[Mapbender-commits] r4385 -
branches/mifan_dev/mapbender/http/classes
svn_mapbender at osgeo.org
Mon Jul 20 04:36:01 EDT 2009
Author: mifan
Date: 2009-07-20 04:36:01 -0400 (Mon, 20 Jul 2009)
New Revision: 4385
branches/mifan_dev/mapbender/http/classes/class_csw.php
storing multiple op values
Modified: branches/mifan_dev/mapbender/http/classes/class_csw.php
--- branches/mifan_dev/mapbender/http/classes/class_csw.php 2009-07-20 08:31:46 UTC (rev 4384)
+++ branches/mifan_dev/mapbender/http/classes/class_csw.php 2009-07-20 08:36:01 UTC (rev 4385)
@@ -265,6 +265,8 @@
+ print('op_Val: ');
+ print_r($this->cat_op_values);
//Success/Failure
if(!$this->cat_title || $this->cat_title == ""){
$this->cat_status = false;
@@ -277,6 +279,8 @@
return true;
@@ -303,23 +307,21 @@
# INSERT INTO TABLE cat - auto insert cat_id
$sql = "INSERT INTO cat( ";
- $sql .= "cat_version, cat_title, cat_abstract, cat_op_getcapabilities, ";
- $sql .= "cat_op_describerecord, cat_op_getrecords, cat_op_getrecordbyid, ";
+ $sql .= "cat_version, cat_title, cat_abstract, ";
$sql .= "cat_upload_url, fees, accessconstraints, providername, providersite, ";
$sql .= "individualname, positionname, voice, facsimile, deliverypoint, ";
$sql .= "city, administrativearea, postalcode, country, electronicmailaddress, ";
$sql .= "cat_getcapabilities_doc, cat_owner, cat_timestamp) ";
$sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$15,$16,$17,$18,$19,$20,$21,$22,$23,$24,$25)";
- $v = array($this->cat_version,$this->cat_title,$this->cat_abstract,$this->cat_op_getcapabilities,
- $this->cat_op_describerecord,$this->cat_op_getrecords,$this->cat_op_getrecordbyid,
+ $v = array($this->cat_version,$this->cat_title,$this->cat_abstract,
$this->cat_upload_url,$this->fees,$this->accessconstraints,$this->providername,$this->providersite,
$this->contactperson, $this->contactposition, $this->contactvoicetelephone,$this->contactfacsimiletelephone,$this->delivery,
$this->city,$this->address,$this->postcode,$this->country,$this->contactelectronicmailaddress,
$admin->char_encode($this->cat_getcapabilities_doc),
$_SESSION['mb_user_id'],strtotime("now"));
- $t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','i','i');
+ $t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','i','i');
$res = db_prep_query($sql,$v,$t);
if(!$res){
@@ -341,18 +343,31 @@
//CAT_OP_CONF
- //getcapabilities_get
- $sql = " INSERT INTO cat_op_conf(fk_cat_id, param_name, param_value) " ;
- $sql .= " VALUES ($1, $2, $3)";
- $v = array($cat_insert_id,'get_capabilities_get','');
- $t = array('i','s','s');
- $res = db_prep_query($sql,$v,$t);
- if(!$res){
- db_rollback();
+ foreach ($this->cat_op_values as $op_category=>$op_name_array){
+ foreach($op_name_array as $op_type=>$op_value_array){
+ foreach($op_value_array as $op_sub_type=>$value){
+ $op_type_value = '';
+ if($op_sub_type != 'dflt'){
+ //If not dflt, then it is either soap or xml - store this info as post_xml etc
+ $op_type_value = $op_type.'_'.$op_sub_type;
+ //Store values
+ $sql = " INSERT INTO cat_op_conf(fk_cat_id, param_type, param_name, param_value) " ;
+ $sql .= " VALUES ($1, $2, $3)";
+ $v = array($cat_insert_id,'get_capabilities_get','');
+ $t = array('i','s','s');
+ $res = db_prep_query($sql,$v,$t);
+ if(!$res){
+ db_rollback();
//Commit Changes
db_commit();
More information about the Mapbender_commits
