[Mapbender-commits] r3662 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Mar 10 11:30:38 EDT 2009
Author: christoph
Date: 2009-03-10 11:30:37 -0400 (Tue, 10 Mar 2009)
New Revision: 3662
   trunk/mapbender/http/php/mb_listGUIs.php
please take a look at the Mapbender code conventions!!!!
http://www.mapbender.org/Code_conventions
Modified: trunk/mapbender/http/php/mb_listGUIs.php
--- trunk/mapbender/http/php/mb_listGUIs.php	2009-03-10 12:59:34 UTC (rev 3661)
+++ trunk/mapbender/http/php/mb_listGUIs.php	2009-03-10 15:30:37 UTC (rev 3662)
@@ -22,7 +22,6 @@
 		echo "<h1>Error</h1>";
 		echo "<p>There are no GUIs available for this user.</p>";
 		printf("<p><a href=\"../php/mod_logout.php?%s\"><img src=\"../img/button_gray/logout_off.png\" onmouseover=\"this.src='../img/button_gray/logout_over.png'\" onmouseout=\"this.src='../img/button_gray/logout_off.png'\" alt=\"Logout\" title=\"Logout\"></a></p>",SID);
 		return;
@@ -60,52 +59,52 @@
 	echo "<ul class=\"gui_list\">\n";
-  $num =  pg_numrows($result);
+	$num =  pg_numrows($result);
-  for ($j=0; $j<$num; $j++){
-    $row = pg_fetch_array ($result, $j);
-     if($category !== $row["category_name"]) {
-  			$category = $row["category_name"];
+	for ($j = 0; $j < $num; $j++) {
+		$row = pg_fetch_array ($result, $j);
+		if ($category !== $row["category_name"]) {
+			$category = $row["category_name"];
-  			if(strlen($row["category_name"]) > 0) {
+			if (strlen($row["category_name"]) > 0) {
-          printf("\t<li class=\"gui_category\" id=\"%s\"><h2>%s</h2>",$row["category_name"],$row["category_name"]);
-        else {
-        	//$category="NULL";
-          printf("\t<li class=\"gui_category\" ><h2>Application(s) without category</h2>");
+				printf("\t<li class=\"gui_category\" id=\"%s\"><h2>%s</h2>",$row["category_name"],$row["category_name"]);
+			else {
+				//$category="NULL";
+				printf("\t<li class=\"gui_category\" ><h2>Application(s) without category</h2>");
-  			if(strlen($row["category_description"]) > 0) {
-  				printf("<label for=\"%s\" class=\"gui_category_description\">%s</label>\n",$row["category_name"],$row["category_description"]);
-          echo "\t\t<ul>\n";
-        else {
-  			  echo "\n\t\t<ul>\n";
+			if(strlen($row["category_description"]) > 0) {
+				printf("<label for=\"%s\" class=\"gui_category_description\">%s</label>\n",$row["category_name"],$row["category_description"]);
+				echo "\t\t<ul>\n";
+			else {
+				echo "\n\t\t<ul>\n";
-  		$url = sprintf("index.php?%s&amp;gui_id=%s",strip_tags(SID),$row["gui_id"]);
-  		if(($j % 2) == 0){$class= "class='alternate' ";}
-  		else {$class="class='normal'";}
-      //printf("\t\t<li id=\"%s\" %s onclick=\"location.href='%s'\" ><a href=\"%s\">%s</a><label for=\"%s\">%s</label></li>\n",$row["gui_name"],$class,$url,$url,$row["gui_name"],$row["gui_name"],$row["gui_description"]);
+		$url = sprintf("index.php?%s&amp;gui_id=%s",strip_tags(SID),$row["gui_id"]);
+		if (($j % 2) == 0) {
+			$class= "class='alternate' ";
+  		else {
+  			$class="class='normal'";
+		//printf("\t\t<li id=\"%s\" %s onclick=\"location.href='%s'\" ><a href=\"%s\">%s</a><label for=\"%s\">%s</label></li>\n",$row["gui_name"],$class,$url,$url,$row["gui_name"],$row["gui_name"],$row["gui_description"]);
-      printf("\t\t<li id=\"%s\" %s onclick=\"location.href='%s'\" ><a href=\"%s\">%s</a> \n\t\t\t <ul><li>%s</li></ul></li>\n",$row["gui_name"],$class,$url,$url,$row["gui_name"],$row["gui_description"]);
-     //checks next category or last category
-     $nextrow = pg_fetch_array ($result, $j+1);
-     if(($category !== $nextrow["category_name"]) ||($num==$j+1)) {
-     echo "\t\t</ul>\n";
-     echo "\t</li>\n";
-echo "</ul>\n";
-echo "</div>\n";
+		printf("\t\t<li id=\"%s\" %s onclick=\"location.href='%s'\" ><a href=\"%s\">%s</a> \n\t\t\t <ul><li>%s</li></ul></li>\n",$row["gui_name"],$class,$url,$url,$row["gui_name"],$row["gui_description"]);
+		//checks next category or last category
+		$nextrow = pg_fetch_array ($result, $j+1);
+		if(($category !== $nextrow["category_name"]) ||($num==$j+1)) {
+			echo "\t\t</ul>\n";
+			echo "\t</li>\n";
+	echo "</ul>\n";
+	echo "</div>\n";
\ No newline at end of file
More information about the Mapbender_commits mailing list
