[Mapbender-commits] r3678 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Mar 12 12:10:24 EDT 2009
Author: christoph
Date: 2009-03-12 12:10:23 -0400 (Thu, 12 Mar 2009)
New Revision: 3678
   trunk/mapbender/http/javascripts/map_obj.js
   trunk/mapbender/http/javascripts/mapnf.php
http://trac.osgeo.org/mapbender/ticket/319
Modified: trunk/mapbender/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js	2009-03-12 16:09:23 UTC (rev 3677)
+++ trunk/mapbender/http/javascripts/map_obj.js	2009-03-12 16:10:23 UTC (rev 3678)
@@ -78,8 +78,14 @@
 		var clickX, clickY;
 		if ($.browser.msie) {
-			clickX = e.clientX;
-			clickY = e.clientY;
+			if (window.event) {
+				clickX = window.event.clientX;
+				clickY = window.event.clientY;
+			else {
+				clickX = e.clientX;
+				clickY = e.clientY;
 		else{
 			clickX = e.pageX;
Modified: trunk/mapbender/http/javascripts/mapnf.php
--- trunk/mapbender/http/javascripts/mapnf.php	2009-03-12 16:09:23 UTC (rev 3677)
+++ trunk/mapbender/http/javascripts/mapnf.php	2009-03-12 16:10:23 UTC (rev 3678)
@@ -19,4 +19,67 @@
 require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-mb_registerMapObj('', 'mapframe1', null,<?php echo $e_width; ?>, <?php echo $e_height; ?>);
\ No newline at end of file
+(function () {
+	var mapTimeout;
+	var	sum_delta = 0;
+	var lastTimestamp;
+	var lastScrollPosition;
+	var mapObject;
+	eventInitMap.register(function init_mod_map1(){
+		mapObject = mb_registerMapObj('', 'mapframe1', null,<?php echo $e_width; ?>, <?php echo $e_height; ?>);
+		$(document).mousewheel(function (e, delta) {
+			if (sum_delta == 0) {
+				mapTimeout = setTimeout(function () {
+						lastScrollPosition = mapObject.getMousePosition(e);
+						mousewheelZoom();
+					100);
+			sum_delta = sum_delta + (delta);
+			var currentTime = new Date();
+			lastTimestamp = currentTime.getTime();
+			return false;
+	function mousewheelZoom () {
+		if (currentTime.getTime() - lastTimestamp > 200) {
+			if (lastScrollPosition !== null) {
+				var pos = mapObject.convertPixelToReal(lastScrollPosition);
+				if (sum_delta > 0) {
+					mapObject.zoom(true, Math.pow(Mapbender.zoomMousewheel, sum_delta), pos.x, pos.y);
+				else {
+					mapObject.zoom(false, Math.pow(Mapbender.zoomMousewheel, -sum_delta), pos.x, pos.y);
+				var newPos = new Point();
+				newPos.x = mapObject.width - lastScrollPosition.x;
+				newPos.y = mapObject.height - lastScrollPosition.y;
+				var posAfterZoom = mapObject.convertPixelToReal(newPos);
+				mapObject.zoom(false, 1.0, posAfterZoom.x, posAfterZoom.y);
+			sum_delta = 0;
+			clearTimeout(mapTimeout);
+		else {
+					mousewheelZoom(sum_delta);
+				100
More information about the Mapbender_commits mailing list
