[Mapbender-commits] r4357 - branches/2.6
svn_mapbender at osgeo.org
Wed Jul 15 07:42:29 EDT 2009
Author: vschulze
Date: 2009-07-15 07:42:29 -0400 (Wed, 15 Jul 2009)
New Revision: 4357
branches/2.6/Install.txt
more information about using mapbender_setup.php
Modified: branches/2.6/Install.txt
--- branches/2.6/Install.txt 2009-07-15 10:05:21 UTC (rev 4356)
+++ branches/2.6/Install.txt 2009-07-15 11:42:29 UTC (rev 4357)
@@ -174,7 +174,7 @@
-- 6. Database:
-(NOTE: If want to save time, use the new shell script at
+(NOTE: If you want to save time, use the new shell script at
resources/db/install.sh
@@ -264,8 +264,24 @@
-- check the database connection
http://localhost/tools/mapbender_setup.php
+You can check your setup with the script mapbender_setup.php.
+The script mapbender_setup.php moved to the directory:
+/mapbender/tools/mapbender_setup.php
+To run the script you have to move it to mapbender/http/tools/mapbender_setup.php,
+as it can't be accessed at /mapbender/tools/mapbender_setup.php.
+-- Notice
+Please notice that for security reasons the directory tools should not be available for external users, as e.g. the mapbender_setup.php displays internal information about your system (PHP version, databasename, database user...).
+Protect the directory by htaccess or just remove the tools-directory again after testing.
+Run the mapbender_setup.php:
+http://localhost/mapbender/tools/mapbender_setup.php
+The mapbender_setup.php checks if all configurations of the mapbender.conf are correct
+and checks some system settings.
-- 8. print configuration
More information about the Mapbender_commits
