[Mapbender-commits] r3588 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Feb 24 15:24:25 EST 2009
Author: astrid_emde
Date: 2009-02-24 15:24:25 -0500 (Tue, 24 Feb 2009)
New Revision: 3588
   trunk/mapbender/resources/db/update/update_2.6.sql
Columns was to small for content
ALTER TABLE gui_element ALTER e_mb_mod TYPE varchar(100);
Modified: trunk/mapbender/resources/db/update/update_2.6.sql
--- trunk/mapbender/resources/db/update/update_2.6.sql	2009-02-24 16:30:43 UTC (rev 3587)
+++ trunk/mapbender/resources/db/update/update_2.6.sql	2009-02-24 20:24:25 UTC (rev 3588)
@@ -24,6 +24,7 @@
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css');
 --add all used modules for gazetteerWFS
+ALTER TABLE gui_element ALTER e_mb_mod TYPE varchar(100);
 UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/jquery.tablesorter.js' WHERE e_id = 'gazetteerWFS' AND fkey_gui_id = 'gui';
 UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/jquery.tablesorter.js' WHERE e_id = 'gazetteerWFS' AND fkey_gui_id = 'gui2';
 UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/jquery.tablesorter.js' WHERE e_id = 'gazetteerWFS' AND fkey_gui_id = 'gui_digitize';
More information about the Mapbender_commits mailing list
