[Mapbender-commits] r3649 - in branches/print_dev/http: extensions img img/button_digitize javascripts php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Mar 9 05:08:08 EDT 2009
Author: mschulz
Date: 2009-03-09 05:08:08 -0400 (Mon, 09 Mar 2009)
New Revision: 3649
Added:
   branches/print_dev/http/extensions/DifferenceEngine.php
   branches/print_dev/http/img/asc.gif
   branches/print_dev/http/img/bg.gif
   branches/print_dev/http/img/button_digitize/punchPolygon_off.png
   branches/print_dev/http/img/button_digitize/punchPolygon_on.png
   branches/print_dev/http/img/button_digitize/punchPolygon_over.png
   branches/print_dev/http/img/desc.gif
   branches/print_dev/http/img/digitize.png
   branches/print_dev/http/img/map.png
   branches/print_dev/http/javascripts/mod_tooltip.php
   branches/print_dev/http/javascripts/wfsFilter.js
   branches/print_dev/http/php/mod_category_filteredGUI.php
   branches/print_dev/http/php/mod_createCategory.php
merged from trunk
Added: branches/print_dev/http/extensions/DifferenceEngine.php
--- branches/print_dev/http/extensions/DifferenceEngine.php	                        (rev 0)
+++ branches/print_dev/http/extensions/DifferenceEngine.php	2009-03-09 09:08:08 UTC (rev 3649)
@@ -0,0 +1,1062 @@
+<?php
+ * A PHP diff engine for phpwiki. (Taken from phpwiki-1.3.3)
+ * Additions by Axel Boldt for MediaWiki
+ * @copyright (C) 2000, 2001 Geoffrey T. Dairiki <dairiki at dairiki.org>
+ * @license  You may copy this code freely under the conditions of the GPL.
+define('USE_ASSERTS', function_exists('assert'));
+class _DiffOp {
+  var $type;
+  var $orig;
+  var $closing;
+  function reverse() {
+    trigger_error("pure virtual", E_USER_ERROR);
+  function norig() {
+    return $this->orig ? sizeof($this->orig) : 0;
+  function nclosing() {
+    return $this->closing ? sizeof($this->closing) : 0;
+class _DiffOp_Copy extends _DiffOp {
+  var $type = 'copy';
+  function _DiffOp_Copy ($orig, $closing = false) {
+    if (!is_array($closing))
+      $closing = $orig;
+    $this->orig = $orig;
+    $this->closing = $closing;
+    return new _DiffOp_Copy($this->closing, $this->orig);
+class _DiffOp_Delete extends _DiffOp {
+  var $type = 'delete';
+  function _DiffOp_Delete ($lines) {
+    $this->orig = $lines;
+    $this->closing = false;
+    return new _DiffOp_Add($this->orig);
+class _DiffOp_Add extends _DiffOp {
+  var $type = 'add';
+  function _DiffOp_Add ($lines) {
+    $this->closing = $lines;
+    $this->orig = false;
+    return new _DiffOp_Delete($this->closing);
+class _DiffOp_Change extends _DiffOp {
+  var $type = 'change';
+  function _DiffOp_Change ($orig, $closing) {
+    return new _DiffOp_Change($this->closing, $this->orig);
+ * Class used internally by Diff to actually compute the diffs.
+ * The algorithm used here is mostly lifted from the perl module
+ * Algorithm::Diff (version 1.06) by Ned Konz, which is available at:
+ *   http://www.perl.com/CPAN/authors/id/N/NE/NEDKONZ/Algorithm-Diff-1.06.zip
+ * More ideas are taken from:
+ *   http://www.ics.uci.edu/~eppstein/161/960229.html
+ * Some ideas are (and a bit of code) are from from analyze.c, from GNU
+ * diffutils-2.7, which can be found at:
+ *   ftp://gnudist.gnu.org/pub/gnu/diffutils/diffutils-2.7.tar.gz
+ * closingly, some ideas (subdivision by NCHUNKS > 2, and some optimizations)
+ * are my own.
+ * @author Geoffrey T. Dairiki
+ * @access private
+class _DiffEngine
+  function diff ($from_lines, $to_lines) {
+    $n_from = sizeof($from_lines);
+    $n_to = sizeof($to_lines);
+    $this->xchanged = $this->ychanged = array();
+    $this->xv = $this->yv = array();
+    $this->xind = $this->yind = array();
+    unset($this->seq);
+    unset($this->in_seq);
+    unset($this->lcs);
+    // Skip leading common lines.
+    for ($skip = 0; $skip < $n_from && $skip < $n_to; $skip++) {
+      if ($from_lines[$skip] != $to_lines[$skip])
+        break;
+      $this->xchanged[$skip] = $this->ychanged[$skip] = false;
+    // Skip trailing common lines.
+    $xi = $n_from; $yi = $n_to;
+    for ($endskip = 0; --$xi > $skip && --$yi > $skip; $endskip++) {
+      if ($from_lines[$xi] != $to_lines[$yi])
+        break;
+      $this->xchanged[$xi] = $this->ychanged[$yi] = false;
+    // Ignore lines which do not exist in both files.
+    for ($xi = $skip; $xi < $n_from - $endskip; $xi++)
+      $xhash[$from_lines[$xi]] = 1;
+    for ($yi = $skip; $yi < $n_to - $endskip; $yi++) {
+      $line = $to_lines[$yi];
+      if ( ($this->ychanged[$yi] = empty($xhash[$line])) )
+        continue;
+      $yhash[$line] = 1;
+      $this->yv[] = $line;
+      $this->yind[] = $yi;
+    for ($xi = $skip; $xi < $n_from - $endskip; $xi++) {
+      $line = $from_lines[$xi];
+      if ( ($this->xchanged[$xi] = empty($yhash[$line])) )
+        continue;
+      $this->xv[] = $line;
+      $this->xind[] = $xi;
+    // Find the LCS.
+    $this->_compareseq(0, sizeof($this->xv), 0, sizeof($this->yv));
+    // Merge edits when possible
+    $this->_shift_boundaries($from_lines, $this->xchanged, $this->ychanged);
+    $this->_shift_boundaries($to_lines, $this->ychanged, $this->xchanged);
+    // Compute the edit operations.
+    $edits = array();
+    $xi = $yi = 0;
+    while ($xi < $n_from || $yi < $n_to) {
+      USE_ASSERTS && assert($yi < $n_to || $this->xchanged[$xi]);
+      USE_ASSERTS && assert($xi < $n_from || $this->ychanged[$yi]);
+      // Skip matching "snake".
+      $copy = array();
+      while ( $xi < $n_from && $yi < $n_to
+          && !$this->xchanged[$xi] && !$this->ychanged[$yi]) {
+        $copy[] = $from_lines[$xi++];
+        ++$yi;
+      if ($copy)
+        $edits[] = new _DiffOp_Copy($copy);
+      // Find deletes & adds.
+      $delete = array();
+      while ($xi < $n_from && $this->xchanged[$xi])
+        $delete[] = $from_lines[$xi++];
+      $add = array();
+      while ($yi < $n_to && $this->ychanged[$yi])
+        $add[] = $to_lines[$yi++];
+      if ($delete && $add)
+        $edits[] = new _DiffOp_Change($delete, $add);
+      elseif ($delete)
+        $edits[] = new _DiffOp_Delete($delete);
+      elseif ($add)
+        $edits[] = new _DiffOp_Add($add);
+    return $edits;
+   * Divide the Largest Common Subsequence (LCS) of the sequences
+   * [XOFF, XLIM) and [YOFF, YLIM) into NCHUNKS approximately equally
+   * sized segments.
+   * Returns (LCS, PTS).  LCS is the length of the LCS. PTS is an
+   * array of NCHUNKS+1 (X, Y) indexes giving the diving points between
+   * sub sequences.  The first sub-sequence is contained in [X0, X1),
+   * [Y0, Y1), the second in [X1, X2), [Y1, Y2) and so on.  Note
+   * that (X0, Y0) == (XOFF, YOFF) and
+   * (X[NCHUNKS], Y[NCHUNKS]) == (XLIM, YLIM).
+   * This function assumes that the first lines of the specified portions
+   * of the two files do not match, and likewise that the last lines do not
+   * match.  The caller must trim matching lines from the beginning and end
+   * of the portions it is going to specify.
+  function _diag ($xoff, $xlim, $yoff, $ylim, $nchunks) {
+  $flip = false;
+  if ($xlim - $xoff > $ylim - $yoff) {
+    // Things seems faster (I'm not sure I understand why)
+      // when the shortest sequence in X.
+      $flip = true;
+    list ($xoff, $xlim, $yoff, $ylim)
+    = array( $yoff, $ylim, $xoff, $xlim);
+  if ($flip)
+    for ($i = $ylim - 1; $i >= $yoff; $i--)
+    $ymatches[$this->xv[$i]][] = $i;
+  else
+    $ymatches[$this->yv[$i]][] = $i;
+  $this->lcs = 0;
+  $this->seq[0]= $yoff - 1;
+  $this->in_seq = array();
+  $ymids[0] = array();
+  $numer = $xlim - $xoff + $nchunks - 1;
+  $x = $xoff;
+  for ($chunk = 0; $chunk < $nchunks; $chunk++) {
+    if ($chunk > 0)
+    for ($i = 0; $i <= $this->lcs; $i++)
+      $ymids[$i][$chunk-1] = $this->seq[$i];
+    $x1 = $xoff + (int)(($numer + ($xlim-$xoff)*$chunk) / $nchunks);
+    for ( ; $x < $x1; $x++) {
+        $line = $flip ? $this->yv[$x] : $this->xv[$x];
+        if (empty($ymatches[$line]))
+      continue;
+    $matches = $ymatches[$line];
+        reset($matches);
+    while (list ($junk, $y) = each($matches))
+      if (empty($this->in_seq[$y])) {
+      $k = $this->_lcs_pos($y);
+      USE_ASSERTS && assert($k > 0);
+      $ymids[$k] = $ymids[$k-1];
+      break;
+    while (list ($junk, $y) = each($matches)) {
+      if ($y > $this->seq[$k-1]) {
+      USE_ASSERTS && assert($y < $this->seq[$k]);
+      // Optimization: this is a common case:
+      //  next match is just replacing previous match.
+      $this->in_seq[$this->seq[$k]] = false;
+      $this->seq[$k] = $y;
+      $this->in_seq[$y] = 1;
+      else if (empty($this->in_seq[$y])) {
+  $seps[] = $flip ? array($yoff, $xoff) : array($xoff, $yoff);
+  $ymid = $ymids[$this->lcs];
+  for ($n = 0; $n < $nchunks - 1; $n++) {
+    $x1 = $xoff + (int)(($numer + ($xlim - $xoff) * $n) / $nchunks);
+    $y1 = $ymid[$n] + 1;
+    $seps[] = $flip ? array($y1, $x1) : array($x1, $y1);
+  $seps[] = $flip ? array($ylim, $xlim) : array($xlim, $ylim);
+  return array($this->lcs, $seps);
+  function _lcs_pos ($ypos) {
+  $end = $this->lcs;
+  if ($end == 0 || $ypos > $this->seq[$end]) {
+    $this->seq[++$this->lcs] = $ypos;
+    $this->in_seq[$ypos] = 1;
+    return $this->lcs;
+  $beg = 1;
+  while ($beg < $end) {
+    $mid = (int)(($beg + $end) / 2);
+    if ( $ypos > $this->seq[$mid] )
+    $beg = $mid + 1;
+    else
+    $end = $mid;
+  USE_ASSERTS && assert($ypos != $this->seq[$end]);
+  $this->in_seq[$this->seq[$end]] = false;
+  $this->seq[$end] = $ypos;
+  return $end;
+   * Find LCS of two sequences.
+   * The results are recorded in the vectors $this->{x,y}changed[], by
+   * storing a 1 in the element for each line that is an insertion
+   * or deletion (ie. is not in the LCS).
+   * The subsequence of file 0 is [XOFF, XLIM) and likewise for file 1.
+   * Note that XLIM, YLIM are exclusive bounds.
+   * All line numbers are origin-0 and discarded lines are not counted.
+  function _compareseq ($xoff, $xlim, $yoff, $ylim) {
+  // Slide down the bottom initial diagonal.
+  while ($xoff < $xlim && $yoff < $ylim
+         && $this->xv[$xoff] == $this->yv[$yoff]) {
+    ++$xoff;
+    ++$yoff;
+  // Slide up the top initial diagonal.
+  while ($xlim > $xoff && $ylim > $yoff
+         && $this->xv[$xlim - 1] == $this->yv[$ylim - 1]) {
+    --$xlim;
+    --$ylim;
+  if ($xoff == $xlim || $yoff == $ylim)
+    $lcs = 0;
+  else {
+    // This is ad hoc but seems to work well.
+    //$nchunks = sqrt(min($xlim - $xoff, $ylim - $yoff) / 2.5);
+    //$nchunks = max(2,min(8,(int)$nchunks));
+    $nchunks = min(7, $xlim - $xoff, $ylim - $yoff) + 1;
+    list ($lcs, $seps)
+    = $this->_diag($xoff,$xlim,$yoff, $ylim,$nchunks);
+  if ($lcs == 0) {
+    // X and Y sequences have no common subsequence:
+    // mark all changed.
+    while ($yoff < $ylim)
+    $this->ychanged[$this->yind[$yoff++]] = 1;
+    while ($xoff < $xlim)
+    $this->xchanged[$this->xind[$xoff++]] = 1;
+  else {
+    // Use the partitions to split this problem into subproblems.
+    reset($seps);
+    $pt1 = $seps[0];
+    while ($pt2 = next($seps)) {
+    $this->_compareseq ($pt1[0], $pt2[0], $pt1[1], $pt2[1]);
+    $pt1 = $pt2;
+   * Adjust inserts/deletes of identical lines to join changes
+   * as much as possible.
+   * We do something when a run of changed lines include a
+   * line at one end and has an excluded, identical line at the other.
+   * We are free to choose which identical line is included.
+   * `compareseq' usually chooses the one at the beginning,
+   * but usually it is cleaner to consider the following identical line
+   * to be the "change".
+   * This is extracted verbatim from analyze.c (GNU diffutils-2.7).
+  function _shift_boundaries ($lines, &$changed, $other_changed) {
+  $i = 0;
+  $j = 0;
+  USE_ASSERTS && assert('sizeof($lines) == sizeof($changed)');
+  $len = sizeof($lines);
+  $other_len = sizeof($other_changed);
+  while (1) {
+     * Scan forwards to find beginning of another run of changes.
+     * Also keep track of the corresponding point in the other file.
+     * Throughout this code, $i and $j are adjusted together so that
+     * the first $i elements of $changed and the first $j elements
+     * of $other_changed both contain the same number of zeros
+     * (unchanged lines).
+     * Furthermore, $j is always kept so that $j == $other_len or
+     * $other_changed[$j] == false.
+    while ($j < $other_len && $other_changed[$j])
+    $j++;
+    while ($i < $len && ! $changed[$i]) {
+    USE_ASSERTS && assert('$j < $other_len && ! $other_changed[$j]');
+    $i++; $j++;
+      $j++;
+    if ($i == $len)
+    break;
+    $start = $i;
+    // Find the end of this run of changes.
+    while (++$i < $len && $changed[$i])
+    continue;
+    do {
+     * Record the length of this run of changes, so that
+     * we can later determine whether the run has grown.
+    $runlength = $i - $start;
+     * Move the changed region back, so long as the
+     * previous unchanged line matches the last changed one.
+     * This merges with previous changed regions.
+    while ($start > 0 && $lines[$start - 1] == $lines[$i - 1]) {
+      $changed[--$start] = 1;
+      $changed[--$i] = false;
+      while ($start > 0 && $changed[$start - 1])
+      $start--;
+      USE_ASSERTS && assert('$j > 0');
+      while ($other_changed[--$j])
+      continue;
+      USE_ASSERTS && assert('$j >= 0 && !$other_changed[$j]');
+     * Set CORRESPONDING to the end of the changed run, at the last
+     * point where it corresponds to a changed run in the other file.
+     * CORRESPONDING == LEN means no such point has been found.
+    $corresponding = $j < $other_len ? $i : $len;
+     * Move the changed region forward, so long as the
+     * first changed line matches the following unchanged one.
+     * This merges with following changed regions.
+     * Do this second, so that if there are no merges,
+     * the changed region is moved forward as far as possible.
+    while ($i < $len && $lines[$start] == $lines[$i]) {
+      $changed[$start++] = false;
+      $changed[$i++] = 1;
+      while ($i < $len && $changed[$i])
+      $i++;
+      $j++;
+      if ($j < $other_len && $other_changed[$j]) {
+      $corresponding = $i;
+        $j++;
+      } while ($runlength != $i - $start);
+     * If possible, move the fully-merged run of changes
+     * back to a corresponding run in the other file.
+    while ($corresponding < $i) {
+    $changed[--$i] = 0;
+      continue;
+ * Class representing a 'diff' between two sequences of strings.
+class Diff
+  var $edits;
+   * Constructor.
+   * Computes diff between sequences of strings.
+   * @param $from_lines array An array of strings.
+   *      (Typically these are lines from a file.)
+   * @param $to_lines array An array of strings.
+  function Diff($from_lines, $to_lines) {
+    $eng = new _DiffEngine;
+    $this->edits = $eng->diff($from_lines, $to_lines);
+    //$this->_check($from_lines, $to_lines);
+   * Compute reversed Diff.
+   * SYNOPSIS:
+   *  $diff = new Diff($lines1, $lines2);
+   *  $rev = $diff->reverse();
+   * @return object A Diff object representing the inverse of the
+   *          original diff.
+  function reverse () {
+  $rev = $this;
+    $rev->edits = array();
+    foreach ($this->edits as $edit) {
+      $rev->edits[] = $edit->reverse();
+  return $rev;
+   * Check for empty diff.
+   * @return bool True iff two sequences were identical.
+  function isEmpty () {
+      if ($edit->type != 'copy')
+        return false;
+    return true;
+   * Compute the length of the Longest Common Subsequence (LCS).
+   * This is mostly for diagnostic purposed.
+   * @return int The length of the LCS.
+  function lcs () {
+  $lcs = 0;
+      if ($edit->type == 'copy')
+        $lcs += sizeof($edit->orig);
+  return $lcs;
+   * Get the original set of lines.
+   * This reconstructs the $from_lines parameter passed to the
+   * constructor.
+   * @return array The original sequence of strings.
+  function orig() {
+    $lines = array();
+      if ($edit->orig)
+        array_splice($lines, sizeof($lines), 0, $edit->orig);
+    return $lines;
+   * Get the closing set of lines.
+   * This reconstructs the $to_lines parameter passed to the
+   * constructor.
+   * @return array The sequence of strings.
+  function closing() {
+    $lines = array();
+      if ($edit->closing)
+        array_splice($lines, sizeof($lines), 0, $edit->closing);
+    return $lines;
+   * Check a Diff for validity.
+   * This is here only for debugging purposes.
+  function _check ($from_lines, $to_lines) {
+    if (serialize($from_lines) != serialize($this->orig()))
+      trigger_error("Reconstructed original doesn't match", E_USER_ERROR);
+    if (serialize($to_lines) != serialize($this->closing()))
+      trigger_error("Reconstructed closing doesn't match", E_USER_ERROR);
+    $rev = $this->reverse();
+    if (serialize($to_lines) != serialize($rev->orig()))
+      trigger_error("Reversed original doesn't match", E_USER_ERROR);
+    if (serialize($from_lines) != serialize($rev->closing()))
+      trigger_error("Reversed closing doesn't match", E_USER_ERROR);
+    $prevtype = 'none';
+      if ( $prevtype == $edit->type )
+        trigger_error("Edit sequence is non-optimal", E_USER_ERROR);
+      $prevtype = $edit->type;
+    $lcs = $this->lcs();
+    trigger_error("Diff okay: LCS = $lcs", E_USER_NOTICE);
+ * FIXME: bad name.
+class MappedDiff
+extends Diff
+   * Constructor.
+   * This can be used to compute things like
+   * case-insensitve diffs, or diffs which ignore
+   * changes in white-space.
+   * @param $mapped_from_lines array This array should
+   *  have the same size number of elements as $from_lines.
+   *  The elements in $mapped_from_lines and
+   *  $mapped_to_lines are what is actually compared
+   *  when computing the diff.
+   * @param $mapped_to_lines array This array should
+   *  have the same number of elements as $to_lines.
+  function MappedDiff($from_lines, $to_lines,
+            $mapped_from_lines, $mapped_to_lines) {
+    assert(sizeof($from_lines) == sizeof($mapped_from_lines));
+    assert(sizeof($to_lines) == sizeof($mapped_to_lines));
+    $this->Diff($mapped_from_lines, $mapped_to_lines);
+    $xi = $yi = 0;
+    for ($i = 0; $i < sizeof($this->edits); $i++) {
+      $orig = &$this->edits[$i]->orig;
+      if (is_array($orig)) {
+        $orig = array_slice($from_lines, $xi, sizeof($orig));
+        $xi += sizeof($orig);
+      $closing = &$this->edits[$i]->closing;
+      if (is_array($closing)) {
+        $closing = array_slice($to_lines, $yi, sizeof($closing));
+        $yi += sizeof($closing);
+ * A class to format Diffs
+ * This class formats the diff in classic diff format.
+ * It is intended that this class be customized via inheritance,
+ * to obtain fancier outputs.
+class DiffFormatter
+   * Number of leading context "lines" to preserve.
+   * This should be left at zero for this class, but subclasses
+   * may want to set this to other values.
+  var $leading_context_lines = 0;
+   * Number of trailing context "lines" to preserve.
+  var $trailing_context_lines = 0;
+   * Format a diff.
+   * @param $diff object A Diff object.
+   * @return string The formatted output.
+  function format($diff) {
+    $xi = $yi = 1;
+    $block = false;
+    $context = array();
+    $nlead = $this->leading_context_lines;
+    $ntrail = $this->trailing_context_lines;
+    $this->_start_diff();
+    foreach ($diff->edits as $edit) {
+      if ($edit->type == 'copy') {
+        if (is_array($block)) {
+          if (sizeof($edit->orig) <= $nlead + $ntrail) {
+            $block[] = $edit;
+          else{
+            if ($ntrail) {
+              $context = array_slice($edit->orig, 0, $ntrail);
+              $block[] = new _DiffOp_Copy($context);
+            $this->_block($x0, $ntrail + $xi - $x0,
+                    $y0, $ntrail + $yi - $y0,
+                    $block);
+            $block = false;
+        $context = $edit->orig;
+      else {
+        if (! is_array($block)) {
+          $context = array_slice($context, sizeof($context) - $nlead);
+          $x0 = $xi - sizeof($context);
+          $y0 = $yi - sizeof($context);
+          $block = array();
+          if ($context)
+        $block[] = $edit;
+      if ($edit->orig)
+        $xi += sizeof($edit->orig);
+        $yi += sizeof($edit->closing);
+      $this->_block($x0, $xi - $x0,
+              $y0, $yi - $y0,
+              $block);
+    return $this->_end_diff();
+  function _block($xbeg, $xlen, $ybeg, $ylen, &$edits) {
+    $this->_start_block($this->_block_header($xbeg, $xlen, $ybeg, $ylen));
+    foreach ($edits as $edit) {
+        $this->_context($edit->orig);
+      elseif ($edit->type == 'add')
+        $this->_added($edit->closing);
+      elseif ($edit->type == 'delete')
+        $this->_deleted($edit->orig);
+      elseif ($edit->type == 'change')
+        $this->_changed($edit->orig, $edit->closing);
+      else
+        trigger_error("Unknown edit type", E_USER_ERROR);
+    $this->_end_block();
+  function _start_diff() {
+    ob_start();
+  function _end_diff() {
+    $val = ob_get_contents();
+    ob_end_clean();
+    return $val;
+  function _block_header($xbeg, $xlen, $ybeg, $ylen) {
+    if ($xlen > 1)
+      $xbeg .= "," . ($xbeg + $xlen - 1);
+    if ($ylen > 1)
+      $ybeg .= "," . ($ybeg + $ylen - 1);
+    return $xbeg . ($xlen ? ($ylen ? 'c' : 'd') : 'a') . $ybeg;
+  function _start_block($header) {
+    echo $header;
+  function _end_block() {
+  function _lines($lines, $prefix = ' ') {
+    foreach ($lines as $line)
+      echo "$prefix $line\n";
+  function _context($lines) {
+    $this->_lines($lines);
+  function _added($lines) {
+    $this->_lines($lines, ">");
+  function _deleted($lines) {
+    $this->_lines($lines, "<");
+  function _changed($orig, $closing) {
+    $this->_deleted($orig);
+    echo "---\n";
+    $this->_added($closing);
+ *  Additions by Axel Boldt follow, partly taken from diff.php, phpwiki-1.3.3
+define('NBSP', "\xC2\xA0");     // utf-8 non-breaking space.
+class _HWLDF_WordAccumulator {
+  function _HWLDF_WordAccumulator () {
+    $this->_lines = array();
+    $this->_line = '';
+    $this->_group = '';
+    $this->_tag = '';
+  function _flushGroup ($new_tag) {
+    if ($this->_group !== '') {
+    if ($this->_tag == 'mark')
+      $this->_line .= '<strong>'.$this->_group.'</strong>';
+    else
+    $this->_line .= $this->_group;
+    $this->_tag = $new_tag;
+  function _flushLine ($new_tag) {
+    $this->_flushGroup($new_tag);
+    if ($this->_line != '')
+      $this->_lines[] = $this->_line;
+  function addWords ($words, $tag = '') {
+    if ($tag != $this->_tag)
+      $this->_flushGroup($tag);
+    foreach ($words as $word) {
+      // new-line should only come as first char of word.
+      if ($word == '')
+        continue;
+      if ($word[0] == "\n") {
+        $this->_group .= NBSP;
+        $this->_flushLine($tag);
+        $word = substr($word, 1);
+      assert(!strstr($word, "\n"));
+      $this->_group .= $word;
+  function getLines() {
+    $this->_flushLine('~done');
+    return $this->_lines;
+class WordLevelDiff extends MappedDiff
+  function WordLevelDiff ($orig_lines, $closing_lines) {
+    list ($orig_words, $orig_stripped) = $this->_split($orig_lines);
+    list ($closing_words, $closing_stripped) = $this->_split($closing_lines);
+    $this->MappedDiff($orig_words, $closing_words,
+              $orig_stripped, $closing_stripped);
+  function _split($lines) {
+    // FIXME: fix POSIX char class.
+#    if (!preg_match_all('/ ( [^\S\n]+ | [[:alnum:]]+ | . ) (?: (?!< \n) [^\S\n])? /xs',
+    if (!preg_match_all('/ ( [^\S\n]+ | [0-9_A-Za-z\x80-\xff]+ | . ) (?: (?!< \n) [^\S\n])? /xs',
+              implode("\n", $lines),
+              $m)) {
+      return array(array(''), array(''));
+    return array($m[0], $m[1]);
+  function orig () {
+    $orig = new _HWLDF_WordAccumulator;
+        $orig->addWords($edit->orig);
+      elseif ($edit->orig)
+        $orig->addWords($edit->orig, 'mark');
+    return $orig->getLines();
+  function closing () {
+    $closing = new _HWLDF_WordAccumulator;
+        $closing->addWords($edit->closing);
+      elseif ($edit->closing)
+        $closing->addWords($edit->closing, 'mark');
+    return $closing->getLines();
+ * "Unified" diff formatter.
+ * This class formats the diff in classic "unified diff" format.
+class UnifiedDiffFormatter extends DiffFormatter
+    function UnifiedDiffFormatter($context_lines = 4) {
+        $this->leading_context_lines = $context_lines;
+        $this->trailing_context_lines = $context_lines;
+        if ($xlen != 1)
+            $xbeg .= "," . $xlen;
+        if ($ylen != 1)
+            $ybeg .= "," . $ylen;
+        return "@@ -$xbeg +$ybeg @@\n";
+        $this->_lines($lines, "+");
+        $this->_lines($lines, "-");
+    function _changed($orig, $final) {
+        $this->_added($final);
+ *  Wikipedia Table style diff formatter.
+class TableDiffFormatter extends DiffFormatter
+  function TableDiffFormatter() {
+    $this->leading_context_lines = 2;
+    $this->trailing_context_lines = 2;
+  function _pre($text){
+    $text = htmlspecialchars($text);
+    $text = str_replace('  ',' &nbsp;',$text);
+    return $text;
+  function _block_header( $xbeg, $xlen, $ybeg, $ylen ) {
+    global $lang;
+    $l1 = $lang['line'].' '.$xbeg;
+    $l2 = $lang['line'].' '.$ybeg;
+    $r = '<tr><td class="diff-blockheader" colspan="2">'.$l1.":</td>\n" .
+      '<td class="diff-blockheader" colspan="2">'.$l2.":</td></tr>\n";
+    return $r;
+  function _start_block( $header ) {
+    print( $header );
+  function _lines( $lines, $prefix=' ', $color="white" ) {
+  function addedLine( $line ) {
+    $line = str_replace('  ','&nbsp; ',$line);
+    return '<td>+</td><td class="diff-addedline">' .
+      $line.'</td>';
+  function deletedLine( $line ) {
+    return '<td>-</td><td class="diff-deletedline">' .
+      $line.'</td>';
+  function emptyLine() {
+    //$line = str_replace('  ','&nbsp; ',$line);
+    return '<td colspan="2">&nbsp;</td>';
+  function contextLine( $line ) {
+    return '<td> </td><td class="diff-context">'.$line.'</td>';
+    foreach ($lines as $line) {
+      print( '<tr>' . $this->emptyLine() .
+        $this->addedLine( $line ) . "</tr>\n" );
+      print( '<tr>' . $this->deletedLine( $line ) .
+        $this->emptyLine() . "</tr>\n" );
+  function _context( $lines ) {
+      print( '<tr>' . $this->contextLine( $line ) .
+        $this->contextLine( $line ) . "</tr>\n" );
+  function _changed( $orig, $closing ) {
+    $diff = new WordLevelDiff( $orig, $closing );
+    $del = $diff->orig();
+    $add = $diff->closing();
+    while ( $line = array_shift( $del ) ) {
+      $aline = array_shift( $add );
+        $this->addedLine( $aline ) . "</tr>\n" );
+    $this->_added( $add ); # If any leftovers
+//Setup VIM: ex: et ts=2 enc=utf-8 :
Added: branches/print_dev/http/img/asc.gif
(Binary files differ)
Property changes on: branches/print_dev/http/img/asc.gif
___________________________________________________________________
   + application/octet-stream
Added: branches/print_dev/http/img/bg.gif
Property changes on: branches/print_dev/http/img/bg.gif
Added: branches/print_dev/http/img/button_digitize/punchPolygon_off.png
Property changes on: branches/print_dev/http/img/button_digitize/punchPolygon_off.png
Added: branches/print_dev/http/img/button_digitize/punchPolygon_on.png
Property changes on: branches/print_dev/http/img/button_digitize/punchPolygon_on.png
Added: branches/print_dev/http/img/button_digitize/punchPolygon_over.png
Property changes on: branches/print_dev/http/img/button_digitize/punchPolygon_over.png
Added: branches/print_dev/http/img/desc.gif
Property changes on: branches/print_dev/http/img/desc.gif
Added: branches/print_dev/http/img/digitize.png
Property changes on: branches/print_dev/http/img/digitize.png
Added: branches/print_dev/http/img/map.png
Property changes on: branches/print_dev/http/img/map.png
Added: branches/print_dev/http/javascripts/mod_tooltip.php
--- branches/print_dev/http/javascripts/mod_tooltip.php	                        (rev 0)
+++ branches/print_dev/http/javascripts/mod_tooltip.php	2009-03-09 09:08:08 UTC (rev 3649)
@@ -0,0 +1,367 @@
+<?php
+# $Id: mod_toggleModule.php 2238 2008-03-13 14:24:56Z christoph $
+# http://www.mapbender.org/index.php/mod_toggleModule.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+$wfs_conf_filename = "wfs_default.conf";
+include '../include/dyn_php.php';
+$fname = dirname(__FILE__) . "/../../conf/" . $wfs_conf_filename;
+if (file_exists($fname)) {
+	include($fname);
+else {
+	$e = new mb_exception("tooltip.php: Configuration file " . $wfs_conf_filename . " not found.");
+echo "var tooltipTarget ='".$e_target[0]."';";
+include '../include/dyn_js.php';
+//tolerance when we ask wfs
+var mb_wfs_tolerance = 8;
+//initialize Element Vars
+//destination frame for the request (creates Popup if empty)
+if(typeof(tooltip_destinationFrame)==='undefined')
+	var tooltip_destinationFrame = "";
+if(typeof(tooltip_timeDelay)==='undefined')
+	var tooltip_timeDelay = 1000;
+if(typeof(tooltip_styles)==='undefined')
+	var tooltip_styles = "";
+if(typeof(tooltip_width)==='undefined')
+	var tooltip_width = 270;
+if(typeof(tooltip_height)==='undefined')
+	var tooltip_height = 200;
+if(typeof(tooltip_styles_detail)==='undefined')
+	var tooltip_styles_detail = "";
+try{
+	var no_result_text = eval(tooltip_noResultArray);
+}catch(e){
+	var no_result_text = ["Kein Ergebnis.",'<body onLoad="javascript:window.close()">'];
+var mouseMoves=0;
+var tooltipWin=null;
+var point;
+var tooltipWfsRequestCount = 0;
+var tooltipWmsRequestCount = 0;
+var numberOfFinishedWfsRequests = 0;
+var numberOfFinishedWmsRequests = 0;
+var visibleRequest = 0;
+var TooltipMsg = {'title':"<?php echo _mb("Information");?>"};
+//buttonWfs_toDigitize_on ="0";
+function mod_tooltipInit(){
+var tooltip_map = getMapObjByName(tooltipTarget);
+var ind = getMapObjIndexByName(tooltipTarget);
+var myMapObj = mb_mapObj[ind];
+var map_el = myMapObj.getDomElement();
+	$(map_el.ownerDocument).mousemove(function(event){
+		var point = tooltip_map.getMousePos(event);
+		//mb_getMousePos(event,myMapObj.getMousePosition(event));
+		mod_tooltip_run();
+	}).mouseout(function(){mouseMoves=0;});
+eventInit.register(mod_tooltipInit);
+function mod_tooltip_run(){
+	mouseMoves++;
+	setTimeout("if(mouseMoves=="+mouseMoves+"&&clickX=="+clickX+"&&clickY=="+clickY+")fireRequests();",tooltip_timeDelay);
+function fireRequests(){
+	var ind = getMapObjIndexByName(tooltipTarget);
+	point = new Point(clickX,clickY);
+	var point_geom = new Geometry(geomType.point);
+	point_geom.addPoint(mapToReal(tooltipTarget,point));
+	visibleRequest = 0;
+	//FeatureInfo requests
+	urls = mb_mapObj[ind].getFeatureInfoRequests(point);
+	tooltipWmsRequestCount = urls.length;
+	numberOfFinishedWmsRequests	= 0;
+	for(var j=0;j < urls.length;j++){
+		mb_ajax_post("../extensions/ext_featureInfoTunnel.php", {url:urls[j]},
+			checkFeatureInfoResults);
+	//WFS requests
+	requests = getWfsRequests(tooltipTarget, point_geom, true);
+	tooltipWfsRequestCount = requests.length;
+	numberOfFinishedWfsRequests = 0;
+	resultGeomArray = new GeometryArray();
+	for(var j=0;j< requests.length;j++){
+		mb_ajax_post("../" + wfsResultModulePath + wfsResultModuleFilename,requests[j],function(js_code,status){
+			if (js_code) {
+				eval(js_code);
+			if (typeof(geom) == "undefined") {
+				var geom = new GeometryArray();
+			checkWfsResultsFinished(geom);
+function checkFeatureInfoResults(js_code,status){
+	numberOfFinishedWmsRequests++;
+	//check if there are results
+	if(js_code == ""){
+		if(!isFirstResult())
+			displayResultDoc("");
+		return;
+	for(var k=0;k < no_result_text.length;k++){
+		if(js_code.indexOf(no_result_text[k])!==-1){
+			return;
+	//output code
+	displayResultDoc(js_code);
+function checkWfsResultsFinished(g){
+	//check if all wfs requests arrived
+	numberOfFinishedWfsRequests++;
+	if (typeof(g) == 'object'){
+		resultGeomArray.union(g);
+	if (numberOfFinishedWfsRequests == tooltipWfsRequestCount) {
+		if(resultGeomArray.count()>0){
+			//generate and output result
+			if(resultGeomArray.count()>1)
+				var html = createSimpleWfsResultHtml(resultGeomArray);
+			else
+				var html = createDetailedWfsResultHtml(resultGeomArray);
+			displayResultDoc(html);
+		else if(!isFirstResult())
+function isFirstResult(){
+	return visibleRequest == 0;
+function isLastResult(){
+	return (numberOfFinishedWfsRequests == tooltipWfsRequestCount && numberOfFinishedWmsRequests == tooltipWmsRequestCount);
+function displayResultDoc(html){
+	//test if we have a fixed destination and create popup otherwise
+	if(tooltip_destinationFrame=="")
+		return showBalloonFrame(html);
+	//put the frame there
+	$("#"+tooltip_destinationFrame).each(function(){
+	    var oDoc = this.contentWindow || this.contentDocument;
+	    if (oDoc.document) {
+	        oDoc = oDoc.document;
+		if(isFirstResult())
+	  		oDoc.open();
+		oDoc.write(html);
+		if(isLastResult())
+			oDoc.close();
+	visibleRequest++;
+function showBalloonFrame(html){
+	if(isFirstResult()){
+		//claculate Position
+		x=point.x+parseInt(document.getElementById(tooltipTarget).style.left);
+		y=point.y+parseInt(document.getElementById(tooltipTarget).style.top);
+		//hide old Popup
+		if(tooltipWin&&tooltipWin.isVisible())
+			tooltipWin.destroy();
+		//create Popup and append document
+		tooltipWin = new mb_popup({html:'<iframe id="tooltipWin" name="tooltipWin" src="about:blank"/>',title:TooltipMsg.title,width:tooltip_width,height:tooltip_height,balloon:true,left:x,top:y});
+		//open document
+		tooltipWin.open();
+	tooltipWin.write(html);
+	if(isLastResult()){
+		tooltipWin.close();
+	//finally display popup
+	tooltipWin.show();
+function getWfsRequests(target, geom, checkscale, filteroption){
+	//get all configurations
+	wfs_config = get_complete_wfs_conf();
+	var ind = getMapObjIndexByName(target);
+	var db_wfs_conf_id = [];
+	var js_wfs_conf_id = [];
+	//search configurations that are selected (and in scale)
+	for (var i=0; i < mb_mapObj[ind].wms.length; i++){
+		for(var ii=0; ii < mb_mapObj[ind].wms[i].objLayer.length; ii++){
+			var o = mb_mapObj[ind].wms[i].objLayer[ii];
+			if(o.gui_layer_wfs_featuretype != '' && o.gui_layer_querylayer == '1'){
+				if(!checkscale || o.checkScale(mb_mapObj[ind]))
+					db_wfs_conf_id[db_wfs_conf_id.length] = o.gui_layer_wfs_featuretype;
+	for(var i=0; i < db_wfs_conf_id.length; i++){
+		for(var ii=0; ii < wfs_config.length; ii++){
+			if(wfs_config[ii]['wfs_conf_id'] == db_wfs_conf_id[i]){
+				js_wfs_conf_id[js_wfs_conf_id.length] = ii;
+				break;
+	//build requests
+	var requests = [];
+	for(var i=0;i < js_wfs_conf_id.length; i++){
+		//build url
+		var url = wfs_config[js_wfs_conf_id[i]]['wfs_getfeature'];
+		url += mb_getConjunctionCharacter(wfs_config[js_wfs_conf_id[i]]['wfs_getfeature']);
+		url += "service=wfs&request=getFeature&version=1.0.0";
+		url += "&typename="+ wfs_config[js_wfs_conf_id[i]]['featuretype_name'];
+		url += "&filter=";
+		//search for geometry column
+		var geometryCol;
+		for(var j=0; j < wfs_config[js_wfs_conf_id[i]]['element'].length; j++){
+			if(wfs_config[js_wfs_conf_id[i]]['element'][j]['f_geom'] == 1){
+				geometryCol = wfs_config[js_wfs_conf_id[i]]['element'][j]['element_name'];
+		//get filter
+		var filter = new WfsFilter();
+		filter.addSpatial(geom, geometryCol, filteroption, wfs_config[js_wfs_conf_id[i]]['featuretype_srs'], target);
+		requests.push({'url':url,'filter':filter.toString(), 'typename':wfs_config[js_wfs_conf_id[i]]['featuretype_name'],'js_wfs_conf_id':js_wfs_conf_id[i], 'db_wfs_conf_id':db_wfs_conf_id[i]});
+	return requests;
+function createSimpleWfsResultHtml(_geomArray){
+	var geometryIndex = 0;
+	wfsConf = get_complete_wfs_conf();
+	var html = '<html><head><style type="text/css">';
+	html += tooltip_styles;
+	html += "</style></head><body><table>\n";
+	for (var i = 0 ; i < _geomArray.count(); i ++) {
+		if (_geomArray.get(i).get(-1).isComplete()) {
+			html += "\t<tr class='list_"+(i%2?"uneven":"even")+"'>\n\t\t<td \n";
+//			html += "\t\t\t onmouseover='mb_wfs_perform(\"over\",_geomArray.get("+i+"));' ";
+//			html += " onmouseout='mb_wfs_perform(\"out\",_geomArray.get("+i+"))' ";
+//			html += " onclick='mb_wfs_perform(\"click\",_geomArray.get("+i+"));' ";
+			var geomName = getWfsListEntry(_geomArray.get(i));
+			html += ">" + geomName +"</td>";
+			html += "\t\t</tr>\n";
+	html += "</table></body>\n";
+	return html;
+function createDetailedWfsResultHtml(_geomArray){
+	var cnt = 0;
+	html += tooltip_styles_detail;
+	var wfsConfIndex = _geomArray.get(geometryIndex).wfs_conf;
+	var currentWfsConf = wfsConf[wfsConfIndex];
+	for (var i = 0 ; i <currentWfsConf.element.length; i ++) {
+	    if(currentWfsConf.element[i].f_show_detail==1){
+	    	if( _geomArray.get(geometryIndex).e.getElementValueByName(currentWfsConf.element[i].element_name)!=false){
+				html +="<tr class='list_"+(cnt%2?"uneven":"even")+"'><td>\n";
+				html += currentWfsConf.element[i].f_label;
+				html +="</td>\n";
+				html += "<td>\n";
+				var elementVal = _geomArray.get(geometryIndex).e.getElementValueByName(currentWfsConf.element[i].element_name);
+				if(currentWfsConf.element[i].f_form_element_html.indexOf("href")!=-1){
+					var setUrl = currentWfsConf.element[i].f_form_element_html.replace(/href\s*=\s*['|"]\s*['|"]/, "href='"+elementVal+"' target='_blank'");
+					if(setUrl.match(/><\/a>/)){
+						var newLink	=	setUrl.replace(/><\/a>/, ">"+elementVal+"</a>");
+					else{
+						var newLink = setUrl;
+					html +=  newLink;
+				else{
+					html += elementVal;
+				html += "</td></tr>\n";
+				cnt++;
+	return html;
+function getWfsListEntry (geom) {
+	wfsConfId = geom.wfs_conf;
+	wfsConf = window.frames["wfs_conf"].get_wfs_conf();
+	if (typeof(wfsConfId) == "number" && wfsConfId >=0 && wfsConfId < wfsConf.length) {
+		var resultArray = [];
+		for (var i = 0 ; i < wfsConf[wfsConfId]['element'].length ; i++) {
+			if (wfsConf[wfsConfId]['element'][i]['f_show'] == 1 && geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']) !=false) {
+				var pos = wfsConf[wfsConfId]['element'][i]['f_respos'];
+				if (typeof(resultArray[pos]) != "undefined") {
+					resultArray[pos] += " " + geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']);
+				else {
+					resultArray[pos] = geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']);
+		var resultName = resultArray.join(" ");
+		if (resultName == "") {
+			resultName = wfsConf[wfsConfId]['g_label'];
+		return resultName;
+	else {
+		return false;
Added: branches/print_dev/http/javascripts/wfsFilter.js
--- branches/print_dev/http/javascripts/wfsFilter.js	                        (rev 0)
+++ branches/print_dev/http/javascripts/wfsFilter.js	2009-03-09 09:08:08 UTC (rev 3649)
@@ -0,0 +1,236 @@
+function WfsFilter () {
+	this.operators = [
+			"operator":"==",
+			"wfsOpenTag":"PropertyIsEqualTo",
+			"wfsCloseTag":"PropertyIsEqualTo"
+			"operator":">=",
+			"wfsOpenTag":"PropertyIsGreaterThanOrEqualTo",
+			"wfsCloseTag":"PropertyIsGreaterThanOrEqualTo"
+			"operator":"<=",
+			"wfsOpenTag":"PropertyIsLessThanOrEqualTo",
+			"wfsCloseTag":"PropertyIsLessThanOrEqualTo"
+			"operator":">>",
+			"wfsOpenTag":"PropertyIsGreaterThan",
+			"wfsCloseTag":"PropertyIsGreaterThan"
+			"operator":"<<",
+			"wfsOpenTag":"PropertyIsLessThan",
+			"wfsCloseTag":"PropertyIsLessThan"
+			"operator":"<>",
+			"wfsOpenTag":"PropertyIsNotEqualTo",
+			"wfsCloseTag":"PropertyIsNotEqualTo"
+			"operator":"LIKE",
+			"wfsOpenTag":"PropertyIsLike wildCard='*' singleChar='.' escape='!'",
+			"wfsCloseTag":"PropertyIsLike"
+	var conditionToString = function (condition, operator){
+		var splitParam = condition.split(operator);
+		var columnName = trim(splitParam[0]);
+		var columnValue = trim(splitParam[1]);
+		if (operator == 'LIKE') {
+			columnValue = "*"+ columnValue +"*";
+		for (var i = 0 ; i < that.operators.length ; i++) {
+			if (that.operators[i].operator == operator){
+				// add condition: Property
+				var condString = '<'+that.operators[i].wfsOpenTag+'>' +
+					'<PropertyName>'+columnName+'</PropertyName>' +
+					'<Literal>'+columnValue+'</Literal>' +
+					'</'+that.operators[i].wfsCloseTag+'>';
+				// add condition: Property is not null
+					'<ogc:Not><ogc:PropertyIsNull>' +
+					'<ogc:PropertyName>'+columnName+'</ogc:PropertyName>' +
+					'</ogc:PropertyIsNull></ogc:Not>';
+				return condString;
+		return "";
+	var getOperatorFromCondition = function (aCondition) {
+		for (var j = 0; j < that.operators.length; j++) {
+			if (aCondition.match(that.operators[j].operator)) {
+				return that.operators[j].operator;
+		return false;
+	 * parse the filter from the HTML form,
+	 * @param {String} filter like "[usertype]<>3 AND [firstname]==Emil"
+	this.parse = function (filter) {
+		if (filter !== '') {
+			filter = filter.replace(/\[/g,"");
+			filter = filter.replace(/\]/g,"");
+			var condArray = filter.split(' AND ');
+			var wfsCond = [];
+			for (var i = 0 ; i < condArray.length ; i++) {
+				var currentOperator = getOperatorFromCondition(condArray[i]);
+				if (!currentOperator) {
+					return false;
+				wfsCond.push(conditionToString(condArray[i], currentOperator));
+			conditionArray = conditionArray.concat(wfsCond);
+		return true;
+	this.addSpatial = function (spatialRequestGeom, geometryColumn, filteroption, srs, target) {
+		if(typeof(spatialRequestGeom) != "undefined"){
+			var spatialRequestFilter = "";
+			if(spatialRequestGeom.geomType == geomType.polygon){
+				spatialRequestFilter += "<" + filteroption + "><ogc:PropertyName>" +
+					geometryColumn + "</ogc:PropertyName><gml:Polygon srsName=\""+srs+"\">" +
+					"<gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
+				for(var k=0; k<spatialRequestGeom.count(); k++){
+					if (k > 0) {
+						spatialRequestFilter += " ";
+					spatialRequestFilter += spatialRequestGeom.get(k).x+","+spatialRequestGeom.get(k).y;
+				spatialRequestFilter += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs>";
+				spatialRequestFilter += "</gml:Polygon></" + filteroption + ">";
+			else if(spatialRequestGeom.geomType == geomType.line){
+				var rectangle = [];
+				rectangle = spatialRequestGeom.getBBox();
+					"<gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>" +
+					rectangle[0].x+","+rectangle[0].y + " " +
+					rectangle[0].x+","+rectangle[1].y + " " +
+					rectangle[1].x+","+rectangle[1].y + " " +
+					rectangle[1].x+","+rectangle[0].y + " " +
+					"</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs>" +
+					"</gml:Polygon></" + filteroption + ">";
+			else if(spatialRequestGeom.geomType == geomType.point){
+				var tmp = spatialRequestGeom.get(0);
+				var mapPos = makeRealWorld2mapPos(target,tmp.x, tmp.y);
+				var buffer = mb_wfs_tolerance/2;
+				var realWorld1 = makeClickPos2RealWorldPos(target,mapPos[0]-buffer,mapPos[1]-buffer);
+				var realWorld2 = makeClickPos2RealWorldPos(target,mapPos[0]+buffer,mapPos[1]-buffer);
+				var realWorld3 = makeClickPos2RealWorldPos(target,mapPos[0]+buffer,mapPos[1]+buffer);
+				var realWorld4 = makeClickPos2RealWorldPos(target,mapPos[0]-buffer,mapPos[1]+buffer);
+				spatialRequestFilter += "<Intersects><ogc:PropertyName>";
+				spatialRequestFilter += geometryColumn;
+				spatialRequestFilter += "</ogc:PropertyName><gml:Polygon srsName=\""+srs+"\"><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
+				spatialRequestFilter += realWorld1[0] + "," + realWorld1[1] + " " + realWorld2[0] + "," + realWorld2[1] +  " ";
+				spatialRequestFilter += realWorld3[0] + "," + realWorld3[1] + " " + realWorld4[0] + "," + realWorld4[1] + " " + realWorld1[0] + "," + realWorld1[1];
+				spatialRequestFilter += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersects>";
+			spatialRequestFilter += "<ogc:Not><ogc:PropertyIsNull>";
+            spatialRequestFilter += "<ogc:PropertyName>" + geometryColumn + "</ogc:PropertyName>";
+       		spatialRequestFilter += "</ogc:PropertyIsNull></ogc:Not>";
+			conditionArray.push(spatialRequestFilter);
+	this.addPreConfigured = function (propName, propValueArray, toUpper, operator) {
+		var orConditions = "";
+		for (var j=0; j < propValueArray.length; j++) {
+			if (operator == 'greater_than' || operator == 'less_than' || operator == 'equal') {
+				if(propValueArray[j]!=''){
+					var tag;
+					if (operator == 'greater_than') {
+						tag = "PropertyIsGreaterThan";
+					else if (operator == 'less_than') {
+						tag = "PropertyIsLessThan";
+					else if (operator == 'equal') {
+						tag = "PropertyIsEqualTo";
+					orConditions += "<ogc:" + tag + ">";
+					orConditions += "<ogc:PropertyName>" + propName + "</ogc:PropertyName>";
+					orConditions += "<ogc:Literal>";
+					if (toUpper == 1) {
+						propValueArray[j] = propValueArray[j].toUpperCase();
+					orConditions += propValueArray[j] + "</ogc:Literal></ogc:" + tag + ">";
+			else {
+				var leftSide = "";
+				var rightSide = "*";
+				if (operator != 'rightside') {
+					leftSide = "*";
+				orConditions += "<ogc:PropertyIsLike wildCard='*' singleChar='.' escape='!'>";
+				orConditions += "<ogc:Literal>" + leftSide;
+				if (toUpper == 1){
+				orConditions += propValueArray[j] + rightSide;
+				orConditions += "</ogc:Literal></ogc:PropertyIsLike>";
+			orConditions += "<ogc:Not><ogc:PropertyIsNull>";
+       		orConditions += "</ogc:PropertyIsNull></ogc:Not>";
+		if(propValueArray.length > 1){
+			orConditions = "<Or>" + orConditions + "</Or>";
+		this.add(orConditions);
+	this.add = function (aFilterString) {
+		conditionArray.push(aFilterString);
+	this.toString = function () {
+		var str = "";
+		str += "<ogc:Filter xmlns:ogc='http://www.opengis.net/ogc' ";
+		str += "xmlns:gml='http://www.opengis.net/gml'>";
+		if (conditionArray.length > 1) {
+			str += "<And>" + conditionArray.join("") + "</And>";
+		else {
+			str += conditionArray.join("");
+		str += "</ogc:Filter>";
+		return str;
+	var conditionArray = [];
+	var that = this;
Added: branches/print_dev/http/php/mod_category_filteredGUI.php
--- branches/print_dev/http/php/mod_category_filteredGUI.php	                        (rev 0)
+++ branches/print_dev/http/php/mod_category_filteredGUI.php	2009-03-09 09:08:08 UTC (rev 3649)
@@ -0,0 +1,250 @@
+<?php
+# $Id:$
+# http://www.mapbender.org/index.php/Administration
+import_request_variables("PG");
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Administration</title>
+<?php
+include '../include/dyn_css.php';
+<script language="JavaScript">
+function validate(wert){
+	if(document.forms[0]["selected_category"].selectedIndex == -1){
+		document.getElementsByName("selected_category")[0].style.backgroundColor = '#ff0000';
+		return;
+	}else{
+		if(wert == "remove"){
+			if(document.forms[0]["remove_gui[]"].selectedIndex == -1){
+				document.getElementsByName("remove_gui[]")[0].style.backgroundColor = '#ff0000';
+				return;
+			document.form1.remove.value = 'true';
+			document.form1.submit();
+		if(wert == "insert"){
+			if(document.forms[0]["selected_gui[]"].selectedIndex == -1){
+				document.getElementsByName("selected_gui[]")[0].style.backgroundColor = '#ff0000';
+				return;
+			document.form1.insert.value = 'true';
+ * filter the category list
+function filtercategory(list, all, str){
+	str=str.toLowerCase();
+	var selection=[];
+	var i,j,selected;
+	for(i=0;i<list.options.length;i++){
+		if(list.options[i].selected)
+			selection[selection.length]=list.options[i].value;
+	list.options.length = 0;
+	for(i=0; i<all.length; i++){
+		if(all[i]['name'].toLowerCase().indexOf(str)==-1)
+			continue;
+		selected=false;
+		for(j=0;j<selection.length;j++){
+			if(selection[j]==all[i]['id']){
+				selected=true;
+				break;
+		var newOption = new Option(selected?all[i]['name']:all[i]['name'],all[i]['id'],false,selected);
+		newOption.setAttribute("title", all[i]['description']);
+		list.options[list.options.length] = newOption;
+</script>
+</head>
+<body>
+<?php
+$fieldHeight = 20;
+$cnt_gui = 0;
+$cnt_category = 0;
+$cnt_gui = 0;
+$cnt_gui_category = 0;
+$cnt_gui_gui = 0;
+$exists = false;
+$logged_user_name=$_SESSION["mb_user_name"];
+$logged_user_id=$_SESSION["mb_user_id"];
+$admin = new administration();
+/*handle remove, update and insert*****************************************************************/
+if($insert){
+	if(count($selected_gui)>0){
+		for($i=0; $i<count($selected_gui); $i++){
+			$exists = false;
+			$sql_insert = "SELECT * from gui_gui_category where fkey_gui_category_id = $1 and fkey_gui_id = $2";
+			$v = array($selected_category,$selected_gui[$i]);
+			$t = array('i','s');
+			$res_insert = db_prep_query($sql_insert,$v,$t);
+			while(db_fetch_row($res_insert)){$exists = true;}
+			if($exists == false){
+				$sql_insert = "INSERT INTO gui_gui_category(fkey_gui_category_id, fkey_gui_id) VALUES($1, $2)";
+if($remove){
+	if(count($remove_gui)>0){
+		for($i=0; $i<count($remove_gui); $i++){
+			$sql_remove = "DELETE FROM gui_gui_category WHERE fkey_gui_id = $1 and fkey_gui_category_id = $2";
+			$v = array($remove_gui[$i],$selected_category);
+			$t = array('s','i');
+			db_prep_query($sql_remove,$v,$t);
+/*get owner guis  *******************************************************************************/
+$guisByOwner = $admin->getGuisByOwner($logged_user_id,false);
+for ($i = 0; $i < count($guisByOwner); $i++) {
+	$gui_id[$cnt_gui] = $guisByOwner[$i];
+	$gui_name[$cnt_gui] = $guisByOwner[$i];
+	$cnt_gui++;
+/*get categories **********************************************************************************/
+$sql_category = "SELECT * FROM gui_category order by category_id;";
+$res_category = db_query($sql_category);
+while($row = db_fetch_array($res_category)){
+	$category_id[$cnt_category] = $row["category_id"];
+	$category_name[$cnt_category] = $row["category_name"];
+	$category_description[$cnt_category] = $row["category_description"];
+	$cnt_category++;
+# has to be solved by a function
+$guiCategories = $admin->getGuiCategories();
+echo "<br>getGuiCategories - mehrere Spalten";
+echo "Noch einbauen getGuiCategories".count($guiCategories);
+* get owner gui for selected category
+if (count($category_id) == 0 AND count($gui_id) == 0){ die("There is no gui or category available for this user");}
+#$sql_category_gui = "SELECT gui.gui_id, gui.gui_name, gui_gui_category.fkey_gui_category_id FROM gui_gui_category ";
+#$sql_category_gui .= "INNER JOIN gui ON gui_gui_category.fkey_gui_id = gui.gui_id ";
+#$sql_category_gui .= "WHERE gui_gui_category.fkey_gui_category_id = $1 ";
+#echo $sql_category_gui;egories);
+#if(!$selected_category){$v = array($category_id[0]);}
+#if($selected_category){$v = array($selected_category);}
+#$t = array('i');
+#$sql_category_gui .= " ORDER BY gui.gui_name";
+if(!$selected_category){$selectedCategory = $category_id[0];}
+if($selected_category){$selectedCategory = $selected_category;}
+$getGuisByOwnerBySelectedGuiCategory = $admin->getGuisByOwnerByGuiCategory($logged_user_id,$selectedCategory);
+$cnt_gui_category = count($getGuisByOwnerBySelectedGuiCategory);
+$gui_category_id = $getGuisByOwnerBySelectedGuiCategory;
+#$res_category_gui = db_prep_query($sql_category_gui,$v,$t);
+#while($row = db_fetch_array($res_category_gui)){
+#$gui_category_id[$cnt_gui_category] = $row["gui_id"];
+#$gui_category_name[$cnt_gui_category] =  $row["gui_name"];
+#$cnt_gui_category++;
+/*INSERT HTML*/
+echo "<form name='form1' action='" . $self ."' method='post'>";
+/*filterbox****************************************************************************************/
+echo "<input type='text' value='' class='filter1' id='filter1' name='filter1' onkeyup='filtercategory(document.getElementById(\"selectedcategory\"),category,this.value);'/>";
+/*insert all category in selectbox*****************************************************************/
+echo "<div class='text1'>Category: </div>";
+echo "<select style='background:#ffffff' onchange='submit();' class='select1' id='selectedcategory' name='selected_category' size='10'>";
+for($i=0; $i<$cnt_category; $i++){
+	echo "<option value='" . $category_id[$i] . "' ";
+	if($selected_category && $selected_category == $category_id[$i]){
+		echo "selected>".$category_name[$i];
+	else
+		echo ">" . $category_name[$i];
+	echo "</option>";
+echo "</select>";
+/*insert all guis in selectbox********************************************************************/
+echo "<div class='text2'>GUI:</div>";
+echo "<select style='background:#ffffff' class='select2' multiple='multiple' name='selected_gui[]' size='$fieldHeight' >";
+for($i=0; $i<$cnt_gui; $i++){
+	echo "<option value='" . $gui_name[$i]  . "'>" . $gui_name[$i]  . "</option>";
+echo "</select>";
+/*Button******************************************************************************************/
+echo "<div class='button1'><input type='button'  value='==>' onClick='validate(\"insert\")'></div>";
+echo "<input type='hidden' name='insert'>";
+echo "<div class='button2'><input type='button' value='<==' onClick='validate(\"remove\")'></div>";
+echo "<input type='hidden' name='remove'>";
+/*insert category_gui_dependence in selectbox**************************************************/
+echo "<div class='text3'>SELECTED GUI:</div>";
+echo "<select style='background:#ffffff' class='select3' multiple='multiple' name='remove_gui[]' size='$fieldHeight' >";
+for($i=0; $i<$cnt_gui_category; $i++){
+	echo "<option value='" . $gui_category_id[$i]  . "'>" .$gui_category_id[$i]. "</option>";
+echo "</select>";
+echo "</form>";
+<script type="text/javascript">
+document.forms[0].selected_category.focus();
+var category=[];
+<?php
+	echo "category[".$i."]=[];\n";
+	echo "category[".$i."]['id']='" . $category_id[$i]  . "';\n";
+	echo "category[".$i."]['name']='" . $category_name[$i]  . "';\n";
+	echo "category[".$i."]['description']='" . $category_description[$i]  . "';\n";
+</script>
+</body>
+</html>
\ No newline at end of file
Added: branches/print_dev/http/php/mod_createCategory.php
--- branches/print_dev/http/php/mod_createCategory.php	                        (rev 0)
+++ branches/print_dev/http/php/mod_createCategory.php	2009-03-09 09:08:08 UTC (rev 3649)
@@ -0,0 +1,127 @@
+<?php
+# $Id:$
+<html>
+<head>
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<?php
+<title>New Category</title>
+<?php include '../include/dyn_css.php'; ?>
+<?php
+if(isset($newCategory) && $newCategory != ""){
+  $sql = "SELECT category_name FROM gui_category WHERE category_name = $1";
+  $v = array($newCategory);
+  $t = array('s');
+  $res = db_prep_query($sql,$v,$t);
+  if(db_fetch_row($res)){
+     echo "<script type='text/javascript'>";
+     echo "alert('Error: Category already exists!');";
+     echo "</script>";
+  else{
+	$sql = "INSERT INTO gui_category (category_name,category_description) ";
+	$sql .= "VALUES($1, $2)";
+	$v = array($newCategory,$newDesc);
+	$t = array('s','s');
+	$categoryCreated=true;
+function setFocus(){
+	document.form1.newCategory.focus();
+function validate(){
+	if(document.form1.newCategory.value == ""){
+		alert("<?php echo _mb("Please enter a category name!")?>");
+		return;
+	else if(document.form1.newDesc.value == ""){
+		alert("<?php echo _mb("Please enter a category description!")?>");
+		document.form1.newDesc.focus();
+		return;
+	else{
+</script>
+</head>
+<body onload='setFocus()'>
+<form name='form1' action="<?php echo $self; ?>" method="POST">
+<?php
+	$v = array();
+	$t = array();
+	$c = 1;
+	$sql = "SELECT * from gui_category";
+	$sql .= " order by lower(category_name);";
+	$count=0;
+	while($row = db_fetch_array($res)){
+		$category_name[$count]= $row["category_name"];
+		$category_description[$count]=$row["category_description"];
+		$count++;
+	echo "<p\n";
+	echo "<div class= 'guiList1_text'>"._mb("existing Categories").":</div>\n";
+#echo "<select class='categoryList' size='14' name='categoryList' onchange='setCategory(this.value)'>\n";
+	echo "<select class='categoryList' size='14' name='categoryList' onchange=''>\n";
+	for ($i=0; $i<count($category_name);$i++){
+		echo "<option value='".$category_name[$i]."' ";
+		echo ">".$category_name[$i]. " - ".$category_description[$i]."</option>\n";
+	echo "</select>\n";
+	echo "</p\n";
+<table>
+<tr><td><?php echo _mb("Category Name"); ?>: </td><td><input type='text' name='newCategory'></td></tr>
+<tr><td><?php echo _mb("Description"); ?>: </td><td><input type='text' name='newDesc'></td></tr>
+<tr><td></td><td><input type='button' onclick='validate()' value="<?php echo _mb("new"); ?>"></td></tr>
+</table>
+<?php
+	if ($categoryCreated==true){
+		echo "<p class = 'categroyList'>";
+		echo "<b>".$newCategory."</b> - "._mb("The Category has been created successfully.");
+		echo "<p>";
+		}else{
+			echo"error";
+</form>
+</body>
+</html>
More information about the Mapbender_commits mailing list
