[Mapbender-commits] r5225 - in trunk/mapbender/http: extensions
extensions/jGrowl-1.2.4 javascripts
svn_mapbender at osgeo.org
Tue Dec 22 08:08:05 EST 2009
Author: christoph
Date: 2009-12-22 08:08:04 -0500 (Tue, 22 Dec 2009)
New Revision: 5225
Added:
trunk/mapbender/http/extensions/jGrowl-1.2.4/
trunk/mapbender/http/extensions/jGrowl-1.2.4/jquery.jgrowl.css
trunk/mapbender/http/extensions/jGrowl-1.2.4/jquery.jgrowl.js
trunk/mapbender/http/extensions/jGrowl-1.2.4/jquery.jgrowl_compressed.js
trunk/mapbender/http/extensions/jGrowl-1.2.4/jquery.jgrowl_minimized.js
trunk/mapbender/http/javascripts/jq_jgrowl.js
new growl-like application element to replace alerts
Added: trunk/mapbender/http/extensions/jGrowl-1.2.4/jquery.jgrowl.css
--- trunk/mapbender/http/extensions/jGrowl-1.2.4/jquery.jgrowl.css (rev 0)
+++ trunk/mapbender/http/extensions/jGrowl-1.2.4/jquery.jgrowl.css 2009-12-22 13:08:04 UTC (rev 5225)
@@ -0,0 +1,128 @@
+div.jGrowl {
+ padding: 10px;
+ z-index: 9999;
+ color: #fff;
+ font-size: 12px;
+/** Special IE6 Style Positioning **/
+div.ie6 {
+ position: absolute;
+div.ie6.top-right {
+ right: auto;
+ bottom: auto;
+ left: expression( ( 0 - jGrowl.offsetWidth + ( document.documentElement.clientWidth ? document.documentElement.clientWidth : document.body.clientWidth ) + ( ignoreMe2 = document.documentElement.scrollLeft ? document.documentElement.scrollLeft : document.body.scrollLeft ) ) + 'px' );
+ top: expression( ( 0 + ( ignoreMe = document.documentElement.scrollTop ? document.documentElement.scrollTop : document.body.scrollTop ) ) + 'px' );
+div.ie6.top-left {
+ left: expression( ( 0 + ( ignoreMe2 = document.documentElement.scrollLeft ? document.documentElement.scrollLeft : document.body.scrollLeft ) ) + 'px' );
+div.ie6.bottom-right {
+ top: expression( ( 0 - jGrowl.offsetHeight + ( document.documentElement.clientHeight ? document.documentElement.clientHeight : document.body.clientHeight ) + ( ignoreMe = document.documentElement.scrollTop ? document.documentElement.scrollTop : document.body.scrollTop ) ) + 'px' );
+div.ie6.bottom-left {
+div.ie6.center {
+ width: 100%;
+/** Normal Style Positions **/
+body > div.jGrowl {
+ position: fixed;
+body > div.jGrowl.top-left {
+ left: 0px;
+ top: 0px;
+body > div.jGrowl.top-right {
+ right: 0px;
+ top: 0px;
+body > div.jGrowl.bottom-left {
+ left: 0px;
+ bottom: 0px;
+body > div.jGrowl.bottom-right {
+ right: 0px;
+ bottom: 0px;
+body > div.jGrowl.center {
+ top: 0px;
+ width: 50%;
+ left: 25%;
+/** Cross Browser Styling **/
+div.center div.jGrowl-notification, div.center div.jGrowl-closer {
+ margin-left: auto;
+ margin-right: auto;
+div.jGrowl div.jGrowl-notification, div.jGrowl div.jGrowl-closer {
+ background-color: #000;
+ opacity: .85;
+ -ms-filter: "progid:DXImageTransform.Microsoft.Alpha(Opacity=85)";
+ filter: progid:DXImageTransform.Microsoft.Alpha(Opacity=85);
+ zoom: 1;
+ width: 235px;
+ padding: 10px;
+ margin-top: 5px;
+ margin-bottom: 5px;
+ font-family: Tahoma, Arial, Helvetica, sans-serif;
+ font-size: 1em;
+ text-align: left;
+ display: none;
+ -moz-border-radius: 5px;
+ -webkit-border-radius: 5px;
+div.jGrowl div.jGrowl-notification {
+ min-height: 40px;
+div.jGrowl div.jGrowl-notification div.header {
+ font-weight: bold;
+ font-size: .85em;
+div.jGrowl div.jGrowl-notification div.close {
+ z-index: 99;
+ float: right;
+ font-size: 1em;
+ cursor: pointer;
+div.jGrowl div.jGrowl-closer {
+ padding-top: 4px;
+ padding-bottom: 4px;
+ cursor: pointer;
+ font-size: .9em;
+ text-align: center;
+/** Hide jGrowl when printing **/
+ at media print {
+ div.jGrowl {
+ display: none;
\ No newline at end of file
Added: trunk/mapbender/http/extensions/jGrowl-1.2.4/jquery.jgrowl.js
--- trunk/mapbender/http/extensions/jGrowl-1.2.4/jquery.jgrowl.js (rev 0)
+++ trunk/mapbender/http/extensions/jGrowl-1.2.4/jquery.jgrowl.js 2009-12-22 13:08:04 UTC (rev 5225)
@@ -0,0 +1,307 @@
+ * jGrowl 1.2.4
+ * Dual licensed under the MIT (http://www.opensource.org/licenses/mit-license.php)
+ * and GPL (http://www.opensource.org/licenses/gpl-license.php) licenses.
+ * Written by Stan Lemon <stosh1985 at gmail.com>
+ * Last updated: 2009.12.13
+ * jGrowl is a jQuery plugin implementing unobtrusive userland notifications. These
+ * notifications function similarly to the Growl Framework available for
+ * Mac OS X (http://growl.info).
+ * To Do:
+ * - Move library settings to containers and allow them to be changed per container
+ * Changes in 1.2.4
+ * - Fixed IE bug with the close-all button
+ * - Fixed IE bug with the filter CSS attribute (special thanks to gotwic)
+ * - Update IE opacity CSS
+ * - Changed font sizes to use "em", and only set the base style
+ * Changes in 1.2.3
+ * - The callbacks no longer use the container as context, instead they use the actual notification
+ * - The callbacks now receive the container as a parameter after the options parameter
+ * - beforeOpen and beforeClose now check the return value, if it's false - the notification does
+ * not continue. The open callback will also halt execution if it returns false.
+ * - Fixed bug where containers would get confused
+ * - Expanded the pause functionality to pause an entire container.
+ * Changes in 1.2.2
+ * - Notification can now be theme rolled for jQuery UI, special thanks to Jeff Chan!
+ * Changes in 1.2.1
+ * - Fixed instance where the interval would fire the close method multiple times.
+ * - Added CSS to hide from print media
+ * - Fixed issue with closer button when div { position: relative } is set
+ * - Fixed leaking issue with multiple containers. Special thanks to Matthew Hanlon!
+ * Changes in 1.2.0
+ * - Added message pooling to limit the number of messages appearing at a given time.
+ * - Closing a notification is now bound to the notification object and triggered by the close button.
+ * Changes in 1.1.2
+ * - Added iPhone styled example
+ * - Fixed possible IE7 bug when determining if the ie6 class shoudl be applied.
+ * - Added template for the close button, so that it's content could be customized.
+ * Changes in 1.1.1
+ * - Fixed CSS styling bug for ie6 caused by a mispelling
+ * - Changes height restriction on default notifications to min-height
+ * - Added skinned examples using a variety of images
+ * - Added the ability to customize the content of the [close all] box
+ * - Added jTweet, an example of using jGrowl + Twitter
+ * Changes in 1.1.0
+ * - Multiple container and instances.
+ * - Standard $.jGrowl() now wraps $.fn.jGrowl() by first establishing a generic jGrowl container.
+ * - Instance methods of a jGrowl container can be called by $.fn.jGrowl(methodName)
+ * - Added glue preferenced, which allows notifications to be inserted before or after nodes in the container
+ * - Added new log callback which is called before anything is done for the notification
+ * - Corner's attribute are now applied on an individual notification basis.
+ * Changes in 1.0.4
+ * - Various CSS fixes so that jGrowl renders correctly in IE6.
+ * Changes in 1.0.3
+ * - Fixed bug with options persisting across notifications
+ * - Fixed theme application bug
+ * - Simplified some selectors and manipulations.
+ * - Added beforeOpen and beforeClose callbacks
+ * - Reorganized some lines of code to be more readable
+ * - Removed unnecessary this.defaults context
+ * - If corners plugin is present, it's now customizable.
+ * - Customizable open animation.
+ * - Customizable close animation.
+ * - Customizable animation easing.
+ * - Added customizable positioning (top-left, top-right, bottom-left, bottom-right, center)
+ * Changes in 1.0.2
+ * - All CSS styling is now external.
+ * - Added a theme parameter which specifies a secondary class for styling, such
+ * that notifications can be customized in appearance on a per message basis.
+ * - Notification life span is now customizable on a per message basis.
+ * - Added the ability to disable the global closer, enabled by default.
+ * - Added callbacks for when a notification is opened or closed.
+ * - Added callback for the global closer.
+ * - Customizable animation speed.
+ * - jGrowl now set itself up and tears itself down.
+ * Changes in 1.0.1:
+ * - Removed dependency on metadata plugin in favor of .data()
+ * - Namespaced all events
+(function($) {
+ /** jGrowl Wrapper - Establish a base jGrowl Container for compatibility with older releases. **/
+ $.jGrowl = function( m , o ) {
+ // To maintain compatibility with older version that only supported one instance we'll create the base container.
+ if ( $('#jGrowl').size() == 0 )
+ $('<div id="jGrowl"></div>').addClass($.jGrowl.defaults.position).appendTo('body');
+ // Create a notification on the container.
+ $('#jGrowl').jGrowl(m,o);
+ /** Raise jGrowl Notification on a jGrowl Container **/
+ $.fn.jGrowl = function( m , o ) {
+ if ( $.isFunction(this.each) ) {
+ var args = arguments;
+ return this.each(function() {
+ var self = this;
+ /** Create a jGrowl Instance on the Container if it does not exist **/
+ if ( $(this).data('jGrowl.instance') == undefined ) {
+ $(this).data('jGrowl.instance', $.extend( new $.fn.jGrowl(), { notifications: [], element: null, interval: null } ));
+ $(this).data('jGrowl.instance').startup( this );
+ /** Optionally call jGrowl instance methods, or just raise a normal notification **/
+ if ( $.isFunction($(this).data('jGrowl.instance')[m]) ) {
+ $(this).data('jGrowl.instance')[m].apply( $(this).data('jGrowl.instance') , $.makeArray(args).slice(1) );
+ } else {
+ $(this).data('jGrowl.instance').create( m , o );
+ $.extend( $.fn.jGrowl.prototype , {
+ /** Default JGrowl Settings **/
+ defaults: {
+ pool: 0,
+ header: '',
+ group: '',
+ sticky: false,
+ position: 'top-right', // Is this still needed?
+ glue: 'after',
+ theme: 'default',
+ corners: '10px',
+ check: 250,
+ life: 3000,
+ speed: 'normal',
+ easing: 'swing',
+ closer: true,
+ closeTemplate: '×',
+ closerTemplate: '<div>[ close all ]</div>',
+ log: function(e,m,o) {},
+ beforeOpen: function(e,m,o) {},
+ open: function(e,m,o) {},
+ beforeClose: function(e,m,o) {},
+ close: function(e,m,o) {},
+ animateOpen: {
+ opacity: 'show'
+ animateClose: {
+ opacity: 'hide'
+ notifications: [],
+ /** jGrowl Container Node **/
+ element: null,
+ /** Interval Function **/
+ interval: null,
+ /** Create a Notification **/
+ create: function( message , o ) {
+ var o = $.extend({}, this.defaults, o);
+ this.notifications.push({ message: message , options: o });
+ o.log.apply( this.element , [this.element,message,o] );
+ render: function( notification ) {
+ var self = this;
+ var message = notification.message;
+ var o = notification.options;
+ var notification = $(
+ '<div class="jGrowl-notification ui-state-highlight ui-corner-all' +
+ ((o.group != undefined && o.group != '') ? ' ' + o.group : '') + '">' +
+ '<div class="close">' + o.closeTemplate + '</div>' +
+ '<div class="header">' + o.header + '</div>' +
+ '<div class="message">' + message + '</div></div>'
+ ).data("jGrowl", o).addClass(o.theme).children('div.close').bind("click.jGrowl", function() {
+ $(this).parent().trigger('jGrowl.close');
+ }).parent();
+ /** Notification Actions **/
+ $(notification).bind("mouseover.jGrowl", function() {
+ $('div.jGrowl-notification', self.element).data("jGrowl.pause", true);
+ }).bind("mouseout.jGrowl", function() {
+ $('div.jGrowl-notification', self.element).data("jGrowl.pause", false);
+ }).bind('jGrowl.beforeOpen', function() {
+ if ( o.beforeOpen.apply( notification , [notification,message,o,self.element] ) != false ) {
+ $(this).trigger('jGrowl.open');
+ }).bind('jGrowl.open', function() {
+ if ( o.open.apply( notification , [notification,message,o,self.element] ) != false ) {
+ if ( o.glue == 'after' ) {
+ $('div.jGrowl-notification:last', self.element).after(notification);
+ } else {
+ $('div.jGrowl-notification:first', self.element).before(notification);
+ $(this).animate(o.animateOpen, o.speed, o.easing, function() {
+ // Fixes some anti-aliasing issues with IE filters.
+ if ($.browser.msie && (parseInt($(this).css('opacity'), 10) === 1 || parseInt($(this).css('opacity'), 10) === 0))
+ this.style.removeAttribute('filter');
+ $(this).data("jGrowl").created = new Date();
+ }).bind('jGrowl.beforeClose', function() {
+ if ( o.beforeClose.apply( notification , [notification,message,o,self.element] ) != false )
+ $(this).trigger('jGrowl.close');
+ }).bind('jGrowl.close', function() {
+ // Pause the notification, lest during the course of animation another close event gets called.
+ $(this).data('jGrowl.pause', true);
+ $(this).animate(o.animateClose, o.speed, o.easing, function() {
+ $(this).remove();
+ var close = o.close.apply( notification , [notification,message,o,self.element] );
+ if ( $.isFunction(close) )
+ close.apply( notification , [notification,message,o,self.element] );
+ }).trigger('jGrowl.beforeOpen');
+ /** Optional Corners Plugin **/
+ if ( $.fn.corner != undefined ) $(notification).corner( o.corners );
+ /** Add a Global Closer if more than one notification exists **/
+ if ( $('div.jGrowl-notification:parent', self.element).size() > 1 &&
+ $('div.jGrowl-closer', self.element).size() == 0 && this.defaults.closer != false ) {
+ $(this.defaults.closerTemplate).addClass('jGrowl-closer ui-state-highlight ui-corner-all').addClass(this.defaults.theme)
+ .appendTo(self.element).animate(this.defaults.animateOpen, this.defaults.speed, this.defaults.easing)
+ .bind("click.jGrowl", function() {
+ $(this).siblings().children('div.close').trigger("click.jGrowl");
+ if ( $.isFunction( self.defaults.closer ) ) {
+ self.defaults.closer.apply( $(this).parent()[0] , [$(this).parent()[0]] );
+ /** Update the jGrowl Container, removing old jGrowl notifications **/
+ update: function() {
+ $(this.element).find('div.jGrowl-notification:parent').each( function() {
+ if ( $(this).data("jGrowl") != undefined && $(this).data("jGrowl").created != undefined &&
+ ($(this).data("jGrowl").created.getTime() + $(this).data("jGrowl").life) < (new Date()).getTime() &&
+ $(this).data("jGrowl").sticky != true &&
+ ($(this).data("jGrowl.pause") == undefined || $(this).data("jGrowl.pause") != true) ) {
+ $(this).trigger('jGrowl.beforeClose');
+ if ( this.notifications.length > 0 &&
+ (this.defaults.pool == 0 || $(this.element).find('div.jGrowl-notification:parent').size() < this.defaults.pool) )
+ this.render( this.notifications.shift() );
+ if ( $(this.element).find('div.jGrowl-notification:parent').size() < 2 ) {
+ $(this.element).find('div.jGrowl-closer').animate(this.defaults.animateClose, this.defaults.speed, this.defaults.easing, function() {
+ $(this).remove();
+ /** Setup the jGrowl Notification Container **/
+ startup: function(e) {
+ this.element = $(e).addClass('jGrowl').append('<div class="jGrowl-notification"></div>');
+ this.interval = setInterval( function() {
+ $(e).data('jGrowl.instance').update();
+ }, this.defaults.check);
+ if ($.browser.msie && parseInt($.browser.version) < 7 && !window["XMLHttpRequest"]) {
+ $(this.element).addClass('ie6');
+ /** Shutdown jGrowl, removing it and clearing the interval **/
+ shutdown: function() {
+ $(this.element).removeClass('jGrowl').find('div.jGrowl-notification').remove();
+ clearInterval( this.interval );
+ close: function() {
+ $(this.element).find('div.jGrowl-notification').each(function(){
+ /** Reference the Defaults Object for compatibility with older versions of jGrowl **/
+ $.jGrowl.defaults = $.fn.jGrowl.prototype.defaults;
+})(jQuery);
Added: trunk/mapbender/http/extensions/jGrowl-1.2.4/jquery.jgrowl_compressed.js
--- trunk/mapbender/http/extensions/jGrowl-1.2.4/jquery.jgrowl_compressed.js (rev 0)
+++ trunk/mapbender/http/extensions/jGrowl-1.2.4/jquery.jgrowl_compressed.js 2009-12-22 13:08:04 UTC (rev 5225)
@@ -0,0 +1,120 @@
+(function($){
+$.jGrowl=function(m,o){
+if($("#jGrowl").size()==0){
+$("<div id=\"jGrowl\"></div>").addClass($.jGrowl.defaults.position).appendTo("body");
+$("#jGrowl").jGrowl(m,o);
+$.fn.jGrowl=function(m,o){
+if($.isFunction(this.each)){
+var _6=arguments;
+return this.each(function(){
+var _7=this;
+if($(this).data("jGrowl.instance")==undefined){
+$(this).data("jGrowl.instance",$.extend(new $.fn.jGrowl(),{notifications:[],element:null,interval:null}));
+$(this).data("jGrowl.instance").startup(this);
+if($.isFunction($(this).data("jGrowl.instance")[m])){
+$(this).data("jGrowl.instance")[m].apply($(this).data("jGrowl.instance"),$.makeArray(_6).slice(1));
+}else{
+$(this).data("jGrowl.instance").create(m,o);
+$.extend($.fn.jGrowl.prototype,{defaults:{pool:0,header:"",group:"",sticky:false,position:"top-right",glue:"after",theme:"default",corners:"10px",check:250,life:3000,speed:"normal",easing:"swing",closer:true,closeTemplate:"×",closerTemplate:"<div>[ close all ]</div>",log:function(e,m,o){
+},beforeOpen:function(e,m,o){
+},open:function(e,m,o){
+},beforeClose:function(e,m,o){
+},close:function(e,m,o){
+},animateOpen:{opacity:"show"},animateClose:{opacity:"hide"}},notifications:[],element:null,interval:null,create:function(_17,o){
+var o=$.extend({},this.defaults,o);
+this.notifications.push({message:_17,options:o});
+o.log.apply(this.element,[this.element,_17,o]);
+},render:function(_19){
+var _1a=this;
+var _1b=_19.message;
+var o=_19.options;
+var _19=$("<div class=\"jGrowl-notification ui-state-highlight ui-corner-all"+((o.group!=undefined&&o.group!="")?" "+o.group:"")+"\">"+"<div class=\"close\">"+o.closeTemplate+"</div>"+"<div class=\"header\">"+o.header+"</div>"+"<div class=\"message\">"+_1b+"</div></div>").data("jGrowl",o).addClass(o.theme).children("div.close").bind("click.jGrowl",function(){
+$(this).parent().trigger("jGrowl.close");
+}).parent();
+$(_19).bind("mouseover.jGrowl",function(){
+$("div.jGrowl-notification",_1a.element).data("jGrowl.pause",true);
+}).bind("mouseout.jGrowl",function(){
+$("div.jGrowl-notification",_1a.element).data("jGrowl.pause",false);
+}).bind("jGrowl.beforeOpen",function(){
+if(o.beforeOpen.apply(_19,[_19,_1b,o,_1a.element])!=false){
+$(this).trigger("jGrowl.open");
+}).bind("jGrowl.open",function(){
+if(o.open.apply(_19,[_19,_1b,o,_1a.element])!=false){
+if(o.glue=="after"){
+$("div.jGrowl-notification:last",_1a.element).after(_19);
+}else{
+$("div.jGrowl-notification:first",_1a.element).before(_19);
+$(this).animate(o.animateOpen,o.speed,o.easing,function(){
+if($.browser.msie&&(parseInt($(this).css("opacity"),10)===1||parseInt($(this).css("opacity"),10)===0)){
+this.style.removeAttribute("filter");
+$(this).data("jGrowl").created=new Date();
+}).bind("jGrowl.beforeClose",function(){
+if(o.beforeClose.apply(_19,[_19,_1b,o,_1a.element])!=false){
+$(this).trigger("jGrowl.close");
+}).bind("jGrowl.close",function(){
+$(this).data("jGrowl.pause",true);
+$(this).animate(o.animateClose,o.speed,o.easing,function(){
+$(this).remove();
+var _1d=o.close.apply(_19,[_19,_1b,o,_1a.element]);
+if($.isFunction(_1d)){
+_1d.apply(_19,[_19,_1b,o,_1a.element]);
+}).trigger("jGrowl.beforeOpen");
+if($.fn.corner!=undefined){
+$(_19).corner(o.corners);
+if($("div.jGrowl-notification:parent",_1a.element).size()>1&&$("div.jGrowl-closer",_1a.element).size()==0&&this.defaults.closer!=false){
+$(this.defaults.closerTemplate).addClass("jGrowl-closer ui-state-highlight ui-corner-all").addClass(this.defaults.theme).appendTo(_1a.element).animate(this.defaults.animateOpen,this.defaults.speed,this.defaults.easing).bind("click.jGrowl",function(){
+$(this).siblings().children("div.close").trigger("click.jGrowl");
+if($.isFunction(_1a.defaults.closer)){
+_1a.defaults.closer.apply($(this).parent()[0],[$(this).parent()[0]]);
+},update:function(){
+$(this.element).find("div.jGrowl-notification:parent").each(function(){
+if($(this).data("jGrowl")!=undefined&&$(this).data("jGrowl").created!=undefined&&($(this).data("jGrowl").created.getTime()+$(this).data("jGrowl").life)<(new Date()).getTime()&&$(this).data("jGrowl").sticky!=true&&($(this).data("jGrowl.pause")==undefined||$(this).data("jGrowl.pause")!=true)){
+$(this).trigger("jGrowl.beforeClose");
+if(this.notifications.length>0&&(this.defaults.pool==0||$(this.element).find("div.jGrowl-notification:parent").size()<this.defaults.pool)){
+this.render(this.notifications.shift());
+if($(this.element).find("div.jGrowl-notification:parent").size()<2){
+$(this.element).find("div.jGrowl-closer").animate(this.defaults.animateClose,this.defaults.speed,this.defaults.easing,function(){
+$(this).remove();
+},startup:function(e){
+this.element=$(e).addClass("jGrowl").append("<div class=\"jGrowl-notification\"></div>");
+this.interval=setInterval(function(){
+$(e).data("jGrowl.instance").update();
+},this.defaults.check);
+if($.browser.msie&&parseInt($.browser.version)<7&&!window["XMLHttpRequest"]){
+$(this.element).addClass("ie6");
+},shutdown:function(){
+$(this.element).removeClass("jGrowl").find("div.jGrowl-notification").remove();
+clearInterval(this.interval);
+},close:function(){
+$(this.element).find("div.jGrowl-notification").each(function(){
+$.jGrowl.defaults=$.fn.jGrowl.prototype.defaults;
+})(jQuery);
Added: trunk/mapbender/http/extensions/jGrowl-1.2.4/jquery.jgrowl_minimized.js
--- trunk/mapbender/http/extensions/jGrowl-1.2.4/jquery.jgrowl_minimized.js (rev 0)
+++ trunk/mapbender/http/extensions/jGrowl-1.2.4/jquery.jgrowl_minimized.js 2009-12-22 13:08:04 UTC (rev 5225)
@@ -0,0 +1,9 @@
+(function($){$.jGrowl=function(m,o){if($('#jGrowl').size()==0)
+$('<div id="jGrowl"></div>').addClass($.jGrowl.defaults.position).appendTo('body');$('#jGrowl').jGrowl(m,o);};$.fn.jGrowl=function(m,o){if($.isFunction(this.each)){var args=arguments;return this.each(function(){var self=this;if($(this).data('jGrowl.instance')==undefined){$(this).data('jGrowl.instance',$.extend(new $.fn.jGrowl(),{notifications:[],element:null,interval:null}));$(this).data('jGrowl.instance').startup(this);}
+if($.isFunction($(this).data('jGrowl.instance')[m])){$(this).data('jGrowl.instance')[m].apply($(this).data('jGrowl.instance'),$.makeArray(args).slice(1));}else{$(this).data('jGrowl.instance').create(m,o);}});};};$.extend($.fn.jGrowl.prototype,{defaults:{pool:0,header:'',group:'',sticky:false,position:'top-right',glue:'after',theme:'default',corners:'10px',check:250,life:3000,speed:'normal',easing:'swing',closer:true,closeTemplate:'×',closerTemplate:'<div>[ close all ]</div>',log:function(e,m,o){},beforeOpen:function(e,m,o){},open:function(e,m,o){},beforeClose:function(e,m,o){},close:function(e,m,o){},animateOpen:{opacity:'show'},animateClose:{opacity:'hide'}},notifications:[],element:null,interval:null,create:function(message,o){var o=$.extend({},this.defaults,o);this.notifications.push({message:message,options:o});o.log.apply(this.element,[this.element,message,o]);},render:function(notification){var self=this;var message=notification.message;var o=notification.options;var notification=$('<div class="jGrowl-notification ui-state-highlight ui-corner-all'+
+((o.group!=undefined&&o.group!='')?' '+o.group:'')+'">'+'<div class="close">'+o.closeTemplate+'</div>'+'<div class="header">'+o.header+'</div>'+'<div class="message">'+message+'</div></div>').data("jGrowl",o).addClass(o.theme).children('div.close').bind("click.jGrowl",function(){$(this).parent().trigger('jGrowl.close');}).parent();$(notification).bind("mouseover.jGrowl",function(){$('div.jGrowl-notification',self.element).data("jGrowl.pause",true);}).bind("mouseout.jGrowl",function(){$('div.jGrowl-notification',self.element).data("jGrowl.pause",false);}).bind('jGrowl.beforeOpen',function(){if(o.beforeOpen.apply(notification,[notification,message,o,self.element])!=false){$(this).trigger('jGrowl.open');}}).bind('jGrowl.open',function(){if(o.open.apply(notification,[notification,message,o,self.element])!=false){if(o.glue=='after'){$('div.jGrowl-notification:last',self.element).after(notification);}else{$('div.jGrowl-notification:first',self.element).before(notification);}
+$(this).animate(o.animateOpen,o.speed,o.easing,function(){if($.browser.msie&&(parseInt($(this).css('opacity'),10)===1||parseInt($(this).css('opacity'),10)===0))
+this.style.removeAttribute('filter');$(this).data("jGrowl").created=new Date();});}}).bind('jGrowl.beforeClose',function(){if(o.beforeClose.apply(notification,[notification,message,o,self.element])!=false)
+$(this).trigger('jGrowl.close');}).bind('jGrowl.close',function(){$(this).data('jGrowl.pause',true);$(this).animate(o.animateClose,o.speed,o.easing,function(){$(this).remove();var close=o.close.apply(notification,[notification,message,o,self.element]);if($.isFunction(close))
+close.apply(notification,[notification,message,o,self.element]);});}).trigger('jGrowl.beforeOpen');if($.fn.corner!=undefined)$(notification).corner(o.corners);if($('div.jGrowl-notification:parent',self.element).size()>1&&$('div.jGrowl-closer',self.element).size()==0&&this.defaults.closer!=false){$(this.defaults.closerTemplate).addClass('jGrowl-closer ui-state-highlight ui-corner-all').addClass(this.defaults.theme).appendTo(self.element).animate(this.defaults.animateOpen,this.defaults.speed,this.defaults.easing).bind("click.jGrowl",function(){$(this).siblings().children('div.close').trigger("click.jGrowl");if($.isFunction(self.defaults.closer)){self.defaults.closer.apply($(this).parent()[0],[$(this).parent()[0]]);}});};},update:function(){$(this.element).find('div.jGrowl-notification:parent').each(function(){if($(this).data("jGrowl")!=undefined&&$(this).data("jGrowl").created!=undefined&&($(this).data("jGrowl").created.getTime()+$(this).data("jGrowl").life)<(new Date()).getTime()&&$(this).data("jGrowl").sticky!=true&&($(this).data("jGrowl.pause")==undefined||$(this).data("jGrowl.pause")!=true)){$(this).trigger('jGrowl.beforeClose');}});if(this.notifications.length>0&&(this.defaults.pool==0||$(this.element).find('div.jGrowl-notification:parent').size()<this.defaults.pool))
+this.render(this.notifications.shift());if($(this.element).find('div.jGrowl-notification:parent').size()<2){$(this.element).find('div.jGrowl-closer').animate(this.defaults.animateClose,this.defaults.speed,this.defaults.easing,function(){$(this).remove();});}},startup:function(e){this.element=$(e).addClass('jGrowl').append('<div class="jGrowl-notification"></div>');this.interval=setInterval(function(){$(e).data('jGrowl.instance').update();},this.defaults.check);if($.browser.msie&&parseInt($.browser.version)<7&&!window["XMLHttpRequest"]){$(this.element).addClass('ie6');}},shutdown:function(){$(this.element).removeClass('jGrowl').find('div.jGrowl-notification').remove();clearInterval(this.interval);},close:function(){$(this.element).find('div.jGrowl-notification').each(function(){$(this).trigger('jGrowl.beforeClose');});}});$.jGrowl.defaults=$.fn.jGrowl.prototype.defaults;})(jQuery);
Added: trunk/mapbender/http/javascripts/jq_jgrowl.js
--- trunk/mapbender/http/javascripts/jq_jgrowl.js (rev 0)
+++ trunk/mapbender/http/javascripts/jq_jgrowl.js 2009-12-22 13:08:04 UTC (rev 5225)
@@ -0,0 +1,40 @@
+ * Package: jq_jgrowl
+ * Description:
+ * The container for the jQuery plugin jGrowl
+ * Files:
+ * - http/javascripts/jq_ui_effects.js
+ * - http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.*
+ * SQL:
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES('<appId>','jq_jgrowl',1,1,'',
+ * > '','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','jq_jgrowl.js',
+ * > '../extensions/jGrowl-1.2.4/jquery.jgrowl_minimized.js','','',
+ * > 'http://stanlemon.net/projects/jgrowl.html');
+ * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value,
+ * > context, var_type) VALUES('<appId>', 'body', 'jq_jgrowl',
+ * > '../extensions/jGrowl-1.2.4/jquery.jgrowl.css', '' ,'file/css');
+ * Help:
+ * http://www.mapbender.org/jq_jgrowl
+ * http://stanlemon.net/projects/jgrowl.html
+ * Maintainer:
+ * http://www.mapbender.org/User:Christoph_Baudson
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+function alert (msg) {
+ $.jGrowl(msg);
More information about the Mapbender_commits
