[Mapbender-commits] r3681 - in trunk/mapbender: http/javascripts lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Mar 12 12:29:44 EDT 2009
Author: christoph
Date: 2009-03-12 12:29:44 -0400 (Thu, 12 Mar 2009)
New Revision: 3681
   trunk/mapbender/http/javascripts/mod_add_SLD.php
   trunk/mapbender/http/javascripts/mod_digitize_tab.php
   trunk/mapbender/http/javascripts/mod_dynamicOverview.php
   trunk/mapbender/http/javascripts/mod_help.php
   trunk/mapbender/http/javascripts/mod_legend.php
   trunk/mapbender/http/javascripts/mod_loadwmc.js
   trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php
   trunk/mapbender/http/javascripts/wms.js
   trunk/mapbender/lib/buttonNew.js
removed console.logs
Modified: trunk/mapbender/http/javascripts/mod_add_SLD.php
--- trunk/mapbender/http/javascripts/mod_add_SLD.php	2009-03-12 16:20:01 UTC (rev 3680)
+++ trunk/mapbender/http/javascripts/mod_add_SLD.php	2009-03-12 16:29:44 UTC (rev 3681)
@@ -54,7 +54,6 @@
 function mod_set_sld(sldString){
-	//console.debug("%s",sldString);
 	mb_ajax_post("../orlando/saveSLD.php", {'sld':sldString}, function (json, status) {
 	var result = eval('('+json+')');
 	sldURL = sldLocationUrl + result.filename;
Modified: trunk/mapbender/http/javascripts/mod_digitize_tab.php
--- trunk/mapbender/http/javascripts/mod_digitize_tab.php	2009-03-12 16:20:01 UTC (rev 3680)
+++ trunk/mapbender/http/javascripts/mod_digitize_tab.php	2009-03-12 16:29:44 UTC (rev 3681)
@@ -475,11 +475,9 @@
 function executeDigitizeSubFunctions(){
-//	console.profile();
 	for(var i=0; i<mod_digitizeSubFunctions.length; i++){
 		eval(mod_digitizeSubFunctions[i]);
-//	console.profileEnd();
 function executeDigitizePreFunctions(){
Modified: trunk/mapbender/http/javascripts/mod_dynamicOverview.php
--- trunk/mapbender/http/javascripts/mod_dynamicOverview.php	2009-03-12 16:20:01 UTC (rev 3680)
+++ trunk/mapbender/http/javascripts/mod_dynamicOverview.php	2009-03-12 16:29:44 UTC (rev 3681)
@@ -122,7 +122,6 @@
 		//check and set minExtent for overview
 		var newMinExt = mod_dynamicOverviewCheckDiagonal(arrayTargets[1], minx,miny, maxx, maxy);
 		if(newMinExt){
-//			console.log("newMin: "+newMinExt);
 			var minCoords = newMinExt.split(",");
 			minx = 	parseFloat(minCoords[0]);
 			miny = 	parseFloat(minCoords[1]);
@@ -152,7 +151,6 @@
 	var d = Math.sqrt(Math.pow(xPerPix,2)+Math.pow(yPerPix,2));
 	if(mod_dynamicOverview_minScale && mod_dynamicOverview_minScale > d){
 		var newDistx = Math.sqrt(Math.pow((mod_dynamicOverview_minScale),2)/2)*mb_mapObj[ind].width;
-//		console.log(newDistx);
 		minx = centerx - newDistx/2;
 		maxx = centerx + newDistx/2;
 		miny = centery - newDistx/2;
@@ -173,7 +171,6 @@
 	for(var i=0; i<wms.gui_epsg.length; i++){
 		if(srs == wms.gui_epsg[i]){
 			var re = wms.gui_minx[i] +","+ wms.gui_miny[i]  +","+ wms.gui_maxx[i] +","+ wms.gui_maxy[i];
-//			window.console.log(re);
 	return re;
Modified: trunk/mapbender/http/javascripts/mod_help.php
--- trunk/mapbender/http/javascripts/mod_help.php	2009-03-12 16:20:01 UTC (rev 3680)
+++ trunk/mapbender/http/javascripts/mod_help.php	2009-03-12 16:29:44 UTC (rev 3681)
@@ -145,7 +145,7 @@
 	catch(e){
-		console.log(e);
+		var e = new Mb_exception(e);
Modified: trunk/mapbender/http/javascripts/mod_legend.php
--- trunk/mapbender/http/javascripts/mod_legend.php	2009-03-12 16:20:01 UTC (rev 3680)
+++ trunk/mapbender/http/javascripts/mod_legend.php	2009-03-12 16:29:44 UTC (rev 3681)
@@ -131,11 +131,9 @@
 					else{
 						legendUrl = parent.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layerNames[j],layerStyle);
-					//console.log("layer_infos : %s",layerNames[j],"---",layerParent,"---",layerTitle,"---",layerStyle,"---",legendUrl);
 					if (legendUrl !== false){
-//						console.log("legendUrl: %s, typeof(legendUrl): %s", legendUrl, typeof(legendUrl));
 //	 					if(layerParent == 0){
 		 					if(showlayertitle == 'true'){
 								str_tmp += "<div><span class='titles'>" + layerTitle+ "</span></div>";
@@ -162,7 +160,6 @@
 				str_tmp ='';
-		//console.log("ind =%s",ind,"str =",str);
 	    if(str != ""){
 			parent.writeTag("legend", "leg", str);
Modified: trunk/mapbender/http/javascripts/mod_loadwmc.js
--- trunk/mapbender/http/javascripts/mod_loadwmc.js	2009-03-12 16:20:01 UTC (rev 3680)
+++ trunk/mapbender/http/javascripts/mod_loadwmc.js	2009-03-12 16:29:44 UTC (rev 3681)
@@ -102,7 +102,7 @@
 						try {
 							if (resultObj.javascript && typeof(resultObj.javascript) == "object") {
 								for (var j=0; j < resultObj.javascript.length; j++) {
-//									console.log("Statement: %s", resultObj.javascript[j]);
+//									var e = new Mb_notice("Statement: %s", resultObj.javascript[j]);
 									eval(resultObj.javascript[j]);
Modified: trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php
--- trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php	2009-03-12 16:20:01 UTC (rev 3680)
+++ trunk/mapbender/http/javascripts/mod_wfs_SpatialRequest.php	2009-03-12 16:29:44 UTC (rev 3681)
@@ -720,7 +720,6 @@
 	for (var i = 0 ; i <currentWfsConf.element.length; i ++) {
 	    if(currentWfsConf.element[i].f_show_detail==1){
 	    	if( geomArray.get(geometryIndex).e.getElementValueByName(currentWfsConf.element[i].element_name)!=false){
-				//console.log(currentWfsConf.element[i].element_name+"---"+currentWfsConf.element[i].f_respos);
 				resultHtml +="<tr><td>\n";
 				resultHtml += currentWfsConf.element[i].f_label;
 				resultHtml +="</td>\n";
Modified: trunk/mapbender/http/javascripts/wms.js
--- trunk/mapbender/http/javascripts/wms.js	2009-03-12 16:20:01 UTC (rev 3680)
+++ trunk/mapbender/http/javascripts/wms.js	2009-03-12 16:29:44 UTC (rev 3681)
@@ -173,7 +173,6 @@
 	rq += "&EXCEPTIONS=" + this.gui_wms_exceptionformat;
 	//Todo: error occurs:
 	//var throwNotice = new Mb_notice("getMapRequest: " + rq);
-	//window.console.log("getMapRequest: " + rq);
 	return rq;
@@ -217,7 +216,6 @@
 	rq += "&EXCEPTIONS=application/vnd.ogc.se_xml";
 	rq += "&X=" + clickPoint.x;
 	rq += "&Y=" + clickPoint.y;
-	//console.log(rq);
 	return rq;
@@ -280,7 +278,6 @@
 			var hasNoChildren = (!this.objLayer[i].has_childs);
 			if (isVisible && hasNoChildren){
 				if(this.objLayer[i].checkScale(mapObj)){
-					//console.log("checkLayer: " + this.objLayer[i].layer_name);
 					visibleLayers.push(this.objLayer[i].layer_name);
@@ -765,7 +762,6 @@
 wms_layer.prototype.setVisible = function(visible){
 	this.gui_layer_visible = parseInt(visible, 10);
-	//console.log("setVisible(%i) for Layer %s",visible, this.layer_name);
@@ -775,5 +771,4 @@
 wms_layer.prototype.setQueryable = function(queryable){
 	this.gui_layer_querylayer = parseInt(queryable, 10);
-	//console.log("setQueryable(%i) for Layer %s",queryable, this.layer_name);
Modified: trunk/mapbender/lib/buttonNew.js
--- trunk/mapbender/lib/buttonNew.js	2009-03-12 16:20:01 UTC (rev 3680)
+++ trunk/mapbender/lib/buttonNew.js	2009-03-12 16:29:44 UTC (rev 3681)
@@ -8,7 +8,6 @@
 	this.add = function (button) {
 		if (!button.constructor == "Button") {
-//			console.log("not a button, but a %s", button.constructor);
 			return false;
 		if (button.type == "toggle") {
More information about the Mapbender_commits mailing list
