[Mapbender-commits] r3683 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Mar 12 12:34:47 EDT 2009
Author: verenadiewald
Date: 2009-03-12 12:34:47 -0400 (Thu, 12 Mar 2009)
New Revision: 3683
   trunk/mapbender/resources/db/update/update_2.6.sql
featureInfo popup for gui_digitize
Modified: trunk/mapbender/resources/db/update/update_2.6.sql
--- trunk/mapbender/resources/db/update/update_2.6.sql	2009-03-12 16:33:34 UTC (rev 3682)
+++ trunk/mapbender/resources/db/update/update_2.6.sql	2009-03-12 16:34:47 UTC (rev 3683)
@@ -383,15 +383,11 @@
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
--- featureInfoTunnel is not part of gui1
---INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var');--INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
---INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoLayerPopup', 'true', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoLayerPopup', 'true', '' ,'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
More information about the Mapbender_commits mailing list
