[Mapbender-commits] r3666 - in branches/2.5/http: classes javascripts php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Mar 11 09:40:12 EDT 2009
Author: christoph
Date: 2009-03-11 09:40:11 -0400 (Wed, 11 Mar 2009)
New Revision: 3666
   branches/2.5/http/classes/class_administration.php
   branches/2.5/http/classes/class_wmcToXml.php
   branches/2.5/http/classes/class_wms.php
   branches/2.5/http/javascripts/map.php
   branches/2.5/http/javascripts/mod_loadwmc.php
   branches/2.5/http/php/mod_createJSObjFromDB.php
   branches/2.5/http/php/mod_createJSObjFromDBByWMS.php
   branches/2.5/http/php/mod_createJSObjFromXML.php
waking up from the encoding nightmare
Modified: branches/2.5/http/classes/class_administration.php
--- branches/2.5/http/classes/class_administration.php	2009-03-10 16:42:31 UTC (rev 3665)
+++ branches/2.5/http/classes/class_administration.php	2009-03-11 13:40:11 UTC (rev 3666)
@@ -1082,6 +1082,22 @@
 		return ($this->is_utf8_xml($data) || $this->is_utf8_string($data));
+	public static function convertIncomingString ($str) {
+		if (CHARSET == "ISO-8859-1") {
+			$e = new mb_notice("Conversion to UTF-8: " . $str . " to " . utf8_encode($str));
+			return utf8_encode($str);
+		return $str;
+	public static function convertOutgoingString ($str) {
+			$e = new mb_notice("Conversion to ISO-8859-1: " . $str . " to " . utf8_decode($str));
+			return utf8_decode($str);
+		return $str;
 	function char_encode($data) {
 		if (CHARSET == "UTF-8") {
 			if (!$this->is_utf8($data)) {
Modified: branches/2.5/http/classes/class_wmcToXml.php
--- branches/2.5/http/classes/class_wmcToXml.php	2009-03-10 16:42:31 UTC (rev 3665)
+++ branches/2.5/http/classes/class_wmcToXml.php	2009-03-11 13:40:11 UTC (rev 3666)
@@ -47,6 +47,12 @@
 	public function getXml () {
+		if (is_null($this->wmc)) {
+			return null;
+		if ($this->xml == "") {
+			$this->toXml();
 		return $this->xml;
@@ -120,7 +126,10 @@
 		$e_view_context->appendChild($e_layer_list);
 		$this->doc->appendChild($e_view_context);
+//		$this->xml = $this->doc->saveXML($this->doc->documentElement);
 		$this->xml = $this->doc->saveXML();
+//		$e = new mb_notice($this->xml);
 	private function createGeneralNode () {
@@ -279,11 +288,13 @@
 			$e_layer->appendChild($e_service);
 			// Name
-			$e_layer_name = $this->doc->createElement("Name", $currentLayer->layer_name);
+			$currentLayerName = $currentLayer->layer_name;
+			$e_layer_name = $this->doc->createElement("Name", $currentLayerName);
 			$e_layer->appendChild($e_layer_name);
 			// Title
-			$e_layer_title = $this->doc->createElement("Title", $currentLayer->layer_title);
+			$currentLayerTitle = $currentLayer->layer_title;
+			$e_layer_title = $this->doc->createElement("Title", $currentLayerTitle);
 			$e_layer->appendChild($e_layer_title);
 			// Abstract
Modified: branches/2.5/http/classes/class_wms.php
--- branches/2.5/http/classes/class_wms.php	2009-03-10 16:42:31 UTC (rev 3665)
+++ branches/2.5/http/classes/class_wms.php	2009-03-11 13:40:11 UTC (rev 3666)
@@ -1875,8 +1875,8 @@
 				$this->addLayer($row2["layer_pos"],$row2["layer_parent"]);
 				$layer_cnt=count($this->objLayer)-1;
 				$this->objLayer[$layer_cnt]->layer_uid = $layer_id;
-				$this->objLayer[$layer_cnt]->layer_name =$row2["layer_name"];
-				$this->objLayer[$layer_cnt]->layer_title =$row2["layer_title"];
+				$this->objLayer[$layer_cnt]->layer_name = administration::convertIncomingString($row2["layer_name"]);
+				$this->objLayer[$layer_cnt]->layer_title = administration::convertIncomingString($row2["layer_title"]);
 				$this->objLayer[$layer_cnt]->layer_dataurl_href =$row2["layer_dataurl"];
 				$this->objLayer[$layer_cnt]->layer_metadataurl =$row2["layer_metadataurl"];
 				$this->objLayer[$layer_cnt]->layer_pos =$row2["layer_pos"];
Modified: branches/2.5/http/javascripts/map.php
--- branches/2.5/http/javascripts/map.php	2009-03-10 16:42:31 UTC (rev 3665)
+++ branches/2.5/http/javascripts/map.php	2009-03-11 13:40:11 UTC (rev 3666)
@@ -91,7 +91,10 @@
 while($row = db_fetch_array($res)) {
 	$mywms = new wms();
 	$mywms->createObjFromDB($gui_id, $row["fkey_wms_id"]);
-	$mywms->createJsObjFromWMS();
+	$output = $mywms->createJsObjFromWMS_();
+	echo administration::convertOutgoingString($output);
+	unset($output);
Modified: branches/2.5/http/javascripts/mod_loadwmc.php
--- branches/2.5/http/javascripts/mod_loadwmc.php	2009-03-10 16:42:31 UTC (rev 3665)
+++ branches/2.5/http/javascripts/mod_loadwmc.php	2009-03-11 13:40:11 UTC (rev 3666)
@@ -29,15 +29,15 @@
 		$e = new mb_notice("wmc not set, generating from app: " . $_SESSION["mb_user_gui"]);
 		$wmc->createFromApplication($_SESSION["mb_user_gui"]);
 		$_SESSION["mb_wmc"] = $wmc->toXml();
-//		$e = new mb_exception("initial WMC: " . $_SESSION["mb_wmc"]);
+		$e = new mb_notice("creating initial WMC.");
 	if (isset($_SESSION['mb_wmc'])) {
-		$e = new mb_notice("merging with WMC.");
 		if ($wmc->createFromXml($_SESSION['mb_wmc'])) {
 			if ($mergeWms) {
+				$e = new mb_notice("merging with WMS.");
 				$wmsArray = array();
 				for ($i = 0; $i < count($_SESSION["wms"]); $i++) {
 					$currentWms = new wms();
@@ -59,7 +59,6 @@
 	else {
-		$e = new mb_notice("not merging WMC");
 		$jsString .= "var e = new Mb_warning('mod_loadwmc: load_wmc_session: no wmc set!');";
 	return $jsString;
@@ -81,10 +80,10 @@
 	$e = new mb_notice("NOT merging with WMS in Session...");
 	$output = createJs(false);
-if (CHARSET == "ISO-8859-1") {
-	$output = utf8_decode($output);
+$output = administration::convertOutgoingString($output);
 echo $output;
Modified: branches/2.5/http/php/mod_createJSObjFromDB.php
--- branches/2.5/http/php/mod_createJSObjFromDB.php	2009-03-10 16:42:31 UTC (rev 3665)
+++ branches/2.5/http/php/mod_createJSObjFromDB.php	2009-03-11 13:40:11 UTC (rev 3666)
@@ -18,6 +18,7 @@
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
 require_once(dirname(__FILE__)."/../classes/class_wms.php");
 $sql = "SELECT fkey_wms_id FROM gui_wms WHERE fkey_gui_id = $1 ORDER BY gui_wms_position";
@@ -28,6 +29,8 @@
 while($row = db_fetch_array($res)){
 	$mywms = new wms();
 	$mywms->createObjFromDB($_SESSION["mb_user_gui"],$row["fkey_wms_id"]);
+	unset($output);
\ No newline at end of file
Modified: branches/2.5/http/php/mod_createJSObjFromDBByWMS.php
--- branches/2.5/http/php/mod_createJSObjFromDBByWMS.php	2009-03-10 16:42:31 UTC (rev 3665)
+++ branches/2.5/http/php/mod_createJSObjFromDBByWMS.php	2009-03-11 13:40:11 UTC (rev 3666)
@@ -46,7 +46,9 @@
 	else{
 		$mywms->createObjFromDBNoGui($wms_id);
-	$mywms->createJsObjFromWMS(true);
+	$output = $mywms->createJsObjFromWMS_(true);
+	unset($output);
 	echo "parent.mod_addWMS_refresh();";
 else {
Modified: branches/2.5/http/php/mod_createJSObjFromXML.php
--- branches/2.5/http/php/mod_createJSObjFromXML.php	2009-03-10 16:42:31 UTC (rev 3665)
+++ branches/2.5/http/php/mod_createJSObjFromXML.php	2009-03-11 13:40:11 UTC (rev 3666)
@@ -19,6 +19,7 @@
 $capabilitiesURL = html_entity_decode($_REQUEST['caps']);
@@ -41,7 +42,9 @@
 	echo "prompt('" . $errorMessage . "', '" . $capabilitiesURL . "');";
 	die;
-$mywms->createJsObjFromWMS(true);
+$output = $mywms->createJsObjFromWMS_(true);
+echo administration::convertOutgoingString($output);
+unset($output);
More information about the Mapbender_commits mailing list
