[Mapbender-commits] r3397 - in trunk/mapbender/http: javascripts php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jan 2 10:24:40 EST 2009
Author: christoph
Date: 2009-01-02 10:24:40 -0500 (Fri, 02 Jan 2009)
New Revision: 3397
Added:
   trunk/mapbender/http/javascripts/mod_changeEPSG.php
Removed:
   trunk/mapbender/http/php/mod_changeEPSG.php
http://trac.osgeo.org/mapbender/ticket/360
file moved to javascripts
Copied: trunk/mapbender/http/javascripts/mod_changeEPSG.php (from rev 3395, trunk/mapbender/http/php/mod_changeEPSG.php)
--- trunk/mapbender/http/javascripts/mod_changeEPSG.php	                        (rev 0)
+++ trunk/mapbender/http/javascripts/mod_changeEPSG.php	2009-01-02 15:24:40 UTC (rev 3397)
@@ -0,0 +1,109 @@
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/mod_changeEPSG.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require(dirname(__FILE__)."/mb_validateSession.php");
+include(dirname(__FILE__)."/../include/dyn_js.php");
+echo "var myTarget = '".$e_target[0]."';";
+echo "var myId = '".$e_id."';";
+var exists = false;
+eventAfterMapRequest.register(function () {
+	mod_changeEPSG_setBox();
+eventInit.register(function () {
+//	mod_changeEPSG_init();
+function mod_changeEPSG_setBox(){
+	$("#"+myId+" option").each(function () {
+		if (this.value == mb_mapObj[0].epsg) {
+			isEPSG = true;
+			$(this).attr("selected", "selected");
+$("#"+myId).change(function () {
+	var srsArray = [];
+	for (var i = 0; i < mb_mapObj.length; i++) {
+		var currentSrs = {
+			"frameName" : mb_mapObj[i].elementName,
+			"epsg" : mb_mapObj[i].epsg,
+			"extent" : mb_mapObj[i].extent,
+			"width" : mb_mapObj[i].width,
+			"height" : mb_mapObj[i].height
+		srsArray.push(currentSrs);
+	var req = new Mapbender.Ajax.Request({
+		"method":"changeEpsg",
+		"parameters":{
+			"srs":srsArray,
+			"newSrs": $("#"+myId).get(0).value
+	req.send("../php/mod_changeEPSG_server.php", function (obj, success, message) {
+		if (!success) {
+			new Mb_exception("!!!!!!"+message);
+			return;
+		var newExtent = obj;
+		for(var i = 0; i < newExtent.length; i++) {
+			if(newExtent[i].frameName == myTarget){
+				var ind = getMapObjIndexByName(myTarget);
+				for(var ii = 0; ii < mb_mapObj[ind].mb_MapHistoryObj.length; ii++) {
+					if (mb_mapObj[ind].mb_MapHistoryObj[ii].epsg == newExtent[i].newSrs) {
+						exists = ii;
+						var goback = true;
+				if (goback) {
+					mb_mapObj[ind].epsg = newExtent[i].newSrs;
+					mb_mapObj[ind].extent = mb_mapObj[ind].mb_MapHistoryObj[exists].extent;
+					setMapRequest(newExtent[i].frameName);
+				else{
+					mb_mapObj[ind].extent = parseFloat(newExtent[i].minx) + "," + parseFloat(newExtent[i].miny) + "," +
+						parseFloat(newExtent[i].maxx) + "," + parseFloat(newExtent[i].maxy);
+			else {
+				var ind = getMapObjIndexByName(newExtent[i].frameName);
\ No newline at end of file
Deleted: trunk/mapbender/http/php/mod_changeEPSG.php
--- trunk/mapbender/http/php/mod_changeEPSG.php	2009-01-02 15:23:56 UTC (rev 3396)
+++ trunk/mapbender/http/php/mod_changeEPSG.php	2009-01-02 15:24:40 UTC (rev 3397)
@@ -1,109 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mod_changeEPSG.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require(dirname(__FILE__)."/mb_validateSession.php");
-include(dirname(__FILE__)."/../include/dyn_js.php");
-echo "var myTarget = '".$e_target[0]."';";
-echo "var myId = '".$e_id."';";
-var exists = false;
-eventAfterMapRequest.register(function () {
-	mod_changeEPSG_setBox();
-eventInit.register(function () {
-//	mod_changeEPSG_init();
-function mod_changeEPSG_setBox(){
-	$("#"+myId+" option").each(function () {
-		if (this.value == mb_mapObj[0].epsg) {
-			isEPSG = true;
-			$(this).attr("selected", "selected");
-$("#"+myId).change(function () {
-	var srsArray = [];
-	for (var i = 0; i < mb_mapObj.length; i++) {
-		var currentSrs = {
-			"frameName" : mb_mapObj[i].elementName,
-			"epsg" : mb_mapObj[i].epsg,
-			"extent" : mb_mapObj[i].extent,
-			"width" : mb_mapObj[i].width,
-			"height" : mb_mapObj[i].height
-		srsArray.push(currentSrs);
-	var req = new Mapbender.Ajax.Request({
-		"method":"changeEpsg",
-		"parameters":{
-			"srs":srsArray,
-			"newSrs": $("#"+myId).get(0).value
-	req.send("../php/mod_changeEPSG_server.php", function (obj, success, message) {
-		if (!success) {
-			new Mb_exception("!!!!!!"+message);
-			return;
-		var newExtent = obj;
-		for(var i = 0; i < newExtent.length; i++) {
-			if(newExtent[i].frameName == myTarget){
-				var ind = getMapObjIndexByName(myTarget);
-				for(var ii = 0; ii < mb_mapObj[ind].mb_MapHistoryObj.length; ii++) {
-					if (mb_mapObj[ind].mb_MapHistoryObj[ii].epsg == newExtent[i].newSrs) {
-						exists = ii;
-						var goback = true;
-				if (goback) {
-					mb_mapObj[ind].epsg = newExtent[i].newSrs;
-					mb_mapObj[ind].extent = mb_mapObj[ind].mb_MapHistoryObj[exists].extent;
-					setMapRequest(newExtent[i].frameName);
-				else{
-					mb_mapObj[ind].extent = parseFloat(newExtent[i].minx) + "," + parseFloat(newExtent[i].miny) + "," +
-						parseFloat(newExtent[i].maxx) + "," + parseFloat(newExtent[i].maxy);
-			else {
-				var ind = getMapObjIndexByName(newExtent[i].frameName);
More information about the Mapbender_commits mailing list
