[Mapbender-commits] r3517 - in trunk/mapbender/http: classes javascripts php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Feb 5 04:46:20 EST 2009
Author: christoph
Date: 2009-02-05 04:46:20 -0500 (Thu, 05 Feb 2009)
New Revision: 3517
   trunk/mapbender/http/classes/class_connector.php
   trunk/mapbender/http/classes/class_ows.php
   trunk/mapbender/http/classes/class_wfs.php
   trunk/mapbender/http/classes/class_wfs_1_0_factory.php
   trunk/mapbender/http/classes/class_wfs_1_1_factory.php
   trunk/mapbender/http/classes/class_wfs_factory.php
   trunk/mapbender/http/classes/class_wfs_featuretype.php
   trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php
   trunk/mapbender/http/php/mod_loadwfs.php
wfs featuretype is no longer abstract
getfeature us done via POST
Modified: trunk/mapbender/http/classes/class_connector.php
--- trunk/mapbender/http/classes/class_connector.php	2009-02-04 10:22:50 UTC (rev 3516)
+++ trunk/mapbender/http/classes/class_connector.php	2009-02-05 09:46:20 UTC (rev 3517)
@@ -55,6 +55,10 @@
 	 * Loads content from the given URL.
 	public function load($url) {
+		if (!$url) {
+			$e = new mb_exception("connector: no URL given");
+			return false;
 		switch ($this->connectionType) {
 			case "curl":
 				if (in_array($host, $NOT_PROXY_HOSTS_array)){
Modified: trunk/mapbender/http/classes/class_ows.php
--- trunk/mapbender/http/classes/class_ows.php	2009-02-04 10:22:50 UTC (rev 3516)
+++ trunk/mapbender/http/classes/class_ows.php	2009-02-05 09:46:20 UTC (rev 3517)
@@ -45,7 +45,24 @@
 	var $electronicMailAddress;
 	var $country;
+	 * Get namespace from a tag name.
+	 * Example: input is "topp:the_geom" will return "topp".
+	 * @return String
+	 * @param $s String
+	final protected function getNameSpace($s) {
+		$c = strpos($s, ":");
+		if ($c > 0) {
+			return substr($s, 0, $c);
+		return $s;
 	 * Returns the conjunction character of an URL
 	 * @param String $url
Modified: trunk/mapbender/http/classes/class_wfs.php
--- trunk/mapbender/http/classes/class_wfs.php	2009-02-04 10:22:50 UTC (rev 3516)
+++ trunk/mapbender/http/classes/class_wfs.php	2009-02-05 09:46:20 UTC (rev 3517)
@@ -46,21 +46,62 @@
 		array_push($this->featureTypeArray, $aFeatureType);
+	protected function findFeatureTypeByName ($name) {
+		foreach ($this->featureTypeArray as $ft) {
+			if ($ft->name == $name) {
+				return $ft;
+		return null;
 	public function getFeature ($featureTypeName, $filter) {
+/* POST */
-		$url = $this->getFeature .
-				$this->getConjunctionCharacter($this->getFeature) .
-				"service=WFS&request=getFeature&version=" .
-				$this->getVersion() . "&typename=" . $featureTypeName .
-				"&filter=" . urlencode($filter);
+		$postData = "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n" .
+			"<wfs:GetFeature version=\"" . $this->getVersion() . "\" " .
+			"xmlns:wfs=\"http://www.opengis.net/wfs\">" .
+			"<wfs:Query ";
+		// add namespace
+		if (strpos($featureTypeName, ":") !== false) {
+			$ft = $this->findFeatureTypeByName($featureTypeName);
+			$ns = $this->getNamespace($featureTypeName);
+			$url = $ft->getNamespace($ns);
+			$postData .= "xmlns:" . $ns . "=\"" . $url . "\" ";
+		$postData .= "typeName=\"" . $featureTypeName . "\"/>" .
+			"</wfs:GetFeature>";
-		$connection = new connector($url);
-		$data = $connection->file;
+		$connection = new connector();
+		$connection->set("httpType", "post");
+		$connection->set("httpContentType", "xml");
+		$connection->set("httpPostData", $postData);
+		$data = $connection->load($this->getFeature);
 		if (!$data) {
-			$e = new mb_exception("WFS request returned no result: " . $url);
+			$e = new mb_exception("WFS request returned no result: " . $url . "\n" . $postData);
 			return null;
 		return $data;
+/* GET */
+//		$url = $this->getFeature .
+//				$this->getConjunctionCharacter($this->getFeature) .
+//				"service=WFS&request=getFeature&version=" .
+//				$this->getVersion() . "&typename=" . $featureTypeName .
+//				"&filter=" . urlencode($filter);
+//		$connection = new connector($url);
+//		$data = $connection->file;
+//		if (!$data) {
+//			$e = new mb_exception("WFS request returned no result: " . $url);
+//			return null;
+//		return $data;
Modified: trunk/mapbender/http/classes/class_wfs_1_0_factory.php
--- trunk/mapbender/http/classes/class_wfs_1_0_factory.php	2009-02-04 10:22:50 UTC (rev 3516)
+++ trunk/mapbender/http/classes/class_wfs_1_0_factory.php	2009-02-05 09:46:20 UTC (rev 3517)
@@ -32,7 +32,7 @@
 class Wfs_1_0_Factory extends WfsFactory {
 	protected function createFeatureTypeFromXml ($xml, $myWfs) {
-		$newFeatureType = new Wfs_1_0_FeatureType($myWfs);
+		$newFeatureType = new WfsFeatureType($myWfs);
 		$admin = new administration();
 		$values = $admin->parseXml($xml);
@@ -166,7 +166,7 @@
 					$currentFeatureType = $this->createFeatureTypeFromUrl($myWfs, $featuretype_name, $featureTypeNsArray);
 					if ($currentFeatureType !== null) {
-						$currentFeatureType->name = $this->sepNameSpace($featuretype_name);
+						$currentFeatureType->name = $featuretype_name;
 						$currentFeatureType->title = $featuretype_title;
 						$currentFeatureType->summary = $featuretype_abstract;
 						$currentFeatureType->srs = $featuretype_srs;
Modified: trunk/mapbender/http/classes/class_wfs_1_1_factory.php
--- trunk/mapbender/http/classes/class_wfs_1_1_factory.php	2009-02-04 10:22:50 UTC (rev 3516)
+++ trunk/mapbender/http/classes/class_wfs_1_1_factory.php	2009-02-05 09:46:20 UTC (rev 3517)
@@ -32,7 +32,7 @@
 class Wfs_1_1_Factory extends WfsFactory {
-		$newFeatureType = new Wfs_1_1_FeatureType($myWfs);
@@ -167,7 +167,7 @@
Modified: trunk/mapbender/http/classes/class_wfs_factory.php
--- trunk/mapbender/http/classes/class_wfs_factory.php	2009-02-04 10:22:50 UTC (rev 3516)
+++ trunk/mapbender/http/classes/class_wfs_factory.php	2009-02-05 09:46:20 UTC (rev 3517)
@@ -20,6 +20,7 @@
 require_once(dirname(__FILE__)."/../../core/globalSettings.php");
 require_once(dirname(__FILE__)."/../classes/class_administration.php");
 require_once(dirname(__FILE__)."/../classes/class_ows_factory.php");
+require_once(dirname(__FILE__)."/../classes/class_wfs_featuretype.php");
@@ -88,7 +89,6 @@
 		while(db_fetch_row($res)){
 			$aWfs->id = db_result($res, $cnt, "wfs_id");
-			new mb_exception("WFS:".$aWfs->id);
 			$aWfs->name = db_result($res, $cnt, "wfs_name");
 			$aWfs->title = db_result($res, $cnt, "wfs_title");
 			$aWfs->summary = db_result($res, $cnt, "wfs_abstract");
@@ -112,42 +112,46 @@
 			while(db_fetch_row($res_fe)){
-				$c = count($aWfs->featureTypeArray);
-				$aWfs->featureTypeArray[$c]->id = db_result($res_fe, $cnt_fe, "featuretype_id");
-				new mb_exception("FT:".$aWfs->featureTypeArray[$c]->id);
-				$aWfs->featureTypeArray[$c]->name = db_result($res_fe, $cnt_fe, "featuretype_name");
-				$aWfs->featureTypeArray[$c]->title = db_result($res_fe, $cnt_fe, "featuretype_title");
-				$aWfs->featureTypeArray[$c]->summary = db_result($res_fe, $cnt_fe, "featuretype_abstract");
-				$aWfs->featureTypeArray[$c]->srs = db_result($res_fe, $cnt_fe, "featuretype_srs");
+				$ft = new WfsFeatureType($aWfs);
+				$ft->id = db_result($res_fe, $cnt_fe, "featuretype_id");
+				$ft->name = db_result($res_fe, $cnt_fe, "featuretype_name");
+				$ft->title = db_result($res_fe, $cnt_fe, "featuretype_title");
+				$ft->summary = db_result($res_fe, $cnt_fe, "featuretype_abstract");
+				$ft->srs = db_result($res_fe, $cnt_fe, "featuretype_srs");
 				// Elements
 				$sql_el = "SELECT * FROM wfs_element WHERE fkey_featuretype_id = $1 ORDER BY element_id";
-				$v = array($aWfs->featureTypeArray[$c]->id);
+				$v = array($ft->id);
 				$t = array("i");
 				$res_el = db_prep_query($sql_el, $v, $t);
 				$cnt_el = 0;
 				while(db_fetch_row($res_el)){
-					$z = count($aWfs->featureTypeArray[$c]->elementArray);
-					$aWfs->featureTypeArray[$c]->elementArray[$z] = new stdClass();
-					$aWfs->featureTypeArray[$c]->elementArray[$z]->id = db_result($res_el, $cnt_el, "element_id");
-					$aWfs->featureTypeArray[$c]->elementArray[$z]->name = db_result($res_el, $cnt_el, "element_name");
-					$aWfs->featureTypeArray[$c]->elementArray[$z]->type = db_result($res_el, $cnt_el, "element_type");
+					$ft->addElement(
+						db_result($res_el, $cnt_el, "element_name"),
+						db_result($res_el, $cnt_el, "element_type"),
+						db_result($res_el, $cnt_el, "element_id")
 					$cnt_el++;
 				//Namespaces
 				$sql_ns = "SELECT * FROM wfs_featuretype_namespace WHERE fkey_featuretype_id = $1 ORDER BY namespace";
 				$t = array("i");
 				$res_ns = db_prep_query($sql_ns, $v, $t);
 				$cnt_ns = 0;
 				while(db_fetch_row($res_ns)){
-					$z = count($aWfs->featureTypeArray[$c]->namespaceArray);
-					$aWfs->featureTypeArray[$c]->namespaceArray[$z] = new stdClass();
-					$aWfs->featureTypeArray[$c]->namespaceArray[$z]->name = db_result($res_ns, $cnt_ns, "namespace");
-					$aWfs->featureTypeArray[$c]->namespaceArray[$z]->value = db_result($res_ns, $cnt_ns, "namespace_location");
+					$ft->addNamespace(
+						db_result($res_ns, $cnt_ns, "namespace"),
+						db_result($res_ns, $cnt_ns, "namespace_location")
 					$cnt_ns++;
+				$aWfs->addFeatureType($ft);
 				$cnt_fe++;
 			$cnt++;
Modified: trunk/mapbender/http/classes/class_wfs_featuretype.php
--- trunk/mapbender/http/classes/class_wfs_featuretype.php	2009-02-04 10:22:50 UTC (rev 3516)
+++ trunk/mapbender/http/classes/class_wfs_featuretype.php	2009-02-05 09:46:20 UTC (rev 3517)
@@ -22,7 +22,7 @@
 require_once(dirname(__FILE__)."/class_administration.php");
 require_once(dirname(__FILE__)."/class_wfs.php");
-abstract class WfsFeatureType {
+class WfsFeatureType {
 	var $id;
 	var $name;
 	var $title;
@@ -32,7 +32,11 @@
 	var $namespaceArray = array();
 	var $elementArray = array();
-	private function hasNamespace ($key, $value) {
+	public function __construct ($aWfs) {
+		$this->wfs = $aWfs;
+	public function hasNamespace ($key, $value) {
 		for ($i = 0; $i < count($this->namespaceArray); $i++) {
 			if ($this->namespaceArray[$i]->name == $key &&
 				$this->namespaceArray[$i]->value == $value)
@@ -43,6 +47,15 @@
 		return false;
+	public function getNamespace ($key) {
+		for ($i = 0; $i < count($this->namespaceArray); $i++) {
+			if ($this->namespaceArray[$i]->name == $key) {
+				return $this->namespaceArray[$i]->value;
+		return null;
 	public function addNamespace ($key, $value) {
 		if ($this->hasNamespace($key, $value)) {
 			return $this;
@@ -59,7 +72,14 @@
 	public function addElement ($name, $type) {
 		$newElement = new stdClass();
-		$newElement->id = null;
+		if (func_num_args() == 3) {
+			$newElement->id = func_get_arg(2);
+		else {
+			$newElement->id = null;
 		$newElement->name = $name;
 		$newElement->type = $type;
@@ -94,22 +114,4 @@
 		return $this->toHtml();
- * This class will be implemented only if needed
-class Wfs_1_0_FeatureType extends WfsFeatureType {
-	public function __construct ($aWfs) {
-		$this->wfs = $aWfs;
-class Wfs_1_1_FeatureType extends WfsFeatureType {
\ No newline at end of file
Modified: trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php
--- trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php	2009-02-04 10:22:50 UTC (rev 3516)
+++ trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php	2009-02-05 09:46:20 UTC (rev 3517)
@@ -979,10 +979,6 @@
 	       		//andConditions += "</ogc:PropertyIsNull></ogc:Not>";
-			var u = global_wfsConfObj[global_selectedWfsConfId].wfs_getfeature + parent.mb_getConjunctionCharacter(global_wfsConfObj[global_selectedWfsConfId].wfs_getfeature);
-			u += "REQUEST=getFeature&Typename="+global_wfsConfObj[global_selectedWfsConfId].featuretype_name+"&Version=1.0.0&service=WFS";
-			u += "&filter=";
 			if (filterParameterCount > 1 || spatialRequestGeom != null) {
 				andConditions = "<And>" + andConditions + "</And>";
@@ -995,7 +991,6 @@
 				"wfs_conf_id" : global_selectedWfsConfId,
 				"typename" : global_wfsConfObj[global_selectedWfsConfId].featuretype_name,
 				"frame" : this.name,
-				"url" : u,
 				"filter" : filter,
 				"backlink" : ""
Modified: trunk/mapbender/http/php/mod_loadwfs.php
--- trunk/mapbender/http/php/mod_loadwfs.php	2009-02-04 10:22:50 UTC (rev 3516)
+++ trunk/mapbender/http/php/mod_loadwfs.php	2009-02-05 09:46:20 UTC (rev 3517)
@@ -32,7 +32,7 @@
 $myWfsFactory = new UniversalWfsFactory();
 $myWfs = $myWfsFactory->createFromUrl($url);
-if ($myWfs == null) {
+if (is_null($myWfs)) {
 	echo "WFS could not be uploaded.";
 $myWfs->insertOrUpdate();
More information about the Mapbender_commits mailing list
