[Mapbender-commits] r3567 - in branches/print_dev/http/print: .
	classes
    svn_mapbender at osgeo.org
    Wed Feb 18 11:02:42 EST 2009
Author: mschulz
Date: 2009-02-18 11:02:42 -0500 (Wed, 18 Feb 2009)
New Revision: 3567
Added:
   branches/print_dev/http/print/classes/mbMeasureDecorator.php
   branches/print_dev/http/print/classes/mbMapDecorator.php
   branches/print_dev/http/print/classes/mbTemplatePdf.php
   branches/print_dev/http/print/mod_printPDF_div.php
   branches/print_dev/http/print/print_functions.php
   branches/print_dev/http/print/testConfigTemplate.json
added simple mbMeasureDecorator
Modified: branches/print_dev/http/print/classes/mbMapDecorator.php
--- branches/print_dev/http/print/classes/mbMapDecorator.php	2009-02-18 08:52:26 UTC (rev 3566)
+++ branches/print_dev/http/print/classes/mbMapDecorator.php	2009-02-18 16:02:42 UTC (rev 3567)
@@ -53,7 +53,8 @@
 		$res = $this->pdf->objPdf->k * ($this->res_dpi/72);
 		$myURL = new stripRequest($array_urls[0]);
 		$e = new mb_notice("mbMapDecorator: original bbox: ".$myURL->get('BBOX'));
-		$this->pdf->setMapExtent($this->adjustBbox(explode(",",$myURL->get('BBOX')), $myURL->get('srs')));
+		#$this->pdf->setMapExtent($this->adjustBbox(explode(",",$myURL->get('BBOX')), $myURL->get('srs')));
+		$this->pdf->setMapInfo($this->conf->x_ul, $this->conf->y_ul, $width, $height, $this->adjustBbox(explode(",",$myURL->get('BBOX')), $myURL->get('srs')));
 		$e = new mb_notice("mbMapDecorator: adjusted bbox: ".$this->pdf->getMapExtent());
 		for($i=0; $i<count($array_urls); $i++){
 			$m = new stripRequest($array_urls[$i]);
Added: branches/print_dev/http/print/classes/mbMeasureDecorator.php
--- branches/print_dev/http/print/classes/mbMeasureDecorator.php	                        (rev 0)
+++ branches/print_dev/http/print/classes/mbMeasureDecorator.php	2009-02-18 16:02:42 UTC (rev 3567)
@@ -0,0 +1,79 @@
+<?php
+class mbMeasureDecorator extends mbTemplatePdfDecorator {
+	protected $pageElementType = "measure";
+	protected $elementId;
+	public function __construct($pdfObj, $elementId, $mapConf, $controls) {
+		parent::__construct($pdfObj, $mapConf, $controls);
+		$this->elementId = $elementId;
+		$this->override();
+		$this->decorate();
+	public function override() {}
+	public function decorate() {
+		include (dirname(__FILE__)."/../print_functions.php");
+		global $mapOffset_left, $mapOffset_bottom, $map_height, $map_width, $coord;
+		global $yAxisOrientation;
+		$yAxisOrientation = 1;
+		if (isset($_REQUEST["measured_x_values"]) && $_REQUEST["measured_x_values"] != "") {
+			$x_value_str = $_REQUEST["measured_x_values"];
+			$y_value_str = $_REQUEST["measured_y_values"];
+			$e = new mb_notice("mbMeasureDecorator: x values: ".$x_value_str);
+			$e = new mb_notice("mbMeasureDecorator: y values: ".$y_value_str);
+		else {
+			return "No measurements found.";
+		$coord = mb_split(",",$this->pdf->getMapExtent());
+		$mapInfo = $this->pdf->getMapInfo();
+		foreach ($mapInfo as $k => $v) {
+			$e = new mb_notice("mbMeasureDecorator: mapInfo: ".$k."=".$v);
+		$mapOffset_left = $mapInfo["x_ul"];
+		$mapOffset_bottom = $mapInfo["y_ul"];
+		$map_height = $mapInfo["height"];
+		$map_width = $mapInfo["width"];
+		// get the arrays, be aware of the different y-axis values
+		$theFullArr = makeCoordPairs($x_value_str, $y_value_str);
+		foreach ($theFullArr as $oneFullArr) {
+			$e = new mb_notice("mbMeasureDecorator: coordinates: ".implode(" ",array_values($oneFullArr)));
+    	$thePolyArr = makePolyFromCoord($theFullArr);
+    	$e = new mb_notice("mbMeasureDecorator: coordinates: ".implode(" ",$thePolyArr));
+		if (isClosedPolygon($theFullArr)) {
+			$isClosed = TRUE;
+		else {
+			$isClosed = FALSE;
+		$nr_of_points = count($theFullArr);
+		$e = new mb_notice("mbMeasureDecorator: closed polygon: ".$isClosed);
+		if ($isClosed) {
+			$this->pdf->objPdf->Polygon($thePolyArr);
+		else {
+			$theStrokePointPairs = makeStrokePointPairs($theFullArr);
+			for($i = 0; $i < count($theStrokePointPairs); $i++) {
+				$line = $theStrokePointPairs[$i];
+				$e = new mb_notice("mbMeasureDecorator: line coordinates: ".implode(" ",$line));
+				if ($i != count($theStrokePointPairs) - 1) {
+			    	$this->pdf->objPdf->Line($line[0], $line[1], $line[2], $line[3]);
\ No newline at end of file
Modified: branches/print_dev/http/print/classes/mbTemplatePdf.php
--- branches/print_dev/http/print/classes/mbTemplatePdf.php	2009-02-18 08:52:26 UTC (rev 3566)
+++ branches/print_dev/http/print/classes/mbTemplatePdf.php	2009-02-18 16:02:42 UTC (rev 3567)
@@ -5,7 +5,7 @@
 class mbTemplatePdf extends mbPdf {
 	/* it seems several decorators are going to need this information */
-	public $mapExtent;
+	public $mapInfo = array();
 	public function __construct($jsonConf) {
 		$this->confPdf = $jsonConf;
@@ -18,14 +18,28 @@
 		$this->outputFileName = $this->generateOutputFileName("map","pdf");
+	public function setMapInfo($x_ul, $y_ul, $width, $height, $aBboxString) {
+		$this->mapinfo["x_ul"] = $x_ul;
+		$this->mapinfo["y_ul"] = $y_ul;
+		$this->mapinfo["width"] = $width;
+		$this->mapinfo["height"] = $height;
+		$this->mapinfo["extent"] = $aBboxString;
+		$e = new mb_notice("mbTemplatePdf: setting mapInfo ...");
+	public function getMapInfo() {
+		$e = new mb_notice("mbTemplatePdf: getting mapInfo ..");
+		return $this->mapinfo;
 	public function setMapExtent($aBboxString) {
-		$this->mapExtent = $aBboxString;
-		$e = new mb_notice("mbTemplatePdf: setting mapExtent to ".$this->mapExtent);
+		$e = new mb_notice("mbTemplatePdf: setting mapExtent to ".$this->mapinfo["extent"]);
 	public function getMapExtent() {
-		$e = new mb_notice("mbTemplatePdf: getting mapExtent as ".$this->mapExtent);
-		return $this->mapExtent;
+		$e = new mb_notice("mbTemplatePdf: getting mapExtent as ".$this->mapinfo["extent"]);
+		return $this->mapinfo["extent"];
 	public function render() {
@@ -50,7 +64,10 @@
 						break;
 					case "para":
 						$err = new mbParagraphDecorator($this, $pageElementId, $pageElementConf, $controls);
-						break;
+						break;
+					case "measure":
+						$err = new mbMeasureDecorator($this, $pageElementId, $pageElementConf, $controls);
+						break;
Modified: branches/print_dev/http/print/mod_printPDF_div.php
--- branches/print_dev/http/print/mod_printPDF_div.php	2009-02-18 08:52:26 UTC (rev 3566)
+++ branches/print_dev/http/print/mod_printPDF_div.php	2009-02-18 16:02:42 UTC (rev 3567)
@@ -62,6 +62,20 @@
+ * update form values helper function
+function updateFormField(formData, key, value) {
+	for(var j=0; j < formData.length; j++){
+		if (formData[j].name == key) {
+			formData[j].value = value;
+			break;
  * Validates and updates form data values.
  * Adds the elements before the submit button.
@@ -83,25 +97,35 @@
-	for(var j=0; j < formData.length; j++){
-		if (formData[j].name == "map_url") {
-			formData[j].value = f.map_url.value;
-			break;
+	updateFormField(formData, "map_url", f.map_url.value);
 	//overview_url
 	var ind_overview = getMapObjIndexByName('overview');
+	if(mb_mapObj[ind_overview].mapURL != false ){
+		updateFormField(formData, "overview_url", mb_mapObj[ind_overview].mapURL);
-	if(mb_mapObj[ind_overview].mapURL != false ){
-			if (formData[j].name == "overview_url") {
-				formData[j].value = mb_mapObj[ind_overview].mapURL;
-				break;
+	// write the measured coordinates
+	if (mod_measure_RX != undefined && mod_measure_RY != undefined) {
+		var tmp_x = '';
+		var tmp_y = '';
+		for(i = 0; i < mod_measure_RX.length; i++) {
+			if(tmp_x != '') {
+				tmp_x += ','
+			tmp_x += mod_measure_RX[i];
+		for(i = 0; i < mod_measure_RY.length; i++) {
+			if(tmp_y != '') {
+				tmp_y += ','
+			tmp_y += mod_measure_RY[i];
+		updateFormField(formData, "measured_x_values", tmp_x);
+		updateFormField(formData, "measured_y_values", tmp_y);
 	if (f.map_url.value!="") {
 		return true;
 	} else {
Modified: branches/print_dev/http/print/print_functions.php
--- branches/print_dev/http/print/print_functions.php	2009-02-18 08:52:26 UTC (rev 3566)
+++ branches/print_dev/http/print/print_functions.php	2009-02-18 16:02:42 UTC (rev 3567)
@@ -61,6 +61,7 @@
 function transformForPDF ($theRealCoord, $theType) {
 	$thePDFvalue = "";
@@ -77,7 +78,10 @@
 			$real_shown_height = $coord[3] - $coord[1];
 			$ratio_to_display  = $map_height / $real_shown_height;
 			$target_height     = $theRealCoord - $coord[1];
-			$thePDFvalue       = $mapOffset_bottom + ($target_height * $ratio_to_display);
+			if (isset($yAxisOrientation) && $yAxisOrientation==1)
+				$thePDFvalue   = $map_height + $mapOffset_bottom - ($target_height * $ratio_to_display);
+			else
+				$thePDFvalue   = $mapOffset_bottom + ($target_height * $ratio_to_display);
 		  break;
 		default:
 		  // a non valid parameter was given
Modified: branches/print_dev/http/print/testConfigTemplate.json
--- branches/print_dev/http/print/testConfigTemplate.json	2009-02-18 08:52:26 UTC (rev 3566)
+++ branches/print_dev/http/print/testConfigTemplate.json	2009-02-18 16:02:42 UTC (rev 3567)
@@ -57,6 +57,9 @@
 	    		"width" : 280,
     			"height" : 185
+	   		"messung" : {
+    			"type" : "measure"
 	   		"minikarte" : {
     			"type" : "overview",
     			"res_dpi" : 72,
More information about the Mapbender_commits
