[Mapbender-commits] r3641 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Mar 6 09:57:29 EST 2009
Author: verenadiewald
Date: 2009-03-06 09:57:29 -0500 (Fri, 06 Mar 2009)
New Revision: 3641
Added:
   trunk/mapbender/http/javascripts/wfsFilter.js
wfsFilter.js for tooltip module
Added: trunk/mapbender/http/javascripts/wfsFilter.js
--- trunk/mapbender/http/javascripts/wfsFilter.js	                        (rev 0)
+++ trunk/mapbender/http/javascripts/wfsFilter.js	2009-03-06 14:57:29 UTC (rev 3641)
@@ -0,0 +1,236 @@
+function WfsFilter () {
+	this.operators = [
+			"operator":"==",
+			"wfsOpenTag":"PropertyIsEqualTo",
+			"wfsCloseTag":"PropertyIsEqualTo"
+			"operator":">=",
+			"wfsOpenTag":"PropertyIsGreaterThanOrEqualTo",
+			"wfsCloseTag":"PropertyIsGreaterThanOrEqualTo"
+			"operator":"<=",
+			"wfsOpenTag":"PropertyIsLessThanOrEqualTo",
+			"wfsCloseTag":"PropertyIsLessThanOrEqualTo"
+			"operator":">>",
+			"wfsOpenTag":"PropertyIsGreaterThan",
+			"wfsCloseTag":"PropertyIsGreaterThan"
+			"operator":"<<",
+			"wfsOpenTag":"PropertyIsLessThan",
+			"wfsCloseTag":"PropertyIsLessThan"
+			"operator":"<>",
+			"wfsOpenTag":"PropertyIsNotEqualTo",
+			"wfsCloseTag":"PropertyIsNotEqualTo"
+			"operator":"LIKE",
+			"wfsOpenTag":"PropertyIsLike wildCard='*' singleChar='.' escape='!'",
+			"wfsCloseTag":"PropertyIsLike"
+	var conditionToString = function (condition, operator){
+		var splitParam = condition.split(operator);
+		var columnName = trim(splitParam[0]);
+		var columnValue = trim(splitParam[1]);
+		if (operator == 'LIKE') {
+			columnValue = "*"+ columnValue +"*";
+		for (var i = 0 ; i < that.operators.length ; i++) {
+			if (that.operators[i].operator == operator){
+				// add condition: Property
+				var condString = '<'+that.operators[i].wfsOpenTag+'>' +
+					'<PropertyName>'+columnName+'</PropertyName>' +
+					'<Literal>'+columnValue+'</Literal>' +
+					'</'+that.operators[i].wfsCloseTag+'>';
+				// add condition: Property is not null
+					'<ogc:Not><ogc:PropertyIsNull>' +
+					'<ogc:PropertyName>'+columnName+'</ogc:PropertyName>' +
+					'</ogc:PropertyIsNull></ogc:Not>';
+				return condString;
+		return "";
+	var getOperatorFromCondition = function (aCondition) {
+		for (var j = 0; j < that.operators.length; j++) {
+			if (aCondition.match(that.operators[j].operator)) {
+				return that.operators[j].operator;
+		return false;
+	 * parse the filter from the HTML form,
+	 * @param {String} filter like "[usertype]<>3 AND [firstname]==Emil"
+	this.parse = function (filter) {
+		if (filter !== '') {
+			filter = filter.replace(/\[/g,"");
+			filter = filter.replace(/\]/g,"");
+			var condArray = filter.split(' AND ');
+			var wfsCond = [];
+			for (var i = 0 ; i < condArray.length ; i++) {
+				var currentOperator = getOperatorFromCondition(condArray[i]);
+				if (!currentOperator) {
+					return false;
+				wfsCond.push(conditionToString(condArray[i], currentOperator));
+			conditionArray = conditionArray.concat(wfsCond);
+		return true;
+	this.addSpatial = function (spatialRequestGeom, geometryColumn, filteroption, srs, target) {
+		if(typeof(spatialRequestGeom) != "undefined"){
+			var spatialRequestFilter = "";
+			if(spatialRequestGeom.geomType == geomType.polygon){
+				spatialRequestFilter += "<" + filteroption + "><ogc:PropertyName>" +
+					geometryColumn + "</ogc:PropertyName><gml:Polygon srsName=\""+srs+"\">" +
+					"<gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
+				for(var k=0; k<spatialRequestGeom.count(); k++){
+					if (k > 0) {
+						spatialRequestFilter += " ";
+					spatialRequestFilter += spatialRequestGeom.get(k).x+","+spatialRequestGeom.get(k).y;
+				spatialRequestFilter += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs>";
+				spatialRequestFilter += "</gml:Polygon></" + filteroption + ">";
+			else if(spatialRequestGeom.geomType == geomType.line){
+				var rectangle = [];
+				rectangle = spatialRequestGeom.getBBox();
+					"<gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>" +
+					rectangle[0].x+","+rectangle[0].y + " " +
+					rectangle[0].x+","+rectangle[1].y + " " +
+					rectangle[1].x+","+rectangle[1].y + " " +
+					rectangle[1].x+","+rectangle[0].y + " " +
+					"</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs>" +
+					"</gml:Polygon></" + filteroption + ">";
+			else if(spatialRequestGeom.geomType == geomType.point){
+				var tmp = spatialRequestGeom.get(0);
+				var mapPos = makeRealWorld2mapPos(target,tmp.x, tmp.y);
+				var buffer = mb_wfs_tolerance/2;
+				var realWorld1 = makeClickPos2RealWorldPos(target,mapPos[0]-buffer,mapPos[1]-buffer);
+				var realWorld2 = makeClickPos2RealWorldPos(target,mapPos[0]+buffer,mapPos[1]-buffer);
+				var realWorld3 = makeClickPos2RealWorldPos(target,mapPos[0]+buffer,mapPos[1]+buffer);
+				var realWorld4 = makeClickPos2RealWorldPos(target,mapPos[0]-buffer,mapPos[1]+buffer);
+				spatialRequestFilter += "<Intersects><ogc:PropertyName>";
+				spatialRequestFilter += geometryColumn;
+				spatialRequestFilter += "</ogc:PropertyName><gml:Polygon srsName=\""+srs+"\"><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
+				spatialRequestFilter += realWorld1[0] + "," + realWorld1[1] + " " + realWorld2[0] + "," + realWorld2[1] +  " ";
+				spatialRequestFilter += realWorld3[0] + "," + realWorld3[1] + " " + realWorld4[0] + "," + realWorld4[1] + " " + realWorld1[0] + "," + realWorld1[1];
+				spatialRequestFilter += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersects>";
+			spatialRequestFilter += "<ogc:Not><ogc:PropertyIsNull>";
+            spatialRequestFilter += "<ogc:PropertyName>" + geometryColumn + "</ogc:PropertyName>";
+       		spatialRequestFilter += "</ogc:PropertyIsNull></ogc:Not>";
+			conditionArray.push(spatialRequestFilter);
+	this.addPreConfigured = function (propName, propValueArray, toUpper, operator) {
+		var orConditions = "";
+		for (var j=0; j < propValueArray.length; j++) {
+			if (operator == 'greater_than' || operator == 'less_than' || operator == 'equal') {
+				if(propValueArray[j]!=''){
+					var tag;
+					if (operator == 'greater_than') {
+						tag = "PropertyIsGreaterThan";
+					else if (operator == 'less_than') {
+						tag = "PropertyIsLessThan";
+					else if (operator == 'equal') {
+						tag = "PropertyIsEqualTo";
+					orConditions += "<ogc:" + tag + ">";
+					orConditions += "<ogc:PropertyName>" + propName + "</ogc:PropertyName>";
+					orConditions += "<ogc:Literal>";
+					if (toUpper == 1) {
+						propValueArray[j] = propValueArray[j].toUpperCase();
+					orConditions += propValueArray[j] + "</ogc:Literal></ogc:" + tag + ">";
+			else {
+				var leftSide = "";
+				var rightSide = "*";
+				if (operator != 'rightside') {
+					leftSide = "*";
+				orConditions += "<ogc:PropertyIsLike wildCard='*' singleChar='.' escape='!'>";
+				orConditions += "<ogc:Literal>" + leftSide;
+				if (toUpper == 1){
+				orConditions += propValueArray[j] + rightSide;
+				orConditions += "</ogc:Literal></ogc:PropertyIsLike>";
+			orConditions += "<ogc:Not><ogc:PropertyIsNull>";
+       		orConditions += "</ogc:PropertyIsNull></ogc:Not>";
+		if(propValueArray.length > 1){
+			orConditions = "<Or>" + orConditions + "</Or>";
+		this.add(orConditions);
+	this.add = function (aFilterString) {
+		conditionArray.push(aFilterString);
+	this.toString = function () {
+		var str = "";
+		str += "<ogc:Filter xmlns:ogc='http://www.opengis.net/ogc' ";
+		str += "xmlns:gml='http://www.opengis.net/gml'>";
+		if (conditionArray.length > 1) {
+			str += "<And>" + conditionArray.join("") + "</And>";
+		else {
+			str += conditionArray.join("");
+		str += "</ogc:Filter>";
+		return str;
+	var conditionArray = [];
+	var that = this;
More information about the Mapbender_commits mailing list
