[Mapbender-commits] r4899 - in
branches/jqMapbender/mapstraction/http: javascripts plugins
svn_mapbender at osgeo.org
Sun Nov 1 12:53:16 EST 2009
Author: christoph
Date: 2009-11-01 12:53:15 -0500 (Sun, 01 Nov 2009)
New Revision: 4899
Added:
branches/jqMapbender/mapstraction/http/plugins/mb_legend.js
branches/jqMapbender/mapstraction/http/plugins/ui_portlet.js
branches/jqMapbender/mapstraction/http/javascripts/map.php
branches/jqMapbender/mapstraction/http/javascripts/mod_legend.php
branches/jqMapbender/mapstraction/http/plugins/ui_accordion.js
Modified: branches/jqMapbender/mapstraction/http/javascripts/map.php
--- branches/jqMapbender/mapstraction/http/javascripts/map.php 2009-11-01 12:41:27 UTC (rev 4898)
+++ branches/jqMapbender/mapstraction/http/javascripts/map.php 2009-11-01 17:53:15 UTC (rev 4899)
@@ -78,7 +78,7 @@
$extFileArray = array( "jquery-1.3.2.min.js",
"jqjson.js",
"jquery.form.js",
- "jquery-ui-1.7.2.custom/js/jquery-ui-1.7.2.custom.min.js"
+ "jquery-ui-1.7.2.custom/development-bundle/ui/ui.core.js"
for ($i = 0; $i < count($extFileArray); $i++) {
Modified: branches/jqMapbender/mapstraction/http/javascripts/mod_legend.php
--- branches/jqMapbender/mapstraction/http/javascripts/mod_legend.php 2009-11-01 12:41:27 UTC (rev 4898)
+++ branches/jqMapbender/mapstraction/http/javascripts/mod_legend.php 2009-11-01 17:53:15 UTC (rev 4899)
@@ -1,95 +1,41 @@
-<?php
-# $Id: mod_legend.php 4879 2009-10-29 17:28:53Z christoph $
-# http://www.mapbender.org/index.php/Legend
-# Copyright (C) 2005 CCGIS / terrestris
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+var target = Mapbender.modules[options.target];
+var $this = $(this);
-<html>
-<head>
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>Legend</title>
-<?php
-include '../include/dyn_css.php';
+var mod_legend_offsetLeft = 25;
+var mod_legend_offsetTop = -10;
-$sql = "SELECT DISTINCT e_target, e_width, e_height FROM gui_element WHERE e_id = '".$_REQUEST["e_id_css"]."' AND fkey_gui_id = $1";
-$v = array($gui_id);
-$t = array('s');
-$res = db_prep_query($sql, $v, $t);
-$cnt = 0;
-while($row = db_fetch_array($res)){
- $e_target = $row["e_target"];
- $cnt++;
+var checkbox_on_off = false;
+if (typeof options.checkbox_on_off !== "undefined") {
+ checkbox_on_off = options.checkbox_on_off;
-if($cnt > 1){
- echo "alert('legend: ID not unique!');";
-$sql2 = "SELECT e_left,e_top,e_width,e_height FROM gui_element WHERE e_id = '".$e_target."' AND fkey_gui_id = $1";
-$t = array('s');
-$res2 = db_prep_query($sql2, $v, $t);
-echo "<script type='text/javascript'>\n";
-echo "var mod_legend_target = '".$e_target."';\n";
-echo "var mod_legend_target_left = ".db_result($res2,0,"e_left").";\n";
-echo "var mod_legend_target_top = ".db_result($res2,0,"e_top").";\n";
-echo "var mod_legend_target_width = ".db_result($res2,0,"e_width").";\n";
-echo "var mod_legend_target_height = ".db_result($res2,0,"e_height").";\n";
-echo "</script>\n";
-<script type="text/javascript">
-mod_legend_offsetLeft = 25;
-mod_legend_offsetTop = -10;
-try{
- if (checkbox_on_off){}
+var stickylegend = false;
+if (typeof options.stickylegend !== "undefined") {
+ stickylegend = options.stickylegend;
-catch(e){
- checkbox_on_off = 'false';
-try{
- if (stickylegend){}
-catch(e){
- stickylegend = 'false';
-// Todo: return-value may change in the next version....
-parent.eventAfterMapRequest.register(function (obj) {
+Mapbender.eventAfterMapRequest.register(function (obj) {
mod_legend_pos(obj.map.elementName)
+$this.append($(
+ "<form><span class='switch'><div id='" + options.id + "_checkboxstyle' " +
+ "style='display:block;'>on/off" +
+ "<input type='checkbox' name='sw' checked='true'></div></span>" +
+ "<div name='leg' id='" + options.id + "_leg' ></div></form>"
-function mod_legend_init(){
- var obj = parent.document.getElementById("legend");
- obj.style.top = mod_legend_target_top + mod_legend_offsetTop;
- obj.style.left = mod_legend_target_left + mod_legend_target_width + mod_legend_offsetLeft;
- var checkobj = document.getElementById("checkboxstyle");
- if (checkbox_on_off == 'false'){
+$("#" + options.id + "_checkboxstyle > input").click(function () {
+ mod_legend_repaint(this);
+Mapbender.events.init.register(function (){
+ $this.css(
+ top: mod_legend_target_top + mod_legend_offsetTop,
+ left: mod_legend_target_left + mod_legend_target_width + mod_legend_offsetLeft
+ if (!checkbox_on_off){
+ var checkobj = document.getElementById(options.id + "_checkboxstyle");
checkobj.style.display = "none";
checkobj.style.width = 0;
checkobj.style.height = 0;
@@ -122,69 +68,53 @@
for(var i=0; i<parent.mb_mapObj[ind].wms.length; i++){
- var layerNames = parent.mb_mapObj[ind].wms[i].getLayers(parent.mb_mapObj[ind]);
- for(var j=0; j<layerNames.length; j++){
- var layerParent = parent.mb_mapObj[ind].wms[i].checkLayerParentByLayerName(layerNames[j]);
- var layerTitle = parent.mb_mapObj[ind].wms[i].getTitleByLayerName(layerNames[j]);
- var layerStyle = parent.mb_mapObj[ind].wms[i].getCurrentStyleByLayerName(layerNames[j]);
- var legendUrl = false;
- if(layerStyle == false){
- legendUrl = parent.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layerNames[j],"");
- else{
- legendUrl = parent.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layerNames[j],layerStyle);
- if (legendUrl !== false){
-// if(layerParent == 0){
- if(showlayertitle == 'true'){
- str_tmp += "<div><span class='titles'>" + layerTitle+ "</span></div>";
- str_tmp += "<div>";
- if(legendlink == 'true'){
- str_tmp += "<a href='../php/result.php?lingo=deutsch&layer="+layerNames[j]+"' class='link_metadata' title='Zeigt Liste zum Thema: "+layerTitle+"' target='result'>";
- str_tmp += "<img border=0 src = '";
- str_tmp += legendUrl;
- str_tmp += "'></img>";
- if (legendlink == 'true'){
- str_tmp += "</a>";
- str_tmp += "</div>";
+ var layerNames = parent.mb_mapObj[ind].wms[i].getLayers(parent.mb_mapObj[ind]);
+ for(var j=0; j<layerNames.length; j++){
+ var layerParent = parent.mb_mapObj[ind].wms[i].checkLayerParentByLayerName(layerNames[j]);
+ var layerTitle = parent.mb_mapObj[ind].wms[i].getTitleByLayerName(layerNames[j]);
+ var layerStyle = parent.mb_mapObj[ind].wms[i].getCurrentStyleByLayerName(layerNames[j]);
+ var legendUrl = false;
+ if(layerStyle == false){
+ legendUrl = parent.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layerNames[j],"");
+ else{
+ legendUrl = parent.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layerNames[j],layerStyle);
+ if (legendUrl !== false){
+ if(showlayertitle == 'true'){
+ str_tmp += "<div><span class='titles'>" + layerTitle+ "</span></div>";
+ str_tmp += "<div>";
+ if(legendlink == 'true'){
+ str_tmp += "<a href='../php/result.php?lingo=deutsch&layer="+layerNames[j]+"' class='link_metadata' title='Zeigt Liste zum Thema: "+layerTitle+"' target='result'>";
+ str_tmp += "<img border=0 src = '";
+ str_tmp += legendUrl;
+ str_tmp += "'></img>";
+ if (legendlink == 'true'){
+ str_tmp += "</a>";
+ str_tmp += "</div>";
if(str_tmp !=''){
if (showwmstitle == 'true'){
- str += "<div><span class='header'>" +parent.mb_mapObj[ind].wms[i].wms_title+ "</span></div>";
+ str += "<div><span class='header'>" +
+ mb_mapObj[ind].wms[i].wms_currentTitle +
+ "</span></div>";
str += str_tmp;
str_tmp ='';
if(str != ""){
- parent.writeTag("legend", "leg", str);
+ $(options.id + "_leg").html(str);
else{
- parent.writeTag("legend", "leg", "");
+ $(options.id + "_leg").empty();
return true;
-</script>
-</head>
-<body onload='mod_legend_init()'>
-<form>
-<span class='switch'>
-<div id="checkboxstyle" style="display:block;">on/off<input type='checkbox' name='sw' checked='true' onclick='mod_legend_repaint(this)'></div>
-</span>
-<div name='leg' id='leg' ></div>
-</form>
-</body>
-</html>
Added: branches/jqMapbender/mapstraction/http/plugins/mb_legend.js
--- branches/jqMapbender/mapstraction/http/plugins/mb_legend.js (rev 0)
+++ branches/jqMapbender/mapstraction/http/plugins/mb_legend.js 2009-11-01 17:53:15 UTC (rev 4899)
@@ -0,0 +1,142 @@
+var target = Mapbender.modules[options.target[0]];
+var showlayertitle = false;
+if (typeof options.showlayertitle !== "undefined") {
+ showlayertitle = options.showlayertitle;
+var legendlink = false;
+if (typeof options.legendlink !== "undefined") {
+ legendlink = options.legendlink;
+var showwmstitle = false;
+if (typeof options.showwmstitle !== "undefined") {
+ showwmstitle = options.showwmstitle;
+Mapbender.events.afterMapRequest.register(function (obj) {
+ mod_legend_pos(obj.map.elementName)
+$this.append($(
+ $this.css({
+ top: options.top + mod_legend_offsetTop,
+ left: options.left + options.width + mod_legend_offsetLeft
+ checkobj.style.display = "none";
+ checkobj.style.width = 0;
+ checkobj.style.height = 0;
+function mod_legend_repaint(obj) {
+ if (checkobj.style.display == "block") {
+ mod_legend_pos();
+function mod_legend_pos(frameName){
+ if (frameName !== options.target[0]) {
+ return;
+ var ind = getMapObjIndexByName(options.target[0]);
+ var obj = document.getElementById(options.id + "_leg");
+ if (stickylegend) {
+ obj.style.left = parseInt(
+ mb_mapObj[ind].getWidth() +
+ options.left +
+ mod_legend_offsetLeft,
+ 10
+ if (!$("#" + options.id + "_checkboxstyle > input").attr("checked")){
+ $("#" + options.id + "_leg").empty();
+ return;
+ var str = "";
+ var str_tmp = "";
+ for(var i=0; i<mb_mapObj[ind].wms.length; i++){
+ var layerNames = mb_mapObj[ind].wms[i].getLayers(mb_mapObj[ind]);
+ var layerParent = mb_mapObj[ind].wms[i].checkLayerParentByLayerName(layerNames[j]);
+ var layerTitle = mb_mapObj[ind].wms[i].getTitleByLayerName(layerNames[j]);
+ var layerStyle = mb_mapObj[ind].wms[i].getCurrentStyleByLayerName(layerNames[j]);
+ legendUrl = mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layerNames[j],"");
+ else{
+ legendUrl = mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layerNames[j],layerStyle);
+ if (showlayertitle) {
+ if(legendlink){
+ if (legendlink){
+ if(str_tmp !=''){
+ if (showwmstitle){
+ "</span></div>";
+ str += str_tmp;
+ str_tmp ='';
+ if (str !== "") {
+ $("#" + options.id + "_leg").html(str);
+ else{
+ return true;
Modified: branches/jqMapbender/mapstraction/http/plugins/ui_accordion.js
--- branches/jqMapbender/mapstraction/http/plugins/ui_accordion.js 2009-11-01 12:41:27 UTC (rev 4898)
+++ branches/jqMapbender/mapstraction/http/plugins/ui_accordion.js 2009-11-01 17:53:15 UTC (rev 4899)
@@ -1,10 +1,56 @@
+ * Package: ui_accordion
+ * Description:
+ * An accordion decorator, replaces the deprecated element "tabs"
+ * Enter the elements to be put in the accordion in its target field
+ * (comma-separated list of element ids).
+ * Avoid styles in elements within the accordion.
+ * The overview won't work in the accordion, as it cannot be positioned
+ * absolutely.
+ * The width of this module determines the accordion width, but the height
+ * of the individual elements determines the height.
+ * Files:
+ * - http/plugins/ui_accordion.js
+ * - http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/ui.accordion.js
+ * SQL:
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES('gui','ui_accordion',2,1,
+ * > 'An accordion decorator, replaces the deprecated element tabs','','div',
+ * > '','',10,240,300,NULL ,2,'','','div','../plugins/ui_accordion.js',
+ * > '../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/ui.accordion.js',
+ * > '','','http://docs.jquery.com/UI/Accordion');
+ * Help:
+ * http://docs.jquery.com/UI/Accordion
+ * Maintainer:
+ * http://www.mapbender.org/User:Christoph_Baudson
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
$this = $(this);
-var selectorArray = [];
+// tab to open onload
+var active = typeof options.active !== "number" ?
+ false : options.active - 1;
for (var i = 0; i < options.target.length; i++) {
- var selector = "#" + options.target[i];
- $c = $(selector);
+ $c = $("#" + options.target[i]);
$this.append(
"<h3><a id='header_" + options.id + "_" + $c.attr("id") +
@@ -22,13 +68,8 @@
-//Mapbender.events.localize.register(function () {
-// $(".ui-" + options.id).each(function () {
-// $("#header_" + options.id + "_" + this.id)
$("#" + options.id).accordion({
collapsible: true,
- autoHeight: false
+ autoHeight: false,
+ active: active
Added: branches/jqMapbender/mapstraction/http/plugins/ui_portlet.js
--- branches/jqMapbender/mapstraction/http/plugins/ui_portlet.js (rev 0)
+++ branches/jqMapbender/mapstraction/http/plugins/ui_portlet.js 2009-11-01 17:53:15 UTC (rev 4899)
@@ -0,0 +1,75 @@
+ * Description:
+ * absolutely.
+ * Files:
+ * SQL:
+ * Help:
+ * Maintainer:
+ * License:
+$this = $(this);
+for (var i = 0; i < options.target.length; i++) {
+ $this.append(
+ "<h3><a id='header_" + options.id + "_" + $c.attr("id") +
+ "' href='#'>" + Mapbender.modules[$c.attr("id")].currentTitle +
+ "</a></h3>"
+ ).append(
+ "<div></div>"
+ ).append(
+ "<div style='height:" + $c.css("height") + "'></div>"
+ ).append($c)
+$("#" + options.id).accordion({
+ collapsible: true,
+ active: active
More information about the Mapbender_commits
