[Mapbender-commits] r3639 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Mar 6 08:48:32 EST 2009
Author: verenadiewald
Date: 2009-03-06 08:48:31 -0500 (Fri, 06 Mar 2009)
New Revision: 3639
   trunk/mapbender/resources/db/update/update_2.6.sql
set standard element vars for possibility to use popup in featureInfoTunnel
Modified: trunk/mapbender/resources/db/update/update_2.6.sql
--- trunk/mapbender/resources/db/update/update_2.6.sql	2009-03-06 13:31:49 UTC (rev 3638)
+++ trunk/mapbender/resources/db/update/update_2.6.sql	2009-03-06 13:48:31 UTC (rev 3639)
@@ -370,4 +370,24 @@
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'option_gui', '0', '1 enables option "load configured wms by gui"' ,'var');
 -- set popup.js as required module for gui element loadwmc
-UPDATE gui_element SET e_mb_mod = 'popup.js' WHERE e_id = 'loadwmc';
\ No newline at end of file
+UPDATE gui_element SET e_mb_mod = 'popup.js' WHERE e_id = 'loadwmc';
+-- set popup.js as required module for gui element featureInfoTunnel
+UPDATE gui_element SET e_mb_mod = 'popup.js' WHERE e_id = 'featureInfoTunnel'
+-- set standard element vars for possibility to use popup in featureInfoTunnel; activated for gui_digitize
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoLayerPopup', 'true', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
More information about the Mapbender_commits mailing list
