[Mapbender-commits] r3521 - trunk/mapbender/http/classes
    svn_mapbender at osgeo.org
    Fri Feb  6 11:14:30 EST 2009
Author: christoph
Date: 2009-02-06 11:14:29 -0500 (Fri, 06 Feb 2009)
New Revision: 3521
   trunk/mapbender/http/classes/class_connector.php
   trunk/mapbender/http/classes/class_gml_3_factory.php
   trunk/mapbender/http/classes/class_universal_gml_factory.php
   trunk/mapbender/http/classes/class_wfs.php
WFS redesign
Modified: trunk/mapbender/http/classes/class_connector.php
--- trunk/mapbender/http/classes/class_connector.php	2009-02-06 14:54:33 UTC (rev 3520)
+++ trunk/mapbender/http/classes/class_connector.php	2009-02-06 16:14:29 UTC (rev 3521)
@@ -139,7 +139,7 @@
 	private function isValidHttpContentType ($value) {
 		$validHttpContentTypeArray = array("XML");
 		if (in_array(mb_strtoupper($value), $validHttpContentTypeArray)) {
-			switch ($value) {
+			switch (mb_strtoupper($value)) {
 				case "XML":
 					$this->httpContentType = "application/xml";
 					break;
@@ -181,16 +181,36 @@
 				$port = 80;
 			$path = $urlComponentArray["path"];
+			$query = $urlComponentArray["query"];
 			$buf = '';
 		    $fp = fsockopen($host, $port);
-		    fputs($fp, "POST $path HTTP/".$this->httpVersion . "\r\n");
-		    fputs($fp, "Host: $host\r\n");
+			$postStr = "";
+			$postPath = "POST " . $path . "?" . $query . " HTTP/".$this->httpVersion . "\r\n";
+			$postStr .= $postPath;
+		    fputs($fp, $postPath);
+			$postHost = "Host: " . $host . "\r\n";
+			$postStr .= $postHost;
+		    fputs($fp, $postHost);
 		    if ($this->isValidHttpContentType($this->httpContentType)) {
-		    	fputs($fp,"Content-type: " . $this->httpContentType . "\r\n");
+				$postContentType = "Content-type: " . $this->httpContentType . "\r\n";
+				$postStr .= $postContentType;
+		    	fputs($fp, $postContentType);
-		    fputs($fp, "Content-length: " . strlen($this->httpPostData) . "\r\n");
-		    fputs($fp, "Connection: close\r\n\r\n");
-		    fputs($fp, $this->httpPostData);
+			$postContentLength = "Content-length: " . strlen($this->httpPostData) . "\r\n";
+			$postStr .= $postContentLength;
+		    fputs($fp, $postContentLength);
+			$postClose = "Connection: close\r\n\r\n";
+			$postStr .= $postClose;
+		    fputs($fp, $postClose);
+		    $postStr .= $this->httpPostData;
+			fputs($fp, $this->httpPostData);
+			new mb_exception($postStr);
 		    $xmlstr = false;
 		    while (!feof($fp)) {
 		    	$content = fgets($fp,4096);
Modified: trunk/mapbender/http/classes/class_gml_3_factory.php
--- trunk/mapbender/http/classes/class_gml_3_factory.php	2009-02-06 14:54:33 UTC (rev 3520)
+++ trunk/mapbender/http/classes/class_gml_3_factory.php	2009-02-06 16:14:29 UTC (rev 3521)
@@ -45,8 +45,17 @@
 		return parent::createFromXml($xml, $gml3);
+	protected function getDimensionFromNode ($domNode) {
+		if (!$domNode->hasAttribute("srsDimension")) {
+			return 2;
+		$dim = intval($domNode->getAttribute("srsDimension"), 10);
+		if (2 == $dim || 3 == $dim) {
+			return $dim;
+		return 2;
 	function findNameSpace($s){
 		list($ns,$FeaturePropertyName) = split(":",$s);
 		$nodeName = array('ns' => $ns, 'value' => $FeaturePropertyName);
@@ -56,8 +65,8 @@
 	private function parsePoint ($domNode, $gmlPoint) {
 		$currentSibling = $domNode->firstChild;
 		while ($currentSibling) {
-			list($x, $y, $z) = explode(",", $currentSibling->nodeValue);
-			$gmlPoint->setPoint($x, $y);
+			$coordArray = explode(" ", $currentSibling->nodeValue);
+			$gmlPoint->setPoint($coordArray[0], $coordArray[1]);
 			$currentSibling = $currentSibling->nextSibling;
@@ -65,9 +74,12 @@
 	private function parseLine ($domNode, $gmlLine) {
-			foreach(explode(' ',$currentSibling->nodeValue) as $cords){
-				list($x,$y,$z) = explode(',',$cords);
+			$dim = $this->getDimensionFromNode($currentSibling);
+			$coordArray = explode(' ', trim($currentSibling->nodeValue));
+			for ($i = 0; $i < count($coordArray); $i += $dim) {
+				$x = $coordArray[$i];
+				$y = $coordArray[$i+1];
 				$gmlLine->addPoint($x, $y);
@@ -84,16 +96,14 @@
 		$cnt=0;
 		foreach ($allCoords as $Coords) {
 			$coordsDom = dom_import_simplexml($Coords);
-			$dim = $coordsDom->getAttribute("srsDimension");
-			if ($dim == "2") {
-				$coordArray = explode(' ', trim($coordsDom->nodeValue));
-				for ($i = 0; $i < count($coordArray); $i += 2) {
-					$x = $coordArray[$i];
-					$y = $coordArray[$i+1];
-					$gmlPolygon->addPoint($x, $y);
+			$dim = $this->getDimensionFromNode($coordsDom);
+			$coordArray = explode(' ', trim($coordsDom->nodeValue));
+				$gmlPolygon->addPoint($x, $y);
 			$cnt++;
@@ -105,14 +115,12 @@
 				foreach ($coordinates as $coordinate) {
 					$coordsDom = dom_import_simplexml($coordinate);
-							$gmlPolygon->addPointToRing($ringCount, $x, $y);
+						$gmlPolygon->addPointToRing($ringCount, $x, $y);
 				$ringCount++;
@@ -125,7 +133,7 @@
 		$simpleXMLNode->registerXPathNamespace('gml', 'http://www.opengis.net/gml');
-		$allCoords = $simpleXMLNode->xpath("gml:lineStringMember/gml:LineString/gml:coordinates");
+		$allCoords = $simpleXMLNode->xpath("gml:curveMembers/gml:LineString/gml:posList");
 		$cnt=0;
@@ -133,16 +141,14 @@
 			$gmlMultiLine->lineArray[$cnt] = array();
-//			$name = $coordsDom->nodeName;
-//			$value = $coordsDom->nodeValue;
-//			echo "===> name: ".$name. ", Value: ".$value."<br>";
-			foreach(explode(' ',$coordsDom->nodeValue) as $pointCoords){
-				list($x,$y,$z) = explode(',',$pointCoords);
 				$gmlMultiLine->addPoint($x, $y, $cnt);
 			$cnt++;
@@ -163,19 +169,14 @@
-						$gmlMultiPolygon->addPoint($x, $y, $cnt);
+					$gmlMultiPolygon->addPoint($x, $y, $cnt);
-				// assume $dim == "3"
-				else {
-					$e = new mb_exception("GML with three-dimensional coordinates are not supported.");
 			$gmlMultiPolygon->innerRingArray[$cnt] = array();
@@ -189,19 +190,13 @@
-									$gmlMultiPolygon->addPointToRing($cnt, $ringCount, $x, $y);
+								$gmlMultiPolygon->addPointToRing($cnt, $ringCount, $x, $y);
-							else {
 						$ringCount++;
@@ -291,11 +286,11 @@
 				$geomNode = $currentSibling->firstChild;
 					$geomType = $geomNode->nodeName;
 					switch ($geomType) {
-						case "gml:Polygon" :
+						case "gml:Polygon" :// untested!
 							$feature->geometry = new GMLPolygon();
 							$this->parsePolygon($geomNode, $feature->geometry);
 							break;
-						case "gml:LineString" :
+						case "gml:LineString" :// untested!
 							$feature->geometry = new GMLLine();
 							$this->parseLine($geomNode, $feature->geometry);
 							break;
@@ -307,7 +302,7 @@
 							$feature->geometry = new GMLMultiLine();
 							$this->parseMultiLine($geomNode, $feature->geometry);
 							break;
-						case "gml:MultiSurface" :
+						case "gml:MultiSurface" :
 							$feature->geometry = new GMLMultiPolygon();
 							$this->parseMultiPolygon($geomNode, $feature->geometry);
 							break;
Modified: trunk/mapbender/http/classes/class_universal_gml_factory.php
--- trunk/mapbender/http/classes/class_universal_gml_factory.php	2009-02-06 14:54:33 UTC (rev 3520)
+++ trunk/mapbender/http/classes/class_universal_gml_factory.php	2009-02-06 16:14:29 UTC (rev 3521)
@@ -45,6 +45,12 @@
 		if (count($nodeArray) > 0 ) {
 			return "3";
+		$nodeArray = $simpleXml->xpath("gml:featureMember//gml:pos");
+		if (count($nodeArray) > 0 ) {
+			return "3";
 		return "2";
 		throw new Exception("GML version could not be determined from XML.");
Modified: trunk/mapbender/http/classes/class_wfs.php
--- trunk/mapbender/http/classes/class_wfs.php	2009-02-06 14:54:33 UTC (rev 3520)
+++ trunk/mapbender/http/classes/class_wfs.php	2009-02-06 16:14:29 UTC (rev 3521)
@@ -55,9 +55,24 @@
 		return null;
-	public function getFeature ($featureTypeName, $filter) {
-/* POST */
+	protected function getFeatureGet ($featureTypeName, $filter) {
+		$url = $this->getFeature .
+				$this->getConjunctionCharacter($this->getFeature) .
+				"service=WFS&request=getFeature&version=" .
+				$this->getVersion() . "&typename=" . $featureTypeName .
+				"&filter=" . urlencode($filter);
+		$connection = new connector($url);
+		$data = $connection->file;
+		if (!$data) {
+			$e = new mb_exception("WFS request returned no result: " . $url);
+			return null;
+		new mb_exception("Reply from WFS: " . $url . "\n\n" . $data);
+		return $data;
+	protected function getFeaturePost ($featureTypeName, $filter) {
 		$postData = "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n" .
 			"<wfs:GetFeature version=\"" . $this->getVersion() . "\" " .
 			"xmlns:wfs=\"http://www.opengis.net/wfs\">" .
@@ -86,25 +101,16 @@
 			return null;
 		return $data;
-/* GET */
-//		$url = $this->getFeature .
-//				$this->getConjunctionCharacter($this->getFeature) .
-//				"service=WFS&request=getFeature&version=" .
-//				$this->getVersion() . "&typename=" . $featureTypeName .
-//				"&filter=" . urlencode($filter);
-//		$connection = new connector($url);
-//		$data = $connection->file;
-//		if (!$data) {
-//			$e = new mb_exception("WFS request returned no result: " . $url);
-//			return null;
-//		return $data;
+	public function getFeature ($featureTypeName, $filter) {
+		if (strpos($this->getFeature, "?") === false) {
+			return $this->getFeaturePost($featureTypeName, $filter);
+		return $this->getFeatureGet($featureTypeName, $filter);
 	// Output formats
More information about the Mapbender_commits
