[Mapbender-commits] r3574 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Feb 18 12:37:14 EST 2009
Author: christoph
Date: 2009-02-18 12:37:14 -0500 (Wed, 18 Feb 2009)
New Revision: 3574
   trunk/mapbender/http/javascripts/geometry.js
geoJSON adjusted to conform with finalized spec 1.0
Modified: trunk/mapbender/http/javascripts/geometry.js
--- trunk/mapbender/http/javascripts/geometry.js	2009-02-18 17:36:04 UTC (rev 3573)
+++ trunk/mapbender/http/javascripts/geometry.js	2009-02-18 17:37:14 UTC (rev 3574)
@@ -772,7 +772,7 @@
 	var epsg = this.getEpsg();
 	if (epsg) {
-		str += "\"crs\": {\"type\": \"EPSG\", \"properties\": {\"code\": " + epsg + "}}, ";
+		str += "\"crs\": {\"type\": \"name\", \"properties\": {\"name\": \"" + epsg + "\"}}, ";
 	str += "\"geometry\": {";
@@ -1028,10 +1028,9 @@
 	this.setEpsg = function (someEpsg) {
 		// TODO: how to check if EPSG code is correct?
-		if (typeof(someEpsg) == "number") {
-			epsg = someEpsg;
-			return true;
+		epsg = someEpsg;
+		return true;
 		var e = new Mb_exception("EPSG code not valid ("+someEpsg+")");
 		return false;
More information about the Mapbender_commits mailing list
