api_js/files/mod_addWMSfromTree-js.html
   trunk/mapbender/documents/api_js/files/mod_changeEPSG-js.html
   trunk/mapbender/documents/api_js/files/mod_coordsLookup-js.html
   trunk/mapbender/documents/api_js/files/mod_doubleclickZoom-js.html
   trunk/mapbender/documents/api_js/files/mod_log-js.html
   trunk/mapbender/documents/api_js/files/mod_mousewheelZoom-js.html
   trunk/mapbender/documents/api_js/files/mod_overview-js.html
   trunk/mapbender/documents/api_js/files/mod_overviewToggle-js.html
   trunk/mapbender/documents/api_js/files/mod_pan-js.html
   trunk/mapbender/documents/api_js/files/mod_reload-js.html
   trunk/mapbender/documents/api_js/files/mod_repaint-js.html
   trunk/mapbender/documents/api_js/files/mod_repaint-php.html
   trunk/mapbender/documents/api_js/files/mod_resize_mapsize-js.html
   trunk/mapbender/documents/api_js/files/mod_sandclock-js.html
   trunk/mapbender/documents/api_js/files/mod_savewmc-js.html
   trunk/mapbender/documents/api_js/files/mod_scalebar-js.html
   trunk/mapbender/documents/api_js/files/mod_selArea-js.html
   trunk/mapbender/documents/api_js/files/mod_zoomFull-js.html
   trunk/mapbender/documents/api_js/files/mod_zoomIn1-js.html
   trunk/mapbender/documents/api_js/files/mod_zoomOut1-js.html
   trunk/mapbender/documents/api_js/index.html
   trunk/mapbender/documents/api_js/index/Classes.html
   trunk/mapbender/documents/api_js/index/Functions.html
   trunk/mapbender/documents/api_js/index/General.html
updated_documentation
Modified: trunk/mapbender/documents/api_js/Data/ConfigFileInfo.nd
(Binary files differ)
Modified: trunk/mapbender/documents/api_js/Data/PreviousMenuState.nd
Modified: trunk/mapbender/documents/api_js/Menu.txt
--- trunk/mapbender/documents/api_js/Menu.txt	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/Menu.txt	2009-12-11 11:38:00 UTC (rev 5128)
@@ -46,8 +46,12 @@
+File: Mapbender  (core.php)
 Group: Mapbender  {
+   File: Map  (map_obj.js)
    Group: modules  {
       File: AddWmsFromTree  (mod_addWMSfromTree.js)
@@ -55,8 +59,6 @@
       File: coordsLookup  (mod_coordsLookup.js)
       File: doubleclickZoom  (mod_doubleclickZoom.js)
       File: Log  (mod_log.js)
-      File: Map  (map_obj.js)
-      File: Mapbender  (core.php)
       File: mousewheelZoom  (mod_mousewheelZoom.js)
       File: Overview  (mod_overview.js)
       File: overviewToggle  (mod_overviewToggle.js)
Modified: trunk/mapbender/documents/api_js/files/core-php.html
--- trunk/mapbender/documents/api_js/files/core-php.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/core-php.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -19,7 +19,7 @@
 <div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile id=MSelected>Mapbender</div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile id=MSelected>Mapbender</div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
 var searchPanel = new SearchPanel("searchPanel", "HTML", "../search");
 --></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option  id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Functions">Functions</option></select></div></div><!--Menu-->
Modified: trunk/mapbender/documents/api_js/files/map_obj-js.html
--- trunk/mapbender/documents/api_js/files/map_obj-js.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/map_obj-js.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -25,7 +25,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile id=MSelected>Map</div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile id=MSelected>Map</div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_addWMSfromTree-js.html
--- trunk/mapbender/documents/api_js/files/mod_addWMSfromTree-js.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/mod_addWMSfromTree-js.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -39,7 +39,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile id=MSelected>AddWmsFromTree</div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile id=MSelected>AddWmsFromTree</div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_changeEPSG-js.html
--- trunk/mapbender/documents/api_js/files/mod_changeEPSG-js.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/mod_changeEPSG-js.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -35,7 +35,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile id=MSelected>changeEPSG</div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile id=MSelected>changeEPSG</div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_coordsLookup-js.html
--- trunk/mapbender/documents/api_js/files/mod_coordsLookup-js.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/mod_coordsLookup-js.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -34,7 +34,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile id=MSelected>coordsLookup</div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile id=MSelected>coordsLookup</div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_doubleclickZoom-js.html
--- trunk/mapbender/documents/api_js/files/mod_doubleclickZoom-js.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/mod_doubleclickZoom-js.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -26,7 +26,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile id=MSelected>doubleclickZoom</div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile id=MSelected>doubleclickZoom</div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_log-js.html
--- trunk/mapbender/documents/api_js/files/mod_log-js.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/mod_log-js.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -28,7 +28,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile id=MSelected>Log</div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile id=MSelected>Log</div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_mousewheelZoom-js.html
--- trunk/mapbender/documents/api_js/files/mod_mousewheelZoom-js.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/mod_mousewheelZoom-js.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -30,7 +30,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile id=MSelected>mousewheelZoom</div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile id=MSelected>mousewheelZoom</div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_overview-js.html
--- trunk/mapbender/documents/api_js/files/mod_overview-js.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/mod_overview-js.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -37,7 +37,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile id=MSelected>Overview</div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile id=MSelected>Overview</div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_overviewToggle-js.html
--- trunk/mapbender/documents/api_js/files/mod_overviewToggle-js.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/mod_overviewToggle-js.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -32,7 +32,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile id=MSelected>overviewToggle</div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile id=MSelected>overviewToggle</div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_pan-js.html
--- trunk/mapbender/documents/api_js/files/mod_pan-js.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/mod_pan-js.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -21,7 +21,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile id=MSelected>selArea</div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile id=MSelected>selArea</div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_reload-js.html
--- trunk/mapbender/documents/api_js/files/mod_reload-js.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/mod_reload-js.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -29,7 +29,7 @@
 <div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile id=MSelected>Reload</div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile id=MSelected>Reload</div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
 var searchPanel = new SearchPanel("searchPanel", "HTML", "../search");
 --></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option  id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Functions">Functions</option></select></div></div><!--Menu-->
Modified: trunk/mapbender/documents/api_js/files/mod_repaint-js.html
--- trunk/mapbender/documents/api_js/files/mod_repaint-js.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/mod_repaint-js.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -25,7 +25,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile id=MSelected>repaint</div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile id=MSelected>repaint</div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_repaint-php.html
--- trunk/mapbender/documents/api_js/files/mod_repaint-php.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/mod_repaint-php.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -25,7 +25,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile id=MSelected>repaint</div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile id=MSelected>repaint</div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_resize_mapsize-js.html
--- trunk/mapbender/documents/api_js/files/mod_resize_mapsize-js.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/mod_resize_mapsize-js.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -40,7 +40,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile id=MSelected>ResizeMapsize</div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile id=MSelected>ResizeMapsize</div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_sandclock-js.html
--- trunk/mapbender/documents/api_js/files/mod_sandclock-js.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/mod_sandclock-js.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -40,7 +40,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile id=MSelected>Sandclock</div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile id=MSelected>Sandclock</div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_savewmc-js.html
--- trunk/mapbender/documents/api_js/files/mod_savewmc-js.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/mod_savewmc-js.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -34,7 +34,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile id=MSelected>savewmc</div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile id=MSelected>savewmc</div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_scalebar-js.html
--- trunk/mapbender/documents/api_js/files/mod_scalebar-js.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/mod_scalebar-js.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -24,7 +24,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile id=MSelected>scalebar</div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile id=MSelected>scalebar</div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_selArea-js.html
--- trunk/mapbender/documents/api_js/files/mod_selArea-js.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/mod_selArea-js.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -21,7 +21,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile id=MSelected>selArea</div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile id=MSelected>selArea</div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_zoomFull-js.html
--- trunk/mapbender/documents/api_js/files/mod_zoomFull-js.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/mod_zoomFull-js.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -26,7 +26,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile id=MSelected>zoomFull</div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile id=MSelected>zoomFull</div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_zoomIn1-js.html
--- trunk/mapbender/documents/api_js/files/mod_zoomIn1-js.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/mod_zoomIn1-js.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -26,7 +26,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile id=MSelected>ZoomIn1</div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile id=MSelected>ZoomIn1</div></div><div class=MEntry><div class=MFile><a href="mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/files/mod_zoomOut1-js.html
--- trunk/mapbender/documents/api_js/files/mod_zoomOut1-js.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/files/mod_zoomOut1-js.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -26,7 +26,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile id=MSelected>ZoomOut1</div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile id=MSelected>ZoomOut1</div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="../index/General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="../index/Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/index/Classes.html
--- trunk/mapbender/documents/api_js/index/Classes.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/index/Classes.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -53,7 +53,7 @@
 <div id=Footer><a href="http://www.naturaldocs.org">Generated by Natural Docs</a></div><!--Footer-->
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Classes</div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="../files/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Classes</div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
 var searchPanel = new SearchPanel("searchPanel", "HTML", "../search");
 --></script><div id=MSearchPanel class=MSearchPanelInactive><input type=text id=MSearchField value=Search onFocus="searchPanel.OnSearchFieldFocus(true)" onBlur="searchPanel.OnSearchFieldFocus(false)" onKeyUp="searchPanel.OnSearchFieldChange()"><select id=MSearchType onFocus="searchPanel.OnSearchTypeFocus(true)" onBlur="searchPanel.OnSearchTypeFocus(false)" onChange="searchPanel.OnSearchTypeChange()"><option  id=MSearchEverything selected value="General">Everything</option><option value="Classes">Classes</option><option value="Functions">Functions</option></select></div></div><!--Menu-->
Modified: trunk/mapbender/documents/api_js/index/Functions.html
--- trunk/mapbender/documents/api_js/index/Functions.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/index/Functions.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -33,7 +33,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Functions</div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="../files/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex><a href="General.html">Everything</a></div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex id=MSelected>Functions</div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/index/General.html
--- trunk/mapbender/documents/api_js/index/General.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/index/General.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -61,7 +61,7 @@
-<div id=Menu><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MFile><a href="../files/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex id=MSelected>Everything</div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
+<div id=Menu><div class=MEntry><div class=MFile><a href="../files/core-php.html">Mapbender</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent2')">Mapbender</a><div class=MGroupContent id=MGroupContent2><div class=MEntry><div class=MFile><a href="../files/map_obj-js.html">Map</a></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent1')">modules</a><div class=MGroupContent id=MGroupContent1><div class=MEntry><div class=MFile><a href="../files/mod_addWMSfromTree-js.html">AddWmsFromTree</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_changeEPSG-js.html">changeEPSG</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_coordsLookup-js.html">coordsLookup</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_doubleclickZoom-js.html">doubleclickZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_log-js.html">Log</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_mousewheelZoom-js.html">mousewheelZoom</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_overview-js.html">Overview</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_overviewToggle-js.html">overviewToggle</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_reload-js.html">Reload</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_repaint-js.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_repaint-php.html">repaint</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_resize_mapsize-js.html">ResizeMapsize</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_sandclock-js.html">Sandclock</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_savewmc-js.html">savewmc</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_scalebar-js.html">scalebar</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_pan-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_selArea-js.html">selArea</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_zoomFull-js.html">zoomFull</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_zoomIn1-js.html">ZoomIn1</a></div></div><div class=MEntry><div class=MFile><a href="../files/mod_zoomOut1-js.html">ZoomOut1</a></div></div></div></div></div></div></div></div><div class=MEntry><div class=MGroup><a href="javascript:ToggleMenu('MGroupContent3')">Index</a><div class=MGroupContent id=MGroupContent3><div class=MEntry><div class=MIndex id=MSelected>Everything</div></div><div class=MEntry><div class=MIndex><a href="Classes.html">Classes</a></div></div><div class=MEntry><div class=MIndex><a href="Functions.html">Functions</a></div></div></div></div></div><script type="text/javascript"><!--
Modified: trunk/mapbender/documents/api_js/index.html
--- trunk/mapbender/documents/api_js/index.html	2009-12-11 11:36:28 UTC (rev 5127)
+++ trunk/mapbender/documents/api_js/index.html	2009-12-11 11:38:00 UTC (rev 5128)
@@ -1 +1 @@
-<html><head><meta http-equiv="Refresh" CONTENT="0; URL=files/mod_addWMSfromTree-js.html"></head></html>
\ No newline at end of file
+<html><head><meta http-equiv="Refresh" CONTENT="0; URL=files/core-php.html"></head></html>
More information about the Mapbender_commits mailing list
