[Mapbender-commits] r4313 - in branches/2.6/http: classes javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jul 6 12:29:58 EDT 2009
Author: verenadiewald
Date: 2009-07-06 12:29:57 -0400 (Mon, 06 Jul 2009)
New Revision: 4313
   branches/2.6/http/classes/class_wfs_conf.php
   branches/2.6/http/javascripts/mod_wfs_gazetteer_client.php
http://trac.osgeo.org/mapbender/ticket/463
Modified: branches/2.6/http/classes/class_wfs_conf.php
--- branches/2.6/http/classes/class_wfs_conf.php	2009-07-06 13:39:29 UTC (rev 4312)
+++ branches/2.6/http/classes/class_wfs_conf.php	2009-07-06 16:29:57 UTC (rev 4313)
@@ -1,7 +1,7 @@
 <?php
 # $Id$
 # http://www.mapbender.org/index.php/class_wfs_conf.php
-# Copyright (C) 2002 CCGIS
+# Copyright (C) 2002 CCGIS
 # This program is free software; you can redistribute it and/or modify
 # it under the terms of the GNU General Public License as published by
@@ -31,23 +31,23 @@
 	function __construct () {
 	function __toString () {
 		$json = new Mapbender_JSON();
 		return $json->encode($this->confArray);
 	 * Loads WFS conf data from the database
 	 * @return Object WFS conf data.
 	 * @param $idOrIdArray Object May be an integer or an array of integers representing WFS conf IDs.
 	public function load ($idOrIdArray) {
 		// Check parameter and set idArray
 		if (isset($idOrIdArray)){
-			// parameter is a number
+			// parameter is a number
 			if (!is_array($idOrIdArray) && is_numeric($idOrIdArray)) {
 				$idOrIdArray = array(intval($idOrIdArray));
@@ -82,13 +82,13 @@
 			return null;
 	// --------------------------- private -----------------------------------
 	 * Gets the database content for a number of WFS configurations given by their IDs.
 	 * @return Array
 	 * @param $idArray Array an array of integer values representing WFS conf IDs.
@@ -98,7 +98,7 @@
         		$sql = "SELECT * FROM wfs_conf ";
                 $sql .= "JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
                 $sql .= "WHERE wfs_conf.wfs_conf_id = $1 LIMIT 1";
                 $v = array($id);
                 $t = array("i");
                 $res = db_prep_query($sql, $v, $t);
@@ -107,7 +107,7 @@
         return $rowArray;
 	public static function getGeomColumnNameByConfId ($confId) {
 		$elArray = self::getWfsConfElementFromDb($confId);
 		foreach ($elArray as $element) {
@@ -117,10 +117,10 @@
 		return null;
 	 * Gets the database content of a WFS conf element given by a WFS conf ID.
 	 * @return Array
 	 * @param $id Integer the WFS conf ID.
@@ -134,7 +134,7 @@
 		$v = array($id);
 		$t = array('i');
 		$elementArray = array();
 		while ($row = db_fetch_array($res)) {
 			$currentElement = array("element_name" => $row["element_name"],
@@ -162,7 +162,7 @@
 	 * Gets the database content of a WFS feature type given by a WFS ID and a featuretype ID.
 	 * @return Array
 	 * @param $wfsId Integer the WFS ID.
 	 * @param $featuretypeId Integer the WFS featuretype ID.
@@ -171,35 +171,36 @@
 		$sql = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1 AND featuretype_id = $2";
 		$v = array($wfsId, $featuretypeId);
 		$t = array("i", "i");
 		$currentRow = array();
 		if($row = db_fetch_array($res)){
 			$currentRow["featuretype_name"] = $row["featuretype_name"];
 			$currentRow["featuretype_srs"] = $row["featuretype_srs"];
 		return $currentRow;
 	 * get WFS conf data from database
 	private function getWfsConfFromDB ($idArray) {
 		// if a user has access to some WFS confs...
 		if (count($idArray) > 0) {
 			// get WFS conf data from DB
 			$rowArray = self::getWfsConfFromDbByArray($idArray);
 			for ($i=0; $i < count($rowArray); $i++) {
-				// WFS conf data
-				$currentRow = array("g_label" => $rowArray[$i]["g_label"],
+				// WFS conf data
+				$currentRow = array("g_label" => $rowArray[$i]["g_label"],
 			                        "g_label_id" => $rowArray[$i]["g_label_id"],
+									"wfs_conf_abstract" => $rowArray[$i]["wfs_conf_abstract"],
 									"g_style" => $rowArray[$i]["g_style"],
 									"g_button" => $rowArray[$i]["g_button"],
 									"g_button_id" => $rowArray[$i]["g_button_id"],
@@ -232,14 +233,14 @@
 			return array();
  * @deprecated
 class wfs_conf{
 	var $wfs_id;
 	var $wfs_name;
 	var $wfs_title;
@@ -247,18 +248,18 @@
 	var $wfs_getcapabilities;
 	var $wfs_describefeaturetype;
 	var $wfs_getfeature;
 	var $features;
 	var $elements;
 	var $namespaces;
 	function getallwfs($userid){
 		$this->wfs_id = array();
 		$this->wfs_name = array();
 		$this->wfs_title = array();
 		$this->wfs_abstract = array();
 		global $DBSERVER,$DB,$OWNER,$PW;
 		$con = db_connect($DBSERVER,$OWNER,$PW);
 		db_select_db($DB,$con);
@@ -272,7 +273,7 @@
 		 	$sql = "SELECT * FROM wfs";
 			$res = db_query($sql);
 		$cnt = 0;
 		while ($row = db_fetch_array($res)){
 			$this->wfs_version[$cnt] = $row["wfs_version"];
@@ -284,7 +285,7 @@
 			$this->wfs_describefeaturetype[$cnt] = $row["wfs_describefeaturetype"];
 			$this->wfs_getfeature[$cnt] = $row["wfs_getfeature"];
 			$cnt++;
 	function getfeatures($wfsid){
 		$this->features = new features($wfsid);
@@ -297,19 +298,19 @@
 class features extends wfs_conf{
 	var $featuretype_id;
 	var $featuretype_name;
 	var $featuretype_title;
 	var $featuretype_srs;
-	function features($id){
+	function features($id){
 		$featuretype_id = array();
 		$featuretype_name = array();
 		$featuretype_title = array();
 		$featuretype_srs = array();
@@ -324,21 +325,21 @@
 			$this->featuretype_title[$cnt] = $row["featuretype_title"];
 			$this->featuretype_srs[$cnt] = $row["featuretype_srs"];
 			$cnt++;
 class elements extends wfs_conf{
 	var $element_id;
 	var $element_name;
 	var $element_type;
 	function elements($fid){
 		$element_id = array();
 		$element_name = array();
 		$element_type = array();
@@ -356,15 +357,15 @@
 class namespaces extends wfs_conf{
 	var $namespace_name;
 	var $namespace_location;
 	function namespaces($fid){
 		$namespace_name = array();
 		$namespace_location = array();
Modified: branches/2.6/http/javascripts/mod_wfs_gazetteer_client.php
--- branches/2.6/http/javascripts/mod_wfs_gazetteer_client.php	2009-07-06 13:39:29 UTC (rev 4312)
+++ branches/2.6/http/javascripts/mod_wfs_gazetteer_client.php	2009-07-06 16:29:57 UTC (rev 4313)
@@ -1,8 +1,8 @@
-<?php
+<?php
 # $Id$
 # maintained by http://www.mapbender.org/index.php/User:Verena Diewald
 # http://www.mapbender.org/index.php/WFS_gazetteer
@@ -27,14 +27,14 @@
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
 <html>
 <head>
-<meta http-equiv="Content-Type" content="text/html; charset=<?php echo CHARSET;?>">
+<meta http-equiv="Content-Type" content="text/html; charset=<?php echo CHARSET;?>">
 <title>mod_wfs_gazetteer</title>
 <?php
 include '../include/dyn_css.php';
 <script type="text/javascript">
-<?php
+<?php
 	include '../include/dyn_js.php';
 	include '../include/dyn_php.php';
 	include(dirname(__FILE__) . "/../../conf/" . $wfs_spatial_request_conf_filename);
@@ -145,9 +145,9 @@
 function wfsInitFunction (j) {
 	var functionCall = "parent.mb_regButton_frame('initWfsButton', '"+frameName+"', "+j+")";
-	var x = new Function ("", functionCall);
+	var x = new Function ("", functionCall);
 	x();
 function initWfsButton(ind, pos) {
 	parent.mb_button[ind] = document.getElementById(buttonWfs_id[pos]);
@@ -165,7 +165,7 @@
 	mod_wfs_spatialRequest_height = parent.mb_mapObj[ind].height;
 	mod_wfs_spatialRequest_epsg = parent.mb_mapObj[ind].epsg;
 	parent.mb_registerPanSubElement("measuring");
 function displayButtons() {
 	for (var i = 0 ; i < buttonWfs_id.length ; i ++) {
@@ -193,7 +193,7 @@
    	el.onmousedown = null;
    	el.onmouseup = null;
    	el.onmousemove = null;
 	if (obj.id == button_point) {
 		if (activeButton == null) {
 			activeButton = obj;
@@ -238,7 +238,7 @@
 				spatialRequestGeom = queryGeom;
 			parent.mb_disableThisButton(selectedType);
 			// spatialRequestGeom is a Geometry, but for the highlight
 			// a MultiGeometry is needed.
 			var multiGeom;
@@ -262,11 +262,11 @@
 				multiGeom = new parent.MultiGeometry(spatialRequestGeom.geomType);
 				multiGeom.add(spatialRequestGeom);
 			// add highlight of geometry
 			requestGeometryHighlight.add(multiGeom);
 			requestGeometryHighlight.paint();
@@ -303,7 +303,7 @@
 		// rebuild form
 		initModWfsGazetteer();
 function removeChildNodes(node) {
@@ -316,7 +316,7 @@
  * removes whitespaces and endlines before and after a string
 function trimString (str) {
 	return str.replace(/^\s+|\s+|\n+$/g, '');
@@ -341,7 +341,7 @@
 		styleObj=document.createElement("style");
 		styleObj.setAttribute("type","text/css");
 		document.getElementsByTagName("head")[0].appendChild(styleObj);
-		styleObj.appendChild(document.createTextNode(rule+"\n"));
+		styleObj.appendChild(document.createTextNode(rule+"\n"));
@@ -356,14 +356,14 @@
 		var currentNode = document.getElementById(currentId);
 		removeChildNodes(currentNode);
 	geomArray = new parent.GeometryArray();
 	parent.mb_ajax_json("../php/mod_wfs_gazetteer_server.php", {command:"getWfsConf",wfsConfIdString:wfsConfIdString}, function(json, status) {
 		global_wfsConfObj = json;
 		var wfsCount = 0;
 		for (var wfsConfId in global_wfsConfObj) {
-			global_selectedWfsConfId = wfsConfId;
+			global_selectedWfsConfId = wfsConfId;
 			if (typeof(global_wfsConfObj[wfsConfId] != 'function')) {
 				wfsCount++;
@@ -377,23 +377,23 @@
 		else {
 			appendWfsConfSelectBox();
 		parent.mb_setWmcExtensionData({"wfsConfIdString":wfsConfIdString});
 	// creates a Highlight object for the request geometry
 	var styleProperties = {"position":"absolute", "top":"0px", "left":"0px", "z-index":100};
 	requestGeometryHighlight = new parent.Highlight(targetArray, "requestGeometryHighlight", styleProperties, 2);
 	parent.mb_registerSubFunctions("window.frames['" + frameName +"'].requestGeometryHighlight.paint()");
 function setWfsInfo() {
 	var bodyNode = document.getElementById("wfsIcons");
 	removeChildNodes(bodyNode);
-	var bulbNode = document.createElement("a");
+	var bulbNode = document.createElement("a");
 	bulbNode.name = "wfsInfo";
 	bulbNode.id = "wfsInfo";
 	bodyNode.appendChild(bulbNode);
@@ -409,7 +409,7 @@
 	bulbNode.appendChild(imgNode);
 	bulbNode.href = "javascript:openwindow('../php/mod_featuretypeMetadata.php?wfs_conf_id=" + global_selectedWfsConfId.toString() + "');";
 	bulbNode.style.visibility = "visible";
 	// set image: remove this WFS
 	var wfsRemoveNode = document.createElement("img");
 	wfsRemoveNode.name = "wfsRemove";
@@ -422,8 +422,8 @@
 	// Internet explorer
 	if (parent.ie) {
 		wfsRemoveNode.onclick = function() {
-			var x = new Function ("", "delete global_wfsConfObj[global_selectedWfsConfId];setWfsConfIdString();initModWfsGazetteer();parent.mb_setWmcExtensionData({'wfsConfIdString':wfsConfIdString});");
-			x();
+			var x = new Function ("", "delete global_wfsConfObj[global_selectedWfsConfId];setWfsConfIdString();initModWfsGazetteer();parent.mb_setWmcExtensionData({'wfsConfIdString':wfsConfIdString});");
+			x();
 	// Firefox
@@ -431,10 +431,10 @@
 		wfsRemoveNode.onclick = function () {
-			initModWfsGazetteer();
+			initModWfsGazetteer();
 	// set wfsGeomType image
 	var wfsGeomTypeNode = document.createElement("img");
 	wfsGeomTypeNode.name = "wfsGeomType";
@@ -467,7 +467,7 @@
 function setWfsConfIdString() {
 	var str = [];
 			str.push(wfsConfId);
@@ -498,9 +498,9 @@
 	var isSelected = false;
 		var optionNode = document.createElement("option");
 		optionNode.value = wfsConfId;
-		optionNode.innerHTML = global_wfsConfObj[wfsConfId].g_label;
+		optionNode.innerHTML = global_wfsConfObj[wfsConfId].wfs_conf_abstract;
 		if (!isSelected) {
 			optionNode.selected = true;
@@ -512,7 +512,7 @@
 	var form = document.getElementById('selectWfsConfForm');
 	form.appendChild(selectNode);
 	appendStyles();
 	appendWfsForm();
@@ -525,12 +525,12 @@
 	removeChildNodes(form);
 	var resultDiv = document.getElementById("res");
 	removeChildNodes(resultDiv);
 	var divContainer = document.createElement("div");
 	divContainer.className = global_wfsConfObj[global_selectedWfsConfId].g_label_id;
 	divContainer.innerHTML = global_wfsConfObj[global_selectedWfsConfId].g_label;
 	form.appendChild(divContainer);
 	var wfsConfElementArray = global_wfsConfObj[global_selectedWfsConfId].element;
@@ -551,7 +551,7 @@
 				inputNode.id = wfsConfElementArray[i].element_name+"Checkbox";
 				inputNode.innerHTML = wfsConfElementArray[i].f_form_element_html;
-			else{
+			else{
 				var inputNode = document.createElement("input");
 				inputNode.type = "text";
 				inputNode.className = wfsConfElementArray[i].f_style_id;
@@ -564,7 +564,7 @@
 			form.appendChild(spanNode);
 			form.appendChild(inputNode);
 			//build imgNode for datepicker image
 			if(wfsConfElementArray[i].f_form_element_html.match(/datepicker/)){
 				var imgNode = document.createElement("span");
@@ -581,9 +581,9 @@
 	submitButton.id = "submitButton";
 	submitButton.className = global_wfsConfObj[global_selectedWfsConfId].g_button_id;
 	submitButton.value = global_wfsConfObj[global_selectedWfsConfId].g_button;
 	form.appendChild(submitButton);
 	var delFilterButton = document.createElement("input");
 	delFilterButton.type = "button";
 	delFilterButton.style.marginLeft = "5px";
@@ -592,8 +592,8 @@
 	if (parent.ie) {
 		delFilterButton.onclick = function() {
-			var x = new Function ("", "clearFilter();");
-			x();
+			var x = new Function ("", "clearFilter();");
+			x();
 	// Firefox
@@ -603,7 +603,7 @@
  	form.appendChild(delFilterButton);
 	checkSrs();
@@ -618,7 +618,7 @@
 		var msg = '<?php echo _mb("Different EPSG of map and wfs featuretype, no spatial request possible!");?>';
 		msg += parent.mb_mapObj[ind].getSRS()+"  -  "+global_wfsConfObj[global_selectedWfsConfId].featuretype_srs;
 		alert(msg);
 		//disable Submit Button
 		if(submit)submit.disabled = true;
@@ -634,17 +634,17 @@
 		if (parseInt(wfsConfElementArray[i].f_search)) {
 			if(wfsConfElementArray[i].f_form_element_html.match(/checkbox/)){
 				var elementArray = document.getElementsByName(wfsConfElementArray[i].element_name);
-				for (var j = 0; j < elementArray.length; j++){
+				for (var j = 0; j < elementArray.length; j++){
 					elementArray[j].checked = "";
 				document.getElementById('checkAll').checked = "";
 			else{
-				document.getElementById(wfsConfElementArray[i].element_name).value = "";
+				document.getElementById(wfsConfElementArray[i].element_name).value = "";
 	//remove geometry from spatialrequest, remove drawn rectangle or polygon and hint
 	spatialRequestGeom = null;
 	requestGeometryHighlight.clean();
@@ -652,7 +652,7 @@
 	if(document.getElementById('spatialResHint')){
  		document.getElementById("spatialResHint").innerHTML = "";
 	//remove result popup
 	if(typeof(resultGeometryPopup)!="undefined"){
  		resultGeometryPopup.destroy();
@@ -661,7 +661,7 @@
  	if(typeof(wfsPopup)!="undefined"){
  		wfsPopup.destroy();
@@ -673,7 +673,7 @@
 	var el = global_wfsConfObj[global_selectedWfsConfId].element;
 	inputNotEnough = [];
 	for (var i = 0; i < el.length; i++){
 		if( el[i]['f_search'] == 1){
 			if(el[i]['f_form_element_html'].match(/\<select/)){
 				var elementValue = document.getElementById(el[i]['element_name']).options[document.getElementById(el[i]['element_name']).selectedIndex].value;
@@ -681,8 +681,8 @@
     		else if(el[i]['f_form_element_html'].match(/checkbox/)){
 				var elementArray = document.getElementsByName(el[i]['element_name']);
 				var selectedVal = [];
-					if (elementArray[j].checked == true){
+					if (elementArray[j].checked == true){
 						selectedVal.push(elementArray[j].value);
@@ -691,7 +691,7 @@
 			else{
 				var elementValue = document.getElementById(el[i]['element_name']).value;
 			if (elementValue != '') {
 				cnt++;
@@ -700,17 +700,17 @@
 	if(inputNotEnough.length>0){
 		alert("Mandatory fields: "+inputNotEnough.join(', '));
 		return false;
 //	if(spatialRequestGeom == null){
 //		alert("Bitte räumliche Eingrenzung vornehmen.");
 //		return false;
 	return cnt;
 function validate(){
@@ -726,7 +726,7 @@
 	global_resultHighlight = new parent.Highlight(targetArray, "wfs_gazetteer_highlight", {"position":"absolute", "top":"0px", "left":"0px", "z-index":100}, 2);
 	var filterParameterCount = getNumberOfFilterParameters();
 	if(filterParameterCount == 0 && spatialRequestGeom == null){
 	//if(filterParameterCount == 0){
 		//alert("Please specify at least one filter attribute.");
@@ -735,10 +735,10 @@
 	else{
 		if(inputNotEnough.length==0){
 			var andConditions = "";
 			var srs = global_wfsConfObj[global_selectedWfsConfId].featuretype_srs;
 			for (var i = 0; i < el.length; i++) {
 				if (el[i]['f_search'] == 1){
@@ -747,8 +747,8 @@
@@ -758,7 +758,7 @@
 				if (el[i]['f_search'] == 1 && elementValue != '') {
 					var a = new Array();
 					a = elementValue.split(",");
@@ -877,10 +877,10 @@
 			if(spatialRequestGeom!=null){
 				if(spatialRequestGeom.geomType == "polygon"){
-					if(buttonPolygon.filteroption=='within'){
+					if(buttonPolygon.filteroption=='within'){
 						andConditions += "<Within><ogc:PropertyName>";
 						for (var j=0; j < el.length; j++) {
 							if(el[j]['f_geom']==1){
@@ -906,7 +906,7 @@
 						andConditions += "</ogc:PropertyName><gml:Polygon srsName=\""+srs+"\">";
-						andConditions += "<gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
+						andConditions += "<gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
 						for(var k=0; k<spatialRequestGeom.count(); k++){
 							if(k>0)	andConditions += " ";
 							andConditions += spatialRequestGeom.get(k).x+","+spatialRequestGeom.get(k).y;
@@ -914,12 +914,12 @@
 						andConditions += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs>";
 						andConditions += "</gml:Polygon></Intersects>";
 				else if(spatialRequestGeom.geomType == "line"){
 					var rectangle = [];
 					rectangle = spatialRequestGeom.getBBox();
-					if(buttonRectangle.filteroption=='within'){
+					if(buttonRectangle.filteroption=='within'){
@@ -950,7 +950,7 @@
 						andConditions += rectangle[0].x+","+rectangle[0].y;
 						andConditions += rectangle[0].x+","+rectangle[1].y;
@@ -962,13 +962,13 @@
 				else if(spatialRequestGeom.geomType == "point"){
 					var tmp = spatialRequestGeom.get(0);
 					var mapPos = parent.makeRealWorld2mapPos("mapframe1",tmp.x, tmp.y);
 					var buffer = mb_wfs_tolerance/2;
-					var mapPosXAddPix = mapPos[0] + buffer;
+					var mapPosXAddPix = mapPos[0] + buffer;
 					var mapPosYAddPix = mapPos[1] +buffer;
 					var mapPosXRemovePix = mapPos[0] - buffer;
 					var mapPosYRemovePix = mapPos[1] - buffer;
@@ -983,47 +983,47 @@
 							andConditions += el[j]['element_name'];
-					andConditions += "</ogc:PropertyName><gml:Polygon srsName=\""+srs+"\"><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
+					andConditions += "</ogc:PropertyName><gml:Polygon srsName=\""+srs+"\"><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
 					andConditions += realWorld1[0] + "," + realWorld1[1] + " " + realWorld2[0] + "," + realWorld2[1] +  " ";
-					andConditions += realWorld3[0] + "," + realWorld3[1] + " " + realWorld4[0] + "," + realWorld4[1] + " " + realWorld1[0] + "," + realWorld1[1];
+					andConditions += realWorld3[0] + "," + realWorld3[1] + " " + realWorld4[0] + "," + realWorld4[1] + " " + realWorld1[0] + "," + realWorld1[1];
 					andConditions += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersects>";
 				//andConditions += "<ogc:Not><ogc:PropertyIsNull>";
 	            //andConditions += "<ogc:PropertyName>" + elementName + "</ogc:PropertyName>";
 	       		//andConditions += "</ogc:PropertyIsNull></ogc:Not>";
 			if (filterParameterCount > 1 || spatialRequestGeom != null) {
 				andConditions = "<And>" + andConditions + "</And>";
 			var filter = "<ogc:Filter xmlns:ogc='http://ogc.org' xmlns:gml='http://www.opengis.net/gml'>"+andConditions+"</ogc:Filter>";
 			document.getElementById("res").innerHTML = "<table><tr><td><img src='"+progressIndicatorImg+"'></td><td>"+progressIndicatorText+"</td></tr></table>";
 			var parameters = {
-				"command" : "getSearchResults",
-				"wfs_conf_id" : global_selectedWfsConfId,
+				"command" : "getSearchResults",
+				"wfs_conf_id" : global_selectedWfsConfId,
 				"typename" : global_wfsConfObj[global_selectedWfsConfId].featuretype_name,
-				"frame" : this.name,
-				"filter" : filter,
+				"frame" : this.name,
+				"filter" : filter,
 				"backlink" : ""
 			parent.mb_ajax_get("../php/mod_wfs_gazetteer_server.php", parameters, function (jsCode, status) {
 				document.getElementById("res").innerHTML = "<table><tr><td>"+arrangeResultsText+"</td></tr></table>";
 				if(status=='success'){
 					for (var i=0; i < parent.wms.length; i++) {
 						for (var j=0; j < parent.wms[i].objLayer.length; j++) {
 							var currentLayer = parent.wms[i].objLayer[j];
-							var wms_id = parent.wms[i].wms_id;
+							var wms_id = parent.wms[i].wms_id;
 							if (currentLayer.gui_layer_wfs_featuretype == global_selectedWfsConfId) {
-								var layer_name = currentLayer.layer_name;
-								parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'querylayer',1);
-								parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'visible',1);
+								var layer_name = currentLayer.layer_name;
+								parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'querylayer',1);
+								parent.handleSelectedLayer_array(targetArray[0],[wms_id],[layer_name],'visible',1);
-					var geoObj = eval('(' + jsCode + ')');
+					var geoObj = eval('(' + jsCode + ')');
 		       		if (jsCode) {
 			        	if (typeof(geoObj) == 'object') {
 			        		geomArray.importGeoJSON(geoObj);
@@ -1045,7 +1045,7 @@
 		else{
 			return false;
 	//spatialRequestGeom = null;
 	return false;
@@ -1058,7 +1058,7 @@
 	else{
 		var contentHtml = "No results.";
 	if(showResultInPopup==1){
 		if (typeof(resultGeometryPopup) == "undefined") {
 			resultGeometryPopup = new parent.mb_popup(searchPopupTitle,contentHtml,searchPopupWidth,searchPopupHeight,searchPopupX,searchPopupY);
@@ -1070,13 +1070,13 @@
 		resultGeometryPopup.show();
 		parent.$("#resultTable").tablesorter({
      		sortList: [[0,0]],
-     		widgets: ['zebra']
+     		widgets: ['zebra']
 	else{
 		document.getElementById("res").innerHTML = contentHtml;
 function createListOfGeometries(){
@@ -1089,7 +1089,7 @@
 	var wfsConf = global_wfsConfObj[global_selectedWfsConfId];
 	var labelArray = [];
 	if (geomArray.count() > 0) {
 			listOfGeom += "<thead><tr>";
 			var labelObj = getListTitle();
@@ -1100,7 +1100,7 @@
 			listOfGeom += "</tr></thead>";
-		listOfGeom += "<tbody>";
+		listOfGeom += "<tbody>";
 		for (var i = 0 ; i < geomArray.count(); i ++) {
 			if (geomArray.get(i).get(-1).isComplete()) {
 				listOfGeom += "<tr>\n";
@@ -1129,13 +1129,13 @@
 						listOfGeom += " onclick=\""+domPath+"setResult('click',"+i+"); "+domPath+"showWfs("+i+");\" ";
 						listOfGeom += ">"+ resultElObj[l] +"</td>";
-				listOfGeom += "\t</tr>\n";
+				listOfGeom += "\t</tr>\n";
 	listOfGeom += "</tbody></table></form>\n";
-	return listOfGeom;
+	return listOfGeom;
 function getListTitle(){
@@ -1149,7 +1149,7 @@
 	return labelArray;
 function getListValues(geom){
 	var resultArray = [];
@@ -1217,9 +1217,9 @@
 		for(var key in currentDetail){
 			var currentDetailName = key;
 			var currentDetailValue = currentDetail[key];
-			resultHtml +="<tr><td>\n";
+			resultHtml +="<tr><td>\n";
 			resultHtml += currentDetailName;
-			resultHtml +="</td>\n";
+			resultHtml +="</td>\n";
 			resultHtml += "<td>\n";
 			resultHtml += currentDetailValue;
 			resultHtml += "</td></tr>\n";
More information about the Mapbender_commits mailing list
