[Mapbender-commits] r3644 - in trunk/mapbender: conf http/img/button_digitize http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Mar 6 11:00:41 EST 2009
Author: christoph
Date: 2009-03-06 11:00:41 -0500 (Fri, 06 Mar 2009)
New Revision: 3644
Added:
   trunk/mapbender/http/img/button_digitize/punchPolygon_off.png
   trunk/mapbender/http/img/button_digitize/punchPolygon_on.png
   trunk/mapbender/http/img/button_digitize/punchPolygon_over.png
   trunk/mapbender/conf/digitize_default.conf
   trunk/mapbender/conf/wfs_default.conf
   trunk/mapbender/http/img/button_digitize/mergePolygons_off.png
   trunk/mapbender/http/img/button_digitize/mergePolygons_on.png
   trunk/mapbender/http/img/button_digitize/mergePolygons_over.png
   trunk/mapbender/http/javascripts/map.php
   trunk/mapbender/http/javascripts/mapnf.php
   trunk/mapbender/http/javascripts/mod_digitize_tab.php
   trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php
   trunk/mapbender/http/javascripts/ovnf.php
* icons for merge and cut polygon
* remove original polygons after cutting/merging/splitting
* bug fixing spatial request: toDigitize/popup
Modified: trunk/mapbender/conf/digitize_default.conf
--- trunk/mapbender/conf/digitize_default.conf	2009-03-06 15:40:30 UTC (rev 3643)
+++ trunk/mapbender/conf/digitize_default.conf	2009-03-06 16:00:41 UTC (rev 3644)
@@ -10,9 +10,9 @@
 addButtonDig("setBasePoint", 1, "new_node_off.png", "", "", 112, 0);
 addButtonDig("delBasePoint", 1, "delete_node_off.png", "", "", 140, 0);
 addButtonDig("clear", 1, "del_off.png", "", "", 168, 0);
-addButtonDig("digitizeDifference", 0, "splitPolygon_off.png", "", "", 0, 28);
-addButtonDig("digitizeSplit", 0, "splitPolygon_off.png", "", "", 28, 28);
-addButtonDig("digitizeMerge", 0, "mergePolygons_off.png", "", "", 56, 28);
+addButtonDig("digitizeSplit", 1, "splitPolygon_off.png", "", "", 0, 28);
+addButtonDig("digitizeDifference", 1, "punchPolygon_off.png", "", "", 28, 28);
+addButtonDig("digitizeMerge", 1, "mergePolygons_off.png", "", "", 56, 28);
 //definition of directory of digitize buttons
 buttonDig_imgdir = "../img/button_digitize/";
@@ -58,4 +58,5 @@
 var wfsWindowWidth = 400;
 var wfsWindowHeight = 300;
-var spatialRequestResultToDigitize = 1;
\ No newline at end of file
+// deprecated! check wfs_default.conf to configure this behaviour
+//var spatialRequestResultToDigitize = 1;
Modified: trunk/mapbender/conf/wfs_default.conf
--- trunk/mapbender/conf/wfs_default.conf	2009-03-06 15:40:30 UTC (rev 3643)
+++ trunk/mapbender/conf/wfs_default.conf	2009-03-06 16:00:41 UTC (rev 3644)
@@ -19,7 +19,9 @@
 var buttonWfs_imgdir = "../img/button_gray/";
 var buttonWfs_zIndex = 10;
-var buttonWfs_toDigitize_on = 1;
+// if wfsResultToPopupDiv is 0, this is automatically 1
+var buttonWfs_toDigitize_on = 1;
+var buttonWfs_toDigitize_target = "digitize";
 var buttonWfs_toDigitize_src = "../img/pencil.png";
 var generalHighlightZIndex = 90;
Modified: trunk/mapbender/http/img/button_digitize/mergePolygons_off.png
(Binary files differ)
Modified: trunk/mapbender/http/img/button_digitize/mergePolygons_on.png
Modified: trunk/mapbender/http/img/button_digitize/mergePolygons_over.png
Added: trunk/mapbender/http/img/button_digitize/punchPolygon_off.png
Property changes on: trunk/mapbender/http/img/button_digitize/punchPolygon_off.png
___________________________________________________________________
   + application/octet-stream
Added: trunk/mapbender/http/img/button_digitize/punchPolygon_on.png
Property changes on: trunk/mapbender/http/img/button_digitize/punchPolygon_on.png
Added: trunk/mapbender/http/img/button_digitize/punchPolygon_over.png
Property changes on: trunk/mapbender/http/img/button_digitize/punchPolygon_over.png
Modified: trunk/mapbender/http/javascripts/map.php
--- trunk/mapbender/http/javascripts/map.php	2009-03-06 15:40:30 UTC (rev 3643)
+++ trunk/mapbender/http/javascripts/map.php	2009-03-06 16:00:41 UTC (rev 3644)
@@ -77,7 +77,8 @@
 $extPath = dirname(__FILE__) . "/../extensions/";
 $extFileArray = array(  "jquery-1.2.6.min.js",
 						"jqjson.js",
-						"jquery.mousewheel.min.js");
+						"jquery.mousewheel.min.js",
+						"jquery.form.js");
 for ($i = 0; $i < count($extFileArray); $i++) {
 	$currentFile = $extPath . $extFileArray[$i];
@@ -163,6 +164,8 @@
 			$e_src = $row_js["e_src"];
 			$e_require = $row_js["e_requires"];
 			$e_target = explode(",",$row_js["e_target"]);
+			$e_width = intval($row_js["e_width"]);
+			$e_height = intval($row_js["e_height"]);
 			$currentFile = trim($jsArray[$i]);
 			if (file_exists($currentFile)) {
 				if (in_array($e_id, $modulesNotRelyingOnGlobalsArray)) {
Modified: trunk/mapbender/http/javascripts/mapnf.php
--- trunk/mapbender/http/javascripts/mapnf.php	2009-03-06 15:40:30 UTC (rev 3643)
+++ trunk/mapbender/http/javascripts/mapnf.php	2009-03-06 16:00:41 UTC (rev 3644)
@@ -19,4 +19,4 @@
 require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-mb_registerMapObj('', 'mapframe1', null,500, 500);
+mb_registerMapObj('', 'mapframe1', null,<?php echo $e_width; ?>, <?php echo $e_height; ?>);
Modified: trunk/mapbender/http/javascripts/mod_digitize_tab.php
--- trunk/mapbender/http/javascripts/mod_digitize_tab.php	2009-03-06 15:40:30 UTC (rev 3643)
+++ trunk/mapbender/http/javascripts/mod_digitize_tab.php	2009-03-06 16:00:41 UTC (rev 3644)
@@ -514,10 +514,6 @@
 	parent.eventAfterMapRequest.register(function () {
 		updateExtent();
-	try {if(spatialRequestResultToDigitize){}}catch(e) {spatialRequestResultToDigitize = 1;}
-	if(spatialRequestResultToDigitize==1){
-		parent.mb_registerWfsReadSubFunctions(function(geom){parent.tab_open(mod_digitize_elName);parent.window.frames[mod_digitize_elName].appendGeometryArray(geom);});
 	parent.mb_registerWfsWriteSubFunctions(function(){parent.zoom(mod_digitize_target, true, 0.999);});
@@ -856,6 +852,12 @@
 				var response = eval('(' + json + ')');
 				var polygon = response.polygon;
 				d.importGeometryFromText(polygon);
+				// remove the original polygons
+				var len = d.count();
+				for (var i = 0; i < len-1; i++) {
+					d.del(0);
 				parent.mb_disableThisButton(button_merge);
@@ -880,6 +882,9 @@
 					d.importGeometryFromText(polygonArray[i]);
 					d.get(-1).wfs_conf = wfsConfId;
+				// remove the original polygon and the temporary line
+				d.del(0);
+				d.del(0);
 				parent.mb_disableThisButton(button_split);
Modified: trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php
--- trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php	2009-03-06 15:40:30 UTC (rev 3643)
+++ trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php	2009-03-06 16:00:41 UTC (rev 3644)
@@ -93,6 +93,44 @@
 try {if(mod_digitize_elName){}}catch(e) {mod_digitize_elName = "digitize";}
+try{
+	if (wfsResultToPopupDiv){}
+catch(e){
+	wfsResultToPopupDiv = 0;
+try{
+	if (buttonWfs_toDigitize_on){}
+catch(e){
+	buttonWfs_toDigitize_on = 0;
+if (wfsResultToPopupDiv == 1) {
+	mb_registerWfsReadSubFunctions(function (geom) {
+		displayPopup(geom);
+else {
+	if (buttonWfs_toDigitize_on == 1) {
+		mb_registerWfsReadSubFunctions(function(geom){
+			if (buttonWfs_toDigitize_target && window.frames[buttonWfs_toDigitize_target]) {
+				tab_open(buttonWfs_toDigitize_target);
+				appendGeometryArrayToDigitize(geom);
+			else {
+				var msg = "No digitizing module available. " +
+					"Check you WFS spatial request configuration.";
+				var e = new Mb_warning(msg);
+var msgObj;
+mb_registerInitFunctions("init_wfsSpatialRequest()");
+//mb_registerL10nFunctions("init_wfsSpatialRequest()");
 function addButtonWfs(id, isOn, src, title, x, y) {
 	buttonWfs_id.push(id);
 	buttonWfs_on.push(isOn);
@@ -103,11 +141,6 @@
 	buttonWfs_y.push(y);
-var msgObj;
-mb_registerInitFunctions("init_wfsSpatialRequest()");
-//mb_registerL10nFunctions("init_wfsSpatialRequest()");
 function init_wfsSpatialRequest() {
 	mb_ajax_json("../php/mod_wfsSpatialRequest_messages.php", function(obj, status) {
 		msgObj = obj;
@@ -172,7 +205,6 @@
 	mod_wfs_spatialRequest_width = mb_mapObj[ind].width;
 	mod_wfs_spatialRequest_height = mb_mapObj[ind].height;
 	mod_wfs_spatialRequest_epsg = mb_mapObj[ind].epsg;
-	mb_registerSubFunctions("drawDashedLineExt()");
 	mb_registerPanSubElement("measuring");
 	geomArray = new GeometryArray();
@@ -280,11 +312,6 @@
 	mod_wfs_spatialRequestSubFunctions[mod_wfs_spatialRequestSubFunctions.length] = stringFunction;
-function isSetWfsResultToDigitize() {
-	if (parseInt(buttonWfs_toDigitize_on)==1) return true;
-	return false;
 function mod_wfs_SpatialRequest_dialog(){
 	if(!mod_wfs_spatialRequest_win || mod_wfs_spatialRequest_win == null || mod_wfs_spatialRequest_win.closed == true){
 		mod_wfs_spatialRequest_win = window.open("","mod_wfs_spatialRequest_win","width=200,height=150,resizable=yes");
@@ -527,7 +554,6 @@
 					geom.get(i).wfs_conf = parseInt(js_wfs_conf_id);
 			checkIfAllAjaxCallsFinished(geom);
@@ -597,8 +623,14 @@
 function appendGeometryArrayToDigitize(geom){
 	var mapIndex = getMapObjIndexByName(mod_wfs_spatialRequest_target);
+	var proceed = true;
 	if (geom.get(0).getEpsg() !== mb_mapObj[mapIndex].epsg) {
-		var e = new Mb_exception("SRS mismatch. Geometry is in " + geom.get(0).getEpsg() + ", map is in " + mb_mapObj[mapIndex].epsg + ". Geometry discarded.");
+		var msg = "SRS mismatch. Geometry is in " + geom.get(0).getEpsg() +
+			", map is in " + mb_mapObj[mapIndex].epsg + ".";
+		proceed = confirm(msg + " Proceed?");
+	if (!proceed) {
 		return;
 	try {
@@ -613,11 +645,16 @@
 function appendGeometryToDigitize(i){
 	if (geomArray.get(i).getEpsg() !== mb_mapObj[mapIndex].epsg) {
+	if (!proceed) {
 		return;
 	var digitizeArray = new GeometryArray();
 	digitizeArray.addCopy(geomArray.get(i));
 	try {
@@ -720,13 +757,4 @@
 		wfsPopup = new mb_popup(detailPopupTitle,resultHtml,detailPopupWidth,detailPopupHeight,detailPopupX,detailPopupY);
 	wfsPopup.show();
-try{
-	if (wfsResultToPopupDiv){}
-catch(e){
-	wfsResultToPopupDiv =0;
-if(wfsResultToPopupDiv==1){
-	mb_registerWfsReadSubFunctions(function(geom){displayPopup(geom);});
Modified: trunk/mapbender/http/javascripts/ovnf.php
--- trunk/mapbender/http/javascripts/ovnf.php	2009-03-06 15:40:30 UTC (rev 3643)
+++ trunk/mapbender/http/javascripts/ovnf.php	2009-03-06 16:00:41 UTC (rev 3644)
@@ -24,7 +24,7 @@
 if (typeof(overview_wms) === 'undefined')overview_wms = 0;
 overview_wms = parseInt(overview_wms);
-mb_registerMapObj('', 'overview', overview_wms ,150, 150);
+mb_registerMapObj('', 'overview', overview_wms ,<?php echo $e_width; ?>, <?php echo $e_height; ?>);
 parent.eventInitMap.register(function init_overview(){
 		var ind = getMapObjIndexByName('overview');
More information about the Mapbender_commits mailing list
