[Mapbender-commits] r3412 - branches/print_dev/http/print/classes
svn_mapbender at osgeo.org
Wed Jan 7 11:40:24 EST 2009
Author: mschulz
Date: 2009-01-07 11:40:24 -0500 (Wed, 07 Jan 2009)
New Revision: 3412
branches/print_dev/http/print/classes/mbMapDecorator.php
branches/print_dev/http/print/classes/mbPdf.php
branches/print_dev/http/print/classes/mbTemplatePdf.php
branches/print_dev/http/print/classes/mbTemplatePdfDecorator.php
start of map decorator implementation
Modified: branches/print_dev/http/print/classes/mbMapDecorator.php
--- branches/print_dev/http/print/classes/mbMapDecorator.php 2009-01-07 13:08:15 UTC (rev 3411)
+++ branches/print_dev/http/print/classes/mbMapDecorator.php 2009-01-07 16:40:24 UTC (rev 3412)
@@ -1,9 +1,35 @@
-<?php
+<?php
+include (dirname(__FILE__)."/../../classes/class_stripRequest.php");
+include (dirname(__FILE__)."/../../classes/class_weldMaps2PNG.php");
class mbMapDecorator extends mbTemplatePdfDecorator {
+ protected $filename;
+ protected $pdf;
+ protected $conf;
public function __construct($pdfObj, $mapConf) {
+ $this->pdf = $pdfObj;
+ $this->conf = $mapConf;
+ $this->filename = TMPDIR."/".parent::generateOutputFileName("map","png");
+ $this->draw();
+ protected function draw() {
+ $urls = $_REQUEST["map_url"];
+ $array_urls = explode("___", $urls);
+ $myURL = new stripRequest($array_urls[0]);
+ $map_width = $this->conf->width;
+ $map_height = $this->conf->height;
+ for($i=0; $i<count($array_urls); $i++){
+ $m = new stripRequest($array_urls[$i]);
+ $m->set('width',(intval($map_width*$this->pdf->k)));
+ $m->set('height',(intval($map_height*$this->pdf->k)));
+ $array_urls[$i] = $m->url;
+ $i = new weldMaps2PNG(implode("___",$array_urls),$this->filename);
+ $this->pdf->Image($this->filename, $this->conf->x_ul, $this->conf->y_ul, $map_width, $map_height,'png');
Modified: branches/print_dev/http/print/classes/mbPdf.php
--- branches/print_dev/http/print/classes/mbPdf.php 2009-01-07 13:08:15 UTC (rev 3411)
+++ branches/print_dev/http/print/classes/mbPdf.php 2009-01-07 16:40:24 UTC (rev 3412)
@@ -16,8 +16,8 @@
abstract public function render();
abstract public function save();
- public function generateOutputFileName() {
- $this->outputFileName = "map_".substr(md5(uniqid(rand())),0,7).".pdf";
+ public function generateOutputFileName($prefix, $suffix) {
+ return $prefix."_".substr(md5(uniqid(rand())),0,7).".".$suffix;
public function returnURL() {
Modified: branches/print_dev/http/print/classes/mbTemplatePdf.php
--- branches/print_dev/http/print/classes/mbTemplatePdf.php 2009-01-07 13:08:15 UTC (rev 3411)
+++ branches/print_dev/http/print/classes/mbTemplatePdf.php 2009-01-07 16:40:24 UTC (rev 3412)
@@ -12,7 +12,7 @@
$this->objPdf = new mb_fpdi($this->confPdf->orientation,
$this->confPdf->units,
$this->confPdf->format);
- $this->generateOutputFileName();
+ $this->outputFileName = $this->generateOutputFileName("map","pdf");
public function render() {
@@ -25,8 +25,8 @@
foreach ($pageConf->elements as $pageElementId => $pageElementConf) {
switch ($pageElementId) {
- case "map1":
- #$this->objPdf = new mbMapDecorator($this->objPdf, $pageElementConf);
+ case "map":
+ $err = new mbMapDecorator($this->objPdf, $pageElementConf);
break;
Modified: branches/print_dev/http/print/classes/mbTemplatePdfDecorator.php
--- branches/print_dev/http/print/classes/mbTemplatePdfDecorator.php 2009-01-07 13:08:15 UTC (rev 3411)
+++ branches/print_dev/http/print/classes/mbTemplatePdfDecorator.php 2009-01-07 16:40:24 UTC (rev 3412)
@@ -1,10 +1,8 @@
<?php
-abstract class mbPdfDecorator extends mbPdf {
+abstract class mbTemplatePdfDecorator extends mbTemplatePdf {
- protected $mbPdf;
- public function __construct();
+ public function __construct() {}
More information about the Mapbender_commits
