[Mapbender-commits] r4286 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jul 2 07:28:23 EDT 2009
Author: christoph
Date: 2009-07-02 07:28:22 -0400 (Thu, 02 Jul 2009)
New Revision: 4286
   trunk/mapbender/resources/db/update/update_2.7.sql
removed content from mapframe1
Modified: trunk/mapbender/resources/db/update/update_2.7.sql
--- trunk/mapbender/resources/db/update/update_2.7.sql	2009-07-02 06:26:48 UTC (rev 4285)
+++ trunk/mapbender/resources/db/update/update_2.7.sql	2009-07-02 11:28:22 UTC (rev 4286)
@@ -82,6 +82,8 @@
 -- reload uses Mapbender API
 UPDATE gui_element SET e_attributes = '' WHERE e_id = 'reload';
+-- init event is now triggered by jQuery
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'body';
--- body uses Mapbender API
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'body'
\ No newline at end of file
+-- mapframe layers are now added dynamically by the modules
+UPDATE gui_element SET e_content = '' WHERE e_id = 'mapframe1';
More information about the Mapbender_commits mailing list
