[Mapbender-commits] r3618 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Mar 2 09:58:45 EST 2009
Author: christoph
Date: 2009-03-02 09:58:45 -0500 (Mon, 02 Mar 2009)
New Revision: 3618
   trunk/mapbender/http/classes/class_gml_factory.php
   trunk/mapbender/http/php/mod_wfs_gazetteer_server.php
bug fixes
Modified: trunk/mapbender/http/classes/class_gml_factory.php
--- trunk/mapbender/http/classes/class_gml_factory.php	2009-03-02 14:48:04 UTC (rev 3617)
+++ trunk/mapbender/http/classes/class_gml_factory.php	2009-03-02 14:58:45 UTC (rev 3618)
@@ -184,6 +184,9 @@
 			// used in this WFS configuration
 			$wfsFactory = new UniversalWfsFactory();
 			$myWfs = $wfsFactory->createFromDb($wfsConf->wfsId);
+			if (is_null($myWfs)) {
+				return null;
 			$featureType = $myWfs->findFeatureTypeById($wfsConf->featureTypeId);
 			// register namespace of feature type
Modified: trunk/mapbender/http/php/mod_wfs_gazetteer_server.php
--- trunk/mapbender/http/php/mod_wfs_gazetteer_server.php	2009-03-02 14:48:04 UTC (rev 3617)
+++ trunk/mapbender/http/php/mod_wfs_gazetteer_server.php	2009-03-02 14:58:45 UTC (rev 3618)
@@ -23,6 +23,7 @@
 require_once(dirname(__FILE__)."/../classes/class_wfs_conf.php");
 require_once(dirname(__FILE__)."/../classes/class_universal_wfs_factory.php");
 require_once(dirname(__FILE__)."/../classes/class_universal_gml_factory.php");
+require_once(dirname(__FILE__)."/../classes/class_wfs_configuration.php");
 $command = $_REQUEST["command"];
@@ -107,60 +108,26 @@
 	$url = $_REQUEST["url"];
 	$typename = $_REQUEST["typename"];
-	/* wfs_conf */
-	$sql = "SELECT * FROM wfs_conf JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
-	$sql .= "WHERE wfs_conf.wfs_conf_id = $1";
-	$v = array($wfs_conf_id);
-	$t = array('i');
-	$res = db_prep_query($sql,$v,$t);
-	if ($row = db_fetch_array($res)) {
-		$g_res_style  = $row["g_res_style"];
+	$wfsConf = WfsConfiguration::createFromDb($wfs_conf_id);
+	if (is_null($wfsConf)) {
+		sendErrorMessage("Invalid WFS conf: " . $wfs_conf_id);
-	else {
-		die("wfs_conf " . $wfs_conf_id . "data not available");
-	/* wfs_conf_element */
-	$sql = "SELECT * FROM wfs_conf_element ";
-	$sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
-	$sql .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
-	$sql .= "AND wfs_conf_element.f_show = 1 ORDER BY wfs_conf_element.f_respos;";
-	$t = array('i');
-	$col = array();
-	while ($row = db_fetch_array($res)) {
-		array_push($col, $row["element_name"]);
-	if (count($col) == 0) {
-		die("wfs_conf_element data not available");
-	// append authorisation condition to filter
-	$filter = checkAccessConstraint($filter, $wfs_conf_id);
 	$admin = new administration();
 	$filter = $admin->char_decode(stripslashes($filter));
-	$sql = "SELECT fkey_wfs_id FROM wfs_conf WHERE wfs_conf_id = $1";
-	$t = array('i');
-	$res = db_prep_query($sql, $v, $t);
-	$row = db_fetch_array($res);
-	$wfsId = $row["fkey_wfs_id"];
+	$wfsId = $wfsConf->wfsId;
 	$myWfsFactory = new UniversalWfsFactory();
 	$myWfs = $myWfsFactory->createFromDb($wfsId);
 	$data = $myWfs->getFeature($typename, $filter);
 	if ($data === null) die('{}');
-	$geomColumn = WfsConf::getGeomColumnNameByConfId($wfs_conf_id);
+//	$geomColumn = WfsConf::getGeomColumnNameByConfId($wfs_conf_id);
 	$gmlFactory = new UniversalGmlFactory();
-	$myGml = $gmlFactory->createFromXml($data);
+	$myGml = $gmlFactory->createFromXml($data, $wfsConf);
 	$geoJson = $myGml->toGeoJSON();
 	header("Content-type:application/x-json; charset=utf-8");
More information about the Mapbender_commits mailing list
