[Mapbender-commits] r3779 - in trunk/mapbender/resources/db:
mysql/ISO-8859-1 mysql/ISO-8859-1/update mysql/UTF-8
mysql/UTF-8/update pgsql/ISO-8859-1 pgsql/ISO-8859-1/update
pgsql/UTF-8 pgsql/UTF-8/update
svn_mapbender at osgeo.org
Tue Mar 17 12:16:15 EDT 2009
Author: christoph
Date: 2009-03-17 12:16:15 -0400 (Tue, 17 Mar 2009)
New Revision: 3779
Added:
trunk/mapbender/resources/db/mysql/ISO-8859-1/update/
trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql
trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_mysql_ISO-8859-1.sql
trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_mysql_ISO-8859-1.sql
trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.5rc6_to_2.5_mysql_ISO-8859-1.sql
trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_mysql_ISO-8859-1.sql
trunk/mapbender/resources/db/mysql/UTF-8/update/
trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql
trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.5.1rc1_to_2.5.1_mysql_UTF-8.sql
trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.5_to_2.5.1rc1_mysql_UTF-8.sql
trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.5rc6_to_2.5_mysql_UTF-8.sql
trunk/mapbender/resources/db/mysql/UTF-8/update/update_guis_2.4.5_to_2.5_mysql_UTF-8.sql
trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/
trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_pgsql_ISO-8859-1.sql
trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_pgsql_ISO-8859-1.sql
trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.5rc6_to_2.5_pgsql_ISO-8859-1.sql
trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
trunk/mapbender/resources/db/pgsql/UTF-8/update/
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.5rc6_to_2.5_pgsql_UTF-8.sql
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_guis_2.4.5_to_2.5_pgsql_UTF-8.sql
update sqls
Added: trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql
--- trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql (rev 0)
+++ trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.4.5_to_2.5_mysql_ISO-8859-1.sql 2009-03-17 16:16:15 UTC (rev 3779)
@@ -0,0 +1,521 @@
+-- database changes in version 2.5
+-- notice language plpgsql has to be installed
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin_de_services', 20, '');
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin_en_services', 20, '');
+-- table mb_monitort: new columns for mb_monitor
+ALTER TABLE mb_monitor ADD COLUMN image int(11);
+ALTER TABLE mb_monitor ADD COLUMN map_url varchar(2048);
+-- WFS database handling
+-- enhancement of the datadase structure concerning WFS metadata (same solution like for WMS)
+ALTER table wfs add wfs_getcapabilities_doc text;
+ALTER table wfs add wfs_upload_url varchar(255);
+ALTER table wfs add fees varchar(255);
+ALTER table wfs add accessconstraints text;
+ALTER table wfs add individualname varchar(255);
+ALTER table wfs add positionname varchar(255);
+ALTER table wfs add providername varchar(255);
+ALTER table wfs add city varchar(255);
+ALTER table wfs add deliverypoint varchar(255);
+ALTER table wfs add administrativearea varchar(255);
+ALTER table wfs add postalcode varchar(255);
+ALTER table wfs add voice varchar(255);
+ALTER table wfs add facsimile varchar(255);
+ALTER table wfs add electronicmailaddress varchar(255);
+ALTER table wfs add wfs_mb_getcapabilities_doc text;
+ALTER table wfs add wfs_owner int(11);
+ALTER table wfs add wfs_timestamp int(11);
+ALTER table wfs add country varchar(255);
+ALTER TABLE wfs MODIFY wfs_title varchar(255) NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_title SET DEFAULT '';
+ALTER TABLE wfs MODIFY wfs_version NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_version SET DEFAULT '';
+ALTER TABLE wfs MODIFY wfs_getcapabilities NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_getcapabilities SET DEFAULT '';
+alter table wfs_featuretype add column featuretype_searchable integer default 1;
+alter table wfs_featuretype add column featuretype_abstract character varying(50);
+-- grant root access to default wfs
+UPDATE wfs SET wfs_owner = 1;
+-- new table gui_wfs_conf
+CREATE TABLE gui_wfs_conf (
+ fkey_gui_id character varying(50) DEFAULT '' NOT NULL,
+ fkey_wfs_conf_id integer DEFAULT 0 NOT NULL
+ALTER TABLE gui_wfs_conf
+ ADD CONSTRAINT pk_fkey_wfs_conf_id PRIMARY KEY (fkey_gui_id, fkey_wfs_conf_id);
+ ADD CONSTRAINT gui_wfs_conf_ibfk_1 FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
+ ADD CONSTRAINT gui_wfs_conf_ibfk_2 FOREIGN KEY (fkey_wfs_conf_id) REFERENCES wfs_conf(wfs_conf_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- insert wfs confs into gui digitize
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 1);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 3);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 4);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 2);
+-- new table wfs_featuretype_keyword:
+CREATE TABLE wfs_featuretype_keyword (
+ fkey_featuretype_id integer NOT NULL,
+ fkey_keyword_id integer NOT NULL
+ALTER TABLE wfs_featuretype_keyword
+ ADD CONSTRAINT fkey_keyword_id_fkey_featuretype_id FOREIGN KEY (fkey_keyword_id) REFERENCES keyword(keyword_id) ON UPDATE CASCADE ON DELETE CASCADE;
+ ADD CONSTRAINT fkey_featuretype_id_fkey_keyword_id FOREIGN KEY (fkey_featuretype_id) REFERENCES wfs_featuretype(featuretype_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- new table layer_load_count
+CREATE TABLE layer_load_count (
+ fkey_layer_id int4,
+ load_count int8
+-- table wfs_conf
+ALTER TABLE wfs_conf add COLUMN wfs_conf_description text;
+ALTER TABLE `wfs_conf`
+ ADD CONSTRAINT wfs_conf_ibfk_2 FOREIGN KEY (fkey_featuretype_id) REFERENCES wfs_featuretype(featuretype_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- table wfs_conf_element: change in WFS configuration: access to geometries may now be restricted
+ALTER TABLE wfs_conf_element ADD COLUMN f_show_detail int4;
+ALTER TABLE wfs_conf_element ADD COLUMN f_operator VARCHAR(50);
+-- table gui_element: new column for translation
+-- ALTER TABLE gui_element ADD COLUMN e_title VARCHAR(255) NULL;
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','WFS',2,1,'edit wfs settings','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,1005,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT WFS','a','','','','AdminFrame','');
+ fkey_layer_id int(11),
+ load_count int(11)
+-- new table translation: new table for translations
+ CREATE TABLE translations
+ trs_id int(11) NOT NULL auto_increment,
+ locale varchar(8),
+ msgid varchar(512),
+ msgstr varchar(512),
+ PRIMARY KEY (trs_id)
+ CREATE INDEX msgid_idx ON translations(msgid);
+-- new function gettext for easy translations
+-- function has to be translated
+-- new entries for table translations
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Pan', 'Ausschnitt verschieben');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Display complete map', 'gesamte Karte anzeigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom in', 'In die Karte hineinzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom out', 'Aus der Karte herauszoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Back', 'Zurueck');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Forward', 'Nach vorne');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Coordinates', 'Koordinaten anzeigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom by rectangle', 'Ausschnitt waehlen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Redraw', 'Neu laden oder Tastatur: Leertaste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Query', 'Datenabfrage');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Logout', 'Abmelden');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'WMS preferences', 'WMS Einstellungen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS from filtered list', 'WMS von gefilteter Liste hinzufuegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set map center', 'Kartenmittelpunkt setzen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Help', 'Hilfe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Show WMS infos', 'Anzeige von WMS Informationen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Save workspace as web map context document', 'Ansicht als Web Map Context Dokument speichern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Resize Mapsize', 'Bildschirmgroesse anpassen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Rubber', 'Skizze loeschen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Get Area', 'Flaeche berechnen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Close Polygon', 'Polygon schliessen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Move back to your GUI list', 'Zurueck zur GUI Liste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Legend', 'Legende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Print', 'Druck');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Imprint', 'Impressum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Maps', 'Karten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Search', 'Suche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Meetingpoint', 'Treffpunkt');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Metadatasearch', 'Metadatensuche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS', 'WMS hinzufuegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS from List', 'WMS aus Liste hinzufuegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Change Projection', 'Projektion aendern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Digitize', 'Digitalisierung');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Overview', 'UEbersichtskarte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Drag Mapsize', 'Karte vergroessern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Mapframe', 'Kartenfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Navigation Frame', 'Navigationsfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scale Select', 'Auswahl des Massstabes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scale Text', 'Massstab per Texteingabe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scalebar', 'Massstabsleiste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set Background', 'Hintegrundkarte auswaehlen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom to Coordinates', 'Zu den Koordinaten zoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Change Password', 'Passwort aendern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Load a web map context document', 'laden eines Web Map Context Dokumentes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de ', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Pan', '???????? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Display complete map', '?????? ?????? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom in', '?????? ??????? ? ??-???? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom out', '?????? ??????? ? ??-?????? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Back', '?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Forward', '??????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Coordinates', '??????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom by rectangle', '??????? ??????? ? ????????? ??????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Redraw', '????????? ??? ?? ????????????: ?????? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Query', '????? ??? ???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Logout', '????? ?? ??????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'WMS preferences', 'WMS ?????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS from filtered list', '?????? WMS ?? ?????? ??????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Set map center', '??????? ?????? ?? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Help', '?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Show WMS infos', '?????? WMS ??????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Save workspace as web map context document', '?????? ???????? ???????? ???? Web Map Context ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Resize Mapsize', '??????? ?????????? ?? ???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Rubber', '??????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Get Area', '??????? ????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Close Polygon', '??????? ???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Move back to your GUI list', '????? ??? ??????? ? ?????????? (GUI)');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Legend', '???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Print', '?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Imprint', '???????? ????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Maps', '?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Search', '???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Meetingpoint', '????? ?? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Metadatasearch', '??????? ?? ?????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS', '?????? WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS from List', '?????? WMS ?? ??????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Info', '??????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Change Projection', '??????? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Copyright', '???????? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Digitize', '??????????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Overview','??????? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Drag Mapsize', '??????? ??????? ?? ???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Mapframe', '????? ?? ???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Navigation Frame', '???????????? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scale Select', '????? ?? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scale Text', '?????? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scalebar', '??????? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Set Background', '?????? ?????? ???????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom to Coordinates', '?????? ??????? ????? ?????????? ??????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Change Password', '??????? ??????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Load a web map context document', '?????? Web Map Context ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Logo', '?????? ????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Measure distance', '?????? ??????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Pan', '??????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Display complete map', '???????? ??????? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom in', 'Zoom In');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom out', 'Zoom Out');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Back', '????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Forward', '???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Coordinates', '?????????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom by rectangle', '???? ??? ?????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Redraw', '????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Query', '??????? ???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Logout', '??????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'WMS preferences', '??????? ?? ??????? ??? WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS from filtered list', '???????? WMS ??? ?? ????????????? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Set map center', '?? ??????????? ?????? ??????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Help', '???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Save workspace as web map context document', 'Ansicht als Web Map Context Dokument speichern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Rubber', '?? ???????- ???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Close Polygon', '?? ??????? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ( 'gr', 'Move back to your GUI list', '?????????? ??? GUI ?????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Print', '????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Maps', ' ??????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS', '???????? WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS from List', '???????? WMS ??? ??? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Navigation Frame', 'Navigationsfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Load a web map context document', 'laden eines Web Map Context Dokumentes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Measure distance', '??????? ?????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Meetingpoint', '?????? ??????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Info', '???????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Digitize', '???????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Change Projection', '?????? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Set Background', '??????? ??????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Overview', '?????????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Change Password', '?????? ????????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scalebar', '??????? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr ', 'Logo', '????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom to Coordinates', '??????? ?? ?????????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scale Text', '??????? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Show WMS infos', '??????? WMS ???????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Legend', '???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Search', '?????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Resize Mapsize', '?????? ???????? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Drag Mapsize', '?????? ???????? ????? ?? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Mapframe', '??????? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Get Area', '??????? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Imprint', '?????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scale Select', '??????? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Metadatasearch', '????????? ??? Metadata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Pan', 'Selectie verschuiven');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Display complete map', 'Hele kaart tonen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom in', 'Inzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom out', 'Uitzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Back', 'Terug');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Forward', 'Voorwaarts');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Coordinates', 'Koordinaten tonen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom by rectangle', 'Zoom rechthoek-selectie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Redraw', 'Opfrissen of toetsenbord : spatiebalk');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Query', 'Data opvragen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Logout', 'Afmelden');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'WMS preferences', 'WMS instellingen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS from filtered list', 'WMS van gefilterte lijst toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set map center', 'Kaartmiddelpunt aangeven');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Help', 'Help');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Show WMS infos', 'Tonen van WMS Informatie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Save workspace as web map context document', 'zicht als Web map context dokument bewaren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Resize Mapsize', 'beeldschermgrote aanpassen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Rubber', 'schets verwerpen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Get Area', 'oppervlakte berekenen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Close Polygon', 'Polygoon sluiten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Move back to your GUI list', 'Terug naar GUI lijst');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Legend', 'Legende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Print', 'Drukken');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Imprint', 'Impressum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Maps', 'Kaarten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Search', 'Zoek');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Meetingpoint', 'Trefpunt');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Metadatasearch', 'Zoeken naar Metadata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS', 'WMS toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS from List', 'WMS uit lijst toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Info', 'Informatie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Change Projection', 'Projektie veranderen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Digitize', 'Digitaliseren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Overview', 'overzichtskaart');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Drag Mapsize', 'Kaart vergroten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Mapframe', 'Kaartvenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Navigation Frame', 'Navigeervenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scale Select', 'Schaal selecteren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scale Text', 'Schaal via tekstingave');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scalebar', 'Schaalbalk');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set Background', 'Achtergrond selecteren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom to Coordinates', 'Naar koordinaten zoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Change Password', 'Paswoord wijzigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Load a web map context document', 'Laad een Web Map Context Dokument');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Measure distance', 'Meet afstand');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Pan', 'Sposta dettaglio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Display complete map', 'Mostra tutta la mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom in', 'Ingrandisci');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom out', 'Riduci');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Back', 'Indietro');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Forward', 'Avanti');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Coordinates', 'Mostra coordinate');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom by rectangle', 'Seleziona dettaglio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Redraw', 'Ridisegna oppure, da tastiera: spazio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Query', 'Interroga');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Logout', 'Logout');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'WMS preferences', 'Impostazioni WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS from filtered list', 'Aggiungi un WMS da una lista filtrata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set map center', 'Fissa il centro della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Help', 'Aiuto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Show WMS infos', 'Mostra informazioni sul WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Save workspace as web map context document', 'Salva vista come documento di Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Resize Mapsize', 'Adatta la dimensione della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Rubber', 'Cancella bozza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Get Area', 'Calcola area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Close Polygon', 'Chiudi poligono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Move back to your GUI list', 'Torna alla lista delle GUI');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Legend', 'Legenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Print', 'Stampa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Imprint', 'Colophon');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Maps', 'Mappe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Search', 'Cerca');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Meetingpoint', 'Punti di incontro');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Metadatasearch', 'Ricerca metadati');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS', 'Aggiungi WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS from List', 'Aggiungi WMS da lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Change Projection', 'Cambia proiezione');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Digitize', 'Digitalizza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Overview', 'Mappa di insieme');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Drag Mapsize', 'Cambia dimensione mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Mapframe', 'Quadro della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Navigation Frame', 'Quadro di navigazione');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scale Select', 'Scelta della scala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scale Text', 'Scala dei testi');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scalebar', 'Scala di riferimento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set Background', 'Seleziona mappa di sfondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom to Coordinates', 'Ingrandisci alle coordinate');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Change Password', 'Cambia password');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Load a web map context document', 'Carica un documento Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Measure distance', 'Misura distanza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Pan', 'Desplazamiento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Display complete map', 'Desplazamiento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom in', 'Zoom +');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom out', 'Zoom -');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Back', 'Zoom previo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Forward', 'Zoom siguiente');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Coordinates', 'Mostrar coordenadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom by rectangle', 'Zoom rectangulo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Redraw', 'Refrescar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Query', 'Busqueda de datos');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Logout', 'Terminar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'WMS preferences', 'Ajuste WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS from filtered list', 'Anadir WMS desde lista filtrada');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set map center', 'Centrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Help', 'Ayuda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Show WMS infos', 'Mostrar informacion sobre WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Save workspace as web map context document', 'Guardar vista como fichero Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Resize Mapsize', 'Modificar el tamano de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Rubber', 'Borrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Get Area', 'Calcular area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Close Polygon', 'Cerrar poligono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Move back to your GUI list', 'Volver a la lista WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Legend', 'Leyenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Print', 'Imprimir');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Imprint', 'Aviso legal');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Maps', 'Mapas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Search', 'Busqueda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Meetingpoint', 'Lugar de reunion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Metadatasearch', 'Busqueda de datos meta');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS', 'Anadir WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS from List', 'Anadir WMS desde lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Info', 'Informacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Change Projection', 'Cambiar projecto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Digitize', 'Digitalizacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Overview', 'Mapa de vision general');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Drag Mapsize', 'Ampilar vista de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Mapframe', 'Ventana de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Navigation Frame', 'Ventana de navigacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scale Select', 'Selecionar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scale Text', 'Teclar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scalebar', 'Fraja de escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set Background', 'Poner el fondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom to Coordinates', 'Zoom en coordenadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Change Password', 'Cambiar clave');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Load a web map context document', 'Cargar un documento de Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Measure distance', 'Medir distancias');
+-- new table gui_kml
+CREATE TABLE gui_kml (
+ kml_id int(11) NOT NULL auto_increment,
+ fkey_mb_user_id int(11) NOT NULL,
+ fkey_gui_id varchar(50) NOT NULL,
+ kml_doc text NOT NULL,
+ kml_name varchar(64),
+ kml_description text,
+ kml_timestamp int(11) NOT NULL,
+ PRIMARY KEY (kml_id)
+ALTER TABLE gui_kml
+ADD CONSTRAINT gui_kml_fkey_mb_user_id FOREIGN KEY (fkey_mb_user_id)
+REFERENCES mb_user(mb_user_id) MATCH SIMPLE ON UPDATE CASCADE ON DELETE CASCADE;
+ADD CONSTRAINT gui_kml_id_fkey_gui_id FOREIGN KEY (fkey_gui_id)
+REFERENCES gui(gui_id) MATCH SIMPLE ON UPDATE CASCADE ON DELETE CASCADE;
+-- new SLD table
+CREATE TABLE sld_user_layer (
+ sld_user_layer_id int(11) NOT NULL auto_increment,
+ fkey_mb_user_id int(11) NOT NULL default '0',
+ fkey_layer_id int(11) NOT NULL default '0',
+ fkey_gui_id varchar(50) NOT NULL default '',
+ sld_xml text,
+ use_sld tinyint(1) default '0',
+ PRIMARY KEY (sld_user_layer_id)
+) TYPE=InnoDB;
+-- constraints for new table sld_user_layer
+ALTER TABLE sld_user_layer ADD CONSTRAINT sld_user_layer_ibfk1 FOREIGN KEY (fkey_mb_user_id) REFERENCES mb_user (mb_user_id) ON DELETE CASCADE ON UPDATE CASCADE;
+ALTER TABLE sld_user_layer ADD CONSTRAINT ADD CONSTRAINT sld_user_layer_ibfk2 FOREIGN KEY (fkey_layer_id) REFERENCES layer (layer_id) ON DELETE CASCADE ON UPDATE CASCADE;
+ALTER TABLE sld_user_layer ADD CONSTRAINT ADD CONSTRAINT sld_user_layer_ibfk3 FOREIGN KEY (fkey_gui_id) REFERENCES gui (gui_id) ON DELETE CASCADE ON UPDATE CASCADE;
+-- add sld related columns
+ALTER TABLE gui_wms ADD COLUMN gui_wms_sldurl varchar(255) NOT NULL default '';
+ALTER TABLE wms ADD COLUMN wms_supportsld boolean NULL;
+ALTER TABLE wms ADD COLUMN wms_userlayer boolean NULL;
+ALTER TABLE wms ADD COLUMN wms_userstyle boolean NULL;
+ALTER TABLE wms ADD COLUMN wms_remotewfs boolean NULL;
+-- opacity handeling
+ALTER TABLE gui_wms ADD COLUMN gui_wms_opacity INT DEFAULT 100;
+UPDATE gui_element SET e_mb_mod = 'mod_addWMSgeneralFunctions.js' WHERE e_id = 'addWMS';
+ALTER TABLE gui_element MODIFY e_js_file character varying(255);
+ALTER TABLE gui_element MODIFY e_mb_mod character varying(255);
+ALTER TABLE wms MODIFY fees text;
+ALTER TABLE wms CHANGE COLUMN wms_mb_getcapabilies_doc wms_mb_getcapabilities_doc text;
\ No newline at end of file
Added: trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_mysql_ISO-8859-1.sql
--- trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_mysql_ISO-8859-1.sql (rev 0)
+++ trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_mysql_ISO-8859-1.sql 2009-03-17 16:16:15 UTC (rev 3779)
@@ -0,0 +1,11 @@
+-- database changes in version 2.5.1
+DELETE FROM wfs_conf_element WHERE f_id NOT IN (SELECT DISTINCT element_id AS f_id FROM wfs_element);
+ALTER TABLE `wfs_element`
+ ADD CONSTRAINT wfs_element_element_id_key UNIQUE (element_id);
+ALTER TABLE `wfs_conf_element`
+ ADD CONSTRAINT wfs_conf_element_id_ibfk_1 FOREIGN KEY (f_id) REFERENCES wfs_element (element_id) ON UPDATE CASCADE ON DELETE CASCADE;
Added: trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_mysql_ISO-8859-1.sql
--- trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_mysql_ISO-8859-1.sql (rev 0)
+++ trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_mysql_ISO-8859-1.sql 2009-03-17 16:16:15 UTC (rev 3779)
@@ -0,0 +1,19 @@
+UPDATE gui_element SET e_closetag = '' WHERE e_element = 'img';
+-- translations missing for bg,gr,nl
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set language', 'Sprache auswählen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set language', 'Seleccion del idioma');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set language', 'Lingua');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Set language', 'Choisir une langue');
+-- enlarge WFS metadata columns
+ALTER TABLE wfs_featuretype MODIFY featuretype_abstract text;
+ALTER TABLE wfs_featuretype MODIFY featuretype_title varchar(255);
+ALTER TABLE wfs_featuretype MODIFY featuretype_name varchar(255) NOT NULL DEFAULT '';
+ALTER TABLE wfs_element MODIFY element_name varchar(255);
+ALTER TABLE wfs_element MODIFY element_type varchar(255);
Added: trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.5rc6_to_2.5_mysql_ISO-8859-1.sql
--- trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.5rc6_to_2.5_mysql_ISO-8859-1.sql (rev 0)
+++ trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_2.5rc6_to_2.5_mysql_ISO-8859-1.sql 2009-03-17 16:16:15 UTC (rev 3779)
@@ -0,0 +1 @@
+DELETE FROM gui_treegde WHERE fkey_gui_id IN ('gui', 'gui1', 'admin1', 'gui2', 'wms_africa');
Added: trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_mysql_ISO-8859-1.sql
--- trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_mysql_ISO-8859-1.sql (rev 0)
+++ trunk/mapbender/resources/db/mysql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_mysql_ISO-8859-1.sql 2009-03-17 16:16:15 UTC (rev 3779)
@@ -0,0 +1,901 @@
+-- update of mapbender guis
+-- gui / gui1 / gui2 / gui_digitize
+-- admin1 / admin2_de / admin2_de / admin_de_services / admin_en_services
+-- Mapbender Test for Version: 2.5
+-- 2008-09-29
+-- notice: this guis are not all working properly
+-- the guis contain the e_title informations fpor i18n
+-- these sql are for developers to get the guis working
+Delete from gui_element where fkey_gui_id ='gui';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','FeatureInfoRedirect',2,1,'redirect featureInfoRequests in an iframe for each wms','Info','iframe','../html/mod_blank.html','frameborder="0"',83,-17,1,1,0,'','','iframe','mod_featureInfoRedirect.php','','','','http://www.mapbender.org/index.php/FeatureInfoRedirect');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','WMS_preferences',2,1,'configures the preferences of each loaded wms','WMS preferences','img','../img/button_gray/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',540,10,24,24,1,'','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_gray/add_off.png','onclick=''mod_addWMS()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',515,10,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','back',2,1,'History.back()','Back','img','../img/button_gray/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"',360,10,24,24,1,'','','','mod_back.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','body',1,1,'body (obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','featureInfo1',2,0,'FeatureInfoRequest','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')"',425,10,24,24,1,'','','','mod_featureInfoTunnel.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfoTunnel');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','forward',2,1,'History.forward()','Forward','img','../img/button_gray/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" ',385,10,24,24,1,'','','','mod_forward.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','gazetteerMetadata',2,1,'gazetteer for metadata','Metadatasearch','iframe','../php/mod_gazetteerMetadata.php?sessionID&target=mapframe1,overview','frameborder = "0"',1,1,1,1,4,'visibility:hidden;','','iframe','','','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','Search','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','geometry.js','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" ',620,10,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','highlightPOI',2,1,'highlight 1 to n pois in your gui with a Symbol and a special text','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_highlightPOI.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','imprint',2,1,'Information about the owner of the gui','Imprint','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_back',3,1,'layout, background for buttons','','div','','',360,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_featureInfo',3,1,'layout, background for FeatureInfo','','div','','',425,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_help',3,1,'layout, background for Help-button','','div','','',620,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_logout',3,1,'layout, background for Logout-button','','div','','',660,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_metadata',3,1,'layout, background for Metadata','','div','','',580,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_wms',3,1,'layout, background for wms','','div','','',490,10,76,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_zoom',3,1,'layout, background for Zoom-button','','div','','',220,10,126,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','loadData',2,1,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','logo',2,1,'Logo','Logo','img','../img/mapbender_logo.png','',20,20,180,26,5,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' ',660,10,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','mapframe1',2,1,'frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',230,55,500,450,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','meetingPoint',2,1,'create a meeting point','Meetingpoint','iframe','../php/mod_meetingPoint.php?sessionID','frameborder = "0" ',0,0,NULL ,NULL ,4,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_gray/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_gray/metadata_over.png"'' onmouseout=''this.src="../img/button_gray/metadata_off.png"'' ',580,10,24,24,1,'','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,0,0,0,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',30,65,150,130,100,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','pan1',2,1,'pan','Pan','img','../img/button_gray/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')" ',270,10,24,24,1,'','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','printPDF',2,1,'pdf print','Print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_gray/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')" ',295,10,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','setBBOX',2,0,'set extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','setBackground',2,1,'switch background-wms','Set Background','form','','',30,210,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','showCoords_div',2,1,'displays coodinates by onmouseover','Coordinates','img','../img/button_gray/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ',450,10,24,24,1,'','','','mod_coords_div.php','','mapframe1','dependendDiv','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','tabs',2,1,'vertical tabs to handle iframes','','div','','',10,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2','Maps','iframe','../html/mod_treefolder2.php?sessionID','frameborder = "0" ',10,220,200,300,NULL ,'visibility:visible','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_gray/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)" ',320,10,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_gray/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' ',220,10,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_gray/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''',245,10,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_all', '0', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_group', '0', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_gui', '0', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'gazetteerWFS', 'wfsConfIdString', '1', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_height', '14', 'height of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_width', '14', 'width of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_ccs_file', '../css/meetingPoint.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_format', 'prompt', 'decide which format to choose (email, prompt)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_subject', 'Ein Treffpunkt wurde erzeugt. Folgen Sie dem Link!', 'if you choose format email, define the text for the subject', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_height', '14', 'height of the meetingPoint_icon', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_icon', '../img/redball.gif', 'path to meetingPoint image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_max_characters', '70', 'define the maximum length of the text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_please_click', 'Please click in the map to define the meeting point position!', 'text to show if no clickposition is set', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_style', 'background-color:white;font-weight: bold;color:red;font-family:Arial;', 'style to display the meetingPoint text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_width', '14', 'width of the meetingPoint_icon', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[5]', '160', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[6]', '280', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[5]', 'meetingPoint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[6]', 'gazetteerMetadata', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_prefix', ' ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'menu', 'opacity_up,opacity_down,zoom,metainfo,hide,wms_up,wms_down,layer_up,layer_down,remove', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'metadatalink', 'false', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui1';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','WMS_preferences',2,1,'configure the preferences of each loaded wms','WMS preferences','img','../img/button_blink_red/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',670,60,24,24,1,'','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_blink_red/add_off.png','onclick=''mod_addWMS()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',645,60,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMSfromList',2,1,'add a WMS to the running application from a list','Adding WMS from List','img','../img/button_blink_red/addlist_off.png','onclick=''window.open("../javascripts/mod_addWMSfromList.php?sessionID","printWin","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',595,60,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',620,60,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','back',2,1,'History.back()','Back','img','../img/button_blink_red/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" ',400,60,24,24,1,'','','','mod_back.php','','mapframe1,overview','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','body',1,1,'body (obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','center1',2,1,'Center button','Set map center','img','../img/button_blink_red/center_off.png','onmouseover = "mb_regButton(''init_gui1_center'')" ',310,60,24,24,1,'','','','mod_center1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','changeEPSG',2,1,'change EPSG, Postgres required, overview is targed for full extent','Change Projection','iframe','../php/mod_changeEPSG.php?sessionID','scrolling="no" frameborder=''0'' ',432,25,107,24,1,'','','iframe','','','overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','changePassword_button',2,1,'button: change password of logged user','Change Password','img','../img/button_blink_red/change_password_off.png','onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0'' onmouseover=''this.src="../img/button_blink_red/change_password_over.png"'' onmouseout=''this.src="../img/button_blink_red/change_password_off.png"'' ',750,60,24,24,1,'cursor:hand','','','','','','','http://www.mapbender.org/index.php/ChangePassword');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','closePolygon',3,1,'close Polygon ','Close Polygon','div','','',0,0,0,0,0,'','','div','mod_closePolygon.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',-59,1,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',-59,1,0,0,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','featureInfo1',2,1,'FeatureInfoRequest','Query','img','../img/button_blink_red/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')" ',465,60,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','forward',2,1,'History.forward()','Forward','img','../img/button_blink_red/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" ',425,60,24,24,1,'','','','mod_forward.php','','mapframe1,overview','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','getArea',3,1,'Calculation of area, Postgis required','Get Area','div','','',0,0,0,0,0,'','','div','mod_getArea.php','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','help',2,1,'button help','Help','img','../img/button_blink_red/help_off.png','onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")''',790,60,24,24,1,'','','','','','','','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','help1',2,1,'button help','Help','img','../img/button_blink_red/help_off.png','onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")''',790,60,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/help');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','highlightPOI',2,1,'highlight 1 to n pois in your gui with a Symbol and a special text','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_highlightPOI.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','layout_1',3,1,'layout, background for buttons','','div','','',208,58,670,28,0,'background-color:#FFFFFF;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&wms_legend = yes','frameborder=''0''',-59,200,180,600,3,'','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','loadData',2,1,'IFRAME to load data','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','loadwmc',2,1,'load workspace from WMC','Load a web map context document','img','../img/button_blink_red/wmc_load_off.png','onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',895,60,24,24,1,'','','','mod_loadwmc.php','','mapframe1','','http://www.mapbender.org/index.php/LoadWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','logout',2,1,'Logout','Logout','img','../img/button_blink_red/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blink_red/logout_over.png"'' onmouseout=''this.src="../img/button_blink_red/logout_off.png"'' ',830,60,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',-59,1,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','mapframe1',2,1,'Frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',220,105,625,400,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','measure',2,1,'Measure','Measure distance','img','../img/button_blink_red/measure_off.png','onmouseover = "mb_regButton(''init_mod_measure'')"',515,60,24,24,1,'','','','mod_measure.php','','mapframe1','','http://www.mapbender.org/index.php/Measure');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_blink_red/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_blink_red/metadata_over.png"'' onmouseout=''this.src="../img/button_blink_red/metadata_off.png"'' ',710,60,24,24,1,'','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,0,0,10,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',15,25,150,150,2,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','pan1',2,1,'pan','Pan','img','../img/button_blink_red/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')"',260,60,24,24,1,'','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','print1',2,0,'start print GUI','Print','img','../img/button_blink_red/print_off.png','onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID","printWin","width=300, height=400, resizable=yes ")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',555,60,24,24,1,'','','','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','printPDF',2,1,'start print GUI','Print','img','../img/button_blink_red/print_off.png','onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF_b.conf","printWin","width=180, height=200, resizable=yes ")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',555,60,24,24,1,'','','','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','repaint',2,1,'refresh a mapobject','Redraw','img','../img/button_blink_red/repaint_off.png','onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)'' ',360,60,24,24,1,'','','','mod_repaint.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','rubber',3,1,'deletes temporary (digitized) objects','Rubber','div','','',0,0,0,0,0,'','','div','mod_rubber.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',0,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','savewmc',2,1,'save workspace as WMC','Save workspace as web map context document','img','../img/button_blink_red/wmc_save_off.png','onclick=''mod_savewmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',870,60,24,24,1,'','','','mod_savewmc.php','','mapframe1','','http://www.mapbender.org/index.php/SaveWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scaleSelect',2,1,'Scale-Selectbox','Scale Select','select','','onchange=''mod_scaleSelect(this)''',555,25,100,20,1,'','<option value = ''''>Scale</option> <option value=''100''>1 : 100</option> <option value=''250''>1 : 250</option> <option value=''500''>1 : 500</option> <option value=''1000''>1 : 1000</option> <option value=''2500''>1 : 2500</option> <option value=''5000''>1 : 5000</option> <option value=''10000''>1 : 10000</option> <option value=''25000''>1 : 25000</option> <option value=''30000''>1 : 30000</option> <option value=''50000''>1 : 50000</option> <option value=''75000''>1 : 75000</option> <option value=''100000''>1 : 100000</option> <option value=''200000''>1 : 200000</option> <option value=''300000''>1 : 300000</option> <option value=''400000''>1 : 400000</option> <option value=''500000''>1 : 500000</option> <option value=''600000''>1 : 600000</option> <option value=''700000''>1 : 700000</option> <option value=''800000''>1 : 800000</option> <option value=''900000''>1 : 900000</option> <option value=''1000000''>1 : 1000000</option>','select','mod_scaleSel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scaleText',2,1,'Scale-description field','Scale Text','form','','onsubmit=''return mod_scaleText()''',672,25,100,30,0,'','<input type="text">','form','mod_scaleText.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scalebar',2,1,'scalebar','Scalebar','div','','',0,0,0,0,0,'','','div','mod_scalebar.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_blink_red/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')"',285,60,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBBOX',2,1,'set Extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBackground',2,0,'switch background-wms','Set Background','form','','',15,190,0,0,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBackground_all',2,0,'switch all background-wms','Set Background','form','','',157,190,40,20,1,'','<input type=''checkbox'' onclick=''mod_setBackground_all_init(this)''> <font face="Arial, sans-serif" size="2">all</font>','form','mod_setBackground_all.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setPOI2Scale',2,1,'zoom to a poi (get-parameter)','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_setPOI2Scale.php','','mapframe1','','http://www.mapbender.org/index.php/Mod_setPoi2Scale');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setScaleHint',1,0,'set scaleHint for mapframes','','div','','',1,1,1,1,0,'visibility:hidden;','','div','mod_scaleHint.php','','mapframe1,100,10000000','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','showCoords_div',2,1,'displays coordinates by onmouseover','Coordinates','img','../img/button_blink_red/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ',490,60,24,24,1,'','','','mod_coords_div.php','','mapframe1','','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeConfGDE',2,0,'configurable directory tree','Maps','iframe','../php/mod_treefolderClient.php?sessionID','frameborder = "0" ',0,180,250,500,0,'visibility:visible','','iframe','mod_treeConf.js','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeGDE_1',2,0,'directory tree, checkbox for visible, checkbox for querylayer, no immediate refreshing, with nested layers','Maps','iframe','../html/mod_sync_treefolder_1.html','frameborder = "0" ',0,180,250,500,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','wfs_gazetteer',2,0,'gazetteer using wfs','Search','iframe','../php/mod_wfs_gazetteer.php?sessionID&color=255,0,255','frameborder = "0" ',-50,490,250,300,0,'visibility:visible','','iframe','','','mapframe1,overview','wfs','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomCoords',2,1,'zoom to coordinate','Zoom to Coordinates','iframe','../php/mod_zoomCoords_en.php?sessionID','frameborder = "0" ',205,7,220,45,0,'','','iframe','','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_blink_red/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)" ',335,60,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_blink_red/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' ',210,60,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_blink_red/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' ',235,60,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_db', '0', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_height', '25', 'height of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_width', '25', 'width of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'css_file_legend', '../css/legend.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'stickylegend', 'true', 'parameter to decide wether the legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'logout', 'logout_location', 'http://www.mapbender.org/', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'setPOI2Scale', 'mod_setPOI2Scale_defScale', '5000', 'default scale', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'menu', '', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui2';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','WMS_preferences',2,1,'configures the preferences of each loaded wms','WMS preferences','img','../img/button_blue/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',604,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_blue/add_off.png','onclick=''mod_addWMS()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',580,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blue/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',553,40,28,28,1,'filter:Chroma(color=#C2CBCF);','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','back',2,1,'History.back()','Back','img','../img/button_blue/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"',398,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_back.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','body',1,1,'body
+(obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'background-image:url(../img/background_yellow.jpg);background-repeat:repeat-x;','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','center1',2,1,'Center button','Set map center','img','../img/button_blue/center_off.png','onmouseover = "mb_regButton(''init_gui1_center'')"',308,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_center1.php','','mapframe1','','http://www.mapbender.org/index.php/ReCenter');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','changePassword_button',2,1,'button: change password of logged user','Change Password','img','../img/button_blue/change_password_off.png','onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0''
+onmouseover=''this.src="../img/button_blue/change_password_over.png"'' onmouseout=''this.src="../img/button_blue/change_password_off.png"''',668,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','','','http://www.mapbender.org/index.php/ChangePassword');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','closePolygon',3,1,'close Polygon ','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_closePolygon.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#799FEB; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dynamicOverview',2,1,'oveview acts in accordance with main mapframe','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','mod_dynamicOverview.php','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','featureInfo1',2,0,'FeatureInfoRequest','Query','img','../img/button_blue/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','Query','img','../img/button_blue/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')"',461,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_featureInfoTunnel.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfoTunnel');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','forward',2,1,'History.forward()','Forward','img','../img/button_blue/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()"',423,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_forward.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','Search','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','geometry.js','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','getArea',3,1,'Calculation of area, Postgis required','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_getArea.php','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','header_yellow',2,0,'header','','img','../img/header_yellow.jpg','',-1,-1,833,75,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','help',2,1,'button help','Help','img','../img/button_blue/help_off.png','onmouseover = "mb_regButton(''init_help'')"',693,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','imprint',2,1,'Information about the owner of the gui','Imprint','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','layout_linie',3,0,'layout','','div','','',1,70,830,1,1,'background-color:#799FEB;font-size:1px;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','layout_linie2',3,0,'layout','','div','','',1,35,830,1,1,'background-color:#799FEB;font-size:1px;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','loadData',2,1,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','loadwmc',2,1,'load workspace from WMC','Load a web map context document','img','../img/button_blue/wmc_load_off.png','onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");''',758,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_loadwmc.php','','mapframe1','','http://www.mapbender.org/index.php/LoadWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','logo',2,1,'Logo','Logo','img','../img/mapbender_oo.png','',10,35,129,32,5,'filter:Chroma(color=#C2CBCF);','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','logout',2,1,'Logout','Logout','img','../img/button_blue/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blue/logout_over.png"'' onmouseout=''this.src="../img/button_blue/logout_off.png"''',798,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','mapframe1',2,1,'frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',213,90,608,467,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','measure',2,1,'Measure','Measure distance','img','../img/button_blue/measure_off.png','onmouseover = "mb_regButton(''init_mod_measure'')"',513,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_measure.php','','mapframe1','','http://www.mapbender.org/index.php/Measure');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_blue/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0''
+onmouseover=''this.src="../img/button_blue/metadata_over.png"'' onmouseout=''this.src="../img/button_blue/metadata_off.png"''',643,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,0,0,0,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>
+<div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>
+<div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>
+<div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div>
+<div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div>
+<div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>
+<div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>
+<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',9,80,185,130,100,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','pan1',2,1,'pan','Pan','img','../img/button_blue/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')"',258,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','printPDF',2,1,'pdf print','Print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','repaint',2,1,'refresh a mapobject','Redraw','img','../img/button_blue/repaint_off.png','onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)''',358,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_repaint.php','','mapframe1','','http://www.mapbender.org/index.php/Repaint');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','resizeMapsize',2,1,'resize mapsize to browser window size','Resize Mapsize','img','../img/button_blink_red/resizemapsize_off.png','onclick = "adjustDimension()"
+onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',838,40,24,24,3,'filter:Chroma(color=#C2CBCF);','','','mod_resize_mapsize.php','','mapframe1','','http://www.mapbender.org/index.php/ResizeMapsize');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','rubber',3,1,'deletes temporary (digitized) objects','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_rubber.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','savewmc',2,1,'save workspace as WMC','Save workspace as web map context document','img','../img/button_blue/wmc_save_off.png','onclick=''mod_savewmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',733,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_savewmc.php','','mapframe1','','http://www.mapbender.org/index.php/SaveWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_blue/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')"',283,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','setBBOX',2,0,'set extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','setBackground',2,1,'switch background-wms','Set Background','form','','',10,218,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','showCoords_div',2,1,'displays coodinates by onmouseover','Coordinates','img','../img/button_blue/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')"',488,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_coords_div.php','','mapframe1','dependendDiv','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','tabs',2,1,'vertical tabs to handle iframes','','div','','',2,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2','Maps','iframe','../html/mod_treefolder2.php?sessionID','frameborder = "0" ',10,220,200,300,NULL ,'visibility:visible','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_blue/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"',333,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_blue/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)''',203,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_blue/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''',231,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_class_bg', 'body{background-color: #FEF8D4;}', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_minScale', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_startExtent', '-24.5,32,34.5,71', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_useMaxExtent', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_wmsIndex', '0', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_zoomFactor', '5', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'gazetteerWFS', 'wfsConfIdString', '1', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_height', '-35', 'to adjust the height of the mapframe on the bottom of the window', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_width', '-45', 'to adjust the width of the mapframe on the right side of the window', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'resize_option', 'button', 'auto (autoresize on load), button (resize by button)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'sandclock', 'mod_sandclock_image', '../img/sandclock_oo.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_prefix', ' ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid #FDCC1A;font-size:12;color:#FFFFFF;background-color:#799FEB;cursor:pointer;margin-top:-3px; padding-top:3px;padding-left:4px;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'menu', 'opacity_up,opacity_down,zoom,metainfo,hide,wms_up,wms_down,layer_up,layer_down,remove', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui_digitize';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','FeatureInfoRedirect',2,0,'redirect featureInfoRequests in an iframe for each wms','Info','iframe','../html/mod_blank.html','frameborder="0"',83,-17,1,1,NULL ,'','','iframe','mod_featureInfoRedirect.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','WMS_preferences',2,1,'configures the preferences of each loaded wms','WMS preferences','img','../img/button_gray/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");''',540,10,24,24,1,'','','','','','mapframe1,treeGDE','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_gray/add_off.png','onclick=''mod_addWMS()''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");''',515,10,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','back',2,1,'History.back()','Back','img','../img/button_gray/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"',360,10,24,24,1,'','','','mod_back.php','','mapframe1,overview0','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','body',1,1,'body (obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','closePolygonExt',3,0,'close Polygon ','Close Polygon','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_closePolygonExt.js','','mapframe1','setExtRequest','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_copyright.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','digitize',2,1,'Digitize tool.','Digitize','iframe','../javascripts/mod_digitize_tab.php?sessionID','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','geometry.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','featureInfo1',2,0,'FeatureInfoRequest','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')"',425,10,24,24,1,'','','','mod_featureInfoTunnel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','forward',2,1,'History.forward()','Forward','img','../img/button_gray/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()"',385,10,24,24,1,'','','','mod_forward.php','','mapframe1,overview0','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','Search','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','geometry.js','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',620,10,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','imprint',2,1,'Information about the owner of the gui','Imprint','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','initWmc',2,0,'initialise client with wmc','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_initWmc.php','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_1',3,0,'Warning notice','','div','','',150,250,300,16,100,'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none;','Development Version - Work in Progress!','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_back',3,1,'layout, background for buttons','','div','','',360,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_featureInfo',3,1,'layout, background for FeatureInfo','','div','','',425,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_help',3,1,'layout, background for Help-button','','div','','',620,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_logout',3,1,'layout, background for Logout-button','','div','','',660,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_metadata',3,1,'layout, background for Metadata','','div','','',580,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_wms',3,1,'layout, background for wms','','div','','',490,10,76,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_zoom',3,1,'layout, background for Zoom-button','','div','','',220,10,126,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','loadData',2,1,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','loadwmc',2,0,'load workspace from WMC','Load a web map context document','img','../img/button_wmc/wmc_load.png','onclick=''mod_loadwmc()'' onmouseover=''mod_loadwmc_init(this)''',760,10,24,24,1,'','','','mod_loadwmc.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','logo',2,1,'Logo','','img','../img/mapbender_logo.png','',20,20,180,26,5,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''
+onmouseover=''this.src="../img/button_gray/logout_over.png"''
+onmouseout=''this.src="../img/button_gray/logout_off.png"''',660,10,24,24,1,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr>
+<script language="javascript">
+mb_registerSubFunctions("mod_mapbender()");
+function mod_mapbender(){
+document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90;
+document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1;
+</script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','mapframe1',2,1,'frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',230,55,500,450,2,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_gray/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''"
+border=''0''
+onmouseover=''this.src="../img/button_gray/metadata_over.png"''
+onmouseout=''this.src="../img/button_gray/metadata_off.png"''',580,10,24,24,1,'','','','mod_displayObj.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,NULL ,NULL ,NULL ,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>
+<div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>
+<div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>
+<div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div>
+<div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div>
+<div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>
+<div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>
+<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>
+','div','mod_navFrame.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',30,65,150,130,100,'','','iframe','','mod_box1.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','pan1',2,1,'pan','Pan','img','../img/button_gray/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')"',270,10,24,24,1,'','','','mod_pan.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','printPDF',2,1,'pdf print','Print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','rubberExt',3,1,'deletes temporary (digitized) objects','Rubber','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_rubberExt.js','','mapframe1','setExtRequest','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','savewmc',2,0,'save workspace as WMC','Save workspace as web map context document','img','../img/button_wmc/wmc_save.png','onclick=''mod_savewmc()'' onmouseover=''mod_savewmc_init(this)''',730,10,24,24,1,'','','','mod_savewmc.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','scaleSelect',2,0,'Scale-Selectbox','Scale Select','select','','onchange=''mod_scaleSelect(this)''',555,25,100,20,1,'','<option value = ''''>Scale</option>
+<option value=''100''>1 : 100</option>
+<option value=''250''>1 : 250</option>
+<option value=''500''>1 : 500</option>
+<option value=''1000''>1 : 1000</option>
+<option value=''2500''>1 : 2500</option>
+<option value=''5000''>1 : 5000</option>
+<option value=''10000''>1 : 10000</option>
+<option value=''25000''>1 : 25000</option>
+<option value=''30000''>1 : 30000</option>
+<option value=''50000''>1 : 50000</option>
+<option value=''75000''>1 : 75000</option>
+<option value=''100000''>1 : 100000</option>
+<option value=''200000''>1 : 200000</option>
+<option value=''300000''>1 : 300000</option>
+<option value=''400000''>1 : 400000</option>
+<option value=''500000''>1 : 500000</option>
+<option value=''600000''>1 : 600000</option>
+<option value=''700000''>1 : 700000</option>
+<option value=''800000''>1 : 800000</option>
+<option value=''900000''>1 : 900000</option>
+<option value=''1000000''>1 : 1000000</option>','select','mod_scaleSel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_gray/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')"',295,10,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setBBOX',2,0,'set extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setBackground',2,1,'switch background-wms','Set Background','form','','',30,210,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12''
+name=''mod_setBackground_list''
+onchange=''mod_setBackground_change(this)'' ><option
+value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setSpatialRequest',2,1,'Spatial Request','','div','','',1,1,1,1,1,'visibility:hidden;','','div','../javascripts/mod_wfs_SpatialRequest.php','geometry.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','showCoords_div',2,1,'displays coodinates by onmouseover','Coordinates','img','../img/button_gray/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ',450,10,24,24,1,'','','','mod_coords_div.php','','mapframe1','dependendDiv','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','showLoggedUser',2,0,'Displays current user','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','tabs',1,1,'vertical tabs to handle iframes','','div','','',10,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfs',2,1,'wfs request and result handling','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','wfs.js','../extensions/wz_jsgraphics.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfs_conf',2,1,'get all wfs_conf-params','','iframe','../php/mod_wfs.php','frameborder = "0"',1,1,1,1,0,'visibility:hidden','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfsresult',2,1,'display the list of wfs results','','iframe','../html/mod_blank.html','frameborder = "0"',10,730,200,150,4,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_gray/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"',320,10,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_gray/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)''',220,10,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_gray/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''',245,10,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'cssUrl', '../css/digitize.css', 'url to the style sheet of the mapframe', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'digitize_conf_filename', 'digitize_default.conf', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'text css', ' body{
+ font-family: Arial, Helvetica, sans-serif;
+ font-size : 12px;
+ color: #ff00ff;
+ background-color: #ffffff;
+ margin-top: 0px;
+ margin-left: 0px;
+ .button{
+ height: 18px;
+ width: 32px;
+', 'text css', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'wfsCssUrl', '../css/mapbender.css', 'var', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'gazetteerWFS', 'wfsConfIdString', '1,2,3,4', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'useUsemap', '0', '"1" adds a usemap to each geometry; the geometry will be highlighted onMouseOver. Every other value will skip the usemap.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'wfs_conf_filename', 'wfs_default.conf', 'location and name of the WFS configuration file', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'open_tab', '5', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[5]', '250', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[5]', 'digitize', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_prefix', ' ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;padding-left:8px;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'menu', '', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'wfs', 'displayWfsResultList', '1', '', 'var');
+Delete from gui_element where fkey_gui_id ='admin1';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','AdminFrame',2,1,'the frame for administration modules','','iframe','','frameborder = "0"',220,20,800,800,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','CreateTreeGDE',2,1,'create a foldertree for a individual geodataexplorer','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,810,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','CREATE TREE_GDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','EditWMSMetadata',2,1,'edit the metadata of wms','edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,950,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT WMS-METADATA','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_Gui',2,1,'allocate groups to guis','','a','','href = "../php/mod_group_gui.php?sessionID&e_id_css=Group_Gui" target = "AdminFrame" ',10,610,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_User',2,1,'allocate groups to user','','a','','href = "../php/mod_group_user.php?sessionID&e_id_css=Group_User" target = "AdminFrame" ',10,550,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','GROUP -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_filteredGui',2,1,'allocate Groups to the guis of this admin','','a','','href = "../php/mod_group_filteredGui.php?sessionID&e_id_css=Group_filteredGui" target = "AdminFrame" ',10,710,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Gui_Group',2,1,'allocate guis to groups','','a','','href = "../php/mod_gui_group.php?sessionID&e_id_css=Gui_Group" target = "AdminFrame" ',10,250,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Gui_User',2,1,'allocate a gui to user','','a','','href = "../php/mod_gui_user.php?sessionID&e_id_css=Gui_User" target = "AdminFrame" ',10,190,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','User_Group',2,1,'allocat user to groups','','a','','href = "../php/mod_user_group.php?sessionID&e_id_css=User_Group" target = "AdminFrame" ',10,430,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','body',1,1,'navigation','','body','','onload=''mod_adminNavigation_init()''',0,0,0,0,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteGui',2,1,'delete gui','','a','','href = "../php/mod_deleteGUI.php?sessionID" target = "AdminFrame" ',10,150,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteWFS',2,1,'delete WFS','Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,890,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteWMS',2,1,'delete wms','Delete WMS completely','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,110,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','delete_filteredGui',2,1,'delete guis of this admin','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,790,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editElements',2,1,'edit gui elements','Edit GUI elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,170,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','EDIT GUI-ELEMENTS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editFilteredGroup',2,1,'edit group of this admin','Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',10,530,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editFilteredUser',2,1,'save, edit, delete user where this admin is owner','Create and edit user','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',10,350,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editGUI_WMS',2,1,'edit the elements of the gui','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,90,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT GUI-WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editGroup',2,1,'edit group','','a','','href = "../php/mod_editGroup.php?sessionID" target = "AdminFrame" ',10,510,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editUser',2,1,'save, edit, delete user','','a','','href = "../php/mod_editUser.php?sessionID" target="AdminFrame"',10,330,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','exportGUI',2,1,'export gui, create SQLL','export GUI, create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,310,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EXPORT GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGoup_filteredUser',2,1,'allocate the groups of this admin to user where the admin is owner','Add several users to one group','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',10,590,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> myUSER ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_Gui',2,1,'allocate groups of this admin to guis','','a','','href = "../php/mod_filteredGroup_Gui.php?sessionID&e_id_css=filteredGroup_Gui" target = "AdminFrame" ',10,750,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_User',2,1,'allocate groups of this admin to user','','a','','href = "../php/mod_filteredGroup_User.php?sessionID&e_id_css=filteredGroup_User" target = "AdminFrame" ',10,690,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_filteredGui',2,1,'allocate groups of this admin to guis of this admin','Allow one group access to several GUIs','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',10,730,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_Group',2,1,'allocate guis to groups','','a','','href = "../php/mod_filteredGui_group.php?sessionID&e_id_css=filteredGui_Group" target = "AdminFrame" ',10,270,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> GROUP ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_filteredGroup',2,1,'allocate guis of this admin to groups where this admin is owner','Allow several groups access to one GUI','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',10,290,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_filteredUser',2,1,'allocate the user where the admin is owner to his guis ','Allow several users access to one GUI ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',10,230,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_user',2,1,'allocate the guis of this admin to a user','','a','','href = "../php/mod_filteredGui_User.php?sessionID&e_id_css=filteredGui_user" target = "AdminFrame" ',10,210,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> USER ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_Group',2,1,'allocate user of this admin to groups','','a','','href = "../php/mod_filteredUser_Group.php?sessionID&e_id_css=filteredUser_Group" target = "AdminFrame" ',10,670,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_Gui',2,1,'allocate user of this admin to guis','','a','','href = "../php/mod_filteredUser_Gui.php?sessionID&e_id_css=filteredUser_Gui" target = "AdminFrame" ',10,770,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_filteredGroup',2,1,'allocate user where this admin is owner to groups where this admin is owner','Add one user to serveral groups','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',10,490,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_filteredGui',2,1,'allocate admins user to guis of this admin','Allow one user to access several GUIs','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',10,410,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','getStyles',2,0,'load styles from wms','','a','','href = "../php/mod_getStyles.php?sessionID" target = "AdminFrame" ',10,890,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GET_STYLES','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','group_filteredUser',2,1,'allocate groups to user where this admin is owner','','a','','href = "../php/mod_group_filteredUser.php?sessionID&e_id_css=group_filteredUser" target = "AdminFrame" ',10,570,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_filteredGroup',2,1,'allocate guis to groups of this admin','','a','','href = "../php/mod_gui_filteredGroup.php?sessionID&e_id_css=gui_filteredGroup" target = "AdminFrame" ',10,650,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_filteredUser',2,1,'allocate guis to user of this admin','','a','','href = "../php/mod_gui_filteredUser.php?sessionID&e_id_css=gui_filteredUser" target = "AdminFrame" ',10,630,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_owner',2,1,'set owner','Edit GUI assign to user','a','','href = "../php/mod_gui_owner.php?sessionID&e_id_css=gui_owner" target = "AdminFrame" ',10,830,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> OWNER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWFS',2,1,'load capabilities in a gui','Load WFS Capabilities into a GUI','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,850,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/WFS_Konfiguration');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWMS',2,1,'load capabilities in a gui','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,30,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWMSList',2,1,'load wms from a list','Link WMS into GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,50,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD myWMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,1,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','myGUIlist',2,1,'go back to your GUI list','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' ',150,2,24,24,1,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','newGui',2,1,'create a new gui','Create new GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,130,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','NEW GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','orphanWMS',2,1,'display orphaned WMS','Delete orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID&&elementID=orphanWMS" target = "AdminFrame"',10,930,200,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','ORPHAN WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','owsproxy',2,1,'secure services','OWSPROXY','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,910,200,20,1,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','OWSPROXY','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','rename_copy_Gui',2,1,'rename and copy gui','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,470,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','RENAME COPY GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','showLoggedUser',2,1,'displays the logged admin','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','updateWMSs',2,1,'edit the elements of the gui','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,70,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','UPDATE WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_filteredGroup',2,1,'allocate user to groups where this admin is owner','','a','','href = "../php/mod_user_filteredGroup.php?sessionID&e_id_css=user_filteredGroup" target = "AdminFrame" ',10,450,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> myGROUP','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_filteredGui',2,1,'allocate guis of this admin to user','','a','','href = "../php/mod_user_filteredGui.php?sessionID&e_id_css=user_filteredGui" target = "AdminFrame" ',10,390,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER-> myGUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_gui',2,1,'allocate guis to user','','a','','href = "../php/mod_user_gui.php?sessionID&e_id_css=user_gui" target = "AdminFrame" ',10,370,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> GUI ','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','wfs_conf',2,1,'create and edit a gazetteer module','Configure WFS','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,870,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','WFS CONF','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','wfs_gui',2,1,'edit wfs settings','Assign WFS conf to gui','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,1000,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','asign WFS conf to gui','a','','','','AdminFrame','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_Gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'User_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'editGUI_WMS', 'file_css', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_Gui', 'file css', '../css/administration_alloc.css', 'file', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_user', 'file css', '../css/administration_alloc.css', 'a file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_Gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'group_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin2_de';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','AdminFrame',2,1,'Bereich f�r Administrationsmodule','','iframe','','frameborder = "0"',200,20,980,800,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','CreateTreeGDE',2,1,'Ordnerbaum konfigurieren','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',8,280,190,20,5,'','Ordnerbaum konfigurieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','body',1,1,'Navigation','','body','','onload=''mod_adminNavigation_init()''',0,0,180,20,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','deleteWMS',2,1,'!Vollst�ndig l�schen!','Delete WMS completely','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',8,100,190,20,5,'','!Vollst�ndig l�schen!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','delete_filteredGui',2,1,'GUI l�schen','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',110,240,80,20,5,'','GUI l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editElements',2,1,'Oberfl�chenelemente editieren','Edit GUI elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',8,260,190,20,5,'','GUI-Elemente editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editFilteredGroup',2,1,'Gruppe anlegen und editieren','Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',8,400,190,20,10,'','Gruppe anlegen und editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editFilteredUser',2,1,'Benutzer anlegen und editieren','Create and edit user','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',8,380,190,20,10,'','Benutzer anlegen und editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editGUI_WMS',2,1,'WMS GUI Einstellungen','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',8,180,190,20,5,'','WMS GUI Einstellungen','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','exportGUI',2,1,'Oberfl�che (GUI) exportieren, SQL erzeugen','export GUI, create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',8,300,190,20,10,'','GUI exportieren (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGoup_filteredUser',2,1,'Gruppe mit Benutzern best�cken','Add several users to one group','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',8,440,190,20,10,'','Gruppe mit Benutzern best�cken ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGroup_filteredGui',2,1,'Einzelner Gruppe mehrere Oberflaechen zuordnen','Allow one group access to several GUIs','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',8,570,190,25,10,'','Einzelner Gruppe mehrere <br>GUIs zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGui_filteredGroup',2,1,'Einzelner Oberfl�che mehrere Gruppen zuordnen','Allow several groups access to one GUI','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',8,605,190,25,10,'','Einzelner GUI mehrere<br> Gruppen zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGui_filteredUser',2,1,'Oberfl�che mehreren Benutzer zuordnen ','Allow several users access to one GUI ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',8,535,190,25,10,'','GUI mehreren Benutzern <br> zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredUser_filteredGroup',2,1,'Benutzer in Gruppen eintragen','Add one user to serveral groups','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,420,190,20,10,'','Benutzer in Gruppen eintragen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredUser_filteredGui',2,1,'Einem Nutzer Zugriff auf mehrere Oberfl�chen erteilen','Allow one user to access several GUIs','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',8,500,190,25,10,'','Einem Nutzer Zugriff auf <br> mehrere GUIs erteilen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','gui_owner',2,1,'GUI editieren Benutzer zuordnen','Edit GUI assign to user','a','','href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame" ',8,640,190,20,10,'','GUI editieren Benutzer zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_Configure_WMS_Access',3,1,'Hintergrund WMS Zuordnung','Configure WMS Access','div','','',5,137,193,66,2,'',' WMS Zuordnung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_GUI_Management',3,1,'Hintergrund Oberfl�chenverwaltung','GUI Management','div','','',5,217,193,126,2,'',' GUI-Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_User_Authorization',3,1,'Hintergrund Benutzerzugriff erteilen','Authorization ','div','','',5,477,193,196,2,'',' Benutzerzugriff erteilen','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_User_Management',3,1,'Hintergrund Benutzerverwaltung','User Management','div','','',5,357,193,106,2,'',' Benutzerverwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_WMS_Management',3,1,'Hintergrund WMS Management','WMS Management','div','','',5,37,193,86,2,'',' WMS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','loadWMS',2,1,'Capabilities hochladen','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',8,60,190,20,5,'','Capabilities hochladen','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','loadWMSList',2,1,'WMS in GUI einbinden','Link WMS into GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',8,160,190,20,5,'','WMS in GUI einbinden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','myGUIlist',2,1,'Zur�ck zur eigenen GUI Liste','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','newGui',2,1,'GUI erzeugen','Create new GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',8,240,85,20,5,'','GUI erzeugen','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','rename_copy_Gui',2,1,'GUI umbenennen/ kopieren','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',8,320,190,20,10,'','GUI umbenennen/kopieren','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','showLoggedUser',2,1,'Anzeige des eingeloggten Benutzers','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','updateWMSs',2,1,'Hochgeladene aktualisieren','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',8,80,190,20,5,'','Hochgeladene aktualisieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'body', 'body_css_file', '../css/admin.css', 'css-file to define the style fo the admin-gui', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin2_en';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','AdminFrame',2,1,'the frame for administration modules','','iframe','','frameborder = "0"',200,20,800,800,0,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','CreateTreeGDE',2,1,'TreeGDE set up','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',8,280,190,20,5,'','Create treeGDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','body',1,1,'navigation','','body','','onload=''mod_adminNavigation_init()''',0,0,0,0,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','deleteWMS',2,1,'!Delete WMS completely!','Delete WMS completely','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',8,100,190,20,5,'','!Delete WMS completely!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','delete_filteredGui',2,1,'Delete GUI','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',120,240,80,20,5,'','Delete GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editElements',2,1,'Edit GUI elements','Edit GUI elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',8,260,190,20,5,'','Edit GUI elements','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editFilteredGroup',2,1,'Create and edit group','Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',8,400,190,20,10,'','Create and edit group','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editFilteredUser',2,1,'Create and edit user','Create and edit user','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',8,380,190,20,10,'','Create and edit user','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editGUI_WMS',2,1,'WMS GUI settings','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',8,180,190,20,5,'','WMS GUI settings','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','exportGUI',2,1,'export GUI, create SQL','export GUI, create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',8,300,190,20,10,'','Export GUI (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGoup_filteredUser',2,1,'Add several users to one group','Add several users to one group','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',8,440,190,20,10,'','Add several users to one group ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGroup_filteredGui',2,1,'Allow one group access to several GUIs','Allow one group access to several GUIs','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',8,570,190,25,10,'','Allow one group access to <br> several GUIs','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGui_filteredGroup',2,1,'Allow several groups access to one GUI','Allow several groups access to one GUI','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',8,605,190,25,10,'','Allow several groups access <br> to one GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGui_filteredUser',2,1,'Allow several users access to one GUI ','Allow several users access to one GUI ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',8,535,190,25,10,'','Allow several users access to <br> one GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredUser_filteredGroup',2,1,'Add one user to serveral groups','Add one user to serveral groups','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,420,190,20,10,'','Add one user to serveral groups','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredUser_filteredGui',2,1,'Allow one user to access several GUIs','Allow one user to access several GUIs','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',8,500,190,25,10,'','Allow one user to access <br> several GUIs','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','gui_owner',2,1,'Edit GUI assign to user','Edit GUI assign to user','a','','href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame" ',8,640,190,20,10,'','Edit GUI assign to user','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_Configure_WMS_Access',3,1,'Configure WMS Access','Configure WMS Access','div','','',5,137,193,66,2,'',' Configure WMS Access','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_GUI_Management',3,1,'GUI Management caption','GUI Management','div','','',5,217,193,126,2,'',' GUI Management ','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_User_Authorization',3,1,'Authorization caption','Authorization ','div','','',5,477,193,186,2,'',' Authorization','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_User_Management',3,1,'User Management caption','User Management','div','','',5,357,193,106,2,'',' User Management ','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_WMS_Management',3,1,'WMS Management caption','WMS Management','div','','',5,37,193,86,2,'',' WMS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" ',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','loadWMS',2,1,'Load Capabilities','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',8,60,190,20,5,'','Load WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','loadWMSList',2,1,'Link WMS into GUI','Link WMS into GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',8,160,190,20,5,'','Link WMS into GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','myGUIlist',2,1,'go back to your GUI list','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' ',150,2,24,24,2,'','','img','mod_home.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','newGui',2,1,'Create new GUI','Create new GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',8,240,110,20,5,'','Create new GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','rename_copy_Gui',2,1,'Rename/ copy GUI','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',8,320,190,20,10,'','Rename / copy GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','showLoggedUser',2,1,'Logged User:','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','updateWMSs',2,1,'Update with Capabilities','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',8,80,190,20,5,'','Update WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'body', 'body_css_file', '../css/admin.css', 'css-file to define the style fo the admin-gui', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGoup_filteredUser', 'css_file_filteredGroup_filterdUser', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGroup', 'css_filteredUser_filteredGroup', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin_de_services';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','AdminFrame',2,1,'Bereich f�r Administrationsmodule','','iframe','','frameborder = "0"',210,25,800,800,12,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','CreateTreeGDE',2,1,'Ordnerbaum konfigurieren','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,533,200,20,5,'','Ordnerbaum konfigurieren','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','EditWMSMetadata',2,1,'edit the metadata of wms','edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,275,200,20,5,'','WMS Metadaten','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_WMS_Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','body',1,1,'Navigation','','body','','onload=''mod_adminNavigation_init()''',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','deleteWFS',2,1,'WFS l�schen','Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,393,200,20,5,'','WFS l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','deleteWMS',2,1,'!Vollst�ndig l�schen!','!Delete WMS completely!','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,100,200,20,5,'','WMS l�schen!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','delete_filteredGui',2,1,'GUI l�schen','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,491,200,20,5,'','GUI l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','editElements',2,1,'Oberfl�chenelemente editieren','Edit GUI Elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,511,200,25,5,'','GUI editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','editGUI_WMS',2,1,'WMS GUI Einstellungen','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,218,200,20,5,'','WMS Einstellungen �ndern','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','exportGUI',2,1,'GUI exportieren, SQL erzeugen','Export GUI (SQL), create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,554,200,25,10,'x','GUI exportieren (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','filteredWms_layer_topic',2,1,'allocate topics to layers of wms of this user','allocate topics to layers of wms of this user','a','','href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ',10,295,200,20,5,'','Kategoriezuordnung','a','','','','AdminFrame','http://www.mapbender.org/index.php/Topic_/_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_Configure_WMS_Access',3,1,'Hintergrund WMS Zuordnung','WMS Assignment','div','','',1,175,210,63,2,'','WMS Zuordnung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_GUI_Management',3,1,'Oberfl�chenverwaltung','GUI Management','div','','',1,448,210,153,2,'','GUI Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_Metadata',3,1,'Metadateneditor Caption','Metadata','div','','',1,252,210,63,2,'','Metadaten','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_WFS_Management',3,1,'WFS Verwaltung','WFS Management','div','','',1,330,210,103,2,'','WFS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_WMS_Management',3,1,'Dienstverwaltung Beschriftung','WMS Management','div','','',0,37,210,123,2,'','WMS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWFS',2,1,'WFS Capabilities in eine GUI laden','Load WFS Capabilities into a GUI','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,353,200,20,5,'','WFS laden','a','','','','AdminFrame','http://www.mapbender.org/index.php/LoadWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWMS',2,1,'Capabilities hochladen','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,60,200,20,5,'','WMS laden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWMSList',2,1,'WMS in GUI einbinden','Assign WMS to a GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,198,200,20,5,'','WMS einbinden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','myGUIlist',2,1,'Zur�ck zur eigenen GUI Liste','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','newGui',2,1,'GUI erzeugen','New GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,471,200,20,5,'','GUI erzeugen','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','orphanWMS',2,1,'display orphaned WMS','Delete orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID"
+target = "AdminFrame"',10,120,200,20,5,'','WMS ohne Zuordung l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','owsproxy',2,1,'secure services','OWSPROXY','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,140,200,20,10,'','OWSPROXY','a','','','','AdminFrame','http://www.mapbender.org/index.php/Owsproxy');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','rename_copy_Gui',2,1,'GUI umbenennen/ kopieren','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,576,200,20,10,'','GUI umbenennen/kopieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/RenameGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','showLoggedUser',2,1,'Anzeige des eingeloggten Benutzers','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','updateWMSs',2,1,'Hochgeladene aktualisieren','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,80,200,20,5,'','WMS aktualisieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','wfs_conf',2,1,'WFS konfigurieren','Configure WFS','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,373,200,20,5,'','WFS konfigurieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Wfs_conf');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','wfs_gui',2,1,'edit wfs settings','Assign WFS conf to gui','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,413,200,20,10,'','WFS Konfiguration GUI zuweisen','a','','','','AdminFrame','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'EditWMSMetadata', 'file_css', '../css/metadata.css', 'css-file to use for the metadata modul', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'body', 'body_file_css', '../css/admin_service.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'filteredWms_layer_topic', 'file css', '../css/administration_alloc_4.css', 'css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'filteredWms_layer_topic', 'language', 'de', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin_en_services';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','AdminFrame',2,1,'administration frame','','iframe','','frameborder = "0"',210,25,1000,800,12,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','CreateTreeGDE',2,1,'Configure TreeGDE','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,533,200,20,5,'','Configure TreeGDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','EditWMSMetadata',2,1,'edit the metadata of wms','edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,275,200,20,5,'','WMS Metadata','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_WMS_Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','body',1,1,'Navigation','','body','','onload=''mod_adminNavigation_init()''',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','deleteWFS',2,1,'Delete WFS','Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,393,200,20,5,'','Delete WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','deleteWMS',2,1,'!Delete completely!','!Delete WMS completely!','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,100,200,20,5,'','!Delete WMS completely!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','delete_filteredGui',2,1,'Delete GUI','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,491,200,20,5,'','Delete GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','editElements',2,1,'Edit GUI Elements','Edit GUI Elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,511,200,20,5,'','Edit GUI Elements','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','editGUI_WMS',2,1,'WMS GUI settings','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,218,200,20,5,'','WMS GUI settings','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','exportGUI',2,1,'Export GUI (SQL), create SQL','Export GUI (SQL), create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,553,200,20,10,'x','Export GUI (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','filteredWms_layer_topic',2,1,'allocate topics to layers of wms of this user','allocate topics to layers of wms of this user','a','','href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ',10,295,200,20,5,'','Allocate topics','a','','','','AdminFrame','http://www.mapbender.org/index.php/Topic_/_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_Configure_WMS_Access',3,1,'WMS Assignment','WMS Assignment','div','','',1,175,210,63,2,'','WMS Assignment','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_GUI_Management',3,1,'GUI Management','GUI Management','div','','',1,448,210,148,2,'','GUI Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_Metadata',3,1,'Metadata','Metadata','div','','',1,252,210,63,2,'','Metadata','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_WFS_Management',3,1,'WFS Management','WFS Management','div','','',1,330,210,103,2,'','WFS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_WMS_Management',3,1,'WMS Management','WMS Management','div','','',0,37,210,123,2,'','WMS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWFS',2,1,'Load WFS Capabilities into a GUI','Load WFS Capabilities into a GUI','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,353,200,20,5,'','Load WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/LoadWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWMS',2,1,'load Capabilities','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,60,200,20,5,'','Load WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWMSList',2,1,'assign WMS to a GUI','Assign WMS to a GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,198,200,20,5,'','Assign WMS to a GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' ',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','myGUIlist',2,1,'back to GUI list','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','newGui',2,1,'New GUI','New GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,471,200,20,5,'','New GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','orphanWMS',2,1,'Delete orphaned WMS','Delete orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID"
+target = "AdminFrame"',10,120,200,20,5,'','Delete orphaned WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','owsproxy',2,1,'secure services','OWSPROXY','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,140,200,20,10,'','OWSPROXY','a','','','','AdminFrame','http://www.mapbender.org/index.php/Owsproxy');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','rename_copy_Gui',2,1,'Rename / copy GUI','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,576,200,20,10,'','Rename / copy GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/RenameGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','showLoggedUser',2,1,'show logged in user','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','updateWMSs',2,1,'Update Capabilities','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,80,200,20,5,'','Update WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','wfs_conf',2,1,'Configure WFS','Configure WFS','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,373,200,20,5,'','Configure WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Wfs_conf');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','wfs_gui',2,1,'edit wfs settings (Assign WFS conf to GUI)','Assign WFS conf to gui','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,413,200,20,10,'','Assign WFS conf to GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'EditWMSMetadata', 'file_css', '../css/metadata.css', 'css-file to use for the metadata modul', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'body', 'body_file_css', '../css/admin_service.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'filteredWms_layer_topic', 'file css', '../css/administration_alloc_4.css', 'css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'filteredWms_layer_topic', 'language', 'de', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui','switchLocale_noreload',8,1,'changes the locale without reloading the client','Set language','div','','frameborder=''0''',696,14,50,30,5,'','<form id=''form_switch_locale'' name=''form_switch_locale'' target=''parent''>
+<select id=''language'' name=''language'' onchange=''validate_locale()''>
+</select>
+</form>
+','div','mod_switchLocale_noreload.php','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'switchLocale_noreload', 'languages', 'de,en,bg,gr,nl,it,es', '' ,'var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_closetag, e_js_file) VALUES('gui1', 'popup', 6, 1, 'popup replacement', 'div', 'div', 'popup.js');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui1' AND e_id = 'wfs_gazetteer';
+DELETE FROM gui_treegde WHERE fkey_gui_id IN ('gui', 'gui1', 'admin1', 'gui2', 'wms_africa');
+-- update own applications
+Update gui_element set e_title =
+mynew.e_title from gui_element as mynew
+where gui_element.e_id = mynew.e_id
+and mynew.fkey_gui_id = 'gui'
+and gui_element.fkey_gui_id != 'gui'
+and gui_element.fkey_gui_id != 'gui1'
+and gui_element.fkey_gui_id != 'gui2'
+and gui_element.fkey_gui_id != 'gui_digitize';
+and mynew.fkey_gui_id = 'gui1'
+and mynew.fkey_gui_id = 'gui2'
+and mynew.fkey_gui_id = 'gui_digitize'
+Delete from gui_element_vars where fkey_e_id ='tabs' and var_name LIKE 'tab_titles[%';
+Update gui_element_vars set var_type='php_var' where fkey_e_id ='tabs' and var_name LIKE 'tab_ids[%' and var_type='var';
+DELETE FROM gui_element WHERE e_id = 'ajax';
+Delete from gui_element where e_id='keyHandler';
+DELETE FROM gui_element WHERE e_id = 'geometry';
+Select * from gui_element where e_mb_mod ='geometry.js' ;
+update gui_element set e_mb_mod = 'geometry.js'
+where e_id = 'digitize';
+where e_id = 'gazetteerWFS';
+where e_id = 'setSpatialRequest';
Added: trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql
--- trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql (rev 0)
+++ trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.4.5_to_2.5_mysql_UTF-8.sql 2009-03-17 16:16:15 UTC (rev 3779)
@@ -0,0 +1,521 @@
+-- database changes in version 2.5
+-- notice language plpgsql has to be installed
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin_de_services', 20, '');
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin_en_services', 20, '');
+-- table mb_monitort: new columns for mb_monitor
+ALTER TABLE mb_monitor ADD COLUMN image int(11);
+ALTER TABLE mb_monitor ADD COLUMN map_url varchar(2048);
+-- WFS database handling
+-- enhancement of the datadase structure concerning WFS metadata (same solution like for WMS)
+ALTER table wfs add wfs_getcapabilities_doc text;
+ALTER table wfs add wfs_upload_url varchar(255);
+ALTER table wfs add fees varchar(255);
+ALTER table wfs add accessconstraints text;
+ALTER table wfs add individualname varchar(255);
+ALTER table wfs add positionname varchar(255);
+ALTER table wfs add providername varchar(255);
+ALTER table wfs add city varchar(255);
+ALTER table wfs add deliverypoint varchar(255);
+ALTER table wfs add administrativearea varchar(255);
+ALTER table wfs add postalcode varchar(255);
+ALTER table wfs add voice varchar(255);
+ALTER table wfs add facsimile varchar(255);
+ALTER table wfs add electronicmailaddress varchar(255);
+ALTER table wfs add wfs_mb_getcapabilities_doc text;
+ALTER table wfs add wfs_owner int(11);
+ALTER table wfs add wfs_timestamp int(11);
+ALTER table wfs add country varchar(255);
+ALTER TABLE wfs MODIFY wfs_title varchar(255) NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_title SET DEFAULT '';
+ALTER TABLE wfs MODIFY wfs_version NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_version SET DEFAULT '';
+ALTER TABLE wfs MODIFY wfs_getcapabilities NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_getcapabilities SET DEFAULT '';
+alter table wfs_featuretype add column featuretype_searchable integer default 1;
+alter table wfs_featuretype add column featuretype_abstract character varying(50);
+-- grant root access to default wfs
+UPDATE wfs SET wfs_owner = 1;
+-- new table gui_wfs_conf
+CREATE TABLE gui_wfs_conf (
+ fkey_gui_id character varying(50) DEFAULT '' NOT NULL,
+ fkey_wfs_conf_id integer DEFAULT 0 NOT NULL
+ALTER TABLE gui_wfs_conf
+ ADD CONSTRAINT pk_fkey_wfs_conf_id PRIMARY KEY (fkey_gui_id, fkey_wfs_conf_id);
+ ADD CONSTRAINT gui_wfs_conf_ibfk_1 FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
+ ADD CONSTRAINT gui_wfs_conf_ibfk_2 FOREIGN KEY (fkey_wfs_conf_id) REFERENCES wfs_conf(wfs_conf_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- insert wfs confs into gui digitize
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 1);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 3);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 4);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 2);
+-- new table wfs_featuretype_keyword:
+CREATE TABLE wfs_featuretype_keyword (
+ fkey_featuretype_id integer NOT NULL,
+ fkey_keyword_id integer NOT NULL
+ALTER TABLE wfs_featuretype_keyword
+ ADD CONSTRAINT fkey_keyword_id_fkey_featuretype_id FOREIGN KEY (fkey_keyword_id) REFERENCES keyword(keyword_id) ON UPDATE CASCADE ON DELETE CASCADE;
+ ADD CONSTRAINT fkey_featuretype_id_fkey_keyword_id FOREIGN KEY (fkey_featuretype_id) REFERENCES wfs_featuretype(featuretype_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- new table layer_load_count
+CREATE TABLE layer_load_count (
+ fkey_layer_id int4,
+ load_count int8
+-- table wfs_conf
+ALTER TABLE wfs_conf add COLUMN wfs_conf_description text;
+ALTER TABLE `wfs_conf`
+ ADD CONSTRAINT wfs_conf_ibfk_2 FOREIGN KEY (fkey_featuretype_id) REFERENCES wfs_featuretype(featuretype_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- table wfs_conf_element: change in WFS configuration: access to geometries may now be restricted
+ALTER TABLE wfs_conf_element ADD COLUMN f_show_detail int4;
+ALTER TABLE wfs_conf_element ADD COLUMN f_operator VARCHAR(50);
+-- table gui_element: new column for translation
+-- ALTER TABLE gui_element ADD COLUMN e_title VARCHAR(255) NULL;
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','WFS',2,1,'edit wfs settings','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,1005,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT WFS','a','','','','AdminFrame','');
+ fkey_layer_id int(11),
+ load_count int(11)
+-- new table translation: new table for translations
+ CREATE TABLE translations
+ trs_id int(11) NOT NULL auto_increment,
+ locale varchar(8),
+ msgid varchar(512),
+ msgstr varchar(512),
+ PRIMARY KEY (trs_id)
+ CREATE INDEX msgid_idx ON translations(msgid);
+-- new function gettext for easy translations
+-- function has to be translated
+-- new entries for table translations
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Pan', 'Ausschnitt verschieben');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Display complete map', 'gesamte Karte anzeigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom in', 'In die Karte hineinzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom out', 'Aus der Karte herauszoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Back', 'Zurück');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Forward', 'Nach vorne');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Coordinates', 'Koordinaten anzeigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom by rectangle', 'Ausschnitt wählen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Redraw', 'Neu laden oder Tastatur: Leertaste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Query', 'Datenabfrage');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Logout', 'Abmelden');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'WMS preferences', 'WMS Einstellungen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS from filtered list', 'WMS von gefilteter Liste hinzufügen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set map center', 'Kartenmittelpunkt setzen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Help', 'Hilfe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Show WMS infos', 'Anzeige von WMS Informationen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Save workspace as web map context document', 'Ansicht als Web Map Context Dokument speichern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Resize Mapsize', 'BildschirmgröÃe anpassen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Rubber', 'Skizze löschen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Get Area', 'Fläche berechnen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Close Polygon', 'Polygon schliessen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Move back to your GUI list', 'Zurück zur GUI Liste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Legend', 'Legende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Print', 'Druck');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Imprint', 'Impressum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Maps', 'Karten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Search', 'Suche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Meetingpoint', 'Treffpunkt');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Metadatasearch', 'Metadatensuche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS', 'WMS hinzufügen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS from List', 'WMS aus Liste hinzufügen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Change Projection', 'Projektion ändern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Digitize', 'Digitalisierung');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Overview', 'Ãbersichtskarte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Drag Mapsize', 'Karte vergröÃern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Mapframe', 'Kartenfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Navigation Frame', 'Navigationsfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scale Select', 'Auswahl des MaÃstabes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scale Text', 'MaÃstab per Texteingabe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scalebar', 'MaÃstabsleiste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set Background', 'Hintegrundkarte auswählen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom to Coordinates', 'Zu den Koordinaten zoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Change Password', 'Passwort ändern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Load a web map context document', 'laden eines Web Map Context Dokumentes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de ', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Pan', 'ÐÑемеÑÑи облаÑÑÑа');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Display complete map', 'Ðокажи ÑÑлаÑа каÑÑа');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom in', 'Ðокажи каÑÑаÑа в по-едÑÑ Ð¼Ð°Ñаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom out', 'Ðокажи каÑÑаÑа в по-дÑебен маÑаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Back', 'Ðазад');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Forward', 'ÐапÑед');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Coordinates', 'ÐооÑдинаÑи');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom by rectangle', 'УвелиÑи каÑÑаÑа в избÑанаÑа облаÑÑ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Redraw', 'ÐÑеÑеÑÑай или Ð¾Ñ ÐºÐ»Ð°Ð²Ð¸Ð°ÑÑÑаÑа: пÑазен инÑеÑвал');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Query', 'ÐÑвка кÑм данниÑе');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Logout', 'ÐзÑ
од на поÑÑебиÑел');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'WMS preferences', 'WMS наÑÑÑойки');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS from filtered list', 'Ðобави WMS Ð¾Ñ Ð¸Ð·Ð±Ñан ÑпиÑÑк');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Set map center', 'ÐоÑÑави ÑенÑÑÑ Ð½Ð° каÑÑа');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Help', 'ÐомоÑ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Show WMS infos', 'Ðокажи WMS инÑоÑмаÑиÑ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Save workspace as web map context document', 'Ðапази ÑабоÑÐ½Ð¸Ñ Ð´Ð¾ÐºÑÐ¼ÐµÐ½Ñ ÐºÐ°Ñо Web Map Context докÑменÑ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Resize Mapsize', 'ÐапаÑни големинаÑа на каÑÑаÑа');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Rubber', 'ÐзÑÑий');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Get Area', 'ÐзÑиÑли плоÑ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Close Polygon', 'ÐаÑвоÑи полигон');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Move back to your GUI list', 'Ðазад кÑм ÑпиÑÑка Ñ Ð¸Ð½ÑеÑÑейÑи (GUI)');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Legend', 'Ðегенда');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Print', 'ÐеÑаÑ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Imprint', 'ÐвÑоÑÑко каÑе');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Maps', 'ÐаÑÑи');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Search', 'ТÑÑÑене');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Meetingpoint', 'ÐÑÑÑо на ÑÑеÑа');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Metadatasearch', 'ТÑÑÑене по меÑаданни');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS', 'Ðобави WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS from List', 'Ðобави WMS Ð¾Ñ ÑпиÑÑк');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Info', 'ÐнÑоÑмаÑиÑ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Change Projection', 'ÐÑомени пÑоекÑиÑ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Copyright', 'ÐвÑоÑÑко пÑаво');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Digitize', 'ÐигиÑализиÑане');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Overview','ÐбзоÑна каÑÑа');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Drag Mapsize', 'ÐÑомени ÑазмеÑа на каÑÑаÑа');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Mapframe', 'Рамка на каÑÑаÑа');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Navigation Frame', 'ÐавигаÑионна Ñамка');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scale Select', 'ÐÐ·Ð±Ð¾Ñ Ð½Ð° маÑаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scale Text', 'ÐÑведи маÑаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scalebar', 'ÐаÑабна Ñкала');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Set Background', 'ÐзбеÑи Ñоново изобÑажение');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom to Coordinates', 'Ðокажи каÑÑаÑа около поÑоÑениÑе кооÑдинаÑи');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Change Password', 'ÐÑомени паÑола');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Load a web map context document', 'ÐаÑеди Web Map Context докÑменÑ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Logo', 'ФиÑмен знак');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Measure distance', 'ÐзмеÑи ÑазÑÑоÑние');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Pan', 'ÎεÏακίνηÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Display complete map', 'ÎÏίδειξη ΠλήÏοÏ
Ï Î§Î¬ÏÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom in', 'Zoom In');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom out', 'Zoom Out');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Back', 'ΠίÏÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Forward', 'Î ÏÏÏθια');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Coordinates', 'ΣÏ
νÏεÏαγμÎνεÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom by rectangle', 'ÎοÏ
μ αÏÏ Î¿ÏθογÏνιο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Redraw', 'ÎÏÏÏÏ
ÏÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Query', 'ÎÎÏÏηÏη ÎμβαδοÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Logout', 'ÎÏοÏÏνδεÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'WMS preferences', 'ÎλλάξÏε Ïη διάÏαξη ÏÏν WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS from filtered list', 'Î ÏÏÏθεÏη WMS αÏÏ Ïο ÏιλÏÏαÏιÏμÎνο καÏάλογο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Set map center', 'Το καθοÏιÏμÎνο ÎÎνÏÏο ΧαÏÏÏν');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Help', 'Îοήθεια');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Save workspace as web map context document', 'Ansicht als Web Map Context Dokument speichern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Rubber', 'Το λάÏÏιÏο- ΤÏίÏÏηÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Close Polygon', 'Το ÎλειÏÏÏ Î Î¿Î»ÏγÏνο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ( 'gr', 'Move back to your GUI list', 'ΠαÏοÏ
ÏίαÏη ÏοÏ
GUI ÎαÏαλÏγοÏ
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Print', 'ÎκÏÏÏÏÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Maps', ' ΧάÏÏεÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS', 'Î ÏÏÏθεÏη WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS from List', 'Î ÏÏÏθεÏη WMS αÏÏ Ïον καÏάλογο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Navigation Frame', 'Navigationsfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Load a web map context document', 'laden eines Web Map Context Dokumentes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Measure distance', 'ÎÎÏÏηÏη ÎÏÏÏÏαÏηÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Meetingpoint', 'Σημείο ΣÏ
νάνÏηÏηÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Info', 'ΠληÏοÏοÏίεÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Digitize', 'ΨηÏιοÏοίηÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Change Projection', 'Îλλαγή Î ÏοβολήÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Set Background', 'ÎÏιλογή ΦÏνÏοÏ
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Overview', 'Î ÏοεÏιÏκÏÏιÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Change Password', 'Îλλαγή ΣÏ
νθημαÏικοÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scalebar', 'ÎανÏÎ½Î±Ï ÎλίμακαÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr ', 'Logo', 'ÎογÏÏÏ
Ïο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom to Coordinates', 'ÎÏÏίαÏη Ïε ΣÏ
νÏεÏαγμÎνεÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scale Text', 'Îείμενο ÎλίμακαÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Show WMS infos', 'Î Ïοβολή WMS ÏληÏοÏοÏιÏν');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Legend', 'ÎεζάνÏα');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Search', 'ÎναζήÏηÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Resize Mapsize', 'Îλλαγή ÎεγÎθοÏ
Ï Î§Î¬ÏÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Drag Mapsize', 'Îλλαγή ÎεγÎθοÏ
Ï Î§Î¬ÏÏη με ÎλίÏθηÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Mapframe', 'ΠλαίÏιο ΧάÏÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Get Area', 'Î Ïοβολή ΠεÏιοÏήÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Imprint', 'ÎÏοÏÏÏÏÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scale Select', 'ÎÏιλογή ÎλίμακαÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Metadatasearch', 'ÎναζήÏηÏη ÏÏα Metadata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Pan', 'Selectie verschuiven');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Display complete map', 'Hele kaart tonen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom in', 'Inzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom out', 'Uitzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Back', 'Terug');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Forward', 'Voorwaarts');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Coordinates', 'Koordinaten tonen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom by rectangle', 'Zoom rechthoek-selectie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Redraw', 'Opfrissen of toetsenbord : spatiebalk');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Query', 'Data opvragen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Logout', 'Afmelden');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'WMS preferences', 'WMS instellingen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS from filtered list', 'WMS van gefilterte lijst toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set map center', 'Kaartmiddelpunt aangeven');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Help', 'Help');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Show WMS infos', 'Tonen van WMS Informatie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Save workspace as web map context document', 'zicht als Web map context dokument bewaren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Resize Mapsize', 'beeldschermgrote aanpassen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Rubber', 'schets verwerpen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Get Area', 'oppervlakte berekenen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Close Polygon', 'Polygoon sluiten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Move back to your GUI list', 'Terug naar GUI lijst');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Legend', 'Legende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Print', 'Drukken');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Imprint', 'Impressum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Maps', 'Kaarten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Search', 'Zoek');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Meetingpoint', 'Trefpunt');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Metadatasearch', 'Zoeken naar Metadata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS', 'WMS toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS from List', 'WMS uit lijst toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Info', 'Informatie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Change Projection', 'Projektie veranderen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Digitize', 'Digitaliseren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Overview', 'overzichtskaart');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Drag Mapsize', 'Kaart vergroten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Mapframe', 'Kaartvenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Navigation Frame', 'Navigeervenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scale Select', 'Schaal selecteren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scale Text', 'Schaal via tekstingave');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scalebar', 'Schaalbalk');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set Background', 'Achtergrond selecteren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom to Coordinates', 'Naar koordinaten zoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Change Password', 'Paswoord wijzigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Load a web map context document', 'Laad een Web Map Context Dokument');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Measure distance', 'Meet afstand');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Pan', 'Sposta dettaglio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Display complete map', 'Mostra tutta la mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom in', 'Ingrandisci');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom out', 'Riduci');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Back', 'Indietro');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Forward', 'Avanti');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Coordinates', 'Mostra coordinate');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom by rectangle', 'Seleziona dettaglio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Redraw', 'Ridisegna oppure, da tastiera: spazio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Query', 'Interroga');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Logout', 'Logout');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'WMS preferences', 'Impostazioni WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS from filtered list', 'Aggiungi un WMS da una lista filtrata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set map center', 'Fissa il centro della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Help', 'Aiuto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Show WMS infos', 'Mostra informazioni sul WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Save workspace as web map context document', 'Salva vista come documento di Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Resize Mapsize', 'Adatta la dimensione della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Rubber', 'Cancella bozza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Get Area', 'Calcola area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Close Polygon', 'Chiudi poligono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Move back to your GUI list', 'Torna alla lista delle GUI');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Legend', 'Legenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Print', 'Stampa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Imprint', 'Colophon');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Maps', 'Mappe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Search', 'Cerca');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Meetingpoint', 'Punti di incontro');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Metadatasearch', 'Ricerca metadati');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS', 'Aggiungi WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS from List', 'Aggiungi WMS da lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Change Projection', 'Cambia proiezione');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Digitize', 'Digitalizza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Overview', 'Mappa di insieme');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Drag Mapsize', 'Cambia dimensione mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Mapframe', 'Quadro della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Navigation Frame', 'Quadro di navigazione');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scale Select', 'Scelta della scala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scale Text', 'Scala dei testi');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scalebar', 'Scala di riferimento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set Background', 'Seleziona mappa di sfondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom to Coordinates', 'Ingrandisci alle coordinate');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Change Password', 'Cambia password');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Load a web map context document', 'Carica un documento Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Measure distance', 'Misura distanza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Pan', 'Desplazamiento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Display complete map', 'Desplazamiento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom in', 'Zoom +');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom out', 'Zoom -');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Back', 'Zoom previo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Forward', 'Zoom siguiente');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Coordinates', 'Mostrar coordenadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom by rectangle', 'Zoom rectángulo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Redraw', 'Refrescar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Query', 'Busqueda de datos');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Logout', 'Terminar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'WMS preferences', 'Ajuste WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS from filtered list', 'Anadir WMS desde lista filtrada');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set map center', 'Centrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Help', 'Ayuda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Show WMS infos', 'Mostrar información sobre WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Save workspace as web map context document', 'Guardar vista como fichero Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Resize Mapsize', 'Modificar el tamano de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Rubber', 'Borrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Get Area', 'Calcular area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Close Polygon', 'Cerrar polÃgono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Move back to your GUI list', 'Volver a la lista WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Legend', 'Leyenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Print', 'Imprimir');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Imprint', 'Aviso legal');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Maps', 'Mapas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Search', 'Busqueda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Meetingpoint', 'Lugar de reunión');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Metadatasearch', 'Búsqueda de datos meta');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS', 'Añadir WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS from List', 'Añadir WMS desde lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Info', 'Informacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Change Projection', 'Cambiar projecto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Digitize', 'Digitalización');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Overview', 'Mapa de visión general');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Drag Mapsize', 'Ampilar vista de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Mapframe', 'Ventana de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Navigation Frame', 'Ventana de navigacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scale Select', 'Selecionar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scale Text', 'Teclar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scalebar', 'Fraja de escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set Background', 'Poner el fondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom to Coordinates', 'Zoom en coordenadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Change Password', 'Cambiar clave');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Load a web map context document', 'Cargar un documento de Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Measure distance', 'Medir distancias');
+-- new table gui_kml
+CREATE TABLE gui_kml (
+ kml_id int(11) NOT NULL auto_increment,
+ fkey_mb_user_id int(11) NOT NULL,
+ fkey_gui_id varchar(50) NOT NULL,
+ kml_doc text NOT NULL,
+ kml_name varchar(64),
+ kml_description text,
+ kml_timestamp int(11) NOT NULL,
+ PRIMARY KEY (kml_id)
+ALTER TABLE gui_kml
+ADD CONSTRAINT gui_kml_fkey_mb_user_id FOREIGN KEY (fkey_mb_user_id)
+REFERENCES mb_user(mb_user_id) MATCH SIMPLE ON UPDATE CASCADE ON DELETE CASCADE;
+ADD CONSTRAINT gui_kml_id_fkey_gui_id FOREIGN KEY (fkey_gui_id)
+REFERENCES gui(gui_id) MATCH SIMPLE ON UPDATE CASCADE ON DELETE CASCADE;
+-- new SLD table
+CREATE TABLE sld_user_layer (
+ sld_user_layer_id int(11) NOT NULL auto_increment,
+ fkey_mb_user_id int(11) NOT NULL default '0',
+ fkey_layer_id int(11) NOT NULL default '0',
+ fkey_gui_id varchar(50) NOT NULL default '',
+ sld_xml text,
+ use_sld tinyint(1) default '0',
+ PRIMARY KEY (sld_user_layer_id)
+) TYPE=InnoDB;
+-- constraints for new table sld_user_layer
+ALTER TABLE sld_user_layer ADD CONSTRAINT sld_user_layer_ibfk1 FOREIGN KEY (fkey_mb_user_id) REFERENCES mb_user (mb_user_id) ON DELETE CASCADE ON UPDATE CASCADE;
+ALTER TABLE sld_user_layer ADD CONSTRAINT ADD CONSTRAINT sld_user_layer_ibfk2 FOREIGN KEY (fkey_layer_id) REFERENCES layer (layer_id) ON DELETE CASCADE ON UPDATE CASCADE;
+ALTER TABLE sld_user_layer ADD CONSTRAINT ADD CONSTRAINT sld_user_layer_ibfk3 FOREIGN KEY (fkey_gui_id) REFERENCES gui (gui_id) ON DELETE CASCADE ON UPDATE CASCADE;
+-- add sld related columns
+ALTER TABLE gui_wms ADD COLUMN gui_wms_sldurl varchar(255) NOT NULL default '';
+ALTER TABLE wms ADD COLUMN wms_supportsld boolean NULL;
+ALTER TABLE wms ADD COLUMN wms_userlayer boolean NULL;
+ALTER TABLE wms ADD COLUMN wms_userstyle boolean NULL;
+ALTER TABLE wms ADD COLUMN wms_remotewfs boolean NULL;
+-- opacity handeling
+ALTER TABLE gui_wms ADD COLUMN gui_wms_opacity INT DEFAULT 100;
+UPDATE gui_element SET e_mb_mod = 'mod_addWMSgeneralFunctions.js' WHERE e_id = 'addWMS';
+ALTER TABLE gui_element MODIFY e_js_file character varying(255);
+ALTER TABLE gui_element MODIFY e_mb_mod character varying(255);
+ALTER TABLE wms MODIFY fees text;
+ALTER TABLE wms CHANGE COLUMN wms_mb_getcapabilies_doc wms_mb_getcapabilities_doc text;
\ No newline at end of file
Added: trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.5.1rc1_to_2.5.1_mysql_UTF-8.sql
--- trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.5.1rc1_to_2.5.1_mysql_UTF-8.sql (rev 0)
+++ trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.5.1rc1_to_2.5.1_mysql_UTF-8.sql 2009-03-17 16:16:15 UTC (rev 3779)
@@ -0,0 +1,11 @@
+-- database changes in version 2.5.1
+DELETE FROM wfs_conf_element WHERE f_id NOT IN (SELECT DISTINCT element_id AS f_id FROM wfs_element);
+ALTER TABLE `wfs_element`
+ ADD CONSTRAINT wfs_element_element_id_key UNIQUE (element_id);
+ALTER TABLE `wfs_conf_element`
+ ADD CONSTRAINT wfs_conf_element_id_ibfk_1 FOREIGN KEY (f_id) REFERENCES wfs_element (element_id) ON UPDATE CASCADE ON DELETE CASCADE;
Added: trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.5_to_2.5.1rc1_mysql_UTF-8.sql
--- trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.5_to_2.5.1rc1_mysql_UTF-8.sql (rev 0)
+++ trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.5_to_2.5.1rc1_mysql_UTF-8.sql 2009-03-17 16:16:15 UTC (rev 3779)
@@ -0,0 +1,19 @@
+UPDATE gui_element SET e_closetag = '' WHERE e_element = 'img';
+-- translations missing for bg,gr,nl
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set language', 'Sprache auswählen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set language', 'Selección del idioma');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set language', 'Lingua');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Set language', 'Choisir une langue');
+-- enlarge WFS metadata columns
+ALTER TABLE wfs_featuretype MODIFY featuretype_abstract text;
+ALTER TABLE wfs_featuretype MODIFY featuretype_title varchar(255);
+ALTER TABLE wfs_featuretype MODIFY featuretype_name varchar(255) NOT NULL DEFAULT '';
+ALTER TABLE wfs_element MODIFY element_name varchar(255);
+ALTER TABLE wfs_element MODIFY element_type varchar(255);
Added: trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.5rc6_to_2.5_mysql_UTF-8.sql
--- trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.5rc6_to_2.5_mysql_UTF-8.sql (rev 0)
+++ trunk/mapbender/resources/db/mysql/UTF-8/update/update_2.5rc6_to_2.5_mysql_UTF-8.sql 2009-03-17 16:16:15 UTC (rev 3779)
@@ -0,0 +1 @@
Added: trunk/mapbender/resources/db/mysql/UTF-8/update/update_guis_2.4.5_to_2.5_mysql_UTF-8.sql
--- trunk/mapbender/resources/db/mysql/UTF-8/update/update_guis_2.4.5_to_2.5_mysql_UTF-8.sql (rev 0)
+++ trunk/mapbender/resources/db/mysql/UTF-8/update/update_guis_2.4.5_to_2.5_mysql_UTF-8.sql 2009-03-17 16:16:15 UTC (rev 3779)
@@ -0,0 +1,901 @@
+-- update of mapbender guis
+-- gui / gui1 / gui2 / gui_digitize
+-- admin1 / admin2_de / admin2_de / admin_de_services / admin_en_services
+-- Mapbender Test for Version: 2.5
+-- 2008-09-29
+-- notice: this guis are not all working properly
+-- the guis contain the e_title informations fpor i18n
+-- these sql are for developers to get the guis working
+Delete from gui_element where fkey_gui_id ='gui';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','FeatureInfoRedirect',2,1,'redirect featureInfoRequests in an iframe for each wms','Info','iframe','../html/mod_blank.html','frameborder="0"',83,-17,1,1,0,'','','iframe','mod_featureInfoRedirect.php','','','','http://www.mapbender.org/index.php/FeatureInfoRedirect');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','WMS_preferences',2,1,'configures the preferences of each loaded wms','WMS preferences','img','../img/button_gray/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',540,10,24,24,1,'','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_gray/add_off.png','onclick=''mod_addWMS()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',515,10,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','back',2,1,'History.back()','Back','img','../img/button_gray/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"',360,10,24,24,1,'','','','mod_back.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','body',1,1,'body (obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','featureInfo1',2,0,'FeatureInfoRequest','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')"',425,10,24,24,1,'','','','mod_featureInfoTunnel.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfoTunnel');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','forward',2,1,'History.forward()','Forward','img','../img/button_gray/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" ',385,10,24,24,1,'','','','mod_forward.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','gazetteerMetadata',2,1,'gazetteer for metadata','Metadatasearch','iframe','../php/mod_gazetteerMetadata.php?sessionID&target=mapframe1,overview','frameborder = "0"',1,1,1,1,4,'visibility:hidden;','','iframe','','','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','Search','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','geometry.js','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" ',620,10,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','highlightPOI',2,1,'highlight 1 to n pois in your gui with a Symbol and a special text','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_highlightPOI.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','imprint',2,1,'Information about the owner of the gui','Imprint','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_back',3,1,'layout, background for buttons','','div','','',360,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_featureInfo',3,1,'layout, background for FeatureInfo','','div','','',425,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_help',3,1,'layout, background for Help-button','','div','','',620,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_logout',3,1,'layout, background for Logout-button','','div','','',660,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_metadata',3,1,'layout, background for Metadata','','div','','',580,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_wms',3,1,'layout, background for wms','','div','','',490,10,76,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_zoom',3,1,'layout, background for Zoom-button','','div','','',220,10,126,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','loadData',2,1,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','logo',2,1,'Logo','Logo','img','../img/mapbender_logo.png','',20,20,180,26,5,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' ',660,10,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','mapframe1',2,1,'frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',230,55,500,450,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','meetingPoint',2,1,'create a meeting point','Meetingpoint','iframe','../php/mod_meetingPoint.php?sessionID','frameborder = "0" ',0,0,NULL ,NULL ,4,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_gray/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_gray/metadata_over.png"'' onmouseout=''this.src="../img/button_gray/metadata_off.png"'' ',580,10,24,24,1,'','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,0,0,0,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',30,65,150,130,100,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','pan1',2,1,'pan','Pan','img','../img/button_gray/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')" ',270,10,24,24,1,'','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','printPDF',2,1,'pdf print','Print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_gray/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')" ',295,10,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','setBBOX',2,0,'set extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','setBackground',2,1,'switch background-wms','Set Background','form','','',30,210,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','showCoords_div',2,1,'displays coodinates by onmouseover','Coordinates','img','../img/button_gray/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ',450,10,24,24,1,'','','','mod_coords_div.php','','mapframe1','dependendDiv','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','tabs',2,1,'vertical tabs to handle iframes','','div','','',10,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2','Maps','iframe','../html/mod_treefolder2.php?sessionID','frameborder = "0" ',10,220,200,300,NULL ,'visibility:visible','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_gray/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)" ',320,10,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_gray/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' ',220,10,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_gray/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''',245,10,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_all', '0', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_group', '0', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_gui', '0', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'gazetteerWFS', 'wfsConfIdString', '1', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_height', '14', 'height of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_width', '14', 'width of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_ccs_file', '../css/meetingPoint.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_format', 'prompt', 'decide which format to choose (email, prompt)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_subject', 'Ein Treffpunkt wurde erzeugt. Folgen Sie dem Link!', 'if you choose format email, define the text for the subject', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_height', '14', 'height of the meetingPoint_icon', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_icon', '../img/redball.gif', 'path to meetingPoint image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_max_characters', '70', 'define the maximum length of the text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_please_click', 'Please click in the map to define the meeting point position!', 'text to show if no clickposition is set', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_style', 'background-color:white;font-weight: bold;color:red;font-family:Arial;', 'style to display the meetingPoint text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_width', '14', 'width of the meetingPoint_icon', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[5]', '160', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[6]', '280', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[5]', 'meetingPoint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[6]', 'gazetteerMetadata', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_prefix', ' ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'menu', 'opacity_up,opacity_down,zoom,metainfo,hide,wms_up,wms_down,layer_up,layer_down,remove', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'metadatalink', 'false', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui1';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','WMS_preferences',2,1,'configure the preferences of each loaded wms','WMS preferences','img','../img/button_blink_red/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',670,60,24,24,1,'','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_blink_red/add_off.png','onclick=''mod_addWMS()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',645,60,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMSfromList',2,1,'add a WMS to the running application from a list','Adding WMS from List','img','../img/button_blink_red/addlist_off.png','onclick=''window.open("../javascripts/mod_addWMSfromList.php?sessionID","printWin","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',595,60,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',620,60,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','back',2,1,'History.back()','Back','img','../img/button_blink_red/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" ',400,60,24,24,1,'','','','mod_back.php','','mapframe1,overview','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','body',1,1,'body (obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','center1',2,1,'Center button','Set map center','img','../img/button_blink_red/center_off.png','onmouseover = "mb_regButton(''init_gui1_center'')" ',310,60,24,24,1,'','','','mod_center1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','changeEPSG',2,1,'change EPSG, Postgres required, overview is targed for full extent','Change Projection','iframe','../php/mod_changeEPSG.php?sessionID','scrolling="no" frameborder=''0'' ',432,25,107,24,1,'','','iframe','','','overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','changePassword_button',2,1,'button: change password of logged user','Change Password','img','../img/button_blink_red/change_password_off.png','onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0'' onmouseover=''this.src="../img/button_blink_red/change_password_over.png"'' onmouseout=''this.src="../img/button_blink_red/change_password_off.png"'' ',750,60,24,24,1,'cursor:hand','','','','','','','http://www.mapbender.org/index.php/ChangePassword');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','closePolygon',3,1,'close Polygon ','Close Polygon','div','','',0,0,0,0,0,'','','div','mod_closePolygon.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',-59,1,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',-59,1,0,0,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','featureInfo1',2,1,'FeatureInfoRequest','Query','img','../img/button_blink_red/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')" ',465,60,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','forward',2,1,'History.forward()','Forward','img','../img/button_blink_red/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" ',425,60,24,24,1,'','','','mod_forward.php','','mapframe1,overview','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','getArea',3,1,'Calculation of area, Postgis required','Get Area','div','','',0,0,0,0,0,'','','div','mod_getArea.php','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','help',2,1,'button help','Help','img','../img/button_blink_red/help_off.png','onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")''',790,60,24,24,1,'','','','','','','','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','help1',2,1,'button help','Help','img','../img/button_blink_red/help_off.png','onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")''',790,60,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/help');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','highlightPOI',2,1,'highlight 1 to n pois in your gui with a Symbol and a special text','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_highlightPOI.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','layout_1',3,1,'layout, background for buttons','','div','','',208,58,670,28,0,'background-color:#FFFFFF;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&wms_legend = yes','frameborder=''0''',-59,200,180,600,3,'','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','loadData',2,1,'IFRAME to load data','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','loadwmc',2,1,'load workspace from WMC','Load a web map context document','img','../img/button_blink_red/wmc_load_off.png','onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',895,60,24,24,1,'','','','mod_loadwmc.php','','mapframe1','','http://www.mapbender.org/index.php/LoadWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','logout',2,1,'Logout','Logout','img','../img/button_blink_red/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blink_red/logout_over.png"'' onmouseout=''this.src="../img/button_blink_red/logout_off.png"'' ',830,60,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',-59,1,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','mapframe1',2,1,'Frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',220,105,625,400,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','measure',2,1,'Measure','Measure distance','img','../img/button_blink_red/measure_off.png','onmouseover = "mb_regButton(''init_mod_measure'')"',515,60,24,24,1,'','','','mod_measure.php','','mapframe1','','http://www.mapbender.org/index.php/Measure');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_blink_red/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_blink_red/metadata_over.png"'' onmouseout=''this.src="../img/button_blink_red/metadata_off.png"'' ',710,60,24,24,1,'','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,0,0,10,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',15,25,150,150,2,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','pan1',2,1,'pan','Pan','img','../img/button_blink_red/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')"',260,60,24,24,1,'','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','print1',2,0,'start print GUI','Print','img','../img/button_blink_red/print_off.png','onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID","printWin","width=300, height=400, resizable=yes ")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',555,60,24,24,1,'','','','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','printPDF',2,1,'start print GUI','Print','img','../img/button_blink_red/print_off.png','onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF_b.conf","printWin","width=180, height=200, resizable=yes ")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',555,60,24,24,1,'','','','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','repaint',2,1,'refresh a mapobject','Redraw','img','../img/button_blink_red/repaint_off.png','onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)'' ',360,60,24,24,1,'','','','mod_repaint.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','rubber',3,1,'deletes temporary (digitized) objects','Rubber','div','','',0,0,0,0,0,'','','div','mod_rubber.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',0,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','savewmc',2,1,'save workspace as WMC','Save workspace as web map context document','img','../img/button_blink_red/wmc_save_off.png','onclick=''mod_savewmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',870,60,24,24,1,'','','','mod_savewmc.php','','mapframe1','','http://www.mapbender.org/index.php/SaveWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scaleSelect',2,1,'Scale-Selectbox','Scale Select','select','','onchange=''mod_scaleSelect(this)''',555,25,100,20,1,'','<option value = ''''>Scale</option> <option value=''100''>1 : 100</option> <option value=''250''>1 : 250</option> <option value=''500''>1 : 500</option> <option value=''1000''>1 : 1000</option> <option value=''2500''>1 : 2500</option> <option value=''5000''>1 : 5000</option> <option value=''10000''>1 : 10000</option> <option value=''25000''>1 : 25000</option> <option value=''30000''>1 : 30000</option> <option value=''50000''>1 : 50000</option> <option value=''75000''>1 : 75000</option> <option value=''100000''>1 : 100000</option> <option value=''200000''>1 : 200000</option> <option value=''300000''>1 : 300000</option> <option value=''400000''>1 : 400000</option> <option value=''500000''>1 : 500000</option> <option value=''600000''>1 : 600000</option> <option value=''700000''>1 : 700000</option> <option value=''800000''>1 : 800000</option> <option value=''900000''>1 : 900000</option> <option value=''1000000''>1 : 1000000</option>','select','mod_scaleSel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scaleText',2,1,'Scale-description field','Scale Text','form','','onsubmit=''return mod_scaleText()''',672,25,100,30,0,'','<input type="text">','form','mod_scaleText.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scalebar',2,1,'scalebar','Scalebar','div','','',0,0,0,0,0,'','','div','mod_scalebar.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_blink_red/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')"',285,60,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBBOX',2,1,'set Extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBackground',2,0,'switch background-wms','Set Background','form','','',15,190,0,0,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBackground_all',2,0,'switch all background-wms','Set Background','form','','',157,190,40,20,1,'','<input type=''checkbox'' onclick=''mod_setBackground_all_init(this)''> <font face="Arial, sans-serif" size="2">all</font>','form','mod_setBackground_all.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setPOI2Scale',2,1,'zoom to a poi (get-parameter)','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_setPOI2Scale.php','','mapframe1','','http://www.mapbender.org/index.php/Mod_setPoi2Scale');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setScaleHint',1,0,'set scaleHint for mapframes','','div','','',1,1,1,1,0,'visibility:hidden;','','div','mod_scaleHint.php','','mapframe1,100,10000000','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','showCoords_div',2,1,'displays coordinates by onmouseover','Coordinates','img','../img/button_blink_red/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ',490,60,24,24,1,'','','','mod_coords_div.php','','mapframe1','','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeConfGDE',2,0,'configurable directory tree','Maps','iframe','../php/mod_treefolderClient.php?sessionID','frameborder = "0" ',0,180,250,500,0,'visibility:visible','','iframe','mod_treeConf.js','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeGDE_1',2,0,'directory tree, checkbox for visible, checkbox for querylayer, no immediate refreshing, with nested layers','Maps','iframe','../html/mod_sync_treefolder_1.html','frameborder = "0" ',0,180,250,500,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','wfs_gazetteer',2,0,'gazetteer using wfs','Search','iframe','../php/mod_wfs_gazetteer.php?sessionID&color=255,0,255','frameborder = "0" ',-50,490,250,300,0,'visibility:visible','','iframe','','','mapframe1,overview','wfs','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomCoords',2,1,'zoom to coordinate','Zoom to Coordinates','iframe','../php/mod_zoomCoords_en.php?sessionID','frameborder = "0" ',205,7,220,45,0,'','','iframe','','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_blink_red/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)" ',335,60,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_blink_red/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' ',210,60,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_blink_red/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' ',235,60,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_db', '0', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_height', '25', 'height of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_width', '25', 'width of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'css_file_legend', '../css/legend.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'stickylegend', 'true', 'parameter to decide wether the legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'logout', 'logout_location', 'http://www.mapbender.org/', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'setPOI2Scale', 'mod_setPOI2Scale_defScale', '5000', 'default scale', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'menu', '', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui2';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','WMS_preferences',2,1,'configures the preferences of each loaded wms','WMS preferences','img','../img/button_blue/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',604,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_blue/add_off.png','onclick=''mod_addWMS()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',580,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blue/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',553,40,28,28,1,'filter:Chroma(color=#C2CBCF);','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','back',2,1,'History.back()','Back','img','../img/button_blue/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"',398,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_back.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','body',1,1,'body
+(obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'background-image:url(../img/background_yellow.jpg);background-repeat:repeat-x;','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','center1',2,1,'Center button','Set map center','img','../img/button_blue/center_off.png','onmouseover = "mb_regButton(''init_gui1_center'')"',308,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_center1.php','','mapframe1','','http://www.mapbender.org/index.php/ReCenter');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','changePassword_button',2,1,'button: change password of logged user','Change Password','img','../img/button_blue/change_password_off.png','onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0''
+onmouseover=''this.src="../img/button_blue/change_password_over.png"'' onmouseout=''this.src="../img/button_blue/change_password_off.png"''',668,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','','','http://www.mapbender.org/index.php/ChangePassword');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','closePolygon',3,1,'close Polygon ','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_closePolygon.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#799FEB; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dynamicOverview',2,1,'oveview acts in accordance with main mapframe','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','mod_dynamicOverview.php','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','featureInfo1',2,0,'FeatureInfoRequest','Query','img','../img/button_blue/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','Query','img','../img/button_blue/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')"',461,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_featureInfoTunnel.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfoTunnel');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','forward',2,1,'History.forward()','Forward','img','../img/button_blue/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()"',423,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_forward.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','Search','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','geometry.js','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','getArea',3,1,'Calculation of area, Postgis required','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_getArea.php','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','header_yellow',2,0,'header','','img','../img/header_yellow.jpg','',-1,-1,833,75,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','help',2,1,'button help','Help','img','../img/button_blue/help_off.png','onmouseover = "mb_regButton(''init_help'')"',693,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','imprint',2,1,'Information about the owner of the gui','Imprint','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','layout_linie',3,0,'layout','','div','','',1,70,830,1,1,'background-color:#799FEB;font-size:1px;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','layout_linie2',3,0,'layout','','div','','',1,35,830,1,1,'background-color:#799FEB;font-size:1px;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','loadData',2,1,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','loadwmc',2,1,'load workspace from WMC','Load a web map context document','img','../img/button_blue/wmc_load_off.png','onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");''',758,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_loadwmc.php','','mapframe1','','http://www.mapbender.org/index.php/LoadWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','logo',2,1,'Logo','Logo','img','../img/mapbender_oo.png','',10,35,129,32,5,'filter:Chroma(color=#C2CBCF);','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','logout',2,1,'Logout','Logout','img','../img/button_blue/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blue/logout_over.png"'' onmouseout=''this.src="../img/button_blue/logout_off.png"''',798,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','mapframe1',2,1,'frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',213,90,608,467,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','measure',2,1,'Measure','Measure distance','img','../img/button_blue/measure_off.png','onmouseover = "mb_regButton(''init_mod_measure'')"',513,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_measure.php','','mapframe1','','http://www.mapbender.org/index.php/Measure');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_blue/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0''
+onmouseover=''this.src="../img/button_blue/metadata_over.png"'' onmouseout=''this.src="../img/button_blue/metadata_off.png"''',643,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,0,0,0,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>
+<div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>
+<div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>
+<div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div>
+<div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div>
+<div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>
+<div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>
+<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',9,80,185,130,100,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','pan1',2,1,'pan','Pan','img','../img/button_blue/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')"',258,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','printPDF',2,1,'pdf print','Print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','repaint',2,1,'refresh a mapobject','Redraw','img','../img/button_blue/repaint_off.png','onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)''',358,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_repaint.php','','mapframe1','','http://www.mapbender.org/index.php/Repaint');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','resizeMapsize',2,1,'resize mapsize to browser window size','Resize Mapsize','img','../img/button_blink_red/resizemapsize_off.png','onclick = "adjustDimension()"
+onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',838,40,24,24,3,'filter:Chroma(color=#C2CBCF);','','','mod_resize_mapsize.php','','mapframe1','','http://www.mapbender.org/index.php/ResizeMapsize');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','rubber',3,1,'deletes temporary (digitized) objects','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_rubber.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','savewmc',2,1,'save workspace as WMC','Save workspace as web map context document','img','../img/button_blue/wmc_save_off.png','onclick=''mod_savewmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',733,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_savewmc.php','','mapframe1','','http://www.mapbender.org/index.php/SaveWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_blue/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')"',283,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','setBBOX',2,0,'set extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','setBackground',2,1,'switch background-wms','Set Background','form','','',10,218,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','showCoords_div',2,1,'displays coodinates by onmouseover','Coordinates','img','../img/button_blue/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')"',488,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_coords_div.php','','mapframe1','dependendDiv','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','tabs',2,1,'vertical tabs to handle iframes','','div','','',2,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2','Maps','iframe','../html/mod_treefolder2.php?sessionID','frameborder = "0" ',10,220,200,300,NULL ,'visibility:visible','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_blue/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"',333,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_blue/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)''',203,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_blue/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''',231,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_class_bg', 'body{background-color: #FEF8D4;}', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_minScale', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_startExtent', '-24.5,32,34.5,71', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_useMaxExtent', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_wmsIndex', '0', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_zoomFactor', '5', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'gazetteerWFS', 'wfsConfIdString', '1', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_height', '-35', 'to adjust the height of the mapframe on the bottom of the window', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_width', '-45', 'to adjust the width of the mapframe on the right side of the window', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'resize_option', 'button', 'auto (autoresize on load), button (resize by button)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'sandclock', 'mod_sandclock_image', '../img/sandclock_oo.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_prefix', ' ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid #FDCC1A;font-size:12;color:#FFFFFF;background-color:#799FEB;cursor:pointer;margin-top:-3px; padding-top:3px;padding-left:4px;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'menu', 'opacity_up,opacity_down,zoom,metainfo,hide,wms_up,wms_down,layer_up,layer_down,remove', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui_digitize';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','FeatureInfoRedirect',2,0,'redirect featureInfoRequests in an iframe for each wms','Info','iframe','../html/mod_blank.html','frameborder="0"',83,-17,1,1,NULL ,'','','iframe','mod_featureInfoRedirect.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','WMS_preferences',2,1,'configures the preferences of each loaded wms','WMS preferences','img','../img/button_gray/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");''',540,10,24,24,1,'','','','','','mapframe1,treeGDE','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_gray/add_off.png','onclick=''mod_addWMS()''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");''',515,10,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','back',2,1,'History.back()','Back','img','../img/button_gray/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"',360,10,24,24,1,'','','','mod_back.php','','mapframe1,overview0','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','body',1,1,'body (obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','closePolygonExt',3,0,'close Polygon ','Close Polygon','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_closePolygonExt.js','','mapframe1','setExtRequest','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_copyright.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','digitize',2,1,'Digitize tool.','Digitize','iframe','../javascripts/mod_digitize_tab.php?sessionID','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','geometry.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','featureInfo1',2,0,'FeatureInfoRequest','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')"',425,10,24,24,1,'','','','mod_featureInfoTunnel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','forward',2,1,'History.forward()','Forward','img','../img/button_gray/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()"',385,10,24,24,1,'','','','mod_forward.php','','mapframe1,overview0','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','Search','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','geometry.js','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',620,10,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','imprint',2,1,'Information about the owner of the gui','Imprint','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','initWmc',2,0,'initialise client with wmc','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_initWmc.php','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_1',3,0,'Warning notice','','div','','',150,250,300,16,100,'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none;','Development Version - Work in Progress!','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_back',3,1,'layout, background for buttons','','div','','',360,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_featureInfo',3,1,'layout, background for FeatureInfo','','div','','',425,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_help',3,1,'layout, background for Help-button','','div','','',620,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_logout',3,1,'layout, background for Logout-button','','div','','',660,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_metadata',3,1,'layout, background for Metadata','','div','','',580,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_wms',3,1,'layout, background for wms','','div','','',490,10,76,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_zoom',3,1,'layout, background for Zoom-button','','div','','',220,10,126,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','loadData',2,1,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','loadwmc',2,0,'load workspace from WMC','Load a web map context document','img','../img/button_wmc/wmc_load.png','onclick=''mod_loadwmc()'' onmouseover=''mod_loadwmc_init(this)''',760,10,24,24,1,'','','','mod_loadwmc.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','logo',2,1,'Logo','','img','../img/mapbender_logo.png','',20,20,180,26,5,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''
+onmouseover=''this.src="../img/button_gray/logout_over.png"''
+onmouseout=''this.src="../img/button_gray/logout_off.png"''',660,10,24,24,1,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr>
+<script language="javascript">
+mb_registerSubFunctions("mod_mapbender()");
+function mod_mapbender(){
+document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90;
+document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1;
+</script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','mapframe1',2,1,'frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',230,55,500,450,2,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_gray/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''"
+border=''0''
+onmouseover=''this.src="../img/button_gray/metadata_over.png"''
+onmouseout=''this.src="../img/button_gray/metadata_off.png"''',580,10,24,24,1,'','','','mod_displayObj.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,NULL ,NULL ,NULL ,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>
+<div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>
+<div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>
+<div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div>
+<div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div>
+<div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>
+<div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>
+<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>
+','div','mod_navFrame.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',30,65,150,130,100,'','','iframe','','mod_box1.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','pan1',2,1,'pan','Pan','img','../img/button_gray/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')"',270,10,24,24,1,'','','','mod_pan.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','printPDF',2,1,'pdf print','Print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','rubberExt',3,1,'deletes temporary (digitized) objects','Rubber','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_rubberExt.js','','mapframe1','setExtRequest','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','savewmc',2,0,'save workspace as WMC','Save workspace as web map context document','img','../img/button_wmc/wmc_save.png','onclick=''mod_savewmc()'' onmouseover=''mod_savewmc_init(this)''',730,10,24,24,1,'','','','mod_savewmc.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','scaleSelect',2,0,'Scale-Selectbox','Scale Select','select','','onchange=''mod_scaleSelect(this)''',555,25,100,20,1,'','<option value = ''''>Scale</option>
+<option value=''100''>1 : 100</option>
+<option value=''250''>1 : 250</option>
+<option value=''500''>1 : 500</option>
+<option value=''1000''>1 : 1000</option>
+<option value=''2500''>1 : 2500</option>
+<option value=''5000''>1 : 5000</option>
+<option value=''10000''>1 : 10000</option>
+<option value=''25000''>1 : 25000</option>
+<option value=''30000''>1 : 30000</option>
+<option value=''50000''>1 : 50000</option>
+<option value=''75000''>1 : 75000</option>
+<option value=''100000''>1 : 100000</option>
+<option value=''200000''>1 : 200000</option>
+<option value=''300000''>1 : 300000</option>
+<option value=''400000''>1 : 400000</option>
+<option value=''500000''>1 : 500000</option>
+<option value=''600000''>1 : 600000</option>
+<option value=''700000''>1 : 700000</option>
+<option value=''800000''>1 : 800000</option>
+<option value=''900000''>1 : 900000</option>
+<option value=''1000000''>1 : 1000000</option>','select','mod_scaleSel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_gray/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')"',295,10,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setBBOX',2,0,'set extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setBackground',2,1,'switch background-wms','Set Background','form','','',30,210,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12''
+name=''mod_setBackground_list''
+onchange=''mod_setBackground_change(this)'' ><option
+value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setSpatialRequest',2,1,'Spatial Request','','div','','',1,1,1,1,1,'visibility:hidden;','','div','../javascripts/mod_wfs_SpatialRequest.php','geometry.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','showCoords_div',2,1,'displays coodinates by onmouseover','Coordinates','img','../img/button_gray/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ',450,10,24,24,1,'','','','mod_coords_div.php','','mapframe1','dependendDiv','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','showLoggedUser',2,0,'Displays current user','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','tabs',1,1,'vertical tabs to handle iframes','','div','','',10,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfs',2,1,'wfs request and result handling','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','wfs.js','../extensions/wz_jsgraphics.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfs_conf',2,1,'get all wfs_conf-params','','iframe','../php/mod_wfs.php','frameborder = "0"',1,1,1,1,0,'visibility:hidden','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfsresult',2,1,'display the list of wfs results','','iframe','../html/mod_blank.html','frameborder = "0"',10,730,200,150,4,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_gray/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"',320,10,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_gray/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)''',220,10,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_gray/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''',245,10,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'cssUrl', '../css/digitize.css', 'url to the style sheet of the mapframe', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'digitize_conf_filename', 'digitize_default.conf', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'text css', ' body{
+ font-family: Arial, Helvetica, sans-serif;
+ font-size : 12px;
+ color: #ff00ff;
+ background-color: #ffffff;
+ margin-top: 0px;
+ margin-left: 0px;
+ .button{
+ height: 18px;
+ width: 32px;
+', 'text css', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'wfsCssUrl', '../css/mapbender.css', 'var', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'gazetteerWFS', 'wfsConfIdString', '1,2,3,4', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'useUsemap', '0', '"1" adds a usemap to each geometry; the geometry will be highlighted onMouseOver. Every other value will skip the usemap.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'wfs_conf_filename', 'wfs_default.conf', 'location and name of the WFS configuration file', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'open_tab', '5', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[5]', '250', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[5]', 'digitize', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_prefix', ' ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;padding-left:8px;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'menu', '', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'wfs', 'displayWfsResultList', '1', '', 'var');
+Delete from gui_element where fkey_gui_id ='admin1';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','AdminFrame',2,1,'the frame for administration modules','','iframe','','frameborder = "0"',220,20,800,800,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','CreateTreeGDE',2,1,'create a foldertree for a individual geodataexplorer','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,810,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','CREATE TREE_GDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','EditWMSMetadata',2,1,'edit the metadata of wms','edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,950,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT WMS-METADATA','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_Gui',2,1,'allocate groups to guis','','a','','href = "../php/mod_group_gui.php?sessionID&e_id_css=Group_Gui" target = "AdminFrame" ',10,610,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_User',2,1,'allocate groups to user','','a','','href = "../php/mod_group_user.php?sessionID&e_id_css=Group_User" target = "AdminFrame" ',10,550,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','GROUP -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_filteredGui',2,1,'allocate Groups to the guis of this admin','','a','','href = "../php/mod_group_filteredGui.php?sessionID&e_id_css=Group_filteredGui" target = "AdminFrame" ',10,710,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Gui_Group',2,1,'allocate guis to groups','','a','','href = "../php/mod_gui_group.php?sessionID&e_id_css=Gui_Group" target = "AdminFrame" ',10,250,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Gui_User',2,1,'allocate a gui to user','','a','','href = "../php/mod_gui_user.php?sessionID&e_id_css=Gui_User" target = "AdminFrame" ',10,190,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','User_Group',2,1,'allocat user to groups','','a','','href = "../php/mod_user_group.php?sessionID&e_id_css=User_Group" target = "AdminFrame" ',10,430,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','body',1,1,'navigation','','body','','onload=''mod_adminNavigation_init()''',0,0,0,0,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteGui',2,1,'delete gui','','a','','href = "../php/mod_deleteGUI.php?sessionID" target = "AdminFrame" ',10,150,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteWFS',2,1,'delete WFS','Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,890,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteWMS',2,1,'delete wms','Delete WMS completely','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,110,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','delete_filteredGui',2,1,'delete guis of this admin','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,790,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editElements',2,1,'edit gui elements','Edit GUI elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,170,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','EDIT GUI-ELEMENTS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editFilteredGroup',2,1,'edit group of this admin','Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',10,530,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editFilteredUser',2,1,'save, edit, delete user where this admin is owner','Create and edit user','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',10,350,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editGUI_WMS',2,1,'edit the elements of the gui','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,90,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT GUI-WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editGroup',2,1,'edit group','','a','','href = "../php/mod_editGroup.php?sessionID" target = "AdminFrame" ',10,510,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editUser',2,1,'save, edit, delete user','','a','','href = "../php/mod_editUser.php?sessionID" target="AdminFrame"',10,330,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','exportGUI',2,1,'export gui, create SQLL','export GUI, create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,310,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EXPORT GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGoup_filteredUser',2,1,'allocate the groups of this admin to user where the admin is owner','Add several users to one group','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',10,590,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> myUSER ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_Gui',2,1,'allocate groups of this admin to guis','','a','','href = "../php/mod_filteredGroup_Gui.php?sessionID&e_id_css=filteredGroup_Gui" target = "AdminFrame" ',10,750,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_User',2,1,'allocate groups of this admin to user','','a','','href = "../php/mod_filteredGroup_User.php?sessionID&e_id_css=filteredGroup_User" target = "AdminFrame" ',10,690,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_filteredGui',2,1,'allocate groups of this admin to guis of this admin','Allow one group access to several GUIs','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',10,730,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_Group',2,1,'allocate guis to groups','','a','','href = "../php/mod_filteredGui_group.php?sessionID&e_id_css=filteredGui_Group" target = "AdminFrame" ',10,270,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> GROUP ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_filteredGroup',2,1,'allocate guis of this admin to groups where this admin is owner','Allow several groups access to one GUI','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',10,290,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_filteredUser',2,1,'allocate the user where the admin is owner to his guis ','Allow several users access to one GUI ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',10,230,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_user',2,1,'allocate the guis of this admin to a user','','a','','href = "../php/mod_filteredGui_User.php?sessionID&e_id_css=filteredGui_user" target = "AdminFrame" ',10,210,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> USER ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_Group',2,1,'allocate user of this admin to groups','','a','','href = "../php/mod_filteredUser_Group.php?sessionID&e_id_css=filteredUser_Group" target = "AdminFrame" ',10,670,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_Gui',2,1,'allocate user of this admin to guis','','a','','href = "../php/mod_filteredUser_Gui.php?sessionID&e_id_css=filteredUser_Gui" target = "AdminFrame" ',10,770,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_filteredGroup',2,1,'allocate user where this admin is owner to groups where this admin is owner','Add one user to serveral groups','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',10,490,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_filteredGui',2,1,'allocate admins user to guis of this admin','Allow one user to access several GUIs','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',10,410,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','getStyles',2,0,'load styles from wms','','a','','href = "../php/mod_getStyles.php?sessionID" target = "AdminFrame" ',10,890,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GET_STYLES','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','group_filteredUser',2,1,'allocate groups to user where this admin is owner','','a','','href = "../php/mod_group_filteredUser.php?sessionID&e_id_css=group_filteredUser" target = "AdminFrame" ',10,570,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_filteredGroup',2,1,'allocate guis to groups of this admin','','a','','href = "../php/mod_gui_filteredGroup.php?sessionID&e_id_css=gui_filteredGroup" target = "AdminFrame" ',10,650,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_filteredUser',2,1,'allocate guis to user of this admin','','a','','href = "../php/mod_gui_filteredUser.php?sessionID&e_id_css=gui_filteredUser" target = "AdminFrame" ',10,630,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_owner',2,1,'set owner','Edit GUI assign to user','a','','href = "../php/mod_gui_owner.php?sessionID&e_id_css=gui_owner" target = "AdminFrame" ',10,830,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> OWNER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWFS',2,1,'load capabilities in a gui','Load WFS Capabilities into a GUI','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,850,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/WFS_Konfiguration');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWMS',2,1,'load capabilities in a gui','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,30,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWMSList',2,1,'load wms from a list','Link WMS into GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,50,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD myWMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,1,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','myGUIlist',2,1,'go back to your GUI list','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' ',150,2,24,24,1,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','newGui',2,1,'create a new gui','Create new GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,130,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','NEW GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','orphanWMS',2,1,'display orphaned WMS','Delete orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID&&elementID=orphanWMS" target = "AdminFrame"',10,930,200,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','ORPHAN WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','owsproxy',2,1,'secure services','OWSPROXY','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,910,200,20,1,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','OWSPROXY','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','rename_copy_Gui',2,1,'rename and copy gui','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,470,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','RENAME COPY GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','showLoggedUser',2,1,'displays the logged admin','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','updateWMSs',2,1,'edit the elements of the gui','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,70,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','UPDATE WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_filteredGroup',2,1,'allocate user to groups where this admin is owner','','a','','href = "../php/mod_user_filteredGroup.php?sessionID&e_id_css=user_filteredGroup" target = "AdminFrame" ',10,450,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> myGROUP','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_filteredGui',2,1,'allocate guis of this admin to user','','a','','href = "../php/mod_user_filteredGui.php?sessionID&e_id_css=user_filteredGui" target = "AdminFrame" ',10,390,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER-> myGUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_gui',2,1,'allocate guis to user','','a','','href = "../php/mod_user_gui.php?sessionID&e_id_css=user_gui" target = "AdminFrame" ',10,370,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> GUI ','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','wfs_conf',2,1,'create and edit a gazetteer module','Configure WFS','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,870,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','WFS CONF','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','wfs_gui',2,1,'edit wfs settings','Assign WFS conf to gui','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,1000,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','asign WFS conf to gui','a','','','','AdminFrame','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_Gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'User_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'editGUI_WMS', 'file_css', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_Gui', 'file css', '../css/administration_alloc.css', 'file', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_user', 'file css', '../css/administration_alloc.css', 'a file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_Gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'group_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin2_de';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','AdminFrame',2,1,'Bereich f�r Administrationsmodule','','iframe','','frameborder = "0"',200,20,980,800,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','CreateTreeGDE',2,1,'Ordnerbaum konfigurieren','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',8,280,190,20,5,'','Ordnerbaum konfigurieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','body',1,1,'Navigation','','body','','onload=''mod_adminNavigation_init()''',0,0,180,20,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','deleteWMS',2,1,'!Vollst�ndig l�schen!','Delete WMS completely','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',8,100,190,20,5,'','!Vollst�ndig l�schen!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','delete_filteredGui',2,1,'GUI l�schen','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',110,240,80,20,5,'','GUI l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editElements',2,1,'Oberfl�chenelemente editieren','Edit GUI elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',8,260,190,20,5,'','GUI-Elemente editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editFilteredGroup',2,1,'Gruppe anlegen und editieren','Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',8,400,190,20,10,'','Gruppe anlegen und editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editFilteredUser',2,1,'Benutzer anlegen und editieren','Create and edit user','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',8,380,190,20,10,'','Benutzer anlegen und editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editGUI_WMS',2,1,'WMS GUI Einstellungen','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',8,180,190,20,5,'','WMS GUI Einstellungen','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','exportGUI',2,1,'Oberfl�che (GUI) exportieren, SQL erzeugen','export GUI, create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',8,300,190,20,10,'','GUI exportieren (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGoup_filteredUser',2,1,'Gruppe mit Benutzern best�cken','Add several users to one group','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',8,440,190,20,10,'','Gruppe mit Benutzern best�cken ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGroup_filteredGui',2,1,'Einzelner Gruppe mehrere Oberflaechen zuordnen','Allow one group access to several GUIs','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',8,570,190,25,10,'','Einzelner Gruppe mehrere <br>GUIs zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGui_filteredGroup',2,1,'Einzelner Oberfl�che mehrere Gruppen zuordnen','Allow several groups access to one GUI','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',8,605,190,25,10,'','Einzelner GUI mehrere<br> Gruppen zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGui_filteredUser',2,1,'Oberfl�che mehreren Benutzer zuordnen ','Allow several users access to one GUI ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',8,535,190,25,10,'','GUI mehreren Benutzern <br> zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredUser_filteredGroup',2,1,'Benutzer in Gruppen eintragen','Add one user to serveral groups','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,420,190,20,10,'','Benutzer in Gruppen eintragen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredUser_filteredGui',2,1,'Einem Nutzer Zugriff auf mehrere Oberfl�chen erteilen','Allow one user to access several GUIs','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',8,500,190,25,10,'','Einem Nutzer Zugriff auf <br> mehrere GUIs erteilen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','gui_owner',2,1,'GUI editieren Benutzer zuordnen','Edit GUI assign to user','a','','href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame" ',8,640,190,20,10,'','GUI editieren Benutzer zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_Configure_WMS_Access',3,1,'Hintergrund WMS Zuordnung','Configure WMS Access','div','','',5,137,193,66,2,'',' WMS Zuordnung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_GUI_Management',3,1,'Hintergrund Oberfl�chenverwaltung','GUI Management','div','','',5,217,193,126,2,'',' GUI-Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_User_Authorization',3,1,'Hintergrund Benutzerzugriff erteilen','Authorization ','div','','',5,477,193,196,2,'',' Benutzerzugriff erteilen','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_User_Management',3,1,'Hintergrund Benutzerverwaltung','User Management','div','','',5,357,193,106,2,'',' Benutzerverwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_WMS_Management',3,1,'Hintergrund WMS Management','WMS Management','div','','',5,37,193,86,2,'',' WMS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','loadWMS',2,1,'Capabilities hochladen','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',8,60,190,20,5,'','Capabilities hochladen','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','loadWMSList',2,1,'WMS in GUI einbinden','Link WMS into GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',8,160,190,20,5,'','WMS in GUI einbinden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','myGUIlist',2,1,'Zur�ck zur eigenen GUI Liste','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','newGui',2,1,'GUI erzeugen','Create new GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',8,240,85,20,5,'','GUI erzeugen','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','rename_copy_Gui',2,1,'GUI umbenennen/ kopieren','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',8,320,190,20,10,'','GUI umbenennen/kopieren','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','showLoggedUser',2,1,'Anzeige des eingeloggten Benutzers','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','updateWMSs',2,1,'Hochgeladene aktualisieren','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',8,80,190,20,5,'','Hochgeladene aktualisieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'body', 'body_css_file', '../css/admin.css', 'css-file to define the style fo the admin-gui', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin2_en';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','AdminFrame',2,1,'the frame for administration modules','','iframe','','frameborder = "0"',200,20,800,800,0,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','CreateTreeGDE',2,1,'TreeGDE set up','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',8,280,190,20,5,'','Create treeGDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','body',1,1,'navigation','','body','','onload=''mod_adminNavigation_init()''',0,0,0,0,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','deleteWMS',2,1,'!Delete WMS completely!','Delete WMS completely','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',8,100,190,20,5,'','!Delete WMS completely!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','delete_filteredGui',2,1,'Delete GUI','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',120,240,80,20,5,'','Delete GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editElements',2,1,'Edit GUI elements','Edit GUI elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',8,260,190,20,5,'','Edit GUI elements','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editFilteredGroup',2,1,'Create and edit group','Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',8,400,190,20,10,'','Create and edit group','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editFilteredUser',2,1,'Create and edit user','Create and edit user','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',8,380,190,20,10,'','Create and edit user','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editGUI_WMS',2,1,'WMS GUI settings','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',8,180,190,20,5,'','WMS GUI settings','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','exportGUI',2,1,'export GUI, create SQL','export GUI, create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',8,300,190,20,10,'','Export GUI (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGoup_filteredUser',2,1,'Add several users to one group','Add several users to one group','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',8,440,190,20,10,'','Add several users to one group ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGroup_filteredGui',2,1,'Allow one group access to several GUIs','Allow one group access to several GUIs','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',8,570,190,25,10,'','Allow one group access to <br> several GUIs','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGui_filteredGroup',2,1,'Allow several groups access to one GUI','Allow several groups access to one GUI','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',8,605,190,25,10,'','Allow several groups access <br> to one GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGui_filteredUser',2,1,'Allow several users access to one GUI ','Allow several users access to one GUI ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',8,535,190,25,10,'','Allow several users access to <br> one GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredUser_filteredGroup',2,1,'Add one user to serveral groups','Add one user to serveral groups','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,420,190,20,10,'','Add one user to serveral groups','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredUser_filteredGui',2,1,'Allow one user to access several GUIs','Allow one user to access several GUIs','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',8,500,190,25,10,'','Allow one user to access <br> several GUIs','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','gui_owner',2,1,'Edit GUI assign to user','Edit GUI assign to user','a','','href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame" ',8,640,190,20,10,'','Edit GUI assign to user','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_Configure_WMS_Access',3,1,'Configure WMS Access','Configure WMS Access','div','','',5,137,193,66,2,'',' Configure WMS Access','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_GUI_Management',3,1,'GUI Management caption','GUI Management','div','','',5,217,193,126,2,'',' GUI Management ','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_User_Authorization',3,1,'Authorization caption','Authorization ','div','','',5,477,193,186,2,'',' Authorization','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_User_Management',3,1,'User Management caption','User Management','div','','',5,357,193,106,2,'',' User Management ','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_WMS_Management',3,1,'WMS Management caption','WMS Management','div','','',5,37,193,86,2,'',' WMS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" ',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','loadWMS',2,1,'Load Capabilities','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',8,60,190,20,5,'','Load WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','loadWMSList',2,1,'Link WMS into GUI','Link WMS into GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',8,160,190,20,5,'','Link WMS into GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','myGUIlist',2,1,'go back to your GUI list','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' ',150,2,24,24,2,'','','img','mod_home.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','newGui',2,1,'Create new GUI','Create new GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',8,240,110,20,5,'','Create new GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','rename_copy_Gui',2,1,'Rename/ copy GUI','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',8,320,190,20,10,'','Rename / copy GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','showLoggedUser',2,1,'Logged User:','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','updateWMSs',2,1,'Update with Capabilities','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',8,80,190,20,5,'','Update WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'body', 'body_css_file', '../css/admin.css', 'css-file to define the style fo the admin-gui', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGoup_filteredUser', 'css_file_filteredGroup_filterdUser', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGroup', 'css_filteredUser_filteredGroup', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin_de_services';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','AdminFrame',2,1,'Bereich f�r Administrationsmodule','','iframe','','frameborder = "0"',210,25,800,800,12,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','CreateTreeGDE',2,1,'Ordnerbaum konfigurieren','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,533,200,20,5,'','Ordnerbaum konfigurieren','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','EditWMSMetadata',2,1,'edit the metadata of wms','edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,275,200,20,5,'','WMS Metadaten','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_WMS_Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','body',1,1,'Navigation','','body','','onload=''mod_adminNavigation_init()''',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','deleteWFS',2,1,'WFS l�schen','Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,393,200,20,5,'','WFS l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','deleteWMS',2,1,'!Vollst�ndig l�schen!','!Delete WMS completely!','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,100,200,20,5,'','WMS l�schen!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','delete_filteredGui',2,1,'GUI l�schen','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,491,200,20,5,'','GUI l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','editElements',2,1,'Oberfl�chenelemente editieren','Edit GUI Elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,511,200,25,5,'','GUI editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','editGUI_WMS',2,1,'WMS GUI Einstellungen','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,218,200,20,5,'','WMS Einstellungen �ndern','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','exportGUI',2,1,'GUI exportieren, SQL erzeugen','Export GUI (SQL), create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,554,200,25,10,'x','GUI exportieren (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','filteredWms_layer_topic',2,1,'allocate topics to layers of wms of this user','allocate topics to layers of wms of this user','a','','href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ',10,295,200,20,5,'','Kategoriezuordnung','a','','','','AdminFrame','http://www.mapbender.org/index.php/Topic_/_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_Configure_WMS_Access',3,1,'Hintergrund WMS Zuordnung','WMS Assignment','div','','',1,175,210,63,2,'','WMS Zuordnung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_GUI_Management',3,1,'Oberfl�chenverwaltung','GUI Management','div','','',1,448,210,153,2,'','GUI Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_Metadata',3,1,'Metadateneditor Caption','Metadata','div','','',1,252,210,63,2,'','Metadaten','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_WFS_Management',3,1,'WFS Verwaltung','WFS Management','div','','',1,330,210,103,2,'','WFS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_WMS_Management',3,1,'Dienstverwaltung Beschriftung','WMS Management','div','','',0,37,210,123,2,'','WMS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWFS',2,1,'WFS Capabilities in eine GUI laden','Load WFS Capabilities into a GUI','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,353,200,20,5,'','WFS laden','a','','','','AdminFrame','http://www.mapbender.org/index.php/LoadWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWMS',2,1,'Capabilities hochladen','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,60,200,20,5,'','WMS laden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWMSList',2,1,'WMS in GUI einbinden','Assign WMS to a GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,198,200,20,5,'','WMS einbinden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','myGUIlist',2,1,'Zur�ck zur eigenen GUI Liste','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','newGui',2,1,'GUI erzeugen','New GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,471,200,20,5,'','GUI erzeugen','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','orphanWMS',2,1,'display orphaned WMS','Delete orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID"
+target = "AdminFrame"',10,120,200,20,5,'','WMS ohne Zuordung l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','owsproxy',2,1,'secure services','OWSPROXY','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,140,200,20,10,'','OWSPROXY','a','','','','AdminFrame','http://www.mapbender.org/index.php/Owsproxy');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','rename_copy_Gui',2,1,'GUI umbenennen/ kopieren','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,576,200,20,10,'','GUI umbenennen/kopieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/RenameGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','showLoggedUser',2,1,'Anzeige des eingeloggten Benutzers','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','updateWMSs',2,1,'Hochgeladene aktualisieren','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,80,200,20,5,'','WMS aktualisieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','wfs_conf',2,1,'WFS konfigurieren','Configure WFS','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,373,200,20,5,'','WFS konfigurieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Wfs_conf');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','wfs_gui',2,1,'edit wfs settings','Assign WFS conf to gui','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,413,200,20,10,'','WFS Konfiguration GUI zuweisen','a','','','','AdminFrame','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'EditWMSMetadata', 'file_css', '../css/metadata.css', 'css-file to use for the metadata modul', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'body', 'body_file_css', '../css/admin_service.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'filteredWms_layer_topic', 'file css', '../css/administration_alloc_4.css', 'css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'filteredWms_layer_topic', 'language', 'de', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin_en_services';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','AdminFrame',2,1,'administration frame','','iframe','','frameborder = "0"',210,25,1000,800,12,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','CreateTreeGDE',2,1,'Configure TreeGDE','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,533,200,20,5,'','Configure TreeGDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','EditWMSMetadata',2,1,'edit the metadata of wms','edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,275,200,20,5,'','WMS Metadata','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_WMS_Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','body',1,1,'Navigation','','body','','onload=''mod_adminNavigation_init()''',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','deleteWFS',2,1,'Delete WFS','Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,393,200,20,5,'','Delete WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','deleteWMS',2,1,'!Delete completely!','!Delete WMS completely!','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,100,200,20,5,'','!Delete WMS completely!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','delete_filteredGui',2,1,'Delete GUI','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,491,200,20,5,'','Delete GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','editElements',2,1,'Edit GUI Elements','Edit GUI Elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,511,200,20,5,'','Edit GUI Elements','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','editGUI_WMS',2,1,'WMS GUI settings','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,218,200,20,5,'','WMS GUI settings','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','exportGUI',2,1,'Export GUI (SQL), create SQL','Export GUI (SQL), create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,553,200,20,10,'x','Export GUI (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','filteredWms_layer_topic',2,1,'allocate topics to layers of wms of this user','allocate topics to layers of wms of this user','a','','href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ',10,295,200,20,5,'','Allocate topics','a','','','','AdminFrame','http://www.mapbender.org/index.php/Topic_/_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_Configure_WMS_Access',3,1,'WMS Assignment','WMS Assignment','div','','',1,175,210,63,2,'','WMS Assignment','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_GUI_Management',3,1,'GUI Management','GUI Management','div','','',1,448,210,148,2,'','GUI Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_Metadata',3,1,'Metadata','Metadata','div','','',1,252,210,63,2,'','Metadata','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_WFS_Management',3,1,'WFS Management','WFS Management','div','','',1,330,210,103,2,'','WFS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_WMS_Management',3,1,'WMS Management','WMS Management','div','','',0,37,210,123,2,'','WMS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWFS',2,1,'Load WFS Capabilities into a GUI','Load WFS Capabilities into a GUI','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,353,200,20,5,'','Load WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/LoadWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWMS',2,1,'load Capabilities','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,60,200,20,5,'','Load WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWMSList',2,1,'assign WMS to a GUI','Assign WMS to a GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,198,200,20,5,'','Assign WMS to a GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' ',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','myGUIlist',2,1,'back to GUI list','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','newGui',2,1,'New GUI','New GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,471,200,20,5,'','New GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','orphanWMS',2,1,'Delete orphaned WMS','Delete orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID"
+target = "AdminFrame"',10,120,200,20,5,'','Delete orphaned WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','owsproxy',2,1,'secure services','OWSPROXY','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,140,200,20,10,'','OWSPROXY','a','','','','AdminFrame','http://www.mapbender.org/index.php/Owsproxy');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','rename_copy_Gui',2,1,'Rename / copy GUI','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,576,200,20,10,'','Rename / copy GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/RenameGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','showLoggedUser',2,1,'show logged in user','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','updateWMSs',2,1,'Update Capabilities','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,80,200,20,5,'','Update WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','wfs_conf',2,1,'Configure WFS','Configure WFS','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,373,200,20,5,'','Configure WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Wfs_conf');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','wfs_gui',2,1,'edit wfs settings (Assign WFS conf to GUI)','Assign WFS conf to gui','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,413,200,20,10,'','Assign WFS conf to GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'EditWMSMetadata', 'file_css', '../css/metadata.css', 'css-file to use for the metadata modul', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'body', 'body_file_css', '../css/admin_service.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'filteredWms_layer_topic', 'file css', '../css/administration_alloc_4.css', 'css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'filteredWms_layer_topic', 'language', 'de', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui','switchLocale_noreload',8,1,'changes the locale without reloading the client','Set language','div','','frameborder=''0''',696,14,50,30,5,'','<form id=''form_switch_locale'' name=''form_switch_locale'' target=''parent''>
+<select id=''language'' name=''language'' onchange=''validate_locale()''>
+</select>
+</form>
+','div','mod_switchLocale_noreload.php','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'switchLocale_noreload', 'languages', 'de,en,bg,gr,nl,it,es', '' ,'var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_closetag, e_js_file) VALUES('gui1', 'popup', 6, 1, 'popup replacement', 'div', 'div', 'popup.js');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui1' AND e_id = 'wfs_gazetteer';
+DELETE FROM gui_treegde WHERE fkey_gui_id IN ('gui', 'gui1', 'admin1', 'gui2', 'wms_africa');
+-- update own applications
+Update gui_element set e_title =
+mynew.e_title from gui_element as mynew
+where gui_element.e_id = mynew.e_id
+and mynew.fkey_gui_id = 'gui'
+and gui_element.fkey_gui_id != 'gui'
+and gui_element.fkey_gui_id != 'gui1'
+and gui_element.fkey_gui_id != 'gui2'
+and gui_element.fkey_gui_id != 'gui_digitize';
+and mynew.fkey_gui_id = 'gui1'
+and mynew.fkey_gui_id = 'gui2'
+and mynew.fkey_gui_id = 'gui_digitize'
+Delete from gui_element_vars where fkey_e_id ='tabs' and var_name LIKE 'tab_titles[%';
+Update gui_element_vars set var_type='php_var' where fkey_e_id ='tabs' and var_name LIKE 'tab_ids[%' and var_type='var';
+DELETE FROM gui_element WHERE e_id = 'ajax';
+Delete from gui_element where e_id='keyHandler';
+DELETE FROM gui_element WHERE e_id = 'geometry';
+Select * from gui_element where e_mb_mod ='geometry.js' ;
+update gui_element set e_mb_mod = 'geometry.js'
+where e_id = 'digitize';
+where e_id = 'gazetteerWFS';
+where e_id = 'setSpatialRequest';
Added: trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
--- trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql (rev 0)
+++ trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.4.5_to_2.5_pgsql_ISO-8859-1.sql 2009-03-17 16:16:15 UTC (rev 3779)
@@ -0,0 +1,539 @@
+-- database changes in version 2.5
+-- notice language plpgsql has to be installed
+-- How to install plpgsql?
+-- createlang plpgsql mapbender
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin_de_services', 20, '');
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin_en_services', 20, '');
+-- table mb_monitor: new columns for mb_monitor
+ALTER TABLE mb_monitor ADD COLUMN image int4;
+ALTER TABLE mb_monitor ADD COLUMN map_url varchar(2048);
+-- WFS database handling
+-- enhancement of the datadase structure concerning WFS metadata (same solution like for WMS)
+ALTER table wfs add wfs_getcapabilities_doc text;
+ALTER table wfs add wfs_upload_url character varying(255);
+ALTER table wfs add fees character varying(255);
+ALTER table wfs add accessconstraints text;
+ALTER table wfs add individualname character varying(255);
+ALTER table wfs add positionname character varying(255);
+ALTER table wfs add providername character varying(255);
+ALTER table wfs add city character varying(255);
+ALTER table wfs add deliverypoint character varying(255);
+ALTER table wfs add administrativearea character varying(255);
+ALTER table wfs add postalcode character varying(255);
+ALTER table wfs add voice character varying(255);
+ALTER table wfs add facsimile character varying(255);
+ALTER table wfs add electronicmailaddress character varying(255);
+ALTER table wfs add wfs_mb_getcapabilities_doc text;
+ALTER table wfs add wfs_owner integer;
+ALTER table wfs add wfs_timestamp integer;
+ALTER table wfs add country character varying(255);
+ALTER TABLE wfs ALTER COLUMN wfs_title SET NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_title SET DEFAULT ''::character varying;
+ALTER TABLE wfs ALTER COLUMN wfs_version SET NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_version SET DEFAULT ''::character varying;
+ALTER TABLE wfs ALTER COLUMN wfs_getcapabilities SET NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_getcapabilities SET DEFAULT ''::character varying;
+alter table wfs_featuretype add column featuretype_searchable integer default 1;
+alter table wfs_featuretype add column featuretype_abstract character varying(50);
+-- grant root access to default wfs
+UPDATE wfs SET wfs_owner = 1;
+-- new table gui_wfs_conf
+CREATE TABLE gui_wfs_conf (
+ fkey_gui_id character varying(50) DEFAULT ''::character varying NOT NULL,
+ fkey_wfs_conf_id integer DEFAULT 0 NOT NULL
+ALTER TABLE ONLY gui_wfs_conf
+ ADD CONSTRAINT pk_fkey_wfs_conf_id PRIMARY KEY (fkey_gui_id, fkey_wfs_conf_id);
+ ADD CONSTRAINT gui_wfs_conf_ibfk_1 FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
+ ADD CONSTRAINT gui_wfs_conf_ibfk_2 FOREIGN KEY (fkey_wfs_conf_id) REFERENCES wfs_conf(wfs_conf_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- insert wfs confs into gui digitize
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 1);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 3);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 4);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 2);
+-- new table wfs_featuretype_keyword:
+CREATE TABLE wfs_featuretype_keyword (
+ fkey_featuretype_id integer NOT NULL,
+ fkey_keyword_id integer NOT NULL
+ALTER TABLE ONLY wfs_featuretype_keyword
+ ADD CONSTRAINT fkey_keyword_id_fkey_featuretype_id FOREIGN KEY (fkey_keyword_id) REFERENCES keyword(keyword_id) ON UPDATE CASCADE ON DELETE CASCADE;
+ ADD CONSTRAINT fkey_featuretype_id_fkey_keyword_id FOREIGN KEY (fkey_featuretype_id) REFERENCES wfs_featuretype(featuretype_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- new table layer_load_count
+CREATE TABLE layer_load_count (
+ fkey_layer_id int4,
+ load_count int8
+-- table wfs_conf
+ALTER TABLE wfs_conf add COLUMN wfs_conf_description text;
+-- table wfs_conf_element: change in WFS configuration: access to geometries may now be restricted
+ALTER TABLE wfs_conf_element ADD COLUMN f_show_detail int4;
+ALTER TABLE wfs_conf_element ADD COLUMN f_operator VARCHAR(50);
+ALTER TABLE ONLY wfs_conf
+ ADD CONSTRAINT wfs_conf_ibfk_2 FOREIGN KEY (fkey_featuretype_id) REFERENCES wfs_featuretype(featuretype_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- table gui_element: new element for table admin1 to edit wfs settings
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','WFS',2,1,'edit wfs settings','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,1005,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT WFS','a','','','','AdminFrame','');
+-- new table translation: new table for translations
+CREATE TABLE translations
+ trs_id serial PRIMARY KEY not null,
+ locale varchar(8),
+ msgid varchar(512),
+ msgstr varchar(512)
+CREATE INDEX msgid_idx ON translations(msgid);
+ CREATE TRUSTED PROCEDURAL LANGUAGE 'plpgsql'
+ HANDLER plpgsql_call_handler;
+-- new function gettext for easy translations
+CREATE OR REPLACE FUNCTION gettext(locale_arg "text", string "text")
+RETURNS "varchar" AS
+$BODY$
+DECLARE
+ msgstr varchar(512);
+ trl RECORD;
+BEGIN
+ -- RAISE NOTICE '>%<', locale_arg;
+ SELECT INTO trl * FROM translations
+ WHERE trim(from locale) = trim(from locale_arg) AND msgid = string;
+ -- we return the original string, if no translation is found.
+ -- this is consistent with gettext's behaviour
+ IF NOT FOUND THEN
+ RETURN string;
+ ELSE
+ RETURN trl.msgstr;
+ END IF;
+END;
+$BODY$
+ LANGUAGE 'plpgsql' VOLATILE;
+-- new entries for table translations
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Pan', 'Ausschnitt verschieben');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Display complete map', 'gesamte Karte anzeigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom in', 'In die Karte hineinzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom out', 'Aus der Karte herauszoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Back', 'Zurueck');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Forward', 'Nach vorne');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Coordinates', 'Koordinaten anzeigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom by rectangle', 'Ausschnitt waehlen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Redraw', 'Neu laden oder Tastatur: Leertaste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Query', 'Datenabfrage');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Logout', 'Abmelden');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'WMS preferences', 'WMS Einstellungen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS from filtered list', 'WMS von gefilteter Liste hinzufuegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set map center', 'Kartenmittelpunkt setzen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Help', 'Hilfe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Show WMS infos', 'Anzeige von WMS Informationen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Save workspace as web map context document', 'Ansicht als Web Map Context Dokument speichern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Resize Mapsize', 'Bildschirmgroesse anpassen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Rubber', 'Skizze loeschen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Get Area', 'Flaeche berechnen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Close Polygon', 'Polygon schliessen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Move back to your GUI list', 'Zurueck zur GUI Liste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Legend', 'Legende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Print', 'Druck');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Imprint', 'Impressum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Maps', 'Karten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Search', 'Suche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Meetingpoint', 'Treffpunkt');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Metadatasearch', 'Metadatensuche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS', 'WMS hinzufuegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS from List', 'WMS aus Liste hinzufuegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Change Projection', 'Projektion aendern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Digitize', 'Digitalisierung');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Overview', 'UEbersichtskarte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Drag Mapsize', 'Karte vergroessern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Mapframe', 'Kartenfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Navigation Frame', 'Navigationsfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scale Select', 'Auswahl des Massstabes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scale Text', 'Massstab per Texteingabe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scalebar', 'Massstabsleiste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set Background', 'Hintegrundkarte auswaehlen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom to Coordinates', 'Zu den Koordinaten zoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Change Password', 'Passwort aendern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Load a web map context document', 'laden eines Web Map Context Dokumentes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de ', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Pan', '???????? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Display complete map', '?????? ?????? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom in', '?????? ??????? ? ??-???? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom out', '?????? ??????? ? ??-?????? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Back', '?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Forward', '??????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Coordinates', '??????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom by rectangle', '??????? ??????? ? ????????? ??????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Redraw', '????????? ??? ?? ????????????: ?????? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Query', '????? ??? ???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Logout', '????? ?? ??????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'WMS preferences', 'WMS ?????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS from filtered list', '?????? WMS ?? ?????? ??????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Set map center', '??????? ?????? ?? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Help', '?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Show WMS infos', '?????? WMS ??????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Save workspace as web map context document', '?????? ???????? ???????? ???? Web Map Context ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Resize Mapsize', '??????? ?????????? ?? ???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Rubber', '??????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Get Area', '??????? ????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Close Polygon', '??????? ???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Move back to your GUI list', '????? ??? ??????? ? ?????????? (GUI)');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Legend', '???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Print', '?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Imprint', '???????? ????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Maps', '?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Search', '???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Meetingpoint', '????? ?? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Metadatasearch', '??????? ?? ?????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS', '?????? WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS from List', '?????? WMS ?? ??????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Info', '??????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Change Projection', '??????? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Copyright', '???????? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Digitize', '??????????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Overview','??????? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Drag Mapsize', '??????? ??????? ?? ???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Mapframe', '????? ?? ???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Navigation Frame', '???????????? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scale Select', '????? ?? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scale Text', '?????? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scalebar', '??????? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Set Background', '?????? ?????? ???????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom to Coordinates', '?????? ??????? ????? ?????????? ??????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Change Password', '??????? ??????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Load a web map context document', '?????? Web Map Context ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Logo', '?????? ????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Measure distance', '?????? ??????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Pan', '??????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Display complete map', '???????? ??????? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom in', 'Zoom In');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom out', 'Zoom Out');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Back', '????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Forward', '???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Coordinates', '?????????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom by rectangle', '???? ??? ?????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Redraw', '????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Query', '??????? ???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Logout', '??????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'WMS preferences', '??????? ?? ??????? ??? WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS from filtered list', '???????? WMS ??? ?? ????????????? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Set map center', '?? ??????????? ?????? ??????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Help', '???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Save workspace as web map context document', 'Ansicht als Web Map Context Dokument speichern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Rubber', '?? ???????- ???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Close Polygon', '?? ??????? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ( 'gr', 'Move back to your GUI list', '?????????? ??? GUI ?????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Print', '????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Maps', ' ??????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS', '???????? WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS from List', '???????? WMS ??? ??? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Navigation Frame', 'Navigationsfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Load a web map context document', 'laden eines Web Map Context Dokumentes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Measure distance', '??????? ?????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Meetingpoint', '?????? ??????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Info', '???????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Digitize', '???????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Change Projection', '?????? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Set Background', '??????? ??????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Overview', '?????????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Change Password', '?????? ????????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scalebar', '??????? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr ', 'Logo', '????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom to Coordinates', '??????? ?? ?????????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scale Text', '??????? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Show WMS infos', '??????? WMS ???????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Legend', '???????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Search', '?????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Resize Mapsize', '?????? ???????? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Drag Mapsize', '?????? ???????? ????? ?? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Mapframe', '??????? ?????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Get Area', '??????? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Imprint', '?????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scale Select', '??????? ????????');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Metadatasearch', '????????? ??? Metadata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Pan', 'Selectie verschuiven');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Display complete map', 'Hele kaart tonen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom in', 'Inzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom out', 'Uitzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Back', 'Terug');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Forward', 'Voorwaarts');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Coordinates', 'Koordinaten tonen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom by rectangle', 'Zoom rechthoek-selectie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Redraw', 'Opfrissen of toetsenbord : spatiebalk');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Query', 'Data opvragen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Logout', 'Afmelden');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'WMS preferences', 'WMS instellingen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS from filtered list', 'WMS van gefilterte lijst toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set map center', 'Kaartmiddelpunt aangeven');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Help', 'Help');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Show WMS infos', 'Tonen van WMS Informatie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Save workspace as web map context document', 'zicht als Web map context dokument bewaren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Resize Mapsize', 'beeldschermgrote aanpassen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Rubber', 'schets verwerpen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Get Area', 'oppervlakte berekenen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Close Polygon', 'Polygoon sluiten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Move back to your GUI list', 'Terug naar GUI lijst');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Legend', 'Legende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Print', 'Drukken');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Imprint', 'Impressum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Maps', 'Kaarten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Search', 'Zoek');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Meetingpoint', 'Trefpunt');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Metadatasearch', 'Zoeken naar Metadata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS', 'WMS toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS from List', 'WMS uit lijst toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Info', 'Informatie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Change Projection', 'Projektie veranderen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Digitize', 'Digitaliseren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Overview', 'overzichtskaart');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Drag Mapsize', 'Kaart vergroten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Mapframe', 'Kaartvenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Navigation Frame', 'Navigeervenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scale Select', 'Schaal selecteren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scale Text', 'Schaal via tekstingave');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scalebar', 'Schaalbalk');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set Background', 'Achtergrond selecteren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom to Coordinates', 'Naar koordinaten zoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Change Password', 'Paswoord wijzigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Load a web map context document', 'Laad een Web Map Context Dokument');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Measure distance', 'Meet afstand');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Pan', 'Sposta dettaglio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Display complete map', 'Mostra tutta la mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom in', 'Ingrandisci');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom out', 'Riduci');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Back', 'Indietro');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Forward', 'Avanti');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Coordinates', 'Mostra coordinate');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom by rectangle', 'Seleziona dettaglio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Redraw', 'Ridisegna oppure, da tastiera: spazio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Query', 'Interroga');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Logout', 'Logout');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'WMS preferences', 'Impostazioni WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS from filtered list', 'Aggiungi un WMS da una lista filtrata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set map center', 'Fissa il centro della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Help', 'Aiuto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Show WMS infos', 'Mostra informazioni sul WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Save workspace as web map context document', 'Salva vista come documento di Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Resize Mapsize', 'Adatta la dimensione della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Rubber', 'Cancella bozza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Get Area', 'Calcola area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Close Polygon', 'Chiudi poligono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Move back to your GUI list', 'Torna alla lista delle GUI');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Legend', 'Legenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Print', 'Stampa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Imprint', 'Colophon');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Maps', 'Mappe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Search', 'Cerca');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Meetingpoint', 'Punti di incontro');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Metadatasearch', 'Ricerca metadati');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS', 'Aggiungi WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS from List', 'Aggiungi WMS da lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Change Projection', 'Cambia proiezione');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Digitize', 'Digitalizza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Overview', 'Mappa di insieme');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Drag Mapsize', 'Cambia dimensione mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Mapframe', 'Quadro della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Navigation Frame', 'Quadro di navigazione');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scale Select', 'Scelta della scala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scale Text', 'Scala dei testi');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scalebar', 'Scala di riferimento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set Background', 'Seleziona mappa di sfondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom to Coordinates', 'Ingrandisci alle coordinate');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Change Password', 'Cambia password');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Load a web map context document', 'Carica un documento Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Measure distance', 'Misura distanza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Pan', 'Desplazamiento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Display complete map', 'Desplazamiento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom in', 'Zoom +');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom out', 'Zoom -');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Back', 'Zoom previo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Forward', 'Zoom siguiente');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Coordinates', 'Mostrar coordenadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom by rectangle', 'Zoom rectangulo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Redraw', 'Refrescar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Query', 'Busqueda de datos');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Logout', 'Terminar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'WMS preferences', 'Ajuste WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS from filtered list', 'Anadir WMS desde lista filtrada');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set map center', 'Centrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Help', 'Ayuda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Show WMS infos', 'Mostrar informacion sobre WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Save workspace as web map context document', 'Guardar vista como fichero Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Resize Mapsize', 'Modificar el tamano de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Rubber', 'Borrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Get Area', 'Calcular area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Close Polygon', 'Cerrar poligono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Move back to your GUI list', 'Volver a la lista WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Legend', 'Leyenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Print', 'Imprimir');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Imprint', 'Aviso legal');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Maps', 'Mapas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Search', 'Busqueda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Meetingpoint', 'Lugar de reunion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Metadatasearch', 'Busqueda de datos meta');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS', 'Anadir WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS from List', 'Anadir WMS desde lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Info', 'Informacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Change Projection', 'Cambiar projecto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Digitize', 'Digitalizacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Overview', 'Mapa de vision general');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Drag Mapsize', 'Ampilar vista de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Mapframe', 'Ventana de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Navigation Frame', 'Ventana de navigacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scale Select', 'Selecionar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scale Text', 'Teclar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scalebar', 'Fraja de escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set Background', 'Poner el fondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom to Coordinates', 'Zoom en coordenadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Change Password', 'Cambiar clave');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Load a web map context document', 'Cargar un documento de Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Measure distance', 'Medir distancias');
+-- new table gui_kml
+CREATE TABLE gui_kml (
+ kml_id serial,
+ fkey_mb_user_id integer NOT NULL,
+ fkey_gui_id character varying(50) NOT NULL,
+ kml_doc text NOT NULL,
+ kml_name character varying(64),
+ kml_description text,
+ kml_timestamp integer NOT NULL
+ALTER TABLE ONLY gui_kml
+ ADD CONSTRAINT mb_gui_kml_pkey PRIMARY KEY (kml_id);
+ ADD CONSTRAINT gui_kml_fkey_mb_user_id FOREIGN KEY (fkey_mb_user_id) REFERENCES mb_user(mb_user_id) ON UPDATE CASCADE ON DELETE CASCADE;
+ ADD CONSTRAINT gui_kml_id_fkey_gui_id FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- new sld_user_layer table
+CREATE TABLE sld_user_layer (
+ sld_user_layer_id serial NOT NULL,
+ fkey_layer_id integer NOT NULL,
+ fkey_gui_id character varying,
+ sld_xml text,
+ use_sld smallint
+ALTER TABLE sld_user_layer ADD CONSTRAINT pk_sld_user_layer PRIMARY KEY (sld_user_layer_id);
+-- Name: sld_user_layer_ibfk_1; Type: FK CONSTRAINT; Schema: public; Owner: admin
+ALTER TABLE ONLY sld_user_layer
+ ADD CONSTRAINT sld_user_layer_ibfk_1 FOREIGN KEY (fkey_mb_user_id) REFERENCES mb_user(mb_user_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- Name: sld_user_layer_ibfk_2; Type: FK CONSTRAINT; Schema: public; Owner: admin
+ ADD CONSTRAINT sld_user_layer_ibfk_2 FOREIGN KEY (fkey_layer_id) REFERENCES layer(layer_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- Name: sld_user_layer_ibfk_3; Type: FK CONSTRAINT; Schema: public; Owner: admin
+ ADD CONSTRAINT sld_user_layer_ibfk_3 FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- add sld related columns
+alter table gui_wms add column gui_wms_sldurl character varying(255) DEFAULT ''::character varying NOT NULL;
+alter table wms add column wms_supportsld boolean;
+alter table wms add column wms_userlayer boolean;
+alter table wms add column wms_userstyle boolean;
+alter table wms add column wms_remotewfs boolean;
+-- opacity handeling
+ALTER TABLE gui_wms ADD COLUMN gui_wms_opacity INT DEFAULT 100;
+UPDATE gui_element SET e_mb_mod = 'mod_addWMSgeneralFunctions.js' WHERE e_id = 'addWMS';
+ALTER TABLE gui_element ALTER COLUMN e_js_file TYPE character varying(255);
+ALTER TABLE gui_element ALTER COLUMN e_mb_mod TYPE character varying(255);
+ALTER TABLE wms ALTER COLUMN fees TYPE text;
+ALTER TABLE wms RENAME COLUMN wms_mb_getcapabilies_doc TO wms_mb_getcapabilities_doc;
Added: trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_pgsql_ISO-8859-1.sql
--- trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_pgsql_ISO-8859-1.sql (rev 0)
+++ trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.5.1rc1_to_2.5.1_pgsql_ISO-8859-1.sql 2009-03-17 16:16:15 UTC (rev 3779)
@@ -0,0 +1,11 @@
+-- database changes in version 2.5.1
+DELETE FROM wfs_conf_element WHERE f_id = ((SELECT DISTINCT f_id FROM wfs_conf_element) EXCEPT (SELECT DISTINCT f_id FROM wfs_conf_element, wfs_element WHERE f_id = element_id));
+ALTER TABLE ONLY wfs_element
+ ADD CONSTRAINT wfs_element_element_id_key UNIQUE (element_id);
+ALTER TABLE ONLY wfs_conf_element
+ ADD CONSTRAINT wfs_conf_element_id_ibfk_1 FOREIGN KEY (f_id) REFERENCES wfs_element (element_id) ON UPDATE CASCADE ON DELETE CASCADE;
Added: trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_pgsql_ISO-8859-1.sql
--- trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_pgsql_ISO-8859-1.sql (rev 0)
+++ trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.5_to_2.5.1rc1_pgsql_ISO-8859-1.sql 2009-03-17 16:16:15 UTC (rev 3779)
@@ -0,0 +1,18 @@
+UPDATE gui_element SET e_closetag = '' WHERE e_element = 'img';
+-- translations missing for bg,gr,nl
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set language', 'Sprache auswählen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set language', 'Seleccion del idioma');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set language', 'Lingua');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Set language', 'Choisir une langue');
+-- enlarge WFS metadata columns
+ALTER TABLE wfs_featuretype ALTER COLUMN featuretype_abstract TYPE text;
+ALTER TABLE wfs_featuretype ALTER COLUMN featuretype_title TYPE varchar(255);
+ALTER TABLE wfs_featuretype ALTER COLUMN featuretype_name TYPE varchar(255);
+ALTER TABLE wfs_element ALTER COLUMN element_name TYPE varchar(255);
+ALTER TABLE wfs_element ALTER COLUMN element_type TYPE varchar(255);
Added: trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.5rc6_to_2.5_pgsql_ISO-8859-1.sql
--- trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.5rc6_to_2.5_pgsql_ISO-8859-1.sql (rev 0)
+++ trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_2.5rc6_to_2.5_pgsql_ISO-8859-1.sql 2009-03-17 16:16:15 UTC (rev 3779)
@@ -0,0 +1 @@
\ No newline at end of file
Added: trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_pgsql_ISO-8859-1.sql
--- trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_pgsql_ISO-8859-1.sql (rev 0)
+++ trunk/mapbender/resources/db/pgsql/ISO-8859-1/update/update_guis_2.4.5_to_2.5_pgsql_ISO-8859-1.sql 2009-03-17 16:16:15 UTC (rev 3779)
@@ -0,0 +1,899 @@
+-- update of mapbender guis
+-- gui / gui1 / gui2 / gui_digitize
+-- admin1 / admin2_de / admin2_de / admin_de_services / admin_en_services
+-- Mapbender Test for Version: 2.5
+-- 2008-09-29
+-- notice: this guis are not all working properly
+-- the guis contain the e_title informations fpor i18n
+-- these sql are for developers to get the guis working
+Delete from gui_element where fkey_gui_id ='gui';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','FeatureInfoRedirect',2,1,'redirect featureInfoRequests in an iframe for each wms','Info','iframe','../html/mod_blank.html','frameborder="0"',83,-17,1,1,0,'','','iframe','mod_featureInfoRedirect.php','','','','http://www.mapbender.org/index.php/FeatureInfoRedirect');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','WMS_preferences',2,1,'configures the preferences of each loaded wms','WMS preferences','img','../img/button_gray/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',540,10,24,24,1,'','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_gray/add_off.png','onclick=''mod_addWMS()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',515,10,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','back',2,1,'History.back()','Back','img','../img/button_gray/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"',360,10,24,24,1,'','','','mod_back.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','body',1,1,'body (obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','featureInfo1',2,0,'FeatureInfoRequest','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')"',425,10,24,24,1,'','','','mod_featureInfoTunnel.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfoTunnel');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','forward',2,1,'History.forward()','Forward','img','../img/button_gray/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" ',385,10,24,24,1,'','','','mod_forward.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','gazetteerMetadata',2,1,'gazetteer for metadata','Metadatasearch','iframe','../php/mod_gazetteerMetadata.php?sessionID&target=mapframe1,overview','frameborder = "0"',1,1,1,1,4,'visibility:hidden;','','iframe','','','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','Search','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','geometry.js','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" ',620,10,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','highlightPOI',2,1,'highlight 1 to n pois in your gui with a Symbol and a special text','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_highlightPOI.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','imprint',2,1,'Information about the owner of the gui','Imprint','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_back',3,1,'layout, background for buttons','','div','','',360,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_featureInfo',3,1,'layout, background for FeatureInfo','','div','','',425,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_help',3,1,'layout, background for Help-button','','div','','',620,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_logout',3,1,'layout, background for Logout-button','','div','','',660,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_metadata',3,1,'layout, background for Metadata','','div','','',580,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_wms',3,1,'layout, background for wms','','div','','',490,10,76,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_zoom',3,1,'layout, background for Zoom-button','','div','','',220,10,126,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','loadData',2,1,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','logo',2,1,'Logo','Logo','img','../img/mapbender_logo.png','',20,20,180,26,5,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' ',660,10,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','mapframe1',2,1,'frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',230,55,500,450,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','meetingPoint',2,1,'create a meeting point','Meetingpoint','iframe','../php/mod_meetingPoint.php?sessionID','frameborder = "0" ',0,0,NULL ,NULL ,4,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_gray/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_gray/metadata_over.png"'' onmouseout=''this.src="../img/button_gray/metadata_off.png"'' ',580,10,24,24,1,'','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,0,0,0,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',30,65,150,130,100,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','pan1',2,1,'pan','Pan','img','../img/button_gray/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')" ',270,10,24,24,1,'','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','printPDF',2,1,'pdf print','Print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_gray/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')" ',295,10,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','setBBOX',2,0,'set extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','setBackground',2,1,'switch background-wms','Set Background','form','','',30,210,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','showCoords_div',2,1,'displays coodinates by onmouseover','Coordinates','img','../img/button_gray/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ',450,10,24,24,1,'','','','mod_coords_div.php','','mapframe1','dependendDiv','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','tabs',2,1,'vertical tabs to handle iframes','','div','','',10,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2','Maps','iframe','../html/mod_treefolder2.php?sessionID','frameborder = "0" ',10,220,200,300,NULL ,'visibility:visible','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_gray/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)" ',320,10,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_gray/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' ',220,10,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_gray/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''',245,10,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_all', '0', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_group', '0', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_gui', '0', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'gazetteerWFS', 'wfsConfIdString', '1', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_height', '14', 'height of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_width', '14', 'width of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_ccs_file', '../css/meetingPoint.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_format', 'prompt', 'decide which format to choose (email, prompt)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_subject', 'Ein Treffpunkt wurde erzeugt. Folgen Sie dem Link!', 'if you choose format email, define the text for the subject', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_height', '14', 'height of the meetingPoint_icon', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_icon', '../img/redball.gif', 'path to meetingPoint image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_max_characters', '70', 'define the maximum length of the text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_please_click', 'Please click in the map to define the meeting point position!', 'text to show if no clickposition is set', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_style', 'background-color:white;font-weight: bold;color:red;font-family:Arial;', 'style to display the meetingPoint text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_width', '14', 'width of the meetingPoint_icon', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[5]', '160', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[6]', '280', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[5]', 'meetingPoint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[6]', 'gazetteerMetadata', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_prefix', ' ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'menu', 'opacity_up,opacity_down,zoom,metainfo,hide,wms_up,wms_down,layer_up,layer_down,remove', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'metadatalink', 'false', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui1';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','WMS_preferences',2,1,'configure the preferences of each loaded wms','WMS preferences','img','../img/button_blink_red/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',670,60,24,24,1,'','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_blink_red/add_off.png','onclick=''mod_addWMS()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',645,60,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMSfromList',2,1,'add a WMS to the running application from a list','Adding WMS from List','img','../img/button_blink_red/addlist_off.png','onclick=''window.open("../javascripts/mod_addWMSfromList.php?sessionID","printWin","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',595,60,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',620,60,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','back',2,1,'History.back()','Back','img','../img/button_blink_red/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" ',400,60,24,24,1,'','','','mod_back.php','','mapframe1,overview','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','body',1,1,'body (obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','center1',2,1,'Center button','Set map center','img','../img/button_blink_red/center_off.png','onmouseover = "mb_regButton(''init_gui1_center'')" ',310,60,24,24,1,'','','','mod_center1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','changeEPSG',2,1,'change EPSG, Postgres required, overview is targed for full extent','Change Projection','iframe','../php/mod_changeEPSG.php?sessionID','scrolling="no" frameborder=''0'' ',432,25,107,24,1,'','','iframe','','','overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','changePassword_button',2,1,'button: change password of logged user','Change Password','img','../img/button_blink_red/change_password_off.png','onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0'' onmouseover=''this.src="../img/button_blink_red/change_password_over.png"'' onmouseout=''this.src="../img/button_blink_red/change_password_off.png"'' ',750,60,24,24,1,'cursor:hand','','','','','','','http://www.mapbender.org/index.php/ChangePassword');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','closePolygon',3,1,'close Polygon ','Close Polygon','div','','',0,0,0,0,0,'','','div','mod_closePolygon.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',-59,1,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',-59,1,0,0,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','featureInfo1',2,1,'FeatureInfoRequest','Query','img','../img/button_blink_red/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')" ',465,60,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','forward',2,1,'History.forward()','Forward','img','../img/button_blink_red/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" ',425,60,24,24,1,'','','','mod_forward.php','','mapframe1,overview','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','getArea',3,1,'Calculation of area, Postgis required','Get Area','div','','',0,0,0,0,0,'','','div','mod_getArea.php','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','help',2,1,'button help','Help','img','../img/button_blink_red/help_off.png','onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")''',790,60,24,24,1,'','','','','','','','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','help1',2,1,'button help','Help','img','../img/button_blink_red/help_off.png','onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")''',790,60,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/help');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','highlightPOI',2,1,'highlight 1 to n pois in your gui with a Symbol and a special text','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_highlightPOI.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','layout_1',3,1,'layout, background for buttons','','div','','',208,58,670,28,0,'background-color:#FFFFFF;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&wms_legend = yes','frameborder=''0''',-59,200,180,600,3,'','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','loadData',2,1,'IFRAME to load data','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','loadwmc',2,1,'load workspace from WMC','Load a web map context document','img','../img/button_blink_red/wmc_load_off.png','onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',895,60,24,24,1,'','','','mod_loadwmc.php','','mapframe1','','http://www.mapbender.org/index.php/LoadWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','logout',2,1,'Logout','Logout','img','../img/button_blink_red/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blink_red/logout_over.png"'' onmouseout=''this.src="../img/button_blink_red/logout_off.png"'' ',830,60,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',-59,1,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','mapframe1',2,1,'Frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',220,105,625,400,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','measure',2,1,'Measure','Measure distance','img','../img/button_blink_red/measure_off.png','onmouseover = "mb_regButton(''init_mod_measure'')"',515,60,24,24,1,'','','','mod_measure.php','','mapframe1','','http://www.mapbender.org/index.php/Measure');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_blink_red/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_blink_red/metadata_over.png"'' onmouseout=''this.src="../img/button_blink_red/metadata_off.png"'' ',710,60,24,24,1,'','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,0,0,10,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',15,25,150,150,2,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','pan1',2,1,'pan','Pan','img','../img/button_blink_red/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')"',260,60,24,24,1,'','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','print1',2,0,'start print GUI','Print','img','../img/button_blink_red/print_off.png','onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID","printWin","width=300, height=400, resizable=yes ")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',555,60,24,24,1,'','','','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','printPDF',2,1,'start print GUI','Print','img','../img/button_blink_red/print_off.png','onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF_b.conf","printWin","width=180, height=200, resizable=yes ")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',555,60,24,24,1,'','','','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','repaint',2,1,'refresh a mapobject','Redraw','img','../img/button_blink_red/repaint_off.png','onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)'' ',360,60,24,24,1,'','','','mod_repaint.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','rubber',3,1,'deletes temporary (digitized) objects','Rubber','div','','',0,0,0,0,0,'','','div','mod_rubber.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',0,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','savewmc',2,1,'save workspace as WMC','Save workspace as web map context document','img','../img/button_blink_red/wmc_save_off.png','onclick=''mod_savewmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',870,60,24,24,1,'','','','mod_savewmc.php','','mapframe1','','http://www.mapbender.org/index.php/SaveWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scaleSelect',2,1,'Scale-Selectbox','Scale Select','select','','onchange=''mod_scaleSelect(this)''',555,25,100,20,1,'','<option value = ''''>Scale</option> <option value=''100''>1 : 100</option> <option value=''250''>1 : 250</option> <option value=''500''>1 : 500</option> <option value=''1000''>1 : 1000</option> <option value=''2500''>1 : 2500</option> <option value=''5000''>1 : 5000</option> <option value=''10000''>1 : 10000</option> <option value=''25000''>1 : 25000</option> <option value=''30000''>1 : 30000</option> <option value=''50000''>1 : 50000</option> <option value=''75000''>1 : 75000</option> <option value=''100000''>1 : 100000</option> <option value=''200000''>1 : 200000</option> <option value=''300000''>1 : 300000</option> <option value=''400000''>1 : 400000</option> <option value=''500000''>1 : 500000</option> <option value=''600000''>1 : 600000</option> <option value=''700000''>1 : 700000</option> <option value=''800000''>1 : 800000</option> <option value=''900000''>1 : 900000</option> <option value=''1000000''>1 : 1000000</option>','select','mod_scaleSel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scaleText',2,1,'Scale-description field','Scale Text','form','','onsubmit=''return mod_scaleText()''',672,25,100,30,0,'','<input type="text">','form','mod_scaleText.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scalebar',2,1,'scalebar','Scalebar','div','','',0,0,0,0,0,'','','div','mod_scalebar.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_blink_red/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')"',285,60,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBBOX',2,1,'set Extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBackground',2,0,'switch background-wms','Set Background','form','','',15,190,0,0,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBackground_all',2,0,'switch all background-wms','Set Background','form','','',157,190,40,20,1,'','<input type=''checkbox'' onclick=''mod_setBackground_all_init(this)''> <font face="Arial, sans-serif" size="2">all</font>','form','mod_setBackground_all.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setPOI2Scale',2,1,'zoom to a poi (get-parameter)','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_setPOI2Scale.php','','mapframe1','','http://www.mapbender.org/index.php/Mod_setPoi2Scale');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setScaleHint',1,0,'set scaleHint for mapframes','','div','','',1,1,1,1,0,'visibility:hidden;','','div','mod_scaleHint.php','','mapframe1,100,10000000','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','showCoords_div',2,1,'displays coordinates by onmouseover','Coordinates','img','../img/button_blink_red/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ',490,60,24,24,1,'','','','mod_coords_div.php','','mapframe1','','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeConfGDE',2,0,'configurable directory tree','Maps','iframe','../php/mod_treefolderClient.php?sessionID','frameborder = "0" ',0,180,250,500,0,'visibility:visible','','iframe','mod_treeConf.js','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeGDE_1',2,0,'directory tree, checkbox for visible, checkbox for querylayer, no immediate refreshing, with nested layers','Maps','iframe','../html/mod_sync_treefolder_1.html','frameborder = "0" ',0,180,250,500,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','wfs_gazetteer',2,0,'gazetteer using wfs','Search','iframe','../php/mod_wfs_gazetteer.php?sessionID&color=255,0,255','frameborder = "0" ',-50,490,250,300,0,'visibility:visible','','iframe','','','mapframe1,overview','wfs','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomCoords',2,1,'zoom to coordinate','Zoom to Coordinates','iframe','../php/mod_zoomCoords_en.php?sessionID','frameborder = "0" ',205,7,220,45,0,'','','iframe','','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_blink_red/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)" ',335,60,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_blink_red/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' ',210,60,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_blink_red/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' ',235,60,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_db', '0', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_height', '25', 'height of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_width', '25', 'width of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'css_file_legend', '../css/legend.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'stickylegend', 'true', 'parameter to decide wether the legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'logout', 'logout_location', 'http://www.mapbender.org/', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'setPOI2Scale', 'mod_setPOI2Scale_defScale', '5000', 'default scale', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'menu', '', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui2';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','WMS_preferences',2,1,'configures the preferences of each loaded wms','WMS preferences','img','../img/button_blue/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',604,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_blue/add_off.png','onclick=''mod_addWMS()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',580,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blue/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',553,40,28,28,1,'filter:Chroma(color=#C2CBCF);','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','back',2,1,'History.back()','Back','img','../img/button_blue/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"',398,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_back.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','body',1,1,'body
+(obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'background-image:url(../img/background_yellow.jpg);background-repeat:repeat-x;','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','center1',2,1,'Center button','Set map center','img','../img/button_blue/center_off.png','onmouseover = "mb_regButton(''init_gui1_center'')"',308,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_center1.php','','mapframe1','','http://www.mapbender.org/index.php/ReCenter');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','changePassword_button',2,1,'button: change password of logged user','Change Password','img','../img/button_blue/change_password_off.png','onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0''
+onmouseover=''this.src="../img/button_blue/change_password_over.png"'' onmouseout=''this.src="../img/button_blue/change_password_off.png"''',668,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','','','http://www.mapbender.org/index.php/ChangePassword');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','closePolygon',3,1,'close Polygon ','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_closePolygon.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#799FEB; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dynamicOverview',2,1,'oveview acts in accordance with main mapframe','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','mod_dynamicOverview.php','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','featureInfo1',2,0,'FeatureInfoRequest','Query','img','../img/button_blue/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','Query','img','../img/button_blue/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')"',461,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_featureInfoTunnel.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfoTunnel');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','forward',2,1,'History.forward()','Forward','img','../img/button_blue/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()"',423,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_forward.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','Search','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','geometry.js','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','getArea',3,1,'Calculation of area, Postgis required','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_getArea.php','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','header_yellow',2,0,'header','','img','../img/header_yellow.jpg','',-1,-1,833,75,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','help',2,1,'button help','Help','img','../img/button_blue/help_off.png','onmouseover = "mb_regButton(''init_help'')"',693,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','imprint',2,1,'Information about the owner of the gui','Imprint','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','layout_linie',3,0,'layout','','div','','',1,70,830,1,1,'background-color:#799FEB;font-size:1px;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','layout_linie2',3,0,'layout','','div','','',1,35,830,1,1,'background-color:#799FEB;font-size:1px;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','loadData',2,1,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','loadwmc',2,1,'load workspace from WMC','Load a web map context document','img','../img/button_blue/wmc_load_off.png','onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");''',758,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_loadwmc.php','','mapframe1','','http://www.mapbender.org/index.php/LoadWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','logo',2,1,'Logo','Logo','img','../img/mapbender_oo.png','',10,35,129,32,5,'filter:Chroma(color=#C2CBCF);','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','logout',2,1,'Logout','Logout','img','../img/button_blue/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blue/logout_over.png"'' onmouseout=''this.src="../img/button_blue/logout_off.png"''',798,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','mapframe1',2,1,'frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',213,90,608,467,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','measure',2,1,'Measure','Measure distance','img','../img/button_blue/measure_off.png','onmouseover = "mb_regButton(''init_mod_measure'')"',513,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_measure.php','','mapframe1','','http://www.mapbender.org/index.php/Measure');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_blue/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0''
+onmouseover=''this.src="../img/button_blue/metadata_over.png"'' onmouseout=''this.src="../img/button_blue/metadata_off.png"''',643,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,0,0,0,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>
+<div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>
+<div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>
+<div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div>
+<div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div>
+<div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>
+<div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>
+<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',9,80,185,130,100,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','pan1',2,1,'pan','Pan','img','../img/button_blue/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')"',258,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','printPDF',2,1,'pdf print','Print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','repaint',2,1,'refresh a mapobject','Redraw','img','../img/button_blue/repaint_off.png','onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)''',358,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_repaint.php','','mapframe1','','http://www.mapbender.org/index.php/Repaint');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','resizeMapsize',2,1,'resize mapsize to browser window size','Resize Mapsize','img','../img/button_blink_red/resizemapsize_off.png','onclick = "adjustDimension()"
+onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',838,40,24,24,3,'filter:Chroma(color=#C2CBCF);','','','mod_resize_mapsize.php','','mapframe1','','http://www.mapbender.org/index.php/ResizeMapsize');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','rubber',3,1,'deletes temporary (digitized) objects','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_rubber.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','savewmc',2,1,'save workspace as WMC','Save workspace as web map context document','img','../img/button_blue/wmc_save_off.png','onclick=''mod_savewmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',733,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_savewmc.php','','mapframe1','','http://www.mapbender.org/index.php/SaveWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_blue/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')"',283,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','setBBOX',2,0,'set extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','setBackground',2,1,'switch background-wms','Set Background','form','','',10,218,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','showCoords_div',2,1,'displays coodinates by onmouseover','Coordinates','img','../img/button_blue/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')"',488,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_coords_div.php','','mapframe1','dependendDiv','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','tabs',2,1,'vertical tabs to handle iframes','','div','','',2,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2','Maps','iframe','../html/mod_treefolder2.php?sessionID','frameborder = "0" ',10,220,200,300,NULL ,'visibility:visible','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_blue/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"',333,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_blue/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)''',203,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_blue/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''',231,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_class_bg', 'body{background-color: #FEF8D4;}', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_minScale', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_startExtent', '-24.5,32,34.5,71', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_useMaxExtent', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_wmsIndex', '0', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_zoomFactor', '5', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'gazetteerWFS', 'wfsConfIdString', '1', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_height', '-35', 'to adjust the height of the mapframe on the bottom of the window', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_width', '-45', 'to adjust the width of the mapframe on the right side of the window', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'resize_option', 'button', 'auto (autoresize on load), button (resize by button)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'sandclock', 'mod_sandclock_image', '../img/sandclock_oo.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_prefix', ' ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid #FDCC1A;font-size:12;color:#FFFFFF;background-color:#799FEB;cursor:pointer;margin-top:-3px; padding-top:3px;padding-left:4px;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'menu', 'opacity_up,opacity_down,zoom,metainfo,hide,wms_up,wms_down,layer_up,layer_down,remove', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui_digitize';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','FeatureInfoRedirect',2,0,'redirect featureInfoRequests in an iframe for each wms','Info','iframe','../html/mod_blank.html','frameborder="0"',83,-17,1,1,NULL ,'','','iframe','mod_featureInfoRedirect.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','WMS_preferences',2,1,'configures the preferences of each loaded wms','WMS preferences','img','../img/button_gray/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");''',540,10,24,24,1,'','','','','','mapframe1,treeGDE','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_gray/add_off.png','onclick=''mod_addWMS()''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");''',515,10,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','back',2,1,'History.back()','Back','img','../img/button_gray/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"',360,10,24,24,1,'','','','mod_back.php','','mapframe1,overview0','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','body',1,1,'body (obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','closePolygonExt',3,0,'close Polygon ','Close Polygon','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_closePolygonExt.js','','mapframe1','setExtRequest','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_copyright.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','digitize',2,1,'Digitize tool.','Digitize','iframe','../javascripts/mod_digitize_tab.php?sessionID','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','geometry.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','featureInfo1',2,0,'FeatureInfoRequest','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')"',425,10,24,24,1,'','','','mod_featureInfoTunnel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','forward',2,1,'History.forward()','Forward','img','../img/button_gray/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()"',385,10,24,24,1,'','','','mod_forward.php','','mapframe1,overview0','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','Search','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','geometry.js','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',620,10,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','imprint',2,1,'Information about the owner of the gui','Imprint','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','initWmc',2,0,'initialise client with wmc','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_initWmc.php','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_1',3,0,'Warning notice','','div','','',150,250,300,16,100,'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none;','Development Version - Work in Progress!','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_back',3,1,'layout, background for buttons','','div','','',360,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_featureInfo',3,1,'layout, background for FeatureInfo','','div','','',425,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_help',3,1,'layout, background for Help-button','','div','','',620,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_logout',3,1,'layout, background for Logout-button','','div','','',660,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_metadata',3,1,'layout, background for Metadata','','div','','',580,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_wms',3,1,'layout, background for wms','','div','','',490,10,76,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_zoom',3,1,'layout, background for Zoom-button','','div','','',220,10,126,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','loadData',2,1,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','loadwmc',2,0,'load workspace from WMC','Load a web map context document','img','../img/button_wmc/wmc_load.png','onclick=''mod_loadwmc()'' onmouseover=''mod_loadwmc_init(this)''',760,10,24,24,1,'','','','mod_loadwmc.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','logo',2,1,'Logo','','img','../img/mapbender_logo.png','',20,20,180,26,5,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''
+onmouseover=''this.src="../img/button_gray/logout_over.png"''
+onmouseout=''this.src="../img/button_gray/logout_off.png"''',660,10,24,24,1,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr>
+<script language="javascript">
+mb_registerSubFunctions("mod_mapbender()");
+function mod_mapbender(){
+document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90;
+document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1;
+</script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','mapframe1',2,1,'frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',230,55,500,450,2,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_gray/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''"
+border=''0''
+onmouseover=''this.src="../img/button_gray/metadata_over.png"''
+onmouseout=''this.src="../img/button_gray/metadata_off.png"''',580,10,24,24,1,'','','','mod_displayObj.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,NULL ,NULL ,NULL ,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>
+<div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>
+<div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>
+<div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div>
+<div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div>
+<div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>
+<div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>
+<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>
+','div','mod_navFrame.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',30,65,150,130,100,'','','iframe','','mod_box1.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','pan1',2,1,'pan','Pan','img','../img/button_gray/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')"',270,10,24,24,1,'','','','mod_pan.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','printPDF',2,1,'pdf print','Print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','rubberExt',3,1,'deletes temporary (digitized) objects','Rubber','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_rubberExt.js','','mapframe1','setExtRequest','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','savewmc',2,0,'save workspace as WMC','Save workspace as web map context document','img','../img/button_wmc/wmc_save.png','onclick=''mod_savewmc()'' onmouseover=''mod_savewmc_init(this)''',730,10,24,24,1,'','','','mod_savewmc.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','scaleSelect',2,0,'Scale-Selectbox','Scale Select','select','','onchange=''mod_scaleSelect(this)''',555,25,100,20,1,'','<option value = ''''>Scale</option>
+<option value=''100''>1 : 100</option>
+<option value=''250''>1 : 250</option>
+<option value=''500''>1 : 500</option>
+<option value=''1000''>1 : 1000</option>
+<option value=''2500''>1 : 2500</option>
+<option value=''5000''>1 : 5000</option>
+<option value=''10000''>1 : 10000</option>
+<option value=''25000''>1 : 25000</option>
+<option value=''30000''>1 : 30000</option>
+<option value=''50000''>1 : 50000</option>
+<option value=''75000''>1 : 75000</option>
+<option value=''100000''>1 : 100000</option>
+<option value=''200000''>1 : 200000</option>
+<option value=''300000''>1 : 300000</option>
+<option value=''400000''>1 : 400000</option>
+<option value=''500000''>1 : 500000</option>
+<option value=''600000''>1 : 600000</option>
+<option value=''700000''>1 : 700000</option>
+<option value=''800000''>1 : 800000</option>
+<option value=''900000''>1 : 900000</option>
+<option value=''1000000''>1 : 1000000</option>','select','mod_scaleSel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_gray/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')"',295,10,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setBBOX',2,0,'set extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setBackground',2,1,'switch background-wms','Set Background','form','','',30,210,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12''
+name=''mod_setBackground_list''
+onchange=''mod_setBackground_change(this)'' ><option
+value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setSpatialRequest',2,1,'Spatial Request','','div','','',1,1,1,1,1,'visibility:hidden;','','div','../javascripts/mod_wfs_SpatialRequest.php','geometry.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','showCoords_div',2,1,'displays coodinates by onmouseover','Coordinates','img','../img/button_gray/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ',450,10,24,24,1,'','','','mod_coords_div.php','','mapframe1','dependendDiv','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','showLoggedUser',2,0,'Displays current user','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','tabs',1,1,'vertical tabs to handle iframes','','div','','',10,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfs',2,1,'wfs request and result handling','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','wfs.js','../extensions/wz_jsgraphics.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfs_conf',2,1,'get all wfs_conf-params','','iframe','../php/mod_wfs.php','frameborder = "0"',1,1,1,1,0,'visibility:hidden','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfsresult',2,1,'display the list of wfs results','','iframe','../html/mod_blank.html','frameborder = "0"',10,730,200,150,4,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_gray/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"',320,10,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_gray/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)''',220,10,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_gray/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''',245,10,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'cssUrl', '../css/digitize.css', 'url to the style sheet of the mapframe', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'digitize_conf_filename', 'digitize_default.conf', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'text css', ' body{
+ font-family: Arial, Helvetica, sans-serif;
+ font-size : 12px;
+ color: #ff00ff;
+ background-color: #ffffff;
+ margin-top: 0px;
+ margin-left: 0px;
+ .button{
+ height: 18px;
+ width: 32px;
+', 'text css', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'wfsCssUrl', '../css/mapbender.css', 'var', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'gazetteerWFS', 'wfsConfIdString', '1,2,3,4', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'useUsemap', '0', '"1" adds a usemap to each geometry; the geometry will be highlighted onMouseOver. Every other value will skip the usemap.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'wfs_conf_filename', 'wfs_default.conf', 'location and name of the WFS configuration file', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'open_tab', '5', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[5]', '250', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[5]', 'digitize', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_prefix', ' ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;padding-left:8px;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'menu', '', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'wfs', 'displayWfsResultList', '1', '', 'var');
+Delete from gui_element where fkey_gui_id ='admin1';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','AdminFrame',2,1,'the frame for administration modules','','iframe','','frameborder = "0"',220,20,800,800,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','CreateTreeGDE',2,1,'create a foldertree for a individual geodataexplorer','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,810,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','CREATE TREE_GDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','EditWMSMetadata',2,1,'edit the metadata of wms','edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,950,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT WMS-METADATA','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_Gui',2,1,'allocate groups to guis','','a','','href = "../php/mod_group_gui.php?sessionID&e_id_css=Group_Gui" target = "AdminFrame" ',10,610,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_User',2,1,'allocate groups to user','','a','','href = "../php/mod_group_user.php?sessionID&e_id_css=Group_User" target = "AdminFrame" ',10,550,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','GROUP -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_filteredGui',2,1,'allocate Groups to the guis of this admin','','a','','href = "../php/mod_group_filteredGui.php?sessionID&e_id_css=Group_filteredGui" target = "AdminFrame" ',10,710,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Gui_Group',2,1,'allocate guis to groups','','a','','href = "../php/mod_gui_group.php?sessionID&e_id_css=Gui_Group" target = "AdminFrame" ',10,250,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Gui_User',2,1,'allocate a gui to user','','a','','href = "../php/mod_gui_user.php?sessionID&e_id_css=Gui_User" target = "AdminFrame" ',10,190,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','User_Group',2,1,'allocat user to groups','','a','','href = "../php/mod_user_group.php?sessionID&e_id_css=User_Group" target = "AdminFrame" ',10,430,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','body',1,1,'navigation','','body','','onload=''mod_adminNavigation_init()''',0,0,0,0,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteGui',2,1,'delete gui','','a','','href = "../php/mod_deleteGUI.php?sessionID" target = "AdminFrame" ',10,150,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteWFS',2,1,'delete WFS','Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,890,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteWMS',2,1,'delete wms','Delete WMS completely','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,110,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','delete_filteredGui',2,1,'delete guis of this admin','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,790,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editElements',2,1,'edit gui elements','Edit GUI elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,170,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','EDIT GUI-ELEMENTS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editFilteredGroup',2,1,'edit group of this admin','Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',10,530,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editFilteredUser',2,1,'save, edit, delete user where this admin is owner','Create and edit user','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',10,350,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editGUI_WMS',2,1,'edit the elements of the gui','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,90,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT GUI-WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editGroup',2,1,'edit group','','a','','href = "../php/mod_editGroup.php?sessionID" target = "AdminFrame" ',10,510,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editUser',2,1,'save, edit, delete user','','a','','href = "../php/mod_editUser.php?sessionID" target="AdminFrame"',10,330,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','exportGUI',2,1,'export gui, create SQLL','export GUI, create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,310,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EXPORT GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGoup_filteredUser',2,1,'allocate the groups of this admin to user where the admin is owner','Add several users to one group','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',10,590,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> myUSER ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_Gui',2,1,'allocate groups of this admin to guis','','a','','href = "../php/mod_filteredGroup_Gui.php?sessionID&e_id_css=filteredGroup_Gui" target = "AdminFrame" ',10,750,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_User',2,1,'allocate groups of this admin to user','','a','','href = "../php/mod_filteredGroup_User.php?sessionID&e_id_css=filteredGroup_User" target = "AdminFrame" ',10,690,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_filteredGui',2,1,'allocate groups of this admin to guis of this admin','Allow one group access to several GUIs','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',10,730,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_Group',2,1,'allocate guis to groups','','a','','href = "../php/mod_filteredGui_group.php?sessionID&e_id_css=filteredGui_Group" target = "AdminFrame" ',10,270,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> GROUP ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_filteredGroup',2,1,'allocate guis of this admin to groups where this admin is owner','Allow several groups access to one GUI','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',10,290,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_filteredUser',2,1,'allocate the user where the admin is owner to his guis ','Allow several users access to one GUI ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',10,230,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_user',2,1,'allocate the guis of this admin to a user','','a','','href = "../php/mod_filteredGui_User.php?sessionID&e_id_css=filteredGui_user" target = "AdminFrame" ',10,210,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> USER ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_Group',2,1,'allocate user of this admin to groups','','a','','href = "../php/mod_filteredUser_Group.php?sessionID&e_id_css=filteredUser_Group" target = "AdminFrame" ',10,670,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_Gui',2,1,'allocate user of this admin to guis','','a','','href = "../php/mod_filteredUser_Gui.php?sessionID&e_id_css=filteredUser_Gui" target = "AdminFrame" ',10,770,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_filteredGroup',2,1,'allocate user where this admin is owner to groups where this admin is owner','Add one user to serveral groups','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',10,490,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_filteredGui',2,1,'allocate admins user to guis of this admin','Allow one user to access several GUIs','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',10,410,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','getStyles',2,0,'load styles from wms','','a','','href = "../php/mod_getStyles.php?sessionID" target = "AdminFrame" ',10,890,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GET_STYLES','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','group_filteredUser',2,1,'allocate groups to user where this admin is owner','','a','','href = "../php/mod_group_filteredUser.php?sessionID&e_id_css=group_filteredUser" target = "AdminFrame" ',10,570,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_filteredGroup',2,1,'allocate guis to groups of this admin','','a','','href = "../php/mod_gui_filteredGroup.php?sessionID&e_id_css=gui_filteredGroup" target = "AdminFrame" ',10,650,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_filteredUser',2,1,'allocate guis to user of this admin','','a','','href = "../php/mod_gui_filteredUser.php?sessionID&e_id_css=gui_filteredUser" target = "AdminFrame" ',10,630,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_owner',2,1,'set owner','Edit GUI assign to user','a','','href = "../php/mod_gui_owner.php?sessionID&e_id_css=gui_owner" target = "AdminFrame" ',10,830,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> OWNER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWFS',2,1,'load capabilities in a gui','Load WFS Capabilities into a GUI','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,850,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/WFS_Konfiguration');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWMS',2,1,'load capabilities in a gui','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,30,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWMSList',2,1,'load wms from a list','Link WMS into GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,50,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD myWMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,1,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','myGUIlist',2,1,'go back to your GUI list','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' ',150,2,24,24,1,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','newGui',2,1,'create a new gui','Create new GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,130,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','NEW GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','orphanWMS',2,1,'display orphaned WMS','Delete orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID&&elementID=orphanWMS" target = "AdminFrame"',10,930,200,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','ORPHAN WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','owsproxy',2,1,'secure services','OWSPROXY','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,910,200,20,1,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','OWSPROXY','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','rename_copy_Gui',2,1,'rename and copy gui','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,470,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','RENAME COPY GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','showLoggedUser',2,1,'displays the logged admin','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','updateWMSs',2,1,'edit the elements of the gui','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,70,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','UPDATE WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_filteredGroup',2,1,'allocate user to groups where this admin is owner','','a','','href = "../php/mod_user_filteredGroup.php?sessionID&e_id_css=user_filteredGroup" target = "AdminFrame" ',10,450,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> myGROUP','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_filteredGui',2,1,'allocate guis of this admin to user','','a','','href = "../php/mod_user_filteredGui.php?sessionID&e_id_css=user_filteredGui" target = "AdminFrame" ',10,390,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER-> myGUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_gui',2,1,'allocate guis to user','','a','','href = "../php/mod_user_gui.php?sessionID&e_id_css=user_gui" target = "AdminFrame" ',10,370,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> GUI ','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','wfs_conf',2,1,'create and edit a gazetteer module','Configure WFS','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,870,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','WFS CONF','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','wfs_gui',2,1,'edit wfs settings','Assign WFS conf to gui','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,1000,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','asign WFS conf to gui','a','','','','AdminFrame','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_Gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'User_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'editGUI_WMS', 'file_css', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_Gui', 'file css', '../css/administration_alloc.css', 'file', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_user', 'file css', '../css/administration_alloc.css', 'a file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_Gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'group_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin2_de';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','AdminFrame',2,1,'Bereich f�r Administrationsmodule','','iframe','','frameborder = "0"',200,20,980,800,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','CreateTreeGDE',2,1,'Ordnerbaum konfigurieren','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',8,280,190,20,5,'','Ordnerbaum konfigurieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','body',1,1,'Navigation','','body','','onload=''mod_adminNavigation_init()''',0,0,180,20,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','deleteWMS',2,1,'!Vollst�ndig l�schen!','Delete WMS completely','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',8,100,190,20,5,'','!Vollst�ndig l�schen!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','delete_filteredGui',2,1,'GUI l�schen','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',110,240,80,20,5,'','GUI l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editElements',2,1,'Oberfl�chenelemente editieren','Edit GUI elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',8,260,190,20,5,'','GUI-Elemente editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editFilteredGroup',2,1,'Gruppe anlegen und editieren','Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',8,400,190,20,10,'','Gruppe anlegen und editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editFilteredUser',2,1,'Benutzer anlegen und editieren','Create and edit user','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',8,380,190,20,10,'','Benutzer anlegen und editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editGUI_WMS',2,1,'WMS GUI Einstellungen','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',8,180,190,20,5,'','WMS GUI Einstellungen','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','exportGUI',2,1,'Oberfl�che (GUI) exportieren, SQL erzeugen','export GUI, create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',8,300,190,20,10,'','GUI exportieren (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGoup_filteredUser',2,1,'Gruppe mit Benutzern best�cken','Add several users to one group','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',8,440,190,20,10,'','Gruppe mit Benutzern best�cken ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGroup_filteredGui',2,1,'Einzelner Gruppe mehrere Oberflaechen zuordnen','Allow one group access to several GUIs','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',8,570,190,25,10,'','Einzelner Gruppe mehrere <br>GUIs zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGui_filteredGroup',2,1,'Einzelner Oberfl�che mehrere Gruppen zuordnen','Allow several groups access to one GUI','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',8,605,190,25,10,'','Einzelner GUI mehrere<br> Gruppen zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGui_filteredUser',2,1,'Oberfl�che mehreren Benutzer zuordnen ','Allow several users access to one GUI ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',8,535,190,25,10,'','GUI mehreren Benutzern <br> zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredUser_filteredGroup',2,1,'Benutzer in Gruppen eintragen','Add one user to serveral groups','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,420,190,20,10,'','Benutzer in Gruppen eintragen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredUser_filteredGui',2,1,'Einem Nutzer Zugriff auf mehrere Oberfl�chen erteilen','Allow one user to access several GUIs','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',8,500,190,25,10,'','Einem Nutzer Zugriff auf <br> mehrere GUIs erteilen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','gui_owner',2,1,'GUI editieren Benutzer zuordnen','Edit GUI assign to user','a','','href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame" ',8,640,190,20,10,'','GUI editieren Benutzer zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_Configure_WMS_Access',3,1,'Hintergrund WMS Zuordnung','Configure WMS Access','div','','',5,137,193,66,2,'',' WMS Zuordnung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_GUI_Management',3,1,'Hintergrund Oberfl�chenverwaltung','GUI Management','div','','',5,217,193,126,2,'',' GUI-Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_User_Authorization',3,1,'Hintergrund Benutzerzugriff erteilen','Authorization ','div','','',5,477,193,196,2,'',' Benutzerzugriff erteilen','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_User_Management',3,1,'Hintergrund Benutzerverwaltung','User Management','div','','',5,357,193,106,2,'',' Benutzerverwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_WMS_Management',3,1,'Hintergrund WMS Management','WMS Management','div','','',5,37,193,86,2,'',' WMS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','loadWMS',2,1,'Capabilities hochladen','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',8,60,190,20,5,'','Capabilities hochladen','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','loadWMSList',2,1,'WMS in GUI einbinden','Link WMS into GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',8,160,190,20,5,'','WMS in GUI einbinden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','myGUIlist',2,1,'Zur�ck zur eigenen GUI Liste','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','newGui',2,1,'GUI erzeugen','Create new GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',8,240,85,20,5,'','GUI erzeugen','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','rename_copy_Gui',2,1,'GUI umbenennen/ kopieren','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',8,320,190,20,10,'','GUI umbenennen/kopieren','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','showLoggedUser',2,1,'Anzeige des eingeloggten Benutzers','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','updateWMSs',2,1,'Hochgeladene aktualisieren','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',8,80,190,20,5,'','Hochgeladene aktualisieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'body', 'body_css_file', '../css/admin.css', 'css-file to define the style fo the admin-gui', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin2_en';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','AdminFrame',2,1,'the frame for administration modules','','iframe','','frameborder = "0"',200,20,800,800,0,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','CreateTreeGDE',2,1,'TreeGDE set up','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',8,280,190,20,5,'','Create treeGDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','body',1,1,'navigation','','body','','onload=''mod_adminNavigation_init()''',0,0,0,0,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','deleteWMS',2,1,'!Delete WMS completely!','Delete WMS completely','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',8,100,190,20,5,'','!Delete WMS completely!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','delete_filteredGui',2,1,'Delete GUI','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',120,240,80,20,5,'','Delete GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editElements',2,1,'Edit GUI elements','Edit GUI elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',8,260,190,20,5,'','Edit GUI elements','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editFilteredGroup',2,1,'Create and edit group','Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',8,400,190,20,10,'','Create and edit group','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editFilteredUser',2,1,'Create and edit user','Create and edit user','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',8,380,190,20,10,'','Create and edit user','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editGUI_WMS',2,1,'WMS GUI settings','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',8,180,190,20,5,'','WMS GUI settings','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','exportGUI',2,1,'export GUI, create SQL','export GUI, create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',8,300,190,20,10,'','Export GUI (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGoup_filteredUser',2,1,'Add several users to one group','Add several users to one group','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',8,440,190,20,10,'','Add several users to one group ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGroup_filteredGui',2,1,'Allow one group access to several GUIs','Allow one group access to several GUIs','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',8,570,190,25,10,'','Allow one group access to <br> several GUIs','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGui_filteredGroup',2,1,'Allow several groups access to one GUI','Allow several groups access to one GUI','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',8,605,190,25,10,'','Allow several groups access <br> to one GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGui_filteredUser',2,1,'Allow several users access to one GUI ','Allow several users access to one GUI ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',8,535,190,25,10,'','Allow several users access to <br> one GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredUser_filteredGroup',2,1,'Add one user to serveral groups','Add one user to serveral groups','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,420,190,20,10,'','Add one user to serveral groups','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredUser_filteredGui',2,1,'Allow one user to access several GUIs','Allow one user to access several GUIs','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',8,500,190,25,10,'','Allow one user to access <br> several GUIs','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','gui_owner',2,1,'Edit GUI assign to user','Edit GUI assign to user','a','','href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame" ',8,640,190,20,10,'','Edit GUI assign to user','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_Configure_WMS_Access',3,1,'Configure WMS Access','Configure WMS Access','div','','',5,137,193,66,2,'',' Configure WMS Access','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_GUI_Management',3,1,'GUI Management caption','GUI Management','div','','',5,217,193,126,2,'',' GUI Management ','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_User_Authorization',3,1,'Authorization caption','Authorization ','div','','',5,477,193,186,2,'',' Authorization','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_User_Management',3,1,'User Management caption','User Management','div','','',5,357,193,106,2,'',' User Management ','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_WMS_Management',3,1,'WMS Management caption','WMS Management','div','','',5,37,193,86,2,'',' WMS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" ',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','loadWMS',2,1,'Load Capabilities','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',8,60,190,20,5,'','Load WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','loadWMSList',2,1,'Link WMS into GUI','Link WMS into GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',8,160,190,20,5,'','Link WMS into GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','myGUIlist',2,1,'go back to your GUI list','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' ',150,2,24,24,2,'','','img','mod_home.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','newGui',2,1,'Create new GUI','Create new GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',8,240,110,20,5,'','Create new GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','rename_copy_Gui',2,1,'Rename/ copy GUI','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',8,320,190,20,10,'','Rename / copy GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','showLoggedUser',2,1,'Logged User:','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','updateWMSs',2,1,'Update with Capabilities','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',8,80,190,20,5,'','Update WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'body', 'body_css_file', '../css/admin.css', 'css-file to define the style fo the admin-gui', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGoup_filteredUser', 'css_file_filteredGroup_filterdUser', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGroup', 'css_filteredUser_filteredGroup', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin_de_services';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','AdminFrame',2,1,'Bereich f�r Administrationsmodule','','iframe','','frameborder = "0"',210,25,800,800,12,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','CreateTreeGDE',2,1,'Ordnerbaum konfigurieren','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,533,200,20,5,'','Ordnerbaum konfigurieren','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','EditWMSMetadata',2,1,'edit the metadata of wms','edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,275,200,20,5,'','WMS Metadaten','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_WMS_Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','body',1,1,'Navigation','','body','','onload=''mod_adminNavigation_init()''',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','deleteWFS',2,1,'WFS l�schen','Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,393,200,20,5,'','WFS l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','deleteWMS',2,1,'!Vollst�ndig l�schen!','!Delete WMS completely!','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,100,200,20,5,'','WMS l�schen!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','delete_filteredGui',2,1,'GUI l�schen','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,491,200,20,5,'','GUI l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','editElements',2,1,'Oberfl�chenelemente editieren','Edit GUI Elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,511,200,25,5,'','GUI editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','editGUI_WMS',2,1,'WMS GUI Einstellungen','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,218,200,20,5,'','WMS Einstellungen �ndern','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','exportGUI',2,1,'GUI exportieren, SQL erzeugen','Export GUI (SQL), create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,554,200,25,10,'x','GUI exportieren (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','filteredWms_layer_topic',2,1,'allocate topics to layers of wms of this user','allocate topics to layers of wms of this user','a','','href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ',10,295,200,20,5,'','Kategoriezuordnung','a','','','','AdminFrame','http://www.mapbender.org/index.php/Topic_/_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_Configure_WMS_Access',3,1,'Hintergrund WMS Zuordnung','WMS Assignment','div','','',1,175,210,63,2,'','WMS Zuordnung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_GUI_Management',3,1,'Oberfl�chenverwaltung','GUI Management','div','','',1,448,210,153,2,'','GUI Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_Metadata',3,1,'Metadateneditor Caption','Metadata','div','','',1,252,210,63,2,'','Metadaten','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_WFS_Management',3,1,'WFS Verwaltung','WFS Management','div','','',1,330,210,103,2,'','WFS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_WMS_Management',3,1,'Dienstverwaltung Beschriftung','WMS Management','div','','',0,37,210,123,2,'','WMS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWFS',2,1,'WFS Capabilities in eine GUI laden','Load WFS Capabilities into a GUI','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,353,200,20,5,'','WFS laden','a','','','','AdminFrame','http://www.mapbender.org/index.php/LoadWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWMS',2,1,'Capabilities hochladen','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,60,200,20,5,'','WMS laden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWMSList',2,1,'WMS in GUI einbinden','Assign WMS to a GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,198,200,20,5,'','WMS einbinden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','myGUIlist',2,1,'Zur�ck zur eigenen GUI Liste','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','newGui',2,1,'GUI erzeugen','New GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,471,200,20,5,'','GUI erzeugen','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','orphanWMS',2,1,'display orphaned WMS','Delete orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID"
+target = "AdminFrame"',10,120,200,20,5,'','WMS ohne Zuordung l�schen','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','owsproxy',2,1,'secure services','OWSPROXY','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,140,200,20,10,'','OWSPROXY','a','','','','AdminFrame','http://www.mapbender.org/index.php/Owsproxy');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','rename_copy_Gui',2,1,'GUI umbenennen/ kopieren','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,576,200,20,10,'','GUI umbenennen/kopieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/RenameGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','showLoggedUser',2,1,'Anzeige des eingeloggten Benutzers','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','updateWMSs',2,1,'Hochgeladene aktualisieren','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,80,200,20,5,'','WMS aktualisieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','wfs_conf',2,1,'WFS konfigurieren','Configure WFS','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,373,200,20,5,'','WFS konfigurieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Wfs_conf');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','wfs_gui',2,1,'edit wfs settings','Assign WFS conf to gui','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,413,200,20,10,'','WFS Konfiguration GUI zuweisen','a','','','','AdminFrame','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'EditWMSMetadata', 'file_css', '../css/metadata.css', 'css-file to use for the metadata modul', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'body', 'body_file_css', '../css/admin_service.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'filteredWms_layer_topic', 'file css', '../css/administration_alloc_4.css', 'css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'filteredWms_layer_topic', 'language', 'de', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin_en_services';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','AdminFrame',2,1,'administration frame','','iframe','','frameborder = "0"',210,25,1000,800,12,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','CreateTreeGDE',2,1,'Configure TreeGDE','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,533,200,20,5,'','Configure TreeGDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','EditWMSMetadata',2,1,'edit the metadata of wms','edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,275,200,20,5,'','WMS Metadata','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_WMS_Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','body',1,1,'Navigation','','body','','onload=''mod_adminNavigation_init()''',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','deleteWFS',2,1,'Delete WFS','Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,393,200,20,5,'','Delete WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','deleteWMS',2,1,'!Delete completely!','!Delete WMS completely!','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,100,200,20,5,'','!Delete WMS completely!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','delete_filteredGui',2,1,'Delete GUI','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,491,200,20,5,'','Delete GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','editElements',2,1,'Edit GUI Elements','Edit GUI Elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,511,200,20,5,'','Edit GUI Elements','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','editGUI_WMS',2,1,'WMS GUI settings','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,218,200,20,5,'','WMS GUI settings','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','exportGUI',2,1,'Export GUI (SQL), create SQL','Export GUI (SQL), create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,553,200,20,10,'x','Export GUI (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','filteredWms_layer_topic',2,1,'allocate topics to layers of wms of this user','allocate topics to layers of wms of this user','a','','href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ',10,295,200,20,5,'','Allocate topics','a','','','','AdminFrame','http://www.mapbender.org/index.php/Topic_/_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_Configure_WMS_Access',3,1,'WMS Assignment','WMS Assignment','div','','',1,175,210,63,2,'','WMS Assignment','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_GUI_Management',3,1,'GUI Management','GUI Management','div','','',1,448,210,148,2,'','GUI Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_Metadata',3,1,'Metadata','Metadata','div','','',1,252,210,63,2,'','Metadata','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_WFS_Management',3,1,'WFS Management','WFS Management','div','','',1,330,210,103,2,'','WFS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_WMS_Management',3,1,'WMS Management','WMS Management','div','','',0,37,210,123,2,'','WMS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWFS',2,1,'Load WFS Capabilities into a GUI','Load WFS Capabilities into a GUI','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,353,200,20,5,'','Load WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/LoadWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWMS',2,1,'load Capabilities','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,60,200,20,5,'','Load WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWMSList',2,1,'assign WMS to a GUI','Assign WMS to a GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,198,200,20,5,'','Assign WMS to a GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' ',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','myGUIlist',2,1,'back to GUI list','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','newGui',2,1,'New GUI','New GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,471,200,20,5,'','New GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','orphanWMS',2,1,'Delete orphaned WMS','Delete orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID"
+target = "AdminFrame"',10,120,200,20,5,'','Delete orphaned WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','owsproxy',2,1,'secure services','OWSPROXY','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,140,200,20,10,'','OWSPROXY','a','','','','AdminFrame','http://www.mapbender.org/index.php/Owsproxy');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','rename_copy_Gui',2,1,'Rename / copy GUI','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,576,200,20,10,'','Rename / copy GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/RenameGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','showLoggedUser',2,1,'show logged in user','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','updateWMSs',2,1,'Update Capabilities','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,80,200,20,5,'','Update WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','wfs_conf',2,1,'Configure WFS','Configure WFS','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,373,200,20,5,'','Configure WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Wfs_conf');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','wfs_gui',2,1,'edit wfs settings (Assign WFS conf to GUI)','Assign WFS conf to gui','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,413,200,20,10,'','Assign WFS conf to GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'EditWMSMetadata', 'file_css', '../css/metadata.css', 'css-file to use for the metadata modul', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'body', 'body_file_css', '../css/admin_service.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'filteredWms_layer_topic', 'file css', '../css/administration_alloc_4.css', 'css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'filteredWms_layer_topic', 'language', 'de', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui','switchLocale_noreload',8,1,'changes the locale without reloading the client','Set language','div','','frameborder=''0''',696,14,50,30,5,'','<form id=''form_switch_locale'' name=''form_switch_locale'' target=''parent''>
+<select id=''language'' name=''language'' onchange=''validate_locale()''>
+</select>
+</form>
+','div','mod_switchLocale_noreload.php','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'switchLocale_noreload', 'languages', 'de,en,bg,gr,nl,it,es', '' ,'var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_closetag, e_js_file) VALUES('gui1', 'popup', 6, 1, 'popup replacement', 'div', 'div', 'popup.js');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui1' AND e_id = 'wfs_gazetteer';
+DELETE FROM gui_treegde WHERE fkey_gui_id IN ('gui', 'gui1', 'admin1', 'gui2', 'wms_africa');
+-- update own applications
+Update gui_element set e_title =
+mynew.e_title from gui_element as mynew
+where gui_element.e_id = mynew.e_id
+and mynew.fkey_gui_id = 'gui'
+and gui_element.fkey_gui_id != 'gui'
+and gui_element.fkey_gui_id != 'gui1'
+and gui_element.fkey_gui_id != 'gui2'
+and gui_element.fkey_gui_id != 'gui_digitize';
+and mynew.fkey_gui_id = 'gui1'
+and mynew.fkey_gui_id = 'gui2'
+and mynew.fkey_gui_id = 'gui_digitize'
+Delete from gui_element_vars where fkey_e_id ='tabs' and var_name LIKE 'tab_titles[%';
+Update gui_element_vars set var_type='php_var' where fkey_e_id ='tabs' and var_name LIKE 'tab_ids[%' and var_type='var';
+DELETE FROM gui_element WHERE e_id = 'ajax';
+Delete from gui_element where e_id='keyHandler';
+DELETE FROM gui_element WHERE e_id = 'geometry';
+Select * from gui_element where e_mb_mod ='geometry.js' ;
+update gui_element set e_mb_mod = 'geometry.js'
+where e_id = 'digitize';
+where e_id = 'gazetteerWFS';
+where e_id = 'setSpatialRequest';
Added: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql (rev 0)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.4.5_to_2.5_pgsql_UTF-8.sql 2009-03-17 16:16:15 UTC (rev 3779)
@@ -0,0 +1,546 @@
+-- database changes in version 2.5
+-- notice language plpgsql has to be installed
+-- How to install plpgsql?
+-- createlang plpgsql mapbender
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin_de_services', 20, '');
+INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) VALUES ('admin_en_services', 20, '');
+-- table mb_monitor: new columns for mb_monitor
+ALTER TABLE mb_monitor ADD COLUMN image int4;
+ALTER TABLE mb_monitor ADD COLUMN map_url varchar(2048);
+-- WFS database handling
+-- enhancement of the datadase structure concerning WFS metadata (same solution like for WMS)
+ALTER table wfs add wfs_getcapabilities_doc text;
+ALTER table wfs add wfs_upload_url character varying(255);
+ALTER table wfs add fees character varying(255);
+ALTER table wfs add accessconstraints text;
+ALTER table wfs add individualname character varying(255);
+ALTER table wfs add positionname character varying(255);
+ALTER table wfs add providername character varying(255);
+ALTER table wfs add city character varying(255);
+ALTER table wfs add deliverypoint character varying(255);
+ALTER table wfs add administrativearea character varying(255);
+ALTER table wfs add postalcode character varying(255);
+ALTER table wfs add voice character varying(255);
+ALTER table wfs add facsimile character varying(255);
+ALTER table wfs add electronicmailaddress character varying(255);
+ALTER table wfs add wfs_mb_getcapabilities_doc text;
+ALTER table wfs add wfs_owner integer;
+ALTER table wfs add wfs_timestamp integer;
+ALTER table wfs add country character varying(255);
+ALTER TABLE wfs ALTER COLUMN wfs_title SET NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_title SET DEFAULT ''::character varying;
+ALTER TABLE wfs ALTER COLUMN wfs_version SET NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_version SET DEFAULT ''::character varying;
+ALTER TABLE wfs ALTER COLUMN wfs_getcapabilities SET NOT NULL;
+ALTER TABLE wfs ALTER COLUMN wfs_getcapabilities SET DEFAULT ''::character varying;
+alter table wfs_featuretype add column featuretype_searchable integer default 1;
+alter table wfs_featuretype add column featuretype_abstract character varying(50);
+-- grant root access to default wfs
+UPDATE wfs SET wfs_owner = 1;
+-- new table gui_wfs_conf
+CREATE TABLE gui_wfs_conf (
+ fkey_gui_id character varying(50) DEFAULT ''::character varying NOT NULL,
+ fkey_wfs_conf_id integer DEFAULT 0 NOT NULL
+ALTER TABLE ONLY gui_wfs_conf
+ ADD CONSTRAINT pk_fkey_wfs_conf_id PRIMARY KEY (fkey_gui_id, fkey_wfs_conf_id);
+ ADD CONSTRAINT gui_wfs_conf_ibfk_1 FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
+ ADD CONSTRAINT gui_wfs_conf_ibfk_2 FOREIGN KEY (fkey_wfs_conf_id) REFERENCES wfs_conf(wfs_conf_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- insert wfs confs into gui digitize
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 1);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 3);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 4);
+INSERT INTO gui_wfs_conf (fkey_gui_id, fkey_wfs_conf_id) VALUES ('gui_digitize', 2);
+-- new table wfs_featuretype_keyword:
+CREATE TABLE wfs_featuretype_keyword (
+ fkey_featuretype_id integer NOT NULL,
+ fkey_keyword_id integer NOT NULL
+ALTER TABLE ONLY wfs_featuretype_keyword
+ ADD CONSTRAINT fkey_keyword_id_fkey_featuretype_id FOREIGN KEY (fkey_keyword_id) REFERENCES keyword(keyword_id) ON UPDATE CASCADE ON DELETE CASCADE;
+ ADD CONSTRAINT fkey_featuretype_id_fkey_keyword_id FOREIGN KEY (fkey_featuretype_id) REFERENCES wfs_featuretype(featuretype_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- new table layer_load_count
+CREATE TABLE layer_load_count (
+ fkey_layer_id int4,
+ load_count int8
+-- table wfs_conf
+ALTER TABLE wfs_conf add COLUMN wfs_conf_description text;
+-- table wfs_conf_element: change in WFS configuration: access to geometries may now be restricted
+ALTER TABLE wfs_conf_element ADD COLUMN f_show_detail int4;
+ALTER TABLE wfs_conf_element ADD COLUMN f_operator VARCHAR(50);
+ALTER TABLE ONLY wfs_conf
+ ADD CONSTRAINT wfs_conf_ibfk_2 FOREIGN KEY (fkey_featuretype_id) REFERENCES wfs_featuretype(featuretype_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- table gui_element: new element for table admin1 to edit wfs settings
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','WFS',2,1,'edit wfs settings','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,1005,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT WFS','a','','','','AdminFrame','');
+-- new table translation: new table for translations
+CREATE TABLE translations
+ trs_id serial PRIMARY KEY not null,
+ locale varchar(8),
+ msgid varchar(512),
+ msgstr varchar(512)
+CREATE INDEX msgid_idx ON translations(msgid);
+ CREATE TRUSTED PROCEDURAL LANGUAGE 'plpgsql'
+ HANDLER plpgsql_call_handler;
+-- new function gettext for easy translations
+CREATE OR REPLACE FUNCTION gettext(locale_arg "text", string "text")
+RETURNS "varchar" AS
+$BODY$
+DECLARE
+ msgstr varchar(512);
+ trl RECORD;
+BEGIN
+ -- RAISE NOTICE '>%<', locale_arg;
+ SELECT INTO trl * FROM translations
+ WHERE trim(from locale) = trim(from locale_arg) AND msgid = string;
+ -- we return the original string, if no translation is found.
+ -- this is consistent with gettext's behaviour
+ IF NOT FOUND THEN
+ RETURN string;
+ ELSE
+ RETURN trl.msgstr;
+ END IF;
+END;
+$BODY$
+ LANGUAGE 'plpgsql' VOLATILE;
+-- new entries for table translations
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Pan', 'Ausschnitt verschieben');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Display complete map', 'gesamte Karte anzeigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom in', 'In die Karte hineinzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom out', 'Aus der Karte herauszoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Back', 'Zurück');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Forward', 'Nach vorne');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Coordinates', 'Koordinaten anzeigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom by rectangle', 'Ausschnitt wählen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Redraw', 'Neu laden oder Tastatur: Leertaste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Query', 'Datenabfrage');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Logout', 'Abmelden');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'WMS preferences', 'WMS Einstellungen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS from filtered list', 'WMS von gefilteter Liste hinzufügen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set map center', 'Kartenmittelpunkt setzen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Help', 'Hilfe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Show WMS infos', 'Anzeige von WMS Informationen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Save workspace as web map context document', 'Ansicht als Web Map Context Dokument speichern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Resize Mapsize', 'BildschirmgröÃe anpassen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Rubber', 'Skizze löschen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Get Area', 'Fläche berechnen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Close Polygon', 'Polygon schliessen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Move back to your GUI list', 'Zurück zur GUI Liste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Legend', 'Legende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Print', 'Druck');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Imprint', 'Impressum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Maps', 'Karten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Search', 'Suche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Meetingpoint', 'Treffpunkt');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Metadatasearch', 'Metadatensuche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS', 'WMS hinzufügen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Adding WMS from List', 'WMS aus Liste hinzufügen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Change Projection', 'Projektion ändern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Digitize', 'Digitalisierung');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Overview', 'Ãbersichtskarte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Drag Mapsize', 'Karte vergröÃern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Mapframe', 'Kartenfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Navigation Frame', 'Navigationsfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scale Select', 'Auswahl des MaÃstabes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scale Text', 'MaÃstab per Texteingabe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Scalebar', 'MaÃstabsleiste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set Background', 'Hintegrundkarte auswählen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Zoom to Coordinates', 'Zu den Koordinaten zoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Change Password', 'Passwort ändern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Load a web map context document', 'laden eines Web Map Context Dokumentes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de ', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Pan', 'ÐÑемеÑÑи облаÑÑÑа');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Display complete map', 'Ðокажи ÑÑлаÑа каÑÑа');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom in', 'Ðокажи каÑÑаÑа в по-едÑÑ Ð¼Ð°Ñаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom out', 'Ðокажи каÑÑаÑа в по-дÑебен маÑаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Back', 'Ðазад');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Forward', 'ÐапÑед');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Coordinates', 'ÐооÑдинаÑи');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom by rectangle', 'УвелиÑи каÑÑаÑа в избÑанаÑа облаÑÑ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Redraw', 'ÐÑеÑеÑÑай или Ð¾Ñ ÐºÐ»Ð°Ð²Ð¸Ð°ÑÑÑаÑа: пÑазен инÑеÑвал');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Query', 'ÐÑвка кÑм данниÑе');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Logout', 'ÐзÑ
од на поÑÑебиÑел');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'WMS preferences', 'WMS наÑÑÑойки');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS from filtered list', 'Ðобави WMS Ð¾Ñ Ð¸Ð·Ð±Ñан ÑпиÑÑк');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Set map center', 'ÐоÑÑави ÑенÑÑÑ Ð½Ð° каÑÑа');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Help', 'ÐомоÑ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Show WMS infos', 'Ðокажи WMS инÑоÑмаÑиÑ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Save workspace as web map context document', 'Ðапази ÑабоÑÐ½Ð¸Ñ Ð´Ð¾ÐºÑÐ¼ÐµÐ½Ñ ÐºÐ°Ñо Web Map Context докÑменÑ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Resize Mapsize', 'ÐапаÑни големинаÑа на каÑÑаÑа');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Rubber', 'ÐзÑÑий');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Get Area', 'ÐзÑиÑли плоÑ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Close Polygon', 'ÐаÑвоÑи полигон');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Move back to your GUI list', 'Ðазад кÑм ÑпиÑÑка Ñ Ð¸Ð½ÑеÑÑейÑи (GUI)');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Legend', 'Ðегенда');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Print', 'ÐеÑаÑ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Imprint', 'ÐвÑоÑÑко каÑе');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Maps', 'ÐаÑÑи');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Search', 'ТÑÑÑене');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Meetingpoint', 'ÐÑÑÑо на ÑÑеÑа');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Metadatasearch', 'ТÑÑÑене по меÑаданни');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS', 'Ðобави WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Adding WMS from List', 'Ðобави WMS Ð¾Ñ ÑпиÑÑк');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Info', 'ÐнÑоÑмаÑиÑ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Change Projection', 'ÐÑомени пÑоекÑиÑ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Copyright', 'ÐвÑоÑÑко пÑаво');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Digitize', 'ÐигиÑализиÑане');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Overview','ÐбзоÑна каÑÑа');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Drag Mapsize', 'ÐÑомени ÑазмеÑа на каÑÑаÑа');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Mapframe', 'Рамка на каÑÑаÑа');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Navigation Frame', 'ÐавигаÑионна Ñамка');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scale Select', 'ÐÐ·Ð±Ð¾Ñ Ð½Ð° маÑаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scale Text', 'ÐÑведи маÑаб');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Scalebar', 'ÐаÑабна Ñкала');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Set Background', 'ÐзбеÑи Ñоново изобÑажение');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Zoom to Coordinates', 'Ðокажи каÑÑаÑа около поÑоÑениÑе кооÑдинаÑи');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Change Password', 'ÐÑомени паÑола');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Load a web map context document', 'ÐаÑеди Web Map Context докÑменÑ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Logo', 'ФиÑмен знак');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('bg', 'Measure distance', 'ÐзмеÑи ÑазÑÑоÑние');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Pan', 'ÎεÏακίνηÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Display complete map', 'ÎÏίδειξη ΠλήÏοÏ
Ï Î§Î¬ÏÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom in', 'Zoom In');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom out', 'Zoom Out');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Back', 'ΠίÏÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Forward', 'Î ÏÏÏθια');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Coordinates', 'ΣÏ
νÏεÏαγμÎνεÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom by rectangle', 'ÎοÏ
μ αÏÏ Î¿ÏθογÏνιο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Redraw', 'ÎÏÏÏÏ
ÏÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Query', 'ÎÎÏÏηÏη ÎμβαδοÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Logout', 'ÎÏοÏÏνδεÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'WMS preferences', 'ÎλλάξÏε Ïη διάÏαξη ÏÏν WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS from filtered list', 'Î ÏÏÏθεÏη WMS αÏÏ Ïο ÏιλÏÏαÏιÏμÎνο καÏάλογο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Set map center', 'Το καθοÏιÏμÎνο ÎÎνÏÏο ΧαÏÏÏν');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Help', 'Îοήθεια');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Save workspace as web map context document', 'Ansicht als Web Map Context Dokument speichern');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Rubber', 'Το λάÏÏιÏο- ΤÏίÏÏηÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Close Polygon', 'Το ÎλειÏÏÏ Î Î¿Î»ÏγÏνο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ( 'gr', 'Move back to your GUI list', 'ΠαÏοÏ
ÏίαÏη ÏοÏ
GUI ÎαÏαλÏγοÏ
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Print', 'ÎκÏÏÏÏÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Maps', ' ΧάÏÏεÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS', 'Î ÏÏÏθεÏη WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Adding WMS from List', 'Î ÏÏÏθεÏη WMS αÏÏ Ïον καÏάλογο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Navigation Frame', 'Navigationsfenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Load a web map context document', 'laden eines Web Map Context Dokumentes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Measure distance', 'ÎÎÏÏηÏη ÎÏÏÏÏαÏηÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Meetingpoint', 'Σημείο ΣÏ
νάνÏηÏηÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Info', 'ΠληÏοÏοÏίεÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Digitize', 'ΨηÏιοÏοίηÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Change Projection', 'Îλλαγή Î ÏοβολήÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Set Background', 'ÎÏιλογή ΦÏνÏοÏ
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Overview', 'Î ÏοεÏιÏκÏÏιÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Change Password', 'Îλλαγή ΣÏ
νθημαÏικοÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scalebar', 'ÎανÏÎ½Î±Ï ÎλίμακαÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr ', 'Logo', 'ÎογÏÏÏ
Ïο');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Zoom to Coordinates', 'ÎÏÏίαÏη Ïε ΣÏ
νÏεÏαγμÎνεÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scale Text', 'Îείμενο ÎλίμακαÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Show WMS infos', 'Î Ïοβολή WMS ÏληÏοÏοÏιÏν');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Legend', 'ÎεζάνÏα');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Search', 'ÎναζήÏηÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Resize Mapsize', 'Îλλαγή ÎεγÎθοÏ
Ï Î§Î¬ÏÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Drag Mapsize', 'Îλλαγή ÎεγÎθοÏ
Ï Î§Î¬ÏÏη με ÎλίÏθηÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Mapframe', 'ΠλαίÏιο ΧάÏÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Get Area', 'Î Ïοβολή ΠεÏιοÏήÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Imprint', 'ÎÏοÏÏÏÏÏη');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Scale Select', 'ÎÏιλογή ÎλίμακαÏ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('gr', 'Metadatasearch', 'ÎναζήÏηÏη ÏÏα Metadata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Pan', 'Selectie verschuiven');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Display complete map', 'Hele kaart tonen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom in', 'Inzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom out', 'Uitzoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Back', 'Terug');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Forward', 'Voorwaarts');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Coordinates', 'Koordinaten tonen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom by rectangle', 'Zoom rechthoek-selectie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Redraw', 'Opfrissen of toetsenbord : spatiebalk');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Query', 'Data opvragen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Logout', 'Afmelden');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'WMS preferences', 'WMS instellingen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS from filtered list', 'WMS van gefilterte lijst toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set map center', 'Kaartmiddelpunt aangeven');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Help', 'Help');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Show WMS infos', 'Tonen van WMS Informatie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Save workspace as web map context document', 'zicht als Web map context dokument bewaren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Resize Mapsize', 'beeldschermgrote aanpassen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Rubber', 'schets verwerpen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Get Area', 'oppervlakte berekenen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Close Polygon', 'Polygoon sluiten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Move back to your GUI list', 'Terug naar GUI lijst');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Legend', 'Legende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Print', 'Drukken');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Imprint', 'Impressum');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Maps', 'Kaarten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Search', 'Zoek');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Meetingpoint', 'Trefpunt');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Metadatasearch', 'Zoeken naar Metadata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS', 'WMS toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Adding WMS from List', 'WMS uit lijst toevoegen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Info', 'Informatie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Change Projection', 'Projektie veranderen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Digitize', 'Digitaliseren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Overview', 'overzichtskaart');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Drag Mapsize', 'Kaart vergroten');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Mapframe', 'Kaartvenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Navigation Frame', 'Navigeervenster');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scale Select', 'Schaal selecteren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scale Text', 'Schaal via tekstingave');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Scalebar', 'Schaalbalk');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Set Background', 'Achtergrond selecteren');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Zoom to Coordinates', 'Naar koordinaten zoomen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Change Password', 'Paswoord wijzigen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Load a web map context document', 'Laad een Web Map Context Dokument');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('nl', 'Measure distance', 'Meet afstand');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Pan', 'Sposta dettaglio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Display complete map', 'Mostra tutta la mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom in', 'Ingrandisci');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom out', 'Riduci');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Back', 'Indietro');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Forward', 'Avanti');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Coordinates', 'Mostra coordinate');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom by rectangle', 'Seleziona dettaglio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Redraw', 'Ridisegna oppure, da tastiera: spazio');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Query', 'Interroga');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Logout', 'Logout');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'WMS preferences', 'Impostazioni WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS from filtered list', 'Aggiungi un WMS da una lista filtrata');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set map center', 'Fissa il centro della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Help', 'Aiuto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Show WMS infos', 'Mostra informazioni sul WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Save workspace as web map context document', 'Salva vista come documento di Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Resize Mapsize', 'Adatta la dimensione della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Rubber', 'Cancella bozza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Get Area', 'Calcola area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Close Polygon', 'Chiudi poligono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Move back to your GUI list', 'Torna alla lista delle GUI');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Legend', 'Legenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Print', 'Stampa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Imprint', 'Colophon');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Maps', 'Mappe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Search', 'Cerca');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Meetingpoint', 'Punti di incontro');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Metadatasearch', 'Ricerca metadati');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS', 'Aggiungi WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Adding WMS from List', 'Aggiungi WMS da lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Change Projection', 'Cambia proiezione');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Digitize', 'Digitalizza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Overview', 'Mappa di insieme');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Drag Mapsize', 'Cambia dimensione mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Mapframe', 'Quadro della mappa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Navigation Frame', 'Quadro di navigazione');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scale Select', 'Scelta della scala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scale Text', 'Scala dei testi');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Scalebar', 'Scala di riferimento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set Background', 'Seleziona mappa di sfondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Zoom to Coordinates', 'Ingrandisci alle coordinate');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Change Password', 'Cambia password');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Load a web map context document', 'Carica un documento Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Measure distance', 'Misura distanza');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Pan', 'Desplazamiento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Display complete map', 'Desplazamiento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom in', 'Zoom +');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom out', 'Zoom -');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Back', 'Zoom previo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Forward', 'Zoom siguiente');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Coordinates', 'Mostrar coordenadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom by rectangle', 'Zoom rectángulo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Redraw', 'Refrescar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Query', 'Busqueda de datos');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Logout', 'Terminar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'WMS preferences', 'Ajuste WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS from filtered list', 'Anadir WMS desde lista filtrada');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set map center', 'Centrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Help', 'Ayuda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Show WMS infos', 'Mostrar información sobre WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Save workspace as web map context document', 'Guardar vista como fichero Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Resize Mapsize', 'Modificar el tamano de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Rubber', 'Borrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Get Area', 'Calcular area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Close Polygon', 'Cerrar polÃgono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Move back to your GUI list', 'Volver a la lista WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Legend', 'Leyenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Print', 'Imprimir');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Imprint', 'Aviso legal');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Maps', 'Mapas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Search', 'Busqueda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Meetingpoint', 'Lugar de reunión');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Metadatasearch', 'Búsqueda de datos meta');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS', 'Añadir WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Adding WMS from List', 'Añadir WMS desde lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Info', 'Informacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Change Projection', 'Cambiar projecto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Digitize', 'Digitalización');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Overview', 'Mapa de visión general');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Drag Mapsize', 'Ampilar vista de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Mapframe', 'Ventana de mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Navigation Frame', 'Ventana de navigacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scale Select', 'Selecionar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scale Text', 'Teclar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Scalebar', 'Fraja de escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set Background', 'Poner el fondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Zoom to Coordinates', 'Zoom en coordenadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Change Password', 'Cambiar clave');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Load a web map context document', 'Cargar un documento de Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Measure distance', 'Medir distancias');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Set language', 'Sprache auswählen');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('es', 'Set language', 'Selección del idioma');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('it', 'Set language', 'Lingua');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Set language', 'Choisir une langue');
+-- new table gui_kml
+CREATE TABLE gui_kml (
+ kml_id serial,
+ fkey_mb_user_id integer NOT NULL,
+ fkey_gui_id character varying(50) NOT NULL,
+ kml_doc text NOT NULL,
+ kml_name character varying(64),
+ kml_description text,
+ kml_timestamp integer NOT NULL
+ALTER TABLE ONLY gui_kml
+ ADD CONSTRAINT mb_gui_kml_pkey PRIMARY KEY (kml_id);
+ ADD CONSTRAINT gui_kml_fkey_mb_user_id FOREIGN KEY (fkey_mb_user_id) REFERENCES mb_user(mb_user_id) ON UPDATE CASCADE ON DELETE CASCADE;
+ ADD CONSTRAINT gui_kml_id_fkey_gui_id FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- new sld_user_layer table
+CREATE TABLE sld_user_layer (
+ sld_user_layer_id serial NOT NULL,
+ fkey_layer_id integer NOT NULL,
+ fkey_gui_id character varying,
+ sld_xml text,
+ use_sld smallint
+ALTER TABLE sld_user_layer ADD CONSTRAINT pk_sld_user_layer PRIMARY KEY (sld_user_layer_id);
+-- Name: sld_user_layer_ibfk_1; Type: FK CONSTRAINT; Schema: public; Owner: admin
+ALTER TABLE ONLY sld_user_layer
+ ADD CONSTRAINT sld_user_layer_ibfk_1 FOREIGN KEY (fkey_mb_user_id) REFERENCES mb_user(mb_user_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- Name: sld_user_layer_ibfk_2; Type: FK CONSTRAINT; Schema: public; Owner: admin
+ ADD CONSTRAINT sld_user_layer_ibfk_2 FOREIGN KEY (fkey_layer_id) REFERENCES layer(layer_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- Name: sld_user_layer_ibfk_3; Type: FK CONSTRAINT; Schema: public; Owner: admin
+ ADD CONSTRAINT sld_user_layer_ibfk_3 FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- add sld related columns
+alter table gui_wms add column gui_wms_sldurl character varying(255) DEFAULT ''::character varying NOT NULL;
+alter table wms add column wms_supportsld boolean;
+alter table wms add column wms_userlayer boolean;
+alter table wms add column wms_userstyle boolean;
+alter table wms add column wms_remotewfs boolean;
+-- opacity handeling
+ALTER TABLE gui_wms ADD COLUMN gui_wms_opacity INT DEFAULT 100;
+UPDATE gui_element SET e_mb_mod = 'mod_addWMSgeneralFunctions.js' WHERE e_id = 'addWMS';
+ALTER TABLE gui_element ALTER COLUMN e_js_file TYPE character varying(255);
+ALTER TABLE gui_element ALTER COLUMN e_mb_mod TYPE character varying(255);
+ALTER TABLE wms ALTER COLUMN fees TYPE text;
+ALTER TABLE wms RENAME COLUMN wms_mb_getcapabilies_doc TO wms_mb_getcapabilities_doc;
Added: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql (rev 0)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.5.1_to_2.6rc1_pgsql_UTF-8.sql 2009-03-17 16:16:15 UTC (rev 3779)
@@ -0,0 +1,489 @@
+UPDATE gui_element SET e_mb_mod = 'map_obj.js,map.js,wms.js,wfs_obj.js,initWms.php' WHERE e_id = 'mapframe1';
+--new fields for wfs_conf
+ALTER TABLE wfs_conf_element ADD COLUMN f_detailpos int4 DEFAULT 0;
+ALTER TABLE wfs_conf_element ADD COLUMN f_min_input int4 DEFAULT 0;
+--new element vars for wfs_gazetteer
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'gazetteerWFS', 'showResultInPopup', '1', 'if value is 1 search results will be displayed in popup, otherwise in gazetteer div' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'gazetteerWFS', 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf', 'location and name of the WFS configuration file for spatialRequest' ,'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'gazetteerWFS', 'showResultInPopup', '1', 'if value is 1 search results will be displayed in popup, otherwise in gazetteer div' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'gazetteerWFS', 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf', 'location and name of the WFS configuration file for spatialRequest' ,'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'gazetteerWFS', 'showResultInPopup', '1', 'if value is 1 search results will be displayed in popup, otherwise in gazetteer div' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'gazetteerWFS', 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf', 'location and name of the WFS configuration file for spatialRequest' ,'php_var');
+--new element vars for body for css style of popups and tablesorter
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css');
+--add all used modules for gazetteerWFS
+ALTER TABLE gui_element ALTER e_mb_mod TYPE varchar(100);
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/jquery.tablesorter.js' WHERE e_id = 'gazetteerWFS' AND fkey_gui_id = 'gui';
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/jquery.tablesorter.js' WHERE e_id = 'gazetteerWFS' AND fkey_gui_id = 'gui2';
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/jquery.tablesorter.js' WHERE e_id = 'gazetteerWFS' AND fkey_gui_id = 'gui_digitize';
+-- update wfs configuration Mapbender User (ID: 1) to show new functionality of gazetteerWFS
+UPDATE wfs_conf_element SET f_show_detail = 1, f_detailpos = 1, f_operator = 'rightside' WHERE wfs_conf_element_id = 2 AND fkey_wfs_conf_id = 1;
+UPDATE wfs_conf_element SET f_show_detail = 1, f_detailpos = 2, f_min_input = 1, f_operator = 'bothside' WHERE wfs_conf_element_id = 3 AND fkey_wfs_conf_id = 1;
+UPDATE wfs_conf_element SET f_show_detail = 1, f_detailpos = 3, f_label = 'Organization:', f_label_id = 'd' WHERE wfs_conf_element_id = 5 AND fkey_wfs_conf_id = 1;
+UPDATE wfs_conf_element SET f_show_detail = 1, f_detailpos = 4, f_label = 'URL:', f_label_id = 'd', f_form_element_html = '<a href=""></a>' WHERE wfs_conf_element_id = 6 AND fkey_wfs_conf_id = 1;
+UPDATE wfs_conf_element SET f_search = 1, f_pos = 3, f_style_id = 'c', f_label_id = 'd', f_show_detail = 1, f_detailpos = 5, f_label = 'Usertype:', f_form_element_html = '<select id="usertype" name="usertype">
+<option value="">...</option>
+<option value="1">Company</option>
+<option value="2">Administration</option>
+<option value="3">University</option>
+<option value="4">Individual</option>
+</select>', f_operator = 'equal' WHERE wfs_conf_element_id = 4 AND fkey_wfs_conf_id = 1;
+--add style class to element var text css of element digitize in gui_digitize
+UPDATE gui_element_vars SET var_value =
+.digitizeGeometryList {position:absolute; top:50px; left:0px;}
+.digitizeGeometryListItem {color:#000000; font-size:10px;}
+body {font-family: Arial, Helvetica, sans-serif; font-size:12px; color:#ff00ff; background-color:#ffffff; margin-top: 0px; margin-left:0px;}
+.button {height:18px; width:32px;}
+WHERE fkey_e_id = 'digitize' AND var_name = 'text css';
+-- http://trac.osgeo.org/mapbender/ticket/336
+UPDATE gui_element SET e_js_file = 'wfs.php', e_target='mapframe1,overview' WHERE e_id = 'wfs';
+UPDATE gui_element SET e_attributes = 'onload="init()"' WHERE e_id = 'body' AND fkey_gui_id IN ('admin1', 'admin2_de', 'admin2_en', 'admin_de_services', 'admin_en_services');
+-- new capabilities diff column for monitoring
+ALTER TABLE mb_monitor ADD COLUMN caps_diff text;
+ALTER TABLE mb_monitor ALTER COLUMN caps_diff SET DEFAULT ''::text;
+-- scope
+-- ticket #
+-- remove event handlers, are now in the script
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'forward';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'back';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'zoomIn1';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'zoomOut1';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'measure';
+UPDATE gui_element SET e_content = '<div id="mbN" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_n" style="position:relative;top:0;left:0" src="../img/arrows/arrow_n.gif" width="15" height="10">
+</div>
+<div id="mbNE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_ne" style="position:relative;top:0;left:0" src="../img/arrows/arrow_ne.gif" width="10" height="10">
+</div>
+<div id="mbE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_e" style="position:relative;top:0;left:0" src="../img/arrows/arrow_e.gif" width="10" height="15">
+</div>
+<div id="mbSE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_se" style="position:relative;top:0;left:0" src="../img/arrows/arrow_se.gif" width="10" height="10">
+</div>
+<div id="mbS" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_s" style="position:relative;top:0;left:0" src="../img/arrows/arrow_s.gif" width="15" height="10">
+</div>
+<div id="mbSW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_sw" style="position:relative;top:0;left:0" src="../img/arrows/arrow_sw.gif" width="10" height="10">
+</div>
+<div id="mbW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_w" style="position:relative;top:0;left:0" src="../img/arrows/arrow_w.gif" width="10" height="15">
+</div>
+<div id="mbNW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;">
+<img id="arrow_nw" style="position:relative;top:0;left:0" src="../img/arrows/arrow_nw.gif" width="10" height="10">
+</div>' WHERE e_id = 'navFrame';
+UPDATE gui_element SET e_pos = 1, e_element = 'div', e_src = '', e_attributes = '', e_more_styles = 'overflow:hidden;', e_content = '<div id="markResult" name="maps" style ="position: absolute; left: 0px; top: 0px; width: 0px; height: 0px; z-index:26"> </div>
+<div id="mapframe1_maps" name="maps" style ="position: absolute; left: 0px; top: 0px; width: 0px; height: 0px; z-index:2;"> </div>
+<div id="highlight" style="position:absolute;top:-10px;left:-10px;width:14px;height:14px;z-index:3;visibility:visible"><img src="../img/redball.gif"/></div>
+<div id="l_right" name="l_right" style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:10;visibility:hidden;background-color:#ff0000;cursor: crosshair;"></div>
+<div id="l_bottom" name="l_bottom" style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:11;visibility:hidden;background-color:#ff0000;cursor: crosshair;"></div>
+<div id="l_left" name="l_left" style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:12;visibility:hidden;background-color:#ff0000;cursor: crosshair;"></div>
+<div id="l_top" name="l_top" style="position:absolute;top:0px;left:0px;width:0px;height:0px;overflow:hidden;z-index:13;visibility:hidden;background-color:#ff0000;cursor: crosshair;"></div>
+<div id="sandclock" style="position:absolute; top:0px; left:0px; z-index:14;"></div>
+<div id="scalebar" style="position:absolute; top:0px; left:0px; z-index:15;"></div>
+<div id="measuring" style="position:absolute; top:0px; left:0px; z-index:16; font-size:10px"></div>
+<div id="measure_display" style="position:absolute; top:0px; left:0px; z-index:17;"></div>
+<div id="copyright" style="position:absolute; top:0px; left:0px; z-index:18;"></div>
+<div id="measure_sub" style="position:absolute; top:0px; left:0px; z-index:19;"></div>
+<div id="permanent" style="position:absolute;top:-10px;left:-10px;width:14px;height:14px;z-index:13;visibility:hidden"><img src="../img/redball.gif"/></div>
+<div id="digitize_sub" style="position:absolute; top:0px; left:0px; z-index:24;"></div>
+<div id="digitize_display" style="position:absolute; top:0px; left:0px; z-index:25;"></div>
+<div id="um_title" name="um_title" style="font-family: Arial, Helvetica, sans-serif; DISPLAY:none; OVERFLOW:visible; POSITION:absolute; DISPLAY:none; BACKGROUND:#BEC1C4;border:1px solid black; z-index:98;"></div>
+<div id="um_draw" name="um_draw" style="LEFT:0px;OVERFLOW:visible;POSITION:absolute;TOP:0px;z-index:99;"></div>
+<img id="um_img" name="um_img" style ="position: absolute; left: 0px; top: 0px; width: 0px; height: 0px; border:0;z-index:100" src="../img/transparent.gif" useMap="#um">
+<map name="um" id="um"></map>', e_closetag = 'div', e_js_file = 'mapnf.php' WHERE e_id = 'mapframe1';
+UPDATE gui_element SET e_element = 'div', e_src = '', e_attributes = '', e_more_styles = 'overflow:hidden;', e_content = '<div id="overview_maps" style="position:absolute;left:0px;right:0px;"></div>', e_closetag = 'div', e_js_file = 'ovnf.php', e_target = 'mapframe1', e_requires = 'mapframe1' WHERE e_id = 'overview';
+INSERT INTO gui_element_vars select fkey_gui_id,'overview' as fkey_e_id, 'overview_wms' as var_name, '0' as var_value, 'wms that shows up as overview' as context, 'var' as var_type from gui_element where e_id = 'overview';
+UPDATE gui_element SET e_pos = 2, e_element = 'div', e_more_styles = 'visibility:visible;overflow:scroll', e_content = '', e_closetag = 'div', e_js_file = '../html/mod_treefolderPlain.php', e_mb_mod = 'jsTree.js', e_requires = 'mapframe1' WHERE e_id = 'treeGDE';
+INSERT INTO gui_element_vars select fkey_gui_id,'body' as fkey_e_id, 'treeGDE_css' as var_name, '../css/treeGDE2.css' as var_value, 'cssfile for TreeGDE' as context, 'file/css' as var_type from gui_element where e_id = 'treeGDE';
+UPDATE gui_element SET e_element = 'select', e_src = '', e_attributes = '', e_content = '<option value="">undefined</option>
+<option value="EPSG:4326">EPSG:4326</option>
+<option value="EPSG:31466">EPSG:31466</option>
+<option value="EPSG:31467">EPSG:31467</option>
+<option value="EPSG:31468">EPSG:31468</option>
+<option value="EPSG:31469">EPSG:31469</option>', e_closetag = 'select', e_js_file = 'mod_changeEPSG.php' WHERE e_id = 'changeEPSG';
+DELETE FROM gui_element WHERE e_id = 'closePolygon';
+DELETE FROM gui_element WHERE e_id = 'rubber';
+DELETE FROM gui_element WHERE e_id = 'getArea';
+DELETE FROM gui_element WHERE e_id = 'rubberExt';
+UPDATE gui_element SET e_element = 'div', e_src = '', e_attributes = '', e_more_styles = 'overflow:hidden;', e_content = '', e_closetag = 'div', e_js_file = 'mod_zoomCoords.php', e_target = 'mapframe1,overview', e_requires = 'mapframe1' WHERE e_id = 'zoomCoords';
+-- a demo splash screen for gui1
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'body', 'use_load_message', 'true', '' ,'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'body', 'includeWhileLoading', '../include/gui1_splash.php', '' ,'php_var');
+UPDATE gui_element SET e_mb_mod = '../extensions/wz_jsgraphics.js,geometry.js' WHERE e_id = 'wfs';
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Measure distance', 'Messen');
+UPDATE gui_element SET e_attributes = 'onload="init()"' WHERE e_id = 'body' AND fkey_gui_id IN ('wms_africa', 'wms_australia', 'wms_europe', 'wms_gdi_de', 'wms_germany', 'wms_north_america', 'wms_worldwide');
+-- gui: tab: increase the size of the frames onmouseover
+UPDATE gui_element SET e_attributes = 'frameborder = "0" onmouseover="this.style.zIndex=300;this.style.width=350;" onmouseout="this.style.zIndex=2;this.style.width=200"',
+e_more_styles = 'visibility:hidden; border: 1px solid #a19c8f;' WHERE e_id IN ('treeGDE','printPDF','legend','imprint','meetiongPoint','gazetteerWFS') AND fkey_gui_id IN ('gui');
+UPDATE gui_element SET e_more_styles = e_more_styles || ' background-color:#FFFFFF;' WHERE e_id IN ('treeGDE','imprint') AND fkey_gui_id IN ('gui');
+-- gui_treegde - delete entries which are not needed
+Delete from gui_treegde where fkey_gui_id IN ('gui','gui1','gui2','gui_digitize') and my_layer_title ='new';
+-- new translation entries for portuguese
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Zoom out', 'Zoom -');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Back', 'Zoom previo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Forward', 'Zoom siguiente');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Coordinates', 'Mostrar coordinadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Zoom by rectangle', 'Zoom retángulo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Redraw', 'Refrescar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Query', 'Procurar dados');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Logout', 'Terminar sessão');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'WMS preferences', 'Ajuste WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Adding WMS from filtered list', 'Adicionar WMS desde lista filtrada');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Set map center', 'Centrar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Help', 'Ajuda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Show WMS infos', 'Mostrar informação sobre WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Save workspace as web map context document', 'Guardar vista como arquivo Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Resize Mapsize', 'Modificar tamanho do mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Rubber', 'Apagar');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Get Area', 'Calcular area');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Close Polygon', 'Fechar polÃgono');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Move back to your GUI list', 'Volver a lista WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Legend', 'Legenda');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Print', 'Imprimir');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Imprint', 'Expediente');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Maps', 'Mapas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Search', 'Procura');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Meetingpoint', 'Lugar de reunião, ');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Metadatasearch', 'Procura metadados');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Adding WMS', 'Adicionar WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Adding WMS from List', 'Adicionar WMS desde lista');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Info', 'Informação');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Change Projection', 'Trocar projeto');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Digitize', 'Captura');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Overview', 'Mapa de vição geral');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Drag Mapsize', 'Ampliar janela do mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Mapframe', 'Janela do mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Navigation Frame', 'Janela do navegação');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'scaleSelect', 'Selecionar escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Scale Text', 'Texto da escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Scalebar', 'Barra de escala');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Set Background', 'Pôr fondo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Zoom to Coordinates', 'Zoom pra coordinadas');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Change Password', 'Trocar senha');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Load a web map context document', 'Carregar documento do Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Logo', 'Logo');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Measure distance', 'Medir distância');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'languaje', 'Selecionar Linguajem');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'navFrame', 'Marco de navegacion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'dragMapSize', 'Agrandar Mapa');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Pan', 'Desplazamento');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Display complete map', 'Zoom na Extensão Total');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('pt', 'Zoom in', 'Zoom +');
+-- new translation entries for french
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Pan', 'Déplacer la sélection');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Display complete map', 'Afficher toute la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom in', 'Zoomer');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom out', 'Dézoomer');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Back', 'Précédent');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Forward', 'Suivant');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Coordinates', 'Afficher les coordonnées');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom by rectangle', 'Zoomer sur la sélection');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Redraw', 'Actualiser [Espace]');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Query', 'Interroger la base de données');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Logout', 'Déconnexion');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'WMS preferences', 'Configuration du WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Adding WMS from filtered list', 'Ajouter un WMS de la liste filtrée');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Set map center', 'Définir le centre de la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Help', 'Aide');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Show WMS infos', 'Affichage des informations du WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Save workspace as web map context document', 'Sauvegarder la vue/l''espace de travail en tant que Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Resize Mapsize', 'Redimensionner la taille de la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Rubber', 'Gomme');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Get Area', 'Calculer la superficie');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Close Polygon', 'Fermer le polygone');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Move back to your GUI list', 'Retour à votre liste GUI');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Legend', 'Légende');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Print', 'Imprimer');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Imprint', 'Envoyer / Imprint');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Maps', 'Cartes');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Search', 'Recherche');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Meetingpoint', 'Point de rencontre');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Metadatasearch', 'Recherche des métadonnées');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Adding WMS', 'Ajouter WMS');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Adding WMS from List', 'Ajouter WMS depuis la liste');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Info', 'Info');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Change Projection', 'Changer la projection');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Copyright', 'Copyright');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Digitize', 'Numériser');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Overview', 'Carte d''aperçu');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Drag Mapsize', 'Modifier la taille de la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Mapframe', 'Fenêtre de la carte');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Navigation Frame', 'Fenêtre de navigation');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Scale Select', 'Sélection de l ''échelle');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Scale Text', 'Texte de l''échelle');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Scalebar', 'Echelle graphique');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Set Background', 'Sélectionner la carte d''arrière-plan');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Zoom to Coordinates', 'Zoomer aux coordonnées');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Change Password', 'Changer le mot de passe');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Load a web map context document', 'Charger un fichier Web Map Context');
+INSERT INTO translations (locale, msgid, msgstr) VALUES ('fr', 'Logo', 'Logo');
+-- entries espaniol
+Update translations set msgstr='Seleccionar Idioma' where locale= 'es' and msgid = 'Set language';
+Update translations set msgstr='Agrandar Mapa' where locale= 'es' and msgid = 'dragMapSize';
+Update translations set msgstr='Marco de navegacion' where locale= 'es' and msgid = 'navFrame';
+Update translations set msgstr='Escala de texto' where locale= 'es' and msgid = 'Scale Text';
+Update translations set msgstr='Barra de escala' where locale= 'es' and msgid = 'Scalebar';
+Update translations set msgstr='Referencia' where locale= 'es' and msgid = 'Legend';
+Update translations set msgstr='Mostrar mapa completo' where locale= 'es' and msgid = 'Display complete map';
+UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js' WHERE e_id = 'setSpatialRequest';
+-- building categories to sort the guis in the login.php
+-- have a look at http://www.mapbender.org/GUI_Category
+-- new tables for category handling
+CREATE TABLE public.gui_gui_category
+ fkey_gui_id character varying(50),
+ fkey_gui_category_id integer
+CREATE TABLE public.gui_category
+ category_id serial,
+ category_name character varying(50),
+ category_description character varying(255),
+ CONSTRAINT pk_category_id PRIMARY KEY (category_id)
+ALTER TABLE ONLY gui_gui_category
+ ADD CONSTRAINT gui_gui_category_ibfk_2 FOREIGN KEY (fkey_gui_id) REFERENCES gui(gui_id) ON UPDATE CASCADE ON DELETE CASCADE;
+ ADD CONSTRAINT gui_gui_category_ibfk_1 FOREIGN KEY (fkey_gui_category_id) REFERENCES gui_category(category_id) ON UPDATE CASCADE ON DELETE CASCADE;
+INSERT INTO gui_category (category_id, category_name, category_description) VALUES (1, 'Administration', 'Applications for administration');
+INSERT INTO gui_category (category_id, category_name, category_description) VALUES (3, 'WMS Container', NULL);
+INSERT INTO gui_category (category_id, category_name, category_description) VALUES (2, 'Mapbender Template Applications', 'Template Applications');
+INSERT INTO gui_gui_category VALUES ('admin1',1);
+INSERT INTO gui_gui_category VALUES('admin2_de',1);
+INSERT INTO gui_gui_category VALUES('admin2_en',1);
+INSERT INTO gui_gui_category VALUES('admin_de_services',1);
+INSERT INTO gui_gui_category VALUES('admin_en_services',1);
+INSERT INTO gui_gui_category VALUES ('gui',2);
+INSERT INTO gui_gui_category VALUES('gui1',2);
+INSERT INTO gui_gui_category VALUES('gui2',2);
+INSERT INTO gui_gui_category VALUES('gui_digitize',2);
+INSERT INTO gui_gui_category VALUES('wms_gdi_de',3);
+INSERT INTO gui_gui_category VALUES('wms_germany',3);
+INSERT INTO gui_gui_category VALUES('wms_europe',3);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('gui_category', 'category_id'), (Select max(category_id) from gui_category), true);
+-- admin2_de background
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_de','headline_GUI_Category',3,1,'Hintergrund GUI Kategorien verwalten','GUI Categories','div','','',5,685,193,66,2,'','GUI Kategorien verwalten','div','','','','','');
+-- admin2_de - create a new category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_de','createCategory',2,1,'create a gui category','Create a new category','a','','href = "../php/mod_createCategory.php?sessionID" target = "AdminFrame" ',8,708,140,20,5,'','GUI Kategorien anlegen','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin2_de', 'createCategory', 'cssfile', '../css/administration_alloc.css', '' ,'file/css');
+-- admin2_de - add a gui to a category, remove it from a category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_de','category_filteredGUI',2,1,'add Gui to Category','Add one user to serveral groups','a','','href = "../php/mod_category_filteredGUI.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,728,190,20,10,'','GUI zu Kategorie zuordnen','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin2_de', 'category_filteredGUI', 'cssfile', '../css/administration_alloc.css', 'css file for admin module' ,'file/css');
+-- admin2_en background
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_en','headline_GUI_Category',3,1,'Hintergrund GUI Kategorien verwalten','GUI Categories','div','','',5,685,193,66,2,'','GUI Category Management','div','','','','','');
+-- admin2_en - create a new category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_en','createCategory',2,1,'create a gui category','Create a new category','a','','href = "../php/mod_createCategory.php?sessionID" target = "AdminFrame" ',8,708,140,20,5,'','create a GUI category','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin2_en', 'createCategory', 'cssfile', '../css/administration_alloc.css', '' ,'file/css');
+-- admin2_en - add a gui to a category, remove it from a category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin2_en','category_filteredGUI',2,1,'add Gui to Category','Add one user to serveral groups','a','','href = "../php/mod_category_filteredGUI.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,728,190,20,10,'','add GUI to Category','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin2_en', 'category_filteredGUI', 'cssfile', '../css/administration_alloc.css', 'css file for admin module' ,'file/css');
+-- admin1 - create a new category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','createCategory',2,1,'create a gui category','Create a new category','a','','href = "../php/mod_createCategory.php?sessionID" target = "AdminFrame" ',8,1030,140,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','create a GUI category','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin1', 'createCategory', 'cssfile', '../css/administration_alloc.css', '' ,'file/css');
+-- admin1 - add a gui to a category, remove it from a category
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','category_filteredGUI',2,1,'add Gui to Category','Add one user to serveral groups','a','','href = "../php/mod_category_filteredGUI.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,1050,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','add GUI to Category','a','','','','AdminFrame','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('admin1', 'category_filteredGUI', 'cssfile', '../css/administration_alloc.css', 'css file for admin module' ,'file/css');
+-- remove module addWMSfromfilteredList_ajax from every standard gui and set it new with new parameters and new element vars
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui' and e_id = 'addWMSfromfilteredList_ajax';
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_gray/add_filtered_list_off.png','onclick=''var addWmsFromFilteredListPopup = new mb_popup({title:"Add WMS from filtered list",url:"../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID",width:720, height:600,left:20, top:20});addWmsFromFilteredListPopup.show()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js,popup.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'addWMSfromfilteredList_ajax', 'option_dbgroup', '1', '1 enables option "load configured wms by group"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'addWMSfromfilteredList_ajax', 'option_dbgui', '1', '1 enables option "load configured wms by gui"' ,'var');
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui1' and e_id = 'addWMSfromfilteredList_ajax';
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui1','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_gray/add_filtered_list_off.png','onclick=''var addWmsFromFilteredListPopup = new mb_popup({title:"Add WMS from filtered list",url:"../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID",width:720, height:600,left:20, top:20});addWmsFromFilteredListPopup.show()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',620,60,24,24,1,'','','','','mod_addWMSgeneralFunctions.js,popup.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addWMSfromfilteredList_ajax', 'option_dbgroup', '0', '1 enables option "load configured wms by group"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'addWMSfromfilteredList_ajax', 'option_dbgui', '0', '1 enables option "load configured wms by gui"' ,'var');
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui_digitize' and e_id = 'addWMSfromfilteredList_ajax';
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui_digitize','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_gray/add_filtered_list_off.png','onclick=''var addWmsFromFilteredListPopup = new mb_popup({title:"Add WMS from filtered list",url:"../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID",width:720, height:600,left:20, top:20});addWmsFromFilteredListPopup.show()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js,popup.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_dbgroup', '0', '1 enables option "load configured wms by group"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_dbgui', '0', '1 enables option "load configured wms by gui"' ,'var');
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui2' and e_id = 'addWMSfromfilteredList_ajax';
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui2','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blue/add_filtered_list_off.png','onclick=''var addWmsFromFilteredListPopup = new mb_popup({title:"Add WMS from filtered list",url:"../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID",width:720, height:600,left:20, top:20});addWmsFromFilteredListPopup.show()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="Adding WMS from filtered list"',556,40,28,28,1,'','','','','mod_addWMSgeneralFunctions.js,popup.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'option_dbgroup', '0', '1 enables option "load configured wms by group"' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'addWMSfromfilteredList_ajax', 'option_dbgui', '0', '1 enables option "load configured wms by gui"' ,'var');
+-- set popup.js as required module for gui element loadwmc
+UPDATE gui_element SET e_mb_mod = 'popup.js' WHERE e_id = 'loadwmc';
+-- set popup.js as required module for gui element featureInfoTunnel
+UPDATE gui_element SET e_mb_mod = 'popup.js' WHERE e_id = 'featureInfoTunnel';
+-- set standard element vars for possibility to use popup in featureInfoTunnel; activated for gui_digitize
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoLayerPopup', 'true', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var');
+-- increase size
+ALTER TABLE gui_element ALTER e_js_file TYPE varchar(255);
+ALTER TABLE gui_element ALTER e_mb_mod TYPE varchar(255);
+ALTER TABLE gui_element ALTER e_requires TYPE varchar(255);
+-- changed some styles for gui2
+UPDATE gui_element SET e_left = 225 WHERE fkey_gui_id = 'gui2' AND e_id = 'mapframe1';
+UPDATE gui_element SET e_top = 250 WHERE fkey_gui_id = 'gui2' AND e_id = 'tabs';
+UPDATE gui_element SET e_content = '<div id="mbN" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbNE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbSE" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbS" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbSW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>
+<div id="mbNW" style="position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;">
+</div>' WHERE fkey_gui_id = 'gui2' AND e_id = 'navFrame';
+-- layer 19011 and 19015 not queryable for gui2 for demo of tooltip
+UPDATE gui_layer SET gui_layer_queryable = 0, gui_layer_querylayer = 0 WHERE fkey_gui_id = 'gui2' AND fkey_layer_id = 19011 AND gui_layer_wms_id = 893;
+UPDATE gui_layer SET gui_layer_queryable = 0, gui_layer_querylayer = 0 WHERE fkey_gui_id = 'gui2' AND fkey_layer_id = 19015 AND gui_layer_wms_id = 893;
+-- tooltip module in gui2 + required gui elements wfs and wfs conf
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','tooltip',1,1,'Tooltip demo modul','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_tooltip.php','popup.js,geometry.js,wfsFilter.js','mapframe1','wfs,wfs_conf,featureInfoTunnel,popup','');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui2','wfs',2,1,'wfs request and result handling','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','wfs.php','../extensions/wz_jsgraphics.js,geometry.js','mapframe1,overview','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'wfs', 'displayWfsResultList', '1', '' ,'var');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui2','wfs_conf',2,1,'get all wfs_conf-params','','iframe','../php/mod_wfs.php','frameborder = "0"',1,1,1,1,NULL ,'visibility:hidden','','iframe','','','','','');
+-- element vars for tooltip
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_destinationFrame', '', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_noResultArray', E'["Kein Ergebnis.","<body onload=\"javascript:window.close()\">"]', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_styles', '.list_even{font-size:11px;color:red;}.list_uneven{font-size:11px;color:blue;}', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_styles_detail', '.list_even{font-size:11px;color:green;}.list_uneven{font-size:11px;color:blue;}', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_timeDelay', '1000', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'wfs_conf_filename', 'wfs_default.conf', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_width', '270', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tooltip', 'tooltip_height', '200', '', 'var');
+-- Update URL to Mapbender help
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/AddWMS' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'addWMS';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Back' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'back';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Copyright' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'copyright';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/DragMapSize' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'dragMapSize';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/DependentDiv' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'dependentDiv';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/FeatureInfo' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'featureInfo1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/FeatureInfoRedirect' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'FeatureInfoRedirect';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/FeatureInfoTunnel' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'featureInfoTunnel';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Forward' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'forward';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/GazetteerWFS' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'gazetteerWFS';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Logout' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'logout';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Mapframe' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'mapframe1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Metadata' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'metadata';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/NavFrame' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'navFrame';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Overview' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'overview';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Pan' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'pan1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/Print' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'printPDF';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/SaveWMC' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'savewmc';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/SelArea1' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'selArea1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/SetBackground' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'setBackground';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/ShowCoords_div' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'showCoords_div';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/TreeGde' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'treeGDE';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/WMS_preferences' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'WMS_preferences';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/ZoomFull' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'zoomFull';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/ZoomIn' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'zoomIn1';
+UPDATE gui_element SET e_url = 'http://www.mapbender.org/index.php/ZoomOut' where fkey_gui_id IN ('gui','gui2','gui1','gui_digitize') AND e_id= 'zoomOut1';
+-- new language fr, es pt
+Update gui_element_vars set var_value = 'de,en,bg,gr,nl,it,fr,es,pt' where fkey_gui_id = 'gui' AND fkey_e_id = 'switchLocale_noreload';
+-- customisable tree in admin1
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','Customize Tree',0002,1,'Create a set of nested folders that contain the applications WMS','Customize Tree','a','','href = "../php/mod_customTree.php?sessionID" target="AdminFrame"',10,975,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','CUSTOMIZE TREE','a','','','','AdminFrame','');
Added: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql (rev 0)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.5.1rc1_to_2.5.1_pgsql_UTF-8.sql 2009-03-17 16:16:15 UTC (rev 3779)
@@ -0,0 +1,12 @@
+-- database changes in version 2.5.1
+DELETE FROM wfs_conf_element WHERE f_id = ((SELECT DISTINCT f_id FROM wfs_conf_element) EXCEPT (SELECT DISTINCT f_id FROM wfs_conf_element, wfs_element WHERE f_id = element_id));
+ALTER TABLE ONLY wfs_element
+ ADD CONSTRAINT wfs_element_element_id_key UNIQUE (element_id);
+ALTER TABLE ONLY wfs_conf_element
+ ADD CONSTRAINT wfs_conf_element_id_ibfk_1 FOREIGN KEY (f_id) REFERENCES wfs_element (element_id) ON UPDATE CASCADE ON DELETE CASCADE;
\ No newline at end of file
Added: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql (rev 0)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.5_to_2.5.1rc1_pgsql_UTF-8.sql 2009-03-17 16:16:15 UTC (rev 3779)
@@ -0,0 +1,19 @@
+UPDATE gui_element SET e_closetag = '' WHERE e_element = 'img';
+-- translations missing for bg,gr,nl
+-- enlarge WFS metadata columns
+ALTER TABLE wfs_featuretype ALTER COLUMN featuretype_abstract TYPE text;
+ALTER TABLE wfs_featuretype ALTER COLUMN featuretype_title TYPE varchar(255);
+ALTER TABLE wfs_featuretype ALTER COLUMN featuretype_name TYPE varchar(255);
+ALTER TABLE wfs_element ALTER COLUMN element_name TYPE varchar(255);
+ALTER TABLE wfs_element ALTER COLUMN element_type TYPE varchar(255);
Added: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.5rc6_to_2.5_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.5rc6_to_2.5_pgsql_UTF-8.sql (rev 0)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.5rc6_to_2.5_pgsql_UTF-8.sql 2009-03-17 16:16:15 UTC (rev 3779)
@@ -0,0 +1 @@
+DELETE FROM gui_treegde WHERE fkey_gui_id IN ('gui', 'gui1', 'admin1', 'gui2', 'wms_africa');
Added: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_guis_2.4.5_to_2.5_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_guis_2.4.5_to_2.5_pgsql_UTF-8.sql (rev 0)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_guis_2.4.5_to_2.5_pgsql_UTF-8.sql 2009-03-17 16:16:15 UTC (rev 3779)
@@ -0,0 +1,899 @@
+-- update of mapbender guis
+-- gui / gui1 / gui2 / gui_digitize
+-- admin1 / admin2_de / admin2_de / admin_de_services / admin_en_services
+-- Mapbender Test for Version: 2.5
+-- 2008-09-29
+-- notice: this guis are not all working properly
+-- the guis contain the e_title informations fpor i18n
+-- these sql are for developers to get the guis working
+Delete from gui_element where fkey_gui_id ='gui';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','FeatureInfoRedirect',2,1,'redirect featureInfoRequests in an iframe for each wms','Info','iframe','../html/mod_blank.html','frameborder="0"',83,-17,1,1,0,'','','iframe','mod_featureInfoRedirect.php','','','','http://www.mapbender.org/index.php/FeatureInfoRedirect');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','WMS_preferences',2,1,'configures the preferences of each loaded wms','WMS preferences','img','../img/button_gray/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',540,10,24,24,1,'','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_gray/add_off.png','onclick=''mod_addWMS()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',515,10,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','back',2,1,'History.back()','Back','img','../img/button_gray/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"',360,10,24,24,1,'','','','mod_back.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','body',1,1,'body (obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','featureInfo1',2,0,'FeatureInfoRequest','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')"',425,10,24,24,1,'','','','mod_featureInfoTunnel.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfoTunnel');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','forward',2,1,'History.forward()','Forward','img','../img/button_gray/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" ',385,10,24,24,1,'','','','mod_forward.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','gazetteerMetadata',2,1,'gazetteer for metadata','Metadatasearch','iframe','../php/mod_gazetteerMetadata.php?sessionID&target=mapframe1,overview','frameborder = "0"',1,1,1,1,4,'visibility:hidden;','','iframe','','','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','Search','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','geometry.js','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" ',620,10,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','highlightPOI',2,1,'highlight 1 to n pois in your gui with a Symbol and a special text','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_highlightPOI.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','imprint',2,1,'Information about the owner of the gui','Imprint','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_back',3,1,'layout, background for buttons','','div','','',360,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_featureInfo',3,1,'layout, background for FeatureInfo','','div','','',425,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_help',3,1,'layout, background for Help-button','','div','','',620,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_logout',3,1,'layout, background for Logout-button','','div','','',660,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_metadata',3,1,'layout, background for Metadata','','div','','',580,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_wms',3,1,'layout, background for wms','','div','','',490,10,76,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','layout_zoom',3,1,'layout, background for Zoom-button','','div','','',220,10,126,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','loadData',2,1,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','logo',2,1,'Logo','Logo','img','../img/mapbender_logo.png','',20,20,180,26,5,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' ',660,10,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','mapframe1',2,1,'frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',230,55,500,450,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','meetingPoint',2,1,'create a meeting point','Meetingpoint','iframe','../php/mod_meetingPoint.php?sessionID','frameborder = "0" ',0,0,NULL ,NULL ,4,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_gray/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_gray/metadata_over.png"'' onmouseout=''this.src="../img/button_gray/metadata_off.png"'' ',580,10,24,24,1,'','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,0,0,0,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',30,65,150,130,100,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','pan1',2,1,'pan','Pan','img','../img/button_gray/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')" ',270,10,24,24,1,'','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','printPDF',2,1,'pdf print','Print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_gray/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')" ',295,10,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','setBBOX',2,0,'set extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','setBackground',2,1,'switch background-wms','Set Background','form','','',30,210,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','showCoords_div',2,1,'displays coodinates by onmouseover','Coordinates','img','../img/button_gray/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ',450,10,24,24,1,'','','','mod_coords_div.php','','mapframe1','dependendDiv','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','tabs',2,1,'vertical tabs to handle iframes','','div','','',10,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2','Maps','iframe','../html/mod_treefolder2.php?sessionID','frameborder = "0" ',10,220,200,300,NULL ,'visibility:visible','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_gray/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)" ',320,10,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_gray/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' ',220,10,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_gray/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''',245,10,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_all', '0', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_group', '0', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'option_gui', '0', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'gazetteerWFS', 'wfsConfIdString', '1', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_height', '14', 'height of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'highlightPOI', 'poi_width', '14', 'width of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_ccs_file', '../css/meetingPoint.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_format', 'prompt', 'decide which format to choose (email, prompt)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_export_subject', 'Ein Treffpunkt wurde erzeugt. Folgen Sie dem Link!', 'if you choose format email, define the text for the subject', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_height', '14', 'height of the meetingPoint_icon', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_icon', '../img/redball.gif', 'path to meetingPoint image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_max_characters', '70', 'define the maximum length of the text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_please_click', 'Please click in the map to define the meeting point position!', 'text to show if no clickposition is set', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_style', 'background-color:white;font-weight: bold;color:red;font-family:Arial;', 'style to display the meetingPoint text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'meetingPoint', 'meetingPoint_width', '14', 'width of the meetingPoint_icon', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[5]', '160', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_frameHeight[6]', '280', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[5]', 'meetingPoint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_ids[6]', 'gazetteerMetadata', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_prefix', ' ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'menu', 'opacity_up,opacity_down,zoom,metainfo,hide,wms_up,wms_down,layer_up,layer_down,remove', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'metadatalink', 'false', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui1';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','WMS_preferences',2,1,'configure the preferences of each loaded wms','WMS preferences','img','../img/button_blink_red/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',670,60,24,24,1,'','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_blink_red/add_off.png','onclick=''mod_addWMS()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',645,60,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMSfromList',2,1,'add a WMS to the running application from a list','Adding WMS from List','img','../img/button_blink_red/addlist_off.png','onclick=''window.open("../javascripts/mod_addWMSfromList.php?sessionID","printWin","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',595,60,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',620,60,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','back',2,1,'History.back()','Back','img','../img/button_blink_red/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()" ',400,60,24,24,1,'','','','mod_back.php','','mapframe1,overview','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','body',1,1,'body (obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','center1',2,1,'Center button','Set map center','img','../img/button_blink_red/center_off.png','onmouseover = "mb_regButton(''init_gui1_center'')" ',310,60,24,24,1,'','','','mod_center1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','changeEPSG',2,1,'change EPSG, Postgres required, overview is targed for full extent','Change Projection','iframe','../php/mod_changeEPSG.php?sessionID','scrolling="no" frameborder=''0'' ',432,25,107,24,1,'','','iframe','','','overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','changePassword_button',2,1,'button: change password of logged user','Change Password','img','../img/button_blink_red/change_password_off.png','onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0'' onmouseover=''this.src="../img/button_blink_red/change_password_over.png"'' onmouseout=''this.src="../img/button_blink_red/change_password_off.png"'' ',750,60,24,24,1,'cursor:hand','','','','','','','http://www.mapbender.org/index.php/ChangePassword');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','closePolygon',3,1,'close Polygon ','Close Polygon','div','','',0,0,0,0,0,'','','div','mod_closePolygon.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',-59,1,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',-59,1,0,0,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','featureInfo1',2,1,'FeatureInfoRequest','Query','img','../img/button_blink_red/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')" ',465,60,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','forward',2,1,'History.forward()','Forward','img','../img/button_blink_red/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()" ',425,60,24,24,1,'','','','mod_forward.php','','mapframe1,overview','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','getArea',3,1,'Calculation of area, Postgis required','Get Area','div','','',0,0,0,0,0,'','','div','mod_getArea.php','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','help',2,1,'button help','Help','img','../img/button_blink_red/help_off.png','onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")''',790,60,24,24,1,'','','','','','','','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','help1',2,1,'button help','Help','img','../img/button_blink_red/help_off.png','onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' onclick=''window.open("http://www.mapbender.org/index.php/Using_Mapbender","Hilfe","width=800, height=800, resizable=yes,scrollbars=yes, menubar=yes, toolbar=yes, location=yes")''',790,60,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/help');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','highlightPOI',2,1,'highlight 1 to n pois in your gui with a Symbol and a special text','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_highlightPOI.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','layout_1',3,1,'layout, background for buttons','','div','','',208,58,670,28,0,'background-color:#FFFFFF;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&wms_legend = yes','frameborder=''0''',-59,200,180,600,3,'','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','loadData',2,1,'IFRAME to load data','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','loadwmc',2,1,'load workspace from WMC','Load a web map context document','img','../img/button_blink_red/wmc_load_off.png','onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',895,60,24,24,1,'','','','mod_loadwmc.php','','mapframe1','','http://www.mapbender.org/index.php/LoadWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','logout',2,1,'Logout','Logout','img','../img/button_blink_red/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blink_red/logout_over.png"'' onmouseout=''this.src="../img/button_blink_red/logout_off.png"'' ',830,60,24,24,1,'','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',-59,1,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','mapframe1',2,1,'Frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',220,105,625,400,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','measure',2,1,'Measure','Measure distance','img','../img/button_blink_red/measure_off.png','onmouseover = "mb_regButton(''init_mod_measure'')"',515,60,24,24,1,'','','','mod_measure.php','','mapframe1','','http://www.mapbender.org/index.php/Measure');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_blink_red/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0'' onmouseover=''this.src="../img/button_blink_red/metadata_over.png"'' onmouseout=''this.src="../img/button_blink_red/metadata_off.png"'' ',710,60,24,24,1,'','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,0,0,10,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div> <div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div> <div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div> <div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div> <div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div> <div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div> <div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div> <div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div> ','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',15,25,150,150,2,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','pan1',2,1,'pan','Pan','img','../img/button_blink_red/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')"',260,60,24,24,1,'','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','print1',2,0,'start print GUI','Print','img','../img/button_blink_red/print_off.png','onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID","printWin","width=300, height=400, resizable=yes ")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',555,60,24,24,1,'','','','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','printPDF',2,1,'start print GUI','Print','img','../img/button_blink_red/print_off.png','onclick=''window.open("../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF_b.conf","printWin","width=180, height=200, resizable=yes ")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',555,60,24,24,1,'','','','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','repaint',2,1,'refresh a mapobject','Redraw','img','../img/button_blink_red/repaint_off.png','onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)'' ',360,60,24,24,1,'','','','mod_repaint.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','rubber',3,1,'deletes temporary (digitized) objects','Rubber','div','','',0,0,0,0,0,'','','div','mod_rubber.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',0,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','savewmc',2,1,'save workspace as WMC','Save workspace as web map context document','img','../img/button_blink_red/wmc_save_off.png','onclick=''mod_savewmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',870,60,24,24,1,'','','','mod_savewmc.php','','mapframe1','','http://www.mapbender.org/index.php/SaveWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scaleSelect',2,1,'Scale-Selectbox','Scale Select','select','','onchange=''mod_scaleSelect(this)''',555,25,100,20,1,'','<option value = ''''>Scale</option> <option value=''100''>1 : 100</option> <option value=''250''>1 : 250</option> <option value=''500''>1 : 500</option> <option value=''1000''>1 : 1000</option> <option value=''2500''>1 : 2500</option> <option value=''5000''>1 : 5000</option> <option value=''10000''>1 : 10000</option> <option value=''25000''>1 : 25000</option> <option value=''30000''>1 : 30000</option> <option value=''50000''>1 : 50000</option> <option value=''75000''>1 : 75000</option> <option value=''100000''>1 : 100000</option> <option value=''200000''>1 : 200000</option> <option value=''300000''>1 : 300000</option> <option value=''400000''>1 : 400000</option> <option value=''500000''>1 : 500000</option> <option value=''600000''>1 : 600000</option> <option value=''700000''>1 : 700000</option> <option value=''800000''>1 : 800000</option> <option value=''900000''>1 : 900000</option> <option value=''1000000''>1 : 1000000</option>','select','mod_scaleSel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scaleText',2,1,'Scale-description field','Scale Text','form','','onsubmit=''return mod_scaleText()''',672,25,100,30,0,'','<input type="text">','form','mod_scaleText.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','scalebar',2,1,'scalebar','Scalebar','div','','',0,0,0,0,0,'','','div','mod_scalebar.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_blink_red/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')"',285,60,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBBOX',2,1,'set Extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBackground',2,0,'switch background-wms','Set Background','form','','',15,190,0,0,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setBackground_all',2,0,'switch all background-wms','Set Background','form','','',157,190,40,20,1,'','<input type=''checkbox'' onclick=''mod_setBackground_all_init(this)''> <font face="Arial, sans-serif" size="2">all</font>','form','mod_setBackground_all.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setPOI2Scale',2,1,'zoom to a poi (get-parameter)','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_setPOI2Scale.php','','mapframe1','','http://www.mapbender.org/index.php/Mod_setPoi2Scale');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','setScaleHint',1,0,'set scaleHint for mapframes','','div','','',1,1,1,1,0,'visibility:hidden;','','div','mod_scaleHint.php','','mapframe1,100,10000000','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','showCoords_div',2,1,'displays coordinates by onmouseover','Coordinates','img','../img/button_blink_red/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ',490,60,24,24,1,'','','','mod_coords_div.php','','mapframe1','','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeConfGDE',2,0,'configurable directory tree','Maps','iframe','../php/mod_treefolderClient.php?sessionID','frameborder = "0" ',0,180,250,500,0,'visibility:visible','','iframe','mod_treeConf.js','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','treeGDE_1',2,0,'directory tree, checkbox for visible, checkbox for querylayer, no immediate refreshing, with nested layers','Maps','iframe','../html/mod_sync_treefolder_1.html','frameborder = "0" ',0,180,250,500,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','wfs_gazetteer',2,0,'gazetteer using wfs','Search','iframe','../php/mod_wfs_gazetteer.php?sessionID&color=255,0,255','frameborder = "0" ',-50,490,250,300,0,'visibility:visible','','iframe','','','mapframe1,overview','wfs','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomCoords',2,1,'zoom to coordinate','Zoom to Coordinates','iframe','../php/mod_zoomCoords_en.php?sessionID','frameborder = "0" ',205,7,220,45,0,'','','iframe','','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_blink_red/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)" ',335,60,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_blink_red/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)'' ',210,60,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_blink_red/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)'' ',235,60,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_db', '0', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_height', '25', 'height of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_image', '../img/redball.gif', 'image to use to mark the poi(s)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_style', 'background-color:white;font-weight: bold;color:blue;font-family:Arial;', 'style to display the poi text', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'highlightPOI', 'poi_width', '25', 'width of the poi_image', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'css_file_legend', '../css/legend.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'legend', 'stickylegend', 'true', 'parameter to decide wether the legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'logout', 'logout_location', 'http://www.mapbender.org/', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'setPOI2Scale', 'mod_setPOI2Scale_defScale', '5000', 'default scale', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'menu', '', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui2';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','WMS_preferences',2,1,'configures the preferences of each loaded wms','WMS preferences','img','../img/button_blue/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',604,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_blue/add_off.png','onclick=''mod_addWMS()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',580,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/AddWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blue/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',553,40,28,28,1,'filter:Chroma(color=#C2CBCF);','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','back',2,1,'History.back()','Back','img','../img/button_blue/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"',398,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_back.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Back');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','body',1,1,'body
+(obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'background-image:url(../img/background_yellow.jpg);background-repeat:repeat-x;','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','center1',2,1,'Center button','Set map center','img','../img/button_blue/center_off.png','onmouseover = "mb_regButton(''init_gui1_center'')"',308,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_center1.php','','mapframe1','','http://www.mapbender.org/index.php/ReCenter');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','changePassword_button',2,1,'button: change password of logged user','Change Password','img','../img/button_blue/change_password_off.png','onclick="window.open(''../php/mod_changePassword.php?sessionID'','''',''width=300, height=300, menubar=no,toolbar=no,location=no,status=no,resizable=yes'');" border=''0''
+onmouseover=''this.src="../img/button_blue/change_password_over.png"'' onmouseout=''this.src="../img/button_blue/change_password_off.png"''',668,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','','','http://www.mapbender.org/index.php/ChangePassword');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','closePolygon',3,1,'close Polygon ','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_closePolygon.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,0,0,0,'','','div','mod_copyright.php','','mapframe1','','http://www.mapbender.org/index.php/Copyright');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','http://www.mapbender.org/index.php/DependentDiv');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#799FEB; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','dynamicOverview',2,1,'oveview acts in accordance with main mapframe','','div','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','div','mod_dynamicOverview.php','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','featureInfo1',2,0,'FeatureInfoRequest','Query','img','../img/button_blue/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_featureInfo.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfo');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','Query','img','../img/button_blue/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')"',461,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_featureInfoTunnel.php','','mapframe1','','http://www.mapbender.org/index.php/FeatureInfoTunnel');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','forward',2,1,'History.forward()','Forward','img','../img/button_blue/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()"',423,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_forward.php','','mapframe1,overview0','','http://www.mapbender.org/index.php/Forward');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','Search','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','geometry.js','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','getArea',3,1,'Calculation of area, Postgis required','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_getArea.php','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','header_yellow',2,0,'header','','img','../img/header_yellow.jpg','',-1,-1,833,75,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','help',2,1,'button help','Help','img','../img/button_blue/help_off.png','onmouseover = "mb_regButton(''init_help'')"',693,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','imprint',2,1,'Information about the owner of the gui','Imprint','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','layout_linie',3,0,'layout','','div','','',1,70,830,1,1,'background-color:#799FEB;font-size:1px;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','layout_linie2',3,0,'layout','','div','','',1,35,830,1,1,'background-color:#799FEB;font-size:1px;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','loadData',2,1,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','loadwmc',2,1,'load workspace from WMC','Load a web map context document','img','../img/button_blue/wmc_load_off.png','onclick=''mod_loadwmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");''',758,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_loadwmc.php','','mapframe1','','http://www.mapbender.org/index.php/LoadWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','logo',2,1,'Logo','Logo','img','../img/mapbender_oo.png','',10,35,129,32,5,'filter:Chroma(color=#C2CBCF);','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','logout',2,1,'Logout','Logout','img','../img/button_blue/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_blue/logout_over.png"'' onmouseout=''this.src="../img/button_blue/logout_off.png"''',798,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','','','','','http://www.mapbender.org/index.php/Logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr> <script language="javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','mapframe1',2,1,'frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',213,90,608,467,2,'','','iframe','','','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','measure',2,1,'Measure','Measure distance','img','../img/button_blue/measure_off.png','onmouseover = "mb_regButton(''init_mod_measure'')"',513,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_measure.php','','mapframe1','','http://www.mapbender.org/index.php/Measure');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_blue/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''" border=''0''
+onmouseover=''this.src="../img/button_blue/metadata_over.png"'' onmouseout=''this.src="../img/button_blue/metadata_off.png"''',643,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_displayObj.js','','','','http://www.mapbender.org/index.php/Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,0,0,0,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>
+<div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>
+<div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>
+<div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div>
+<div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div>
+<div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>
+<div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>
+<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#799FEB;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>','div','mod_navFrame.php','','mapframe1','','http://www.mapbender.org/index.php/NavFrame');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',9,80,185,130,100,'','','iframe','','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/Overview');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','pan1',2,1,'pan','Pan','img','../img/button_blue/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')"',258,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_pan.php','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','printPDF',2,1,'pdf print','Print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','http://www.mapbender.org/index.php/Print');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','repaint',2,1,'refresh a mapobject','Redraw','img','../img/button_blue/repaint_off.png','onclick=''mod_repaint()'' onmouseover=''mod_repaint_init(this)''',358,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_repaint.php','','mapframe1','','http://www.mapbender.org/index.php/Repaint');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','resizeMapsize',2,1,'resize mapsize to browser window size','Resize Mapsize','img','../img/button_blink_red/resizemapsize_off.png','onclick = "adjustDimension()"
+onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',838,40,24,24,3,'filter:Chroma(color=#C2CBCF);','','','mod_resize_mapsize.php','','mapframe1','','http://www.mapbender.org/index.php/ResizeMapsize');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','rubber',3,1,'deletes temporary (digitized) objects','','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_rubber.js','','mapframe1','measure','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','savewmc',2,1,'save workspace as WMC','Save workspace as web map context document','img','../img/button_blue/wmc_save_off.png','onclick=''mod_savewmc()'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',733,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_savewmc.php','','mapframe1','','http://www.mapbender.org/index.php/SaveWMC');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_blue/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')"',283,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_selArea1.php','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','setBBOX',2,0,'set extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','setBackground',2,1,'switch background-wms','Set Background','form','','',10,218,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12'' name=''mod_setBackground_list'' onchange=''mod_setBackground_change(this)'' ><option value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','showCoords_div',2,1,'displays coodinates by onmouseover','Coordinates','img','../img/button_blue/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')"',488,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_coords_div.php','','mapframe1','dependendDiv','http://www.mapbender.org/index.php/ShowCoords_div');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','tabs',2,1,'vertical tabs to handle iframes','','div','','',2,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+for more infos have a look at http://www.mapbender.org/index.php/TreeGDE2','Maps','iframe','../html/mod_treefolder2.php?sessionID','frameborder = "0" ',10,220,200,300,NULL ,'visibility:visible','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_blue/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"',333,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','img','mod_zoomFull.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_blue/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)''',203,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_zoomIn1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui2','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_blue/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''',231,40,28,28,3,'filter:Chroma(color=#C2CBCF);','','','mod_zoomOut1.php','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_class_bg', 'body{background-color: #FEF8D4;}', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_minScale', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_startExtent', '-24.5,32,34.5,71', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_useMaxExtent', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_wmsIndex', '0', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'dynamicOverview', 'mod_dynamicOverview_zoomFactor', '5', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'gazetteerWFS', 'wfsConfIdString', '1', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showlayertitle', 'false', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'showwmstitle', 'false', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_height', '-35', 'to adjust the height of the mapframe on the bottom of the window', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'adjust_width', '-45', 'to adjust the width of the mapframe on the right side of the window', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'resizeMapsize', 'resize_option', 'button', 'auto (autoresize on load), button (resize by button)', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'sandclock', 'mod_sandclock_image', '../img/sandclock_oo.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'open_tab', '0', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_prefix', ' ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid #FDCC1A;font-size:12;color:#FFFFFF;background-color:#799FEB;cursor:pointer;margin-top:-3px; padding-top:3px;padding-left:4px;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'menu', 'opacity_up,opacity_down,zoom,metainfo,hide,wms_up,wms_down,layer_up,layer_down,remove', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
+Delete from gui_element where fkey_gui_id ='gui_digitize';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','FeatureInfoRedirect',2,0,'redirect featureInfoRequests in an iframe for each wms','Info','iframe','../html/mod_blank.html','frameborder="0"',83,-17,1,1,NULL ,'','','iframe','mod_featureInfoRedirect.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','WMS_preferences',2,1,'configures the preferences of each loaded wms','WMS preferences','img','../img/button_gray/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");''',540,10,24,24,1,'','','','','','mapframe1,treeGDE','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','addWMS',2,1,'add a WMS to the running application','Adding WMS','img','../img/button_gray/add_off.png','onclick=''mod_addWMS()''
+onmouseout=''this.src = this.src.replace(/_over/, "_off");''',515,10,24,24,1,'','','','mod_addWMS.php','','treeGDE,mapframe1','loadData','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','addWMSfromfilteredList_ajax',2,1,'add a WMS to the running application from a filtered list','Adding WMS from filtered list','img','../img/button_blink_red/add_filtered_list_off.png','onclick=''mod_addWMSfromfilteredList_win=window.open("../javascripts/mod_addWMSfromfilteredList_ajax.php?sessionID","mod_addWMSfromfilteredList_win","width=500, height=600, left=300, resizable=yes, scrollbars=yes")'' onmouseover=''this.src = this.src.replace(/_off/,"_over");'' onmouseout=''this.src = this.src.replace(/_over/, "_off");''',490,10,24,24,1,'','','','','mod_addWMSgeneralFunctions.js','treeGDE,mapframe1','loadData','http://www.mapbender.org/index.php/Add_WMS_from_filtered_list');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','back',2,1,'History.back()','Back','img','../img/button_gray/back_off_disabled.png','onmouseover="mod_back_over(this)" onmouseout="mod_back_out(this)" onclick = "mod_back_set()"',360,10,24,24,1,'','','','mod_back.php','','mapframe1,overview0','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','body',1,1,'body (obligatory)','','body','','onload="init()"',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','closePolygonExt',3,0,'close Polygon ','Close Polygon','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_closePolygonExt.js','','mapframe1','setExtRequest','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','copyright',2,1,'a Copyright in the map','Copyright','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_copyright.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','dependentDiv',2,1,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,0,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','digitize',2,1,'Digitize tool.','Digitize','iframe','../javascripts/mod_digitize_tab.php?sessionID','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','geometry.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','dragMapSize',2,1,'drag & drop Mapsize','Drag Mapsize','div','','',81,-19,NULL ,NULL ,2,'background-color:#B8C1C7; font-size:1px; cursor:move; width:10; height:10;','','div','mod_dragMapSize.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','featureInfo1',2,0,'FeatureInfoRequest','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfo1'')"',140,40,24,24,1,'','','','mod_featureInfo.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','featureInfoTunnel',2,1,'FeatureInfoRequest with local path','Query','img','../img/button_gray/query_off.png','onmouseover = "mb_regButton(''init_featureInfoTunnel'')"',425,10,24,24,1,'','','','mod_featureInfoTunnel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','forward',2,1,'History.forward()','Forward','img','../img/button_gray/forward_off_disabled.png','onmouseover="mod_forward_over(this)" onmouseout="mod_forward_out(this)" onclick = "mod_forward_set()"',385,10,24,24,1,'','','','mod_forward.php','','mapframe1,overview0','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','gazetteerWFS',2,1,'a gazetteer for user in the mapbender user map','Search','iframe','../javascripts/mod_wfs_gazetteer_client.php?sessionID&target=mapframe1,overview','frameborder = "0"',10,600,300,150,4,'visibility:hidden;','','iframe','','geometry.js','mapframe1,overview','wz-graphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',620,10,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','imprint',2,1,'Information about the owner of the gui','Imprint','iframe','../html/tab_imprint.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','initWmc',2,0,'initialise client with wmc','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','mod_initWmc.php','','mapframe1,overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_1',3,0,'Warning notice','','div','','',150,250,300,16,100,'font-family: Arial, Helvetica, sans-serif; font-size : 14px; text-decoration : none;','Development Version - Work in Progress!','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_back',3,1,'layout, background for buttons','','div','','',360,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_featureInfo',3,1,'layout, background for FeatureInfo','','div','','',425,10,51,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_help',3,1,'layout, background for Help-button','','div','','',620,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_logout',3,1,'layout, background for Logout-button','','div','','',660,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_metadata',3,1,'layout, background for Metadata','','div','','',580,10,26,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_wms',3,1,'layout, background for wms','','div','','',490,10,76,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','layout_zoom',3,1,'layout, background for Zoom-button','','div','','',220,10,126,26,0,'background-color:#414547;','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','legend',2,1,'legend','Legend','iframe','../javascripts/mod_legend.php?sessionID&e_id_css=legend','frameborder=''0''',1,1,1,1,3,'visibility:hidden;','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','loadData',2,1,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,0,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','loadwmc',2,0,'load workspace from WMC','Load a web map context document','img','../img/button_wmc/wmc_load.png','onclick=''mod_loadwmc()'' onmouseover=''mod_loadwmc_init(this)''',760,10,24,24,1,'','','','mod_loadwmc.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','logo',2,1,'Logo','','img','../img/mapbender_logo.png','',20,20,180,26,5,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0''
+onmouseover=''this.src="../img/button_gray/logout_over.png"''
+onmouseout=''this.src="../img/button_gray/logout_off.png"''',660,10,24,24,1,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<nobr>Ma<span style="color: blue;">P</span><span style="color: red;">b</span>ender</nobr>
+<script language="javascript">
+mb_registerSubFunctions("mod_mapbender()");
+function mod_mapbender(){
+document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90;
+document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1;
+</script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','mapframe1',2,1,'frame for a map','Mapframe','iframe','../php/mod_map1.php?sessionID','scrolling="no" frameborder=''0'' ',230,55,500,450,2,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','metadata',2,1,'shows informations about the wms and the requests of the gui','Show WMS infos','img','../img/button_gray/metadata_off.png','onClick="window.location.href=''javascript:mod_displayObj()''"
+border=''0''
+onmouseover=''this.src="../img/button_gray/metadata_over.png"''
+onmouseout=''this.src="../img/button_gray/metadata_off.png"''',580,10,24,24,1,'','','','mod_displayObj.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','navFrame',2,1,'navigation mapborder','Navigation Frame','div','','',0,0,NULL ,NULL ,NULL ,'font-size:1px;','<div id=''mbN'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("N")''><img id=''arrow_n'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_n.gif'' width=''15'' height=''10''></div>
+<div id=''mbNE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NE")''><img id=''arrow_ne'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_ne.gif'' width=''10'' height=''10''></div>
+<div id=''mbE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("E")''><img id=''arrow_e'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_e.gif'' width=''10'' height=''15''></div>
+<div id=''mbSE'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SE")''><img id=''arrow_se'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_se.gif'' width=''10'' height=''10''></div>
+<div id=''mbS'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("S")''><img id=''arrow_s'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_s.gif'' width=''15'' height=''10''></div>
+<div id=''mbSW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("SW")''><img id=''arrow_sw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_sw.gif'' width=''10'' height=''10''></div>
+<div id=''mbW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("W")''><img id=''arrow_w'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_w.gif'' width=''10'' height=''15''></div>
+<div id=''mbNW'' style=''position:absolute;width:0;height:0;top:0;left:0;background-color:#B8C1C7;'' onclick=''mod_navFrame("NW")''><img id=''arrow_nw'' style=''position:relative;top:0;left:0'' src=''../img/arrows/arrow_nw.gif'' width=''10'' height=''10''></div>
+','div','mod_navFrame.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','overview',2,1,'OverviewFrame','Overview','iframe','../php/mod_mapOV.php?wms=0&sessionID','scrolling="no" frameborder=''0'' ',30,65,150,130,100,'','','iframe','','mod_box1.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','pan1',2,1,'pan','Pan','img','../img/button_gray/pan_off.png','onmouseover = "mb_regButton(''init_mod_pan'')"',270,10,24,24,1,'','','','mod_pan.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','printPDF',2,1,'pdf print','Print','iframe','../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF.conf','frameborder = "0" ',1,1,2,2,5,'visibility:hidden','','iframe','','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','rubberExt',3,1,'deletes temporary (digitized) objects','Rubber','div','','',0,0,NULL ,NULL ,NULL ,'','','div','mod_rubberExt.js','','mapframe1','setExtRequest','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','savewmc',2,0,'save workspace as WMC','Save workspace as web map context document','img','../img/button_wmc/wmc_save.png','onclick=''mod_savewmc()'' onmouseover=''mod_savewmc_init(this)''',730,10,24,24,1,'','','','mod_savewmc.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','scaleSelect',2,0,'Scale-Selectbox','Scale Select','select','','onchange=''mod_scaleSelect(this)''',555,25,100,20,1,'','<option value = ''''>Scale</option>
+<option value=''100''>1 : 100</option>
+<option value=''250''>1 : 250</option>
+<option value=''500''>1 : 500</option>
+<option value=''1000''>1 : 1000</option>
+<option value=''2500''>1 : 2500</option>
+<option value=''5000''>1 : 5000</option>
+<option value=''10000''>1 : 10000</option>
+<option value=''25000''>1 : 25000</option>
+<option value=''30000''>1 : 30000</option>
+<option value=''50000''>1 : 50000</option>
+<option value=''75000''>1 : 75000</option>
+<option value=''100000''>1 : 100000</option>
+<option value=''200000''>1 : 200000</option>
+<option value=''300000''>1 : 300000</option>
+<option value=''400000''>1 : 400000</option>
+<option value=''500000''>1 : 500000</option>
+<option value=''600000''>1 : 600000</option>
+<option value=''700000''>1 : 700000</option>
+<option value=''800000''>1 : 800000</option>
+<option value=''900000''>1 : 900000</option>
+<option value=''1000000''>1 : 1000000</option>','select','mod_scaleSel.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','selArea1',2,1,'zoombox','Zoom by rectangle','img','../img/button_gray/selArea_off.png','onmouseover = "mb_regButton(''init_selArea1'')"',295,10,24,24,1,'','','','mod_selArea1.php','mod_box1.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setBBOX',2,0,'set extent for mapframe and overviewframe','','div','','',0,0,0,0,0,'','','div','mod_setBBOX1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setBackground',2,1,'switch background-wms','Set Background','form','','',30,210,NULL ,NULL ,1,'','<select style=''font-family: Arial, sans-serif; font-size:12''
+name=''mod_setBackground_list''
+onchange=''mod_setBackground_change(this)'' ><option
+value=''0''></option></select>','form','mod_setBackground.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','setSpatialRequest',2,1,'Spatial Request','','div','','',1,1,1,1,1,'visibility:hidden;','','div','../javascripts/mod_wfs_SpatialRequest.php','geometry.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','showCoords_div',2,1,'displays coodinates by onmouseover','Coordinates','img','../img/button_gray/coords_off.png','onmouseover = "mb_regButton(''init_mod_showCoords_div'')" ',450,10,24,24,1,'','','','mod_coords_div.php','','mapframe1','dependendDiv','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','showLoggedUser',2,0,'Displays current user','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','tabs',1,1,'vertical tabs to handle iframes','','div','','',10,240,200,20,2,'font-family: Arial,Helvetica;font-weight:bold;','','div','mod_tab.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','treeGDE',2,1,'new treegde2 - directory tree, checkbox for visible, checkbox for querylayer
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfs',2,1,'wfs request and result handling','','div','','',1,1,1,1,NULL ,'visibility:hidden','','div','wfs.js','../extensions/wz_jsgraphics.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfs_conf',2,1,'get all wfs_conf-params','','iframe','../php/mod_wfs.php','frameborder = "0"',1,1,1,1,0,'visibility:hidden','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','wfsresult',2,1,'display the list of wfs results','','iframe','../html/mod_blank.html','frameborder = "0"',10,730,200,150,4,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomFull',2,1,'zoom to full extent button','Display complete map','img','../img/button_gray/zoomFull_off.png','onclick="mod_zoomFull()" onmouseover="mod_zoomFull_init(this)"',320,10,24,24,2,'','','img','mod_zoomFull.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomIn1',2,1,'zoomIn button','Zoom in','img','../img/button_gray/zoomIn2_off.png','onclick=''mod_zoomIn1()'' onmouseover=''mod_zoomIn1_init(this)''',220,10,24,24,1,'','','','mod_zoomIn1.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui_digitize','zoomOut1',2,1,'zoomOut button','Zoom out','img','../img/button_gray/zoomOut2_off.png','onclick=''mod_zoomOut1()'' onmouseover=''mod_zoomOut1_init(this)''',245,10,24,24,1,'','','','mod_zoomOut1.php','','mapframe1','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'groupAbstractText', 'group abstract', 'table header for group abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'groupNameText', 'group name', 'table header for group name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'guiAbstractText', 'GUI abstract', 'table header for GUI abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'guiNameText', 'GUI name', 'table header for gui name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'noResultText', 'No result.', 'text that explains that the search ended with an empty result set.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_all', '1', '1 enables option "load all wms"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_db', '1', '1 enables option "load configured wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_group', '1', '1 enables option "load wms from group"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'option_gui', '1', '1 enables option "load wms from gui"', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectGroupText', 'Please select a group:', 'a text asking the user to select a group', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectGuiText', 'Please select a GUI:', 'a text asking the user to select a GUI', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'selectWmsText', 'Please select a WMS:', 'a text asking the user to select a WMS', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'wmsAbstractText', 'WMS abstract', 'table header for WMS abstract', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'addWMSfromfilteredList_ajax', 'wmsNameText', 'WMS name', 'table header for WMS name', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_class_bg', 'body{ background-color: #ffffff; }', 'to define the color of the body', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'body', 'css_file_body', '../css/mapbender.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'copyright', 'mod_copyright_text', 'mapbender.org', 'define a copyright text which should be displayed', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'cssUrl', '../css/digitize.css', 'url to the style sheet of the mapframe', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'digitize_conf_filename', 'digitize_default.conf', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'text css', ' body{
+ font-family: Arial, Helvetica, sans-serif;
+ font-size : 12px;
+ color: #ff00ff;
+ background-color: #ffffff;
+ margin-top: 0px;
+ margin-left: 0px;
+ .button{
+ height: 18px;
+ width: 32px;
+', 'text css', 'text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'wfsCssUrl', '../css/mapbender.css', 'var', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'gazetteerWFS', 'wfsConfIdString', '1,2,3,4', 'comma seperated list of WFS conf ids', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'checkbox_on_off', 'false', 'display or hide the checkbox to set the legend on/off', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'css_file_legend', '../css/legend.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'legendlink', 'false', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showgroupedlayertitle', 'true', 'show the title of the grouped layers in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showlayertitle', 'true', 'show the layer title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'showwmstitle', 'true', 'show the wms title in the legend', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'legend', 'stickylegend', 'false', 'decide wether your legend should stick on the mapframe1', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'logout', 'logout_location', '', 'webside to show after logout', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'sandclock', 'mod_sandclock_image', '../img/sandclock.gif', 'define a sandclock image ', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'useUsemap', '0', '"1" adds a usemap to each geometry; the geometry will be highlighted onMouseOver. Every other value will skip the usemap.', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'setSpatialRequest', 'wfs_conf_filename', 'wfs_default.conf', 'location and name of the WFS configuration file', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'open_tab', '5', 'define which tab should be opened when a gui is opened', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[0]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[1]', '260', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[2]', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[3]', '340', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[4]', '180', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_frameHeight[5]', '250', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[0]', 'treeGDE', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[1]', 'legend', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[2]', 'printPDF', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[3]', 'gazetteerWFS', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[4]', 'imprint', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_ids[5]', 'digitize', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_prefix', ' ', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'tabs', 'tab_style', 'position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;padding-left:8px;', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'alerterror', 'true', 'alertbox for wms loading error', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'cssfile', '../css/treeGDE2.css', 'global stylesheets', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'ficheckbox', 'true', 'checkbox for featureInfo requests', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'imagedir', '../img/tree_new', 'image directory', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'menu', '', 'context menu elements', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'metadatalink', 'true', 'link for layer-metadata', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'wfs', 'displayWfsResultList', '1', '', 'var');
+Delete from gui_element where fkey_gui_id ='admin1';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','AdminFrame',2,1,'the frame for administration modules','','iframe','','frameborder = "0"',220,20,800,800,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','CreateTreeGDE',2,1,'create a foldertree for a individual geodataexplorer','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,810,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','CREATE TREE_GDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','EditWMSMetadata',2,1,'edit the metadata of wms','edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,950,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT WMS-METADATA','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_Gui',2,1,'allocate groups to guis','','a','','href = "../php/mod_group_gui.php?sessionID&e_id_css=Group_Gui" target = "AdminFrame" ',10,610,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_User',2,1,'allocate groups to user','','a','','href = "../php/mod_group_user.php?sessionID&e_id_css=Group_User" target = "AdminFrame" ',10,550,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','GROUP -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Group_filteredGui',2,1,'allocate Groups to the guis of this admin','','a','','href = "../php/mod_group_filteredGui.php?sessionID&e_id_css=Group_filteredGui" target = "AdminFrame" ',10,710,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Gui_Group',2,1,'allocate guis to groups','','a','','href = "../php/mod_gui_group.php?sessionID&e_id_css=Gui_Group" target = "AdminFrame" ',10,250,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','Gui_User',2,1,'allocate a gui to user','','a','','href = "../php/mod_gui_user.php?sessionID&e_id_css=Gui_User" target = "AdminFrame" ',10,190,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','User_Group',2,1,'allocat user to groups','','a','','href = "../php/mod_user_group.php?sessionID&e_id_css=User_Group" target = "AdminFrame" ',10,430,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','body',1,1,'navigation','','body','','onload=''mod_adminNavigation_init()''',0,0,0,0,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteGui',2,1,'delete gui','','a','','href = "../php/mod_deleteGUI.php?sessionID" target = "AdminFrame" ',10,150,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteWFS',2,1,'delete WFS','Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,890,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','deleteWMS',2,1,'delete wms','Delete WMS completely','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,110,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','delete_filteredGui',2,1,'delete guis of this admin','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,790,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editElements',2,1,'edit gui elements','Edit GUI elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,170,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','EDIT GUI-ELEMENTS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editFilteredGroup',2,1,'edit group of this admin','Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',10,530,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editFilteredUser',2,1,'save, edit, delete user where this admin is owner','Create and edit user','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',10,350,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editGUI_WMS',2,1,'edit the elements of the gui','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,90,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT GUI-WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editGroup',2,1,'edit group','','a','','href = "../php/mod_editGroup.php?sessionID" target = "AdminFrame" ',10,510,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','editUser',2,1,'save, edit, delete user','','a','','href = "../php/mod_editUser.php?sessionID" target="AdminFrame"',10,330,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','exportGUI',2,1,'export gui, create SQLL','export GUI, create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,310,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EXPORT GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGoup_filteredUser',2,1,'allocate the groups of this admin to user where the admin is owner','Add several users to one group','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',10,590,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> myUSER ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_Gui',2,1,'allocate groups of this admin to guis','','a','','href = "../php/mod_filteredGroup_Gui.php?sessionID&e_id_css=filteredGroup_Gui" target = "AdminFrame" ',10,750,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_User',2,1,'allocate groups of this admin to user','','a','','href = "../php/mod_filteredGroup_User.php?sessionID&e_id_css=filteredGroup_User" target = "AdminFrame" ',10,690,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> USER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGroup_filteredGui',2,1,'allocate groups of this admin to guis of this admin','Allow one group access to several GUIs','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',10,730,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_Group',2,1,'allocate guis to groups','','a','','href = "../php/mod_filteredGui_group.php?sessionID&e_id_css=filteredGui_Group" target = "AdminFrame" ',10,270,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> GROUP ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_filteredGroup',2,1,'allocate guis of this admin to groups where this admin is owner','Allow several groups access to one GUI','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',10,290,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_filteredUser',2,1,'allocate the user where the admin is owner to his guis ','Allow several users access to one GUI ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',10,230,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredGui_user',2,1,'allocate the guis of this admin to a user','','a','','href = "../php/mod_filteredGui_User.php?sessionID&e_id_css=filteredGui_user" target = "AdminFrame" ',10,210,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> USER ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_Group',2,1,'allocate user of this admin to groups','','a','','href = "../php/mod_filteredUser_Group.php?sessionID&e_id_css=filteredUser_Group" target = "AdminFrame" ',10,670,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> GROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_Gui',2,1,'allocate user of this admin to guis','','a','','href = "../php/mod_filteredUser_Gui.php?sessionID&e_id_css=filteredUser_Gui" target = "AdminFrame" ',10,770,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_filteredGroup',2,1,'allocate user where this admin is owner to groups where this admin is owner','Add one user to serveral groups','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',10,490,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','filteredUser_filteredGui',2,1,'allocate admins user to guis of this admin','Allow one user to access several GUIs','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',10,410,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myUSER -> myGUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','getStyles',2,0,'load styles from wms','','a','','href = "../php/mod_getStyles.php?sessionID" target = "AdminFrame" ',10,890,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GET_STYLES','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','group_filteredUser',2,1,'allocate groups to user where this admin is owner','','a','','href = "../php/mod_group_filteredUser.php?sessionID&e_id_css=group_filteredUser" target = "AdminFrame" ',10,570,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GROUP -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_filteredGroup',2,1,'allocate guis to groups of this admin','','a','','href = "../php/mod_gui_filteredGroup.php?sessionID&e_id_css=gui_filteredGroup" target = "AdminFrame" ',10,650,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_filteredUser',2,1,'allocate guis to user of this admin','','a','','href = "../php/mod_gui_filteredUser.php?sessionID&e_id_css=gui_filteredUser" target = "AdminFrame" ',10,630,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> myUSER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','gui_owner',2,1,'set owner','Edit GUI assign to user','a','','href = "../php/mod_gui_owner.php?sessionID&e_id_css=gui_owner" target = "AdminFrame" ',10,830,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','GUI -> OWNER','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWFS',2,1,'load capabilities in a gui','Load WFS Capabilities into a GUI','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,850,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/WFS_Konfiguration');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWMS',2,1,'load capabilities in a gui','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,30,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','loadWMSList',2,1,'load wms from a list','Link WMS into GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,50,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD myWMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,1,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','myGUIlist',2,1,'go back to your GUI list','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' ',150,2,24,24,1,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','newGui',2,1,'create a new gui','Create new GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,130,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','NEW GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','orphanWMS',2,1,'display orphaned WMS','Delete orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID&&elementID=orphanWMS" target = "AdminFrame"',10,930,200,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','ORPHAN WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','owsproxy',2,1,'secure services','OWSPROXY','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,910,200,20,1,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','OWSPROXY','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','rename_copy_Gui',2,1,'rename and copy gui','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,470,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','RENAME COPY GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','showLoggedUser',2,1,'displays the logged admin','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','updateWMSs',2,1,'edit the elements of the gui','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,70,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','UPDATE WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_filteredGroup',2,1,'allocate user to groups where this admin is owner','','a','','href = "../php/mod_user_filteredGroup.php?sessionID&e_id_css=user_filteredGroup" target = "AdminFrame" ',10,450,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> myGROUP','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_filteredGui',2,1,'allocate guis of this admin to user','','a','','href = "../php/mod_user_filteredGui.php?sessionID&e_id_css=user_filteredGui" target = "AdminFrame" ',10,390,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER-> myGUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','user_gui',2,1,'allocate guis to user','','a','','href = "../php/mod_user_gui.php?sessionID&e_id_css=user_gui" target = "AdminFrame" ',10,370,200,20,0,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','USER -> GUI ','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','wfs_conf',2,1,'create and edit a gazetteer module','Configure WFS','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,870,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','WFS CONF','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','wfs_gui',2,1,'edit wfs settings','Assign WFS conf to gui','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,1000,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','asign WFS conf to gui','a','','','','AdminFrame','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_Gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Group_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'Gui_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'User_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'editGUI_WMS', 'file_css', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_Gui', 'file css', '../css/administration_alloc.css', 'file', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_User', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredGui_user', 'file css', '../css/administration_alloc.css', 'a file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_Group', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_Gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'group_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'gui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin1', 'user_gui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin2_de';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','AdminFrame',2,1,'Bereich für Administrationsmodule','','iframe','','frameborder = "0"',200,20,980,800,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','CreateTreeGDE',2,1,'Ordnerbaum konfigurieren','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',8,280,190,20,5,'','Ordnerbaum konfigurieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','body',1,1,'Navigation','','body','','onload=''mod_adminNavigation_init()''',0,0,180,20,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','deleteWMS',2,1,'!Vollständig löschen!','Delete WMS completely','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',8,100,190,20,5,'','!Vollständig löschen!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','delete_filteredGui',2,1,'GUI löschen','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',110,240,80,20,5,'','GUI löschen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editElements',2,1,'Oberflächenelemente editieren','Edit GUI elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',8,260,190,20,5,'','GUI-Elemente editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editFilteredGroup',2,1,'Gruppe anlegen und editieren','Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',8,400,190,20,10,'','Gruppe anlegen und editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editFilteredUser',2,1,'Benutzer anlegen und editieren','Create and edit user','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',8,380,190,20,10,'','Benutzer anlegen und editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','editGUI_WMS',2,1,'WMS GUI Einstellungen','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',8,180,190,20,5,'','WMS GUI Einstellungen','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','exportGUI',2,1,'Oberfläche (GUI) exportieren, SQL erzeugen','export GUI, create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',8,300,190,20,10,'','GUI exportieren (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGoup_filteredUser',2,1,'Gruppe mit Benutzern bestücken','Add several users to one group','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',8,440,190,20,10,'','Gruppe mit Benutzern bestücken ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGroup_filteredGui',2,1,'Einzelner Gruppe mehrere Oberflaechen zuordnen','Allow one group access to several GUIs','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',8,570,190,25,10,'','Einzelner Gruppe mehrere <br>GUIs zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGui_filteredGroup',2,1,'Einzelner Oberfläche mehrere Gruppen zuordnen','Allow several groups access to one GUI','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',8,605,190,25,10,'','Einzelner GUI mehrere<br> Gruppen zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredGui_filteredUser',2,1,'Oberfläche mehreren Benutzer zuordnen ','Allow several users access to one GUI ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',8,535,190,25,10,'','GUI mehreren Benutzern <br> zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredUser_filteredGroup',2,1,'Benutzer in Gruppen eintragen','Add one user to serveral groups','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,420,190,20,10,'','Benutzer in Gruppen eintragen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','filteredUser_filteredGui',2,1,'Einem Nutzer Zugriff auf mehrere Oberflächen erteilen','Allow one user to access several GUIs','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',8,500,190,25,10,'','Einem Nutzer Zugriff auf <br> mehrere GUIs erteilen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','gui_owner',2,1,'GUI editieren Benutzer zuordnen','Edit GUI assign to user','a','','href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame" ',8,640,190,20,10,'','GUI editieren Benutzer zuordnen','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_Configure_WMS_Access',3,1,'Hintergrund WMS Zuordnung','Configure WMS Access','div','','',5,137,193,66,2,'',' WMS Zuordnung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_GUI_Management',3,1,'Hintergrund Oberflächenverwaltung','GUI Management','div','','',5,217,193,126,2,'',' GUI-Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_User_Authorization',3,1,'Hintergrund Benutzerzugriff erteilen','Authorization ','div','','',5,477,193,196,2,'',' Benutzerzugriff erteilen','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_User_Management',3,1,'Hintergrund Benutzerverwaltung','User Management','div','','',5,357,193,106,2,'',' Benutzerverwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','headline_WMS_Management',3,1,'Hintergrund WMS Management','WMS Management','div','','',5,37,193,86,2,'',' WMS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','loadWMS',2,1,'Capabilities hochladen','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',8,60,190,20,5,'','Capabilities hochladen','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','loadWMSList',2,1,'WMS in GUI einbinden','Link WMS into GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',8,160,190,20,5,'','WMS in GUI einbinden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','myGUIlist',2,1,'Zurück zur eigenen GUI Liste','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','newGui',2,1,'GUI erzeugen','Create new GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',8,240,85,20,5,'','GUI erzeugen','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','rename_copy_Gui',2,1,'GUI umbenennen/ kopieren','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',8,320,190,20,10,'','GUI umbenennen/kopieren','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','showLoggedUser',2,1,'Anzeige des eingeloggten Benutzers','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_de','updateWMSs',2,1,'Hochgeladene aktualisieren','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',8,80,190,20,5,'','Hochgeladene aktualisieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'body', 'body_css_file', '../css/admin.css', 'css-file to define the style fo the admin-gui', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGoup_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_de', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin2_en';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','AdminFrame',2,1,'the frame for administration modules','','iframe','','frameborder = "0"',200,20,800,800,0,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','CreateTreeGDE',2,1,'TreeGDE set up','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',8,280,190,20,5,'','Create treeGDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','body',1,1,'navigation','','body','','onload=''mod_adminNavigation_init()''',0,0,0,0,0,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','deleteWMS',2,1,'!Delete WMS completely!','Delete WMS completely','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',8,100,190,20,5,'','!Delete WMS completely!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','delete_filteredGui',2,1,'Delete GUI','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',120,240,80,20,5,'','Delete GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editElements',2,1,'Edit GUI elements','Edit GUI elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',8,260,190,20,5,'','Edit GUI elements','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editFilteredGroup',2,1,'Create and edit group','Create and edit group','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target = "AdminFrame" ',8,400,190,20,10,'','Create and edit group','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editFilteredUser',2,1,'Create and edit user','Create and edit user','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="AdminFrame"',8,380,190,20,10,'','Create and edit user','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','editGUI_WMS',2,1,'WMS GUI settings','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',8,180,190,20,5,'','WMS GUI settings','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','exportGUI',2,1,'export GUI, create SQL','export GUI, create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',8,300,190,20,10,'','Export GUI (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGoup_filteredUser',2,1,'Add several users to one group','Add several users to one group','a','','href = "../php/mod_filteredGroup_filteredUser.php?sessionID&e_id_css=filteredGoup_filteredUser" target = "AdminFrame" ',8,440,190,20,10,'','Add several users to one group ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGroup_filteredGui',2,1,'Allow one group access to several GUIs','Allow one group access to several GUIs','a','','href = "../php/mod_filteredGroup_filteredGui.php?sessionID&e_id_css=filteredGroup_filteredGui" target = "AdminFrame" ',8,570,190,25,10,'','Allow one group access to <br> several GUIs','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGui_filteredGroup',2,1,'Allow several groups access to one GUI','Allow several groups access to one GUI','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target = "AdminFrame" ',8,605,190,25,10,'','Allow several groups access <br> to one GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredGui_filteredUser',2,1,'Allow several users access to one GUI ','Allow several users access to one GUI ','a','','href = "../php/mod_filteredGui_filteredUser.php?sessionID&e_id_css=filteredGui_filteredUser" target = "AdminFrame" ',8,535,190,25,10,'','Allow several users access to <br> one GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredUser_filteredGroup',2,1,'Add one user to serveral groups','Add one user to serveral groups','a','','href = "../php/mod_filteredUser_filteredGroup.php?sessionID&e_id_css=filteredUser_filteredGroup" target = "AdminFrame" ',8,420,190,20,10,'','Add one user to serveral groups','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','filteredUser_filteredGui',2,1,'Allow one user to access several GUIs','Allow one user to access several GUIs','a','','href = "../php/mod_filteredUser_filteredGui.php?sessionID&e_id_css=filteredUser_filteredGui" target = "AdminFrame" ',8,500,190,25,10,'','Allow one user to access <br> several GUIs','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','gui_owner',2,1,'Edit GUI assign to user','Edit GUI assign to user','a','','href = "../php/mod_gui_owner.php?sessionID" target = "AdminFrame" ',8,640,190,20,10,'','Edit GUI assign to user','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_Configure_WMS_Access',3,1,'Configure WMS Access','Configure WMS Access','div','','',5,137,193,66,2,'',' Configure WMS Access','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_GUI_Management',3,1,'GUI Management caption','GUI Management','div','','',5,217,193,126,2,'',' GUI Management ','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_User_Authorization',3,1,'Authorization caption','Authorization ','div','','',5,477,193,186,2,'',' Authorization','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_User_Management',3,1,'User Management caption','User Management','div','','',5,357,193,106,2,'',' User Management ','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','headline_WMS_Management',3,1,'WMS Management caption','WMS Management','div','','',5,37,193,86,2,'',' WMS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')" ',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','loadWMS',2,1,'Load Capabilities','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',8,60,190,20,5,'','Load WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','loadWMSList',2,1,'Link WMS into GUI','Link WMS into GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',8,160,190,20,5,'','Link WMS into GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','myGUIlist',2,1,'go back to your GUI list','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"'' ',150,2,24,24,2,'','','img','mod_home.php','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','newGui',2,1,'Create new GUI','Create new GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',8,240,110,20,5,'','Create new GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','rename_copy_Gui',2,1,'Rename/ copy GUI','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',8,320,190,20,10,'','Rename / copy GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','showLoggedUser',2,1,'Logged User:','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin2_en','updateWMSs',2,1,'Update with Capabilities','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',8,80,190,20,5,'','Update WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'body', 'body_css_file', '../css/admin.css', 'css-file to define the style fo the admin-gui', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGoup_filteredUser', 'css_file_filteredGroup_filterdUser', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGroup_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredGroup', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredGui_filteredUser', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGroup', 'css_filteredUser_filteredGroup', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'filteredUser_filteredGui', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'gui_owner', 'file css', '../css/administration_alloc.css', 'file css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin2_en', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin_de_services';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','AdminFrame',2,1,'Bereich für Administrationsmodule','','iframe','','frameborder = "0"',210,25,800,800,12,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','CreateTreeGDE',2,1,'Ordnerbaum konfigurieren','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,533,200,20,5,'','Ordnerbaum konfigurieren','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','EditWMSMetadata',2,1,'edit the metadata of wms','edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,275,200,20,5,'','WMS Metadaten','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_WMS_Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','body',1,1,'Navigation','','body','','onload=''mod_adminNavigation_init()''',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','deleteWFS',2,1,'WFS löschen','Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,393,200,20,5,'','WFS löschen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','deleteWMS',2,1,'!Vollständig löschen!','!Delete WMS completely!','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,100,200,20,5,'','WMS löschen!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','delete_filteredGui',2,1,'GUI löschen','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,491,200,20,5,'','GUI löschen','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','editElements',2,1,'Oberflächenelemente editieren','Edit GUI Elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,511,200,25,5,'','GUI editieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','editGUI_WMS',2,1,'WMS GUI Einstellungen','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,218,200,20,5,'','WMS Einstellungen ändern','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','exportGUI',2,1,'GUI exportieren, SQL erzeugen','Export GUI (SQL), create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,554,200,25,10,'x','GUI exportieren (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','filteredWms_layer_topic',2,1,'allocate topics to layers of wms of this user','allocate topics to layers of wms of this user','a','','href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ',10,295,200,20,5,'','Kategoriezuordnung','a','','','','AdminFrame','http://www.mapbender.org/index.php/Topic_/_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_Configure_WMS_Access',3,1,'Hintergrund WMS Zuordnung','WMS Assignment','div','','',1,175,210,63,2,'','WMS Zuordnung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_GUI_Management',3,1,'Oberflächenverwaltung','GUI Management','div','','',1,448,210,153,2,'','GUI Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_Metadata',3,1,'Metadateneditor Caption','Metadata','div','','',1,252,210,63,2,'','Metadaten','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_WFS_Management',3,1,'WFS Verwaltung','WFS Management','div','','',1,330,210,103,2,'','WFS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','headline_WMS_Management',3,1,'Dienstverwaltung Beschriftung','WMS Management','div','','',0,37,210,123,2,'','WMS Verwaltung','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWFS',2,1,'WFS Capabilities in eine GUI laden','Load WFS Capabilities into a GUI','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,353,200,20,5,'','WFS laden','a','','','','AdminFrame','http://www.mapbender.org/index.php/LoadWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWMS',2,1,'Capabilities hochladen','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,60,200,20,5,'','WMS laden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','loadWMSList',2,1,'WMS in GUI einbinden','Assign WMS to a GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,198,200,20,5,'','WMS einbinden','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"''',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','myGUIlist',2,1,'Zurück zur eigenen GUI Liste','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','newGui',2,1,'GUI erzeugen','New GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,471,200,20,5,'','GUI erzeugen','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','orphanWMS',2,1,'display orphaned WMS','Delete orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID"
+target = "AdminFrame"',10,120,200,20,5,'','WMS ohne Zuordung löschen','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','owsproxy',2,1,'secure services','OWSPROXY','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,140,200,20,10,'','OWSPROXY','a','','','','AdminFrame','http://www.mapbender.org/index.php/Owsproxy');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','rename_copy_Gui',2,1,'GUI umbenennen/ kopieren','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,576,200,20,10,'','GUI umbenennen/kopieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/RenameGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','showLoggedUser',2,1,'Anzeige des eingeloggten Benutzers','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','updateWMSs',2,1,'Hochgeladene aktualisieren','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,80,200,20,5,'','WMS aktualisieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','wfs_conf',2,1,'WFS konfigurieren','Configure WFS','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,373,200,20,5,'','WFS konfigurieren','a','','','','AdminFrame','http://www.mapbender.org/index.php/Wfs_conf');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_de_services','wfs_gui',2,1,'edit wfs settings','Assign WFS conf to gui','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,413,200,20,10,'','WFS Konfiguration GUI zuweisen','a','','','','AdminFrame','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'EditWMSMetadata', 'file_css', '../css/metadata.css', 'css-file to use for the metadata modul', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'body', 'body_file_css', '../css/admin_service.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'filteredWms_layer_topic', 'file css', '../css/administration_alloc_4.css', 'css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'filteredWms_layer_topic', 'language', 'de', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_de_services', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+Delete from gui_element where fkey_gui_id ='admin_en_services';
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','AdminFrame',2,1,'administration frame','','iframe','','frameborder = "0"',210,25,1000,800,12,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','CreateTreeGDE',2,1,'Configure TreeGDE','Create treeGDE','a','','href = "../php/nestedSets.php?sessionID" target = "AdminFrame" ',10,533,200,20,5,'','Configure TreeGDE','a','','','','AdminFrame','http://www.mapbender.org/index.php/ConfTreeGde');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','EditWMSMetadata',2,1,'edit the metadata of wms','edit the metadata of wms','a','','href = "../php/mod_editWMS_Metadata.php?show_wms_list=true&sessionID" target="AdminFrame"',10,275,200,20,5,'','WMS Metadata','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_WMS_Metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','body',1,1,'Navigation','','body','','onload=''mod_adminNavigation_init()''',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','mod_adminNavigation.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','deleteWFS',2,1,'Delete WFS','Delete WFS','a','','href = "../php/mod_deleteWFS.php?sessionID" target = "AdminFrame" ',10,393,200,20,5,'','Delete WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','deleteWMS',2,1,'!Delete completely!','!Delete WMS completely!','a','','href = "../php/mod_deleteWMS.php?sessionID" target = "AdminFrame" ',10,100,200,20,5,'','!Delete WMS completely!','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','delete_filteredGui',2,1,'Delete GUI','Delete GUI','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID" target = "AdminFrame" ',10,491,200,20,5,'','Delete GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','editElements',2,1,'Edit GUI Elements','Edit GUI Elements','a','','href = "../php/mod_editElements.php?sessionID" target = "AdminFrame" ',10,511,200,20,5,'','Edit GUI Elements','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','editGUI_WMS',2,1,'WMS GUI settings','WMS GUI settings','a','','href="../php/mod_editGuiWms.php?sessionID"'' target="AdminFrame"',10,218,200,20,5,'','WMS GUI settings','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','exportGUI',2,1,'Export GUI (SQL), create SQL','Export GUI (SQL), create SQL','a','','href = "../php/mod_exportGUI.php?sessionID" target = "AdminFrame" ',10,553,200,20,10,'x','Export GUI (SQL)','a','','','','AdminFrame','http://www.mapbender.org/index.php/Oberfl%C3%A4che_exportieren_%28SQL%29');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','filteredWms_layer_topic',2,1,'allocate topics to layers of wms of this user','allocate topics to layers of wms of this user','a','','href = "../php/mod_filteredWms_layer_topic.php?sessionID&e_id_css=filteredWms_layer_topic" target = "AdminFrame" ',10,295,200,20,5,'','Allocate topics','a','','','','AdminFrame','http://www.mapbender.org/index.php/Topic_/_Category');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_Configure_WMS_Access',3,1,'WMS Assignment','WMS Assignment','div','','',1,175,210,63,2,'','WMS Assignment','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_GUI_Management',3,1,'GUI Management','GUI Management','div','','',1,448,210,148,2,'','GUI Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_Metadata',3,1,'Metadata','Metadata','div','','',1,252,210,63,2,'','Metadata','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_WFS_Management',3,1,'WFS Management','WFS Management','div','','',1,330,210,103,2,'','WFS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','headline_WMS_Management',3,1,'WMS Management','WMS Management','div','','',0,37,210,123,2,'','WMS Management','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','help',2,1,'button help','Help','img','../img/button_gray/help_off.png','onmouseover = "mb_regButton(''init_help'')"',210,2,24,24,1,'','','','mod_help.php','../extensions/wz_jsgraphics.js','','jsGraphics','http://www.mapbender.org');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWFS',2,1,'Load WFS Capabilities into a GUI','Load WFS Capabilities into a GUI','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="AdminFrame"',10,353,200,20,5,'','Load WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/LoadWFS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWMS',2,1,'load Capabilities','Load WMS','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="AdminFrame"',10,60,200,20,5,'','Load WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','loadWMSList',2,1,'assign WMS to a GUI','Assign WMS to a GUI','a','','href = "../php/mod_loadCapabilitiesList.php?sessionID" target="AdminFrame"',10,198,200,20,5,'','Assign WMS to a GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','logout',2,1,'Logout','Logout','img','../img/button_gray/logout_off.png','onClick="window.location.href=''../php/mod_logout.php?sessionID''" border=''0'' onmouseover=''this.src="../img/button_gray/logout_over.png"'' onmouseout=''this.src="../img/button_gray/logout_off.png"'' ',180,2,24,24,2,'','','img','','','','','http://www.mapbender.org/index.php/logout');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','myGUIlist',2,1,'back to GUI list','Move back to your GUI list','img','../img/button_gray/home_off.png','onClick="mod_home_init()" border=''0'' onmouseover=''this.src="../img/button_gray/home_over.png"'' onmouseout=''this.src="../img/button_gray/home_off.png"''',150,2,24,24,2,'','','img','mod_home.php','','','','http://www.mapbender.org/index.php/MyGUIlist');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','newGui',2,1,'New GUI','New GUI','a','','href = "../php/mod_newGui.php?sessionID" target = "AdminFrame" ',10,471,200,20,5,'','New GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','orphanWMS',2,1,'Delete orphaned WMS','Delete orphaned WMS','a','','href = "../php/mod_orphanWMS.php?sessionID"
+target = "AdminFrame"',10,120,200,20,5,'','Delete orphaned WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/OrphanWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','owsproxy',2,1,'secure services','OWSPROXY','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="AdminFrame"',10,140,200,20,10,'','OWSPROXY','a','','','','AdminFrame','http://www.mapbender.org/index.php/Owsproxy');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','rename_copy_Gui',2,1,'Rename / copy GUI','Rename / copy GUI','a','','href = "../php/mod_renameGUI.php?sessionID" target = "AdminFrame" ',10,576,200,20,10,'','Rename / copy GUI','a','','','','AdminFrame','http://www.mapbender.org/index.php/RenameGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','showLoggedUser',2,1,'show logged in user','','iframe','../php/mod_showLoggedUser.php?sessionID','frameborder="0" scrolling=''no''',1,1,200,30,1,'background-color:lightgrey;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','updateWMSs',2,1,'Update Capabilities','Update WMS','a','','href="../php/mod_updateWMS.php?sessionID"'' target="AdminFrame"',10,80,200,20,5,'','Update WMS','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','wfs_conf',2,1,'Configure WFS','Configure WFS','a','','href="../php/mod_wfs_conf.php?sessionID"'' target="AdminFrame"',10,373,200,20,5,'','Configure WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Wfs_conf');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_en_services','wfs_gui',2,1,'edit wfs settings (Assign WFS conf to GUI)','Assign WFS conf to gui','a','','href = "../javascripts/mod_wfs_client.html" target="AdminFrame"',10,413,200,20,10,'','Assign WFS conf to GUI','a','','','','AdminFrame','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'EditWMSMetadata', 'file_css', '../css/metadata.css', 'css-file to use for the metadata modul', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'body', 'body_file_css', '../css/admin_service.css', 'file/css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'editGUI_WMS', 'css_file', '../css/edit_gui.css', '', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'filteredWms_layer_topic', 'file css', '../css/administration_alloc_4.css', 'css', 'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'filteredWms_layer_topic', 'language', 'de', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_color', '#cc33cc', 'color for highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_text', 'click highlighted elements for help', '', 'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'help', 'mod_help_thickness', '3', 'thickness of highlighting', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_en_services', 'showLoggedUser', 'css_file_user_logged', '../css/administration_alloc.css', 'file/css', 'file/css');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui','switchLocale_noreload',8,1,'changes the locale without reloading the client','Set language','div','','frameborder=''0''',696,14,50,30,5,'','<form id=''form_switch_locale'' name=''form_switch_locale'' target=''parent''>
+<select id=''language'' name=''language'' onchange=''validate_locale()''>
+</select>
+</form>
+','div','mod_switchLocale_noreload.php','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'switchLocale_noreload', 'languages', 'de,en,bg,gr,nl,it,es', '' ,'var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_closetag, e_js_file) VALUES('gui1', 'popup', 6, 1, 'popup replacement', 'div', 'div', 'popup.js');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui1', 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css');
+DELETE FROM gui_element WHERE fkey_gui_id = 'gui1' AND e_id = 'wfs_gazetteer';
+DELETE FROM gui_treegde WHERE fkey_gui_id IN ('gui', 'gui1', 'admin1', 'gui2', 'wms_africa');
+-- update own applications
+Update gui_element set e_title =
+mynew.e_title from gui_element as mynew
+where gui_element.e_id = mynew.e_id
+and mynew.fkey_gui_id = 'gui'
+and gui_element.fkey_gui_id != 'gui'
+and gui_element.fkey_gui_id != 'gui1'
+and gui_element.fkey_gui_id != 'gui2'
+and gui_element.fkey_gui_id != 'gui_digitize';
+and mynew.fkey_gui_id = 'gui1'
+and mynew.fkey_gui_id = 'gui2'
+and mynew.fkey_gui_id = 'gui_digitize'
+Delete from gui_element_vars where fkey_e_id ='tabs' and var_name LIKE 'tab_titles[%';
+Update gui_element_vars set var_type='php_var' where fkey_e_id ='tabs' and var_name LIKE 'tab_ids[%' and var_type='var';
+DELETE FROM gui_element WHERE e_id = 'ajax';
+Delete from gui_element where e_id='keyHandler';
+DELETE FROM gui_element WHERE e_id = 'geometry';
+Select * from gui_element where e_mb_mod ='geometry.js' ;
+update gui_element set e_mb_mod = 'geometry.js'
+where e_id = 'digitize';
+where e_id = 'gazetteerWFS';
+where e_id = 'setSpatialRequest';
More information about the Mapbender_commits
