[Mapbender-commits] r3563 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Feb 18 03:46:33 EST 2009
Author: christoph
Date: 2009-02-18 03:46:32 -0500 (Wed, 18 Feb 2009)
New Revision: 3563
   trunk/mapbender/resources/db/schema_2.5.dia
altered types of some columns in WFS tables
Modified: trunk/mapbender/resources/db/schema_2.5.dia
--- trunk/mapbender/resources/db/schema_2.5.dia	2009-02-18 08:45:26 UTC (rev 3562)
+++ trunk/mapbender/resources/db/schema_2.5.dia	2009-02-18 08:46:32 UTC (rev 3563)
@@ -7371,13 +7371,13 @@
         <dia:point val="131,-48"/>
       </dia:attribute>
       <dia:attribute name="obj_bb">
-        <dia:rectangle val="130.95,-48.05;146.95,-40.75"/>
+        <dia:rectangle val="130.95,-48.05;147.3,-40.75"/>
       </dia:attribute>
       <dia:attribute name="elem_corner">
       </dia:attribute>
       <dia:attribute name="elem_width">
-        <dia:real val="15.9"/>
+        <dia:real val="16.25"/>
       </dia:attribute>
       <dia:attribute name="elem_height">
         <dia:real val="7.1999999999999993"/>
@@ -7518,7 +7518,7 @@
             <dia:string>#featuretype_name#</dia:string>
           </dia:attribute>
           <dia:attribute name="type">
-            <dia:string>#varchar(50)#</dia:string>
+            <dia:string>#varchar(255)#</dia:string>
           </dia:attribute>
           <dia:attribute name="value">
             <dia:string>#'' NOT NULL#</dia:string>
@@ -7541,7 +7541,7 @@
             <dia:string>#featuretype_title#</dia:string>
           </dia:attribute>
           </dia:attribute>
             <dia:string>##</dia:string>
@@ -7610,7 +7610,7 @@
             <dia:string>#featuretype_abstract#</dia:string>
           </dia:attribute>
+            <dia:string>#text#</dia:string>
           </dia:attribute>
@@ -7989,7 +7989,7 @@
             <dia:string>#element_name#</dia:string>
           </dia:attribute>
           </dia:attribute>
@@ -8012,7 +8012,7 @@
             <dia:string>#element_type#</dia:string>
           </dia:attribute>
           </dia:attribute>
@@ -8105,13 +8105,13 @@
     </dia:object>
     <dia:object type="UML - Association" version="1" id="O47">
       <dia:attribute name="obj_pos">
-        <dia:point val="146.9,-44.5"/>
+        <dia:point val="147.25,-44.5"/>
       </dia:attribute>
         <dia:rectangle val="146.15,-58.45;160.75,-43.985"/>
       </dia:attribute>
       <dia:attribute name="orth_points">
         <dia:point val="154,-44.5"/>
         <dia:point val="154,-57.7"/>
         <dia:point val="160,-57.7"/>
@@ -14941,13 +14941,13 @@
     </dia:object>
     <dia:object type="UML - Association" version="1" id="O106">
-        <dia:point val="146.9,-46.1"/>
+        <dia:point val="147.25,-46.1"/>
       </dia:attribute>
         <dia:rectangle val="144.75,-62.85;159.35,-45.585"/>
       </dia:attribute>
         <dia:point val="151,-46.1"/>
         <dia:point val="151,-62.1"/>
         <dia:point val="145.5,-62.1"/>
More information about the Mapbender_commits mailing list
