[Mapbender-commits] r3524 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Tue Feb 10 10:53:26 EST 2009
Author: christoph
Date: 2009-02-10 10:53:26 -0500 (Tue, 10 Feb 2009)
New Revision: 3524
trunk/mapbender/http/javascripts/map.php
trunk/mapbender/http/javascripts/mod_addWMSgeneralFunctions.js
add session name to JS
add session data to URL in addWMS
Modified: trunk/mapbender/http/javascripts/map.php
--- trunk/mapbender/http/javascripts/map.php 2009-02-10 15:51:43 UTC (rev 3523)
+++ trunk/mapbender/http/javascripts/map.php 2009-02-10 15:53:26 UTC (rev 3524)
@@ -52,6 +52,7 @@
// Define global variables (TODO: move to mapbender object later on)
echo "var mb_nr = '".session_id()."';";
+echo "var mb_session_name = '".session_name()."';";
echo "var mb_myLogin = '".$_SESSION["mb_login"]."';";
echo "var mb_styleID = '".md5($_SESSION["mb_user_name"])."';";
echo "var mb_myBBOX = '".$_SESSION["mb_myBBOX"]."';";
Modified: trunk/mapbender/http/javascripts/mod_addWMSgeneralFunctions.js
--- trunk/mapbender/http/javascripts/mod_addWMSgeneralFunctions.js 2009-02-10 15:51:43 UTC (rev 3523)
+++ trunk/mapbender/http/javascripts/mod_addWMSgeneralFunctions.js 2009-02-10 15:53:26 UTC (rev 3524)
@@ -20,7 +20,8 @@
function mod_addWMS_load(caps){
- window.frames['loadData'].document.location.href = "../php/mod_createJSObjFromXML.php?caps=" + encodeURIComponent(caps);
+ var capUrl = "../php/mod_createJSObjFromXML.php?" + mb_session_name + "=" + mb_nr + "&caps=" + encodeURIComponent(caps);
+ window.frames['loadData'].document.location.href = capUrl;
function mod_addLayer_load(caps,layer_name){
More information about the Mapbender_commits
