[Mapbender-commits] r5206 - in trunk/mapbender/http/extensions: . firebug-lite
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Dec 18 04:22:15 EST 2009
Author: christoph
Date: 2009-12-18 04:22:12 -0500 (Fri, 18 Dec 2009)
New Revision: 5206
Added:
   trunk/mapbender/http/extensions/firebug-lite/
   trunk/mapbender/http/extensions/firebug-lite/firebug-lite-compressed.js
   trunk/mapbender/http/extensions/firebug-lite/firebug-lite.css
Added: trunk/mapbender/http/extensions/firebug-lite/firebug-lite-compressed.js
--- trunk/mapbender/http/extensions/firebug-lite/firebug-lite-compressed.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/firebug-lite/firebug-lite-compressed.js	2009-12-18 09:22:12 UTC (rev 5206)
@@ -0,0 +1,124 @@
+var firebug={version:[1.23,20090506],el:{},env:{"css":"../extensions/firebug-lite/firebug-lite.css","debug":true,"detectFirebug":true,"dIndex":"console","height":295,"hideDOMFunctions":false,"openInPopup":false,"override":false,"ml":false,"showIconWhenHidden":true,"popupTop":1,"popupLeft":1,"popupWidth":undefined,"popupHeight":undefined,"textNodeChars":0},internal:{"cache":{},"extConsole":null,"init":false,"isPopup":false,"liteFilename":null,"minimized":false,"popupWin":null,"targetWindow":undefined},initConsole:function(){var command;try{if((!window.console||(window.console&&!window.console.firebug))||(firebug.env.override&&!(/Firefox\/3/i.test(navigator.userAgent)))){window.console={"provider":"Firebug Lite"};for(command in firebug.d.console.cmd){window.console[command]=firebug.lib.util.Curry(firebug.d.console.run,window,command);};}
+window.onerror=function(_message,_file,_line){firebug.d.console.run('error',firebug.lib.util.String.format('{0} ({1},{2})',_message,firebug.getFileName(_file),_line));};}catch(e){}},overrideConsole:function(){with(firebug){env.override=true;try{internal.extConsole=window.console;}catch(e){}
+initConsole();}},restoreConsole:function(){with(firebug){if(internal.extConsole){env.override=false;try{window.console=internal.extConsole;}catch(e){}
+internal.extConsole=null;}}},init:function(_css){var i,cssLoaded=false,iconTitle="Click here or press F12, (CTRL|CMD)+SHIFT+L or SHIFT+ENTER to show Firebug Lite. CTRL|CMD click this icon to hide it.";with(firebug){if(document.getElementsByTagName('html')[0].attributes.getNamedItem('debug')){env.debug=document.getElementsByTagName('html')[0].attributes.getNamedItem('debug').nodeValue!=="false";}
+if(internal.isPopup){env.openInPopup=false;internal.targetWindow=window.opener;env.popupWidth=window.opener.firebug.env.popupWidth||window.opener.firebug.lib.util.GetViewport().width;env.popupHeight=window.opener.firebug.env.popupHeight||window.opener.firebug.lib.util.GetViewport().height;}else{internal.targetWindow=window;env.popupWidth=env.popupWidth||lib.util.GetViewport().width;env.popupHeight=env.popupHeight||lib.util.GetViewport().height;}
+settings.readCookie();if(internal.init||(env.detectFirebug&&window.console&&window.console.firebug)){return;}
+for(i=0;i<document.styleSheets.length;i++){if(/firebug-lite\.css/i.test(document.styleSheets[i].href)){cssLoaded=true;break;}}
+if(!cssLoaded){document.getElementsByTagName("head")[0].appendChild(new lib.element("link").attribute.set("rel","stylesheet").attribute.set("type","text/css").attribute.set("href",env.css).element);}
+if(env.override){overrideConsole();}
+el.firebugIcon=new lib.element("div").attribute.set('firebugIgnore',true).attribute.set("id","firebugIconDiv").attribute.set("title",iconTitle).attribute.set("alt",iconTitle).event.addListener("mousedown",win.iconClicked).insert(document.body);el.content={};el.mainiframe=new lib.element("IFRAME").attribute.set("id","FirebugIFrame").attribute.set('firebugIgnore',true).environment.addStyle({"display":"none","width":lib.util.GetViewport().width+"px"}).insert(document.body);el.main=new lib.element("DIV").attribute.set("id","Firebug").attribute.set('firebugIgnore',true).environment.addStyle({"display":"none","width":lib.util.GetViewport().width+"px"}).insert(document.body);if(!internal.isPopup){el.resizer=new lib.element("DIV").attribute.addClass("Resizer").event.addListener("mousedown",win.resizer.start).insert(el.main);}
+el.header=new lib.element("DIV").attribute.addClass("Header").insert(el.main);el.left={};el.left.container=new lib.element("DIV").attribute.addClass("Left").insert(el.main);el.right={};el.right.container=new lib.element("DIV").attribute.addClass("Right").insert(el.main);el.main.child.add(new lib.element("DIV").attribute.addClass('Clear'));el.button={};el.button.container=new lib.element("DIV").attribute.addClass("ButtonContainer").insert(el.header);el.button.logo=new lib.element("A").attribute.set("title","Firebug Lite").attribute.set("target","_blank").attribute.set("href","http://getfirebug.com/lite.html").update("&nbsp;").attribute.addClass("Button Logo").insert(el.button.container);el.button.inspect=new lib.element("A").attribute.addClass("Button").event.addListener("click",internal.targetWindow.firebug.d.inspector.toggle).update("Inspect").insert(el.button.container);el.button.dock=new lib.element("A").attribute.addClass("Button Dock").event.addListener("click",win.dock).insert(el.button.container);el.button.newWindow=new lib.element("A").attribute.addClass("Button NewWindow").event.addListener("click",win.newWindow).insert(el.button.container);if(!internal.isPopup){el.button.maximize=new lib.element("A").attribute.addClass("Button Maximize").event.addListener("click",win.maximize).insert(el.button.container);el.button.minimize=new lib.element("A").attribute.addClass("Button Minimize").event.addListener("click",win.minimize).insert(el.button.container);el.button.close=new lib.element("A").attribute.addClass("Button Close").event.addListener("click",win.hide).insert(el.button.container);}
+if(lib.env.ie||lib.env.webkit){el.button.container.environment.addStyle({"paddingTop":"12px"});}
+el.nav={};el.nav.container=new lib.element("DIV").attribute.addClass("Nav").insert(el.left.container);el.nav.console=new lib.element("A").attribute.addClass("Tab Selected").event.addListener("click",lib.util.Curry(d.navigate,window,"console")).update("Console").insert(el.nav.container);el.nav.html=new lib.element("A").attribute.addClass("Tab").update("HTML").event.addListener("click",lib.util.Curry(d.navigate,window,"html")).insert(el.nav.container);el.nav.css=new lib.element("A").attribute.addClass("Tab").update("CSS").event.addListener("click",lib.util.Curry(d.navigate,window,"css")).insert(el.nav.container);if(!internal.isPopup){el.nav.scripts=new lib.element("A").attribute.addClass("Tab").update("Script").event.addListener("click",lib.util.Curry(d.navigate,window,"scripts")).insert(el.nav.container);}
+el.nav.dom=new lib.element("A").attribute.addClass("Tab").update("DOM").event.addListener("click",lib.util.Curry(d.navigate,internal.targetWindow,"dom")).insert(el.nav.container);el.nav.xhr=new lib.element("A").attribute.addClass("Tab").update("XHR").event.addListener("click",lib.util.Curry(d.navigate,window,"xhr")).insert(el.nav.container);el.nav.optionsdiv=new lib.element("DIV").attribute.addClass("Settings").insert(el.nav.container);el.nav.options=new lib.element("A").attribute.addClass("Tab Button Options").update("Options&nbsp;&nbsp;&nbsp;&nbsp;").event.addListener("click",settings.toggle).insert(el.nav.optionsdiv);el.borderInspector=new lib.element("DIV").attribute.set("id","FirebugBorderInspector").attribute.set('firebugIgnore',true).event.addListener("click",listen.inspector).insert(document.body);el.bgInspector=new lib.element("DIV").attribute.set("id","FirebugBGInspector").attribute.set('firebugIgnore',true).insert(document.body);el.left.console={};el.left.console.container=new lib.element("DIV").attribute.addClass("Console").insert(el.left.container);el.left.console.mlButton=new lib.element("A").attribute.addClass("MLButton").event.addListener("click",d.console.toggleML).insert(el.left.console.container);el.left.console.monitor=new lib.element("DIV").insert(new lib.element("DIV").attribute.addClass("Monitor").insert(el.left.console.container));el.left.console.container.child.add(new lib.element("DIV").attribute.addClass("InputArrow").update(">>>"));el.left.console.input=new lib.element("INPUT").attribute.set("type","text").attribute.addClass("Input").event.addListener("keydown",listen.consoleTextbox).insert(new lib.element("DIV").attribute.addClass("InputContainer").insert(el.left.console.container));el.right.console={};el.right.console.container=new lib.element("DIV").attribute.addClass("Console Container").insert(el.right.container);el.right.console.mlButton=new lib.element("A").attribute.addClass("MLButton CloseML").event.addListener("click",d.console.toggleML).insert(el.right.console.container);el.right.console.input=new lib.element("TEXTAREA").attribute.addClass("Input").insert(el.right.console.container);el.right.console.input.event.addListener("keydown",lib.util.Curry(tab,window,el.right.console.input.element));el.right.console.run=new lib.element("A").attribute.addClass("Button").event.addListener("click",listen.runMultiline).update("Run").insert(el.right.console.container);el.right.console.clear=new lib.element("A").attribute.addClass("Button").event.addListener("click",lib.util.Curry(d.clean,window,el.right.console.input)).update("Clear").insert(el.right.console.container);el.button.console={};el.button.console.container=new lib.element("DIV").attribute.addClass("ButtonSet").insert(el.button.container);el.button.console.clear=new lib.element("A").attribute.addClass("Button").event.addListener("click",d.console.clear).update("Clear").insert(el.button.console.container);el.left.html={};el.left.html.container=new lib.element("DIV").attribute.addClass("HTML").insert(el.left.container);el.right.html={};el.right.html.container=new lib.element("DIV").attribute.addClass("HTML Container").insert(el.right.container);el.right.html.nav={};el.right.html.nav.container=new lib.element("DIV").attribute.addClass("Nav").insert(el.right.html.container);el.right.html.nav.computedStyle=new lib.element("A").attribute.addClass("Tab Selected").event.addListener("click",lib.util.Curry(d.html.navigate,firebug,"computedStyle")).update("Computed Style").insert(el.right.html.nav.container);el.right.html.nav.dom=new lib.element("A").attribute.addClass("Tab").event.addListener("click",lib.util.Curry(d.html.navigate,firebug,"dom")).update("DOM").insert(el.right.html.nav.container);el.right.html.content=new lib.element("DIV").attribute.addClass("Content").insert(el.right.html.container);el.button.html={};el.button.html.container=new lib.element("DIV").attribute.addClass("ButtonSet HTML").insert(el.button.container);el.left.css={};el.left.css.container=new lib.element("DIV").attribute.addClass("CSS").insert(el.left.container);el.right.css={};el.right.css.container=new lib.element("DIV").attribute.addClass("CSS Container").insert(el.right.container);el.right.css.nav={};el.right.css.nav.container=new lib.element("DIV").attribute.addClass("Nav").insert(el.right.css.container);el.right.css.nav.runCSS=new lib.element("A").attribute.addClass("Tab Selected").update("Run CSS").insert(el.right.css.nav.container);el.right.css.mlButton=new lib.element("A").attribute.addClass("MLButton CloseML").event.addListener("click",d.console.toggleML).insert(el.right.css.container);el.right.css.input=new lib.element("TEXTAREA").attribute.addClass("Input").insert(el.right.css.container);el.right.css.input.event.addListener("keydown",lib.util.Curry(firebug.tab,window,el.right.css.input.element));el.right.css.run=new lib.element("A").attribute.addClass("Button").event.addListener("click",listen.runCSS).update("Run").insert(el.right.css.container);el.right.css.clear=new lib.element("A").attribute.addClass("Button").event.addListener("click",lib.util.Curry(d.clean,window,el.right.css.input)).update("Clear").insert(el.right.css.container);el.button.css={};el.button.css.container=new lib.element("DIV").attribute.addClass("ButtonSet CSS").insert(el.button.container);el.button.css.selectbox=new lib.element("SELECT").event.addListener("change",listen.cssSelectbox).insert(el.button.css.container);el.left.scripts={};el.left.scripts.container=new lib.element("DIV").attribute.addClass("Scripts").insert(el.left.container);el.right.scripts={};el.right.scripts.container=new lib.element("DIV").attribute.addClass("Scripts Container").insert(el.right.container);el.button.scripts={};el.button.scripts.container=new lib.element("DIV").attribute.addClass("ButtonSet Scripts").insert(el.button.container);el.button.scripts.selectbox=new lib.element("SELECT").event.addListener("change",listen.scriptsSelectbox).insert(el.button.scripts.container);el.button.scripts.lineNumbers=new lib.element("A").attribute.addClass("Button").event.addListener("click",d.scripts.toggleLineNumbers).update("Show Line Numbers").insert(el.button.scripts.container);el.left.dom={};el.left.dom.container=new lib.element("DIV").attribute.addClass("DOM").insert(el.left.container);el.right.dom={};el.right.dom.container=new lib.element("DIV").attribute.addClass("DOM Container").insert(el.right.container);el.button.dom={};el.button.dom.container=new lib.element("DIV").attribute.addClass("ButtonSet DOM").insert(el.button.container);el.button.dom.label=new lib.element("LABEL").update("Object Path:").insert(el.button.dom.container);el.button.dom.textbox=new lib.element("INPUT").event.addListener("keydown",listen.domTextbox).update(internal.isPopup?"window.opener":"window").insert(el.button.dom.container);el.left.str={};el.left.str.container=new lib.element("DIV").attribute.addClass("STR").insert(el.left.container);el.right.str={};el.right.str.container=new lib.element("DIV").attribute.addClass("STR").insert(el.left.container);el.button.str={};el.button.str.container=new lib.element("DIV").attribute.addClass("ButtonSet XHR").insert(el.button.container);el.button.str.watch=new lib.element("A").attribute.addClass("Button").event.addListener("click",lib.util.Curry(d.navigate,window,"xhr")).update("Back").insert(el.button.str.container);el.left.xhr={};el.left.xhr.container=new lib.element("DIV").attribute.addClass("XHR").insert(el.left.container);el.right.xhr={};el.right.xhr.container=new lib.element("DIV").attribute.addClass("XHR").insert(el.left.container);el.button.xhr={};el.button.xhr.container=new lib.element("DIV").attribute.addClass("ButtonSet XHR").insert(el.button.container);el.button.xhr.label=new lib.element("LABEL").update("XHR Path:").insert(el.button.xhr.container);el.button.xhr.textbox=new lib.element("INPUT").event.addListener("keydown",listen.xhrTextbox).insert(el.button.xhr.container);el.button.xhr.watch=new lib.element("A").attribute.addClass("Button").event.addListener("click",listen.addXhrObject).update("Watch").insert(el.button.xhr.container);el.settings={};el.settings.container=new lib.element("DIV").child.add(new lib.element("DIV").attribute.addClass("Header").child.add(new lib.element().attribute.addClass("Title").update('Firebug Lite Settings'))).attribute.addClass("SettingsDiv").insert(el.main);el.settings.content=new lib.element("DIV").attribute.addClass("Content").insert(el.settings.container);el.settings.progressDiv=new lib.element("DIV").attribute.addClass("ProgressDiv").insert(el.settings.content);el.settings.progress=new lib.element("DIV").attribute.addClass("Progress").insert(el.settings.progressDiv);el.settings.cbxDebug=new lib.element("INPUT").attribute.set("type","checkbox").attribute.addClass("SettingsCBX").insert(el.settings.content);el.settings.content.child.add(document.createTextNode("Start visible"));new lib.element("BR").insert(el.settings.content);el.settings.cbxDetectFirebug=new lib.element("INPUT").attribute.set("type","checkbox").attribute.addClass("SettingsCBX").insert(el.settings.content);el.settings.content.child.add(document.createTextNode("Hide when Firebug active"));new lib.element("BR").insert(el.settings.content);el.settings.cbxHideDOMFunctions=new lib.element("INPUT").attribute.set("type","checkbox").attribute.addClass("SettingsCBX").insert(el.settings.content);el.settings.content.child.add(document.createTextNode("Hide DOM functions"));new lib.element("BR").insert(el.settings.content);el.settings.cbxOverride=new lib.element("INPUT").attribute.set("type","checkbox").attribute.addClass("SettingsCBX").insert(el.settings.content);el.settings.content.child.add(document.createTextNode("Override window.console"));new lib.element("BR").insert(el.settings.content);el.settings.cbxShowIcon=new lib.element("INPUT").attribute.set("type","checkbox").attribute.addClass("SettingsCBX").insert(el.settings.content);el.settings.content.child.add(document.createTextNode("Show icon when hidden"));new lib.element("BR").insert(el.settings.content);el.settings.cbxOpenInPopup=new lib.element("INPUT").attribute.set("type","checkbox").attribute.addClass("SettingsCBX").insert(el.settings.content);el.settings.content.child.add(document.createTextNode("Open in popup"));new lib.element("BR").insert(el.settings.content);el.settings.content.child.add(document.createTextNode("Trim textnode to "));el.settings.textNodeChars=new lib.element("INPUT").attribute.set("type","text").attribute.addClass("SettingsTextbox").insert(el.settings.content);el.settings.content.child.add(document.createTextNode(" chars"));el.settings.buttonDiv=new lib.element("DIV").insert(el.settings.content);el.settings.buttonLeftDiv=new lib.element("DIV").attribute.addClass("ButtonsLeft").insert(el.settings.buttonDiv);el.settings.resetButton=new lib.element("INPUT").attribute.set("type","button").update("Reset").event.addListener("click",settings.reset).insert(el.settings.buttonLeftDiv);el.settings.buttonRightDiv=new lib.element("DIV").attribute.addClass("ButtonsRight").insert(el.settings.buttonDiv);el.settings.cancelButton=new lib.element("INPUT").attribute.set("type","button").update("Cancel").event.addListener("click",settings.hide).insert(el.settings.buttonRightDiv);el.settings.buttonRightDiv.child.add(document.createTextNode(" "));el.settings.saveButton=new lib.element("INPUT").attribute.set("type","button").update("Save").event.addListener("click",settings.saveClicked).insert(el.settings.buttonRightDiv);lib.util.AddEvent(document,"mousemove",listen.mouse)("mousemove",win.resizer.resize)("mouseup",win.resizer.stop)("keydown",listen.keyboard);internal.init=true;for(var i=0,len=d.console.cache.length;i<len;i++){var item=d.console.cache[i];d.console.cmd[item.command].apply(window,item.arg);};if(lib.env.ie6){window.onscroll=lib.util.Curry(win.setVerticalPosition,window,null);var buttons=[el.button.inspect,el.button.close,el.button.inspect,el.button.console.clear,el.right.console.run,el.right.console.clear,el.right.css.run,el.right.css.clear];for(var i=0,len=buttons.length;i<len;i++)
+buttons[i].attribute.set("href","#");win.refreshSize();}
+if(env.showIconWhenHidden){if(!internal.popupWin){el.firebugIcon.environment.addStyle({"display":env.debug&&'none'||'block'});}}
+lib.util.AddEvent(window,"unload",win.unload);if(internal.isPopup){env.height=lib.util.GetViewport().height;lib.util.AddEvent(window,"resize",win.fitToPopup);win.fitToPopup();}else{lib.util.AddEvent(window,"resize",win.refreshSize);}
+win.setHeight(env.height);if(env.openInPopup&&!internal.isPopup){win.newWindow();}else{el.main.environment.addStyle({"display":env.debug&&'block'||'none'});el.mainiframe.environment.addStyle({"display":env.debug&&'block'||'none'});}}},inspect:function(){return firebug.d.html.inspect.apply(window,arguments);},watchXHR:function(){with(firebug){d.xhr.addObject.apply(window,arguments);if(env.dIndex!="xhr"){d.navigate("xhr");}}},settings:{isVisible:false,show:function(){with(firebug){var posXY=lib.util.Element.getPosition(firebug.el.nav.options.element);settings.refreshForm();el.settings.container.environment.addStyle({"display":"block","left":(posXY.offsetLeft-107)+"px"});el.settings.progressDiv.environment.addStyle({"display":"none"});firebug.settings.isVisible=true;}},hide:function(){with(firebug){firebug.el.settings.container.environment.addStyle({"display":"none"});firebug.settings.isVisible=false;}},toggle:function(){with(firebug){settings[!settings.isVisible&&'show'||'hide']();}},saveClicked:function(){firebug.el.settings.progressDiv.environment.addStyle({"display":"block"});setTimeout(firebug.settings.formToSettings,0);},formToSettings:function(){var fe=firebug.env,ofe,elSet=firebug.el.settings,exdate;fe.debug=elSet.cbxDebug.element.checked;fe.detectFirebug=elSet.cbxDetectFirebug.element.checked;fe.hideDOMFunctions=elSet.cbxHideDOMFunctions.element.checked;fe.override=elSet.cbxOverride.element.checked;fe.showIconWhenHidden=elSet.cbxShowIcon.element.checked;fe.openInPopup=elSet.cbxOpenInPopup.element.checked;if(isFinite(elSet.textNodeChars.element.value)&&elSet.textNodeChars.element.value>0){fe.textNodeChars=elSet.textNodeChars.element.value;}else{fe.textNodeChars=0;}
+if(firebug.internal.isPopup){window.opener.firebug.env=firebug.lib.util.Hash.clone(fe);}
+with(firebug){settings.writeCookie();settings.hide();win.refreshDOM();d.html.openHtmlTree();if(internal.isPopup){with(opener.firebug){win.refreshDOM();d.html.openHtmlTree();}}}},reset:function(){var exdate=new Date();exdate.setTime(exdate.getTime()-1);document.cookie='FBLiteSettings=;expires='+exdate.toGMTString();location.reload(true);},readCookie:function(){var i,cookieArr,valueArr,item,value;with(firebug.env){if(firebug.internal.targetWindow.document.cookie.length>0){cookieArr=firebug.internal.targetWindow.document.cookie.split('; ');for(i=0;i<cookieArr.length;i++){if(cookieArr[i].split('=')[0]=='FBLiteSettings'){valueArr=cookieArr[i].split('=')[1].split(',');}}
+if(valueArr){for(i=0;i<valueArr.length;i++){item=valueArr[i].split(':')[0];value=valueArr[i].split(':')[1];switch(item){case'debug':debug=value=="true";break;case'detectFirebug':detectFirebug=value=="true";break;case'hideDOMFunctions':hideDOMFunctions=value=="true";break;case'override':override=value=="true";break;case'showIconWhenHidden':showIconWhenHidden=value=="true";break;case'openInPopup':openInPopup=value=="true";break;case'textNodeChars':textNodeChars=isFinite(value)?parseInt(value,10):0;break;case'popupTop':popupTop=parseInt(value,10);break;case'popupLeft':popupLeft=parseInt(value,10);break;case'popupWidth':popupWidth=parseInt(value,10);break;case'popupHeight':popupHeight=parseInt(value,10);break;case'height':height=parseInt(value,10);break;}}}}}},writeCookie:function(){var values;with(firebug.env){values='debug:'+debug+',';values+='detectFirebug:'+detectFirebug+',';values+='hideDOMFunctions:'+hideDOMFunctions+',';values+='override:'+override+',';values+='showIconWhenHidden:'+showIconWhenHidden+',';values+='openInPopup:'+openInPopup+',';values+='textNodeChars:'+textNodeChars+',';if(firebug.internal.isPopup){if(window.outerWidth===undefined){values+='popupTop:'+(window.screenTop-56)+',';values+='popupLeft:'+(window.screenLeft-8)+',';values+='popupWidth:'+document.body.clientWidth+',';values+='popupHeight:'+document.body.clientHeight+',';}else{values+='popupTop:'+window.screenY+',';values+='popupLeft:'+window.screenX+',';values+='popupWidth:'+window.outerWidth+',';values+='popupHeight:'+window.outerHeight+',';}}else{values+='popupTop:'+popupTop+',';values+='popupLeft:'+popupLeft+',';values+='popupWidth:'+popupWidth+',';values+='popupHeight:'+popupHeight+',';}
+values+='height:'+(parseInt(firebug.internal.targetWindow.firebug.el.main.element.style.height.replace(/px/,''),10)-38);exdate=new Date();exdate.setDate(exdate.getDate()+365);firebug.internal.targetWindow.document.cookie='FBLiteSettings='+values+';expires='+exdate.toGMTString();}},refreshForm:function(){var fe=firebug.env,elSet=firebug.el.settings;elSet.cbxDebug.element.checked=fe.debug;elSet.cbxDetectFirebug.element.checked=fe.detectFirebug;elSet.cbxHideDOMFunctions.element.checked=fe.hideDOMFunctions;elSet.cbxOverride.element.checked=fe.override;elSet.cbxShowIcon.element.checked=fe.showIconWhenHidden;elSet.cbxOpenInPopup.element.checked=fe.openInPopup;elSet.textNodeChars.element.value=fe.textNodeChars;}},win:{hide:function(){with(firebug){el.main.environment.addStyle({"display":"none"});el.mainiframe.environment.addStyle({"display":"none"});if(env.showIconWhenHidden){el.firebugIcon.environment.addStyle({"display":"block"});}}},show:function(){with(firebug){el.main.environment.addStyle({"display":"block"});el.mainiframe.environment.addStyle({"display":"block"});if(env.showIconWhenHidden){el.firebugIcon.environment.addStyle({"display":"none"});}}},iconClicked:function(_event){with(firebug){if(_event.ctrlKey==true||_event.metaKey==true){el.firebugIcon.environment.addStyle({"display":"none"});env.showIconWhenHidden=false;}else{win.show();}}},minimize:function(){with(firebug){internal.minimized=true;el.main.environment.addStyle({"height":"35px"});el.mainiframe.environment.addStyle({"height":"35px"});el.button.maximize.environment.addStyle({"display":"block"});el.button.minimize.environment.addStyle({"display":"none"});win.refreshSize();}},maximize:function(){with(firebug){internal.minimized=false;el.button.minimize.environment.addStyle({"display":"block"});el.button.maximize.environment.addStyle({"display":"none"});win.setHeight(env.height);}},newWindow:function(){var interval,scripts,script,scriptPath,fe=firebug.env,fi=firebug.internal;if(!fi.popupWin){scripts=document.getElementsByTagName('script');fi.popupWin=window.open("","_firebug","status=0,menubar=0,resizable=1,top="+fe.popupTop+",left="+fe.popupLeft+",width="+fe.popupWidth+",height="+fe.popupHeight+",scrollbars=0,addressbar=0,outerWidth="+fe.popupWidth+",outerHeight="+fe.popupHeight+"toolbar=0,location=0,directories=0,dialog=0");if(!fi.popupWin){alert("Firebug Lite could not open a pop-up window, most likely because of a popup blocker.\nPlease enable popups for this domain");}else{firebug.settings.hide();for(i=0,len=scripts.length;i<len;i++){if(scripts[i].src.indexOf(fi.liteFilename)>-1){scriptPath=scripts[i].src;break;}}
+if(scriptPath){done=false;script=fi.popupWin.document.createElement('script');script.type='text/javascript';script.src=scriptPath;script[firebug.lib.env.ie?"onreadystatechange":"onload"]=function(){if(!done&&(!firebug.lib.env.ie||this.readyState=="complete"||this.readyState=="loaded")){done=true;if(fi.popupWin.firebug){with(fi.popupWin.firebug){internal.isPopup=true;env.css=fe.css;init();el.button.dock.environment.addStyle({"display":"block"});el.button.newWindow.environment.addStyle({"display":"none"});}}}};if(!done&&firebug.lib.env.webkit){interval=setInterval(function(){if(firebug.internal.popupWin.firebug){clearInterval(interval);done=true;with(firebug.internal.popupWin.firebug){internal.isPopup=true;env.css=fe.css;init();el.button.dock.environment.addStyle({"display":"block"});el.button.newWindow.environment.addStyle({"display":"none"});}}},10);};if(!firebug.lib.env.ie){firebug.internal.popupWin.document.write('<html><head><title>Firebug Lite - '+document.location.href+'</title></head><body></body></html>');}
+if(!done){firebug.internal.popupWin.document.getElementsByTagName('head')[0].appendChild(script);firebug.el.main.environment.addStyle({"display":"none"});firebug.el.mainiframe.environment.addStyle({"display":"none"});}}else{alert("Unable to detect the following script \""+firebug.internal.liteFilename+"\" ... if the script has been renamed then please set the value of firebug.internal.liteFilename to reflect this change");firebug.internal.popupWin.close();firebug.internal.popupWin=null;}}}},dock:function(){with(opener.firebug){internal.popupWin=null;el.main.environment.addStyle({"display":"block"});el.mainiframe.environment.addStyle({"display":"block"});settings.readCookie();window.close();};},unload:function(){with(firebug){if(internal.isPopup){win.dock();}else if(internal.popupWin){internal.popupWin.close();}}},fitToPopup:function(){with(firebug){var viewport=lib.util.GetViewport(window);win.setHeight((window.innerHeight||viewport.height)-38);el.main.environment.addStyle({"width":(viewport.width)+"px"});el.mainiframe.environment.addStyle({"width":(viewport.width)+"px"});}},resizer:{y:[],enabled:false,start:function(_event){with(firebug){if(internal.minimized)return;win.resizer.y=[el.main.element.offsetHeight,_event.clientY];if(lib.env.ie6){win.resizer.y[3]=parseInt(el.main.environment.getPosition().top);}
+win.resizer.enabled=true;}},resize:function(_event){with(firebug){if(!win.resizer.enabled)return;win.resizer.y[2]=(win.resizer.y[0]+(win.resizer.y[1]-_event.clientY));el.main.environment.addStyle({"height":win.resizer.y[2]+"px"});el.mainiframe.environment.addStyle({"height":win.resizer.y[2]+"px"});if(lib.env.ie6){el.main.environment.addStyle({"top":win.resizer.y[3]-(win.resizer.y[1]-_event.clientY)+"px"});el.mainiframe.environment.addStyle({"top":win.resizer.y[3]-(win.resizer.y[1]-_event.clientY)+"px"});}}},stop:function(_event){with(firebug){if(win.resizer.enabled){win.resizer.enabled=false;win.setHeight(win.resizer.y[2]-35);}}}},setHeight:function(_height){with(firebug){env.height=_height;el.left.container.environment.addStyle({"height":_height+"px"});el.right.container.environment.addStyle({"height":_height+"px"});el.main.environment.addStyle({"height":_height+38+"px"});el.mainiframe.environment.addStyle({"height":_height+38+"px"});win.refreshSize();el.left.console.monitor.element.parentNode.style.height=_height-47+"px";el.left.console.mlButton.environment.addStyle({"top":_height+19+"px"});el.right.console.mlButton.environment.addStyle({"top":_height+19+"px"});el.right.console.input.environment.addStyle({"height":_height-29+"px"});el.left.html.container.environment.addStyle({"height":_height-23+"px"});el.right.html.content.environment.addStyle({"height":_height-23+"px"});el.left.css.container.environment.addStyle({"height":_height-33+"px"});el.right.css.input.environment.addStyle({"height":_height-55+"px"});el.left.scripts.container.environment.addStyle({"height":_height-23+"px"});el.left.dom.container.environment.addStyle({"height":_height-31+"px"});el.left.xhr.container.environment.addStyle({"height":_height-32+"px"});el.left.str.container.environment.addStyle({"height":_height-32+"px"});}},refreshDOM:function(){with(firebug){d.dom.open(eval(el.button.dom.textbox.environment.getElement().value),el.left.dom.container);if(d.html.nIndex=="dom"){firebug.d.html.navigate("dom")}}},refreshSize:function(){with(firebug){if(!internal.init)
+return;var dim=lib.util.GetViewport();el.main.environment.addStyle({"width":dim.width+"px"});el.mainiframe.environment.addStyle({"width":dim.width+"px"});if(lib.env.ie6)
+win.setVerticalPosition(dim);}},setVerticalPosition:function(_dim,_event){with(firebug){var dim=_dim||lib.util.GetViewport();el.main.environment.addStyle({"top":dim.height-el.main.environment.getSize().offsetHeight+Math.max(document.documentElement.scrollTop,document.body.scrollTop)+"px"});el.mainiframe.environment.addStyle({"top":dim.height-el.main.environment.getSize().offsetHeight+Math.max(document.documentElement.scrollTop,document.body.scrollTop)+"px"});}}},d:{clean:function(_element){with(firebug){_element.update("");}},console:{addLine:function(){with(firebug){return new lib.element("DIV").attribute.addClass("Row").insert(el.left.console.monitor);}},cache:[],clear:function(){with(firebug){d.clean(el.left.console.monitor);d.console.cache=[];}},formatArgs:function(){with(firebug){var content=[];for(var i=0,len=arguments.length;i<len;i++){content.push(d.highlight(arguments[i],false,false,true));}
+return content.join(" ");}},history:[],historyIndex:0,openObject:function(_index){with(firebug){d.dom.open(d.console.cache[_index],el.left.dom.container,lib.env.ie);d.navigate("dom");}},print:function(_cmd,_text){with(firebug){d.console.addLine().attribute.addClass("Arrow").update(">>> "+_cmd);d.console.addLine().update(d.highlight(_text,false,false,true));d.console.scroll();}},printException:function(_exception){with(firebug){var message=_exception.description||_exception.message||_exception;if(_exception.fileName){message+=' ('+(_exception.name&&(_exception.name+', ')||'')+getFileName(_exception.fileName)+', '+_exception.lineNumber+')';}
+d.console.addLine().attribute.addClass("Error").update("<strong>Error: </strong>"+message,true);}},eval:function(_cmd){var result;with(firebug){if(_cmd.length==0)
+return;el.left.console.input.environment.getElement().value="";d.console.historyIndex=d.console.history.push(_cmd);try{if(_cmd==='console.firebug'){d.console.addLine().attribute.addClass("Arrow").update(firebug.version);}else{result=eval.call(window,_cmd);d.console.print(_cmd,result);}}catch(e){d.console.addLine().attribute.addClass("Arrow").update(">>> "+_cmd);d.console.printException(e);}
+d.console.scroll();}},scroll:function(){with(firebug){el.left.console.monitor.environment.getElement().parentNode.scrollTop=Math.abs(el.left.console.monitor.environment.getSize().offsetHeight-(el.left.console.monitor.element.parentNode.offsetHeight-11));}},run:function(_command){with(firebug){if(!internal.init){d.console.cache.push({"command":_command,"arg":Array.prototype.slice.call(arguments,1)});}else{d.console.cmd[_command].apply(window,Array.prototype.slice.call(arguments,1));}}},toggleML:function(){with(firebug){var open=!env.ml;env.ml=!env.ml;d.navigateRightColumn("console",open);el[open?"left":"right"].console.mlButton.environment.addStyle({display:"none"});el[!open?"left":"right"].console.mlButton.environment.addStyle({display:"block"});el.left.console.mlButton.attribute[(open?"add":"remove")+"Class"]("CloseML");}},countMap:{},timeMap:{},cmd:{log:function(_value){with(firebug){var args=d.console.formatArgs.apply(window,arguments);d.console.addLine().attribute.addClass("Log").update(args);d.console.scroll();}},warn:function(_value){with(firebug){var args=d.console.formatArgs.apply(window,arguments);d.console.addLine().attribute.addClass("Warn").update(args);d.console.scroll();}},info:function(_value){with(firebug){var args=d.console.formatArgs.apply(window,arguments);d.console.addLine().attribute.addClass("Info").update(args);d.console.scroll();}},debug:function(_value){with(firebug){var args=d.console.formatArgs.apply(window,arguments);d.console.addLine().attribute.addClass("Debug").update(args);d.console.scroll();}},error:function(_value){with(firebug){var args=d.console.formatArgs.apply(window,arguments);d.console.addLine().attribute.addClass("Error").update(args);d.console.scroll();}},trace:function(_value){with(firebug){var stackAmt=3,f=arguments.caller,isArray=lib.util.IsArray(f);if((!isArray&&f)||(isArray&&f.length>0)){d.console.addLine().attribute.addClass("Arrow").update(">>> console.trace(stack)");for(var i=0;i<stackAmt;i++){var func=f.toString(),args=f.arguments;d.dom.open({"function":func,"arguments":args},d.console.addLine());f=f.caller;}}}},dir:function(_value){with(firebug){d.console.addLine().attribute.addClass("Arrow").update(">>> console.dir("+_value+")");d.dom.open(_value,d.console.addLine());}},dirxml:function(){with(firebug){d.console.cmd.log.apply(this,arguments);}},time:function(_name){with(firebug){d.console.timeMap[_name]=new Date().getTime();}},timeEnd:function(_name){with(firebug){if(_name in d.console.timeMap){var delta=new Date().getTime()-d.console.timeMap[_name],args=d.console.formatArgs.apply(window,[_name+":",delta+"ms"]);d.console.addLine().attribute.addClass("log").update(args);delete d.console.timeMap[_name];}}},count:function(_name){with(firebug){if(!d.console.countMap[_name])
+d.console.countMap[_name]=0;d.console.countMap[_name]++;d.console.cmd.log.apply(window,[_name,d.console.countMap[_name]]);}},group:function(){with(firebug){d.console.cmd.log.apply(this,["console.group is not supported"]);}},groupEnd:function(){with(firebug){d.console.cmd.log.apply(this,["console.groupEnd is not supported"]);}},profile:function(){with(firebug){d.console.cmd.log.apply(this,["console.profile is not supported"]);}},profileEnd:function(){with(firebug){d.console.cmd.log.apply(this,["console.profileEnd is not supported"]);}}}},css:{index:-1,open:function(_index){with(firebug){var item=internal.targetWindow.document.styleSheets[_index],uri=item.href;try{var rules=item[lib.env.ie?"rules":"cssRules"],str="";for(var i=0;i<rules.length;i++){var item=rules[i];var selector=item.selectorText;var cssText=lib.env.ie?item.style.cssText:item.cssText.match(/\{(.*)\}/)[1];str+=d.css.printRule(selector,cssText.split(";"),el.left.css.container);}}catch(e){str="<em>Access to restricted URI denied</em>";}
+el.left.css.container.update(str);}},printRule:function(_selector,_css,_layer){with(firebug){var str="<div class='Selector'>"+_selector+" {</div>";for(var i=0,len=_css.length;i<len;i++){var item=_css[i];str+="<div class='CSSText'>"+item.replace(/(.+\:)(.+)/,"<span class='CSSProperty'>$1</span><span class='CSSValue'>$2;</span>")+"</div>";}
+str+="<div class='Selector'>}</div>";return str;}},refresh:function(){with(firebug){el.button.css.selectbox.update("");var collection=internal.targetWindow.document.styleSheets;for(var i=0,len=collection.length;i<len;i++){var uri=getFileName(collection[i].href);d.css.index=d.css.index<0?i:d.css.index;el.button.css.selectbox.child.add(new lib.element("OPTION").attribute.set("value",i).update(uri))};d.css.open(d.css.index);}}},dom:{open:function(_object,_layer){with(firebug){_layer.clean();var container=new lib.element("DIV").attribute.addClass("DOMContent").insert(_layer);d.dom.print(_object,container);}},print:function(_object,_parent,_inTree){with(firebug){var obj=_object||window,parentElement=_parent;parentElement.update("");if(parentElement.opened&&parentElement!=el.left.dom.container){parentElement.environment.getParent().lib.child.get()[0].lib.child.get()[0].lib.attribute.removeClass("Opened");parentElement.opened=false;parentElement.environment.addStyle({"display":"none"});return;}
+if(_inTree)
+parentElement.environment.getParent().lib.child.get()[0].lib.child.get()[0].lib.attribute.addClass("Opened");parentElement.opened=true;for(var key in obj){try{if(env.hideDOMFunctions&&typeof(obj[key])=="function")continue;var value=obj[key],property=key,container=new lib.element("DIV").attribute.addClass("DOMRow").insert(parentElement),left=new lib.element("DIV").attribute.addClass("DOMRowLeft").insert(container),right=new lib.element("DIV").attribute.addClass("DOMRowRight").insert(container);container.child.add(new lib.element("DIV").attribute.addClass('Clear'));var link=new lib.element("A").attribute.addClass(typeof value=="object"&&Boolean(value)?"Property Object":"Property").update(property).insert(left);right.update(d.highlight(value,false,true));var subContainer=new lib.element("DIV").attribute.addClass("DOMRowSubContainer").insert(container);if(typeof value!="object"||Boolean(value)==false)
+continue;link.event.addListener("click",lib.util.Curry(d.dom.print,window,value,subContainer,true));}catch(e){}}
+parentElement.environment.addStyle({"display":"block"});}}},highlight:function(_value,_inObject,_inArray,_link){with(firebug){var isArray=false,isHash,isElement=false,vtype=typeof _value,result=[];if(vtype=="object"){if(Object.prototype.toString.call(_value)==="[object Date]"){vtype="date";}else if(Object.prototype.toString.call(_value)==="[object String]"){vtype="string";}else if(Object.prototype.toString.call(_value)==="[object Boolean]"){vtype="boolean";}else if(Object.prototype.toString.call(_value)==="[object RegExp]"){vtype="regexp";}}
+try{isArray=lib.util.IsArray(_value);isHash=lib.util.IsHash(_value);isElement=_value!=undefined&&Boolean(_value.nodeName)&&Boolean(_value.nodeType);if(_value==null||vtype=="number"||vtype=="string"||vtype=="boolean"||(vtype=="function"&&_value.nodeName!="OBJECT")||vtype=="regexp"||vtype=="date"){if(_value==null){if(_value===undefined){result.push("<span class='Null'>undefined</span>");}else{result.push("<span class='Null'>null</span>");}}else if(vtype=="regexp"){result.push("<span class='Maroon'>"+_value+"</span>");}else if(vtype=="date"){result.push("<span class='DarkBlue'>'"+_value+"'</span>");}else if(vtype=="boolean"||vtype=="number"){result.push("<span class='DarkBlue'>"+_value+"</span>");}else if(vtype=="function"){result.push("<span class='"+(_inObject?"Italic Gray":"Green")+"'>function()</span>");}else{result.push("<span class='Red'>\""+(!_inObject&&!_inArray?_value:_value.substring(0,35)+(_value.length>35?" ...":"")).replace(/\n/g,"\\n").replace(/\s/g,"&nbsp;").replace(/>/g,"&#62;").replace(/</g,"&#60;")+"\"</span>");}}
+else if(isElement){if(_value.nodeType==3)
+result.push(d.highlight(_value.nodeValue));else if(_inObject){result.push("<span class='Gray Italic'>"+_value.nodeName.toLowerCase()+"</span>");}else{result.push("<span class='Blue"+(!_link?"'":" ObjectLink' onmouseover='this.className=this.className.replace(\"ObjectLink\",\"ObjectLinkHover\")' onmouseout='this.className=this.className.replace(\"ObjectLinkHover\",\"ObjectLink\")' onclick='firebug.d.html.inspect(firebug.d.console.cache["+(d.console.cache.push(_value)-1)+"])'")+"'>");if(_inArray){result.push(_value.nodeName.toLowerCase());if(_value.getAttribute){if(_value.getAttribute&&_value.getAttribute("id"))
+result.push("<span class='DarkBlue'>#"+_value.getAttribute("id")+"</span>");var elClass=_value.getAttribute(lib.env.ie&&!lib.env.ie8?"className":"class")||"";result.push(!elClass?"":"<span class='Red'>."+elClass.split(" ")[0]+"</span>");}
+result.push("</span>");}else{result.push("<span class='DarkBlue'>&#60;<span class='Blue TagName'>"+_value.nodeName.toLowerCase());if(_value.attributes){for(var i=0,len=_value.attributes.length;i<len;i++){var item=_value.attributes[i];if(!lib.env.ie||item.nodeValue)
+result.push(" <span class='DarkBlue'>"+item.nodeName+"=\"<span class='Red'>"+item.nodeValue+"</span>\"</span>");}}
+result.push("</span>&#62;</span>");}}}
+else if(isArray||isHash){if(isArray){if(_inObject){result.push("<span class='Gray Italic'>["+_value.length+"]</span>");}else{result.push("<span class='Strong'>[ ");for(var i=0,len=_value.length;i<len;i++){if((_inObject||_inArray)&&i>3){result.push(", <span class='Strong Gray'>"+(len-4)+" More...</span>");break;}
+result.push((i>0?", ":"")+d.highlight(_value[i],false,true,true));}
+result.push(" ]</span>");}}else if(_inObject){result.push("<span class='Gray Italic'>Object</span>");}else{result.push("<span class='Strong Green"+(!_link?"'":" ObjectLink' onmouseover='this.className=this.className.replace(\"ObjectLink\",\"ObjectLinkHover\")' onmouseout='this.className=this.className.replace(\"ObjectLinkHover\",\"ObjectLink\")' onclick='firebug.d.console.openObject("+(d.console.cache.push(_value)-1)+")'")+">Object");var i=0;for(var key in _value){var value=_value[key];if((_inObject||_inArray)&&i>3){result.push(" <span class='Strong Gray'>More...</span>");break;}
+result.push(" "+key+"="+d.highlight(value,true));i++;}
+result.push("</span>");}}else{result.push(["<span class'Gray Italic'>"+_value+"</span>"]);}}catch(e){result.push("..");}
+return result.join("");}},html:{nIndex:"computedStyle",current:null,highlight:function(_element,_clear,_event){with(firebug){if(_element.firebugElement){return;}
+if(_clear){internal.targetWindow.firebug.el.bgInspector.environment.addStyle({"display":"none"});return;}
+d.inspector.inspect(_element,true);}},inspect:function(_element){var map=[],parentLayer,t,link,tagName,searchEl,parent=_element;while(parent){map.push(parent);if(parent==firebug.internal.targetWindow.document.body)break;parent=parent.parentNode;}
+map=map.reverse();with(firebug){if(env.dIndex!="html"){internal.targetWindow.firebug.d.navigate("html");}
+internal.targetWindow.firebug.d.inspector.toggle(false);for(t=0;t<el.left.html.container.child.get().length;t++){searchEl=el.left.html.container.child.get()[t];if(/<body/i.test(searchEl.innerText||searchEl.textContent)){parentLayer=el.left.html.container.child.get()[t].childNodes[1].lib;break;}}
+if(!parentLayer){parentLayer=el.left.html.container.child.get()[3].childNodes[1].lib;}
+for(t=0,len=map.length;map[t];t++){if(t==len-1){link=parentLayer.environment.getElement().previousSibling.lib;link.attribute.addClass("Selected");if(link.element.scrollIntoView){link.element.scrollIntoView(false);}
+if(d.html.current){d.html.current[1].attribute.removeClass("Selected");}
+d.html.current=[_element,link];return;}
+parentLayer=d.html.openHtmlTree(map[t],parentLayer,map[t+1]);}}},navigate:function(_index,_element){with(firebug){el.right.html.nav[d.html.nIndex].attribute.removeClass("Selected");el.right.html.nav[_index].attribute.addClass("Selected");d.html.nIndex=_index;d.html.openProperties();}},openHtmlTree:function(_element,_parent,_returnParentElementByElement,_event){with(firebug){var element=_element||internal.targetWindow.document.documentElement,parent=_parent||el.left.html.container,returnParentEl=_returnParentElementByElement||null,returnParentVal=null,len=element.childNodes.length,nodeLink;if(!window.Node){window.Node={TEXT_NODE:3,COMMENT_NODE:8};}
+if(parent!=el.left.html.container){nodeLink=parent.environment.getParent().lib.child.get()[0].lib;if(d.html.current){d.html.current[1].attribute.removeClass("Selected");}
+nodeLink.attribute.addClass("Selected");d.html.current=[_element,nodeLink];d.html.openProperties();};if(element.childNodes&&(len==0||(len==1&&element.childNodes[0].nodeType==Node.TEXT_NODE)))return;parent.clean();if(parent.opened&&Boolean(_returnParentElementByElement)==false){parent.opened=false;parent.element.previousSibling.lib.attribute.removeClass("Open");parent.element.lib.attribute.removeClass("OpenSubContainer");return;};if(parent!=el.left.html.container){parent.element.previousSibling.lib.attribute.addClass("Open");parent.element.lib.attribute.addClass("OpenSubContainer");parent.opened=true;};if(element==document.documentElement){new lib.element("A").attribute.addClass("Block").update("<span class='DarkBlue'>&#60;<span class='Blue'>html</span>&#62;").insert(parent);};for(var i=0;i<=len;i++){if(i==len){new lib.element("A").attribute.addClass("Block").update("<span class='DarkBlue'>&#60;/<span class='Blue'>"+element.nodeName.toLowerCase()+"</span>&#62;").insert(container);break;}
+var item=element.childNodes[i];if(item.nodeType!=Node.TEXT_NODE&&!item.getAttribute('firebugIgnore')){var container=new lib.element().attribute.addClass("Block").insert(parent),link=new lib.element("A").attribute.addClass("Link").insert(container),spacer=new lib.element("SPAN").attribute.addClass("Spacer").update("&nbsp;").insert(link),html=new lib.element("SPAN").attribute.addClass("Content").update(d.highlight(item)).insert(link),subContainer=new lib.element("DIV").attribute.addClass("SubContainer").insert(container),view;if(item.nodeType==Node.COMMENT_NODE){continue;}
+view=lib.util.Element.getView(item);link.event.addListener("click",lib.util.Curry(d.html.openHtmlTree,window,item,subContainer,false));link.event.addListener("mouseover",lib.util.Curry(d.html.highlight,window,item,false));link.event.addListener("mouseout",lib.util.Curry(d.html.highlight,window,item,true));returnParentVal=returnParentEl==item?subContainer:returnParentVal;if(d.html.current==null&&item==document.body){link.attribute.addClass("Selected");link.attribute.addClass("Parent");d.html.current=[item,link];d.html.openHtmlTree(item,subContainer);}
+if(element.nodeName!="HEAD"&&element!=document.documentElement&&(view.visibility=="hidden"||view.display=="none")){container.attribute.addClass("Unvisible");};if(item.childNodes){var childLen=item.childNodes.length;if(childLen==1&&item.childNodes[0].nodeType==Node.TEXT_NODE){if(isFinite(env.textNodeChars)&&parseInt(env.textNodeChars)>0){html.child.add(document.createTextNode(item.childNodes[0].nodeValue.substring(0,env.textNodeChars)));}else{html.child.add(document.createTextNode(item.childNodes[0].nodeValue));}
+html.child.add(document.createTextNode("</"));html.child.add(new lib.element("span").attribute.addClass("Blue").update(item.nodeName.toLowerCase()).environment.getElement());html.child.add(document.createTextNode(">"));continue;}
+else if(childLen>0){link.attribute.addClass("Parent");}}}};return returnParentVal;}},openProperties:function(){with(firebug){var index=d.html.nIndex;var node=d.html.current[0];d.clean(el.right.html.content);var str="";switch(index){case"computedStyle":var property=["opacity","filter","azimuth","background","backgroundAttachment","backgroundColor","backgroundImage","backgroundPosition","backgroundRepeat","border","borderCollapse","borderColor","borderSpacing","borderStyle","borderTop","borderRight","borderBottom","borderLeft","borderTopColor","borderRightColor","borderBottomColor","borderLeftColor","borderTopStyle","borderRightStyle","borderBottomStyle","borderLeftStyle","borderTopWidth","borderRightWidth","borderBottomWidth","borderLeftWidth","borderWidth","bottom","captionSide","clear","clip","color","content","counterIncrement","counterReset","cue","cueAfter","cueBefore","cursor","direction","display","elevation","emptyCells","cssFloat","font","fontFamily","fontSize","fontSizeAdjust","fontStretch","fontStyle","fontVariant","fontWeight","height","left","letterSpacing","lineHeight","listStyle","listStyleImage","listStylePosition","listStyleType","margin","marginTop","marginRight","marginBottom","marginLeft","markerOffset","marks","maxHeight","maxWidth","minHeight","minWidth","orphans","outline","outlineColor","outlineStyle","outlineWidth","overflow","padding","paddingTop","paddingRight","paddingBottom","paddingLeft","page","pageBreakAfter","pageBreakBefore","pageBreakInside","pause","pauseAfter","pauseBefore","pitch","pitchRange","playDuring","position","quotes","richness","right","size","speak","speakHeader","speakNumeral","speakPunctuation","speechRate","stress","tableLayout","textAlign","textDecoration","textIndent","textShadow","textTransform","top","unicodeBidi","verticalAlign","visibility","voiceFamily","volume","whiteSpace","widows","width","wordSpacing","zIndex"].sort();var view=document.defaultView?document.defaultView.getComputedStyle(node,null):node.currentStyle;for(var i=0,len=property.length;i<len;i++){var item=property[i];if(!view[item])continue;str+="<div class='CSSItem'><div class='CSSProperty'>"+item+"</div><div class='CSSValue'>"+d.highlight(view[item])+"</div></div>";}
+el.right.html.content.update(str);break;case"dom":d.dom.open(node,el.right.html.content,lib.env.ie);break;}}}},inspector:{enabled:false,el:null,inspect:function(_element,_bgInspector){with(firebug){var pos=internal.targetWindow.firebug.lib.util.Element.getPosition(_element);internal.targetWindow.firebug.el[_bgInspector&&"bgInspector"||"borderInspector"].environment.addStyle({"width":_element.offsetWidth+"px","height":_element.offsetHeight+"px","top":pos.offsetTop-(_bgInspector?0:2)+"px","left":pos.offsetLeft-(_bgInspector?0:2)+"px","display":"block"});if(!_bgInspector){d.inspector.el=_element;}};},toggle:function(_absoluteValue,_event){with(firebug){if(_absoluteValue==d.inspector.enabled)
+return;d.inspector.enabled=_absoluteValue!=undefined&&!_absoluteValue.clientX?_absoluteValue:!d.inspector.enabled;el.button.inspect.attribute[(d.inspector.enabled?"add":"remove")+"Class"]("Enabled");if(d.inspector.enabled==false){el.borderInspector.environment.addStyle({"display":"none"});d.inspector.el=null;}else if(lib.env.dIndex!="html"){if(internal.popupWin){internal.popupWin.firebug.d.navigate("html");}else{d.navigate("html");}}}}},scripts:{index:-1,lineNumbers:false,open:function(_index){with(firebug){d.scripts.index=_index;el.left.scripts.container.update("");var i=0,script=document.getElementsByTagName("script")[_index],uri=script.src||document.location.href,source;try{if(uri!=document.location.href){source=internal.cache[uri]||lib.xhr.get(uri).responseText;internal.cache[uri]=source;}else{source=script.innerHTML;}
+source=source.replace(/<|>/g,function(_ch){return({"<":"&#60;",">":"&#62;"})[_ch];});if(d.scripts.lineNumbers){source=source.replace(/(^)|\n/g,function(_ch){i++;return"\n"+i+" ";});}
+el.left.scripts.container.update(source);}catch(e){el.left.scripts.container.child.add(new lib.element("DIV").attribute.addClass("CodeContainer").update("<em>Access to restricted URI denied</em>"));}}},toggleLineNumbers:function(){with(firebug){d.scripts.lineNumbers=!d.scripts.lineNumbers;el.button.scripts.lineNumbers.attribute[(d.scripts.lineNumbers?"add":"remove")+"Class"]("Enabled");d.scripts.open(d.scripts.index);}},refresh:function(){with(firebug){el.button.scripts.selectbox.clean();var collection=internal.targetWindow.document.getElementsByTagName("script");for(var i=0,len=collection.length;i<len;i++){var item=collection[i],fileName=getFileName(item.src||item.baseURI||"..");d.scripts.index=d.scripts.index<0?i:d.scripts.index;el.button.scripts.selectbox.child.add(new lib.element("OPTION").attribute.set("value",i).update(fileName));}
+d.scripts.open(d.scripts.index);}}},str:{open:function(_str){with(firebug){d.navigate("str");el.left.str.container.update(_str.replace(/\n/g,"<br />"))}}},xhr:{objects:[],addObject:function(){with(firebug){for(var i=0,len=arguments.length;i<len;i++){try{var item=arguments[i],val=internal.targetWindow.eval(item);d.xhr.objects.push([item,val]);}catch(e){continue;}}}},open:function(){with(firebug){el.left.xhr.container.update("");el.left.xhr.name=new lib.element("DIV").attribute.addClass("BlockContent").insert(new lib.element("DIV").attribute.addClass("Block").environment.addStyle({"width":"20%"}).insert(el.left.xhr.container));el.left.xhr.nameTitle=new lib.element("STRONG").update("Object Name:").insert(el.left.xhr.name);el.left.xhr.nameContent=new lib.element("DIV").insert(el.left.xhr.name);el.left.xhr.status=new lib.element("DIV").attribute.addClass("BlockContent").insert(new lib.element("DIV").attribute.addClass("Block").environment.addStyle({"width":"10%"}).insert(el.left.xhr.container));el.left.xhr.statusTitle=new lib.element("STRONG").update("Status:").insert(el.left.xhr.status);el.left.xhr.statusContent=new lib.element("DIV").insert(el.left.xhr.status);el.left.xhr.readystate=new lib.element("DIV").attribute.addClass("BlockContent").insert(new lib.element("DIV").environment.addStyle({"width":"15%"}).attribute.addClass("Block").insert(el.left.xhr.container));el.left.xhr.readystateTitle=el.left.xhr.nameTitle=new lib.element("STRONG").update("Ready State:").insert(el.left.xhr.readystate);el.left.xhr.readystateContent=new lib.element("DIV").insert(el.left.xhr.readystate);el.left.xhr.response=new lib.element("DIV").attribute.addClass("BlockContent").insert(new lib.element("DIV").environment.addStyle({"width":(lib.env.ie?"50":"55")+"%"}).attribute.addClass("Block").insert(el.left.xhr.container));el.left.xhr.responseTitle=new lib.element("STRONG").update("Response:").insert(el.left.xhr.response);el.left.xhr.responseContent=new lib.element("DIV").insert(el.left.xhr.response);setTimeout(d.xhr.refresh,500);}},refresh:function(){with(firebug){el.left.xhr.nameContent.update("");el.left.xhr.statusContent.update("");el.left.xhr.readystateContent.update("");el.left.xhr.responseContent.update("");for(var i=0,len=d.xhr.objects.length;i<len;i++){var item=d.xhr.objects[i],response=item[1].responseText;if(Boolean(item[1])==false)continue;el.left.xhr.nameContent.child.add(new lib.element("span").update(item[0]));try{el.left.xhr.statusContent.child.add(new lib.element("span").update(item[1].status));}catch(e){el.left.xhr.statusContent.child.add(new lib.element("span").update("&nbsp;"));}
+el.left.xhr.readystateContent.child.add(new lib.element("span").update(item[1].readyState));el.left.xhr.responseContent.child.add(new lib.element("span").child.add(new lib.element("A").event.addListener("click",lib.util.Curry(d.str.open,window,response)).update("&nbsp;"+response.substring(0,50))));};if(env.dIndex=="xhr")
+setTimeout(d.xhr.refresh,500);}}},navigateRightColumn:function(_index,_open){with(firebug){el.left.container.environment.addStyle({"width":_open?"70%":"100%"});el.right.container.environment.addStyle({"display":_open?"block":"none"});}},navigate:function(_index){with(firebug){var open=_index,close=env.dIndex;env.dIndex=open;settings.hide();el.button[close].container.environment.addStyle({"display":"none"});el.left[close].container.environment.addStyle({"display":"none"});el.right[close].container.environment.addStyle({"display":"none"});el.button[open].container.environment.addStyle({"display":"inline"});el.left[open].container.environment.addStyle({"display":"block"});el.right[open].container.environment.addStyle({"display":"block"});if(el.nav[close])
+el.nav[close].attribute.removeClass("Selected");if(el.nav[open])
+el.nav[open].attribute.addClass("Selected");switch(open){case"console":d.navigateRightColumn(_index);break;case"html":d.navigateRightColumn(_index,true);if(!d.html.current){var t=Number(new Date);d.html.openHtmlTree();}
+break;case"css":d.navigateRightColumn(_index,true);d.css.refresh();break;case"scripts":d.navigateRightColumn(_index);d.scripts.refresh();break;case"dom":d.navigateRightColumn(_index);if(el.left.dom.container.environment.getElement().innerHTML==""){var t=Number(new Date);d.dom.open(eval(el.button.dom.textbox.environment.getElement().value),el.left.dom.container);}
+break;case"xhr":d.navigateRightColumn(_index);d.xhr.open();break;}}}},getFileName:function(_path){var match=_path&&_path.match(/[\w\-\.\?\=\&]+$/);return match&&match[0]||_path;},cancelEvent:function(_event){if(_event.stopPropagation)
+_event.stopPropagation();if(_event.preventDefault)
+_event.preventDefault();},getSelection:function(_el){with(firebug){if(lib.env.ie){var range=document.selection.createRange(),stored=range.duplicate();stored.moveToElementText(_el);stored.setEndPoint('EndToEnd',range);_el.selectionStart=stored.text.length-range.text.length;_el.selectionEnd=_el.selectionStart+range.text.length;}
+return{start:_el.selectionStart,length:_el.selectionEnd-_el.selectionStart}}},tab:function(_el,_event){with(firebug){if(_event.keyCode==9){if(_el.setSelectionRange){var position=firebug.getSelection(_el);_el.value=_el.value.substring(0,position.start)+String.fromCharCode(9)+_el.value.substring(position.start+position.length,_el.value.length);_el.setSelectionRange(position.start+1,position.start+1);}else if(document.selection){var range=document.selection.createRange(),isCollapsed=range.text=='';range.text=String.fromCharCode(9);range.moveStart('character',-1);}
+firebug.cancelEvent(_event);if(lib.env.ie)
+setTimeout(_el.focus,100);};}},listen:{addXhrObject:function(){with(firebug){d.xhr.addObject.apply(internal.targetWindow,el.button.xhr.textbox.environment.getElement().value.split(","));}},consoleTextbox:function(_event){with(firebug){if(_event.keyCode==13&&(env.multilinemode==false||_event.shiftKey==false)){d.console.historyIndex=d.console.history.length;d.console.eval(el.left.console.input.environment.getElement().value);return false;}
+switch(_event.keyCode){case 40:if(d.console.history[d.console.historyIndex+1]){d.console.historyIndex+=1;el.left.console.input.update(d.console.history[d.console.historyIndex]);}
+break;case 38:if(d.console.history[d.console.historyIndex-1]){d.console.historyIndex-=1;el.left.console.input.update(d.console.history[d.console.historyIndex]);}
+break;}}},cssSelectbox:function(){with(firebug){d.css.open(el.button.css.selectbox.environment.getElement().selectedIndex);}},domTextbox:function(_event){with(firebug){if(_event.keyCode==13){d.dom.open(eval(el.button.dom.textbox.environment.getElement().value),el.left.dom.container);}}},inspector:function(){with(firebug){if(internal.popupWin){internal.popupWin.firebug.d.html.inspect(firebug.d.inspector.el);}else{firebug.d.html.inspect(firebug.d.inspector.el);}}},keyboard:function(_event){with(firebug){if(_event.keyCode==27&&d.inspector.enabled){d.inspector.toggle();}else if(_event.keyCode===123&&(_event.ctrlKey||_event.metaKey)){if(internal.isPopup){win.dock();}else{win.newWindow();}}else if((_event.keyCode===123&&(!_event.ctrlKey&&!_event.metaKey))||(_event.keyCode===76&&(_event.ctrlKey||_event.metaKey)&&_event.shiftKey)||(_event.keyCode===13&&_event.shiftKey)){if(internal.isPopup){win.dock();}else if(el.main.environment.getStyle("display")==='none'){win.show();}else{win.hide();}}}},mouse:function(_event){with(firebug){var target;if(document.elementFromPoint){target=document.elementFromPoint(_event.clientX,_event.clientY);}else{if(lib.env.ie){target=_event.srcElement;}else{target=_event.explicitOriginalTarget||_event.target;}}
+if(d.inspector.enabled&&target!=document.body&&target!=document.firstChild&&target!=document.childNodes[1]&&target!=el.borderInspector.environment.getElement()&&target!=el.main.environment.getElement()&&target.offsetParent!=el.main.environment.getElement()){d.inspector.inspect(target);}}},runMultiline:function(){with(firebug){d.console.eval.call(window,el.right.console.input.environment.getElement().value);}},runCSS:function(){with(firebug){var source=el.right.css.input.environment.getElement().value.replace(/\n|\t/g,"").split("}");for(var i=0,len=source.length;i<len;i++){var item=source[i]+"}",rule=!lib.env.ie?item:item.split(/{|}/),styleSheet=document.styleSheets[0];if(item.match(/.+\{.+\}/)){if(lib.env.ie)
+styleSheet.addRule(rule[0],rule[1]);else
+styleSheet.insertRule(rule,styleSheet.cssRules.length);}}}},scriptsSelectbox:function(){with(firebug){d.scripts.open(parseInt(el.button.scripts.selectbox.environment.getElement().value));}},xhrTextbox:function(_event){with(firebug){if(_event.keyCode==13){d.xhr.addObject.apply(internal.targetWindow,el.button.xhr.textbox.environment.getElement().value.split(","));}}}}};(function(_scope){_scope.lib={};var pi=_scope.lib;pi.version=[1.1,2008091000];pi.env={ie:/MSIE/i.test(navigator.userAgent),ie6:/MSIE 6/i.test(navigator.userAgent),ie7:/MSIE 7/i.test(navigator.userAgent),ie8:/MSIE 8/i.test(navigator.userAgent),firefox:/Firefox/i.test(navigator.userAgent),opera:/Opera/i.test(navigator.userAgent),webkit:/Webkit/i.test(navigator.userAgent),camino:/Camino/i.test(navigator.userAgent)};pi.get=function(){return document.getElementById(arguments[0]);};pi.get.byTag=function(){return document.getElementsByTagName(arguments[0]);};pi.get.byClass=function(){return document.getElementsByClassName.apply(document,arguments);};pi.util={Array:{clone:function(_array,_undeep){var tmp=[];Array.prototype.push.apply(tmp,_array);pi.util.Array.forEach(tmp,function(_item,_index,_source){if(_item instanceof Array&&!_undeep)
+_source[_index]=pi.util.Array.clone(_source[_index]);});return tmp;},count:function(_array,_value){var count=0;pi.util.Array.forEach(_array,function(){count+=Number(arguments[0]==_value);});return count;},forEach:function(_array,_function){if(_array.forEach)
+return _array.forEach(_function);for(var i=0,len=_array.length;i<len;i++)
+_function.apply(_array,[_array[i],i,_array]);},getLatest:function(_array){return _array[_array.length-1];},indexOf:function(_array,_value){if(!pi.env.ie){return _array.indexOf(_value);};var index=-1;for(var i=0,len=_array.length;i<len;i++){if(_array[i]==_value){index=i;break;}}
+return index;},remove:function(_array,_index){var result=_array.slice(0,_index);_array=Array.prototype.push.apply(result,_array.slice(_index+1));return result;}},Curry:function(_fn,_scope){var fn=_fn,scope=_scope||window,args=Array.prototype.slice.call(arguments,2);return function(){return fn.apply(scope,args.concat(Array.prototype.slice.call(arguments,0)));};},Extend:function(_superClass,_prototype,_skipClonning){var object=new pi.base;if(_prototype["$Init"]){object.init=_prototype["$Init"];delete _prototype["$Init"];};object.body=_superClass==pi.base?_prototype:pi.util.Hash.merge(_prototype,_superClass.prototype);object.init=object.init||function(){if(_superClass!=pi.base)
+_superClass.apply(this,arguments);};return object.build(_skipClonning);},IsArray:function(_object){if(_object===null){return false;}
+if(window.NodeList&&window.NamedNodeMap&&!pi.env.ie8){if(_object instanceof Array||_object instanceof NodeList||_object instanceof NamedNodeMap||(window.HTMLCollection&&_object instanceof HTMLCollection))
+return true;};if(!_object||_object==window||typeof _object=="function"||typeof _object=="string"||typeof _object.length!="number"){return false};var len=_object.length;if(len>0&&_object[0]!=undefined&&_object[len-1]!=undefined){return true;}else{for(var key in _object){if(key!="item"&&key!="length"&&key!="setNamedItemNS"&&key!="setNamedItem"&&key!="getNamedItem"&&key!="removeNamedItem"&&key!="getNamedItemNS"&&key!="removeNamedItemNS"&&key!="tags"){return false;}}
+return true};},IsHash:function(_object){return _object&&typeof _object=="object"&&(_object==window||_object instanceof Object)&&!_object.nodeName&&!pi.util.IsArray(_object)},Init:[],AddEvent:function(_element,_eventName,_fn,_useCapture){_element[pi.env.ie?"attachEvent":"addEventListener"]((pi.env.ie?"on":"")+_eventName,_fn,_useCapture||false);return pi.util.Curry(pi.util.AddEvent,this,_element);},RemoveEvent:function(_element,_eventName,_fn,_useCapture){_element[pi.env.ie?"detachEvent":"removeEventListener"]((pi.env.ie?"on":"")+_eventName,_fn,_useCapture||false);return pi.util.Curry(pi.util.RemoveEvent,this,_element);},Element:{addClass:function(_element,_class){if(!pi.util.Element.hasClass(_element,_class))
+pi.util.Element.setClass(_element,pi.util.Element.getClass(_element)+" "+_class);},getClass:function(_element){return _element.getAttribute(pi.env.ie&&!pi.env.ie8?"className":"class")||"";},hasClass:function(_element,_class){return pi.util.Array.indexOf(pi.util.Element.getClass(_element).split(" "),_class)>-1;},removeClass:function(_element,_class){if(pi.util.Element.hasClass(_element,_class)){var names=pi.util.Element.getClass(_element,_class).split(" ");pi.util.Element.setClass(_element,pi.util.Array.remove(names,pi.util.Array.indexOf(names,_class)).join(" "));}},setClass:function(_element,_value){if(pi.env.ie8){_element.setAttribute("className",_value);_element.setAttribute("class",_value);}else{_element.setAttribute(pi.env.ie?"className":"class",_value);}},toggleClass:function(){if(pi.util.Element.hasClass.apply(this,arguments))
+pi.util.Element.removeClass.apply(this,arguments);else
+pi.util.Element.addClass.apply(this,arguments);},getOpacity:function(_styleObject){var styleObject=_styleObject;if(!pi.env.ie)
+return styleObject["opacity"];var alpha=styleObject["filter"].match(/opacity\=(\d+)/i);return alpha?alpha[1]/100:1;},setOpacity:function(_element,_value){if(!pi.env.ie)
+return pi.util.Element.addStyle(_element,{"opacity":_value});_value*=100;pi.util.Element.addStyle(_element,{"filter":"alpha(opacity="+_value+")"});return this._parent_;},getPosition:function(_element){var parent=_element,offsetLeft=document.body.offsetLeft,offsetTop=document.body.offsetTop,view=pi.util.Element.getView(_element);while(parent&&parent!=document.body&&parent!=document.firstChild){offsetLeft+=parseInt(parent.offsetLeft);offsetTop+=parseInt(parent.offsetTop);parent=parent.offsetParent;};return{"bottom":view["bottom"],"clientLeft":_element.clientLeft,"clientTop":_element.clientTop,"left":view["left"],"marginTop":view["marginTop"],"marginLeft":view["marginLeft"],"offsetLeft":offsetLeft,"offsetTop":offsetTop,"position":view["position"],"right":view["right"],"top":view["top"],"zIndex":view["zIndex"]};},getSize:function(_element){var view=pi.util.Element.getView(_element);return{"height":view["height"],"clientHeight":_element.clientHeight,"clientWidth":_element.clientWidth,"offsetHeight":_element.offsetHeight,"offsetWidth":_element.offsetWidth,"width":view["width"]}},addStyle:function(_element,_style){for(var key in _style){key=key=="float"?pi.env.ie?"styleFloat":"cssFloat":key;if(key=="opacity"&&pi.env.ie){pi.util.Element.setOpacity(_element,_style[key]);continue;}
+try{_element.style[key]=_style[key];}catch(e){}}},getStyle:function(_element,_property){_property=_property=="float"?pi.env.ie?"styleFloat":"cssFloat":_property;if(_property=="opacity"&&pi.env.ie)
+return pi.util.Element.getOpacity(_element.style);return typeof _property=="string"?_element.style[_property]:_element.style;},getValue:function(_element){switch(_element.nodeName.toLowerCase()){case"input":case"textarea":return _element.value;case"select":return _element.options[_element.selectedIndex].value;default:return _element.innerHTML;break;}},getView:function(_element,_property){var view=document.defaultView?document.defaultView.getComputedStyle(_element,null):_element.currentStyle;_property=_property=="float"?pi.env.ie?"styleFloat":"cssFloat":_property;if(_property=="opacity"&&pi.env.ie)
+return pi.util.Element.getOpacity(_element,view);return typeof _property=="string"?view[_property]:view;}},Hash:{clone:function(_hash,_undeep){var tmp={};for(var key in _hash){if(!_undeep&&pi.util.IsArray(_hash[key])){tmp[key]=pi.util.Array.clone(_hash[key]);}else if(!_undeep&&pi.util.IsHash(_hash[key])){tmp[key]=pi.util.Hash.clone(_hash[key]);}else{tmp[key]=_hash[key];}}
+return tmp;},merge:function(_hash,_source,_undeep){for(var key in _source){var value=_source[key];if(!_undeep&&pi.util.IsArray(_source[key])){if(pi.util.IsArray(_hash[key])){Array.prototype.push.apply(_source[key],_hash[key])}
+else
+value=pi.util.Array.clone(_source[key]);}
+else if(!_undeep&&pi.util.IsHash(_source[key])){if(pi.util.IsHash(_hash[key])){value=pi.util.Hash.merge(_hash[key],_source[key]);}else{value=pi.util.Hash.clone(_source[key]);}}else if(_hash[key])
+value=_hash[key];_hash[key]=value;};return _hash;}},String:{format:function(_str){var values=Array.prototype.slice.call(arguments,1);return _str.replace(/\{(\d)\}/g,function(){return values[arguments[1]];})}},GetViewport:function(){return{height:document.documentElement.clientHeight||document.body.clientHeight,width:document.documentElement.clientWidth||document.body.clientWidth}}};pi.base=function(){this.body={};this.init=null;this.build=function(_skipClonning){var base=this,skipClonning=_skipClonning||false,_private={},fn=function(){var _p=pi.util.Hash.clone(_private);if(!skipClonning){for(var key in this){if(pi.util.IsArray(this[key])){this[key]=pi.util.Array.clone(this[key]);}else
+if(pi.util.IsHash(this[key])){this[key]=pi.util.Hash.clone(this[key],function(_key,_object){this[_key]._parent_=this;});}}};base.createAccessors(_p,this);if(base.init)
+return base.init.apply(this,arguments);return this;};this.movePrivateMembers(this.body,_private);if(this.init){fn["$Init"]=this.init;};fn.prototype=this.body;return fn;};this.createAccessors=function(_p,_branch){var getter=function(_property){return this[_property];},setter=function(_property,_value){this[_property]=_value;return _branch._parent_||_branch;};for(var name in _p){var isPrivate=name.substring(0,1)=="_",title=name.substring(1,2).toUpperCase()+name.substring(2);if(isPrivate){_branch[(_branch["get"+title]?"_":"")+"get"+title]=pi.util.Curry(getter,_p,name);_branch[(_branch["set"+title]?"_":"")+"set"+title]=pi.util.Curry(setter,_p,name);}
+else
+if(pi.util.IsHash(_p[name])){_branch[name]._parent_=_branch;if(!_branch[name])
+_branch[name]={};this.createAccessors(_p[name],_branch[name]);}};};this.movePrivateMembers=function(_object,_branch){for(var name in _object){var isPrivate=name.substring(0,1)=="_";if(isPrivate){_branch[name]=_object[name];delete _object[name];}
+else
+if(pi.util.IsHash(_object[name])){_branch[name]={};this.movePrivateMembers(_object[name],_branch[name]);}};};};pi.element=new pi.base;pi.element.init=function(_val){this.environment.setElement(typeof _val=="string"||!_val?document.createElement(_val||"DIV"):_val);return this;};pi.element.body={"addStyle":function(){return this.environment.addStyle.apply(this.environment,arguments);},"clean":function(){var childs=this.child.get();while(childs.length){childs[0].parentNode.removeChild(childs[0]);}},"clone":function(_deep){return this.environment.getElement().cloneNode(_deep);},"insert":function(_element){_element=_element.environment?_element.environment.getElement():_element;_element.appendChild(this.environment.getElement());return this;},"insertAfter":function(_referenceElement){_referenceElement=_referenceElement.environment?_referenceElement.environment.getElement():_referenceElement;_referenceElement.nextSibling?this.insertBefore(_referenceElement.nextSibling):this.insert(_referenceElement.parentNode);return this;},"insertBefore":function(_referenceElement){_referenceElement=_referenceElement.environment?_referenceElement.environment.getElement():_referenceElement;_referenceElement.parentNode.insertBefore(this.environment.getElement(),_referenceElement);return this;},"query":function(_expression,_resultType,namespaceResolver,_result){return pi.xpath(_expression,_resultType||"ORDERED_NODE_SNAPSHOT_TYPE",this.environment.getElement(),_namespaceResolver,_result);},"remove":function(){if(this.environment.getParent()){this.environment.getParent().removeChild(this.environment.getElement());}},"update":function(_value){this.element[this.element.nodeName.toLowerCase()=="textarea"||this.element.nodeName.toLowerCase()=="input"?"value":"innerHTML"]=_value;return this;},"attribute":{"getAll":function(){return this._parent_.environment.getElement().attributes;},"clear":function(_name){this.set(_name,"");return this._parent_;},"get":function(_name){return this._parent_.environment.getElement().getAttribute(_name);},"has":function(_name){return pi.env.ie?(this.get(_name)!=null):this._parent_.environment.getElement().hasAttribute(_name);},"remove":function(_name){this._parent_.environment.getElement().removeAttribute(_name);return this._parent_;},"set":function(_name,_value){this._parent_.environment.getElement().setAttribute(_name,_value);return this._parent_;},"addClass":function(_classes){for(var i=0,len=arguments.length;i<len;i++){pi.util.Element.addClass(this._parent_.environment.getElement(),arguments[i]);};return this._parent_;},"clearClass":function(){this.setClass("");this._parent_;},"getClass":function(){return pi.util.Element.getClass(this._parent_.environment.getElement());},"hasClass":function(_class){return pi.util.Element.hasClass(this._parent_.environment.getElement(),_class);},"setClass":function(_value){return pi.util.Element.setClass(this._parent_.environment.getElement(),_value);},"removeClass":function(_class){pi.util.Element.removeClass(this._parent_.environment.getElement(),_class);return this._parent_;},"toggleClass":function(_class){pi.util.Element.toggleClass(this._parent_.environment.getElement(),_class);}},"child":{"get":function(){return this._parent_.environment.getElement().childNodes;},"add":function(_elements){for(var i=0;i<arguments.length;i++){var el=arguments[i];this._parent_.environment.getElement().appendChild(el.environment?el.environment.getElement():el);}
+return this._parent_;},"addAfter":function(_element,_referenceElement){this.addBefore(_element.environment?_element.environment.getElement():_element,(_referenceElement.environment?_referenceElement.environment.getElement():_referenceElement).nextSibling);return this._parent_;},"addBefore":function(_element,_referenceElement){this._parent_.environment.getElement().insertBefore(_element.environment?_element.environment.getElement():_element,_referenceElement.environment?_referenceElement.environment.getElement():_referenceElement);return this._parent_;},"remove":function(_element){this._parent_.environment.getElement().removeChild(_element.environment?_element.environment.getElement():_element);}},"environment":{"_element":null,"setElement":function(_value){this._parent_.element=_value;this._parent_.element.lib=this._parent_;this._parent_.element.firebugElement=true;this._setElement(_value);},"getParent":function(){return this.getElement().parentNode;},"getPosition":function(){return pi.util.Element.getPosition(this.getElement());},"getSize":function(){return pi.util.Element.getSize(this.getElement());},"addStyle":function(_styleObject){pi.util.Element.addStyle(this.getElement(),_styleObject);return this._parent_;},"getStyle":function(_property){return pi.util.Element.getStyle(this.getElement(),_property);},"getName":function(){return this.getElement().nodeName;},"getType":function(){return this.getElement().nodeType;},"getValue":function(){return pi.util.Element.getValue(this.getElement());},"getView":function(_property){return pi.util.Element.getView(this.getElement(),_property);}},"event":{"addListener":function(_event,_fn,_useCapture){pi.util.AddEvent(this._parent_.environment.getElement(),_event,_fn,_useCapture);return this._parent_;},"removeListener":function(_event,_fn,_useCapture){pi.util.RemoveEvent(this._parent_.environment.getElement(),_event,_fn,_useCapture);return this._parent_;}}};pi.element=pi.element.build();pi.xhr=new pi.base;pi.xhr.init=function(_url){if(!window.XMLHttpRequest){var names=["Msxml2.XMLHTTP.6.0","Msxml2.XMLHTTP.3.0","Msxml2.XMLHTTP","Microsoft.XMLHTTP"];for(var i=0;i<names.length;i++){try{this.environment.setApi(new ActiveXObject(names[i]));break;}catch(e){continue;}}}
+else{this.environment.setApi(new XMLHttpRequest());}
+this.environment.getApi().onreadystatechange=pi.util.Curry(this.event.readystatechange,this);this.environment.setUrl(_url);this.environment.setCallback([]);return this;};pi.xhr.body={"addCallback":function(){return this.environment.addCallback.apply(this.environment,arguments);},"addData":function(){return this.environment.addData.apply(this.environment,arguments);},"abort":function(){this.environment.getApi().abort();return this;},"send":function(){var url=this.environment.getUrl(),data=this.environment.getData(),dataUrl="";if(!this.environment.getCache())
+data["forceCache"]=Number(new Date);for(var key in data)
+dataUrl+=pi.util.String.format("{0}={1}&",key,data[key]);if(this.environment.getType()=="GET")
+url+=(url.search("\\?")==-1?"?":"&")+pi.util.String.format("{0}",dataUrl);this.api.open(this.environment.getType(),url,this.environment.getAsync());if(this.environment.getType()=="POST"){this.api.setRequestHeader("Content-Type","application/x-www-form-urlencoded");};this.api.send(this.environment.getType()=="GET"?"":dataUrl);return this;}};pi.xhr.body.environment={"_async":true,"_api":null,"_cache":true,"_callback":null,"_data":{},"_type":"GET","_url":"","setApi":function(_value){this._parent_.api=_value;this._setApi(_value);},"addCallback":function(_readyState,_fn){this.getCallback().push({"fn":_fn,"readyState":_readyState});return this._parent_;},"addData":function(_key,_value){this.getData()[_key]=_value;return this._parent_;},"setType":function(_value){this._setType(_value);return this._parent_;}};pi.xhr.body.event={"readystatechange":function(){var readyState=this.environment.getApi().readyState,callback=this.environment.getCallback();for(var i=0,len=callback.length;i<len;i++){if(pi.util.Array.indexOf(callback[i].readyState,readyState)>-1){callback[i].fn.apply(this);}}}};pi.xhr=pi.xhr.build();pi.xhr.get=function(_url,_returnPiObject){var request=new pi.xhr();request.environment.setAsync(false);request.environment.setUrl(_url);request.send();return _returnPiObject?request:request.environment.getApi();};pi.util.AddEvent(pi.env.ie?window:document,pi.env.ie?"load":"DOMContentLoaded",function(){for(var i=0,len=pi.util.Init.length;i<len;i++){pi.util.Init[i]();}});})(firebug);(function(){with(firebug){var scriptsIncluded=document.getElementsByTagName('script');for(var i=scriptsIncluded.length-1;i>=0;i--){var script=scriptsIncluded[i],src=getFileName(script.src);if(src){internal.liteFilename=src;break;}}
+initConsole();lib.util.Init.push(firebug.init);}})();
\ No newline at end of file
Added: trunk/mapbender/http/extensions/firebug-lite/firebug-lite.css
--- trunk/mapbender/http/extensions/firebug-lite/firebug-lite.css	                        (rev 0)
+++ trunk/mapbender/http/extensions/firebug-lite/firebug-lite.css	2009-12-18 09:22:12 UTC (rev 5206)
@@ -0,0 +1,218 @@
+#Firebug div, #Firebug h3, #Firebug span, #Firebug input, #Firebug textarea, #Firebug select, #Firebug option, #Firebug a, #Firebug strong, #Firebug em, #Firebug label, #Firebug center {
+	position:static; float:none; width:auto; height:auto; text-align:left; border:0; overflow:visible; background:transparent none repeat left top; color:#111; font-size:1em; font-weight:normal; font-style:normal; font-family:sans-serif; margin:0; padding:0;  min-height:0;
+#Firebug input, #Firebug select, #Firebug textarea { background:#fff; font:11px Verdana, Geneva, Arial, Helvetica, sans-serif; border:1px outset #aaa; padding:2px }
+#Firebug center { text-align:center; }
+#Firebug strong { font-weight:bold; }
+#Firebug em { font-style:italic; }
+#FirebugIFrame { position:fixed !important; position:absolute; z-index:99999998; left:0; bottom:0; width:100%; height:295px; background:#fff; border-width:0px; }
+#Firebug { position:fixed !important; position:absolute; z-index:99999999; left:0; bottom:0; width:100%; height:295px; background:#fff; overflow:hidden; }
+#Firebug .Resizer { position:absolute; top:0; width:100%; height:5px; background:transparent; *background:url(spacer.gif); cursor:n-resize; -moz-user-select:none; }
+#Firebug .Header { height:38px; background:#ccc url(firebug.gif) 0 -85px; }
+#Firebug .Left, #Firebug > .Right { background:#fff; height:257px;}
+#Firebug .Left { float:left; width:100%; }
+#Firebug .Right { float:left; display:none; width:30%; overflow:hidden; }
+#Firebug .Right .Container { height:100%; border-left:1px solid #ccc; }
+ * buttonset
+#Firebug .ButtonContainer { padding:8px 0 5px 10px; *margin-top:-3px; _margin-top:0; }
+#Firebug .ButtonContainer .Button { cursor:pointer; font:12px "MS Sans Serif", Geneva, sans-serif; color:#000; margin-right:5px; padding:4px 4px 4px 4px; border:1px solid transparent !important; border-color:#ccc; text-decoration:none; }
+#Firebug .ButtonContainer .Button:hover {  border:1px outset #aaa !important; }
+#Firebug .ButtonContainer .Button:active { border-style:inset !important; background-color:#ccc; }
+#Firebug .ButtonContainer .Enabled { border:1px outset #aaa !important; }
+#Firebug .ButtonContainer .Logo { text-decoration:none; padding-left:24px; background:url(firebug.gif) no-repeat 5px 3px; border:0 !important; opacity:0.7; filter:Alpha(Opacity=70); }
+#Firebug .ButtonContainer .Logo:hover, #Firebug .ButtonContainer .Logo:active { border:0 !important; background-color:transparent; opacity:1; filter:Alpha(Opacity=100); }
+#Firebug .ButtonContainer .Maximize, #Firebug .ButtonContainer .Minimize, #Firebug .ButtonContainer .NewWindow, #Firebug .ButtonContainer .Dock, #Firebug .ButtonContainer .Close { position:absolute; right:0; top:12px; padding:6px 8px 8px 8px; background:url(firebug.gif) no-repeat -3px -48px; border:0 !important; opacity:0.7; filter:Alpha(Opacity:80); *padding:0px 7px 1px 7px; }
+#Firebug .ButtonContainer .Maximize:hover, #Firebug .ButtonContainer .Maximize:active, #Firebug .ButtonContainer .NewWindow:hover, #Firebug .ButtonContainer .NewWindow:active,  #Firebug .ButtonContainer .Dock:hover, #Firebug .ButtonContainer .Dock:active, #Firebug .ButtonContainer .Minimize:hover, #Firebug .ButtonContainer .Minimize:active, #Firebug .ButtonContainer .Close:hover, #Firebug .ButtonContainer .Close:active { border:0 !important; background-color:transparent; opacity:1; filter:Alpha(Opacity:100); }
+#Firebug .ButtonContainer .Minimize { background-position:-3px -20px; right:40px; }
+#Firebug .ButtonContainer .Maximize { display:none; background-position:-3px -34px; right:40px; }
+#Firebug .ButtonContainer .NewWindow { background-position:-3px -123px; right:20px; }
+#Firebug .ButtonContainer .Dock { background-position:-3px -137px; }
+#Firebug .ButtonContainer .ButtonSet { border-left:1px solid #ccc; padding:0 0 0 3px; display:inline; }
+ * navigation
+#Firebug .Nav { height:23px; background:url(firebug.gif) repeat-x 0 -62px; padding-left:10px; }
+#Firebug .Nav .Tab { display:block; width:auto; float:left; padding:3px 6px 2px 6px; cursor:pointer; border:1px outset transparent !important; border:0; font:bold 11px Arial, Helvetica, sans-serif; color:#666; }
+#Firebug .Nav .Tab:hover, #Firebug .Nav .Selected { border:1px outset #ccc !important; border-top-color:transparent !important;  }
+#Firebug .Nav .Selected { color:#111; cursor:default; background-color:#f2f2f2; }
+#Firebug .Nav .Settings { float:right; }
+#Firebug .Nav .Settings .Options { text-decoration:none; padding-left:24px; background:url(firebug.gif) no-repeat 65px -151px; border:0 !important; opacity:0.7; filter:Alpha(Opacity=70); }
+#Firebug .Nav .Settings .Options:hover, #Firebug .ButtonContainer .Options:active { border:0 !important; background-color:transparent; opacity:1; filter:Alpha(Opacity=100); }
+ * inspector
+#FirebugBorderInspector { display:none; z-index:99999998; position:absolute; top:0; left:0; border:2px solid #0000ff; background:transparent; *background:url(spacer.gif); opacity:0.5; filter:Alpha(Opacity=50); padding:0; margin:0; }
+#FirebugBGInspector { display:none; z-index:99999998; position:absolute; top:0; left:0; background:rgb(0,150,255); opacity:0.5; filter:Alpha(Opacity=50); padding:0; margin:0; }
+ * dom
+#Firebug .DOMRow { width:100% !important; width:90%; }
+#Firebug .DOMRow .DOMRowLeft { float:left; width:30%; overflow:hidden; }
+#Firebug .DOMRow .DOMRowLeft a { padding-left:15px; }
+#Firebug .DOMRow .DOMRowRight { float:left; width:60%; *width:60%; _overflow:hidden; white-space:nowrap; }
+#Firebug .DOMRow .DOMRowLeft .Object {  background:url(tree_open.gif) no-repeat left center;  cursor:pointer;  }
+#Firebug .DOMRow .DOMRowLeft .Object:hover { text-decoration:underline; color:#0000ff; }
+#Firebug .DOMRow .DOMRowLeft .Opened {  background-image:url(tree_close.gif) }
+#Firebug .DOMRow .DOMRowSubContainer { display:none; padding-left:25px; }
+ * console
+#Firebug .Left .Console { overflow:hidden; }
+#Firebug .Left .Console .Monitor { height:210px; border-bottom:1px solid #ccc; overflow:scroll; overflow-x:hidden; }
+#Firebug .Left .Console .Monitor .Error { background:#ffeff1; color:#ff0000; }
+#Firebug .Left .Console .Monitor .Error strong { color:#ff0000; }
+#Firebug .Left .Console .Monitor .Row { padding:2px 5px 2px 5px; font:11px Verdana, Geneva, Arial, Helvetica, sans-serif; overflow:hidden; border-bottom:1px solid #e5e5e5; }
+#Firebug .Left .Console .Monitor .Arrow { color:rgb(0,0,255); white-space:nowrap; }
+#Firebug .Left .Console .InputArrow { position:absolute; left:0px; width:20px; font:12px Verdana, Geneva, Arial, Helvetica, sans-serif; color:#0000ff; padding:2px 4px 0 4px; }
+#Firebug .Left .Console .InputContainer { margin-left:35px; margin-right:5px; }
+#Firebug .Left .Console .Input { width:100% !important; margin-top:2px; width:98%; overflow:hidden; border:0; font:12px  Verdana, Geneva, Arial, Helvetica, sans-serif; }
+#Firebug .Console .MLButton { cursor:pointer; position:absolute; top:276px; right:-22px; width:20px; padding:4px 10px 10px 10px; font-size:1px; *padding:2px 10px 10px 10px; background:url(firebug.gif) no-repeat -3px -34px; opacity:0.8; filter:Alpha(Opacity:80); }
+#Firebug .Console .MLButton:hover { opacity:1; filter:Alpha(Opacity:100); }
+#Firebug .Console .CloseML { background-position:-3px -20px; }
+#Firebug .Right .Console { background:#eee; }
+#Firebug .Right .Console .Input { width:100%; _width:98%; height:228px; font:12px Verdana, Geneva, Arial, Helvetica, sans-serif; background:#fff; border:0; border-bottom:1px solid #ccc; margin-bottom:2px; *overflow:scroll; }
+#Firebug .Right .Console .Button { cursor:pointer; font:12px Verdana, Geneva, Arial, Helvetica, sans-serif; padding:1px 4px 1px 4px; margin:0 4px 0 4px; background:#eee; border:1px solid #eee;  text-decoration:none; *display:block; *width:auto; *float:left; *margin-top:-1px; }
+#Firebug .Right .Console .Button:hover { border:1px outset #ccc; background:#fff; }
+#Firebug .Right .Console .Button:active { border:1px inset #ccc; background:#ccc; }
+#Firebug .Left .Console .Monitor .Warn { background:url(warningIcon.png) #00FFFF no-repeat 2px center; padding-left:20px; }
+#Firebug .Left .Console .Monitor .Info { background:url(infoIcon.png) #fff no-repeat 2px center; padding-left:20px; }
+#Firebug .Left .Console .Monitor .Error { background:url(errorIcon.png) #FFFFE0 no-repeat 2px center; padding-left:20px; }
+ * html
+#Firebug .Left .HTML { display:none; height:250px; overflow:scroll; padding:0 10px 2px 10px; }
+#Firebug .Left .HTML .Block { padding:0 0 0 0px; font:11px Verdana, Geneva, Arial, Helvetica, sans-serif;  }
+#Firebug .Left .HTML .Block .Spacer { cursor:default; padding:2px 2px 2px 15px; }
+#Firebug .Left .HTML .Block .Link { display:block; color:#333; padding:2px 2px 2px 0; }
+#Firebug .Left .HTML .Block .Link .Content { padding:2px 2px 2px 2px; }
+#Firebug .Left .HTML .Block .Link .TagName { cursor:pointer; }
+#Firebug .Left .HTML .Block .Parent { font-weight:bold; color:#111; text-decoration:none; }
+#Firebug .Left .HTML .Block .Parent .Spacer { background:#fff center no-repeat; }
+#Firebug .Left .HTML .Block .Parent .Spacer { background-image:url(tree_open.gif); }
+#Firebug .Left .HTML .Block .Open .Spacer { background-image:url(tree_close.gif) }
+#Firebug .Left .HTML .Block .Selected { background-color:#4473c4; }
+#Firebug .Left .HTML .Block .Selected * { color:#fff; }
+#Firebug .Left .HTML .Block .SubContainer { padding-left:20px; height:0; font-size:0px; }
+#Firebug .Left .HTML .Block .OpenSubContainer { height:auto; }
+#Firebug .Left .HTML .Unvisible { opacity:0.5; filter:Alpha(Opacity=50); }
+#Firebug .Right .HTML { display:none; }
+#Firebug .Right .HTML .Content { overflow:scroll; height:235px; font:11px Verdana, Geneva, Arial, Helvetica, sans-serif; }
+#Firebug .Right .HTML .Content .CSSItem { padding:5px; color:#333; height:6px }
+#Firebug .Right .HTML .Content .CSSProperty { width:45%; float:left; overflow:hidden; }
+#Firebug .Right .HTML .Content .CSSValue { width:55%; float:left; white-space:nowrap; overflow:visible !important;  overflow:hidden;  }
+#Firebug .Right .HTML .Content .CSSValue input { font:11px ArArial, Helvetica, sans-serif; color:#333; 3px 0 0 -3px; }
+#Firebug .Right .HTML .Content .CSSItem center { color:rgb(0,150,0); padding:0 0 3px 0; font:bold 12px Arial, Helvetica, sans-serif; }
+#Firebug .ButtonContainer .HTML { display:none; }
+ * CSS
+#Firebug .Left .CSS { display:none; padding:5px; height:225px; overflow:scroll; font:11px Verdana, Geneva, Arial, Helvetica, sans-serif; }
+#Firebug .Right .CSS { display:none; }
+#Firebug .Left .CSS .Selector { margin-top:10px }
+#Firebug .Left .CSS .CSSText { padding-left:20px; }
+#Firebug .Left .CSS .CSSProperty { color:#005500; margin-top:10px; }
+#Firebug .Left .CSS .CSSValue { padding-left:5px; color:#000088; }
+#Firebug .ButtonContainer .CSS { display:none; }
+#Firebug .Right .CSS { background:#eee; }
+#Firebug .Right .CSS .Input { width:100%; _width:98%; height:205px; font:12px Verdana, Geneva, Arial, Helvetica, sans-serif; background:#fff; border:0; border-bottom:1px solid #ccc; margin-bottom:2px; *overflow:scroll; }
+#Firebug .Right .CSS .Button { cursor:pointer; font:12px Verdana, Geneva, Arial, Helvetica, sans-serif; padding:1px 4px 1px 4px; margin:0 4px 0 4px; background:#eee; border:1px solid #eee;  text-decoration:none; *display:block; *width:auto; *float:left; *margin-top:-1px; }
+#Firebug .Right .CSS .Button:hover { border:1px outset #ccc; background:#fff; }
+#Firebug .Right .CSS .Button:active { border:1px inset #ccc; background:#ccc; }
+ * Scripts
+#Firebug .Left .Scripts { display:none; height:225px; *height:235px; overflow:scroll; font:12px Verdana, Geneva, Arial, Helvetica, sans-serif; white-space:pre; }
+#Firebug .Left .Scripts .LineNumber { float:left; width:30px; height:20px; padding:0 2px 0 0; background:#eee; color:#666; font-family:Courier; text-align:right; border-right:1px solid #ccc; }
+#Firebug .Left .Scripts .CodeContainer { padding:5px; }
+#Firebug .Left .Scripts .Code { height:20px; }
+#Firebug .Left .Scripts .CodeContainer, #Firebug .Left .Scripts .Code { word-wrap:normal; white-space:pre; }
+#Firebug .Right .Scripts { display:none; }
+#Firebug .ButtonContainer .Scripts { display:none; }
+ * DOM
+#Firebug .Left .DOM { display:none; font:11px Verdana, Geneva, Arial, Helvetica, sans-serif; padding:5px; overflow:scroll; height:225px; }
+#Firebug .Left .DOM .Object { font-weight:bold; }
+#Firebug .Right .DOM { display:none; overflow:scroll; }
+#Firebug .ButtonContainer .DOM { display:none; }
+#Firebug .ButtonContainer .DOM label { font:11px Verdana, Geneva, Arial, Helvetica, sans-serif;  }
+ * XHR
+#Firebug .Left .XHR { display:none; font:11px Verdana, Geneva, Arial, Helvetica, sans-serif; padding:5px; overflow:scroll; height:225px; }
+#Firebug .Left .XHR .Block { float:left; width:30%; }
+#Firebug .Left .XHR .BlockContent { padding:3px; border-right:1px dotted #aaa; }
+#Firebug .Left .XHR .Block strong { display:block; text-align:center; padding:3px; background:rgb(200,225,255); color:rgb(50,50,50); }
+#Firebug .Left .XHR .Block span { display:block; text-align:center; overflow:hidden; }
+#Firebug .Left .XHR .Block span a { cursor:pointer; color:rgb(0,0,200); }
+#Firebug .Right .XHR { display:none; overflow:scroll; }
+#Firebug .ButtonContainer .XHR { display:none; }
+#Firebug .ButtonContainer .XHR label { font:11px Verdana, Geneva, Arial, Helvetica, sans-serif;  }
+#Firebug .Left .STR { display:none; font:11px Verdana, Geneva, Arial, Helvetica, sans-serif; padding:5px; overflow:scroll; height:225px; }
+ * settings
+#Firebug .SettingsDiv {position:absolute;width:190px;top:60px;border:1px outset #000;-x-system-font:none;color:#000;font-family:"MS Sans Serif",Geneva,sans-serif;font-size:12px;font-size-adjust:none;font-stretch:normal;font-style:normal;font-variant:normal;font-weight:normal;line-height:normal;display:none;background-color:#FFF;}
+#Firebug .SettingsDiv .Header {background:#CCC url(firebug.gif) repeat scroll 0 -85px;height:30px;border-bottom:1px inset #000;}
+#Firebug .SettingsDiv .Header .Title {padding-top:10px;text-align:center;}
+#Firebug .SettingsDiv .Content {padding:5px;}
+#Firebug .SettingsDiv .Content .SettingsCBX{position:relative;top:2px;margin: 4px 5px 0 0; border:0 !important; padding:0 !important; height: 15px !important;}
+#Firebug .SettingsDiv .Content .SettingsTextbox{position:relative;top:2px;margin: 4px 5px 0 0; border:0 !important; padding:0 !important; height: 15px !important; width:35px !important; border:1px solid #000000 !important;}
+#Firebug .SettingsDiv .Content .ButtonsLeft {float:left;padding:10px 0px 5px 0px;}
+#Firebug .SettingsDiv .Content .ButtonsRight {float:right;padding:10px 0px 5px 0px;}
+#Firebug .SettingsDiv .Content .ProgressDiv {background-color:#FFF;width:100%;height:100%;position:absolute;left:0;top:0;z-index:1;opacity:.8;filter:alpha(opacity=80);display:none;}
+#Firebug .SettingsDiv .Content .Progress {background-image:url(progress.gif);width:66px;height:66px;position:absolute;top:50%;left:50%;margin-left:-33px;margin-top:-33px;}
+ * element highlighting
+#Firebug .Italic { font-style:italic; }
+#Firebug .Strong { font-weight:bold; }
+#Firebug .NormalWeight { font-weight:normal; }
+#Firebug .Green { color:#008800; }
+#Firebug .Gray { color:#666; }
+#Firebug .Blue { color:#0000ee; }
+#Firebug .DarkBlue { color:#000099; }
+#Firebug .Red { color:#ee0000; }
+#Firebug .Maroon { color:#800000; font:11px Verdana, Geneva, Arial, Helvetica, sans-serif; }
+#Firebug .Null { font:11px Verdana, Geneva, Arial, Helvetica, sans-serif; color:#fff; padding:0 2px 0 2px; background:#999; border:1px solid #666; }
+#Firebug .ObjectLink, #Firebug .ObjectLinkHover { cursor:pointer; }
+#Firebug .ObjectLinkHover { border-bottom:1px solid #008800; }
+#Firebug .Clear { clear:both; height:0px; font-size:0px; }
+#firebugIconDiv { width:38px;height:38px;right:15pt;bottom:5pt;border:2px solid #000;display:none;position:fixed;background-image:url(firebug_logo.png);text-decoration:underline;cursor:pointer;filter:alpha(opacity:60);opacity:.6;z-index:99999998;}
More information about the Mapbender_commits mailing list
