[Mapbender-commits] r5227 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Dec 22 08:24:20 EST 2009
Author: christoph
Date: 2009-12-22 08:24:19 -0500 (Tue, 22 Dec 2009)
New Revision: 5227
Added:
   trunk/mapbender/http/javascripts/jq_ui_effects.php
Added: trunk/mapbender/http/javascripts/jq_ui_effects.php
--- trunk/mapbender/http/javascripts/jq_ui_effects.php	                        (rev 0)
+++ trunk/mapbender/http/javascripts/jq_ui_effects.php	2009-12-22 13:24:19 UTC (rev 5227)
@@ -0,0 +1,155 @@
+ * Package: jq_ui_effects
+ * Description:
+ * A collection of jQuery UI effects
+ * Files:
+ *  - http/javascripts/jq_ui_effects.js
+ *  - http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.*
+ * SQL:
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES('<appId>','jq_ui_effects',
+ * > 1,1,'','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','',
+ * > 'jq_ui_effects.php',
+ * > '../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.effects.core.js',
+ * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value,
+ * > context, var_type) VALUES('<appId>', 'body', 'jq_ui_effect_transfer',
+ * > '.ui-effects-transfer { z-index:1003; border: 2px dotted gray; } ',
+ * > '' ,'text/css');
+ * > context, var_type) VALUES('<appId>', 'jq_ui_effects', 'blind', '0',
+ * > '1 = effect active' ,'php_var');
+ * > context, var_type) VALUES('<appId>', 'jq_ui_effects', 'bounce', '0',
+ * > context, var_type) VALUES('<appId>', 'jq_ui_effects', 'clip', '0',
+ * > context, var_type) VALUES('<appId>', 'jq_ui_effects', 'drop', '0',
+ * > context, var_type) VALUES('<appId>', 'jq_ui_effects', 'explode', '0',
+ * > context, var_type) VALUES('<appId>', 'jq_ui_effects', 'fold', '0',
+ * > context, var_type) VALUES('<appId>', 'jq_ui_effects', 'highlight', '0',
+ * > context, var_type) VALUES('<appId>', 'jq_ui_effects', 'pulsate', '0',
+ * > context, var_type) VALUES('<appId>', 'jq_ui_effects', 'scale', '0',
+ * > context, var_type) VALUES('<appId>', 'jq_ui_effects', 'shake', '0',
+ * > context, var_type) VALUES('<appId>', 'jq_ui_effects', 'slide', '0',
+ * > context, var_type) VALUES('<appId>', 'jq_ui_effects', 'transfer', '1',
+ * Help:
+ * http://www.mapbender.org/jq_ui_effects
+ * Maintainer:
+ * http://www.mapbender.org/User:Christoph_Baudson
+ * Parameters (PHP):
+ * blind      - set to 1 to activate this effect, 0 to disable
+ * bounce     - set to 1 to activate this effect, 0 to disable
+ * clip       - set to 1 to activate this effect, 0 to disable
+ * drop       - set to 1 to activate this effect, 0 to disable
+ * explode    - set to 1 to activate this effect, 0 to disable
+ * fold       - set to 1 to activate this effect, 0 to disable
+ * highlight  - set to 1 to activate this effect, 0 to disable
+ * pulsate    - set to 1 to activate this effect, 0 to disable
+ * scale      - set to 1 to activate this effect, 0 to disable
+ * shake      - set to 1 to activate this effect, 0 to disable
+ * slide      - set to 1 to activate this effect, 0 to disable
+ * transfer   - set to 1 to activate this effect, 0 to disable
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+<?php
+	$uiPath = dirname(__FILE__) . '/' .
+		"../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/";
+	include '../include/dyn_php.php';
+	if ($blind) {
+		include $uiPath . "min.effects.blind.js";
+	if ($bounce) {
+		include $uiPath . "min.effects.bounce.js";
+	if ($clip) {
+		include $uiPath . "min.effects.clip.js";
+	if ($drop) {
+		include $uiPath . "min.effects.drop.js";
+	if ($explode) {
+		include $uiPath . "min.effects.explode.js";
+	if ($fold) {
+		include $uiPath . "min.effects.fold.js";
+	if ($highlight) {
+		include $uiPath . "min.effects.highlight.js";
+	if ($pulsate) {
+		include $uiPath . "min.effects.pulsate.js";
+	if ($scale) {
+		include $uiPath . "min.effects.scale.js";
+	if ($shake) {
+		include $uiPath . "min.effects.shake.js";
+	if ($slide) {
+		include $uiPath . "min.effects.slide.js";
+	if ($transfer) {
+		include $uiPath . "min.effects.transfer.js";
\ No newline at end of file
More information about the Mapbender_commits mailing list
