[Mapbender-commits] r5165 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat Dec 12 07:39:17 EST 2009
Author: astrid_emde
Date: 2009-12-12 07:39:17 -0500 (Sat, 12 Dec 2009)
New Revision: 5165
Added:
   trunk/mapbender/resources/db/update.sh
script to update an existing Mapbender installation
Added: trunk/mapbender/resources/db/update.sh
--- trunk/mapbender/resources/db/update.sh	                        (rev 0)
+++ trunk/mapbender/resources/db/update.sh	2009-12-12 12:39:17 UTC (rev 5165)
@@ -0,0 +1,146 @@
+#!/bin/bash
+# create database for mapbender
+function show_disclaimer() {
+    # Disclaimer
+    echo ""
+    echo "DISCLAIMER: this Mapbender database setup script is not stable. USE AT YOUR OWN RISK!"
+    echo "The script will create a database for you and will import the Mapbender data to the new database"
+    echo "It will also compile the Mapbender.mo files"
+    echo ""
+    echo "To run this script you have to set the following options"
+    # echo " * set the right to execute on this install script"
+    # echo " * set the right to execute on mapbender/tools/i18n_update_mo.sh"
+    # echo " * write access to mapbender/log"
+    # echo " * write access to mapbender/http/tmp"
+    # echo " * write access to mapbender/resources/locale/ and subdirectories"
+    echo " * provide a database user that can create a database"
+    echo ""
+    echo ""
+    echo "If everything is prepared you can continue."
+    echo ""
+function del_logfile() {
+	rm log_*.txt
+	rm err_*.txt
+#get Database Configuration
+function get_db_config(){
+    until [ "$DBVERSION" = "p" -o "$DBVERSION" = "m" ]
+    do
+        echo ""
+        echo "database version? (p)ostgresql or (m)ysql?"
+        read DBVERSION
+    done
+    # db encoding
+    until [ "$DBENCODING" = "i" -o "$DBENCODING" = "u" ]
+    do
+        echo ""
+        echo "database character encoding? (i)so-8859-1 or (u)tf-8?"
+        read DBENCODING
+    done
+    # db name
+    until [ -n "$DBNAME" ]
+    do
+        echo ""
+        echo "database name?"
+        read DBNAME
+    done
+    #nicer vars
+    if [  "$DBVERSION" = "p" ]
+    then
+        DBVERSION="pgsql"
+    else
+        DBVERSION="mysql"
+    fi
+    echo ""
+    echo "database host (e.g. localhost)?"
+    read DBHOST
+    echo ""
+    echo "database port (e.g. 5432 for postgres, 3306 for mysql)?"
+    read DBPORT
+    echo ""
+    echo "database user?"
+    read DBUSER
+#using a password via commandline oder as shell var could lead to security problems, so we don't do it
+#    echo ""
+#    echo "Password for $DBUSER (will not be shown)?"
+#	stty -echo
+#	read DBPASSWORD
+#	stty echo
+function create_mysql_db(){
+    which mysql > /dev/null
+    if [ $? -ne 0 ]
+    then
+        echo "commando mysql, but not found, exiting..."
+        echo "is mysql installed?"
+        echo ""
+        exit 1;
+    fi
+    echo "update to 2.6.1"
+	mysql $DBNAME -p$DBPASSWORD -u $DBUSER -h $DBHOST -P $DBPORT < mysql/$DBENCODING/update/update_2.6_to_2.6.1_mysql_$DBENCODING.sql >> log_update.txt 2>> err_update.txt
+	echo "update to 2.7"
+	mysql $DBNAME -p$DBPASSWORD -u $DBUSER -h $DBHOST -P $DBPORT < mysql/$DBENCODING/update/update_2.6.1_to_2.7_mysql_$DBENCODING.sql >> log_update.txt 2>> err_update.txt
+#Create Database (Postgres)
+function create_pgsql_db(){
+    which psql createdb > /dev/null
+    if [ $? -ne 0 ]
+    then
+        echo "commando pgsql or createdb needed, but not found, exiting..."
+        echo "is PostgreSQL installed?"
+        echo ""
+        exit 1;
+    fi
+	psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6_to_2.6.1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
+	psql -U $DBUSER  -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6.1_to_2.7rc1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
+#magic starts here
+show_disclaimer;
+get_db_config;
+show_db_config;
+if [ $DBVERSION = "pgsql" ]
+then
+    echo "Updating Postgres Database"
+    create_pgsql_db;
+else
+    echo "Upting Mysql Database"
+    create_mysql_db;
+    echo ""
+fi
+echo ""
+echo "Update finished...check the log and error files to see if an error occured.";
More information about the Mapbender_commits mailing list
