[Mapbender-commits] r3623 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Mar 3 03:26:52 EST 2009
Author: astrid_emde
Date: 2009-03-03 03:26:52 -0500 (Tue, 03 Mar 2009)
New Revision: 3623
Added:
   trunk/mapbender/http/php/mod_category_filteredGUI.php
skript to add a gui to a category
http://trac.osgeo.org/mapbender/ticket/344
http://www.mapbender.org/GUI_Category
Added: trunk/mapbender/http/php/mod_category_filteredGUI.php
--- trunk/mapbender/http/php/mod_category_filteredGUI.php	                        (rev 0)
+++ trunk/mapbender/http/php/mod_category_filteredGUI.php	2009-03-03 08:26:52 UTC (rev 3623)
@@ -0,0 +1,250 @@
+<?php
+# $Id:$
+# http://www.mapbender.org/index.php/Administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+import_request_variables("PG");
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Administration</title>
+<?php
+include '../include/dyn_css.php';
+<script language="JavaScript">
+function validate(wert){
+	if(document.forms[0]["selected_category"].selectedIndex == -1){
+		document.getElementsByName("selected_category")[0].style.backgroundColor = '#ff0000';
+		return;
+	}else{
+		if(wert == "remove"){
+			if(document.forms[0]["remove_gui[]"].selectedIndex == -1){
+				document.getElementsByName("remove_gui[]")[0].style.backgroundColor = '#ff0000';
+				return;
+			document.form1.remove.value = 'true';
+			document.form1.submit();
+		if(wert == "insert"){
+			if(document.forms[0]["selected_gui[]"].selectedIndex == -1){
+				document.getElementsByName("selected_gui[]")[0].style.backgroundColor = '#ff0000';
+				return;
+			document.form1.insert.value = 'true';
+ * filter the category list
+function filtercategory(list, all, str){
+	str=str.toLowerCase();
+	var selection=[];
+	var i,j,selected;
+	for(i=0;i<list.options.length;i++){
+		if(list.options[i].selected)
+			selection[selection.length]=list.options[i].value;
+	list.options.length = 0;
+	for(i=0; i<all.length; i++){
+		if(all[i]['name'].toLowerCase().indexOf(str)==-1)
+			continue;
+		selected=false;
+		for(j=0;j<selection.length;j++){
+			if(selection[j]==all[i]['id']){
+				selected=true;
+				break;
+		var newOption = new Option(selected?all[i]['name']:all[i]['name'],all[i]['id'],false,selected);
+		newOption.setAttribute("title", all[i]['description']);
+		list.options[list.options.length] = newOption;
+</script>
+</head>
+<body>
+<?php
+$fieldHeight = 20;
+$cnt_gui = 0;
+$cnt_category = 0;
+$cnt_gui = 0;
+$cnt_gui_category = 0;
+$cnt_gui_gui = 0;
+$exists = false;
+$logged_user_name=$_SESSION["mb_user_name"];
+$logged_user_id=$_SESSION["mb_user_id"];
+$admin = new administration();
+/*handle remove, update and insert*****************************************************************/
+if($insert){
+	if(count($selected_gui)>0){
+		for($i=0; $i<count($selected_gui); $i++){
+			$exists = false;
+			$sql_insert = "SELECT * from gui_gui_category where fkey_gui_category_id = $1 and fkey_gui_id = $2";
+			$v = array($selected_category,$selected_gui[$i]);
+			$t = array('i','s');
+			$res_insert = db_prep_query($sql_insert,$v,$t);
+			while(db_fetch_row($res_insert)){$exists = true;}
+			if($exists == false){
+				$sql_insert = "INSERT INTO gui_gui_category(fkey_gui_category_id, fkey_gui_id) VALUES($1, $2)";
+if($remove){
+	if(count($remove_gui)>0){
+		for($i=0; $i<count($remove_gui); $i++){
+			$sql_remove = "DELETE FROM gui_gui_category WHERE fkey_gui_id = $1 and fkey_gui_category_id = $2";
+			$v = array($remove_gui[$i],$selected_category);
+			$t = array('s','i');
+			db_prep_query($sql_remove,$v,$t);
+/*get owner guis  *******************************************************************************/
+$guisByOwner = $admin->getGuisByOwner($logged_user_id,false);
+for ($i = 0; $i < count($guisByOwner); $i++) {
+	$gui_id[$cnt_gui] = $guisByOwner[$i];
+	$gui_name[$cnt_gui] = $guisByOwner[$i];
+	$cnt_gui++;
+/*get categories **********************************************************************************/
+$sql_category = "SELECT * FROM gui_category order by category_id;";
+$res_category = db_query($sql_category);
+while($row = db_fetch_array($res_category)){
+	$category_id[$cnt_category] = $row["category_id"];
+	$category_name[$cnt_category] = $row["category_name"];
+	$category_description[$cnt_category] = $row["category_description"];
+	$cnt_category++;
+# has to be solved by a function
+$guiCategories = $admin->getGuiCategories();
+echo "<br>getGuiCategories - mehrere Spalten";
+echo "Noch einbauen getGuiCategories".count($guiCategories);
+* get owner gui for selected category
+if (count($category_id) == 0 AND count($gui_id) == 0){ die("There is no gui or category available for this user");}
+#$sql_category_gui = "SELECT gui.gui_id, gui.gui_name, gui_gui_category.fkey_gui_category_id FROM gui_gui_category ";
+#$sql_category_gui .= "INNER JOIN gui ON gui_gui_category.fkey_gui_id = gui.gui_id ";
+#$sql_category_gui .= "WHERE gui_gui_category.fkey_gui_category_id = $1 ";
+#echo $sql_category_gui;egories);
+#if(!$selected_category){$v = array($category_id[0]);}
+#if($selected_category){$v = array($selected_category);}
+#$t = array('i');
+#$sql_category_gui .= " ORDER BY gui.gui_name";
+if(!$selected_category){$selectedCategory = $category_id[0];}
+if($selected_category){$selectedCategory = $selected_category;}
+$getGuisByOwnerBySelectedGuiCategory = $admin->getGuisByOwnerByGuiCategory($logged_user_id,$selectedCategory);
+$cnt_gui_category = count($getGuisByOwnerBySelectedGuiCategory);
+$gui_category_id = $getGuisByOwnerBySelectedGuiCategory;
+#$res_category_gui = db_prep_query($sql_category_gui,$v,$t);
+#while($row = db_fetch_array($res_category_gui)){
+#$gui_category_id[$cnt_gui_category] = $row["gui_id"];
+#$gui_category_name[$cnt_gui_category] =  $row["gui_name"];
+#$cnt_gui_category++;
+/*INSERT HTML*/
+echo "<form name='form1' action='" . $self ."' method='post'>";
+/*filterbox****************************************************************************************/
+echo "<input type='text' value='' class='filter1' id='filter1' name='filter1' onkeyup='filtercategory(document.getElementById(\"selectedcategory\"),category,this.value);'/>";
+/*insert all category in selectbox*****************************************************************/
+echo "<div class='text1'>Category: </div>";
+echo "<select style='background:#ffffff' onchange='submit();' class='select1' id='selectedcategory' name='selected_category' size='10'>";
+for($i=0; $i<$cnt_category; $i++){
+	echo "<option value='" . $category_id[$i] . "' ";
+	if($selected_category && $selected_category == $category_id[$i]){
+		echo "selected>".$category_name[$i];
+	else
+		echo ">" . $category_name[$i];
+	echo "</option>";
+echo "</select>";
+/*insert all guis in selectbox********************************************************************/
+echo "<div class='text2'>GUI:</div>";
+echo "<select style='background:#ffffff' class='select2' multiple='multiple' name='selected_gui[]' size='$fieldHeight' >";
+for($i=0; $i<$cnt_gui; $i++){
+	echo "<option value='" . $gui_name[$i]  . "'>" . $gui_name[$i]  . "</option>";
+echo "</select>";
+/*Button******************************************************************************************/
+echo "<div class='button1'><input type='button'  value='==>' onClick='validate(\"insert\")'></div>";
+echo "<input type='hidden' name='insert'>";
+echo "<div class='button2'><input type='button' value='<==' onClick='validate(\"remove\")'></div>";
+echo "<input type='hidden' name='remove'>";
+/*insert category_gui_dependence in selectbox**************************************************/
+echo "<div class='text3'>SELECTED GUI:</div>";
+echo "<select style='background:#ffffff' class='select3' multiple='multiple' name='remove_gui[]' size='$fieldHeight' >";
+for($i=0; $i<$cnt_gui_category; $i++){
+	echo "<option value='" . $gui_category_id[$i]  . "'>" .$gui_category_id[$i]. "</option>";
+echo "</select>";
+echo "</form>";
+<script type="text/javascript">
+document.forms[0].selected_category.focus();
+var category=[];
+<?php
+	echo "category[".$i."]=[];\n";
+	echo "category[".$i."]['id']='" . $category_id[$i]  . "';\n";
+	echo "category[".$i."]['name']='" . $category_name[$i]  . "';\n";
+	echo "category[".$i."]['description']='" . $category_description[$i]  . "';\n";
+</script>
+</body>
+</html>
\ No newline at end of file
More information about the Mapbender_commits mailing list
